    4. [web-speedy] Teste deine Internetverbindung :)
      sigi234 Forum Testing Most Active @Dutchman last edited by sigi234
      @Dutchman
      Test läuft ewig, System stürzt ab.
      ost.Medion(Test)	2020-02-13 00:36:26.024	error	Caught by controller[20]: ::Heap::Max
      host.Medion(Test)	2020-02-13 00:36:26.024	error	Caught by controller[19]: 6: 00007FF75E439804 v8::internal
      host.Medion(Test)	2020-02-13 00:36:26.024	error	Caught by controller[18]: cessOutOfMemory+639
      host.Medion(Test)	2020-02-13 00:36:26.024	error	Caught by controller[17]: ro
      host.Medion(Test)	2020-02-13 00:36:26.024	error	Caught by controller[16]: P
      host.Medion(Test)	2020-02-13 00:36:26.024	error	Caught by controller[15]: nternal::Fatal
      host.Medion(Test)	2020-02-13 00:36:26.024	error	Caught by controller[14]: 5: 00007FF75E25300F v8::i
      host.Medion(Test)	2020-02-13 00:36:26.024	error	Caught by controller[13]:
      host.Medion(Test)	2020-02-13 00:36:26.024	error	Caught by controller[12]: +846
      host.Medion(Test)	2020-02-13 00:36:26.024	error	Caught by controller[11]: 4: 00007FF75E2530DE v8::internal::FatalProcessOutOfMemory
      host.Medion(Test)	2020-02-13 00:36:26.024	error	Caught by controller[11]: 3: 00007FF75DF39200 node_module_register+2032
      host.Medion(Test)	2020-02-13 00:36:26.024	error	Caught by controller[10]: allback+4534
      host.Medion(Test)	2020-02-13 00:36:26.023	error	Caught by controller[9]: node::MakeC
      host.Medion(Test)	2020-02-13 00:36:26.023	error	Caught by controller[8]: 00007FF75DF38886
      host.Medion(Test)	2020-02-13 00:36:26.023	error	Caught by controller[7]: 2:
      host.Medion(Test)	2020-02-13 00:36:26.023	error	Caught by controller[6]:
      host.Medion(Test)	2020-02-13 00:36:26.023	error	Caught by controller[6]: eTimeHandler::GCIdleTimeHandler+4506
      host.Medion(Test)	2020-02-13 00:36:26.023	error	Caught by controller[5]: l
      host.Medion(Test)	2020-02-13 00:36:26.023	error	Caught by controller[4]: ernal::GCId
      host.Medion(Test)	2020-02-13 00:36:26.023	error	Caught by controller[3]: 1: 00007FF75DF5DD8A v8::int
      host.Medion(Test)	2020-02-13 00:36:26.023	error	Caught by controller[2]: ory
      host.Medion(Test)	2020-02-13 00:36:26.023	error	Caught by controller[1]: k-compacts near heap limit Allocation failed - JavaScript heap out of mem
      host.Medion(Test)	2020-02-13 00:36:26.023	error	Caught by controller[0]: FATAL ERROR: Ineffective mar
      Platform: Windows
      Node.js: v10.16.3
      NPM: 6.9.0
      JS Controller: 2.2.9
      JS Skript: 4.4.2
      Admin: 4.0.2
        @Dutchman
        Bericht 2:
        Test braucht seine Zeit, Log wird schnell sehr Groß (debug)
        Die Intervall Eingabe nimmt er nicht sofort an.
        Beim Ausführung des Tests geht der JS Adapter in die Knie, JS Adapter geht auf Rot. ( 6000 IN)
        • Dutchman
          Dutchman Developer Most Active Administrators @sigi234 last edited by
          @sigi234 sagte in [web-speedy] Teste deine Internetverbindung 🙂:
          @Dutchman
          Bericht 2:
          mag debug aus bitte das wird dan system in die knie bringen da kommen sehr viele daten rein.
          debug bringt auch nicht wirklich was bei dem adapter ....
          wie meinst ? wen ich Intervall ändere, setzt er diesen und starten nach der zeit den niesten run
          Auf was fuer ein system laeuft dein iobroker ? Da ist zu wenig Arbeitsspeicher da ....
          • Negalein
            Cool
            jetzt kann das Script weg 🙂
              @Dutchman sagte in [web-speedy] Teste deine Internetverbindung 🙂:
              Win 10 , 8 GB Ram.
              Beim DP: web-speedy.0.Results.client.country steht als Wert AT, sollte da nicht das Land stehen?
              Wunsch:
              DP um den Intervall zu deaktivieren.
              Negalein Dutchman 2 Replies Last reply Reply Quote 0
              • Negalein
                Negalein Global Moderator @sigi234 last edited by
                Passt so.
