    4. Test Adapter rtspStream v0.0.x GitHub
      Kuddel @dbweb last edited by
      @dbweb
      Error Log:
      host.ioBroker-MASTER	2020-02-14 09:08:32.089	info	Restart adapter system.adapter.rtspStream.0 because enabled
      host.ioBroker-MASTER	2020-02-14 09:08:32.089	info	instance system.adapter.rtspStream.0 terminated with code 0 (NO_ERROR)
      host.ioBroker-MASTER	2020-02-14 09:08:32.089	error	Caught by controller[4]: [h264 @ 0x55901b2783e0] Missing reference picture, default is 65582
      host.ioBroker-MASTER	2020-02-14 09:08:32.089	error	Caught by controller[3]: [h264 @ 0x55901b2783e0] Missing reference picture, default is 65580
      host.ioBroker-MASTER	2020-02-14 09:08:32.089	error	Caught by controller[2]: libpostproc 54. 7.100 / 54. 7.100
      host.ioBroker-MASTER	2020-02-14 09:08:32.089	error	Caught by controller[2]: libswresample 2. 9.100 / 2. 9.100
      host.ioBroker-MASTER	2020-02-14 09:08:32.089	error	Caught by controller[2]: libswscale 4. 8.100 / 4. 8.100
      host.ioBroker-MASTER	2020-02-14 09:08:32.089	error	Caught by controller[2]: libavresample 3. 7. 0 / 3. 7. 0
      host.ioBroker-MASTER	2020-02-14 09:08:32.089	error	Caught by controller[2]: libavfilter 6.107.100 / 6.107.100
      host.ioBroker-MASTER	2020-02-14 09:08:32.089	error	Caught by controller[2]: libavdevice 57. 10.100 / 57. 10.100
      host.ioBroker-MASTER	2020-02-14 09:08:32.089	error	Caught by controller[2]: libavformat 57. 83.100 / 57. 83.100
      host.ioBroker-MASTER	2020-02-14 09:08:32.089	error	Caught by controller[2]: libavcodec 57.107.100 / 57.107.100
      host.ioBroker-MASTER	2020-02-14 09:08:32.089	error	Caught by controller[2]: libavutil 55. 78.100 / 55. 78.100
      host.ioBroker-MASTER	2020-02-14 09:08:32.089	error	Caught by controller[1]: configuration: --prefix=/usr --extra-version=0ubuntu0.18.04.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --d
      host.ioBroker-MASTER	2020-02-14 09:08:32.089	error	Caught by controller[1]: built with gcc 7 (Ubuntu 7.3.0-16ubuntu3)
      host.ioBroker-MASTER	2020-02-14 09:08:32.088	error	Caught by controller[1]: ffmpeg version 3.4.6-0ubuntu0.18.04.1 Copyright (c) 2000-2019 the FFmpeg developers
      host.ioBroker-MASTER	2020-02-14 09:08:32.088	error	Caught by controller[0]: port: 88 }
      host.ioBroker-MASTER	2020-02-14 09:08:32.088	error	Caught by controller[0]: address: '::',
      host.ioBroker-MASTER	2020-02-14 09:08:32.088	error	Caught by controller[0]: syscall: 'listen',
      host.ioBroker-MASTER	2020-02-14 09:08:32.088	error	Caught by controller[0]: errno: 'EADDRINUSE',
      host.ioBroker-MASTER	2020-02-14 09:08:32.088	error	Caught by controller[0]: code: 'EADDRINUSE',
      host.ioBroker-MASTER	2020-02-14 09:08:32.088	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
      host.ioBroker-MASTER	2020-02-14 09:08:32.088	error	Caught by controller[0]: at rtspStream.onStateChange (/opt/iobroker/node_modules/iobroker.rtspStream/main.js:141:43)
      host.ioBroker-MASTER	2020-02-14 09:08:32.088	error	Caught by controller[0]: at new VideoStream (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:23:8)
      host.ioBroker-MASTER	2020-02-14 09:08:32.088	error	Caught by controller[0]: at VideoStream.pipeStreamToSocketServer (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:90:19)
      host.ioBroker-MASTER	2020-02-14 09:08:32.088	error	Caught by controller[0]: at new WebSocketServer (/opt/iobroker/node_modules/node-rtsp-stream/node_modules/ws/lib/websocket-server.js:75:20)
      host.ioBroker-MASTER	2020-02-14 09:08:32.088	error	Caught by controller[0]: at Server.listen (net.js:1415:7)
      host.ioBroker-MASTER	2020-02-14 09:08:32.088	error	Caught by controller[0]: at listenInCluster (net.js:1328:12)
      host.ioBroker-MASTER	2020-02-14 09:08:32.088	error	Caught by controller[0]: at Server.setupListenHandle [as _listen2] (net.js:1280:14)
      host.ioBroker-MASTER	2020-02-14 09:08:32.088	error	Caught by controller[0]: { Error: listen EADDRINUSE: address already in use :::88
      rtspStream.0	2020-02-14 09:08:31.579	info	(67433) Terminated (NO_ERROR): Without reason
      rtspStream.0	2020-02-14 09:08:31.578	info	(67433) terminating
      rtspStream.0	2020-02-14 09:08:31.076	error	(67433) Error: listen EADDRINUSE: address already in use :::88 at Server.setupListenHandle [as _listen2] (net.js:1280:14) at listenInCluster (net.js:1328:12) at Server.listen (net.js:1415:
      rtspStream.0	2020-02-14 09:08:31.076	error	(67433) uncaught exception: listen EADDRINUSE: address already in use :::88
      rtspStream.0	2020-02-14 09:08:31.067	info	(67433) Start stream on rtsp://admin:********@192.168.4.72:88/videoMainwith port 88{"-stats":"","-r":30}
      rtspStream.0	2020-02-14 09:08:31.067	warn	(67433) User ffmpeg options rejected, it contains invalid JSON string: {'-r':30}
      rtspStream.0	2020-02-14 09:08:31.065	warn	(67433) State Change: rtspStream.0.Balkon.startStream to true ack false
      rtspStream.0	2020-02-14 09:08:31.019	info	(67433) Stream Balkon starting Server on Port 88
      rtspStream.0	2020-02-14 09:08:31.019	info	(67433) Stream Balkon using TcpPort 88
      rtspStream.0	2020-02-14 09:08:31.012	info	(67433) Number of streams: 1
      rtspStream.0	2020-02-14 09:08:30.973	info	(67433) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.rtspStream, node: v10.17.0
      host.ioBroker-MASTER	2020-02-14 09:08:29.952	info	instance system.adapter.rtspStream.0 started with pid 67433
      host.ioBroker-MASTER	2020-02-14 09:08:29.942	info	"system.adapter.rtspStream.0" enabled
      dbweb 1 Reply Last reply Reply Quote 0
      • dbweb
        dbweb @Kuddel last edited by
        @Kuddel ändere bitte die ports wie oben angegeben. Du hast die Meldung "port 88 already in use" im Log.
