    4. Material Design Widgets: Calendar Widget
    • Scrounger
      Scrounger Developer @Adnim last edited by
      @Adnim
      Jetzt müsste es gehen:
      // momentjs is required as dependecies in javascript adapter
      const moment = require("moment");
      var instances = $(`[id=ical.*.data.table]`);
      instances.on(ical2CalendarWidget);
      function ical2CalendarWidget() {
          try {
              let calList = [];
              for (var inst = 0; inst <= instances.length - 1; inst++) {
                  let icalObj = getState(instances[inst]).val;
                  if (icalObj) {
                      for (var i = 0; i <= icalObj.length - 1; i++) {
                          let item = icalObj[i];
                          // extract calendar color
                          let calendarName = item._class.split(' ')[0].replace('ical_', '');
                          let startTime = moment(item._date);
                          let endTime = moment(item._end);
                          let start = startTime.format("YYYY-MM-DD HH:mm");
                          let end = endTime.format("YYYY-MM-DD HH:mm");
                          if (startTime.format('HH:mm') === '00:00' && endTime.format('HH:mm') === '00:00') {
                              // is full-day event
                              if (endTime.diff(startTime, 'hours') === 24) {
                                  // full-day event, one day
                                  start = startTime.format("YYYY-MM-DD");
                                  end = startTime.format("YYYY-MM-DD");
                              } else {
                                  // full-day event, multiple days
                                  end = endTime.format("YYYY-MM-DD");
                          // create object for calendar widget
                          calList.push({
                              color: getMyCalendarColor(calendarName),
                              colorText: getMyCalendarTextColor(calendarName),
                              start: start,
                              end: end
                      function getMyCalendarColor(calendarName) {
                          // assign colors via the calendar names, use calendar name as set in ical
                          if (calendarName === 'calendar1') {
                              return '#FF0000';
                          } else if (calendarName === 'calendar2') {
                              return '#44739e'
                          } else if (calendarName === 'calendar3') {
                              return '#32a852'
                      function getMyCalendarTextColor(calendarName) {
                              return '#FFFFFF';
                              return '#FFFFFF'
                              return '#FFFFFF'
                  // Enter the destination data point that is to be used as object ID in the widget
                  setState('0_userdata.0.materialdesignwidgets.ical2Calendar', JSON.stringify(calList), true);
          } catch (e) {
              console.error(`ical2MaterialDesignCalendarWidget: message: ${e.message}, stack: ${e.stack}`);
      ical2CalendarWidget();
      A S 2 Replies Last reply Reply Quote 2
        Adnim @Scrounger last edited by
        @Scrounger
        Ja! Danke Danke
          sveni_lee @Scrounger last edited by
          @Scrounger
          super, so hatte ich mir das vorgestellt.
            jerzimeik last edited by jerzimeik
            soweit läuft das widget inkl. scipt. Nur zeigt er mir nicht die Termine aller Instanzen an.
            Unter den objects steht in der Datei zwar alles drin
            [{"name":"Rest- & Biomüll","start":"2020-02-06","end":"2020-02-06"},{"name":"Friseur","start":"2020-02-05 09:00","end":"2020-02-05 09:30"},{"name":"Physio","start":"2020-02-06 08:00","end":"2020-02-06 08:30"},{"name":"Training AH","start":"2020-02-06 19:30","end":"2020-02-06 21:30"},{"name":"Vitamin D3","start":"2020-02-07 12:30","end":"2020-02-07 12:30"},]
            Aber in der vis nicht:
            Der erste Eintrag steht sogar doppelt.
            Was muss ich tun?
            Witzigerweise zeigt er in der Monatsansicht alle Termine an?!?
            ub.privat 1 Reply Last reply Reply Quote 0
            • ub.privat
              ub.privat @jerzimeik last edited by ub.privat
              Servus und einen schönen guten Abend,
              ich mach es mir noch ein wenig schwer mit dem CalendarWidget.
              1. Wo muss das Script eingestellt werden?
                • zentral unter Scripte "common" , "root-Verzeichnis", oder ...?
                • oder im Widget unter Scripte?
              2. Wie kann ich dem Widget mehrere Kalender zuordnen? Habe zwei ical- Instanzen...
              3. Welchen Datenpunkt der ical-Instanz wähle ich aus?
              Danke schon mal für eure sicher hilfreichen Tipps!
              Agria4800 1 Reply Last reply Reply Quote 0
              • Agria4800
                Agria4800 @ub.privat last edited by
                @ub-privat zu 1: unter javascript Adapter, der muss natürlich installiert sein!
                dann unter:
                zu 2: entweder machst du ein Widget per Instanz ( dann bitte den * aus Punkt 3 mit der ical 0 oder 1 ändern), oder lässt dir wie unter Punkt 3 alle in einem anzeigen!
                und zu 3:
                mit dem * sucht er alle ical Instanzen ab!