                Land = AT = Austria
                • Dutchman
                  baue ich naehste version ein, Intervall 0 = aus
                  • Negalein
                    @Dutchman
                    sollte sich der wert von last_Run nicht ändern?
                    Da steht immer 2020-02-13T09:50:28.481Z im Wert.
                    Zeitstempel und letzte Änderung passt aber mit alle 30 Minuten.
                      sigi234 Forum Testing Most Active @Negalein last edited by
                      @Negalein sagte in [web-speedy] Teste deine Internetverbindung 🙂:
                      Passt so.
                      Land = AT = Austria
                      Nein, das ist der country code
                      • Dr. Bakterius
                        Dr. Bakterius Most Active @Dutchman last edited by Dr. Bakterius
                        @Dutchman Danke für den Adapter!
                        Leider sind die Messwerte sehr unkonstant und bilden auch nicht die Realität ab. Ich habe eine 250 Mb/s Anbindung und der Adapter misst bei hintereinander durchgeführten Messungen Werte zwischen 40 Mb/s bis 400 Mb/s. Speedtest.net gibt mir aber immer so um die 260 Mb/s aus.
                        Beim Upload ist es ähnlich, wenn auch nicht so krass.
                        Und der Prozessor meines NUC wird durch den Test auch um einiges höher belastet. Aber noch deutlich von den 100% entfernt. Daran liegt es also nicht. Auch ist er per Gigabit-LAN angeschlossen.
                        Sorry, aber mit solchen Ergebnissen kann ich nichts anfangen...
                        Dutchman C 2 Replies Last reply Reply Quote 0
                        • Negalein
                          Ja auch, aber die Daten werden so vom Provider kommen.
                          • Dutchman
                            Dutchman Developer Most Active Administrators @Dr. Bakterius last edited by
                            @Dr-Bakterius sagte in [web-speedy] Teste deine Internetverbindung 🙂:
                            naja s stht jdem frei s zu benutzen oder nicht 🙂
                            was mir aufgefallen ist, bei meinem Anschluss sind di werte ihr konstant routings in NL is aber anders als in DE.
                            Ich kan mir vorstellen das dr scan nicht immer dn richtig server ermittelt, werden einbauen das man dies Manuel selektieren kan.
                            Mja desweiteren, werte kommen von dr logic aus spendetest.
                            Ich muss noch bissl weiter analysieren und probieren ob hardware Einfluss auf die Testergebnisse hat und eventuell Settings optimiert werden müssen.
                            anger hey, dafter ist es beta 🙂
                            • Dutchman
                              Dutchman Developer Most Active Administrators @Negalein last edited by
                              jup ich sauge es mir nicht aus dem Daumen kommt Ales vom provider 🙂
                                CruziX @Dr. Bakterius last edited by
                                @Dr-Bakterius Ist vermutlich ne Krankheit des Moduls speedtest-net.
                                Siehe https://forum.iobroker.net/topic/3760/script-für-einen-speedtest-über-speedtest-net/141
                                • Dr. Bakterius
                                  Schon klar, dass der Adapter noch beta ist. Aber ich wollte dir nur rückmelden welche Probleme ich derzeit damit habe und die Werte so für mich (noch) unbrauchbar sind.
                                  Das mag erklären weshalb der Adapter weniger misst als die Leitung hergibt, aber ich hatte auch Messwerte die weit über den technischen Möglichkeiten liegen!
                                  Dass du Speedtest nutzt habe ich mir schon gedacht, deswegen auch der Vergleich mit der Speedtest-Website.
                                  • Dr. Bakterius
                                    Dr. Bakterius Most Active @CruziX last edited by
                                    @CruziX Danke für den Hinweis. Dann muss man wohl da ansetzen. Wer misst, misst Mist - aber mit solchem "Mist" hat man nicht einmal Anhaltswerte die man vergleichen könnte. 🙄
                                      Das Modul speedtest-net scheint ja laut oben genanntem Beitrag eh nicht immer sauber zu laufen, vielleicht ist hier eine Änderung auf fast-cli sinnvoll?
                                        @Dutchman
                                        Cool, bastle gerade an der Vis:
                                        Latzi 1 Reply Last reply Reply Quote 5
                                        • Amnesia1211
                                          Amnesia1211 last edited by
                                          @Dutchman Sehr geil, vielen Dank für deine Arbeit und Mühe !!!!
                                          • skvarel
                                            skvarel Developer last edited by skvarel
                                            Danke @Dutchman !! Läuft 🙂
                                            Genau zu diesem Thema hatte ich gestern in der Facebook ioBroker Gruppe eine Frage gestellt, um es per JavaScript zu lösen.
                                            So ist es natürlich noch einfacher.!
                                            Dutchman N 2 Replies Last reply Reply Quote 0
                                            adapter internet tester
                                            66
                                            321
                                            54112
