    4. Test Adapter fb-checkpresence v0.2.x
    • Neuschwansteini
      Neuschwansteini @afuerhoff last edited by
      @afuerhoff History-Adapter Error...
      hatte das hier schonmal angesprochen, kam damals einmal, dann war es weg.. jetzt kommt der Fehler immer, wenn ich etwas and er Config des FB-Checkpresence Adapters ändere:
      2020-02-12 16:40:41.667  - info: host.iobroker stopInstance system.adapter.fb-checkpresence.0 (force=false, process=true)
      2020-02-12 16:40:41.669  - info: host.iobroker stopInstance system.adapter.fb-checkpresence.0 send kill signal
      2020-02-12 16:40:42.225  - info: host.iobroker instance system.adapter.fb-checkpresence.0 terminated with code 156 (156)
      2020-02-12 16:40:44.975  - info: host.iobroker instance system.adapter.fb-checkpresence.0 started with pid 16504
      2020-02-12 16:40:47.198  - error: history.0 (14174) uncaught exception: Cannot read property 'push' of null
      2020-02-12 16:40:54.545  - error: fb-checkpresence.0 (16504) checkPresence: TypeError: Cannot read property 'history.0' of undefined
      2020-02-12 16:40:55.294  - error: fb-checkpresence.0 (16504) checkPresence: TypeError: Cannot read property 'history.0' of undefined
      2020-02-12 16:40:55.820  - error: fb-checkpresence.0 (16504) checkPresence: TypeError: Cannot read property 'history.0' of undefined
      2020-02-12 16:40:47.211  - error: history.0 (14174) TypeError: Cannot read property 'push' of null
          at storeCached (/opt/iobroker/node_modules/iobroker.history/main.js:182:34)
          at Object.objectChange (/opt/iobroker/node_modules/iobroker.history/main.js:131:21)
          at Immediate.options.objectChange.function.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1506:94)
          at runCallback (timers.js:705:18)
          at tryOnImmediate (timers.js:676:5)
          at processImmediate (timers.js:658:5)
      2020-02-12 16:41:13.873  - error: history.0 (14174) exception by stop: Cannot read property 'push' of null
      Sei so lieb und schau dir nochmal das starten und aufrufen von history an.. irgendwas läuft da ins leere..
      afuerhoff 2 Replies Last reply Reply Quote 0
      • afuerhoff
        afuerhoff Developer @Neuschwansteini last edited by
        @ilovegym
        Wird gemacht.
        • afuerhoff
          @ilovegym sagte in Test Adapter fb-checkpresence v0.2.x:
          Ich habe mir das mal angesehen. Ich kann den Fehler bei mir nicht nachstellen. Kannst Du den Loglevel mal auf Debug stellen und dann den Log posten.
          Neuschwansteini 1 Reply Last reply Reply Quote 0
          • Neuschwansteini
            @afuerhoff mach ich, hab wegen einem anderen Fehler ( kann mit den aktuellen Latest-Versionen keine Scripte speichern oder ändern ), gerade ein Admin-Downgrade auf 4.0.0 und javascript-adapter 4.3.4 am laufen..
              sigi234 Forum Testing Most Active @afuerhoff last edited by
              @afuerhoff
              Hallo, bekomme jetzt immer das:
              fb-checkpresence.0	2020-02-13 19:58:55.700	info	(8484) Sarah: No history before this day is available (lastVal = null)
              fb-checkpresence.0	2020-02-13 19:58:55.587	info	(8484) Ilse: No history before this day is available (lastVal = null)
              fb-checkpresence.0	2020-02-13 19:58:55.343	info	(8484) Sigi: No history before this day is available (lastVal = null)
              afuerhoff 1 Reply Last reply Reply Quote 0
              • afuerhoff
                afuerhoff Developer @sigi234 last edited by
                @sigi234
                Hallo, hast Du evtl. einen Alias in der History bei den Datenpunkten angegeben?
                  @afuerhoff sagte in Test Adapter fb-checkpresence v0.2.x:
                  @sigi234
                  • afuerhoff
                    @sigi234
                    Kannst Du einmal auf die Tabellenwerte in der History umschalten. Sind dort Werte vom Vortag oder früher vorhanden.
                      @sigi234
                      Ja
                      • afuerhoff
                        @sigi234
                        Das log changes interval steht bei Dir auf 5s. Ist das so gewollt? Der Adapter stellt den Wert auf 0 ein.
                          @sigi234
                          Was sollte man einstellen?
                          • afuerhoff
                            @sigi234
                            Wie gesagt. Der Adapter stellt 0 ein. Es werden also nur geänderte Werte gelogged.
                            Bei 5 wird alle 5s ein Wert geschrieben. Ich muss mal schauen, ob das der Grund ist für die LastVal Ausgabe.
