    4. Fehler bei der Installation des Zigbee Adapters
    UNSOLVED Fehler bei der Installation des Zigbee Adapters
      Wolfi last edited by Wolfi
      @Asgothian
      Ich habe das aus der Admin Konsole aus installieren versuch. Das ist das log dazu.
      Also direkt Adapter installation in Ibobroker habe ich so gemacht!
      Bisher hatte ich keinerlei Probleme mit Adapter installationen in iobroker.
      • Achim Weis
        Achim Weis last edited by Achim Weis
        gleiches Problem
        habe 1.0.2 und 1.0.3 von der Oberfläche aus installiert. (bzw probiert)
        Node: 10.19.0
        host.IObroker	2020-02-14 13:21:51.846	error	iobroker events.js:174 throw er; // Unhandled 'error' event ^Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/osram_a60_rgbw.png'Emitted
        host.IObroker	2020-02-14 13:21:49.136	info	iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/trust_zpir_8000.png img/trust_zpir_8000.png image/png
        host.IObroker	2020-02-14 13:21:47.853	error	iobroker Some packets could not be installed. Please install them manually
        host.IObroker	2020-02-14 13:21:47.769	info	iobroker ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_AfterGet(uv_work_t*)’:../src/macros.h:112:60: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::L
        host.IObroker	2020-02-14 13:21:47.755	info	iobroker In file included from ../src/statement.cc:6:../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginGet(node_sqlite3::Statement::Baton*)’:../src/macros
        host.IObroker	2020-02-14 13:21:47.751	info	iobroker ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_AfterBind(uv_work_t*)’:../src/macros.h:112:60: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::
        host.IObroker	2020-02-14 13:21:47.748	info	iobroker In file included from ../src/statement.cc:6:../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginBind(node_sqlite3::Statement::Baton*)’:../src/macro
        host.IObroker	2020-02-14 13:21:47.735	info	iobroker In file included from ../src/statement.cc:6:../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_AfterPrepare(uv_work_t*)’:../src/macros.h:112:60: warnin
        host.IObroker	2020-02-14 13:21:47.727	info	iobroker ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginPrepare(node_sqlite3::Database::Baton*)’:../src/statement.cc:119:58: warning: cast between inco
        host.IObroker	2020-02-14 13:21:47.721	info	iobroker ../src/statement.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE node_sqlite3::Statement::New(Nan::NAN_METHOD_ARGS_TYPE)’:../src/statement.cc:103:10: warning: ‘Nan::Maybe<b
        host.IObroker	2020-02-14 13:21:47.719	info	iobroker In file included from ../src/statement.cc:6:../src/macros.h:112:60: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>
        host.IObroker	2020-02-14 13:21:47.717	info	iobroker In file included from ../src/statement.cc:6:../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Error(T*)’:../src/macros.h:112:60: warning: ‘v8::Local<v8::Va
        host.IObroker	2020-02-14 13:21:47.609	info	iobroker In file included from ../src/database.h:10, from ../src/statement.cc:7:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2298:62: w
        host.IObroker	2020-02-14 13:21:45.306	info	iobroker /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with
        host.IObroker	2020-02-14 13:21:45.282	info	iobroker In file included from /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/database.h:10, from
        host.IObroker	2020-02-14 13:21:45.220	info	iobroker In file included from ../../nan/nan.h:54, from ../src/database.h:10, from ../src/node_sqlite3.cc:8:../src/node_sqlite3.cc: At global scope:/home/iobroker/.cac
        ```[debug.txt](/assets/uploads/files/1581684900624-debug.txt)
        • Achim Weis
          debug.rar
          anbei das komplette log file. leider zu groß um als text zu posten
          • Asgothian
            Asgothian Developer @Achim Weis last edited by
            @Achim-Weis
            Das muss ich mir zu hause anschauen - ich habe das Problem (bisher) nicht.
            A.
            • mickym
              Ich habe bei der Installation seit Version 1.0.1 Probleme - Ich habe den Adapter aber nicht über die Kommandozeile sondern normal über die GUI installiert. Endet immer mit Error Code 1 und das angeblich einen Menge *.png fehlen. Das gleiche Phänomen mit Version 1.0.2. . Ich habe mir bislang - da der Adapter schon in der Version 0.x. installiert war - damit beholfen, dass ich eine zusätzliche Instanz eingerichtet habe, die ich anschließend wieder gelöscht habe. Dabei hat sich der Adapter irgendwie selbst repariert und fehlende Dateien nachinstalliert. Auf die Version 1.0.3 werde ich wohl nicht updaten bis die Installationsprobleme nicht behoben sind - zudem die Version 1.0.2 bei mir nun stabil läuft und meine Zigbee Geräte nun alle laufen.
