    4. JavaScript
    5. [Vorlage] JS: Log-Datei aufbereiten für VIS
    • O
      Oli @sigi234 last edited by
      @sigi234
      ja habe ich, warum?
      • Mic
        Mic Developer @Negalein last edited by
        @Negalein sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
        Beim Start kommen sofort Fehler.
        Oh, das sollte nicht sein. Von welcher Version kommst du denn?
        • O
          Oli @Mic last edited by
          @Mic
          scheint an meiner VIS zu liegen, laut Zeitstempel um 20:37 Uhr gelöscht
          VIS zeigt folgendes an:
          Das Widget ist folgendermaßen eingestellt:
            sigi234 Forum Testing Most Active @Oli last edited by
            @Oli sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
            @sigi234
            ja habe ich, warum?
            Widget:
            [{"tpl":"tplVis-materialdesign-Button-State","data":{"oid":"0_userdata.0.Log-Script.All.visView1.clearJSON","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"outlined","vibrateOnMobilDevices":"50","iconPosition":"right","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"timestamp","lc-is-interval":false,"lc-is-moment":false,"lc-format":"DD.MM.YYYY hh:mm:ss","lc-position-vert":"bottom","lc-position-horz":"left","lc-offset-vert":"-21","lc-offset-horz":"142","lc-font-size":"x-small","lc-font-family":"RobotoCondensed-Light","lc-font-style":"","lc-bkg-color":"#000000","lc-color":"#ffffff","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":"1","value":"true","buttontext":"Clear selectet Log","colorPress":"#d40202","labelWidth":"","image":"trash-can-outline","imageColor":"#d40202","iconHeight":"30","lc-oid":"0_userdata.0.Log-Script.All.visView1.clearJSON"},"style":{"left":"158px","top":"749px","width":"170px","height":"44px","z-index":"1","border-width":"1px","border-style":"solid","border-color":"#c9c9c9","border-radius":"5px","color":"#ffffff","font-family":"RobotoCondensed-Light"},"widgetSet":"materialdesign"}]
            • Negalein
              Negalein Global Moderator @Mic last edited by
              @Mic sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
              Habs gerade nochmal neu von deiner GIT-Seite kopiert und meine Config eingefügt.
              Mic-M iobroker.logfile-script  Parses log file, applies filters, and sets states for visualization.png
              Selbes Ergebnis
              javascript.0	2020-02-11 20:51:01.763	error	(2798) at process._tickCallback (internal/process/next_tick.js:68:7)
              javascript.0	2020-02-11 20:51:01.763	error	(2798) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
              javascript.0	2020-02-11 20:51:01.763	error	(2798) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
              javascript.0	2020-02-11 20:51:01.763	error	(2798) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:572:33)
              javascript.0	2020-02-11 20:51:01.763	error	(2798) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1055:17)
              javascript.0	2020-02-11 20:51:01.763	error	(2798) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1464:17)
              javascript.0	2020-02-11 20:51:01.763	error	(2798) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1411:37)
              javascript.0	2020-02-11 20:51:01.763	error	(2798) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:1188:28)
              javascript.0	2020-02-11 20:51:01.763	error	(2798) at Object.createScript (vm.js:277:10)
              javascript.0	2020-02-11 20:51:01.763	error	(2798) at new Script (vm.js:83:7)
              javascript.0	2020-02-11 20:51:01.763	error	(2798) SyntaxError: Identifier 'LOG_PATT' has already been declared
              javascript.0	2020-02-11 20:51:01.762	error	(2798) ^
              javascript.0	2020-02-11 20:51:01.762	error	(2798) const LOG_PATT = '([0-9_.\\-:\\s]*)(\\s+\\- )(silly|debug|info|warn|error|)(: )([a-z0-9.\\-]*)(\\s)(.*)';
              javascript.0	2020-02-11 20:51:01.762	error	at script.js.System.IOBroker_Log:413
              javascript.0	2020-02-11 20:51:01.762	error	(2798) script.js.System.IOBroker_Log compile failed:
               * Log Script für ioBroker zum Aufbereiten des Logs für Visualisierungen (vis), oder um
               * auf Log-Ereignisse zu reagieren.
               * Das Script nimmt jeden neuen Logeintrag des ioBrokers und wendet entsprechend gesetzte
               * Filter an, um den Eintrag dann in den entsprechenden Datenpunkten dieses Scripts abzulegen.
               * Es stehen auch JSON-Datenpunkte zur Verfügung, mit diesen kann im vis eine
               * Tabelle ausgegeben werden (z.B. über das Widget 'basic - Table' oder 'materialdesign - Table').
               * Aktuelle Version: https://github.com/Mic-M/iobroker.logfile-script
               * Support:          https://forum.iobroker.net/topic/13971/vorlage-log-datei-aufbereiten-f%C3%BCr-vis-javascript
               * Autor:            Mic (ioBroker) | Mic-M (github)
               * VORAUSSETZUNGEN
               * 1.) Nur falls Datenpunkte unterhalb '0_userdata.0' abgelegt werden sollen:
               *     In der Instanz des JavaScript-Adapters die Option [Erlaube das Kommando "setObject"] aktivieren.
               *     Siehe auch: https://github.com/Mic-M/iobroker.createUserStates
               * 2.) Dieses Script benötigt die JavaScript-Adapter-Version 4.3.0 (2019-10-09) oder höher.
               *     Wer eine ältere Version einsetzt: Bitte Script-Version 2.0.2 verwenden.
               * Change Log:
               *  4.0.1 Mic   - Add "jsonDateFormat: 'dd.mm. hh:mm'," to FILTER_LOG, id 'all'.
               *  4.0 Mic     + To allow individual settings per each defined LOG_FILTER, the following global
               *                settings were moved to LOG_FILTER:
               *                 * JSON_DATE_FORMAT                   -> jsonDateFormat
               *                 * JSON_LEN                           -> jsonLogLength
               *                 * JSON_NO_ENTRIES                    -> jsonMaxLines
               *                 * JSON_APPLY_CSS_LIMITED_TO_LEVEL    -> jsonCssToLevel
               *                 * L_SORT_ORDER_DESC                  -> sortDescending
               *              + Code improvements
               *              + Renamed LOG_NO_OF_ENTRIES to MAX_LOG_LINES
               *  3.4 Mic     + Support both '0_userdata.0' and 'javascript.x' for state creation
               *  3.3 Mic     - Fix state path
               *  3.2 Mic     + Create all states under 0_userdata.0, and no longer under javascript.<instance> (like javascript.0)
               *  3.1 Mic     + Change to stable as tests were successful
               *              + Add new option REMOVE_PID: The js-controller version 2.0+ adds the PID number inside brackets
               *                to the beginning of the message. Setting REMOVE_PID = false will remove it.
               *  3.0Alpha Mic + Major Change: JavaScript adapter 4.3+ now provides onLog() function:
               *                 https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#onlog
               *                 We are using this new function to streamline this log script tremendously and to remove node-tail.
               *  2.0.2 Mic   + Changed certain functions to async to get rid of setTimout() and for the sake of better error handling.
               *              + startTailingProcess(): ensure the tailing starts if the file is present (wait to be created)
               *  2.0.1a Mic  Removed constant MERGE_LOGLINES_ACTIVE
               *  2.0.0a Mic  Major improvements and fixes:
               *              + Change from instant state update to schedule (STATE_UPDATE_SCHEDULE). The instant update, so once
               *                new log entries coming in, caused several issues (setting and getting state values (getState() and
               *                setState()) within <1ms simply does not work.
               *              - Fix issue with merging log lines
               *              + Moved global option MERGE_LOGLINES_ACTIVE to LOG_FILTER, for allowing turning on/off for each filter id.
               *              + Several other code improvements
               *              Note: For upgrading from previous version: replace script entirely, re-enter all your options,
               *                    and delete all existing states prior to first activation of this script.
               *  1.5.1 Mic - Set option MERGE_LOGLINES_ACTIVE to 'false' as default, as users reported issues. See
               *              https://forum.iobroker.net/post/288772 . Also option MERGE_LOGLINES_ACTIVE being marked as "experimental"
               *              in the comments. Requires further investigation.
               *  1.5  Mic - Fix issue with option MERGE_LOGLINES_ACTIVE
               *  1.4  Mic + New option MERGE_LOGLINES_TXT for an individual (e.g. localized) string other than 'entries'.
                           - Fix JSON span class closing
               *  1.3  Mic + New option MERGE_LOGLINES_ACTIVE: Merge Loglines with same log message to only one line and adds leading
               *             '[123 entries]' to log message.
               *  1.2  Mic - Fixed issue #6 (Button javascript.0.Log-Script.logXxxx.clearJSON not working reliably)
               *  1.1  Mic + 1. 1.0x script seems to work reliable per user feedback and my own test, so pushing into 1.1 stable.
               *           + New state '.logMostRecent': provides just the most recent log entry to work with "on /
               *             subscribe" on this state and trigger actions accordingly.
               *  1.02 alpha  Mic  - fix restarting at 0:00 (note: restarting is needed due to log file name change)
               *  1.01 alpha  Mic  - fix: creating new file system log file only if not yet existing
               *  1.00 alpha  Mic  + Entirely recoded to implement node-tail (https://github.com/lucagrulla/node-tail).
               *  0.8.1 Mic - Fix: L_SORT_ORDER_DESC was not defined (renamed constant name was not changed in config)
               *  0.8 Mic - Fix: Script caused a "file not found" error if executed right at or shortly after midnight.
               *  0.7 Mic - Fix: States "...clearDateTime" will not get an initial date value on first script start,
               *                 also fix for "on({id: ".
               *  0.6 Mic + Put 0.5.1 BETA into stable
               *          + New option L_APPLY_CSS. If true, it will add <span class='log-info'>xxx</span>
               *            to each log string. 'log-info' for level info, 'log-error' for error, etc.
               *            This makes it easy to format a JSON table with CSS.
               *  0.5.1 BETA Mic + New States "Clear JSON log ..." and "Clear JSON log - Date/Time ...".
               *                   When the button "Clear JSON log" is pushed, the current date/time
               *                   will be set into the date/time state. Once refreshed
               *                   (per schedule in the script, e.g. after 2 minutes), the JSON
               *                   will be cleaned and display just newer logs.
               *                   Use Case: In vis, you can now add a button "clear log" or
               *                   "Mark as read". If you hit the button, the log will be
               *                   cleared and just new log items will be displayed.
               *                   *** THIS IS STILL BEING TESTED *** therefore a beta release...
               *  0.5  Mic + New parameter 'clean' to remove certain strings
               *             from the log line.
               *           + New parameter 'columns' for JSON output to specify which columns
               *             to be shown, and in which order.
               *           + New state "JSONcount" to have the number of log lines in state
               *           - Fixed a few issues
               *  0.4  Mic - Bug fix: improved validation of log line consistency
               *  0.3  Mic + Added filtering and blacklist
               *           - Several fixes
               *  0.2  Mic - Bug fix: corrected wrong function name
               *  0.1  Mic * Initial release
               * Konfiguration: Pfade
              // Pfad, unter dem die States (Datenpunkte) in den Objekten angelegt werden.
              // Es wird die Anlage sowohl unterhalb '0_userdata.0' als auch 'javascript.x' unterstützt.
              const LOG_STATE_PATH = '0_userdata.0.Log-Script';
              // Pfad zum Log-Verzeichnis auf dem Server.
