    4. Kein Zugriff auf Admin Oberfläche
    • joergfrde
      joergfrde last edited by
      Greenlock and ACME.js v3 are on the way!
      Watch for updates at https://indiegogo.com/at/greenlock
      npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      • iobroker.js-controller@2.3.0
        added 392 packages from 735 contributors in 112.079s
      7 packages are looking for funding
      run npm fund for details
      Scheinbar keine Fehler. Aber Admin funktioniert immer noch nicht.
      joergfrde Homoran 2 Replies Last reply Reply Quote 0
      • joergfrde
        joergfrde @joergfrde last edited by
        Statusabfrage bringt jetzt das.
        pi@raspberrypi:/opt/iobroker $ iobroker status
        At least one iobroker host is running.
        Objects type: file
        States type: file
          Homoran Global Moderator Administrators @joergfrde last edited by
          @joergfrde sagte in Kein Zugriff auf Admin Oberfläche:
          wo hast du den npm Befehl ausgeführt?
          hattest du vorher ins Installationsverzeichnis gewechselt?
          Was sagt iobroker list instances ?
          joergfrde 3 Replies Last reply Reply Quote 0
          • joergfrde
            joergfrde @Homoran last edited by Homoran
            @Homoran In /opt/iobroker
            pi@raspberrypi:/opt/iobroker $ iobroker list instances
            + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                : alexa2                -  enabled
              system.adapter.backitup.0              : backitup              -  enabled
              system.adapter.daswetter.0             : daswetter             -  enabled
              system.adapter.devices.0               : devices               -  enabled
            + system.adapter.discovery.0             : discovery             -  enabled
              system.adapter.dwd.0                   : dwd                   -  enabled
            + system.adapter.egigeozone.0            : egigeozone            -  enabled, port: 7654
            + system.adapter.email.0                 : email                 -  enabled
              system.adapter.exchangerates.0         : exchangerates         -  enabled
            + system.adapter.fritzbox.0              : fritzbox              -  enabled
            + system.adapter.fritzdect.0             : fritzdect             -  enabled
              system.adapter.fullcalendar.0          : fullcalendar          -  enabled
            + system.adapter.geofency.0              : geofency              -  enabled, port: 7999
            + system.adapter.harmony.0               : harmony               -  enabled
            + system.adapter.hm-rega.0               : hm-rega               -  enabled
            + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
              system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 0
              system.adapter.hm-rpc.2                : hm-rpc                -  enabled, port: 0
              system.adapter.hm-rpc.3                : hm-rpc                -  enabled, port: 0
            + system.adapter.homee.0                 : homee                 -  enabled
              system.adapter.ical.0                  : ical                  -  enabled
            + system.adapter.info.0                  : info                  -  enabled
              system.adapter.javascript.0            : javascript            -  enabled
              system.adapter.lifx.0                  : lifx                  -  enabled
            + system.adapter.meross.0                : meross                -  enabled
            + system.adapter.paw.0                   : paw                   -  enabled, port: 8898
            + system.adapter.pushover.0              : pushover              -  enabled
            + system.adapter.radar2.0                : radar2                -  enabled
              system.adapter.rpi2.0                  : rpi2                  -  enabled
              system.adapter.sayit.0                 : sayit                 -  enabled
            + system.adapter.shelly.0                : shelly                -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.sony-bravia.0           : sony-bravia           -  enabled
            + system.adapter.tankerkoenig.0          : tankerkoenig          -  enabled
            + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
              system.adapter.telegram.1              : telegram              - disabled, port: 8443, bind: 0.0.0.0
              system.adapter.text2command.0          : text2command          -  enabled
              system.adapter.tr-064.0                : tr-064                -  enabled
              system.adapter.trashschedule.0         : trashschedule         -  enabled
              system.adapter.vis-bars.0              : vis-bars              -  enabled
              system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
              system.adapter.vis-map.0               : vis-map               -  enabled
              system.adapter.vis-weather.0           : vis-weather           -  enabled
              system.adapter.vis.0                   : vis                   -  enabled
              system.adapter.weatherunderground.0    : weatherunderground    -  enabled
              system.adapter.web.0                   : web                   - disabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.yr.0                    : yr                    -  enabled
            + instance is alive
            MOD-EDIT: Code in Code-Tags gesetzt
            • joergfrde
              @Homoran Muß mich korrigieren, Admin läuft wieder, Danke
              • joergfrde
                @Homoran Aber was mache ich mit meienm Admin Adapter. Ich habe hier im Forum von Fehlern nach dem Update gelesen. Mir wird jetzt ein Update von 3.7.7 auf 4.0.1 angeboten. Muß ich dabei etwas beachten?