        • dbweb
          dbweb @tob1 last edited by
          @tob1 dein iFrame ist relativ klein, kannst du mal z.B. 320x240 als Grösse angeben?
          Du kannst das auch in den Objekten ändern ohne in der adapterkonfig zu löschen und neu einzugeben. danach stream stoppen und starten und es sollte sich ändern.
          tob1 1 Reply Last reply Reply Quote 0
          • tob1
            tob1 @dbweb last edited by
            @dbweb
            das iFrame ist schon auf 720px Breite eingestellt.
            Ich hatte den Stream nun im Adapter mit 1920x1080 angegeben, da mir @el_malto sagte ich könne das Widget einfach entsprechend anpassen.
            Geht das doch nicht so einfach und ich brauche immer einen Stream für die entsprechende Widgetgröße?
            @el_malto said in Test Adapter rtspStream v0.0.x GitHub:
            Du brauchst dafür keine zwei Streams im Adapter einrichten. Du kannst bei beiden Views den gleichen Stream verwenden. Die Auflösung die du im Adapter angibst, ist die Auslösung in der ffmpeg den Stream convertiert. Wenn du den Stream in Vollbild angucken willst, würde ich im Adapter auch die volle Auflösung der Kamera einstellen um auch die beste Qualität zu haben. In der VIS kannst du das Widget ja in der Größe frei skalieren.
            Dabei fällt mir gerade noch etwas auf.
            Wenn ich im Adapter 720x480 eingebe, und das iFrame Widget auf die gleiche Größe einstelle, dann ist das angezeigte Bild immer etwas kleiner (ca. 5px rundherum). Ist das korrekt so?
            K E 2 Replies Last reply Reply Quote 0
              Kuddel @dbweb last edited by Kuddel
              @dbweb ich habe den Port jetzt auf 8086 geändert.
              Leider bekomme ich keine Anzeige:
              Link: http://192.168.4.31:8086/
              EDIT: jetzt geht es doch
                Kuddel @tob1 last edited by
                @tob1 ich habe jetzt die gleichen probleme mit den scrollbalken
                • Latzi
                  Latzi last edited by Latzi
                  @dbweb kann jede beliebige Auflösung eingestellt werden?
                  Ich habe gestern 800x600 eingestellt und ein total verschobenes Bild erhalten (Standard-VGA mit 640x480 sowie 1024x768 , 1920x1080, und 320x240 funktionieren tadellos), liegt vielleicht auch an der Kamera.
                  Edit: Ein Hausmeister-Thema hab ich noch:
                  Der Name des DP ffmpegOptions sollte IMHO geändert werden 😉
                    Kanufreak @dbweb last edited by
                    Guten Abend an alle,
                    seitdem ich meine Einstellungen bezüglich Framerate angepasst hatte, läuft der Adapter ohne Crash!
                    Seit Gestern Nacht kein negativer Eintrag im Log.
                    Als ich aber eben von der Arbeit kam, stellte ich fest, das kein Bild mehr auf der VIS angezeigt wurde.
                    Mit klick auf startStream und kurzer Wartezeit (ca. 30 Sekunden) läuft der Stream wieder.
                    Allerdings einstehen folgende Log-Einträge:
                    2020-02-14 19:35:22.059 - debug: rtspStream.0 (10387) system.adapter.admin.0: logging true
                    2020-02-14 19:35:49.266 - error: rtspStream.0 (10387) uncaught exception: i is not defined
                    2020-02-14 19:35:49.267 - error: rtspStream.0 (10387) ReferenceError: i is not defined
                    at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
                    at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
                    at VideoStream.emit (events.js:198:13)
                    at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
                    at Mpeg1Muxer.emit (events.js:198:13)
                    at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
                    at Socket.emit (events.js:198:13)
                    at addChunk (_stream_readable.js:288:12)
                    at readableAddChunk (_stream_readable.js:269:11)
                    at Socket.Readable.push (_stream_readable.js:224:10)
                    2020-02-14 19:35:49.276 - error: rtspStream.0 (10387) uncaught exception: i is not defined
                    2020-02-14 19:35:49.277 - error: rtspStream.0 (10387) ReferenceError: i is not defined
                    2020-02-14 19:35:49.285 - error: rtspStream.0 (10387) uncaught exception: i is not defined
                    2020-02-14 19:35:49.286 - error: rtspStream.0 (10387) ReferenceError: i is not defined
                    2020-02-14 19:35:49.528 - error: rtspStream.0 (10387) uncaught exception: i is not defined
                    2020-02-14 19:35:49.529 - error: rtspStream.0 (10387) ReferenceError: i is not defined
                    2020-02-14 19:35:49.768 - error: rtspStream.0 (10387) uncaught exception: i is not defined
                    2020-02-14 19:35:49.769 - error: rtspStream.0 (10387) ReferenceError: i is not defined
                    2020-02-14 19:35:49.780 - info: rtspStream.0 (10387) terminating
                    2020-02-14 19:35:49.782 - info: rtspStream.0 (10387) Terminated (NO_ERROR): Without reason
                    2020-02-14 19:35:49.796 - error: rtspStream.0 (10387) uncaught exception: i is not defined
                    2020-02-14 19:35:49.797 - error: rtspStream.0 (10387) ReferenceError: i is not defined
                    2020-02-14 19:35:50.027 - error: rtspStream.0 (10387) uncaught exception: i is not defined
                    2020-02-14 19:35:50.028 - error: rtspStream.0 (10387) ReferenceError: i is not defined