              // Standard-Pfad unter Linux: '/opt/iobroker/log/'. Wenn das bei dir auch so ist, dann einfach belassen.
              const LOG_FS_PATH = '/opt/iobroker/log/';
               * Konfiguration: Alle Logeinträge - Global
              // Zahl: Maximale Anzahl der letzten Logeinträge in den Datenpunkten. Alle älteren werden entfernt.
              // Bitte nicht allzu viele behalten, denn das kostet Performance.
              const MAX_LOG_LINES = 100;
              // Der js-Controller Version 2.0 oder größer fügt Logs teils vorne die PID in Klammern hinzu,
              // also z.B. "(12234) Terminated (15): Without reason".
              // Mit dieser Option lassen sich die PIDs aus den Logzeilen entfernen.
              const REMOVE_PID = true;
               * Schwarze Liste (Black list)
               * Falls einer dieser Satzteile/Begriffe in einer Logzeile enthalten ist, dann wird der Log-Eintrag
               * komplett ignoriert, egal was weiter unten eingestellt wird.
               * Dies dient dazu, um penetrante Logeinträge gar nicht erst zu berücksichtigen.
               * Bitte beachten:
               * 1. Mindestens 3 Zeichen erforderlich, sonst wird es nicht berücksichtigt (würde auch wenig Sinn ergeben).
               * 2. Bestehende Datenpunkt-Inhalte dieses Scripts bei Anpassung dieser Option werden nicht nachträglich neu gefiltert,
               *    sondern nur alle neu hinzugefügten Log-Einträge ab Speichern des Scripts werden berücksichtigt.
              const BLACKLIST_GLOBAL = [
                  '<==Disconnect system.user.admin from ::ffff:', // web.0 Adapter
                  'system.adapter.ical.0 terminated with code 0 (OK)',
                  'bring.0 Cannot get translations: RequestError',
                  ' reconnected. Old secret ', // Sonoff
                  'Popup-News readed...', // info.0 Adapter
                  '[warn] Projects disabled : set editorTheme.projects.enabled=true to enable', // see https://forum.iobroker.net/topic/12260/
               * Zusatz-Einstellung für Option "merge" für LOG_FILTER (unter "Konfiguration: Datenpunkte und Filter"):
               * In MERGE_LOGLINES_TXT kann hier ein anderes Wort eingetragen werden, z.B. 'entries' oder 'Zeilen', damit [123 entries]
               * oder [123 Zeilen] vorangestellt wird anstatt [123 Einträge].
               * HINWEIS: Falls MERGE_LOGLINES_TXT geändert wird: bitte alle Datenpunkte des Scripts löschen und dann Script neu starten.
              const MERGE_LOGLINES_TXT = 'Einträge';
               *  Für JSON-Tabelle: Füge CSS-Klasse hinzu je nach Log-Level (debug, silly, info, warn und error), um Tabellen-Text zu formatieren.
               *  Beispiel für Log-Level "debug": ersetzt "xxx" durch "<span class='log-debug'>xxx</span>""
               *  Es wird jeweils "log-" vorangestellt, also: debug -> log-debug, silly -> log-silly, info -> log-info, etc.
               *  Etwa für Widget "basic - Table" im vis können im Reiter "CSS" z.B. folgende Zeilen hinzugefügt werden,
               *  um Warnungen in oranger und Fehler in roter Farbe anzuzeigen.
               *         .log-warn { color: orange; }
               *         .log-error { color: red; }
               *  Tipp: In LOG_FILTER kann dann bei den einzelnen Filtern mittels "jsonCssToLevel" eingestellt werden, dass das CSS
               *        nur  für die Spalte "level" (also debug, error, info) und nicht auf alle Spalten angewendet wird.
              const JSON_APPLY_CSS = true;
               * Konfiguration: Datenpunkte und Filter
               * Dies ist das Herzstück dieses Scripts: hier werden die Datenpunkte konfiguriert, die erstellt werden sollen.
               * Hierbei kannst du entsprechend Filter setzen, also z.B. Wörter/Begriffe, die in Logeinträgen enthalten sein
               * müssen, damit sie in den jeweiligen Datenpunkten aufgenommen werden.
               * id:              Ein Begriff ohne Leerzeichen, z.B. "error", "sonoff", homematic, etc. Die ID wird dann Teil der
               *                  Datenpunkte, z.B. "javascript.0.Log-Script.logHomematic.log" mit automatisch vorangestelltem "log".
               * filter_all:      ALLE Begriffe müssen in der Logzeile enthalten sein. Ist einer der Begriffe nicht enthalten, dann wird der
               *                  komplette Logeintrag auch nicht übernommen. Leeres Array [] eingeben, falls hier filtern nicht gewünscht.
               * filter_any:      Mindestens einer der gelisteten Begriffe muss enthalten sein. Leeres Array [] eingeben, falls hier filtern
               *                  nicht gewünscht.
               * blacklist:       Schwarze Liste: Wenn einer dieser Begriffe im Logeintrag enthalten ist, so wird der komplette Logeintrag
               *                  nicht übernommen, egal was vorher in filter_all oder filter_any definiert ist.
               *                  Mindestens 3 Zeichen erforderlich, sonst wird es nicht berücksichtigt.
               *                  HINWEIS: BLACKLIST_GLOBAL wird vorher schon angewendet, hier kannst du einfach nur noch eine individuelle
               *                  Blackliste pro id definieren.
               * clean:           Der Log-Eintrag wird um diese Zeichenfolgen bereinigt, d.h. diese werden entfernt, aber die restliche Zeile
               *                  bleibt bestehen. Z.B. um unerwünschte Zeichenfolgen zu entfernen oder Log-Ausgaben zu kürzen.
               * merge:           Log-Einträge mit gleichem Text zusammenfassen. Beispiel:
               *                      2019-08-17 20:00:00.335 - info: javascript.0 script.js.Wetter: Wetterdaten abrufen.
               *                      2019-08-17 20:15:00.335 - info: javascript.0 script.js.Wetter: Wetterdaten abrufen.
               *                      2019-08-17 20:30:00.335 - info: javascript.0 script.js.Wetter: Wetterdaten abrufen.
               *                  Daraus wird dann nur noch eine Logzeile mit letztem Datum/Uhrzeit und hinzufügen von "[3 Einträge]":
               *                      2019-08-17 20:30:00.335 - info: javascript.0 [3 Einträge] script.js.Wetter: Wetterdaten abrufen.
               *                  Zum aktivieren: true eintragen, zum deaktivieren: false eintragen.
               * sortDescending:  Wenn true: Sortiert die Logeinträge absteigend, also neuester oben.
               *                  Wenn false: Sortiert die Logeinträge aufsteigend, also ältester oben.
               * jsonColumns:     Nur für JSON (für vis).
               *                  Folgende Spalten gibt es: 'date','level','source','msg'. Hier können einzelne Spalten entfernt oder die
               *                  Reihenfolge verändert werden. Bitte keine anderen Spalten eintragen, sondern nur 'date','level','source','msg'.
               * jsonDateFormat:  Datumsformat für JSON Log. Z.B. volles Datum mit 'YYYY-MM-DD HH:MM:SS' oder nur Uhrzeit mit "HH:MM:SS". Die
               *                  Platzhalter YYYY, MM, DD usw. werden jeweils ersetzt.
               *                  YYYY = Jahr 4stellig (z.B. 2019), YY = Jahr 2stellig (z.B. 19), MM = Monat, DD = Tag, HH = Stunde, MM = Minute,
               *                  SS = Sekunde. Groß- oder Kleinschreibung ist egal, d.h. YYYY ist das gleiche wie yy.
               *                  Die Verbinder (-, :, Leerzeichen, etc.) können im Prinzip frei gewählt werden.
               *                  Beispiele: 'HH:MM:SS' für 19:37:25, 'HH:MM' für 19:37, 'DD.MM. HH:MM' für '25.07. 19:37'
               * jsonLogLength:   Maximale Anzahl Zeichen jeder einzelnen Log-Meldung im JSON-Log. Alles was länger ist, wird abgeschnitten.
               * jsonMaxLines:    Maximale Anzahl der letzten Logeinträge im JSON-Log. Alle älteren werden entfernt.
               *                  Falls in MAX_LOG_LINES z.B. "100" gesetzt wird, wird hier bei 100 der Cut gemacht, selbst wenn in
               *                  jsonMaxLines etwa 250 eingetragen wird. D.h. im Bedarf zuerst MAX_LOG_LINES anpassen/erhöhen.
               * jsonCssToLevel:  Wenn true, dann wird JSON_APPLY_CSS nur für die Spalte "level" (also debug, error, info) angewendet,
               *                  aber nicht für die restlichen Spalten wie Datum, Log-Eintrag, etc.
                                  Falls alle Spalten das CSS bekommen sollen: auf false setzen.
               * WEITERER HINWEIS:
               * Bestehende Datenpunkt-Inhalte dieses Scripts bei Anpassung dieser Option werden nicht nachträglich neu
               * gefiltert, sondern nur alle neu hinzugefügten Log-Einträge ab Speichern des Scripts werden berücksichtigt.
              const LOG_FILTER = [
                // Beispiel für individuellen Eintrag. Hier wird euer Hubschrauber-Landeplatz überwacht :-) Wir wollen nur Einträge
                // vom Adapter 'hubschr.0'. Dabei sollen entweder Wetterwarnungen, Alarme, oder UFOs gemeldet werden. Alles unter
                // Windstärke "5 Bft" interessiert uns dabei nicht, daher haben wir '0 Bft' bis '4 Bft' auf die Blackliste gesetzt.
                // Außerdem entfernen wir von der Log-Zeile die Zeichenfolgen '****', '!!!!' und 'ufo gesichtet', der Rest bleibt
                // aber bestehen. Zudem haben wir unter jsonColumns die Spaltenreihenfolge geändert. 'level' herausgenommen, und Quelle
                // ganz vorne.
                  filter_all:     ['hubschr.0'],
                  filter_any:     ['wetterwarnung', 'alarm', 'ufo'],
                  blacklist:      ['0 Bft', '1 Bft', '2 Bft', '3 Bft', '4 Bft'],
                  clean:          ['****', '!!!!', 'ufo gesichtet'],
                  merge:          true,
                  sortDescending: true,
                  jsonColumns:    ['source','date','msg'],
                  jsonLogLength:  100,
                  jsonMaxLines:   10,
                  jsonCssToLevel: true,
                  id:             'all',    // Beispiel "all": hier kommen alle Logeinträge rein, keine Filterung
                  filter_all:     ['', ''], // wird ignoriert, wenn leer
                  filter_any:     ['', ''], // wird ignoriert, wenn leer
                  blacklist:      ['', ''], // wird ignoriert, wenn leer
                  clean:          ['', '', ''], // wird ignoriert, wenn leer
                  merge:          true,
                  jsonColumns:    ['date','level','source','msg'],  // Spaltenreihenfolge für JSON (Tabelle in vis)
                  jsonLogLength:  100,
                  jsonMaxLines:   10,
                  filter_all:     [' - info: '], // nur Logeinträge mit Level 'info'
                  merge:          true,
                  jsonLogLength:  100,
                  jsonMaxLines:   60,
                  filter_all:     [' - debug: ', ''],  // nur Logeinträge mit Level 'debug'
                  filter_any:     [''],
                  blacklist:      ['', '', ''],
                  merge:          true,
                  jsonLogLength:  100,
                  jsonMaxLines:   60,
                  filter_any:     [' - error: ', ' - warn: '],  // nur Logeinträge mit Levels 'warn' und 'error'
                  blacklist:      ['', 'no playback content', 'Ignore! Actual secret is '],
                  merge:          true,
                  jsonLogLength:  100,
                  jsonMaxLines:   60,
                  // Beispiel, um einen bestimmten Adapter zu überwachen.
