    4. Test Adapter HeatingControl v2.12.x
      MyMeyer last edited by
      @Rene_HM Schau hier bin jetzt ein paar Minuten wieder Online mit WLan und es passiert nichts. Die Temperatur geht nicht hoch.
      heatingcontrol.0 2020-02-09 16:47:26.433 debug (23152) ### state change already handled: true / true /// heatingcontrol.0.Present / heatingcontrol.0.Present
      heatingcontrol.0 2020-02-09 16:47:26.433 debug (23152) ### handle state change heatingcontrol.0.Present {"val":true,"ack":true,"ts":1581263246431,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1581263036403}
      heatingcontrol.0 2020-02-09 16:47:26.432 debug (23152) ### state change already handled: true / true /// heatingcontrol.0.Present / heatingcontrol.0.Present
      heatingcontrol.0 2020-02-09 16:47:26.430 debug (23152) ### handle state change heatingcontrol.0.Present {"val":true,"ack":false,"ts":1581263246427,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1581263036403}
      heatingcontrol.0 2020-02-09 16:45:35.976 debug (23152) system.adapter.admin.0: logging false
      heatingcontrol.0 2020-02-09 16:45:07.290 debug (23152) system.adapter.admin.0: logging true
      heatingcontrol.0 2020-02-09 16:43:56.411 debug (23152) ### state change already handled: true / true /// heatingcontrol.0.Present / heatingcontrol.0.Present
      heatingcontrol.0 2020-02-09 16:43:56.411 debug (23152) ### handle state change heatingcontrol.0.Present {"val":true,"ack":true,"ts":1581263036410,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1581263036403}
      heatingcontrol.0 2020-02-09 16:43:56.411 debug (23152) ### all StateChange handled
      heatingcontrol.0 2020-02-09 16:43:56.409 debug (23152) ### state change already handled: true / true /// heatingcontrol.0.Present / heatingcontrol.0.Present
      heatingcontrol.0 2020-02-09 16:43:56.409 debug (23152) ### handle state change heatingcontrol.0.Present {"val":true,"ack":true,"ts":1581263036407,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1581263036403}
      heatingcontrol.0 2020-02-09 16:43:56.409 debug (23152) ### heatingcontrol.0.Present true 1
      heatingcontrol.0 2020-02-09 16:43:56.407 debug (23152) ### handle state change heatingcontrol.0.Present {"val":true,"ack":false,"ts":1581263036403,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1581263036403}
      • Rene_HM
        Rene_HM Developer @MyMeyer last edited by
        @MyMeyer zeige uns bitte mal, wie du im admin den present-Datenpunkt konfiguriert hast.
        Außerdem: wie sieht der Datenpunkt, den du abfragen willst, im Object-Tree aus?
        Ich denke, dass der Typ des present-Datentypes nicht passt (bool oder number)
        • Semie1
          Semie1 @Rene_HM last edited by
          @Rene_HM
          das ist es ja weiß nicht genau was ich alles einstellen muss
            webseb79 last edited by
            ich benutze zur Zeit das Heizungsscript V2 und wie ich gelesen habe wird es nicht mehr gepflegt und weiter entwickelt.
            Ich habe als Hardware KNX Raumthermostate und Stellantriebe.
            Sind KNX Komponenten mit dem Adapter ansprechbar wie im Script und wenn nicht, ist es geplant die zu integrieren?
            Danke im voraus
            Sebastian
              Pittini Developer @webseb79 last edited by
              @webseb79 sagte in Test Adapter HeatingControl v0.3.x:
              Danke im voraus
              Sebastian
              Alles was mit dem Skript funktioniert hat, sollte auch mit dem Adapter funktionieren. Die entsprechenden Datenpunkte sind ja offenbar vorhanden, sonst liefe ja das Script nicht. Kannst doch einfach mal das Skript stoppen und den Adapter mit einem Raum testen, nicht so zaghaft ;).
                MyMeyer @Rene_HM last edited by MyMeyer
                @Rene_HM
                1x
                und noch eins...
                  Pittini Developer @MyMeyer last edited by
                  @MyMeyer Nein nein nein, das wird so sicher in die Hose gehen. Du baust Zirkelbezüge auf. Die ganzen Datenpunkte dürfen nicht auf die Adapterdatenpunkte verweisen, sondern auf Deine oder leer lassen. So z.B.:
                  Und im Raw sollteste mal schon gar nix ändern. Ich empfehle dringend rtfm hier
                    webseb79 @Pittini last edited by
                    @Pittini
                    hab auf dich gehört und war mal mutig.
                    Installation lief ohne Probleme durch.
                    Einstellungen sind ähnlich dem Script...also auch einfach zu handhaben.
                    Profil ist angelegt und reagiert auf Änderung der Zeit und der Temperatur.
                    Sollwert wird auch zum Thermostat übertragen.
                    Sensoren der Fenster (KNX) sind auch angelegt und der Fensterstatus reagiert auch auf Änderung.