                    2020-02-14 19:35:50.048 - error: rtspStream.0 (10387) uncaught exception: i is not defined
                    2020-02-14 19:35:50.050 - error: rtspStream.0 (10387) ReferenceError: i is not defined
                    2020-02-14 19:35:50.285 - error: rtspStream.0 (10387) uncaught exception: i is not defined
                    2020-02-14 19:35:50.371 - error: host.raspberrypi4 Caught by controller[2]: frame=846180 fps= 11 q=6.3 size= 3004779kB time=20:36:26.82 bitrate= 331.8kbits/s dup=0 drop=478156 speed= 1x
                    2020-02-14 19:35:50.372 - error: host.raspberrypi4 Caught by controller[3]: frame=846180 fps= 11 q=6.3 size= 3004792kB time=20:36:27.33 bitrate= 331.8kbits/s dup=0 drop=478166 speed= 1x
                    2020-02-14 19:35:50.372 - error: host.raspberrypi4 Caught by controller[4]: frame=846180 fps= 11 q=6.3 size= 3004802kB time=20:36:27.83 bitrate= 331.8kbits/s dup=0 drop=478176 speed= 1x
                    2020-02-14 19:35:50.372 - error: host.raspberrypi4 Caught by controller[5]: frame=846180 fps= 11 q=6.3 size= 3004819kB time=20:36:28.48 bitrate= 331.8kbits/s dup=0 drop=478186 speed= 1x
                    2020-02-14 19:35:50.372 - error: host.raspberrypi4 Caught by controller[6]: frame=846180 fps= 11 q=6.3 size= 3004829kB time=20:36:28.98 bitrate= 331.8kbits/s dup=0 drop=478197 speed= 1x
                    2020-02-14 19:35:50.372 - error: host.raspberrypi4 Caught by controller[7]: frame=846180 fps= 11 q=6.3 size= 3004842kB time=20:36:29.56 bitrate= 331.8kbits/s dup=0 drop=478207 speed= 1x
                    2020-02-14 19:35:50.372 - error: host.raspberrypi4 Caught by controller[8]: frame=846180 fps= 11 q=6.3 size= 3004856kB time=20:36:30.06 bitrate= 331.8kbits/s dup=0 drop=478216 speed= 1x
                    2020-02-14 19:35:50.373 - error: host.raspberrypi4 Caught by controller[9]: frame=846180 fps= 11 q=6.3 size= 3004866kB time=20:36:30.57 bitrate= 331.8kbits/s dup=0 drop=478228 speed= 1x
                    2020-02-14 19:35:50.373 - error: host.raspberrypi4 Caught by controller[10]: frame=846180 fps= 11 q=6.3 size= 3004876kB time=20:36:30.93 bitrate= 331.8kbits/s dup=0 drop=478238 speed= 1x
                    2020-02-14 19:35:50.373 - error: host.raspberrypi4 Caught by controller[11]: frame=846180 fps= 11 q=6.3 size= 3004889kB time=20:36:31.57 bitrate= 331.8kbits/s dup=0 drop=478248 speed= 1x
                    2020-02-14 19:35:50.373 - error: host.raspberrypi4 Caught by controller[12]: frame=846180 fps= 11 q=6.3 size= 3004899kB time=20:36:31.93 bitrate= 331.8kbits/s dup=0 drop=478258 speed= 1x
                    2020-02-14 19:35:50.373 - error: host.raspberrypi4 Caught by controller[13]: frame=846180 fps= 11 q=6.3 size= 3004909kB time=20:36:32.43 bitrate= 331.8kbits/s dup=0 drop=478268 speed= 1x
                    2020-02-14 19:35:50.373 - error: host.raspberrypi4 Caught by controller[14]: frame=846180 fps= 11 q=6.3 size= 3004923kB time=20:36:33.01 bitrate= 331.8kbits/s dup=0 drop=478278 speed= 1x
                    2020-02-14 19:35:50.373 - error: host.raspberrypi4 Caught by controller[15]: frame=846180 fps= 11 q=6.3 size= 3004936kB time=20:36:33.51 bitrate= 331.8kbits/s dup=0 drop=478289 speed= 1x
                    2020-02-14 19:35:50.373 - error: host.raspberrypi4 Caught by controller[16]: frame=846180 fps= 11 q=6.3 size= 3004950kB time=20:36:34.16 bitrate= 331.8kbits/s dup=0 drop=478299 speed= 1x
                    2020-02-14 19:35:50.374 - error: host.raspberrypi4 Caught by controller[17]: frame=846180 fps= 11 q=6.3 size= 3004963kB time=20:36:34.67 bitrate= 331.8kbits/s dup=0 drop=478309 speed= 1x
                    2020-02-14 19:35:50.374 - error: host.raspberrypi4 Caught by controller[18]: frame=846180 fps= 11 q=6.3 size= 3004970kB time=20:36:35.03 bitrate= 331.8kbits/s dup=0 drop=478320 speed= 1x
                    2020-02-14 19:35:50.374 - error: host.raspberrypi4 Caught by controller[19]: frame=846180 fps= 11 q=6.3 size= 3004983kB time=20:36:35.53 bitrate= 331.8kbits/s dup=0 drop=478331 speed= 1x
                    2020-02-14 19:35:50.374 - error: host.raspberrypi4 Caught by controller[20]: frame=846180 fps= 11 q=6.3 size= 3004993kB time=20:36:36.03 bitrate= 331.8kbits/s dup=0 drop=478340 speed= 1x
                    2020-02-14 19:35:50.374 - error: host.raspberrypi4 Caught by controller[21]: frame=846180 fps= 11 q=6.3 size= 3005007kB time=20:36:36.54 bitrate= 331.8kbits/s dup=0 drop=478351 speed= 1x
                    2020-02-14 19:35:50.374 - error: host.raspberrypi4 Caught by controller[22]: frame=846180 fps= 11 q=6.3 size= 3005023kB time=20:36:37.26 bitrate= 331.8kbits/s dup=0 drop=478360 speed= 1x
                    2020-02-14 19:35:50.374 - error: host.raspberrypi4 Caught by controller[23]: frame=846180 fps= 11 q=6.3 size= 3005030kB time=20:36:37.62 bitrate= 331.8kbits/s dup=0 drop=478371 speed= 1x
                    2020-02-14 19:35:50.375 - error: host.raspberrypi4 Caught by controller[24]: frame=846180 fps= 11 q=6.3 size= 3005047kB time=20:36:38.26 bitrate= 331.8kbits/s dup=0 drop=478381 speed= 1x
                    2020-02-14 19:35:50.375 - error: host.raspberrypi4 Caught by controller[25]: frame=846180 fps= 11 q=6.3 size= 3005053kB time=20:36:38.62 bitrate= 331.8kbits/s dup=0 drop=478392 speed= 1x
                    2020-02-14 19:35:50.375 - error: host.raspberrypi4 Caught by controller[26]: frame=846180 fps= 11 q=6.3 size= 3005067kB time=20:36:39.13 bitrate= 331.8kbits/s dup=0 drop=478402 speed= 1x
                    2020-02-14 19:35:50.375 - error: host.raspberrypi4 Caught by controller[27]: frame=846180 fps= 11 q=6.3 size= 3005080kB time=20:36:39.78 bitrate= 331.8kbits/s dup=0 drop=478411 speed= 1x