                  // Hier werden alle Fehler und Warnungen des Homematic-Adapters hm-rpc.0 gelistet.
                  filter_all:     ['hm-rpc.0', ''],  // hm-rpc.0 muss enthalten sein.
                  filter_any:     [' - error: ', ' - warn: '],  // entweder error oder warn
                  merge:          true,
                  jsonLogLength:  100,
                  jsonMaxLines:   60,
               * Konfiguration: Konsolen-Ausgaben
              // Auf true setzen, wenn zur Fehlersuche einige Meldungen ausgegeben werden sollen.
              // Ansonsten bitte auf false stellen.
              const LOG_DEBUG = false;
              // Auf true setzen, wenn ein paar Infos dieses Scripts im Log ausgegeben werden dürfen, bei false bleiben die Infos komplett weg.
              const LOG_INFO = true;
               * Experten-Konfiguration
              // Wie oft Datenpunkte aktualisieren?
              // Neu reinkommende Logeinträge werden erst mal gesammelt (in Variable G_NewLogLinesArrayToProcess). Diese werden dann
              // regelmäßig in den Datenpunkten geschrieben. Sinnvoll ist hier nicht kürzer als 2-3 Sekunden, und nicht länger als
              // ein paar Minuten. Zu kurzes Intervall: Script kommt nicht mehr nach. Zu lange: falls viele Logeinträge reinkommen,
              // kann sich vieles "aufstauen" zur Abarbeitung. Benutze den "Cron"-Button oben rechts für komfortable Einstellung.
              const STATE_UPDATE_SCHEDULE = '*/1 * * * *'; // jede Minute
              // Leer lassen! Nur setzen, falls ein eigener Filename für das Logfile verwendet wird für Debug.
              const DEBUG_CUSTOM_FILENAME = '';
              // Regex für die Aufteilung des Logs in 1-Datum/Zeit, 3-Level, 5-Quelle und 7-Logtext.
              // Ggf. anzupassen bei anderem Datumsformat im Log. Wir erwarten ein Format
              // wie z.B.: '2018-07-22 12:45:02.769  - info: javascript.0 Stop script script.js.ScriptAbc'
              // Da als String, wurden alle Backslashes "\" mit einem zweiten Backslash escaped.
              // Debug: Ignore. Wenn dieses String in der Logzeile enthalten ist, dann ignorieren wir es.
              // Dient dazu, dass wir während des Scripts ins Log schreiben können, ohne dass das dieses Script berücksichtigt.
              const DEBUG_IGNORE_STR = '[LOGSCRIPT_IGNORE]'; // Muss ein  individuelles String sein. Sonst gibt es ggf. eine Endlos-Schleife.
              // Debug: Prüfen, ob jede Logzeile erfasst wird, in dem wir diese direkt danach noch mal ins Log schreiben.
              // Bitte nur auf Anweisung vom Entwickler einschalten. Sonst wird jeder Logeintrag noch einmal wiederholt,
              // mit führendem DEBUG_EXTENDED_STR am Anfang und max. DEBUG_EXTENDED_NO_OF_CHARS an Anzahl Zeichen.
              const DEBUG_EXTENDED = false;
              const DEBUG_EXTENDED_STR = '[LOGSCRIPT_DEBUG_EXTENDED]'; // Muss ein  individuelles String sein. Sonst gibt es ggf. eine Endlos-Schleife.
              const DEBUG_EXTENDED_NO_OF_CHARS = 120;
               * Ab hier nichts mehr ändern / Stop editing here!
               * Global variables and constants
              // Final state path
              const FINAL_STATE_LOCATION = validateStatePath(LOG_STATE_PATH, false);
              const FINAL_STATE_PATH = validateStatePath(LOG_STATE_PATH, true);
              // Final number of VIS states. We do not allow more than 9.
              function finalVisStatesQty(qty) {
                  let result = 0;
                  if( (!isLikeEmpty(qty)) && (qty > 0) )  {
                      if(qty > 9) {
                          result = 9;
                      } else {
                          result = qty;
                  return result;
              const FINAL_NUM_OF_VIS_VIEWS = finalVisStatesQty(NUMBER_OF_VIS_VIEWS);
              // Merge loglines: define pattern (and escape the merge text)
              // We added an additional backslash '\' to each backslash as these need to be escaped.
              const MERGE_REGEX_PATT = '^\[(\\d+)\\s' + escapeRegExp(MERGE_LOGLINES_TXT) + '\]\\s(.*)';
              // Log Handler variable for ioBroker function onLog()
              let G_LogHandler;  // being set later
              // Schedule for logfile update
              let G_Schedule_StateUpdate; // being set later
              // We add here all the new log lines to be processed regularly (per STATE_UPDATE_SCHEDULE);
              let G_NewLogLinesArrayToProcess = [];
               * init - This is executed on every script (re)start.
              init();
              function init() {
                  // Unsubscribe log handler
                  onLogUnregister(G_LogHandler);
                  // Create all script states
                  const NEEDED_STATES = buildNeededStates();
                  createUserStates(FINAL_STATE_LOCATION, false, NEEDED_STATES[0], function() { // force = false
                      createUserStates(FINAL_STATE_LOCATION, true, NEEDED_STATES[1], function() { // force = true
                          // -- All states created, so we continue by using callback
                          // Subscribe on changes: Pressed button "clearJSON"
                          subscribeClearJson();
                          // Subscribe to log handler
                          G_LogHandler = onLog('*', data => { // please ignore the red squiggly underline under '*', see Github issue: https://github.com/ioBroker/ioBroker.javascript/issues/457
                              processNewLogLine(data);
                          // Schedule writing changes into states
                          clearSchedule(G_Schedule_StateUpdate);
                          G_Schedule_StateUpdate = schedule(STATE_UPDATE_SCHEDULE, processNewLogsPerSchedule);
                          // Subscribe to clear all states
                          stateSubscribeClearAllJSON()
                          // Subscribe to states for the VIS views
                          if(FINAL_NUM_OF_VIS_VIEWS > 0) {
                              stateSubscribeVisWhichFilter(); // which Filter
                              stateSubscribeVisClearJson(); // clear JSON
                          // Message
                          if (LOG_INFO) log('Start monitoring of the ioBroker log...', 'info');
              function processNewLogLine(data) {
                  // Convert to Log Line
                  // TODO: This is a quick implementation of new function onLog().
                  //       We need to entirely rewrite script later to fully use the data object.
                  //       However, at this time, we convert it to a standard log line being expected.
                  // First, remove PID if desired
                  let msg = data.message;
                  if (REMOVE_PID) msg = removePID(msg);
                  // Now convert to log line
                  let newLogEntry = timestampToLogDate(data.ts) + '  - ' + data.severity + ': ' + msg;
                  // Check if we have DEBUG_IGNORE_STR in the new log line
                  if(! newLogEntry.includes(DEBUG_IGNORE_STR)) {
                      if (newLogEntry.length > 45) {  // a log line with less than 45 chars is not a valid log line.
                          // Cleanse and apply blacklist
                          newLogEntry = cleanseLogLine(newLogEntry);
                          // Push result into logArrayFinal
                          G_NewLogLinesArrayToProcess.push(newLogEntry);
                          // some debugging
                          if (SCRIPT_DEBUG) log (DEBUG_IGNORE_STR + '===============================================================');
                          if (SCRIPT_DEBUG) log (DEBUG_IGNORE_STR + 'New Log Entry, Len (' + newLogEntry.length + '), content: [' + newLogEntry + ']');
                          // This is for debugging purposes, and it will log every new log entry once again. See DEBUG_EXTENDED option above.
                          if (DEBUG_EXTENDED) {
                              if (! newLogEntry.includes(DEBUG_EXTENDED_STR)) { // makes sure no endless loop here.
                                  log(DEBUG_EXTENDED_STR + newLogEntry.substring(0, DEBUG_EXTENDED_NO_OF_CHARS));
               * Called per schedule STATE_UPDATE_SCHEDULE.
               * It processes G_NewLogLinesArrayToProcess
              function processNewLogsPerSchedule() {
                  if (! isLikeEmpty (G_NewLogLinesArrayToProcess) ) {
                      // We use array spreads '...' to copy array. If not, array is changed by reference and not value.
                      // That means, if we change the target array, it will also change the source array.
                      // See https://stackoverflow.com/questions/7486085/copy-array-by-value
                      let logArrayToProcess = [...G_NewLogLinesArrayToProcess];
                      G_NewLogLinesArrayToProcess.length = 0; // emptying array. https://stackoverflow.com/questions/4804235/difference-between-array-length-0-and-array
                       * Apply the filters as set in LOG_FILTER and split up log levels into elements of an array
                       * logArrayToProcessFiltered will look as follows:
                       *   logArrayToProcessFiltered = [
                       *     ['info':'15.08.2019 09:27:55.476 info adapt.0 some log', 'error':''],
                       *     ['info':'15.08.2019 09:33:58.522 info adapt.0 some more log', 'error':''],
                       *     ['info':'', 'error':'15.08.2019 09:37:55.807 error adapt.0 some error log']
                      let logArrayToProcessFiltered = [];
                      for (let lpEntry of logArrayToProcess) {
                          let logEntryFilteredArray = applyFilter(lpEntry);
                          logArrayToProcessFiltered.push(logEntryFilteredArray);
                      // Further process and finally set states with our results.
                      processLogArrayAndSetStates(logArrayToProcessFiltered);
                  // Finally, set updatestate with current date/time
                  setState(FINAL_STATE_PATH + '.All.lastTimeUpdated', Date.now());
               * Filtering
               * This function applies the filters as set in LOG_FILTER.
               * Also, it splits up the log levels into elements of an array we return by this function.
               * @param {string} strLogEntry
               * @return {array}  split up log levels as elements within this array, like: ['info':'logtext', 'error':'logtext'] etc.
              function applyFilter(strLogEntry) {
                  // We add one element per each filter to the Array ('all', 'error', etc.)
                  let logArrayProcessed = [];
                  for (let j = 0; j < LOG_FILTER.length; j++) {
                      logArrayProcessed[LOG_FILTER[j].id] = '';
                  // We apply regex here. This will also eliminate all log lines without proper info
                  // like date/time, log level, and entry.
                  let arrSplitLogLine = logLineSplit(strLogEntry);
                  if (arrSplitLogLine !== false) {
                      if (isLikeEmpty(LOG_FILTER) === false) {
                          // Now let's iterate over the filter array elements
                          // We check if both the "all" and "any" filters  apply. If yes, - and blacklist false - we add the log line.
