    4. Bring! Adapter 1.7.0
    • Negalein
      Negalein Global Moderator last edited by Negalein
      @foxriver76
      In der Adapterkonfig funktioniert "Speichern und schließen" nicht mehr.
      Speichern alleine auch nicht.
      Admin: 4.0.2
      Node: 10.17.0
      NPM: 6.11.3
      • foxriver76
        foxriver76 Developer @Negalein last edited by
        @Negalein Bitte mal F12 im Browser und auf den Tab Konsole. Und welcher Browser? 😉
        • Negalein
          Negalein Global Moderator @foxriver76 last edited by
          @foxriver76 sagte in Bring! Adapter 1.7.0:
          aktueller Chrome
          Meldung (ab Zeile 12) bei drücken auf "Speichern und schließen"
          "tree": {"en": "tree", "de": "tree", "ru": "tree", "pt": "tree", "nl": "tree", "fr": "tree", "es": "tree", "pl": "tree", "it": "tree", "zh-cn": "tree"},
          jquery.fancytree-all.js:113 Fancytree@1 Fancytree.filterNodes() leavesOnly option is deprecated since 2.9.0 / 2015-04-19. Use opts.leavesOnly instead.
          v @ jquery.fancytree-all.js:113
          adminConfig.js:17 Object
          adminConfig.js:24 Unknown event: [object Object]
          adminInstances.js:1065 166
          translate.js:24 "E-Mail": {"en": "E-Mail", "de": "E-Mail", "ru": "E-Mail", "pt": "E-Mail", "nl": "E-Mail", "fr": "E-Mail", "es": "E-Mail", "pl": "E-Mail", "it": "E-Mail", "zh-cn": "E-Mail"},
          translate.js:24 "Telegram": {"en": "Telegram", "de": "Telegram", "ru": "Telegram", "pt": "Telegram", "nl": "Telegram", "fr": "Telegram", "es": "Telegram", "pl": "Telegram", "it": "Telegram", "zh-cn": "Telegram"},
          translate.js:24 "Pushover": {"en": "Pushover", "de": "Pushover", "ru": "Pushover", "pt": "Pushover", "nl": "Pushover", "fr": "Pushover", "es": "Pushover", "pl": "Pushover", "it": "Pushover", "zh-cn": "Pushover"},
          DevTools failed to parse SourceMap: chrome-extension://hdokiejnpimakedhajhdlcegeplioahd/sourcemaps/onloadwff.js.map
          DevTools failed to parse SourceMap: http://localhost:8080/headless-content.js.map
          index_m.html?0:98 Uncaught (in promise) TypeError: Cannot read property 'importKey' of undefined
              at index_m.html?0:98
              at new Promise (<anonymous>)
              at encrypt (index_m.html?0:93)
              at HTMLInputElement.<anonymous> (index_m.html?0:245)
              at Function.each (jquery-3.2.1.min.js:2)
              at r.fn.init.each (jquery-3.2.1.min.js:2)
              at save (index_m.html?0:239)
              at HTMLAnchorElement.<anonymous> (adapter-settings.js:227)
              at HTMLAnchorElement.dispatch (jquery-3.2.1.min.js:3)
              at HTMLAnchorElement.q.handle (jquery-3.2.1.min.js:3)
          • foxriver76
            @Negalein probiere es dann nachzustellen. Läuft dein Admin via https?
            • Negalein
              nein
              • foxriver76
                @Negalein ok, muss was einbauen, dass er dann zurück fällt auf die alte + Hinweis ohne https läuft es nicht im Frontend.
                • Negalein
                  Ok, also ohnehttps geht aes-256-cecnicht?
                  • foxriver76
                    @Negalein du kannst mal probieren ob es Firefox kann. Also Chrome stellt die interne Crypto Bilbiothek nur zur Verfügung, wenn bestimmte Paramter stimmen, zb localhost darf und https darf die Lib nutzen.
                    • Negalein
                      tatsächlich. Da ging das "speichern und schließen".
                      Aber $/aes-256-cec: sehe ich unter system.adapter.bring.0 nicht.
                      • foxriver76
                        foxriver76 Developer @Negalein last edited by foxriver76
                        @Negalein Also du brauchst ja auch nicht dauerhaft einen anderen Browser nutzen. Nur wenn die Config gespeichert wird, muss der Browser den Wert verschlüsseln. Ist er einmal im Objekt gespeichert und wird nicht geändert ist es egal. Backend hat die Methoden immer. Du musst bei dem Ordner system.adapter.bring.0 hinten auf den Stift und dann nativ, da steht dann dein Passwort und dein Nutzername in verschlüsselter Form.
                        Bzw, was hält dich davon ab https für den admin zu aktivieren?
                        • Negalein
                          Danke, funktioniert
                          $/aes-256-cbc:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                          Ja, werde ich jetzt machen.
                          Muss ich da nur HTTPS aktivieren oder sonst noch was zusätzlich Einstellen?
