    4. Material Design Widgets: Table Widget
    • Scrounger
      Scrounger Developer last edited by Scrounger
      Hab das ical2Table skript nochmal überarbeitet:
      • nun werden alle ical instanzen berücksichtigt
      • Sortierung nach Zeit aufsteigend hinzugefügt
      var instances = $(`[id=ical.*.data.table]`);
      instances.on(ical2TableWidget);
      function ical2TableWidget() {
          try {
              let calList = [];
              for (var inst = 0; inst <= instances.length - 1; inst++) {
                  let icalObj = getState(instances[inst]).val;
                  if (icalObj) {
                      for (var i = 0; i <= icalObj.length - 1; i++) {
                          let item = icalObj[i];
                          let calendarName = item._class.split(' ')[0].replace('ical_', '');
                          // Objekt für Tabelle erzeugen
                          calList.push({
                              farbe: `<div style="background: ${getMyCalendarColor(calendarName)}; width: 3px; height: 20px"></div>`,
                              zeit: item.date,
                              termin: item.event,
                              kalender: calendarName,
                              timestamp: Date.parse(item._date)
              // Liste sort by timestamp asc
              calList.sort(function (a, b) {
                  return a.timestamp == b.timestamp ? 0 : +(a.timestamp > b.timestamp) || -1;
              // Enter the destination data point that is to be used as object ID in the widget
              setState('0_userdata.0.ical', JSON.stringify(calList), true);
              function getMyCalendarColor(calendarName) {
                  // assign colors via the calendar names, use calendar name as set in ical
                  if (calendarName === 'calendar1') {
                      return '#FF0000';
                  } else if (calendarName === 'calendar2') {
                      return '#44739e'
                  } else if (calendarName === 'calendar3') {
                      return '#32a852'
          } catch (e) {
              console.error(`ical2MaterialDesignTableWidget: message: ${e.message}, stack: ${e.stack}`);
      ical2TableWidget();
      Widget:
      [{"tpl":"tplVis-materialdesign-Table","data":{"oid":"0_userdata.0.ical","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","countCols":"3","tableLayout":"standard","showHeader":"true","headerTextSize":"headline6","showColumn0":"true","colType0":"text","textAlign0":"left","showColumn1":"true","colType1":"text","textAlign1":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"showColumn2":"true","colType2":"text","textAlign2":"left","showColumn3":"true","colType3":"text","textAlign3":"left","label0":" ","label1":"Zeit","label2":"Termin","label3":"Kalender","columnWidth0":"0","sortKey1":"timestamp"},"style":{"left":"163px","top":"67px","width":"692px","height":"480px"},"widgetSet":"materialdesign"}]
      ub.privat F R 0 4 Replies Last reply Reply Quote 0
        Machinima last edited by Machinima
        Momentan bietet ja das Widget einen rein lesenden Zugriff auf die Werte. Ist das möglich, bei boolschen Werten ein Switch-Schalter einzubauen, sodass man Datenpunkte direkt aus dem Widget heraus steuern kann?
        Vergiss die Frage. Das List Widget bietet genau das, was ich suche 🙄
        • ub.privat
          ub.privat @Scrounger last edited by
          @Scrounger
          ich mal wieder,,,
          Kämpfe mich gerade mit deinem(deinen) Scripten ab.
          Weder beim ical2TableWidget, noch beim ical2CalendarWidget wird unter 0_userdata.0 ein entsprechender Datenpunkt angelegt.
          Mehr gibt's da nicht:
          Habe bereits die entsprechenden Scripte im root oder common-Verzeichnis angelegt - ohne Erfolg.
          Es werden im debug-Modus auch keine Fehler ausgegeben.
          Gibt's da noch einen "Trick" oder etwa szu beachten???
          Bin über jeden Hinweis dankbar, denn nur so lernt man...
          • Scrounger
            Scrounger Developer @ub.privat last edited by
            @ub-privat
            Du musst den Ziel Datenpunkt selbst anlegen.
            Und ggf. im Skript anpassen falls du die Struktur änderst
            ub.privat 1 Reply Last reply Reply Quote 0
            • ub.privat
              @Scrounger
              Danke für deine Antwort,
              Ändern werde ich nichts, kämpfe mich quasi durch...
              Hier der DP
              Bin mir nur nicht bei den Einstellungen sicher:
              Typ = state
              Rolle = json
              Für das Calendar-Widget ist der DP im Script für mich verständlich.