                          for (let k = 0; k < LOG_FILTER.length; k++) {
                              if ( (strMatchesTerms(strLogEntry, LOG_FILTER[k].filter_all, 'every') === true)
                              && (strMatchesTerms(strLogEntry, LOG_FILTER[k].filter_any, 'some') === true)
                              && (strMatchesTerms(strLogEntry, LOG_FILTER[k].blacklist, 'blacklist') === false) ) {
                                  logArrayProcessed[LOG_FILTER[k].id] = logArrayProcessed[LOG_FILTER[k].id] + strLogEntry + "\n";
                              // Now we remove terms if desired
                              if (isLikeEmpty(LOG_FILTER[k].clean) === false) {
                                  for (let lpTerm of LOG_FILTER[k].clean) {
                                      if (lpTerm !== '') {
                                          logArrayProcessed[LOG_FILTER[k].id] = logArrayProcessed[LOG_FILTER[k].id].replace(lpTerm, '');
                  return logArrayProcessed;
               * Further processing
               * Further processes the log array and set states accordingly.
               * @param  arrayLogInput             The Array of the log input.
               *                                   Array is like:
               *                                      ['info':'', 'error':'15.08.2019 09:37:55.807 error adapt.0 some error log'],
              function processLogArrayAndSetStates(arrayLogInput) {
                   * [1] Build array from LOG_FILTER. Looks like: arrayFilterIds = ['info', 'error', 'warn'].
                   * Also, build result array to keep our results. Lools like resultArr = [info: '', error: '', warn: '']
                  let arrayFilterIds = [];
                  let resultArr = [];
                  for (let i = 0; i < LOG_FILTER.length; i++) {
                      arrayFilterIds.push(LOG_FILTER[i].id); // each LOG_FILTER id into array
                      resultArr[LOG_FILTER[i].id] = '';
                   * [2] Process element by element, so ['info':'log test', 'error':'log test'] of given array.
                   * We fill the result array accordingly.
                  for (let lpElement of arrayLogInput) {
                      // Loop thru our new array arrayFilterIds and fill result array
                      for (let k = 0; k < arrayFilterIds.length; k++) {
                          // some variables
                          let lpFilterId = arrayFilterIds[k]; // Filter ID from LOG_FILTER, like 'error', 'info', 'custom', etc.
                          let lpNewLogLine = lpElement[lpFilterId]; // Current log line of provided array element of 'error', 'info', 'custom' etc.
                          if (isLikeEmpty(lpNewLogLine)) {
                              // No log content for the given filter id.
                              if (SCRIPT_DEBUG) log (DEBUG_IGNORE_STR + 'Filter  [' + lpFilterId + ']: No match.');
                          } else {
                              if (SCRIPT_DEBUG) log (DEBUG_IGNORE_STR + 'Filter [' + lpFilterId + ']: Match! New Log Line length: (' + lpNewLogLine.length + ')');
                              // Append new log line to result array
                              if (isLikeEmpty(resultArr[lpFilterId])) {
                                  resultArr[lpFilterId] = lpNewLogLine;
                              } else {
                                  resultArr[lpFilterId] = lpNewLogLine + resultArr[lpFilterId]; // "\n" not needed, always added above
                   * [3] We merge with the current state.
                      let lpStatePath1stPart = FINAL_STATE_PATH + '.log' + cleanseStatePath(lpFilterId); // Get Path to state
                      let lpNewFinalLog = resultArr[lpFilterId];
                      if (! isLikeEmpty(lpNewFinalLog) )  {
                          // Get state value
              			let strCurrentStateLog = getState(lpStatePath1stPart + '.log').val; // Get state contents of loop item
                          // Add state log lines to our final log
                          if (! isLikeEmpty(strCurrentStateLog)) {
                              lpNewFinalLog = lpNewFinalLog + strCurrentStateLog; // "\n" not needed, always added above
                          // Convert to array for easier handling
                          let lpNewFinalLogArray = lpNewFinalLog.split(/\r?\n/);
                          // Remove duplicates
                          lpNewFinalLogArray = arrayRemoveDublicates(lpNewFinalLogArray);
                          // Remove empty values
                          lpNewFinalLogArray = cleanArray(lpNewFinalLogArray);
                          // Sort array descending
                          lpNewFinalLogArray = sortLogArrayByDate(lpNewFinalLogArray, 'desc');
                          // Merge Loglines if multiple values and add leading '[123 entries]' to log message
                          let doMerge = getConfigValuePerKey(LOG_FILTER, 'id', lpFilterId, 'merge');
                          if (doMerge || doMerge === 'true') {    // also check for string 'true' in case user used string
                              lpNewFinalLogArray = mergeLogLines(lpNewFinalLogArray);
                          // We need a separate array for JSON
                          let lpNewFinalLogArrayJSON = lpNewFinalLogArray;
                          // Let's remove elements if time of when button '.clearJSON' was pressed is greater than log date.
                          lpNewFinalLogArrayJSON = clearJsonByDate(lpNewFinalLogArrayJSON, lpStatePath1stPart + '.clearJSON');
                          // Just keep the first x elements of the log. JSON log length is being set individually.
                          lpNewFinalLogArray = lpNewFinalLogArray.slice(0, MAX_LOG_LINES);
                          lpNewFinalLogArrayJSON = lpNewFinalLogArrayJSON.slice(0, getConfigValuePerKey(LOG_FILTER, 'id', lpFilterId, 'jsonMaxLines'));
                          // Get just the most recent log entry into string
                          let lpMostRecent = lpNewFinalLogArray[0];
                          // Sort ascending if desired
                          if (!getConfigValuePerKey(LOG_FILTER, 'id', lpFilterId, 'sortDescending')) {
                              lpNewFinalLogArray = lpNewFinalLogArray.reverse();
                              lpNewFinalLogArrayJSON = lpNewFinalLogArrayJSON.reverse();
                          // ** Finally set the states
                          // -1- Full Log, String, separated by "\n"
                          let strResult = lpNewFinalLogArray.join("\n");
                          if (SCRIPT_DEBUG) log (DEBUG_IGNORE_STR + 'New length to be set into state: (' + strResult.length + '), state: [' + lpStatePath1stPart + '.log' + ']');
                          setState(lpStatePath1stPart + '.log', strResult);
                          // -2- JSON, with elements date and msg
                          // Let's put together the JSON
                          let jsonArr = [];
                          for (let j = 0; j < lpNewFinalLogArrayJSON.length; j++) {
                              // Get 4 elements in array: datetime, level, source, message
                              let arrSplitLogLine = logLineSplit(lpNewFinalLogArrayJSON[j]);
                                  let strLogMsg = arrSplitLogLine.message;
                                  // Reduce the length for each log message per "jsonLogLength"
                                  strLogMsg = strLogMsg.substr(0, LOG_FILTER[k].jsonLogLength);
                                  // Build the final Array
                                  // We need this section to generate the JSON with the columns (which ones, and order) as specified in LOG_FILTER
                                  let objectJSONentry = {}; // object (https://stackoverflow.com/a/13488998)
                                  if (isLikeEmpty(LOG_FILTER[k].jsonColumns)) log('Columns not specified in "jsonColumns".', 'warn');
                                  // Prepare CSS
                                  let strCSS1, strCSS2;
                                  let strCSS1_level, strCSS2_level;
                                  if (JSON_APPLY_CSS) {
                                      strCSS1 = "<span class='log-" + arrSplitLogLine.level + "'>";
                                      strCSS2 = '</span>';
                                      strCSS1_level = strCSS1;
                                      strCSS2_level = strCSS2;
                                      if (LOG_FILTER[k].jsonCssToLevel) {
                                          strCSS1 = '';
                                          strCSS2 = '';
                                  for (let lpCol of LOG_FILTER[k].jsonColumns) {
                                      switch (lpCol) {
                                          case 'date' :
                                              objectJSONentry.date = strCSS1 + formatLogDateStr(arrSplitLogLine.datetime, LOG_FILTER[k].jsonDateFormat) + strCSS2;
                                              break;
                                          case 'level' :
                                              objectJSONentry.level = strCSS1_level + arrSplitLogLine.level + strCSS2_level;
                                              break;
                                          case 'source' :
                                              objectJSONentry.source = strCSS1 + arrSplitLogLine.source + strCSS2;
                                              break;
                                          case 'msg' :
                                              objectJSONentry.msg = strCSS1 + strLogMsg + strCSS2;
                                              break;
                                          default:
                                              //nothing;
                                  // Ok, so now we have the JSON entry.
                                  jsonArr.push(objectJSONentry);
                          if (! isLikeEmpty(lpNewFinalLogArrayJSON)) {
                              setState(lpStatePath1stPart + '.logJSON', JSON.stringify(jsonArr));
                              setState(lpStatePath1stPart + '.logJSONcount', lpNewFinalLogArrayJSON.length);
                   * [4] Finally done. Now we set states for the VIS views.
                      setTimeout(function() { // Apply timeout, to ensure all states are set.
                          for(let i = 0; i < FINAL_NUM_OF_VIS_VIEWS; i++) {
                              let lpStateViewSelFilter = FINAL_STATE_PATH + '.All.visView' + (i+1); // like: 0_userdata.0.Log-Script.All.visView1.whichFilter
                              let currentVisFilter = getState(lpStateViewSelFilter + '.whichFilter').val;
                              if(! isLikeEmpty(currentVisFilter)) {
                                  let jsonStateToGet = LOG_STATE_PATH + '.log' + currentVisFilter + '.logJSON';
                                  if( isState(jsonStateToGet) ) {
                                      setState(lpStateViewSelFilter + '.outputJSON', getState(jsonStateToGet).val); // Finally: set state
                                      setState(lpStateViewSelFilter + '.outputJSONcount', getState(jsonStateToGet + 'count').val); // Finally: set state
                                  } else {
                                      log('Log-Script-Fehler: Gewählter Filter ' +  currentVisFilter + ', aber Datenpunkt [' + jsonStateToGet + '] ist nicht vorhanden.', 'error');
                      }, 2000);
               * Script specific supporting functions
               * Subscribe to all Log-Script.logXXXX.clearJSON
               * This will allow to clear JSON log if button is pressed.
              function subscribeClearJson() {
                  // Set current date to state if button is pressed
                  let logSubscribe = '';
                      let lpFilterId = cleanseStatePath(LOG_FILTER[i].id);
                      let lpStateFirstPart = FINAL_STATE_PATH + '.log' + lpFilterId;
                      logSubscribe += ( (logSubscribe === '') ? '' : ', ') + lpFilterId;
                      on({id: lpStateFirstPart + '.clearJSON', change: 'any', val: true}, function(obj) {
                          let stateBtnPth = obj.id // e.g. [javascript.0.Log-Script.logInfo.clearJSON]
                          let firstPart = stateBtnPth.substring(0, stateBtnPth.length-10); // get first part of obj.id, like "javascript.0.Log-Script.logInfo"
                          let filterID = firstPart.slice(firstPart.lastIndexOf('.') + 1); // gets the filter id, like "logInfo"
                          if (SCRIPT_DEBUG) log(DEBUG_IGNORE_STR + 'Clear JSON states for [' + filterID + '].');
                          // We clear the according JSON states
                          setState(firstPart + '.logJSON', '[]');
                          setState(firstPart + '.logJSONcount', 0);
                  if (SCRIPT_DEBUG) log (DEBUG_IGNORE_STR + 'Subscribing to Clear JSON Buttons: ' + logSubscribe)
               * Subscribe to all .All.clearAllJSON
              function stateSubscribeClearAllJSON() {
                  on({id: FINAL_STATE_PATH + '.All.clearAllJSON', change: 'any', val: true}, function (obj) {
                      // 1. All fitered log states
                      const ALL_FILTER_IDS = getAllFilterIds();
                      for (let loopFilterId of ALL_FILTER_IDS) {
                          // Version 4.5.6
                          // See https://forum.iobroker.net/post/375932
                          // We do no longer set the target states directly, but use the according clearJSON instead.
