    4. Meine VIS
    Meine VIS
      helfi9999 @Guest last edited by
      @biker sorry wenn ich mich erst jetzt melde schau dir mal das Bild an
      falls du noch Hilfe brauchst melde dich.
      • Glasfaser
        Glasfaser @Guest last edited by Glasfaser
        @biker
        Nimm mal dieses TEST-Widget und füge es auf der Seite ein .
        [{"tpl":"tplHqButton","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","oid":"nothing_selected","min":"false","max":"true","iconName":"/icons-mfd-svg/info_error.svg","btIconWidth":"56","offsetAuto":"true","leftOffset":"15","topOffset":"55","timeAsInterval":"true","infoLeftFontSize":"12","infoFontRightSize":"12","infoLeftPaddingLeft":"15","infoLeftPaddingRight":"50","infoRightPaddingRight":"15","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"29px","top":"267px","z-index":"1000"},"widgetSet":"hqwidgets"},{"tpl":"tplHqButton","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","oid":"nothing_selected","min":"false","max":"true","iconName":"/icons-mfd-svg/info_ok.svg","btIconWidth":"56","offsetAuto":"true","leftOffset":"15","topOffset":"55","timeAsInterval":"true","infoLeftFontSize":"12","infoFontRightSize":"12","infoLeftPaddingLeft":"15","infoLeftPaddingRight":"50","infoRightPaddingRight":"15","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"27px","top":"348px","z-index":"1000"},"widgetSet":"hqwidgets"}]
        Mache später folgendes ,deinstalliere bitte den Adapter "Icons-mfd-svg" und installiere Ihn über die Katze neu .
        https://github.com/ioBroker/ioBroker.icons-mfd-svg
        und danach ein upload bei dem Adapter ..
        • Glasfaser
          Glasfaser @Glasfaser last edited by Glasfaser
          EDIT . Doppelpost
            A Former User last edited by
            @Glasfaser @helfi9999
            also sowas, fühle mich wie auf's Pferd gehoben. 🙂
            Dieses jqui-mfd-custom10 wurde mit V 0.6.15 (2015-09-15) (bluefox) add Custom10 to jqui-mfd eingeführt.
            Bei mir zeigt es sich aber nicht. Habe vor 3 Tagen das System mit einem IOBroker-Image, Update usw. neu aufgebaut. Anschließend ein Backup Stand 8.2.2020 wiederhergestellt. Irgendetwas ist dabei wohl zurückgeblieben.
            erzeugt wieder ein qui-mfd-undefined.
            das mach ich nun und berichte danach.
            • Glasfaser
              @biker sagte in Meine VIS:
              Das war ein (standard) Widget , mit dem Verweis zum icon
              ? 2 Replies Last reply Reply Quote 0
                A Former User @Glasfaser last edited by
                @Glasfaser sagte in Meine VIS:
                wenn das ein Standard Widget ist, dann ist hier etwas gehörig daneben gegangen, denn dieses steht hier nicht zur Auswahl obwohl ich dies von früher kenne. Beschäftige mich nur jetzt erst mit VIS.
                Mal schauen, was die Neuinstallation der icons-mfd-svg / png bringt.
                  das ist ein hqwidgets style Widgets, no Standard .. muss separat installiert werden.
                  • Glasfaser
                    … deshalb habe ich es in Klammern gesetzt 😉
                      Aufgeben will ich nicht -
                      @helfi9999 sagte in Meine VIS:
                      deinem Bild folgend muss ein jqui-mfd-custom10 Widged zur Verfügung stehen.
                      Nachdem ich den Adapter "Icons-mfd-svg" nun auf verschiedene Wege deinstalliert / installiert habe, reboot , vis neustart ... usw. stehen bei mir diese jqui* zur Auswahl. Ein *custom10 ist nicht dabei.
                        sigi234 Forum Testing Most Active @Guest last edited by sigi234
                        Du brauchst das:
                        Danach mal:
                        iobroker stop vis
                        iobroker upload vis
                        iobroker start vis
                        Dann, Browser Cache leeren. Editor starten, dann muss ein update found kommen!
                          A Former User @sigi234 last edited by
                          @sigi234
                          ist das erlösend 🙂 das war`s ! .. Granitblock auf Boden knall .. Super vielen Dank
                          Ich nutze dies als mein Einstiegsprojekt. Die eine oder andere Frage wird vielleicht offen bleiben .. komme dann auf das Angebot zurück
                            @biker 👍
                              A Former User @helfi9999 last edited by
                              @helfi9999
                              in View 300Küche enddeckt > javascript.0.TabletVis.Funksteckdose.Lichterkette
                              Schaltest du vielleicht 433 Mhz Steckdosen mit solchen Funk- Sende Modulen per Script ?
                              https://forum.iobroker.net/topic/3909/433-mhz-baumarkt-steckdosen-schalten-kleines-beispiel
                                @biker ja habe 433 Mhz Steckdosen übrig gehabt und habe mir von Sonoff die RF Bridge geholt und die in Iobroker eingebunden
                                  unendlich viele Möglichkeiten sind vorhanden .. Sonoff die RF Bridge .. 👍 Danke
                                  • Wszene
                                    Wszene last edited by
                                    Sehr schöne VIS
                                    Ich habe da mal eine Frage
                                    Wie hast du das in deiner Navigation mit den Aktiven Icons gemacht
                                    Also ich meine es wird ja immer der aktive View blau hervorgehoben
                                    Danke im Voraus
                                    Marcel
                                      helfi9999 @Wszene last edited by
                                      @Wszene Du brauchst folgende Sachen:
                                      Neues Textdokument (3).txt
                                      dann den 9999Header.txt: https://forum.iobroker.net/topic/24174/meine-vis/2
                                      und nicht vergessen die DP's anlegen.
                                      • Wszene
                                        Danke für die schnelle Antwort
                                        ich bin totaler Anfänger auf diesem Gebiet
                                        Kannst du mir das bitte etwas genauer erklären?
                                          @Wszene Du musst als erstes DP = Datenpunkte erstellen siehe Bild:
                                          dann das Script erstellen:
                                          dann das Widget erstellen :
                                          Wszene 1 Reply Last reply Reply Quote 0
                                          • Wszene
                                            Wszene @helfi9999 last edited by
                                            @helfi9999 Ich Danke dir
                                            kannst du mir evtl. das Script, als Export, zur Verfügung stellen?
                                            vis visualisierung
                                            18
                                            114
                                            23389