                          • foxriver76
                            @Negalein Eigentlich nur Https aktivieren, und deinem Browser sagen (fragt dich normal beim öffnen), dass du der Seite vertraust, da es ein selbst-signiertes Zertifikat ist.
                            • foxriver76
                              foxriver76 Developer last edited by foxriver76
                              1.7.1 veröffentlicht.
                              Nun wird auch auf die alte Methode fehlerfrei zurückgegriffen, wenn erkannt wird, dass die interne Crypto Lib nicht da ist. Wurde ein Wert korrekt verschlüsselt, wird nun aber mit inkompatiblem Browser (oder z. B. Chrome ohne https) die Config geöffnet, erscheint eine Mitteilung, dass der Wert mit AES verschlüsselt wurde jedoch nicht entschlüsselt werden kann, die Nutzerdaten werden somit nicht ausgefüllt. Geht man nun einfach wieder raus ohne eine Änderung vorzunehmen, bleiben weiterhin die Daten im Backend unverändert. Wird ohne Crypto Lib gespeichert, wird dies auch mitgeteilt und auf die alte Methode zurückgefallen.
                              • Negalein
                                über GIT?
                                In der Adapterliste seh ich trotz mehrmaligen refresh nur die 1.7.0
                                • foxriver76
                                  @Negalein ne auch Npm, kann allerdings etwas dauern bis es angezeigt wird.
                                  • Holger76
                                    Holger76 last edited by Holger76
                                    Moin,
                                    Was ich mal fragen wollte:
                                    Ich nutze pihole, wo mir zb diese Übersicht angezeigt wird:
                                    Auf Platz eins ist mein Discovergy Adapter, welcher etwa jede Sekunde neue Daten vom Stromzähler liefert. Direkt danach kommt schon der Bring Adapter, zusammen mit Platz 3, was ja wohl dazu gehört, ist es eigentlich das, was für die meisten Zugriffe sorgt.
                                    Ich möchte jetzt nicht sagen, dass das mein Heimnetz in größere Schwierigkeiten bringt, aber im Angesicht der "Wichtigkeit" der mir gelieferten Infos, empfinde ich das als ziemlich heftig. Ich benötige die Daten nur aufm Wandtablet, aktualisierung im Minutentakt wäre für mich zb absolut ausreichend. Falls der Adapter auch etwa im sekundentakt die Infos abfragt, hätte ich doch gern die Möglichkeit, den Abfrageintervall einzustellen. So eine Option finde ich momentan nicht in den Einstellungen. Wäre das machbar ?
                                    • foxriver76
                                      foxriver76 Developer @Holger76 last edited by foxriver76
                                      @Holger76
                                      Habe es ehrlich gesagt schon mal irgendwo geschrieben, alle 90 Sekunden 2 Anfragen sind fix pro Liste macht 1920 Anfragen pro Tag pro Liste, glaube noch eine allgemeine Anfrage in dem Intervall sind dann 1920 * Anzahl Listen + 960 + X Anfragen am Tag .. Für das Entfernen/Hinzufügen je 1 Anfrage, nach jedem Entfernen/Hinzufügen wird eine Liste einmalig außerhalb des Intervalls gepollt, wobei das bei schnellem Hinzufügen verschoben wird, sprich fügst du 10 items mit je 2 sek Abstand hinzu wird nur eine Anfrage gemacht zum Update der Liste. Falls du das Widget nimmst dann beim Laden noch 1-2 Anfragen pro Bild.
                                      • JB_Sullivan
                                        JB_Sullivan last edited by JB_Sullivan
                                        Kurze Frage - die Nummern hinter den Fehlermeldungen sind HTML Fehlermeldungen die auf eine nicht Erreichbarkeit der BRING! Server schließen lassen?
                                        bring.0	2020-06-14 09:42:20.121	warn	(9300) Cannot get lists: StatusCodeError: 504 - ""
                                        bring.0	2020-06-14 09:39:50.589	warn	(9300) Cannot get lists: StatusCodeError: 503 - ""
                                        bring.0	2020-06-14 09:47:21.110	warn	(9300) Cannot get lists: StatusCodeError: 408 - ""
                                        • foxriver76
                                          foxriver76 Developer @JB_Sullivan last edited by
                                          @JB_Sullivan Jop, 5er normal immer Probleme auf Serverseite
                                          Stephan Schleich 1 Reply Last reply Reply Quote 0
                                          • Stephan Schleich
                                            Stephan Schleich @foxriver76 last edited by
                                            Bei mir klappt das Vis Widget nicht.
                                            Ich trage z.b. Käse ein, es kommt kein Vorschlag oder sonstiges und beim klick auf Plus passiert auch nichts, weiß dazu jemand was?
                                            Eine separate visuelle Mengen Eingabe wäre noch ganz gut.
                                            JB_Sullivan foxriver76 2 Replies Last reply Reply Quote 0
                                            31.7k
                                            79.8k
                                            bring test verschlüsselung
                                            16
                                            89
                                            6081