                Homoran AlCalzone 2 Replies Last reply Reply Quote 0
                  Dazu sind Foren da - User mit Problemen melden sich, User ohne Probleme sagen nichts
                    sigi234 Forum Testing Most Active @Homoran last edited by
                    @Homoran sagte in Kein Zugriff auf Admin Oberfläche:
                    oder helfen Usern mit Problemen. 😀
                    • AlCalzone
                      AlCalzone Developer @joergfrde last edited by
                      Changelog des Admin-Adapters (und Web und Socket.io) lesen und verstehen!
                      Ein Major Version Update bedeutet immer, dass danach etwas nicht mehr geht (muss dich aber nicht betreffen).
                      joergfrde 1 Reply Last reply Reply Quote 0
                      • joergfrde
                        joergfrde @AlCalzone last edited by
                        @AlCalzone Hat ohne Probleme funktioniert, danke
                        • N
                          nousefor82 last edited by nousefor82
                          ich komme auch nicht mehr auf die Admin Oberfläche.
                          Ich habe gestern den Admin upgedatet.
                          C:\Users\Jörg\ioBroker>node -v
                          v10.19.0
                          C:\Users\Jörg\ioBroker>npm -v
                          6.4.1
                          C:\Users\Jörg\ioBroker> npm install iobroker.js-controller
                          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                          npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                          > iobroker.js-controller@1.5.14 preinstall C:\Users\Jörg\ioBroker\node_modules\iobroker.js-controller
                          > node lib/preinstallCheck.js
                          NPM version: 6.4.1
                          npm version >= 5: disabling package-lock
                          > unix-dgram@0.2.3 install C:\Users\Jörg\ioBroker\node_modules\unix-dgram
                          > node-gyp rebuild
                          C:\Users\Jörg\ioBroker\node_modules\unix-dgram>if not defined npm_config_node_gyp (node "C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
                          gyp ERR! configure error
                          gyp ERR! stack Error: Can't find Python executable "python2.7", you can set the PYTHON env variable.
                          gyp ERR! stack     at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:484:19)
                          gyp ERR! stack     at PythonFinder.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:509:16)
                          gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29
                          gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:153:21)
                          gyp ERR! System Windows_NT 10.0.17763
                          gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
                          gyp ERR! cwd C:\Users\Jörg\ioBroker\node_modules\unix-dgram
                          gyp ERR! node -v v10.19.0
                          gyp ERR! node-gyp -v v3.8.0
                          gyp ERR! not ok
                          > iobroker.js-controller@1.5.14 install C:\Users\Jörg\ioBroker\node_modules\iobroker.js-controller
                          > node iobroker.js setup first
                          npm WARN enoent ENOENT: no such file or directory, open 'C:\Users\Jörg\ioBroker\node_modules\tmp\package.json'
                          npm WARN enoent ENOENT: no such file or directory, open 'C:\Users\Jörg\ioBroker\node_modules\iobroker.zigbee\node_modules\cc-znp\package.json'
                          npm WARN ws@7.2.1 requires a peer of bufferutil@^4.0.1 but none is installed. You must install peer dependencies yourself.
                          npm WARN ws@7.2.1 requires a peer of utf-8-validate@^5.0.2 but none is installed. You must install peer dependencies yourself.
                          npm WARN onvif-snapshot@1.0.2 requires a peer of onvif@^0.5.5 but none is installed. You must install peer dependencies yourself.
