    4. Test Adapter fb-checkpresence v0.2.x
      sigi234 Forum Testing Most Active @afuerhoff last edited by
      @afuerhoff sagte in Test Adapter fb-checkpresence v0.2.x:
      ich hab noch zwei json Table unter fb-devices eingebaut. Bitte nochmal aus Github aktualisieren.
      Kann man noch die Anzahl der Inaktiven Devices anzeigen?
      afuerhoff 1 Reply Last reply Reply Quote 0
      • afuerhoff
        afuerhoff Developer @sigi234 last edited by
        @sigi234 sagte in Test Adapter fb-checkpresence v0.2.x:
        Ist drin. Bitte neu von Github installieren.
        Neuschwansteini 1 Reply Last reply Reply Quote 2
        • Neuschwansteini
          Neuschwansteini @afuerhoff last edited by
          @afuerhoff
          Hi, super, vielen Dank, ging ja schnell! Funktioniert.
          Bekomme jetzt beim Starten des Adapters Fehler mit der History:
          	at tryOnImmediate (timers.js:676:5)
          history.0	2020-02-09 18:08:08.683	warn	at runCallback (timers.js:705:18)
          history.0	2020-02-09 18:08:08.683	warn	at Immediate.setImmediate [as _onImmediate] (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:227:41)
          history.0	2020-02-09 18:08:08.683	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4803:41)
          history.0	2020-02-09 18:08:08.683	warn	at Object.message (/opt/iobroker/node_modules/iobroker.history/main.js:146:25)
          history.0	2020-02-09 18:08:08.683	warn	at processMessage (/opt/iobroker/node_modules/iobroker.history/main.js:224:9)
          history.0	2020-02-09 18:08:08.683	warn	at getHistory (/opt/iobroker/node_modules/iobroker.history/main.js:812:41)
          history.0	2020-02-09 18:08:08.683	warn	(1967) TypeError: Cannot read property 'start' of undefined
          history.0	2020-02-09 18:08:08.662	warn	(1967) States system pmessage io.messagebox.system.adapter.history.0 {"command":"getHistory","message":{"result":[],"step":null,"error":null},"from":"system.adapter.fb-checkpresence.0","callback":{"m
          fb-checkpresence.0	2020-02-09 18:08:08.558	warn	(14975) Unknown command: getHistory
          fb-checkpresence.0	2020-02-09 18:08:08.557	warn	(14975) Unknown command: getHistory
          fb-checkpresence.0	2020-02-09 18:08:08.553	warn	(14975) Unknown command: getHistory
          • afuerhoff
            afuerhoff Developer @Neuschwansteini last edited by
            @ilovegym
            Den Fehler kann ich mir jetzt überhaupt nicht erklären. Kommt der jedesmal nach Start des Adapters? Kannst Du evtl. nochmal von Github installieren.
            Neuschwansteini 1 Reply Last reply Reply Quote 0
            • Neuschwansteini
              @afuerhoff kam jetzt nicht mehr... Hab nochmals von git installiert... Hmm Mal beobachten.. 🙂
              • MathiasJ
                MathiasJ last edited by
                Hier das selbe.
                Von Github drüber installiert, keine Fehler mehr.
                Sauber, hast Du das hinbekommen! 👍 👍
                  guergen last edited by guergen
                  Die Datenbankverarbeitung scheint nicht richtig zu funktionieren, habe ein Issue dazu aufgemacht...
                  • afuerhoff
                    afuerhoff Developer @guergen last edited by
                    @guergen
                    Hallo, es funktioniert so, wie ich es implementiert habe. Der Adapter legt nach Start die Einstellungen für einen Family Member fest. Wie wichtig ist für Dich der Alias?
                    Kannst Du mal den Reiter Tabelle zum Datenpunkt aus der History posten.
                      guergen @afuerhoff last edited by guergen
                      @afuerhoff Das Problem ist, dass Grafana aus der Datenbank den von FB-Presence gelieferten Daten nicht findet! In der Datenbank sind sie ja drin.
                      Wichtig ist der Alias nicht wirklich, habe nur alle Datenpunkte entsprechend benannt um Sie in Grafana schnell zu finden!
                      Hier die Einstellungen:
                      Hier die History-Einstellungen:
                      • harrym
                        harrym last edited by
                        kurze Frage bzgl. InfluxDB. Habe gerade den fb-checkpresende Adapter aus GIT installiert. InfluxDB läuft schon länger auf meinem Broker ... trotzdem hab ich da nur die Auswahl "disabled" oder "History" ?