                    2020-02-14 19:35:50.375 - error: host.raspberrypi4 Caught by controller[28]: frame=846180 fps= 11 q=6.3 size= 3005090kB time=20:36:40.21 bitrate= 331.8kbits/s dup=0 drop=478422 speed= 1x
                    2020-02-14 19:35:50.375 - error: host.raspberrypi4 Caught by controller[29]: frame=846180 fps= 11 q=6.3 size= 3005104kB time=20:36:40.71 bitrate= 331.8kbits/s dup=0 drop=478431 speed= 1x
                    2020-02-14 19:35:50.375 - error: host.raspberrypi4 Caught by controller[30]: frame=846180 fps= 11 q=6.3 size= 3005117kB time=20:36:41.36 bitrate= 331.8kbits/s dup=0 drop=478442 speed= 1x
                    2020-02-14 19:35:50.376 - error: host.raspberrypi4 Caught by controller[31]: frame=846180 fps= 11 q=6.3 size= 3005127kB time=20:36:41.72 bitrate= 331.8kbits/s dup=0 drop=478453 speed= 1x
                    2020-02-14 19:35:50.376 - error: host.raspberrypi4 Caught by controller[32]: frame=846180 fps= 11 q=6.3 size= 3005141kB time=20:36:42.37 bitrate= 331.8kbits/s dup=0 drop=478462 speed= 1x
                    2020-02-14 19:35:50.376 - error: host.raspberrypi4 Caught by controller[33]: frame=846180 fps= 11 q=6.3 size= 3005151kB time=20:36:42.73 bitrate= 331.8kbits/s dup=0 drop=478474 speed= 1x
                    2020-02-14 19:35:50.376 - error: host.raspberrypi4 Caught by controller[34]: frame=846180 fps= 11 q=6.3 size= 3005161kB time=20:36:43.23 bitrate= 331.8kbits/s dup=0 drop=478483 speed= 1x
                    2020-02-14 19:35:50.376 - error: host.raspberrypi4 Caught by controller[35]: frame=846180 fps= 11 q=6.3 size= 3005174kB time=20:36:43.73 bitrate= 331.8kbits/s dup=0 drop=478494 speed= 1x
                    2020-02-14 19:35:50.376 - error: host.raspberrypi4 Caught by controller[36]: frame=846180 fps= 11 q=6.3 size= 3005184kB time=20:36:44.24 bitrate= 331.8kbits/s dup=0 drop=478504 speed= 1x
                    2020-02-14 19:35:50.376 - error: host.raspberrypi4 Caught by controller[37]: frame=846180 fps= 11 q=6.3 size= 3005197kB time=20:36:44.74 bitrate= 331.8kbits/s dup=0 drop=478515 speed= 1x
                    2020-02-14 19:35:50.377 - error: host.raspberrypi4 Caught by controller[38]: frame=846180 fps= 11 q=6.3 size= 3005208kB time=20:36:45.25 bitrate= 331.8kbits/s dup=0 drop=478524 speed= 1x
                    2020-02-14 19:35:50.377 - error: host.raspberrypi4 Caught by controller[39]: frame=846180 fps= 11 q=6.3 size= 3005224kB time=20:36:45.97 bitrate= 331.8kbits/s dup=0 drop=478534 speed= 1x
                    2020-02-14 19:35:50.377 - error: host.raspberrypi4 Caught by controller[40]: frame=846180 fps= 11 q=6.3 size= 3005234kB time=20:36:46.33 bitrate= 331.8kbits/s dup=0 drop=478544 speed= 1x
                    2020-02-14 19:35:50.377 - error: host.raspberrypi4 Caught by controller[41]: frame=846180 fps= 11 q=6.3 size= 3005244kB time=20:36:46.83 bitrate= 331.8kbits/s dup=0 drop=478555 speed= 1x
                    2020-02-14 19:35:50.377 - error: host.raspberrypi4 Caught by controller[42]: frame=846180 fps= 11 q=6.3 size= 3005258kB time=20:36:47.40 bitrate= 331.8kbits/s dup=0 drop=478565 speed= 1x
                    2020-02-14 19:35:50.377 - error: host.raspberrypi4 Caught by controller[43]: frame=846180 fps= 11 q=6.3 size= 3005268kB time=20:36:47.83 bitrate= 331.8kbits/s dup=0 drop=478576 speed= 1x
                    2020-02-14 19:35:50.377 - error: host.raspberrypi4 Caught by controller[44]: frame=846180 fps= 11 q=6.3 size= 3005281kB time=20:36:48.34 bitrate= 331.8kbits/s dup=0 drop=478586 speed= 1x
                    2020-02-14 19:35:50.377 - error: host.raspberrypi4 Caught by controller[45]: frame=846180 fps= 11 q=6.3 size= 3005291kB time=20:36:48.84 bitrate= 331.8kbits/s dup=0 drop=478597 speed= 1x
                    2020-02-14 19:35:50.378 - error: host.raspberrypi4 Caught by controller[46]: frame=846180 fps= 11 q=6.3 size= 3005305kB time=20:36:49.42 bitrate= 331.8kbits/s dup=0 drop=478606 speed= 1x
                    2020-02-14 19:35:50.378 - error: host.raspberrypi4 Caught by controller[47]: frame=846180 fps= 11 q=6.3 size= 3005321kB time=20:36:50.07 bitrate= 331.8kbits/s dup=0 drop=478616 speed= 1x
                    2020-02-14 19:35:50.378 - error: host.raspberrypi4 Caught by controller[48]: frame=846180 fps= 11 q=6.3 size= 3005328kB time=20:36:50.43 bitrate= 331.8kbits/s dup=0 drop=478627 speed= 1x
                    2020-02-14 19:35:50.378 - error: host.raspberrypi4 Caught by controller[49]: frame=846180 fps= 11 q=6.3 size= 3005342kB time=20:36:50.93 bitrate= 331.8kbits/s dup=0 drop=478637 speed= 1x
                    2020-02-14 19:35:50.378 - error: host.raspberrypi4 Caught by controller[50]: frame=846180 fps= 11 q=6.3 size= 3005375kB time=20:36:52.43 bitrate= 331.8kbits/s dup=0 drop=478647 speed= 1x
                    2020-02-14 19:35:50.378 - error: host.raspberrypi4 Caught by controller[51]: frame=846180 fps= 11 q=6.3 size= 3005385kB time=20:36:52.93 bitrate= 331.7kbits/s dup=0 drop=478658 speed= 1x
                    2020-02-14 19:35:50.378 - error: host.raspberrypi4 Caught by controller[52]: frame=846180 fps= 11 q=6.3 size= 3005398kB time=20:36:53.44 bitrate= 331.7kbits/s dup=0 drop=478668 speed= 1x
                    frame=846180 fps= 11 q=6.3 size= 3005409kB time=20:36:53.94 bitrate= 331.7kbits/s dup=0 drop=478678 speed= 1x
                    frame=846180 fps= 11 q=6.3 size= 3005422kB time=20:36:54.52 bitrate= 331.7kbits/s dup=0 drop=478688 speed= 1x