              Mein System ist Raspberry 4 mit 4 MB und wurde sonst auch vor 2 Wochen auf den neuesten Stand gebracht: Node.js 10.19.0
              • Achim Weis
                da läuft es dem geübten admin vermutlich kalt den Rücken runter...
                auf der Console:
                sudo su
                dann "npm install iobroker.zigbee"
                ein einfaches sudo npm install hat nicht gereicht.
                dann "iobroker upload all"
                iobroker restart
                danach konnte die Instanz hinzugefügt werden.
                Sorry, ich habe so viel "rumprobiert" - kann leider kein komplettes try&error protokoll abgeben.
                Danke für die schnellen Antworten!
                  Wolfi last edited by Negalein
                  Habe es so probiert wie @Achim-Weis
                  leider bei mir ohne Erfog.
                  Fertig mit Fehler: events.js:174 throw er; // Unhandled 'error' event ^Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/lightify-par16.png'Emitted 'error' event at: at lazyFs.open (internal/fs/streams.js:115:12) at FSReqWrap.args [as oncomplete] (fs.js:140:20)
                  • Asgothian
                    Asgothian Developer @Wolfi last edited by
                    @Wolfi
                    ich hab es bei mir probiert, es ging ohne Probleme. Kannst du bitte mal das Fixer-Skript drüber laufen lassen, nicht das wir ein problem mit Zugriffsrechten haben ?
                    A.
                      Wolfi @Asgothian last edited by Wolfi
                      @Asgothian
                      Fixer skript?
                      Was wo wie?
                      Da musst du mir helfen. Bin iobroker Neuling bzw. Umsteiger von FHEM.
                      • Asgothian
                        Asgothian Developer @Wolfi last edited by Asgothian
                        @Wolfi sagte in Fehler bei der Installation des Zigbee Adapters:
                        @Asgothian
                        Fixer skript?
                        Was wo wie?
                        Siehe hier
                        A.
                          @Asgothian
                          Ich probiere es mal.
                          Aber so wie ich das gelesen habe ist der Fixer nur für ältere installationen.
                          Meine ist gerade mal 2-3Monate alt.
                          • Asgothian
                            @Wolfi
                            So war es mal gedacht. Inzwischen ist es das standard Werkzeug um sicher zu gehen das notwendige Verzeichnisse vorhanden und beschreibbar sind.
                            A.
                              Wolfi @Asgothian last edited by Negalein
                              @Asgothian
                              Skript ist gelaufen.
                              Hat leider nicht geholfen.
                                Habe nochmals rumprobiert leider ohne erfolg.
                                Test mit anderem Adapter Installation funktionierte .
                                Keine mehr eine Idee?
                                  @Asgothian
                                  Sollte man mal eine ältere Version z. B < VERSION 1 probieren?
                                  Wenn Ja woher und wie?
                                  • Asgothian
                                    @Wolfi
                                    Du kannst wenn der Adapter installiert ist im Admin interface auf eine niedrigere Version runter gehen. Dazu die adapter liste in Experten Ansicht öffnen. Hinter dem + verstecken sich die anderen Versionen.
                                    Bevor du das machst, kannst du mal schauen ob diese Datei existiert:
                                    '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/lightify-par16.png' und welche Rechte sie hat ?
                                      @Asgothian sagte in Fehler bei der Installation des Zigbee Adapters:
                                      iobroker.zigbee
                                      Denn Ordner gibts bei mir gar nicht die Installation scheint nicht soweit zu kommen?
                                      Das andere was du zuvor geschrieben hast nützt ja nichts wenn der Adapter nicht installiert wurde.
                                      • Asgothian
                                        @Wolfi Doch - das ist in der adapter liste, nicht in der Instanz liste.
                                        A.
                                          @Asgothian
                                          Schon klar aber dieses zusätzliche (im Experten M.) "+" erscheint bei mir nur bei bereits installierten Adaptern!
                                          Und meine Zigbee installation funzt ja nicht.
                                            Malaus @Achim Weis last edited by
                                            Habe auch Schwierigkeiten mit der Installation. Bei mir kommt der Fehler
                                            Fertig mit Fehler: events.js:174 throw er; // Unhandled 'error' event ^Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/admin/img/osram_4058075816718.png'Emitted 'error' event at: at lazyFs.open (internal/fs/streams.js:115:12) at FSReqWrap.args [as oncomplete] (fs.js:140:20)
                                            Das hier hab ich ebenfalls ausprobiert und leider ohne Erfolg.
                                            @Achim-Weis sagte in Fehler bei der Installation des Zigbee Adapters:
                                            auf der Console:
                                            sudo su
                                            iobroker restart
                                            zigbee
                                            2683