              Aber im Script für Table einfach nur ical???
              Hier wird nur auf den Ordner iCal verwiesen?
              • Scrounger
                Scrounger Developer @ub.privat last edited by Scrounger
                @ub-privat
                Ich hab den halt 0_userdata.0.ical genannt, kannst den benennen wie du willst.
                Btw das ist kein Ordner, weil es gibt keine ordner in iob.
                  bommel_030 last edited by bommel_030
                  @Scrounger
                  Spiele gerade mit deinem Tabellenwidget und einer JSON-Liste aus dem fb-checkpresence Adapter.
                  Dabei kamen mir folgende Fragen:
                  1. Ist es möglich die Spaltenüberschrift, die im JSON ja vorhanden ist, automatisch in die Felder Beschriftung zu übernehmen? Gerne optional, wenn man den Titel mal ändern will.
                  2. Kannst du analog zum HTML Widget Titel und Untertitel hinzufügen?
                  3. Ich habe eine Spalte mit IP Adressen, wobei die erste Blöcke alle identisch sind. Beim sortieren ist bei ihm die Reihenfolge xxx.xxx.xxx.1, xxx.xxx.xxx.100, xxx.xxx.xxx.11. Grundsätzlich verständlich, weil für ihn die 0 vor der 1 kommt. Schöner wäre natürlich .1, .11, .100. Kann man das irgendwie anpassen?
                  4. Wenn ich die Höhe der Tabelle festlege und in Y-Richtung scrolle, kann man die Überschriften fixieren? Quasi wie Wiederholbereich / Fenster fixieren in der Office Welt.
                  Scrounger 2 Replies Last reply Reply Quote 0
                  • Scrounger
                    Scrounger Developer @bommel_030 last edited by Scrounger
                    @bommel_030 sagte in Material Design Widgets: Table Widget:
                    Ja das geht wenn du deinen json string dynamisch per skript erstellst.
                    1. Kannst du analog zum HTML Widget Titel und Untertitel hinzufügen?
                    Versteh ich nicht, Beispiel am besten nen Scrennshot oder Mockup.
                    1. Ich habe eine Spalte mit IP Adressen, wobei die erste Blöcke alle identisch sind. Beim sortieren ist bei ihm die Reihenfolge xxx.xxx.xxx.1, xxx.xxx.xxx.100, xxx.xxx.xxx.11. Grundsätzlich verständlich, weil für ihn die 0 vor der 1 kommt. Schöner wäre natürlich .1, .11, .100. Kann man das irgendwie anpassen?
                    Sorry das ist zu speziell. Das kannst du auch über dynamisch erzeugten json string per skript realisieren, musst dann halt die .00x hinzufügen.
                    1. Wenn ich die Höhe der Tabelle festlege und in Y-Richtung scrolle, kann man die Überschriften fixieren? Quasi wie Wiederholbereich / Fenster fixieren in der Office Welt.
                    Tja das hätte ich auch gerne 😉
                    Hab aber leider keine Ahnung wie man das mit ner <table> per css realisiert.
                      @Scrounger
                      Meine Programmierkenntnisse sind größtenteils copy&paste und try&error... Kann daher sein, dass meine Gedankengänge aus Entwicklersicht sinnfrei sind...
                      1. Ich habe einen JSON den ich mir selber per Skript erstelle:
                      [{"Raum":"Wohnzimmer","Temperatur":"20.4 °C","Luftfeuchte":"62%","Ventilstand":"0%","Fenster":["geschlossen","\ngeschlossen"],"Lüften":true,"Zustand":"Bedingungen für Entfeuchten, Kühlen und Auskühlschutz erfüllt."},{"Raum":"Schlafzimmer","Temperatur":"19.8 °C","Luftfeuchte":"62%","Ventilstand":"0%","Fenster":"geschlossen","Lüften":true,"Zustand":"Bedingungen für Entfeuchten, Kühlen und Auskühlschutz erfüllt."},{"Raum":"K1","Temperatur":"20.3 °C","Luftfeuchte":"62%","Ventilstand":"0%","Fenster":"geschlossen","Lüften":true,"Zustand":"Bedingungen für Entfeuchten, Kühlen und Auskühlschutz erfüllt."},{"Raum":"K2","Temperatur":"20.6 °C","Luftfeuchte":"62%","Ventilstand":"0%","Fenster":"geschlossen","Lüften":true,"Zustand":"Bedingungen für Entfeuchten, Kühlen und Auskühlschutz erfüllt."}]
                      Und einen der aus dem fb-checkpresence kommt:
                      [{"Name":"M","Active":"false","Kommt":"10.02.2020 07:16:33","Geht":"11.02.2020 07:26:33"},{"Name":"F","Active":"false","Kommt":"11.02.2020 05:01:33","Geht":"11.02.2020 06:33:33"},{"Name":"K1","Active":"false","Kommt":"11.02.2020 06:00:33","Geht":"11.02.2020 07:52:33"}]
                      Bei beiden ist nach meinem Verständnis die Spaltenüberschrift drin, wird aber nicht übernommen.