                    2020-02-14 19:35:50.379 - error: host.raspberrypi4 Caught by controller[53]: frame=846180 fps= 11 q=6.3 size= 3005435kB time=20:36:55.02 bitrate= 331.7kbits/s dup=0 drop=478699 speed= 1x
                    2020-02-14 19:35:50.379 - error: host.raspberrypi4 Caught by controller[54]: frame=846180 fps= 11 q=6.3 size= 3005449kB time=20:36:55.60 bitrate= 331.7kbits/s dup=0 drop=478708 speed= 1x
                    2020-02-14 19:35:50.379 - error: host.raspberrypi4 Caught by controller[55]: frame=846180 fps= 11 q=6.3 size= 3005459kB time=20:36:56.03 bitrate= 331.7kbits/s dup=0 drop=478719 speed= 1x
                    2020-02-14 19:35:50.379 - error: host.raspberrypi4 Caught by controller[56]: ReferenceError: i is not defined
                    2020-02-14 19:35:50.379 - error: host.raspberrypi4 Caught by controller[56]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
                    2020-02-14 19:35:50.379 - error: host.raspberrypi4 Caught by controller[56]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
                    2020-02-14 19:35:50.379 - error: host.raspberrypi4 Caught by controller[56]: at VideoStream.emit (events.js:198:13)
                    2020-02-14 19:35:50.379 - error: host.raspberrypi4 Caught by controller[56]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
                    2020-02-14 19:35:50.380 - error: host.raspberrypi4 Caught by controller[56]: at Mpeg1Muxer.emit (events.js:198:13)
                    2020-02-14 19:35:50.380 - error: host.raspberrypi4 Caught by controller[56]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
                    2020-02-14 19:35:50.380 - error: host.raspberrypi4 Caught by controller[56]: at Socket.emit (events.js:198:13)
                    2020-02-14 19:35:50.380 - error: host.raspberrypi4 Caught by controller[56]: at addChunk (_stream_readable.js:288:12)
                    2020-02-14 19:35:50.380 - error: host.raspberrypi4 Caught by controller[56]: at readableAddChunk (_stream_readable.js:269:11)
                    2020-02-14 19:35:50.380 - error: host.raspberrypi4 Caught by controller[56]: at Socket.Readable.push (_stream_readable.js:224:10)
                    2020-02-14 19:35:50.380 - error: host.raspberrypi4 Caught by controller[57]: ReferenceError: i is not defined
                    2020-02-14 19:35:50.380 - error: host.raspberrypi4 Caught by controller[57]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
                    2020-02-14 19:35:50.381 - error: host.raspberrypi4 Caught by controller[57]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
                    2020-02-14 19:35:50.381 - error: host.raspberrypi4 Caught by controller[57]: at VideoStream.emit (events.js:198:13)
                    2020-02-14 19:35:50.381 - error: host.raspberrypi4 Caught by controller[57]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
                    2020-02-14 19:35:50.381 - error: host.raspberrypi4 Caught by controller[57]: at Mpeg1Muxer.emit (events.js:198:13)
                    2020-02-14 19:35:50.381 - error: host.raspberrypi4 Caught by controller[57]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
                    2020-02-14 19:35:50.381 - error: host.raspberrypi4 Caught by controller[57]: at Socket.emit (events.js:198:13)
                    2020-02-14 19:35:50.381 - error: host.raspberrypi4 Caught by controller[57]: at addChunk (_stream_readable.js:288:12)
                    2020-02-14 19:35:50.381 - error: host.raspberrypi4 Caught by controller[57]: at readableAddChunk (_stream_readable.js:269:11)
                    2020-02-14 19:35:50.382 - error: host.raspberrypi4 Caught by controller[57]: at Socket.Readable.push (_stream_readable.js:224:10)
                    2020-02-14 19:35:50.382 - error: host.raspberrypi4 Caught by controller[58]: ReferenceError: i is not defined
                    2020-02-14 19:35:50.382 - error: host.raspberrypi4 Caught by controller[58]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
                    2020-02-14 19:35:50.382 - error: host.raspberrypi4 Caught by controller[58]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
                    2020-02-14 19:35:50.382 - error: host.raspberrypi4 Caught by controller[58]: at VideoStream.emit (events.js:198:13)
                    2020-02-14 19:35:50.382 - error: host.raspberrypi4 Caught by controller[58]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
                    2020-02-14 19:35:50.382 - error: host.raspberrypi4 Caught by controller[58]: at Mpeg1Muxer.emit (events.js:198:13)
                    2020-02-14 19:35:50.383 - error: host.raspberrypi4 Caught by controller[58]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
                    2020-02-14 19:35:50.383 - error: host.raspberrypi4 Caught by controller[58]: at Socket.emit (events.js:198:13)
                    2020-02-14 19:35:50.383 - error: host.raspberrypi4 Caught by controller[58]: at addChunk (_stream_readable.js:288:12)
                    2020-02-14 19:35:50.383 - error: host.raspberrypi4 Caught by controller[58]: at readableAddChunk (_stream_readable.js:269:11)
                    2020-02-14 19:35:50.383 - error: host.raspberrypi4 Caught by controller[58]: at Socket.Readable.push (_stream_readable.js:224:10)
                    2020-02-14 19:35:50.383 - error: host.raspberrypi4 Caught by controller[59]: ReferenceError: i is not defined
                    2020-02-14 19:35:50.383 - error: host.raspberrypi4 Caught by controller[59]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
