    4. Test Adapter bshb (Bosch Smart Home) v0.0.x
      holomekc @Guest last edited by
      @pendragon2
      Hi Zwischenstecker ist da und bei mir funktioniert es:
      Vis Einstellung:
      Passenden Wert auswählen:
      In UI auf On klicken:
      Hier siehst du das der Wert auf ON gestellt wird (ack=false => command)
      2020-01-17 19:12:50.897 - debug: bshb.0 (21617) state bshb.0.hdm:HomeMaticIP:3014F711A0000496D858A9D6.PowerSwitch.switchState changed: ON (ack = false)
      Hier siehst du das der Adapter das Gerät gefunden hat
      2020-01-17 19:12:50.901 - debug: bshb.0 (21617) Found cached state: {"device":{"@type":"device","rootDeviceId":"64-da-a0-02-49-0d","id":"hdm:HomeMaticIP:3014F711A0000496D858A9D6","deviceServiceIds":["PowerMeter","PowerSwitch","PowerSwitchProgram"],"manufacturer":"BOSCH","roomId":"hz_2","deviceModel":"PSM","serial":"3014F711A0000496D858A9D6","profile":"GENERIC","iconId":"icon_plug_default","name":"Steckdose","status":"AVAILABLE","childDeviceIds":[]},"deviceService":{"@type":"DeviceServiceData","id":"PowerSwitch","deviceId":"hdm:HomeMaticIP:3014F711A0000496D858A9D6","state":{"@type":"powerSwitchState","switchState":"OFF","automaticPowerOffTime":0},"path":"/devices/hdm:HomeMaticIP:3014F711A0000496D858A9D6/services/PowerSwitch"},"id":"hdm:HomeMaticIP:3014F711A0000496D858A9D6.PowerSwitch.switchState","stateKey":"switchState"}
      Hier siehst du was der Adapter an den Controller schicken will
      2020-01-17 19:12:50.905 - debug: bshb.0 (21617) Data which will be send: {"@type":"powerSwitchState","switchState":"ON"}
      Hier die Antwort vom Controller. Es gibt keinen Inhalt in der Nachricht daher 204 & undefined
      2020-01-17 19:12:51.202 - debug: bshb.0 (21617) HTTP response. status=204,
      body=undefined
      Hier siehst du das der Controller den Adapter informiert das sich etwas geändert hat. Nämlich der powerSwitchState
      2020-01-17 19:12:51.244 - debug: bshb.0 (21617) {"path":"/devices/hdm:HomeMaticIP:3014F711A0000496D858A9D6/services/PowerSwitch","@type":"DeviceServiceData","id":"PowerSwitch","state":{"@type":"powerSwitchState","automaticPowerOffTime":0,"switchState":"ON"},"deviceId":"hdm:HomeMaticIP:3014F711A0000496D858A9D6"}
      Bei OFF dann das gleiche nur halt mit OFF.
      Wenn es bei dir immer noch nicht geht musst du mir noch genauer beschreiben was nicht funktioniert.
        A Former User @holomekc last edited by
        @holomekc
        super - mit dem Widget funktioniert es einwandfrei.
        jetzt noch das powermeter auslesen - mal sehen welches Widget passt.
        Vielen Dank.
          holomekc last edited by holomekc
          Hi. Ich habe noch ein bisschen aufgeräumt in der Version 0.1.3. Feedback wäre super, da die https Verbindung jetzt nicht mehr "aufgeweicht" ist. Schaut mal bitte, ob es geht. Falls nicht bitte melden.
          Was sich geändert hat:
          1. Update auf neue bosch-smart-home-bridge lib version (https Verbesserungen)
          2. Szenarien werden jetzt auch laufend aktualisiert
          3. Nachrichten werden unter einem state angezeigt und auch laufend aktualisiert
          4. Ansonsten nur kleinere Umstrukturierungen die mir die Entwicklung erleichtern
          Für den discovery Adapter habe ich es schon vorbereitet. Ich hoffe es passt jetzt alles dann schaffe ich es hoffentlich den Adapter in stable eintragen zu lassen.
          Vielen Dank schon einmal!
            @holomekc
            wie aktualisiere ich eine Adapter der noch nicht eingetragen ist?
            Danke.
              @pendragon2
              Einfach wieder über github oder npm installieren. Ich bin mir aktuell nicht sicher, ob es vorher gelöscht werden sollte. Habe ich nie gemacht. Ich installiere das beim entwickeln aber auch immer über das pkg für npm.
                Es gab ein Problem mit 0.1.3. Wenn nicht von einer älteren Version migriert wurde startet der Adapter nicht mehr. Der Fehler ist jetzt behoben und kann über GitHub installiert werden. Die Version habe ich noch nicht auf 0.1.4 angehoben. Dementsprechend ist es noch nicht in npm.
                Danke schon einmal für das Feedback, welches ich via Email erhalten habe. Falls noch etwas nicht geht bitte einfach melden.