                      1. Mal so eben zusammengeklimpert...
                        Im HTML Widget habe ich die Möglichkeit Titel, Untertitel und Inhalt einzugeben. Beim Tabellenwidget quasi analog, nur statt dem HTML-Inhalt die Tabelle.
                        Und dann noch die Option nur der Tabelle das Scrollen in y-Richtung erlauben...
                      2. Ist klar, kann ich mit leben.
                      3. Wenn man quasi ein Widget wie unter 2) hat und sozusagen die Tabelle zweimal drin hat, die obere nur die Zeilenüberschriften, die untere nur den Tabelleninhalt ohne Zeilenüberschriften. Wenn die Spaltenbreiten bei beiden dann gekoppelt sind, könnte ich die Daten in der unteren scrollen und die obere behält die Überschriften an der fixen Position.
                      • Scrounger
                        Spalten Überschrift wird nicht aus dem JSON übernommen, sondern muss per Editor konfiguriert werden.
                        Achso du meinst das Html Card Widget und nicht das Html Widget.
                        Nimm das Html Card Widget und leg die Tabelle drüber, dann hast titel, Image, etc. also genau das was du suchst.
                        1. Wenn man quasi ein Widget wie unter 2) hat und sozusagen die Tabelle zweimal drin hat, die obere nur die Zeilenüberschriften, die untere nur den Tabelleninhalt ohne Zeilenüberschriften. Wenn die Spaltenbreiten bei beiden dann gekoppelt sind, könnte ich die Daten in der unteren scrollen und die obere behält die Überschriften an der fixen Position.
                        ist ne Möglichkeit, aber dann funktioniert das sortieren halt nicht.
                          sigi234 Forum Testing Most Active @Scrounger last edited by
                          @Scrounger
                          Hallo, kann ich die Anzahl der Zeilen begrenzen?
                            @Scrounger
                            Hallo, noch immer weis ich nicht wie ich die Reihenfolge der Col ändere?
                            (Objektname zum sortieren?)
                            • Scrounger
                              @sigi234 sagte in Material Design Widgets: Table Widget:
                              @Scrounger
                              @Scrounger
                              Geht beides indem du die Reihenfolge im json Objekt änderst und die Anzahl der Objekte dort begrenzt.
                              Beispiel Ausgangssituation
                              		"img": "/vis.0/myImages/erlebnis_50.png",
                              		"name": "Empire",
                              		"betriebszeit": "4h 06m",
                              		"funk": "5G",
                              		"ip": "10.0.0.1"
                              		"img": "/vis.0/myImages/erlebnis_100.png",
                              		"name": "Handy",
                              		"betriebszeit": "13m",
                              		"funk": "5G",
                              		"ip": "10.0.0.2"
                              		"name": "Harmony Hub - Wohnzimmer",
                              		"betriebszeit": "18T 07h 21m",
                              		"funk": "2G",
                              		"ip": "10.0.0.3"
                              		"img": "/vis.0/myImages/erlebnis_25.png",
                              		"name": "MusicCast - Esszimmer (WX-030)",
                              		"betriebszeit": "1h 57m",
                              		"funk": "2G",
                              		"ip": "10.0.0.4"
                              		"img": "/vis.0/myImages/erlebnis_75.png",
                              		"name": "MusicCast - K�che (ISX-18D)",
                              		"betriebszeit": "4h 10m",
                              		"funk": "2G",
                              		"ip": "10.0.0.5"
                              geänderte Reihenfolge:
                              		"funk": "5G",
                              		"name": "Empire",
                              		"ip": "10.0.0.1"
                              		"funk": "5G",
                              		"name": "Handy",
                              		"ip": "10.0.0.2"
                              		"funk": "2G",
                              		"ip": "10.0.0.3"
                              		"funk": "2G",
                              		"ip": "10.0.0.4"
                              		"funk": "2G",
                              		"ip": "10.0.0.5"
                              auf drei Zeilen bergrenzt
                              		"funk": "5G",
                              		"name": "Empire",
                              		"ip": "10.0.0.1"
                              		"funk": "5G",
                              		"name": "Handy",
                              		"ip": "10.0.0.2"
                              		"funk": "2G",
                              		"ip": "10.0.0.3"
                                calliou1234 last edited by
                                Hallo Zusammen,
                                ich baue mir in einem Skript ein JSON zusammen.