                    Nun zum Problem... WindowIsOpen Status geht auf true aber die Solltemperatur am Thermostat ändert sich nicht.
                    Man kann ja keine Temperaturabsenkung in Grad einstellen, nur relativ , absolut und kein absenken. Was hat das zu bedeuten?
                    Ansonsten kann ich nur sagen das es top Arbeit ist.
                    Sebastian
                    • Rene_HM
                      Rene_HM Developer @webseb79 last edited by Rene_HM
                      Das ist nur die Voreinstellung. Die absolute oder relative Absenkung findest du im Object-Baum, wo du auch das Profil eingestellt hast...
                        Danke.
                        Ich habe es gerade auch gesehen, blind wie ich bin.
                          Kannst du mir noch den Unterschied von absolut und relativ absenken erklären?
                          Ich verstehe das so...ich habe einen Sollwert von 18 Grad und bei 7Grad absolut hätte ich 7 Grad Sollwert erwartet und bei 7Grad relativ 11 Grad.
                          Bei absolut zeigt er mir aber 10 Grad an und relativ 11Grad die passen.
                          Gibt es da eine Untergrenze?
                          • Rene_HM
                            Ja, als Option einstellbar im Admin. Die Mindesttemperatur ist dann wieder im Profil pro Raum.... Wenn man diese Option ausschaltet, arbeitet der Adapter genau wie du oben beschrieben hast.
                            • V
                              Voltage last edited by
                              Mahlzeit.
                              Ich habe jetzt soweit die Profile am laufen, ebenfalls die Temperaturabsenkung mittels diverser Fenstersensoren.
                              Wie bekomme ich es denn jetzt hin, dass mein Homematic Thermostat die Ist-Temperatur meines Xiaomi-Temp-Sensors übernimmt, sprich so lange heizt bis dort die gefoderte Temperatur ansteht?
                              Ich habe gedacht, dass es so funktionieren wird:
                              Ich habe diverse Wege ausprobiert, denke selbst wenn es durch Zufall dann mal klappt wäre es besser ich würde einfach verstehen was ich tue. Hat jemand die STeuerung über ein externen Temperaturfühler bei sich am laufen?
                              • Z
                                zahnheinrich @Voltage last edited by
                                @Voltage
                                Sollte so gehen.
                                Thermostate aber auf manuell einstellen, nicht auf auto
                                • V
                                  Voltage @zahnheinrich last edited by Voltage
                                  @zahnheinrich
                                  Hey. Danke für die Antwort. Ich habe es noch weiter probiert, hänge mal noch ne Menge Fotos an die evtl auch so dem ein oder anderem helfen könnten und damit hier jemand meinen Fehler besser finden kann.
                                  Problem ist, dass das Homematic Thermostat voll aufdreht - siehe Bilder.
                                  Hier steht unter OID-Zielwert "hm-rpc.2.000A1709A64373.1.SET_POINT_TEMPERATURE". Den anderen Wert kann man komplett ablesen
                                  Na die Reihenfolge der Bilder ist jetzt nicht so toll, sorry. Auf jedenfall sieht man, dass er die 22,5 Grad weiter gibt, aber trotz das am Sensor 22,73 Grad sind voll aufdreht.
                                  • Z
                                    zahnheinrich @Voltage last edited by zahnheinrich
                                    @Voltage
                                    Ich habe den Adapter so verstanden:
                                    Für ein und den selben Regler steht nie was unter Thermostat UND Aktor/ Sensor.
                                    Ich würde den Eintrag unter Thermostat löschen, da du zwei getrennte Geräte als Sensor und Aktor benutzt.
                                    Edit: Kommando zurück! Du musst den Sensor/Aktor löschen, den Thermostate so lassen.
                                    Der Aktor steuert nur einen abgesetzten Aktor mit on/off. Daher auch die volle Ventilöffnung.
                                    Rene_HM V 2 Replies Last reply Reply Quote 0
                                      MyMeyer @Pittini last edited by
                                      @Pittini Jau .. 🙂 Das war es ...jetzt läuft es korrekt .Fehler gefunden prima 👍
                                      • Rene_HM
                                        Rene_HM Developer @zahnheinrich last edited by
                                        @zahnheinrich sagte in Test Adapter HeatingControl v0.3.x:
                                        so ist es richtig...
                                          Jens Lattwesen last edited by
                                          Moin,
                                          Frage zu den Profilen: Es gibt 3 Möglichkeiten.
                                          Wie lege ich es am besten an, wenn ich bspw. für 1 Raum (Mo-Fr, Sa-So) brauchen, für einen anderen aber jeden Tage getrennt?
                                          Weiter noch die Frage, wie ich es anstelle, dass ich einen Raum lediglich nach Anwesenheit steuere?
                                          Thx
                                            Jens Lattwesen @Rene_HM last edited by
                                            @Rene_HM
                                            Wie genau konfiguriere ich den Pfad (syntaxtechnisch?)
                                            heating
                                            236
                                            3158
                                            1954104