                            • MathiasJ
                              MathiasJ last edited by
                              Die instanz ist wieder gelb 😞
                              und bringt folgende Ausgabe:
                              fb-checkpresence.0	2020-02-14 04:54:56.670	debug	(14899) checkPresence scheduled
                              fb-checkpresence.0	2020-02-14 04:54:56.662	debug	(14899) getActive [{"Name":"Mathias","Active":"false","Kommt":"14.02.2020 02:59:33","Geht":"14.02.2020 03:34:33"}
                              fb-checkpresence.0	2020-02-14 04:54:56.627	debug	(14899) getActive Mathias 0
                              fb-checkpresence.0	2020-02-14 04:54:56.625	debug	(14899) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\
                              fb-checkpresence.0	2020-02-14 04:54:56.599	debug	(14899) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schem
                              fb-checkpresence.0	2020-02-14 04:54:56.580	error	(14899) getActive: soapAction GetSpecificHostEntry -> {"statusCode":500,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://sche
                              fb-checkpresence.0	2020-02-14 04:54:56.505	debug	(14899) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schem
                              fb-checkpresence.0	2020-02-14 04:54:56.502	debug	(14899) getDeviceList: [{"Index":"1","IPAddress":"192.168.1.20","MACAddress":"94:87:E0:22:16:17","Active":"0","HostName":"Android","InterfaceType":"","X_AVM-DE_Port":"0","X_AVM-DE_Speed":"0","X_AVM-DE
                              fb-checkpresence.0	2020-02-14 04:54:56.472	debug	(14899) body <?xml version="1.0" encoding="UTF-8"?> <List> <!-- devicehosts :47 --> <Item> <Index>1</Index> <IPAddress>192.168.1.20</IPAddress> <MACAddress>94:87:E0:22:16:17</MACAddress> <Active>0</A
                              fb-checkpresence.0	2020-02-14 04:54:55.919	debug	(14899) response: 1 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\
                              fb-checkpresence.0	2020-02-14 04:54:55.874	debug	(14899) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schem
                              fb-checkpresence.0	2020-02-14 04:54:55.870	debug	(14899) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\
                              fb-checkpresence.0	2020-02-14 04:54:55.842	debug	(14899) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schem
                              Gruß,
                              Mathias
                                @sigi234
                                Neuer Log:
                                host.Medion(Test)	2020-02-14 11:00:00.057	info	instance system.adapter.darksky.0 started with pid 9112
                                fb-checkpresence.0	2020-02-14 10:59:13.160	info	(20816) Sarah: No history before this day is available (lastVal = null)
                                fb-checkpresence.0	2020-02-14 10:59:11.566	info	(20816) Ilse: No history before this day is available (lastVal = null)
                                fb-checkpresence.0	2020-02-14 10:58:50.920	info	(20816) Sigi: No history before this day is available (lastVal = null)
                                fb-checkpresence.0	2020-02-14 10:58:31.233	warn	at processImmediate (timers.js:658:5)
                                fb-checkpresence.0	2020-02-14 10:58:31.233	warn	at tryOnImmediate (timers.js:676:5)
                                fb-checkpresence.0	2020-02-14 10:58:31.233	warn	at runCallback (timers.js:705:18)
                                fb-checkpresence.0	2020-02-14 10:58:31.233	warn	at Immediate.setImmediate [as _onImmediate] (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\states\statesInRedis.js:227:41)
                                fb-checkpresence.0	2020-02-14 10:58:31.233	warn	at change (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:4794:71)
                                fb-checkpresence.0	2020-02-14 10:58:31.233	warn	at Object.cb (C:\Program Files\iobroker\Test\node_modules\iobroker.fb-checkpresence\main.js:491:82)
                                fb-checkpresence.0	2020-02-14 10:58:31.233	warn	(20816) TypeError: Cannot read property 'val' of undefined
                                  guergen @afuerhoff last edited by
                                  @afuerhoff Habe jetzt den Alias mal weggelassen wenn das ein Problem sein könnte. Nu habe ich zwar Einträge in der Tabelle, aber Grafana findet nichts:
                                  Und in den Log steht immer noch der Fehler:
                                  • afuerhoff
                                    afuerhoff Developer @guergen last edited by
                                    @guergen
                                    Die Meldung sollte nach einem Tag nicht mehr kommen. Ich brauche für die korrekte Funktion einen Eintrag vom Vortag oder davor.
                                    G sigi234 2 Replies Last reply Reply Quote 0
                                      @afuerhoff In der Tabelle oben drüber sind doch Einträge.... ansonsten kann ich Dir die morgen zur Verfügung stellen!
                                        Ist das selbe wie bei mir.
                                        MathiasJ 1 Reply Last reply Reply Quote 0
                                        • afuerhoff
                                          afuerhoff Developer @MathiasJ last edited by
                                          @MathiasJ sagte in Test Adapter fb-checkpresence v0.2.x:
                                          Hallo, dies ist ein "Internal Server Error". Die Fritzbox meldet den. Evtl. gab es Netzwerkprobleme oder ähnliches. Es ist eine Sammelfehler-Meldung der Fritzbox.
                                          Ist der Fehler wieder verschwunden?
                                          Vinze.nt 1 Reply Last reply Reply Quote 0
                                          • afuerhoff
                                            @guergen sagte in Test Adapter fb-checkpresence v0.2.x:
                                            Sorry. Hatte ich eben auf dem Handy nicht gesehen.
                                            31.7k
                                            79.8k
                                            avm fb-checkpresence fritzbox soap tr-064
                                            26
                                            259
                                            27764