                  Hi. Version 0.1.4 ist jetzt auch im stable repository. Und der Bosch Smart Home Controller kann nun auch über den discovery Adapter gefunden werden.
                    stenmic @holomekc last edited by
                    @holomekc
                    Super Arbeit von dir und vielen Dank für diesen Adapter.
                    Funktionierte von Anfang an echt perfekt 👌🏻
                    • Scotty89
                      Scotty89 last edited by
                      erstmal vielen Dank das es den Adapter nun gibt 😉
                      Nun lohnt es sich bei mir mal mit Iobroker anzufangen, nachdem dieser nun auch auf der Synology mit läuft.
                      Nachdem ich schon ein paar Blockly Skripte erstellt habe zum Jalousie und Zwischenstecker steuern und das mit der Harmony verbinden konnte frage ich mich grade wie ich an folgende Infos komme:
                      -> welche Routine wurde grade gestartet egal ob über Handy oder Twist ?
                      hat jemand eine Idee bzw Lösung?
                      würde gern die Routinen im Blockly erweitern das die Jalousien zeitabhängig und vom ist zustand entsprechend verfahren und nicht wie es leider über die App nur geht immer ...
                      Vielen Dank
                      • Stefan G. 0
                        Stefan G. 0 last edited by
                        Vielen Dank für diesen Adapter!
                        Ich bin ganz neu bei iobroker und habe es auch geschafft, meine Bosch Geräte einzubinden.
                        Die Temperatur der Thermostate konnte ich schon erfolgreich verstellen und auch die Ist-Temperaturen und den Status der Fenstersensoren auslesen.
                        Mich würde nun interessieren, ob schon jemand (erfolgreich) versucht hat, die Geräte über den Yahka Homekit Adapter in Apple Homekit einzubinden?
                          @Scotty89
                          Ich bin mir nicht sicher, ob ich dein Ziel genau verstehe. Leider kenne ich Blockly und die Jalousien nicht daher tue ich mir noch schwer zu verstehen was der ist Zustand sein könnte. Die state Werte kannst du ja jederzeit auslesen. Schau ansonsten mal im Wiki nach (siehe Link im anderen reply). Vielleicht helfen dir dort die Infos um es auf dein Problem zu übertragen.
                          @Stefan-G-0
                          Normal nutze ich Yahka nicht aber ich habe da auf die schnelle etwas gebastelt. Vielleicht hilft das.
                          Yahka Thermostat
                          PS: Falls die Bilder zu klein sind: Rechtsklick -> Bild in neuem Tab öffnen
                          Stefan G. 0 Scotty89 2 Replies Last reply Reply Quote 0
                          • Stefan G. 0
                            Stefan G. 0 @holomekc last edited by
                            @holomekc
                            Wow, vielen Dank! Ich hab das testweise gerade mal in einem Zimmer probiert und es funktioniert einwandfrei! Vielen Dank für die schnelle Hilfe, ich bin total begeistert! Diese Funktionalität wünsche ich mir seit fast 2 Jahren und Bosch bekommt es einfach nicht hin...
                            Und dann auch noch so super erklärt, dass ich als totaler Anfänger damit klar komme! Ich werde das jetzt gleich noch in den restlichen Zimmern umsetzen.
                            Ich trau mich kaum zu fragen, aber könntest du mir mit den Fenstersensoren auch noch helfen? Das dürfte doch eigentlich einfacher sein als die Thermostate? Ich hab da schon rumgespielt, mir war aber nicht ganz klar, wie ich die ausgelesenen Werte konvertieren muss.
                              holomekc @Stefan G. 0 last edited by holomekc
                              @Stefan-G-0
                              Hi. Freut mich das es funktioniert. Ich schaue mal heute Abend.
                              Edit: Diesmal stark verkürzt ohne Bilder. Ich hoffe das ist trotzdem verständlich. WindowContact Yahka
                              Stefan G. 0 1 Reply Last reply Reply Quote 0
                              • Scotty89
                                Scotty89 @holomekc last edited by
                                @holomekc
                                danke für die Rückmeldung.
                                mir geht es darum das ich ein twist habe an den ich ja routinen starten kann.
                                das würde ich nun über den IoBrocker mitlesen wollen damit ich dann auch noch andere aktionen machen kann die Bosch nicht anbietet...
                                ich würde also irgendwo gern eine Info bekommen wollen welche Routine grade im System ausgeführt wird, bspw durch den twist oder am handy ausgelöst...