                    2020-02-14 19:35:50.383 - error: host.raspberrypi4 Caught by controller[59]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
                    2020-02-14 19:35:50.384 - error: host.raspberrypi4 Caught by controller[59]: at VideoStream.emit (events.js:198:13)
                    2020-02-14 19:35:50.384 - error: host.raspberrypi4 Caught by controller[59]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
                    2020-02-14 19:35:50.384 - error: host.raspberrypi4 Caught by controller[59]: at Mpeg1Muxer.emit (events.js:198:13)
                    2020-02-14 19:35:50.384 - error: host.raspberrypi4 Caught by controller[59]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
                    2020-02-14 19:35:50.384 - error: host.raspberrypi4 Caught by controller[59]: at Socket.emit (events.js:198:13)
                    2020-02-14 19:35:50.384 - error: host.raspberrypi4 Caught by controller[59]: at addChunk (_stream_readable.js:288:12)
                    2020-02-14 19:35:50.384 - error: host.raspberrypi4 Caught by controller[59]: at readableAddChunk (_stream_readable.js:269:11)
                    2020-02-14 19:35:50.384 - error: host.raspberrypi4 Caught by controller[59]: at Socket.Readable.push (_stream_readable.js:224:10)
                    2020-02-14 19:35:50.385 - error: host.raspberrypi4 Caught by controller[60]: frame=846180 fps= 11 q=6.3 size= 3005472kB time=20:36:56.61 bitrate= 331.7kbits/s dup=0 drop=478729 speed= 1x
                    2020-02-14 19:35:50.385 - error: host.raspberrypi4 Caught by controller[61]: ReferenceError: i is not defined
                    2020-02-14 19:35:50.385 - error: host.raspberrypi4 Caught by controller[61]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
                    2020-02-14 19:35:50.385 - error: host.raspberrypi4 Caught by controller[61]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
                    2020-02-14 19:35:50.385 - error: host.raspberrypi4 Caught by controller[61]: at VideoStream.emit (events.js:198:13)
                    2020-02-14 19:35:50.385 - error: host.raspberrypi4 Caught by controller[61]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
                    2020-02-14 19:35:50.385 - error: host.raspberrypi4 Caught by controller[61]: at Mpeg1Muxer.emit (events.js:198:13)
                    2020-02-14 19:35:50.386 - error: host.raspberrypi4 Caught by controller[61]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
                    2020-02-14 19:35:50.386 - error: host.raspberrypi4 Caught by controller[61]: at Socket.emit (events.js:198:13)
                    2020-02-14 19:35:50.386 - error: host.raspberrypi4 Caught by controller[61]: at addChunk (_stream_readable.js:288:12)
                    2020-02-14 19:35:50.386 - error: host.raspberrypi4 Caught by controller[61]: at readableAddChunk (_stream_readable.js:269:11)
                    2020-02-14 19:35:50.386 - error: host.raspberrypi4 Caught by controller[61]: at Socket.Readable.push (_stream_readable.js:224:10)
                    2020-02-14 19:35:50.386 - error: host.raspberrypi4 Caught by controller[62]: ReferenceError: i is not defined
                    2020-02-14 19:35:50.386 - error: host.raspberrypi4 Caught by controller[62]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
                    2020-02-14 19:35:50.386 - error: host.raspberrypi4 Caught by controller[62]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
                    2020-02-14 19:35:50.387 - error: host.raspberrypi4 Caught by controller[62]: at VideoStream.emit (events.js:198:13)
                    2020-02-14 19:35:50.387 - error: host.raspberrypi4 Caught by controller[62]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
                    2020-02-14 19:35:50.387 - error: host.raspberrypi4 Caught by controller[62]: at Mpeg1Muxer.emit (events.js:198:13)
                    2020-02-14 19:35:50.387 - error: host.raspberrypi4 Caught by controller[62]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
                    2020-02-14 19:35:50.387 - error: host.raspberrypi4 Caught by controller[62]: at Socket.emit (events.js:198:13)
                    2020-02-14 19:35:50.387 - error: host.raspberrypi4 Caught by controller[62]: at addChunk (_stream_readable.js:288:12)
                    2020-02-14 19:35:50.387 - error: host.raspberrypi4 Caught by controller[62]: at readableAddChunk (_stream_readable.js:269:11)
                    2020-02-14 19:35:50.387 - error: host.raspberrypi4 Caught by controller[62]: at Socket.Readable.push (_stream_readable.js:224:10)
                    2020-02-14 19:35:50.388 - error: host.raspberrypi4 Caught by controller[63]: ReferenceError: i is not defined
                    2020-02-14 19:35:50.388 - error: host.raspberrypi4 Caught by controller[63]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
                    2020-02-14 19:35:50.388 - error: host.raspberrypi4 Caught by controller[63]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
                    2020-02-14 19:35:50.388 - error: host.raspberrypi4 Caught by controller[63]: at VideoStream.emit (events.js:198:13)
                    2020-02-14 19:35:50.388 - error: host.raspberrypi4 Caught by controller[63]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
                    2020-02-14 19:35:50.388 - error: host.raspberrypi4 Caught by controller[63]: at Mpeg1Muxer.emit (events.js:198:13)
                    2020-02-14 19:35:50.388 - error: host.raspberrypi4 Caught by controller[63]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