                                Nun würde ich gerne einzelne Felder in unterschiedlichen Farben in Anhängigkeit eines Objekt anzeigen lassen.
                                Kann man dies mit einbauen? Wenn ja wie?
                                Aktuell zeige ich den Wert in einem html_Basic an und unter Farbe mit dem Binding
                                {co2:netatmo.0.Indoor.Indoor.CO2.CO2; co2 <= 1000 ? "lime" : co2 <= 1300 ? "orange" : "red"}
                                Thomas
                                  ich habe noch ein Thema wo ich Hilfe bräuchte.
                                  Ich möchte in der 2. Spalte auch ein Bild platzieren.
                                  Nur leider funktioniert das nicht.
                                  Es wird immer nur ein bild in der ersten Spalte angezeigt.
                                  Wenn ich das Bild für die 2. Spalte in das JSON hänge wird es in der ersten angezeigt.
                                  Mein JSON sieht so aus:
                                  {"img":"/vis.0/main/img/icons8-Thermometer-48.png",
                                  "img":"/vis.0/Materialicons/baseline_trending_up_white_18dp.png"
                                  • Scrounger
                                    Scrounger Developer @calliou1234 last edited by
                                    @calliou1234
                                    Das Objekt darf nicht indentische namen bei der property haben, so geht es:
                                    		"img2": "/vis.0/myImages/erlebnis_100.png"
                                    Und für Spalte einstellen das es ein Bild ist:
                                      liv-in-sky @calliou1234 last edited by
                                      @calliou1234 sagte in Material Design Widgets: Table Widget:
                                      @Scrounger
                                      ich würde gerne nochmal diese frage in den raum werfen - wie bekome ich dynamisch ein textfeld in einer bestimmten farbe (abhängig von einem wert im script)
                                      als beispiel
                                      • Scrounger
                                        Scrounger Developer @liv-in-sky last edited by
                                        @liv-in-sky
                                        Du kannst HTML tags verwenden.
                                        Z.b. kannst du den Text in <font color="red">mein Text</font> packen, dann ist der Text rot.
                                        Und damit geht noch viel mehr, könntest so zb einen ganze Tabelle in eine einzelne Zelle packen.
                                        • Uwe Clement
                                          Uwe Clement last edited by Uwe Clement
                                          @Scrounger
                                          Habe 2 Fragen:
                                          1. Frage wurde zwar schon oben gestellt, die Antwort darauf hat mir allerdings nicht geholfen: Wie schaffe ich es, dass die Überschriften aus dem JSON genommen werden (ich stelle das JSON per Datenpunkt bereit)
                                          2. Ist es möglich in einer Zelle auch einen Button/Bild darzustellen und beim Klick irgendwas (Event) ausgelöst wird, z.B. mein Shelly geschalten wird. Kann ich bestenfalls eine function aufrufen?
                                          • Scrounger
                                            Scrounger Developer @Uwe Clement last edited by Scrounger
                                            @Uwe-Clement sagte in Material Design Widgets: Table Widget:
                                            Geht nicht.
                                            1. Ist es möglich in einer Zelle auch einen Button/Bild darzustellen und beim Klick irgendwas (Event) ausgelöst wird, z.B. mein Shelly geschalten wird. Kann ich bestenfalls eine function aufrufen?
                                            Geht nicht. Nimm dafür besser das List Widget. Das kann man mit html tags auch zu einer Table machen. Und Funktionen wie button, checkbox, etc. kann das
                                            Uwe Clement 1 Reply Last reply Reply Quote 0
                                            vis
                                            33
                                            95
                                            15649