                          guergen @harrym last edited by
                          @harrym Scroll mal...
                          harrym 1 Reply Last reply Reply Quote 0
                          • afuerhoff
                            @guergen
                            Ich meinte die Daten aus der History
                            • harrym
                              harrym @guergen last edited by
                              @guergen DANKE! da wär ein hinweis toll ^_^
                                Habe eben mit rumgespielt, daher ist da nicht viel drin
                                • afuerhoff
                                  afuerhoff Developer @guergen last edited by afuerhoff
                                  @guergen
                                  Ich frage deshalb, weil der Fehler schon mal aufgetreten ist. Dann kommt er bei dir aber wirklich durch den Alias. Es sollte dann kein History Eintrag vom Vortag vorhanden sein.
                                  Das mit dem Alias muss ich mal bei mir testen.
                                  SBorg G 2 Replies Last reply Reply Quote 0
                                  • SBorg
                                    SBorg Forum Testing Most Active @afuerhoff last edited by
                                    @afuerhoff Danke für die Integration der aktiven Devices der FB. Leider zickt die FB aber mehr rum als gedacht. Eigentlich hätte sie das Device durchgängig als aktiv erkennen müssen (SAT-Receiver, rot: Aufnahme per enigma2-Adapter, türkis: online per fb-checkpresence):
                                    • afuerhoff
                                      afuerhoff Developer @SBorg last edited by
                                      @SBorg
                                      Ich muss mal prüfen, ob das wirklich an der Fritzbox liegt. Danke für die Info.
                                      • Neuschwansteini
                                        @afuerhoff History-Adapter Error...
                                        hatte das hier schonmal angesprochen, kam damals einmal, dann war es weg.. jetzt kommt der Fehler immer, wenn ich etwas and er Config des FB-Checkpresence Adapters ändere:
                                        2020-02-12 16:40:41.667  - info: host.iobroker stopInstance system.adapter.fb-checkpresence.0 (force=false, process=true)
                                        2020-02-12 16:40:41.669  - info: host.iobroker stopInstance system.adapter.fb-checkpresence.0 send kill signal
                                        2020-02-12 16:40:42.225  - info: host.iobroker instance system.adapter.fb-checkpresence.0 terminated with code 156 (156)
                                        2020-02-12 16:40:44.975  - info: host.iobroker instance system.adapter.fb-checkpresence.0 started with pid 16504
                                        2020-02-12 16:40:47.198  - error: history.0 (14174) uncaught exception: Cannot read property 'push' of null
                                        2020-02-12 16:40:54.545  - error: fb-checkpresence.0 (16504) checkPresence: TypeError: Cannot read property 'history.0' of undefined
                                        2020-02-12 16:40:55.294  - error: fb-checkpresence.0 (16504) checkPresence: TypeError: Cannot read property 'history.0' of undefined
                                        2020-02-12 16:40:55.820  - error: fb-checkpresence.0 (16504) checkPresence: TypeError: Cannot read property 'history.0' of undefined
                                        2020-02-12 16:40:47.211  - error: history.0 (14174) TypeError: Cannot read property 'push' of null
                                            at storeCached (/opt/iobroker/node_modules/iobroker.history/main.js:182:34)
                                            at Object.objectChange (/opt/iobroker/node_modules/iobroker.history/main.js:131:21)
                                            at Immediate.options.objectChange.function.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1506:94)
                                            at processImmediate (timers.js:658:5)
                                        2020-02-12 16:41:13.873  - error: history.0 (14174) exception by stop: Cannot read property 'push' of null
                                        Sei so lieb und schau dir nochmal das starten und aufrufen von history an.. irgendwas läuft da ins leere..
                                        afuerhoff 2 Replies Last reply Reply Quote 0
                                        • afuerhoff
                                          @ilovegym
                                          Wird gemacht.
                                          • afuerhoff
                                            @ilovegym sagte in Test Adapter fb-checkpresence v0.2.x:
                                            Ich habe mir das mal angesehen. Ich kann den Fehler bei mir nicht nachstellen. Kannst Du den Loglevel mal auf Debug stellen und dann den Log posten.
                                            31.7k
                                            79.8k
                                            avm fb-checkpresence fritzbox soap tr-064
                                            26
                                            259
                                            27697