                    2020-02-14 19:35:50.388 - error: host.raspberrypi4 Caught by controller[63]: at Socket.emit (events.js:198:13)
                    2020-02-14 19:35:50.389 - error: host.raspberrypi4 Caught by controller[63]: at addChunk (_stream_readable.js:288:12)
                    2020-02-14 19:35:50.389 - error: host.raspberrypi4 Caught by controller[63]: at readableAddChunk (_stream_readable.js:269:11)
                    2020-02-14 19:35:50.389 - error: host.raspberrypi4 Caught by controller[63]: at Socket.Readable.push (_stream_readable.js:224:10)
                    2020-02-14 19:35:50.389 - error: host.raspberrypi4 Caught by controller[64]: frame=846180 fps= 11 q=6.3 size= 3005482kB time=20:36:57.11 bitrate= 331.7kbits/s dup=0 drop=478739 speed= 1x
                    2020-02-14 19:35:50.389 - error: host.raspberrypi4 Caught by controller[65]: ReferenceError: i is not defined
                    2020-02-14 19:35:50.389 - error: host.raspberrypi4 Caught by controller[65]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
                    2020-02-14 19:35:50.389 - error: host.raspberrypi4 Caught by controller[65]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
                    2020-02-14 19:35:50.390 - error: host.raspberrypi4 Caught by controller[65]: at VideoStream.emit (events.js:198:13)
                    2020-02-14 19:35:50.390 - error: host.raspberrypi4 Caught by controller[65]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
                    2020-02-14 19:35:50.390 - error: host.raspberrypi4 Caught by controller[65]: at Mpeg1Muxer.emit (events.js:198:13)
                    2020-02-14 19:35:50.390 - error: host.raspberrypi4 Caught by controller[65]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
                    2020-02-14 19:35:50.390 - error: host.raspberrypi4 Caught by controller[65]: at Socket.emit (events.js:198:13)
                    2020-02-14 19:35:50.390 - error: host.raspberrypi4 Caught by controller[65]: at addChunk (_stream_readable.js:288:12)
                    2020-02-14 19:35:50.390 - error: host.raspberrypi4 Caught by controller[65]: at readableAddChunk (_stream_readable.js:269:11)
                    2020-02-14 19:35:50.390 - error: host.raspberrypi4 Caught by controller[65]: at Socket.Readable.push (_stream_readable.js:224:10)
                    2020-02-14 19:35:50.391 - error: host.raspberrypi4 Caught by controller[66]: ReferenceError: i is not defined
                    2020-02-14 19:35:50.391 - error: host.raspberrypi4 Caught by controller[66]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
                    2020-02-14 19:35:50.391 - error: host.raspberrypi4 Caught by controller[66]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
                    2020-02-14 19:35:50.391 - error: host.raspberrypi4 Caught by controller[66]: at VideoStream.emit (events.js:198:13)
                    2020-02-14 19:35:50.391 - error: host.raspberrypi4 Caught by controller[66]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
                    2020-02-14 19:35:50.391 - error: host.raspberrypi4 Caught by controller[66]: at Mpeg1Muxer.emit (events.js:198:13)
                    2020-02-14 19:35:50.391 - error: host.raspberrypi4 Caught by controller[66]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
                    2020-02-14 19:35:50.391 - error: host.raspberrypi4 Caught by controller[66]: at Socket.emit (events.js:198:13)
                    2020-02-14 19:35:50.392 - error: host.raspberrypi4 Caught by controller[66]: at addChunk (_stream_readable.js:288:12)
                    2020-02-14 19:35:50.392 - error: host.raspberrypi4 Caught by controller[66]: at readableAddChunk (_stream_readable.js:269:11)
                    2020-02-14 19:35:50.392 - error: host.raspberrypi4 Caught by controller[66]: at Socket.Readable.push (_stream_readable.js:224:10)
                    2020-02-14 19:35:50.392 - info: host.raspberrypi4 instance system.adapter.rtspStream.0 terminated with code 0 (NO_ERROR)
                    2020-02-14 19:35:50.392 - info: host.raspberrypi4 Restart adapter system.adapter.rtspStream.0 because enabled
                    2020-02-14 19:36:20.431 - info: host.raspberrypi4 instance system.adapter.rtspStream.0 started with pid 10708
                    2020-02-14 19:36:21.347 - debug: rtspStream.0 (10708) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2020-02-14 19:36:21.388 - debug: rtspStream.0 (10708) Objects client ready ... initialize now
                    2020-02-14 19:36:21.393 - debug: rtspStream.0 (10708) Objects create System PubSub Client
                    2020-02-14 19:36:21.394 - debug: rtspStream.0 (10708) Objects create User PubSub Client
                    2020-02-14 19:36:21.394 - debug: rtspStream.0 (10708) Objects client initialize lua scripts
                    2020-02-14 19:36:21.418 - debug: rtspStream.0 (10708) Objects connected to redis: 127.0.0.1:9001
                    2020-02-14 19:36:21.424 - debug: rtspStream.0 (10708) objectDB connected
                    2020-02-14 19:36:21.427 - debug: rtspStream.0 (10708) Redis States: Use Redis connection: 127.0.0.1:9000
                    2020-02-14 19:36:21.439 - debug: rtspStream.0 (10708) States create User PubSub Client
                    2020-02-14 19:36:21.442 - debug: rtspStream.0 (10708) States create System PubSub Client
                    2020-02-14 19:36:21.461 - debug: rtspStream.0 (10708) States connected to redis: 127.0.0.1:9000
                    2020-02-14 19:36:21.462 - debug: rtspStream.0 (10708) statesDB connected