                          // This is to ensure that user can use the clearJSON timestamp for the time of last clearJSON.
                          setState(FINAL_STATE_PATH + '.log' + loopFilterId + '.clearJSON', true);
                          // setState(FINAL_STATE_PATH + '.log' + loopFilterId + '.logJSON', '[]');
                          // setState(FINAL_STATE_PATH + '.log' + loopFilterId + '.logJSONcount', 0);
                      // 2. Vis add-ons
                              let lpState = FINAL_STATE_PATH + '.All.visView' + (i+1);
                              setState(lpState + '.outputJSON', '[]');
                              setState(lpState + '.outputJSONcount', 0);
               * Subscribe to .All.visViewX.whichFilter
              function stateSubscribeVisWhichFilter() {
                          on({id: lpState + '.whichFilter', change: 'ne'}, function (obj) {
                              if(!isLikeEmpty(obj.state.val)) {
                                  let firstStatePart = obj.id.substr(0, (obj.id.length - obj.id.split('.').pop().length - 1)); // Gibt von '0_userdata.0.System.Log-Script.All.visView1.whichFilter' nur den Hauptteil ohne String nach letztem Punkt zurück, also "0_userdata.0.System.Log-Script.All.visView1"
                                  setState(firstStatePart + '.' + 'outputJSON', getState(LOG_STATE_PATH + '.log' + obj.state.val + '.logJSON').val);
                                  setState(firstStatePart + '.' + 'outputJSONcount', getState(LOG_STATE_PATH + '.log' + obj.state.val + '.logJSONcount').val);
               * Subscribe to all .All.visViewX.clearJSON
              function stateSubscribeVisClearJson() {
                          on({id: lpState + '.clearJSON', change: 'any', val: true}, function (obj) {
                              let firstStatePart = obj.id.substr(0, (obj.id.length - obj.id.split('.').pop().length - 1)); // Gibt von '0_userdata.0.System.Log-Script.All.visView1.clearJSON' nur den Hauptteil ohne String nach letztem Punkt zurück, also "0_userdata.0.System.Log-Script.All.visView1"
                              let selectedFilter = getState(firstStatePart + '.whichFilter').val;
                              if(!isLikeEmpty(selectedFilter)) {
                                  setState(firstStatePart + '.outputJSON', '[]'); // .All.visViewX.outputJSON leeren
                                  setState(firstStatePart + '.outputJSONcount', 0); // .All.visViewX.outputJSONcount leeren
                                  setState(FINAL_STATE_PATH + '.log' + selectedFilter + '.clearJSON', true); // Log-Script.logXXXX.clearJSON leeren
               * Get all filter ids into an array (Homematic, Warnanderror, etc.)
               * @return [array] Filter ids in Array
              function getAllFilterIds() {
                  let allFilterIds = [];
                  for(let i = 0; i < LOG_FILTER.length; i++) {
                      let lpIDClean = cleanseStatePath(LOG_FILTER[i].id)
                      if (LOG_FILTER[i].id !== '') allFilterIds.push(lpIDClean); // für VIS add-on states
                  return allFilterIds;
               * Reformats a log date string accordingly
               * @param {string}    strDate   The date to convert
               * @param {string}    format    e.g. 'yyyy-mm-dd HH:MM:SS'. Both upper case and lower case letters are allowed.
               * @return {string}             Returns the resulting date string
              function formatLogDateStr(strDate, format) {
                  let strResult = format.toLowerCase();
                  strResult = strResult.replace('yyyy', strDate.substr(0,4));
                  strResult = strResult.replace('yy', strDate.substr(2,2));
                  strResult = strResult.replace('mm', strDate.substr(5,2));
                  strResult = strResult.replace('dd', strDate.substr(8,2));
                  strResult = strResult.replace('hh', strDate.substr(11,2));
                  strResult = strResult.replace('mm', strDate.substr(14,2));
                  strResult = strResult.replace('ss', strDate.substr(17,2));
                  return strResult;
               * Cleanse the log line
               * @param {string}   logLine    The log line to be cleansed.
               * @return {string}             The cleaned log line
              function cleanseLogLine(logLine) {
                  // Remove color escapes - https://stackoverflow.com/questions/25245716/remove-all-ansi-colors-styles-from-strings
                  let logLineResult = logLine.replace(/\u001b[.*?m/g, '');
                  // Sometimes, a log line starts with the term "undefined", so we remove it.
                  if (logLineResult.substr(0,9) === 'undefined') logLineResult = logLineResult.substr(9,99999);
                  // Remove white space, tab stops, new line
                  logLineResult = logLineResult.replace(/\s\s+/g, ' ');
                  // Check against global blacklist
                  if(strMatchesTerms(logLineResult, BLACKLIST_GLOBAL, 'blacklist')) logLineResult = '';
                  return logLineResult;
               * Sorts the log array by date. We expect the first 23 chars of each element being a date in string format.
               * @param {array} inputArray       Array to process
               * @param {string}  order          'asc' or 'desc' for ascending or descending order
              function sortLogArrayByDate(inputArray, order) {
                  var result = inputArray.sort(function(a,b){
                          // Turn your strings into dates, and then subtract them
                          // to get a value that is either negative, positive, or zero.
                          a = new Date(a.substr(0,23));
                          b = new Date(b.substr(0,23));
                          if (order === 'asc') {
                              return a - b;
                          } else {
                              return b - a;
                  return result;
               * Splits a given log entry into an array with 4 elements.
               * @param {string}  inputValue  Log line like '2018-07-22 11:47:53.019  - info: javascript.0 script.js ...'
               * @return {object}   Array with 4 elements:
               *                     0. datetime (e.g. 2018-07-22 11:47:53.019),
               *                     1. level (e.g. info)
               *                     2. source (e.g. javascript.0)
               *                     3. message (e.g. script.js....)
               *                     Returns FALSE if no match or input value not valid
              function logLineSplit(inputValue) {
                  // Get RegEx ready
                  let mRegEx = new RegExp(LOG_PATT, 'g');
                  // Split
                  let returnObj = {}
                  let m;
                  do {
                      m = mRegEx.exec(inputValue);
                      if (m) {
                          returnObj.datetime = m[1];
                          returnObj.spaceAt2 = m[2];
                          returnObj.level = m[3];
                          returnObj.spaceAt4 = m[4];
                          returnObj.source = m[5];
                          returnObj.spaceAt6 = m[6];
                          returnObj.message = m[7];
                  } while (m);
                  // Now we check if we have valid entries we want
                  if ((returnObj.datetime === undefined)
                      || (returnObj.level === undefined)
                      || (returnObj.source === undefined)
                      || (returnObj.message === undefined)
                     return false; // no valid hits
                  // We can return the array now, since it meets all requirements
                  return returnObj;
               * Merges date/time, level, source and message to a logline
               * @param  {array}    inputValue   Array with 4 elements: date/time, level, source, message
               * @return {string}   Merged log line as string. Empty string '', if input value not valid.
              function logLineMerge(inputValue) {
                  if (inputValue.length === 4) {
                      let mergedLine = inputValue[0] + ' - ' + inputValue[1] + ': ' + inputValue[2] + ' ' + inputValue[3];
                      return mergedLine;
                  } else {
                      // We expect a size of 4, so go out
                      return '';
               * Merge Loglines if multiple values and add leading '[123 entries]' to log message
               * @param {array}  logArray        array of log entries
               * @return {array} the new merged log array
              function mergeLogLines(logArray) {
                  let arrCopy = [...logArray];
                  let arrNew = [];
                  for (let i = 0; i < arrCopy.length; i++) {
                      if (! isLikeEmpty(arrCopy[i])) {
                          let lpEntry = arrCopy[i];
                          let lineWithoutDate = lpEntry.substring(23);
                          let lpLineSplit = logLineSplit(lpEntry);
                          // Get multiple values
                          let lpMulti = arrayGetElements(arrCopy, removeLeading123entries(lpLineSplit.message), false);
                          let result = lpEntry;
                          let lineCounter = 0;
                          if (lpMulti.length > 1) { // Treffer - die aktuelle Zeile zählt ja auch mit.
                              lineCounter = lpMulti.length;
                              let hitLeadingNumber = -1;
                              for (let hitLine of lpMulti) {
                                  let hitLineSplit = logLineSplit(hitLine);
                                  // Check if hit contains '[123 entries]'. If yes, get the number out of it into lineCounter.
                                  // If not, we just count with 1.
                                  hitLeadingNumber = checkForMultiEntry(hitLineSplit.message);
                                  if (hitLeadingNumber > 1) {
                                      lineCounter = hitLeadingNumber + lpMulti.length - 1;
                          } else {
                              lineCounter = 1;
                          if (lineCounter > 1) {
                                  // remove from array by filling empty value
                                  arrCopy = arrayReplaceElementsByValue(arrCopy, removeLeading123entries(lpLineSplit.message), '', false);
                                  // new result
                                  result = logLineMerge([lpLineSplit.datetime, lpLineSplit.level, lpLineSplit.source, '[' + lineCounter + ' ' + MERGE_LOGLINES_TXT + '] ' + removeLeading123entries(lpLineSplit.message)]);
                          arrNew.push(result);
                  return arrNew;
                   * @param  {string}   strInput    A log message with potential leading '[123 entries]'
                   * @return {string}   string without leading '[123 entries]', if it is there
                  function removeLeading123entries(strInput) {
                      let mRegEx = new RegExp(MERGE_REGEX_PATT);
                      let matches = mRegEx.exec(strInput);
                      if (matches === null) {
                          return strInput;
                      } else {
                          return matches[2];
                   * @param  {string}   strInput    A log message checking for leading '[123 entries]'
                   * @return {number}   returns the number 123 from '[123 entries]' if any match, or -1 if not found
                  function checkForMultiEntry(strInput) {
                      // Get RegEx ready
                          return -1;
                      } else {
                          return parseInt(matches[1]);
               * Get the file system path and filename of the current log file.
               * ioBroker creates a log file every midnight at 0:00 under '/opt/iobroker/log/'
               * Syntax of the log file is: iobroker.YYYY-MM-DD.log
               * This function returns the full path to the log file, considering the current date/time when this function is called.
               * @return {string}      Path and file name to log file.
              function getCurrentFullFsLogPath() {
                  let strLogPathFinal = LOG_FS_PATH;
                  if (strLogPathFinal.slice(-1) !== '/') strLogPathFinal = strLogPathFinal + '/';
                  let strFullLogPath = strLogPathFinal + DEBUG_CUSTOM_FILENAME;
                  if (DEBUG_CUSTOM_FILENAME === '') strFullLogPath = strLogPathFinal + 'iobroker.' + getCurrentISODate() + '.log';
                  return strFullLogPath;
               * Clear array: if stateForTimeStamp is greater or equal than log date, we remove the entire log entry
               * @param {array} inputArray     Array of log entries
               * @param {string} stateForTimeStamp     state of which we need the time stamp
               * @return {array} cleaned log
              function clearJsonByDate(inputArray, stateForTimeStamp) {
                  let dtState = new Date(getState(stateForTimeStamp).ts);
                  if (SCRIPT_DEBUG) log (DEBUG_IGNORE_STR + 'Time of last change of state [' + stateForTimeStamp + ']: ' + dtState);
                  let newArray = [];
                  for (let lpLog of inputArray) {
                      let dtLog = new Date(lpLog.substr(0,23));
                      if (dtLog.getTime() >= dtState.getTime()) {
                          newArray.push(lpLog);
                return newArray;
               * Build an array of states we need to create.
