    4. [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen
      Stormbringer @Stormbringer last edited by
      @Dutchman Wollt grad mal einen Effekt ansteuern, macht er aber leider nicht. Springt dann wieder auf Solid. Im LOG:
      [s=]
      cwled.0	2020-02-15 11:30:05.583	info	(25049) Devices array from bonjour scan : {}
      wled.0	2020-02-15 11:30:05.583	info	(25049) Device wled-2d6e5e found on IP 10.0.1.40
      wled.0	2020-02-15 11:30:05.582	info	(25049) Devices array from bonjour scan : {}
      wled.0	2020-02-15 11:30:05.582	info	(25049) Device wled-c0a1e3 found on IP 10.0.1.45
      wled.0	2020-02-15 11:29:05.583	info	(25049) Devices array from bonjour scan : {}
      wled.0	2020-02-15 11:29:05.583	info	(25049) Device wled-2d6e5e found on IP 10.0.1.40
      wled.0	2020-02-15 11:29:05.581	info	(25049) Devices array from bonjour scan : {}
      wled.0	2020-02-15 11:29:05.581	info	(25049) Device wled-c0a1e3 found on IP 10.0.1.45
      wled.0	2020-02-15 11:28:05.583	info	(25049) Devices array from bonjour scan : {}
      wled.0	2020-02-15 11:28:05.583	info	(25049) Device wled-2d6e5e found on IP 10.0.1.40
      wled.0	2020-02-15 11:28:05.582	info	(25049) Devices array from bonjour scan : {}
      wled.0	2020-02-15 11:28:05.581	info	(25049) Device wled-c0a1e3 found on IP 10.0.1.45
      wled.0	2020-02-15 11:27:05.586	info	(25049) Devices array from bonjour scan : {}
      wled.0	2020-02-15 11:27:05.586	info	(25049) Device wled-2d6e5e found on IP 10.0.1.40
      wled.0	2020-02-15 11:27:05.582	info	(25049) Devices array from bonjour scan : {}
      wled.0	2020-02-15 11:27:05.582	info	(25049) Device wled-c0a1e3 found on IP 10.0.1.45
      wled.0	2020-02-15 11:26:05.587	info	(25049) Devices array from bonjour scan : {}
      wled.0	2020-02-15 11:26:05.584	info	(25049) Device wled-2d6e5e found on IP 10.0.1.40
      wled.0	2020-02-15 11:26:05.581	info	(25049) Devices array from bonjour scan : {}
      wled.0	2020-02-15 11:26:05.580	info	(25049) Device wled-c0a1e3 found on IP 10.0.1.45
      wled.0	2020-02-15 11:25:05.581	info	(25049) Devices array from bonjour scan : {}
      wled.0	2020-02-15 11:25:05.581	info	(25049) Device wled-2d6e5e found on IP 10.0.1.40
      wled.0	2020-02-15 11:25:05.579	info	(25049) Devices array from bonjour scan : {}
      wled.0	2020-02-15 11:25:05.579	info	(25049) Device wled-c0a1e3 found on IP 10.0.1.45
      wled.0	2020-02-15 11:24:05.676	info	(25049) Devices array from bonjour scan : {}
      wled.0	2020-02-15 11:24:05.675	info	(25049) Device wled-2d6e5e found on IP 10.0.1.40
      wled.0	2020-02-15 11:24:05.651	info	(25049) Devices array from bonjour scan : {}
      wled.0	2020-02-15 11:24:05.651	info	(25049) Device wled-c0a1e3 found on IP 10.0.1.45
      wled.0	2020-02-15 11:24:05.572	warn	(25049) State attribute definition missing for + Connection
      wled.0	2020-02-15 11:24:05.504	info	(25049) starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.wled, node: v10.19.0[/s]
      • Dutchman
        Dutchman Developer Most Active Administrators @Stormbringer last edited by Dutchman
        @Stormbringer sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
        [s=]
        Welche WLED Firmware Version haste auf dem ESP ?
        Da kommen keine Daten vermute alte Firmware die noch nicht die json-api hat welche mein Adapter benutzt
          Stormbringer @Dutchman last edited by
          @Dutchman Version 0.8.5. Ist die falsch?
          • Dutchman
            bitte version 0.9.0 probieren von WLED
            S liv-in-sky 2 Replies Last reply Reply Quote 0
              @Dutchman ei ei captain 😉👍🏻
                liv-in-sky @Dutchman last edited by
                @Dutchman
                die segmente werden nicht als datenpunke aktualisiert, wenn man diese über die weboberfläche erhöht oder löscht
                ist es eigentlich möglich segmente über den adapter anzulegen?