                                  holomekc @Scotty89 last edited by
                                  @Scotty89
                                  Hi. Ich habe den Twist auch aber Nachrichten technisch erhält man nicht die Information von wo etwas gestartet wurde du erhälst nur eine Mittelung über das Ergebnis. Also am Beispiel von einem Zwischenschalter. Den habe ich hier via Twist an und aus geschaltet:
                                  2020-02-14 21:30:07.032 - debug: bshb.0 (23357) {"path":"/devices/hdm:HomeMaticIP:3014F711A0000496D858A9D6/services/PowerSwitch","@type":"DeviceServiceData","id":"PowerSwitch","state":{"@type":"powerSwitchState","automaticPowerOffTime":0,"switchState":"ON"},"deviceId":"hdm:HomeMaticIP:3014F711A0000496D858A9D6"}
                                  2020-02-14 21:30:15.595 - debug: bshb.0 (23357) {"path":"/devices/hdm:HomeMaticIP:3014F711A0000496D858A9D6/services/PowerSwitch","@type":"DeviceServiceData","id":"PowerSwitch","state":{"@type":"powerSwitchState","automaticPowerOffTime":0,"switchState":"OFF"},"deviceId":"hdm:HomeMaticIP:3014F711A0000496D858A9D6"}
                                  Es ist nur der Wechsel des Zustands zu sehen jedoch nicht von wo.
                                  Das ist sogar bei Szenarien der Fall. Auch da sehe ich nicht, welches ausgeführt wurde, sondern nur was damit verändert wurde.
                                  Was jedoch geht ist zu schauen, ob (wieder das Beispiel von oben) Der Zwischenstecker auf ON oder OFF gewechselt hat. Oder im Kontext von den Jalousien müsstest du sehen können, wann sich ein Wert verändert und auf welchem Wert.
                                  Ansonsten bräuchte ich noch mehr Infos. Auch gerne via Email
                                  Scotty89 1 Reply Last reply Reply Quote 0
                                  • Scotty89
                                    @holomekc
                                    danke für die Erklärung wenn ich alles vom broker oder VIS aus machen würde wäre das alles auch ok... aber ich habe halt das Problem das wir schon definierte Routinen in der Bosch app haben die auch auf dem Twist verfügbar sind und ich würde nun gern mit anderen Geräten über den Broker dann drauf reagieren wollen je nach gestartete Routine.
                                    bspw.
                                    wenn Routine "nach hause kommen" gestartet wird, dann soll bspw über den ioBroker diverse mclightnig Geräte entsprechend gesetzt werden.
                                    bei einer anderen Routine halt dann bspw mit anderen Werten für mclightnig Geräte
                                      @Scotty89
                                      Hi jetzt habe ich es verstanden 😉
                                      Ich habe noch einmal den Adapter auf silly gestellt und alles mögliche ausprobiert. Szenarien, Automationen bei keinem schickt der Controller eine Information die sagt das etwas ausgelöst wurde.
                                      Ich habe bspw. Ein Szenario erstellt, welches den Alarm abstellt. Wenn der Alarm bereits aus ist kommt keinerlei Nachricht beim Auslösen des Szenarios. Wenn Alarm bereits an ist kommt nur das Alarm ausgeschaltet wurde aber nicht wieso/wodurch.
                                      Dann dachte ich ok vielleicht sehe ich wann zuletzt ein Szenario ausgeführt wurde über die Szenario Schnittstelle des Controllers. Dort ist jedoch nur die Info was ausgelöst wird jedoch leider kein Datum, ansonsten hätte das über Polling gelöst werden können (auch wenn ich davon kein Fan bin).
                                      Dann wollte ich bei Automationen schauen. Aber da ist auch nix. Auch nicht Infos über die textuelle Benachrichtung erhält man vom Controller. Das läuft in dem Fall vermutlich via Internet und dann halt via Google / Apple.
                                      Also ich denke das wird nicht gehen. Ganz habe ich noch nicht aufgegeben aber ich vermute stark da müsste man auf Änderungen von Bosch warten. Ich kann aber auch mal nachfragen.
                                      • Stefan G. 0
                                        @holomekc
                                        Funktioniert einwandfrei, ganz toll! Vielen Dank!
                                        Bei mir ging es auch mit einem einfachen Mapping ohne Script.
                                        • Stefan G. 0
                                          Stefan G. 0 last edited by Stefan G. 0
                                          Ich habe es auch geschafft die Bosch Zwischenstecker mit Yahka in Homekit einzubinden. Hier fürs Wiki:
                                          Service-Typ:
                                          Switch
                                          On
                                          State: bshb.0.hdm:HomeMaticIP:xxx.PowerSwitch.switchState
                                          Conversion: To Homekit:
                                          Map
                                          ioBroker - Homekit
                                          OFF - is simple value - false
                                          ON - is simple value - true
                                          Edit: Ich muss mich leider korrigieren, so ganz 100%ig funktioniert es nicht. Ich kann den Stecker damit über Homekit schalten und der Status in der App ändert sich auch. Wenn ich den Stecker aber über Alexa oder die Bosch App steuere, wird in Homekit der Status nicht aktualisiert. Jemand eine Idee wo mein Denkfehler ist?
                                            @Stefan-G-0
                                            Danke für das Beispiel. Ich habe es auf die Wiki Seite gepackt. Hier der Link zur Startseite. Die anderen Links haben sich verändert, da ich es ein wenig neu strukturiert habe: Wiki
                                            81.1k
                                            bosch
                                            85
                                            437
                                            108223