               * @return {array} 2 array of states to be created. First is for force=false, second is for force=true.
              function buildNeededStates() {
                  let debugCleanIDs = '';  // für Debug-Ausgabe
                  let statesArray = [];
                      if (LOG_FILTER[i].id !== '') {
                          let lpIDClean = cleanseStatePath(LOG_FILTER[i].id);
                          debugCleanIDs += ((debugCleanIDs === '') ? '' : '; ') + lpIDClean; // für Debug-Ausgabe
                          statesArray.push({ id:'log' + lpIDClean + '.log', name:'Filtered Log - ' + lpIDClean, type:"string", role: "state", def: ""});
                          statesArray.push({ id:'log' + lpIDClean + '.logJSON', name:'Filtered Log - ' + lpIDClean + ' - JSON', type:"string", role: "state", def: ""});
                          statesArray.push({ id:'log' + lpIDClean + '.logJSONcount', name:'Filtered Log - Count of JSON ' + lpIDClean, role: "state", type:"number", def: 0});
                          statesArray.push({ id:'log' + lpIDClean + '.clearJSON', name:'Clear JSON log ' + lpIDClean, role: "button", type:"boolean", def: false});
                  if (SCRIPT_DEBUG) log (DEBUG_IGNORE_STR + 'createLogStates(): Clean IDs: ' + debugCleanIDs);
                  let finalStatesForceFalse = [];
                  let finalStatesForceTrue = [];
                  for (let s=0; s < statesArray.length; s++) {
                      finalStatesForceFalse.push([FINAL_STATE_PATH + '.' + statesArray[s].id, {
                          'name': statesArray[s].name,
                          'desc': statesArray[s].name,
                          'type': statesArray[s].type,
                          'read': true,
                          'write': true,
                          'role': statesArray[s].role,
                          'def': statesArray[s].def,
                  // Jetzt noch die VIS Add-on states (All.visView1, All.visView2, etc.)
                      let dropdown = '';
                      for (let lpEntry of ALL_FILTER_IDS) {
                          dropdown += '"' + lpEntry + '":"' + lpEntry + '",'; // fill JSON string
                      dropdown = dropdown.substr(0, dropdown.length-1); // remove last comma ","
                      dropdown = '{' + dropdown + '}'; // finalize JSON string
                      let dropdownJSON = JSON.parse(dropdown); // convert to JSON
                          let lpStateVisViews = FINAL_STATE_PATH + '.All.visView' + (i+1);
                          finalStatesForceTrue.push ([lpStateVisViews + '.whichFilter', {'name':'Für VIS-Button/Auswahlmenü des anzuzeigenden Filter in JSON-Tabelle', 'type':'string', 'read':false, 'write':true, 'role':'value', 'states': dropdownJSON, 'def': ALL_FILTER_IDS[0]}]); // force true to rebuild state drop-down
                          finalStatesForceTrue.push ([lpStateVisViews + '.outputJSON',  {'name': 'JSON-Ausgabe des in whichFilter gewählten Filters', 'type': 'string', 'read': true, 'write': false, 'role': 'state', 'def': '' }]); // force true to empty on re-start of script.
                          finalStatesForceFalse.push ([lpStateVisViews + '.outputJSONcount',  {'name': 'Anzahl Zeilen in JSON-Ausgabe des in whichFilter gewählten Filters', 'type': 'number', 'read': true, 'write': false, 'role': 'state', 'def': 0 }]);
                          finalStatesForceFalse.push([lpStateVisViews + '.clearJSON',   {'name':'Clear currently selected JSON Log', 'type':'boolean', 'read':false, 'write':true, 'role':'button', 'def': false }]);
                  // Nun noch Button zum leeren ALLER JSONs
                  finalStatesForceFalse.push([FINAL_STATE_PATH + '.All.clearAllJSON',   {'name':'Clear ALL JSON logs', 'type':'boolean', 'read':false, 'write':true, 'role':'button', 'def': false }]);
                  // Zeit letztes Update
                  finalStatesForceFalse.push([FINAL_STATE_PATH + '.All.lastTimeUpdated',   {'name':'Date/Time of last update', 'type':'number', 'read':true, 'write':false, 'role':'value.time'}]);
                  // Done.
                  return [finalStatesForceFalse, finalStatesForceTrue];
               * Converts a timestamp to log date format, like 2019-10-15 16:38:00.260.
               * @param {object}  timeStamp   The date/time timestamp to convert.
               * @return {string} The resulting log date format as string.
              function timestampToLogDate(timeStamp) {
                  let date = new Date(timeStamp);
                  // Need to convert to local time as this time provided from onLog() is UTC
                  // https://stackoverflow.com/questions/6525538/convert-utc-date-time-to-local-date-time/18330682
                  let localDate = new Date(date.getTime() - date.getTimezoneOffset()*60*1000);
                  // Convert to ISO string, so like 2019-10-15T16:38:00.260Z
                  let strResult = localDate.toISOString();
                  // date.toISOString() adds T and Z, so we remove these letters, as the log do not show these.
                  strResult = strResult.replace('T', ' ');  // remove T
                  strResult = strResult.replace('Z', '');  // remove Z at the end
                  return strResult;
               * Remove PID in log message
               * The js-controller version 2.0+ adds the PID number inside brackets to the beginning of the message. We remove it here.
               * @param {string} msg   The log message, like: 'javascript.0 (123) Logtext 123 Logtext 123 Logtext 123 Logtext 123'
              function removePID(msg) {
                  // First: Split source and message text.
                  // Input is like: 'javascript.0 (123) Logtext 123 Logtext 123 Logtext 123 Logtext 123'
                  let regexp = /^(\S+)\s(.*)/;
                  let matches_array = msg.match(regexp);
                  let strFirst = matches_array[1];    // like 'javascript.0'
                  let strRest = matches_array[2];     // like '(123) Logtext 123 Logtext 123 Logtext 123 Logtext 123'
                  // Next, we remove the PID
                  strRest = strRest.replace(/^\([0-9]{1,9}\)\s/, '');
                  // Last, we put the two strings together again
                  return strFirst + ' ' + strRest;
               * onStop - Being executed once this ioBroker Script stops.
              // This is to end the Tale. Not sure, if we indeed need it, but just in case...
              onStop(function myScriptStop () {
                  if (LOG_INFO) log('Unsubscribed to Log Handler.', 'info');
              }, 0);
               * General supporting functions
               * Remove Duplicates from Array
               * Source - https://stackoverflow.com/questions/23237704/nodejs-how-to-remove-duplicates-from-array
               * @return {array}  Array without duplicates.
              function arrayRemoveDublicates(inputArray) {
                  let uniqueArray;
                  uniqueArray = inputArray.filter(function(elem, pos) {
                      return inputArray.indexOf(elem) == pos;
                  return uniqueArray;
               * Clean Array: Removes all falsy values: undefined, null, 0, false, NaN and "" (empty string)
               * Source: https://stackoverflow.com/questions/281264/remove-empty-elements-from-an-array-in-javascript
               * @return {array}  Cleaned array
              function cleanArray(inputArray) {
                var newArray = [];
                for (let i = 0; i < inputArray.length; i++) {
                  if (inputArray[i]) {
                    newArray.push(inputArray[i]);
                return newArray;
               * Checks if Array or String is not undefined, null or empty.
               * 08-Sep-2019: added check for [ and ] to also catch arrays with empty strings.
               * @param inputVar - Input Array or String, Number, etc.
               * @return true if it is undefined/null/empty, false if it contains value(s)
               * Array or String containing just whitespaces or >'< or >"< or >[< or >]< is considered empty
              function isLikeEmpty(inputVar) {
                  if (typeof inputVar !== 'undefined' && inputVar !== null) {
                      let strTemp = JSON.stringify(inputVar);
                      strTemp = strTemp.replace(/\s+/g, ''); // remove all whitespaces
                      strTemp = strTemp.replace(/\"+/g, "");  // remove all >"<
                      strTemp = strTemp.replace(/\'+/g, "");  // remove all >'<
                      strTemp = strTemp.replace(/[+/g, "");  // remove all >[<
                      strTemp = strTemp.replace(/]+/g, "");  // remove all >]<
                      if (strTemp !== '') {
                          return false;
                      } else {
                          return true;
                  } else {
                      return true;
               * Returns the current date in ISO format "YYYY-MM-DD".
               * @return  {string}    Date in ISO format
              function getCurrentISODate() {
                  let currDate = new Date();
                  return currDate.getFullYear() + '-' + zeroPad((currDate.getMonth() + 1), 2) + '-' + zeroPad(currDate.getDate(), 2);
               * Fügt Vornullen zu einer Zahl hinzu, macht also z.B. aus 7 eine "007".
               * zeroPad(5, 4);    // wird "0005"
               * zeroPad('5', 6);  // wird "000005"
               * zeroPad(1234, 2); // wird "1234" :)
               * @param  {string|number}  num     Zahl, die Vornull(en) bekommen soll
               * @param  {number}         places  Anzahl Stellen.
               * @return {string}         Zahl mit Vornullen wie gewünscht.
              function zeroPad(num, places) {
                  let zero = places - num.toString().length + 1;
                  return Array(+(zero > 0 && zero)).join("0") + num;
               * Will just keep lower case letters, numbers, '-' and '_' and removes the rest
               * Also, capitalize first Letter.
              function cleanseStatePath(stringInput) {
                  let strProcess = stringInput;
                  strProcess = strProcess.replace(/([^a-z0-9_\-]+)/gi, '');
                  strProcess = strProcess.toLowerCase();
                  strProcess = strProcess.charAt(0).toUpperCase() + strProcess.slice(1);
                  return strProcess;
               * Checks if the string provided contains either every or some terms.
               * Source: https://stackoverflow.com/questions/36283767/javascript-select-the-string-if-it-matches-multiple-words-in-array
               * @param {string} strInput - The string on which we run this search
               * @param {array} arrayTerms - The terms we are searching, e.g. ["hue", "error", "raspberry"]
               * @param {string} type - 'every': all terms must match to be true,
               *                        'some': at least one term (or more) must match
               *                        'blacklist': different here: function will always
               *                         return FALSE, but if one of the arrayTerms contains
               *                         minimum 3 chars and is found in provided string,
               *                         we return TRUE (= blacklisted item found).
               * @return {boolean}       true, if it contains ALL words, false if not all words (or none)
               *                         Also, will return true if arrayTerms is not array or an empty array
              function strMatchesTerms(strInput, arrayTerms, type) {
                  if(type === 'blacklist') {
                      if (Array.isArray(arrayTerms)) {
                          let arrayTermsNew = [];
                          for (let lpTerm of arrayTerms) {
                              if (lpTerm.length >= 3) {
                                  arrayTermsNew.push(lpTerm);
                          if(isLikeEmpty(arrayTermsNew) === false) {
                              let bResultBL = arrayTermsNew.some(function(word) {
                                  return strInput.indexOf(word) > -1;
                              return bResultBL;
                          } else {
                              return false; // return false if no items to be blacklisted
                      } else {
                          return false; // we return false if the arrayTerms given is not an array. Want to make sure if we really should blacklist...