                • ub.privat
                  ub.privat @Agria4800 last edited by ub.privat
                  @Agria4800
                  Danke für deine Hilfe, leider bekomme ich immer noch keine Kalendereinträge angezeigt.
                  Script ist wie folgt hinterlegt:
                  Nun muss ich ja im Widget den DP angeben:
                  HIer kann ich nun die Kalender = ical-Instanzen auswählen:
                  Ich denke, genau hier habe ich mein Verständisproblem!
                  Egal was ich anwähle, es folgt kein Ergebnis.
                  Mache ich etwas falsch?
                  Gemäß Beschreibung;
                  wird ein JSON-String als Object-ID benötigt.
                  Nur in meiner Objekt-Liste ist kein JSON-String, maximal ein HTML und Tabelle...!
                  Wie gesagt, es ist GUTER RAT TEUER!?
                  • Agria4800
                    @ub-privat naja, bist auf den richtigen Weg 🙂
                    im Script wird ein Datenpunkt angelegt (recht weit unten...)
                            setState('0_userdata.0.materialdesignwidgets.ical4Calendar', JSON.stringify(calList), true);
                    diesen Datenpunkt musst du in dem Widget, welches du schon hast, eintragen, dann passt es 😉
                    • ub.privat
                      @Agria4800
                      Dankeschöne, wieder einen kleinen Schritt weiter:
                      Leider ist deser DP nicht erzeugt!
                      Ergo, es muss noch etwas falsch sein...???😢 😠
                        sigi234 Forum Testing Most Active @Scrounger last edited by sigi234
                        @Scrounger
                        Altes Widget funktioniert einwandfrei!
                        J.A.R.V.I.S. Scrounger 2 Replies Last reply Reply Quote 0
                        • J.A.R.V.I.S.
                          J.A.R.V.I.S. Developer @sigi234 last edited by J.A.R.V.I.S.
                          @sigi234 ich vermute mal stark, dass der Calendar Adapter (noch?) nicht unterstützt wird und das Widget derzeit nur auf iCal ausgelegt ist.
                          • Scrounger
                            Scrounger Developer @sigi234 last edited by Scrounger
                            @sigi234 sagte in Material Design Widgets: Calendar Widget:
                            Das kann auch nicht gehen, da du ein Objekt String (de: Zeichenkette) mit einem JSON-String als Objekt verwenden musst und nicht so wie du das gemacht hast eine Datenstruktur.
                            Das ging auch nicht in einer vorherigen Version.
                            Hab jetzt das skript nochmal angepasst, damit es hoffentlich wirklich out of the box funktioniert:
                            // remove this, if you know to use your own datapoint
                            let datapointId = 'materialdesignwidgets.calendar.ical2calendar'
                            createState(datapointId, "[]", {
                              read: true,
                              write: false,
                              desc: "JSON String for Calendar Widget",
                              type: "string",
                              def: "[]"
                                try {
                                    let calList = [];
                                        if (icalObj) {
                                                    } else {
                                                calList.push({
                                                    start: start,
                                                    end: end
                                                    return '#FF0000';
                                                    return '#44739e'
                                                    return '#32a852'
                                                    return '#FFFFFF';
                                                    return '#FFFFFF'
                                                    return '#FFFFFF'
                                        setState(datapointId, JSON.stringify(calList), true);
                                } catch (e) {
                            Es wird euch jetzt autmoatisch ein Datenpunkt in der Javascript instanz angelegt.
                            Im Calendar Wigdet dann unter Objekt Id diesen Datenpunkt auswählen, da muss dann folgendes drin stehen javascript.0.materialdesignwidgets.calendar.ical2calendar
                            J.A.R.V.I.S. ub.privat 2 Replies Last reply Reply Quote 0
                            • J.A.R.V.I.S.
                              J.A.R.V.I.S. Developer @Scrounger last edited by J.A.R.V.I.S.
                              @Scrounger er verwendet den Calendar Adapter. Dieser hat allerdings eine andere Struktur und das Skript müsste daraufhin angepasst werden.
                              Deswegen funktioniert das Skript bei @sigi234 auch nicht.
                                syryna last edited by syryna
                                @Scrounger
                                Erstmal vielen Dank für deine Tollen UI Widgets. Durch dich ist sogar ein Laie wie ich fähig ein UI zusammenzubsateln. Tolle Arbeit !