                    2020-02-14 19:36:22.564 - info: rtspStream.0 (10708) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.rtspStream, node: v10.19.0
                    2020-02-14 19:36:22.597 - debug: rtspStream.0 (10708) Starting rtsp Stream
                    2020-02-14 19:36:22.673 - info: rtspStream.0 (10708) Number of streams: 1
                    2020-02-14 19:36:30.473 - debug: rtspStream.0 (10708) system.adapter.admin.0: logging true
                    2020-02-14 19:37:10.161 - info: rtspStream.0 (10708) Stream Eingang using TcpPort 554
                    2020-02-14 19:37:10.162 - info: rtspStream.0 (10708) Stream Eingang starting Server on Port 8083
                    2020-02-14 19:37:10.224 - warn: rtspStream.0 (10708) State Change: rtspStream.0.Eingang.startStream to true ack false
                    2020-02-14 19:37:10.225 - debug: rtspStream.0 (10708) Action: startStream Name: EingangStatetrue
                    2020-02-14 19:37:10.275 - info: rtspStream.0 (10708) Setting stream Resolution to 640 x 380
                    2020-02-14 19:37:10.278 - error: rtspStream.0 (10708) ffmpeg options ok
                    2020-02-14 19:37:10.279 - info: rtspStream.0 (10708) Start stream on rtsp://User:PW@192.168.20.29/profile3/media.smpwith port 1024{"-stats":"","-vf":" scale=w=640:h=380:force_original_aspect_ratio=decrease","-r":30}
                    2020-02-14 19:39:34.174 - debug: rtspStream.0 (10708) Got a Message: getStreams
                    2020-02-14 19:39:34.205 - debug: rtspStream.0 (10708) sendTo "getStreams" to system.adapter.admin.0 from system.adapter.rtspStream.0
                    2020-02-14 19:39:36.070 - debug: rtspStream.0 (10708) system.adapter.admin.0: logging false
                    2020-02-14 19:43:04.455 - debug: rtspStream.0 (10708) system.adapter.admin.0: logging true
                    Trotzdem nochmal dankte für eure Arbeit und Unterstützung.
                      el_malto @tob1 last edited by
                      @tob1 ich benutze das "basic - image" widget und da wird bei mir kein Scrollbalken angezeigt. Da kann ich das einfach so schieben wie ich will.
                      • tob1
                        tob1 @el_malto last edited by
                        @el_malto
                        wenn ich dort die IP Adresse des generierten Streams eingebe, dann wird mir leider kein Bild angezeigt.
                          @tob1 hmm das ist doof. Bei mir klappt es so.
                            Kuddel @el_malto last edited by
                            @el_malto magst du von deinem Widget mal einen xport zur Verfügung stellen ?
                              el_malto @Kuddel last edited by
                              @Kuddel wie gesagt, ist das standard "basic - image" Widget.
                              [{"tpl":"tplImage","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"http://192.168.0.20:8080/mjpegfeed?oid=1&size=1280x720"},"style":{"left":"609px","top":"0px","width":"415px","height":"233px"},"widgetSet":"basic"}]
                                @el_malto also der Link, den du im Widget verwendest funktioniert.
                                Das Widget selber zeigt leider nichts an.
                                  @Kuddel der Link? Das ist der Link von meiner Cam bzw. der Link von iSpy. Wäre ja Zufall wenn du auch iSpy und die gleiche IP benutzt...🤷‍♂️
                                    @el_malto ich habe die IP und den Port auf die Adresse vom RTSP Adapter geändert
                                      @Kuddel achso. Dann liegt es wohl auch daran welches Programm den Stream erzeugt.
                                        Hat schon jemand eine Lösung, wie man den Stream vernünftig ohne Scroll-Balken einbinden kann ?
                                        Stream = http://192.168.4.31:8086/
                                          daniel_iobroker last edited by
                                          Hab mir heute auch den Adapter installiert. Zuerst natürlich noch das "ffmpeg"
                                          Das ganze am Raspi 4.
                                          Habe dann meinen rtsp link eingetragen (inkl. Username / Passwort). Der Adapter gibt auch keinen Fehler aus.
                                          Wenn ich aber dann meinen Stream mit der IoBroker IP + Port aufrufen will, kommt nur ein Seiten-Ladefehler
                                          Hab ich hier noch was falsch eingestellt? Der rtsp Link funktioniert zumindest im VLC Player ohne Probleme
                                          Hier die Einstellungen vom Adapter:
                                          Hier das log, nach einem Neustart vom Adapter:
                                            skokarl @daniel_iobroker last edited by
                                            @daniel_iobroker
                                            Du kannst keinen RTSP Stream mit User/Pass im Browser ausgeben, lässt der Browser nicht zu.
                                            VLC ist ja ein Programm, da sieht das anders aus.
                                            Der RTSP Stream muss umgewandelt werden, z.b. mit MotionEye
                                            D werner2000x 2 Replies Last reply Reply Quote 0
                                            31.7k
                                            79.8k
                                            rtsp stream
                                            36
                                            157
                                            18651