                  } else {
                          if(type === 'every') {
                              let bResultEvery = arrayTerms.every(function(word) {
                              return bResultEvery;
                          } else if(type === 'some') {
                              let bResultSome = arrayTerms.some(function(word) {
                              return bResultSome;
                      } else {
                          return true; // we return true if the arrayTerms given is not an array
               * Checks if a a given state or part of state is existing.
               * This is a workaround, as getObject() or getState() throw warnings in the log.
               * Set strict to true if the state shall match exactly. If it is false, it will add a wildcard * to the end.
               * See: https://forum.iobroker.net/topic/11354/
               * @param {string}    strStatePath     Input string of state, like 'javas-cript.0.switches.Osram.Bedroom'
               * @param {boolean}   [strict=true]    Optional: Default is true. If true, it will work strict, if false, it will add a wildcard * to the end of the string
               * @return {boolean}                   true if state exists, false if not
              function isState(strStatePath, strict) {
                  if(strict === undefined) strict = true;
                  let mSelector;
                  if (strict) {
                      mSelector = $('state[id=' + strStatePath + '$]');
                  } else {
                      mSelector = $('state[id=' + strStatePath + ']');
                  if (mSelector.length > 0) {
                      return true;
                  } else {
                      return false;
               * Removing Array element(s) by input value.
               * @param {array}   arr             the input array
               * @param {string}  valRemove       the value to be removed
               * @param {boolean} [exact=true]    OPTIONAL: default is true. if true, it must fully match. if false, it matches also if valRemove is part of element string
               * @return {array}  the array without the element(s)
              function arrayRemoveElementsByValue(arr, valRemove, exact) {
                  for ( let i = 0; i < arr.length; i++){
                      if (exact) {
                          if ( arr[i] === valRemove) {
                              arr.splice(i, 1);
                              i--; // required, see https://love2dev.com/blog/javascript-remove-from-array/
                      } else {
                          if (arr[i].indexOf(valRemove) != -1) {
                              arr.splice(i, 1);
                              i--; // see above
                  return arr;
               * Escapes a string for use in RegEx as (part of) pattern
               * Source: https://stackoverflow.com/questions/3446170/escape-string-for-use-in-javascript-regex
               * @param {string} inputStr  The input string to be escaped
               * @return {string}  The escaped string
              function escapeRegExp(inputStr) {
                  return inputStr.replace(/[.*+?^${}()|[]\]/g, '\\$&'); // $& means the whole matched string
               * Get all elements of an array if found
               * @param {string}  valFind         the value to find
               * @return {array}  an array with all hits or empty array if no hits.
              function arrayGetElements(arr, valFind, exact) {
                  let resultArr = [];
                      if (exact) {
                          if ( arr[i] === valFind) {
                              resultArr.push(arr[i]);
                      } else {
                          if (arr[i].indexOf(valFind) != -1) {
                  return resultArr;
               * Replace Array element(s) by input value.
               * @param {string}  valReplace      the value to search for
               * @param {string}  newValue        the new value
               * @return {array}  the array with replaced the element(s)
              function arrayReplaceElementsByValue(arr, valReplace, newValue, exact) {
                      if (exact) {
                          if ( arr[i] === valReplace) {
                              arr[i] = newValue;
                      } else {
                          if (arr[i].indexOf(valReplace) != -1) {
                              arr[i] = newValue;
                  return arr;
               * Retrieve values from a CONFIG variable, example:
               * const CONF = [{car: 'bmw', color: 'black', hp: '250'}, {car: 'audi', color: 'blue', hp: '190'}]
               * To get the color of the Audi, use: getConfigValuePerKey(CONF, 'car', 'audi', 'color')
               * To find out which car has 190 hp, use: getConfigValuePerKey(CONF, 'hp', '190', 'car')
               * @param {object}  config     The configuration variable/constant
               * @param {string}  key1       Key to look for.
               * @param {string}  key1Value  The value the key should have
               * @param {string}  key2       The key which value we return
               * @returns {any}    Returns the element's value, or number -1 of nothing found.
              function getConfigValuePerKey(config, key1, key1Value, key2) {
                  for (let lpConfDevice of config) {
                      if ( lpConfDevice[key1] === key1Value ) {
                          if (lpConfDevice[key2] === undefined) {
                              return -1;
                          } else {
                              return lpConfDevice[key2];
                  return -1;
               * For a given state path, we extract the location '0_userdata.0' or 'javascript.0' or add '0_userdata.0', if missing.
               * @param {string}  path            Like: 'Computer.Control-PC', 'javascript.0.Computer.Control-PC', '0_userdata.0.Computer.Control-PC'
               * @param {boolean} returnFullPath  If true: full path like '0_userdata.0.Computer.Control-PC', if false: just location like '0_userdata.0' or 'javascript.0'
              function validateStatePath(path, returnFullPath) {
                  if (path.startsWith('.')) path = path.substr(1);    // Remove first dot
                  if (path.endsWith('.'))   path = path.slice(0, -1); // Remove trailing dot
                  if (path.length < 1) log('Provided state path is not valid / too short.', 'error')
                  let match = path.match(/^((javascript\.([1-9][0-9]|[0-9])\.)|0_userdata\.0\.)/);
                  let location = (match == null) ? '0_userdata.0' : match[0].slice(0, -1); // default is '0_userdata.0'.
                  if(returnFullPath) {
                      return (path.indexOf(location) == 0) ? path : (location + '.' + path);
                  } else {
                      return location;
               * Create states under 0_userdata.0 or javascript.x
               * Current Version:     https://github.com/Mic-M/iobroker.createUserStates
               * Support:             https://forum.iobroker.net/topic/26839/
               * Version:             1.1 (26 January 2020)
               * Example:             see https://github.com/Mic-M/iobroker.createUserStates#beispiel
               * PLEASE NOTE: Per https://github.com/ioBroker/ioBroker.javascript/issues/474, the used function setObject()
               *              executes the callback PRIOR to completing the state creation. Therefore, we use a setTimeout and counter.
               * @param {string} where          Where to create the state: '0_userdata.0' or 'javascript.x'.
               * @param {boolean} force         Force state creation (overwrite), if state is existing.
               * @param {array} statesToCreate  State(s) to create. single array or array of arrays
               * @param {object} [callback]     Optional: a callback function -- This provided function will be executed after all states are created.
              function createUserStates(where, force, statesToCreate, callback = undefined) {
                  const WARN = false; // Only for 0_userdata.0: Throws warning in log, if state is already existing and force=false. Default is false, so no warning in log, if state exists.
                  const LOG_DEBUG = false; // To debug this function, set to true
                  // Per issue #474 (https://github.com/ioBroker/ioBroker.javascript/issues/474), the used function setObject() executes the callback
                  // before the state is actual created. Therefore, we use a setTimeout and counter as a workaround.
                  const DELAY = 50; // Delay in milliseconds (ms). Increase this to 100, if it is not working.
                  // Validate "where"
                  if (where.endsWith('.')) where = where.slice(0, -1); // Remove trailing dot
                  if ( (where.match(/^((javascript\.([1-9][0-9]|[0-9]))$|0_userdata\.0$)/) == null) ) {
                      log('This script does not support to create states under [' + where + ']', 'error');
                      return;
                  // Prepare "statesToCreate" since we also allow a single state to create
                  if(!Array.isArray(statesToCreate[0])) statesToCreate = [statesToCreate]; // wrap into array, if just one array and not inside an array
                  // Add "where" to STATES_TO_CREATE
                  for (let i = 0; i < statesToCreate.length; i++) {
                      let lpPath = statesToCreate[i][0].replace(/\.*\./g, '.'); // replace all multiple dots like '..', '...' with a single '.'
                      lpPath = lpPath.replace(/^((javascript\.([1-9][0-9]|[0-9])\.)|0_userdata\.0\.)/,'') // remove any javascript.x. / 0_userdata.0. from beginning
                      lpPath = where + '.' + lpPath; // add where to beginning of string
                      statesToCreate[i][0] = lpPath;
                  if (where != '0_userdata.0') {
                      // Create States under javascript.x
                      let numStates = statesToCreate.length;
                      statesToCreate.forEach(function(loopParam) {
                          if (LOG_DEBUG) log('[Debug] Now we are creating new state [' + loopParam[0] + ']');
                          let loopInit = (loopParam[1]['def'] == undefined) ? null : loopParam[1]['def']; // mimic same behavior as createState if no init value is provided
                          createState(loopParam[0], loopInit, force, loopParam[1], function() {
                              numStates--;
                              if (numStates === 0) {
                                  if (LOG_DEBUG) log('[Debug] All states processed.');
                                  if (typeof callback === 'function') { // execute if a function was provided to parameter callback
                                      if (LOG_DEBUG) log('[Debug] Function to callback parameter was provided');
                                      return callback();
                                  } else {
                                      return;
                  } else {
                      // Create States under 0_userdata.0
                      let counter = -1;
                          counter += 1;
                          if (LOG_DEBUG) log ('[Debug] Currently processing following state: [' + loopParam[0] + ']');
                          if( ($(loopParam[0]).length > 0) && (existsState(loopParam[0])) ) { // Workaround due to https://github.com/ioBroker/ioBroker.javascript/issues/478
                              // State is existing.
                              if (WARN && !force) log('State [' + loopParam[0] + '] is already existing and will no longer be created.', 'warn');
                              if (!WARN && LOG_DEBUG) log('[Debug] State [' + loopParam[0] + '] is already existing. Option force (=overwrite) is set to [' + force + '].');
                              if(!force) {
                                  // State exists and shall not be overwritten since force=false
                                  // So, we do not proceed.
                                  numStates--;
                                      if (LOG_DEBUG) log('[Debug] All states successfully processed!');
                                          if (LOG_DEBUG) log('[Debug] An optional callback function was provided, which we are going to execute now.');
                                          return callback();
                                  } else {
                                      // We need to go out and continue with next element in loop.
                                      return; // https://stackoverflow.com/questions/18452920/continue-in-cursor-foreach
                              } // if(!force)
                          // State is not existing or force = true, so we are continuing to create the state through setObject().
                          let obj = {};
                          obj.type = 'state';
                          obj.native = {};
                          obj.common = loopParam[1];
                          setObject(loopParam[0], obj, function (err) {
                              if (err) {
                                  log('Cannot write object for state [' + loopParam[0] + ']: ' + err);
                              } else {
                                  let init = null;
                                  if(loopParam[1].def === undefined) {
                                      if(loopParam[1].type === 'number') init = 0;
                                      if(loopParam[1].type === 'boolean') init = false;
                                      if(loopParam[1].type === 'string') init = '';
                                  } else {
                                      init = loopParam[1].def;
                                      setState(loopParam[0], init, true, function() {
                                          if (LOG_DEBUG) log('[Debug] setState durchgeführt: ' + loopParam[0]);
                                          numStates--;
                                                  return callback();
                                  }, DELAY + (20 * counter) );
              Mic-M created this issue in ioBroker/ioBroker.javascript
              closed onLog() with wildcard *: not identified by editor #457
              closed setObject() function: callback not working as intended. #474
              closed 0_userdata.0: existsState() vs. $-Selector $().length after state deletion #478
              Mic 1 Reply Last reply Reply Quote 0
              • Mic
                Mic Developer @Negalein last edited by
                @Negalein
                Das obige Script von dir wirft im JS-Adapter zahlreiche Fehler, siehe rote Markierungen rechts.