                                Ich hätte jedoch noch 2 Wünsche:
                                1. Der Rot markierte Bereich läßt sich nicht färben. Vermutlich geht es über CSS aber da wäre ebenfalls eine Einstellung gut. ich nehme an es ist follende Klasse: class="v-calendar-daily__scroll-area".
                                  -> Korrektur: die Klasse alleine reicht nicht aus. dann wird der untere Teil schwarz, nicht aber die Scrolbar und ebenfalls nicht der schmale Balken oberhalb der Scrollbar. Ich schätze mal am besten wäre das Scrollen zu deaktivieren. Bei mir gäbe es nichts zu scrollen.
                                2. Wäre es möglich parallele Termine nicht überlappend anzuzeigen sondern nebeneinander?
                                  -> Korrektur: Das geht schon mit Modusüberlappung : Column
                                Grüße, Micha
                                • Scrounger
                                  Scrounger Developer @syryna last edited by
                                  @syryna sagte in Material Design Widgets: Calendar Widget:
                                  Müsste über Hintergrund der View anpassen oder über widget css hintergrund gehen - ungetestet.
                                  Die Scrollbar farben kannst glaub nicht ändern, ist vom browser so vorgegeben, hab ich mich noch nie mit beschäftigt. Ausblenden geht leider nicht, ist von der API so vorgegeben.
                                  • Scrounger
                                    Scrollbar anpassung, siehe hier:
                                    https://forum.iobroker.net/topic/29660/material-design-widgets-top-app-bar-widget/88
                                    • smarthomegirl
                                      smarthomegirl last edited by
                                      ich habe mich die Tage mal an das hier beschriebene Calendar Widget gewagt. Habe es in VIS auch bereits zugeordnet und das hier genannte Skript im ioBroker ordnungsgemäß hinterlegt.
                                      Im Datenpunkt 0_userdata.0.materialdesignwidgets.ical2calendar wird der anstehende Termin auch angezeigt, nur im VIS habe ich folgende Fehlermeldung:
                                      Hier der Datenpunkt:
                                      Wo liegt der Fehler? Was muss ich einstellen?
                                      smarthomegirl 1 Reply Last reply Reply Quote 0
                                      • smarthomegirl
                                        smarthomegirl @smarthomegirl last edited by smarthomegirl
                                        @smarthomegirl
                                        Edit: hat sich erledigt, die Zuweisung war nicht ganz korrekt.
                                        Noch zwei Fragen:
                                        1. Was muss ich einstellen und wo, damit ich farbliche Termine angezeigt bekomme?
                                        2. Ich habe 3 Google-Kalender im iCal Adapter verknüpft, doch im Widget werden mir nur die Termine von einem Kalender angezeigt. Was muss ich einstellen, um die Termine aller Kalender im Widget zu sehen ?
                                        • Scrounger
                                          Scrounger Developer @smarthomegirl last edited by Scrounger
                                          @smarthomegirl sagte in Material Design Widgets: Calendar Widget:
                                          Noch zwei Fragen:
                                          **1. Was muss ich einstellen und wo, damit ich farbliche Termine angezeigt bekomme?
                                          Aktuell muss man die Farben manuell per Skript zuweisen. Das geht in der Funktion getMyCalendarColor. Dort muss man den Kalendernamen eintragen und die Farbe definieren, anbei der Auszug:
        return '#FF0000';
        return '#44739e'
        return '#32a852'
                                          in der nächsten Version vom ical adapter wird die eingestellte Farbe dann mitgeliefert. Das werd ich dann einbauen, dann muss man am Skript gar nichts mehr ändern.
                                          1. Ich habe 3 Google-Kalender im iCal Adapter verknüpft, doch im Widget werden mir nur die Termine von einem Kalender angezeigt. Was muss ich einstellen, um die Termine aller Kalender im Widget zu sehen ?**
                                          Das geht, denke du hast evtl. nicht das richtige Skript oder etwas daran verändert., nimm das von hier:
                                          https://github.com/Scrounger/ioBroker.vis-materialdesign#calendar
                                          Und dann als Datenpunkt (objekt ID) javascript.0.materialdesignwidgets.calendar.ical2calendar im Widget verwenden.
                                            Förster last edited by
                                            Versuche das auch bei mir umzusetzen, scheitere aber am Wigdet: das Kalender Widget wird mir im VIS Editor nicht zur Auswahl angeboten. Die anderen, zB Alerts oder Masonry, schon.
                                            MD Adapter 0.2.49
                                            VIS 1.2.4
                                            Was muss ich tun ?
                                            vis
                                            45
                                            200
                                            31367