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules\osx-temperature-sensor):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules\unix-dgram):
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                          + iobroker.js-controller@1.5.14
                          added 35 packages from 20 contributors, removed 173 packages, updated 40 packages, moved 15 packages and audited 833 packages in 77.298s
                          found 17 vulnerabilities (11 low, 6 high)
                            run `npm audit fix` to fix them, or `npm audit` for details
                          C:\Users\Jörg\ioBroker>node node_modules/iobroker.js-controller/controller.js --logs
                          2020-02-12 21:47:34.750  - info: host.DESKTOP-P9BVQ1I iobroker.js-controller version 1.5.14 js-controller starting
                          2020-02-12 21:47:34.756  - info: host.DESKTOP-P9BVQ1I Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
                          2020-02-12 21:47:34.757  - info: host.DESKTOP-P9BVQ1I hostname: DESKTOP-P9BVQ1I, node: v10.19.0
                          2020-02-12 21:47:34.772  - info: host.DESKTOP-P9BVQ1I ip addresses: 2002:bcc2:441c:0:65e2:1607:2b76:8b96 2002:bcc2:441c:0:9ce6:2d48:78e4:d66b fe80::65e2:1607:2b76:8b96 192.168.188.60
                          2020-02-12 21:47:35.166  - info: host.DESKTOP-P9BVQ1I  inMem-states listening on port 9000
                          2020-02-12 21:47:36.256  - info: host.DESKTOP-P9BVQ1I  inMem-objects listening on port 9001
                          2020-02-12 21:47:36.272  - error: Another instance is running or some application uses port!
                          2020-02-12 21:47:36.274  - error: uncaught exception: listen EADDRINUSE: address already in use 127.0.0.1:9000
                          2020-02-12 21:47:36.286  - info: host.DESKTOP-P9BVQ1I terminated
                          2020-02-12 21:47:36.331  - info: iobroker _restart
                          2020-02-12 21:47:36.353  - info: host.DESKTOP-P9BVQ1I InMemoryDB connected
                          2020-02-12 21:47:36.496  - info: host.DESKTOP-P9BVQ1I 66 instances found
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.admin.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.discovery.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.web.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.vis.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.hue.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-hqwidgets.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.lupusec.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.javascript.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.alexa2.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.cloud.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.daswetter.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.tr-064.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.yr.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.dwd.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-jqui-mfd.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-weather.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.sonos.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.sayit.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.feiertage.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.spotify-premium.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-timeandweather.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-colorpicker.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.ical.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.shelly.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.pushover.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.yamaha.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.telegram.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.text2command.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-players.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.mihome-vacuum.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.harmony.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-metro.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-fancyswitch.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-history.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-google-fonts.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.ical.1" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.javascript.1" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.synology.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.hm-rpc.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.hm-rega.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.hm-rpc.1" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.fullybrowser.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-justgage.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.unifi.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.node-red.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.backitup.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.pollenflug.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.info.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.zigbee.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.mihome.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.iqontrol.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.iot.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.onvif.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.trashschedule.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.parser.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.ical.2" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.simple-api.0" for host "DESKTOP-P9BVQ1I"
                          host.DESKTOP-P9BVQ1I check instance "system.adapter.yahka.0" for host "DESKTOP-P9BVQ1I"
                          2020-02-12 21:47:36.829  - info: host.DESKTOP-P9BVQ1I starting 55 instances
                          listen EADDRINUSE: address already in use 127.0.0.1:9001
                          Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
                              at Server.setupListenHandle [as _listen2] (net.js:1280:14)
                              at listenInCluster (net.js:1328:12)
                              at doListen (net.js:1461:7)
                              at process._tickCallback (internal/process/next_tick.js:63:19)
                              at Function.Module.runMain (internal/modules/cjs/loader.js:834:11)
                              at startup (internal/bootstrap/node.js:283:19)
                              at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                          System: Win10
                          Mit der Bitte um Hilfe,
                          Jörg!
                          mikeal created this issue in request/request
                          open Request’s Past, Present and Future #3142
                          • AlCalzone
                            AlCalzone Developer @nousefor82 last edited by
                            @nousefor82 sagte in Kein Zugriff auf Admin Oberfläche:
                            ==> https://www.npmjs.com/package/windows-build-tools installieren.
                            • N
                              nousefor82 @AlCalzone last edited by
                              @AlCalzone
                              Servus, danke.
                              Leider hat "der" hingeschrieben, dass python bereits installiert ist.
                              Auf 8081 lässt sich immer noch nicht zugreifen.
                              VG
                              • N
                                Noch jemand eine Idee, woran es liegen könnte, dass ich plötzlich nicht mehr auf die Admin Oberfläche zugreifen kann?
                                  arteck Developer Most Active @nousefor82 last edited by
                                  @nousefor82 du hast eine manell installierte iobroker version.. da können wir lange suchen..
                                  nimm den installer und portiere deine jetzige in die neue rein.. fertig
                                  • N
                                    nousefor82 @arteck last edited by nousefor82
                                    @arteck
                                    hab ich probiert...wurde mit eine Fehlermeldung beendet:
                                    Fehler beim Ausführen eines Post - Installationsschrittes.