                So sieht das von Github aus:
                Am besten startest du noch mal mit dem aktuellen Github-Script.
                • Negalein
                  Negalein Global Moderator @Mic last edited by
                  @Mic sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
                  jetzt passt es.
                  DP wurden sofort angelegt.
                  • MartinK.
                    MartinK. @Mic last edited by
                    @Mic Absolut genial gemacht! Sogar für Anfänger wie mich alles zu verstehen 🙂 ... läuft auf anhieb!!! 😀 👍 👍
                      blackeagle998 last edited by blackeagle998
                      @Mic
                      Das Skript läuft wie immer super, solange ich mindestens eine VIS View angebe.
                      Ändere ich den Wert "const NUMBER_OF_VIS_VIEWS = 1;" auf 0, erhalte ich im LOG folgende Fehler:
                      javascript.0	2020-02-13 12:02:44.106	error	(10714) at process._tickCallback (internal/process/next_tick.js:68:7)
                      javascript.0	2020-02-13 12:02:44.106	error	(10714) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                      javascript.0	2020-02-13 12:02:44.105	error	(10714) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                      javascript.0	2020-02-13 12:02:44.105	error	(10714) at client.set.err (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:534:55)
                      javascript.0	2020-02-13 12:02:44.105	error	(10714) at err (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:318:38)
                      javascript.0	2020-02-13 12:02:44.105	error	(10714) at Object.<anonymous> (script.js.common.02_IO-Broker.Logfile:1708:44)
                      javascript.0	2020-02-13 12:02:44.105	error	(10714) at script.js.common.02_IO-Broker.Logfile:421:9
                      javascript.0	2020-02-13 12:02:44.104	error	(10714) at createUserStates (script.js.common.02_IO-Broker.Logfile:1629:43)
                      javascript.0	2020-02-13 12:02:44.103	error	(10714) Error in callback: TypeError: Cannot read property 'replace' of undefined
                      Die Zeilen 1627 bis 1633 enthalten folgenden Code:
                      Das soll nur als Hinweis dienen, da das Skript ja für die VIS Aufbereitung gedacht ist und somit mindestens eine VIS View vorhanden sein sollte.
                      • Mic
                        Mic Developer @blackeagle998 last edited by
                        @blackeagle998 sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
                        Vielen Dank für den Test. Habe ich in Version 4.7 korrigiert. Für ein Update reicht es, alles unterhalb des folgenden Kommentars zu ersetzen:
                        • Latzi
                          Latzi last edited by
                          @Mic
                          ich hab im Log folgende Fehlermeldungen:
                          2020-02-14 20:06:16.407 - error: rtspStream.0 (14568) uncaught exception: i is not defined
                          2020-02-14 20:06:16.408 - error: rtspStream.0 (14568) ReferenceError: i is not defined
                          2020-02-14 20:06:17.452 - error: host.Pi4-Server Caught by controller[43]: frame=95046 fps= 15 q=6.1 size= 315696kB time=01:45:32.56 bitrate= 408.4kbits/s speed= 1x
                          2020-02-14 20:06:17.452 - error: host.Pi4-Server Caught by controller[44]: frame=95054 fps= 15 q=3.9 size= 315727kB time=01:45:33.06 bitrate= 408.4kbits/s speed= 1x
                          2020-02-14 20:06:17.452 - error: host.Pi4-Server Caught by controller[45]: frame=95061 fps= 15 q=4.7 size= 315740kB time=01:45:33.64 bitrate= 408.4kbits/s speed= 1x
                          2020-02-14 20:06:17.452 - error: host.Pi4-Server Caught by controller[46]: frame=95069 fps= 15 q=5.0 size= 315772kB time=01:45:34.07 bitrate= 408.4kbits/s speed= 1x
                          2020-02-14 20:06:17.453 - error: host.Pi4-Server Caught by controller[47]: frame=95076 fps= 15 q=4.7 size= 315785kB time=01:45:34.65 bitrate= 408.4kbits/s speed= 1x
                          2020-02-14 20:06:17.453 - error: host.Pi4-Server Caught by controller[48]: frame=95084 fps= 15 q=4.6 size= 315819kB time=01:45:35.15 bitrate= 408.4kbits/s speed= 1x
                          2020-02-14 20:06:17.453 - error: host.Pi4-Server Caught by controller[49]: frame=95092 fps= 15 q=5.7 size= 315848kB time=01:45:35.66 bitrate= 408.4kbits/s speed= 1x
                          2020-02-14 20:06:17.453 - error: host.Pi4-Server Caught by controller[50]: frame=95100 fps= 15 q=4.7 size= 315864kB time=01:45:36.16 bitrate= 408.4kbits/s speed= 1x
                          2020-02-14 20:06:17.453 - error: host.Pi4-Server Caught by controller[51]: frame=95108 fps= 15 q=4.6 size= 315900kB time=01:45:36.66 bitrate= 408.4kbits/s speed= 1x
                          2020-02-14 20:06:17.453 - error: host.Pi4-Server Caught by controller[52]: frame=95115 fps= 15 q=5.0 size= 315932kB time=01:45:37.24 bitrate= 408.4kbits/s speed= 1x
                          2020-02-14 20:06:17.454 - error: host.Pi4-Server Caught by controller[53]: frame=95123 fps= 15 q=4.2 size= 315949kB time=01:45:37.74 bitrate= 408.4kbits/s speed= 1x
                          2020-02-14 20:06:17.454 - error: host.Pi4-Server Caught by controller[54]: frame=95131 fps= 15 q=4.7 size= 315975kB time=01:45:38.25 bitrate= 408.4kbits/s speed= 1x
                          2020-02-14 20:06:17.454 - error: host.Pi4-Server Caught by controller[55]: frame=95139 fps= 15 q=4.6 size= 316009kB time=01:45:38.75 bitrate= 408.4kbits/s speed= 1x
                          2020-02-14 20:06:17.465 - error: host.Pi4-Server Caught by controller[56]: frame=95146 fps= 15 q=6.0 size= 316021kB time=01:45:39.26 bitrate= 408.4kbits/s speed= 1x
                          2020-02-14 20:06:17.465 - error: host.Pi4-Server Caught by controller[57]: frame=95154 fps= 15 q=4.8 size= 316056kB time=01:45:39.76 bitrate= 408.4kbits/s speed= 1x
                          2020-02-14 20:06:17.465 - error: host.Pi4-Server Caught by controller[58]: frame=95162 fps= 15 q=3.6 size= 316087kB time=01:45:40.26 bitrate= 408.4kbits/s speed= 1x
                          2020-02-14 20:06:17.465 - error: host.Pi4-Server Caught by controller[59]: ReferenceError: i is not defined
                          2020-02-14 20:06:17.465 - error: host.Pi4-Server Caught by controller[59]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
                          2020-02-14 20:06:17.466 - error: host.Pi4-Server Caught by controller[59]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
                          2020-02-14 20:06:17.466 - error: host.Pi4-Server Caught by controller[59]: at VideoStream.emit (events.js:198:13)
                          2020-02-14 20:06:17.466 - error: host.Pi4-Server Caught by controller[59]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
                          2020-02-14 20:06:17.466 - error: host.Pi4-Server Caught by controller[59]: at Mpeg1Muxer.emit (events.js:198:13)
                          2020-02-14 20:06:17.466 - error: host.Pi4-Server Caught by controller[59]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
                          2020-02-14 20:06:17.467 - error: host.Pi4-Server Caught by controller[59]: at Socket.emit (events.js:198:13)
                          2020-02-14 20:06:17.467 - error: host.Pi4-Server Caught by controller[59]: at addChunk (_stream_readable.js:288:12)
                          2020-02-14 20:06:17.467 - error: host.Pi4-Server Caught by controller[59]: at readableAddChunk (_stream_readable.js:269:11)
                          2020-02-14 20:06:17.467 - error: host.Pi4-Server Caught by controller[59]: at Socket.Readable.push (_stream_readable.js:224:10)
                          2020-02-14 20:06:17.467 - error: host.Pi4-Server Caught by controller[59]: frame=95169 fps= 15 q=4.4 size= 316101kB time=01:45:40.84 bitrate= 408.4kbits/s speed= 1x
                          2020-02-14 20:06:17.467 - error: host.Pi4-Server Caught by controller[60]: frame=95177 fps= 15 q=5.3 size= 316135kB time=01:45:41.34 bitrate= 408.4kbits/s speed= 1x
                          Es wird mir im DP error aber nichts angezeigt. Ich habe auch nichts deratiges in der blacklist. Hast du eine Erklärung dafür?
                          Glasfaser Mic 2 Replies Last reply Reply Quote 0
                          • Glasfaser
                            Glasfaser @Latzi last edited by Glasfaser
                            @Latzi
                            Teste mal mit dem Skript von Mic , hast du dort eine Log Ausgabe ?
                            log('Error-Meldung', 'error');
                            log('Warn-Meldung', 'warn');
                            // Nochmal nach 2 Sekunden.
                            }, 2*1000);
                            // Nach 30 Sekunden noch eine Warnmeldung.
                                log('Neue Warn-Meldung nach 30 Sekunden', 'warn');
                            }, 30*1000);
                            Latzi 1 Reply Last reply Reply Quote 0
                            • Latzi
                              Latzi @Glasfaser last edited by
                              @Glasfaser ja, die Meldungen kommen. Liegt wohl an der Art und Weise wie rtspstream die Fehler generiert.
                              Danke dir für die Unterstützung!
                              • Glasfaser
                                @Latzi
                                Habe mal ein Fehler simuliert .... rtspstream wird im LOG angezeigt
                                Zeig doch mal deine Usereinstellung , für die ERROR Filterung.
                                • Latzi
                                  @Glasfaser
                                  mein Block error sieht folgendermaßen aus:
                                      filter_all:     [' - error:', ''],  // nur Logeinträge mit Level 'error'
                                      filter_any:     [''],
                                      merge:          true,
                                      jsonDateFormat: 'dd.mm. hh:mm',
                                      jsonLogLength:  200,
                                      jsonMaxLines:   60,
                                  Kannst du das bitte mal mit deinem Block vergleichen?
                                  • Glasfaser
                                    @Latzi sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
                                    Füge mal das ein :
                                        filter_all:     [' - error: ', ''],  // nur Logeinträge mit Level 'error'
                                        filter_any:     [''],
                                        merge:          true,
                                        jsonLogLength:  200,
                                        jsonMaxLines:   60,
                                    • Latzi
                                      @Glasfaser ändert leider nichts 😞
                                      • Glasfaser
                                        @Latzi
                                        Mhhh , habe gerade nochmal verglichen , dachte es hatte einfluss das nach dem - error: ein Leerzeichen fehlte ...
                                        Kann du den Error im Datenpunkt log sehen ?
                                        • Latzi
                                          @Glasfaser nein, ist darin nicht enthalten
                                          • Glasfaser
                                            @Latzi
                                            Da bin gerade überfragt ….. mehr kann ich dir im Moment leider nicht weiterhelfen , da ich gerade ein großes ? dazu habe …🤔
                                            Warte auf Mic
                                            617
                                            144052