                                    Die Installation wird möglicherweise nicht korrekt abgeschlossen.
                                    Kritischer Installationsfehler. Keine aktive ioBroker Admin-Instanz auf Port 8091.
                                    Abbruch der Installation.
                                    Danke!
                                    • N
                                      Oh Mann...das nervt grad.
                                      Ich habe mal gelesen, dass man über die objects.json die scripte extrahieren kann.
                                      Habe das mal probiert bin mir aber nicht sicher, von wo bis wo die im code aktuell gehen, bzw. was ich da kopieren muss.
                                      Ein Neuinstallation läuft durch...hab dann probiert über backitup ein backup einzuspielen (Stand, bei dem noch alles funktioniert hatte), jetzt komm ich auch nicht mehr auf die neue Admin - Oberfläche.
                                      Noch jemand eine Idee, wie ich auf die 8081 kommen könnte?
                                      Vielen Dank!
                                      • N
                                        So, komme wieder drauf...weiß nur nicht warum.
                                        Habe folgendes eingegeben mit nachfolgenden Fehlermeldungen...trotzdem kann ich wieder zugreifen...
                                        C:\Users\Jörg\ioBroker>iobroker stop
                                        C:\Users\Jörg\ioBroker>node node_modules/iobroker.js-controller/iobroker.js stop
                                        iobroker controller daemon is not running
                                        C:\Users\Jörg\ioBroker>ps auxww|grep io
                                        Der Befehl "ps" ist entweder falsch geschrieben oder
                                        konnte nicht gefunden werden.
                                        C:\Users\Jörg\ioBroker>iobroker upgrade self
                                        C:\Users\Jörg\ioBroker>node node_modules/iobroker.js-controller/iobroker.js upgrade self
                                        Update js-controller from @1.5.14 to @2.2.8
                                        NPM version: 6.4.1
                                        npm install iobroker.js-controller@2.2.8 --unsafe-perm --production --save --prefix "C:/Users/Jörg/ioBroker" (System call)
                                        npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
                                        gyp ERR! cwd C:\Users\Jörg\ioBroker\node_modules\iobroker.js-controller\node_modules\unix-dgram
                                        gyp ERR! not ok
                                        gyp ERR! cwd C:\Users\Jörg\ioBroker\node_modules\iobroker.js-controller\node_modules\diskusage
                                        gyp ERR! not ok
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules\iobroker.js-controller\node_modules\fsevents):
                                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.3 (node_modules\iobroker.js-controller\node_modules\unix-dgram):
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.3 install: `node-gyp rebuild`
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@1.1.3 (node_modules\iobroker.js-controller\node_modules\diskusage):
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@1.1.3 install: `node-gyp rebuild`
                                        Host "DESKTOP-P9BVQ1I" (win32) updated
                                        Starting node restart.js
                                        C:\Users\Jörg\ioBroker>iobroker upgrade admin
                                        C:\Users\Jörg\ioBroker>node node_modules/iobroker.js-controller/iobroker.js upgrade admin
                                        Adapter "admin"          is not installed.
                                        C:\Users\Jörg\ioBroker>iobroker install admin
                                        C:\Users\Jörg\ioBroker>node node_modules/iobroker.js-controller/iobroker.js install admin
                                        adapter "admin" already installed. Use "upgrade" to upgrade to a newer version.
                                        • N
                                          Das war wohl nix....kein Zugriff mehr möglich. Aber solang ich den Zugriff hatte, habe ich per Hand sämtliche Scripte etc. gesichert.
                                          Habe nun komplett neu installiert. LEider noch die Version 1.5.14 .... trau mich nicht mehr mir
                                          abzudaten...
                                          • rweise
                                            rweise last edited by rweise
                                            Bei mir 2 Installationen mit 7.2.1 kein Zugriff mehr. Der IOBroker hat aber im Hintergrund anstandslos gearbeitet. Die Lösung war ein Downgrade zu 7.2.0. hat auf beiden Geräten fuktioniert. Natürlich dann in der Konsole.
                                            1. cd /opt/iobroker
                                            2. iobroker stop
                                            3. npm install iobroker.admin@7.2.0 --production
                                            4. iobroker start
                                            und schon ging es wieder 🙂
                                            Ähm, hab es erst außerhalb von /opt/iobroker versucht. Dann macht er aber kein Downgrade...
                                            admin
                                            2348