                Dutchman Chaot 2 Replies Last reply Reply Quote 0
                • Dutchman
                  Dutchman Developer Most Active Administrators @liv-in-sky last edited by
                  @liv-in-sky sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                  @Dutchman
                  Löschen nicht, erhöhen nach Adapter Neustart.
                  Muss noch überlegen wie ich damit umgehen möchte löschen von states aus Adapter raus mag ich nicht.
                  Wled kan max 10 Segmente eventuell erstelle ich die Standard
                  Uh theoretisch ja aber würde das in wled machen
                  • Chaot
                    Chaot @liv-in-sky last edited by
                    @liv-in-sky Segmente wäre auch mein Gedanke gewesen. Aber der Controler kann nur 10 Segmente.
                    Und das ist dann nicht ganz so geeignet.
                      Rushmed Most Active last edited by
                      Ich hab meine NodeMCU mit WLED erfolgreich eingebunden. MIr gelingt es allerdings nur den Stripe ein und aus zu schalten und die Brightness zu ändern. Mit welchen DP wähle ich effekte und Farben?
                      • Dutchman
                        Dutchman Developer Most Active Administrators @Rushmed last edited by
                        @Rushmed sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                        Schau mal im Ordner Seg 🙂
                          Jess, Danke
                            liv-in-sky @Chaot last edited by
                            @Chaot ich habe das thermometer mit tasmota (geflasht auf nodeMCU) - gelöst - wird also mit dem sonoff-adapter gesteuert bzw http - befehlen
                            Chaot 1 Reply Last reply Reply Quote 1
                            • Chaot
                              @liv-in-sky Jau!!!
                              Genau das ist es!
                              Aber wie steuerst du das? Per Script?
                                @Chaot mach doch einen thread auf - und setze mich mit rein - dann können wir das dort diskutieren - hier geht es ja um WLED
                                • Chaot
                                  @liv-in-sky
                                  Ich habe nachdem heute die Fritzbox abgeschmiert ist eine neue Fehlermeldung bei WLED.
                                  wled.0	2020-02-20 21:27:02.013	error	(21768) Read Data error : TypeError: Cannot read property 'info' of null
                                  wled.0	2020-02-20 21:27:02.011	error	(21768) Read Data error : TypeError: Cannot read property 'info' of null
                                  wled.0	2020-02-20 21:27:01.986	info	(21768) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e","192.168.8.186":"3c71bf29273b","192.168.8.187":"a4cf12d5cc6e","192.168.8.188":"246f28b4865c"}
                                  wled.0	2020-02-20 21:27:01.985	info	(21768) Device wled-b4865c found on IP 192.168.8.188
                                  wled.0	2020-02-20 21:27:01.939	error	(21768) Read Data error : TypeError: Cannot read property 'info' of null
                                  wled.0	2020-02-20 21:27:01.907	info	(21768) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e","192.168.8.186":"3c71bf29273b","192.168.8.187":"a4cf12d5cc6e"}
                                  wled.0	2020-02-20 21:27:01.906	info	(21768) Device wled-d5cc6e found on IP 192.168.8.187
                                  wled.0	2020-02-20 21:27:01.899	info	(21768) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e","192.168.8.186":"3c71bf29273b"}
                                  wled.0	2020-02-20 21:27:01.898	info	(21768) Device wled-29273b found on IP 192.168.8.186
                                  wled.0	2020-02-20 21:27:01.873	info	(21768) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e"}
                                  wled.0	2020-02-20 21:27:01.873	info	(21768) Device wled-ea1b7e found on IP 192.168.8.189
                                  wled.0	2020-02-20 21:27:01.774	warn	(21768) State attribute definition missing for + Connection
                                  wled.0	2020-02-20 21:27:01.706	info	(21768) starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.wled, node: v10.19.0
                                  host.ioBroker	2020-02-20 21:27:00.152	info	instance system.adapter.wled.0 started with pid 21768
                                  Sagt dir das was?
                                    @Chaot
                                    stoppe doch mal den adapter und lösche die datenpunkte - vielleicht hilft das ???
                                    • Chaot
                                      @liv-in-sky Das war nach dem Löschen.
                                      Jetzt habe ich den Adapter aus Git nochmal drübergebügelt und es scheint zu funktionieren.
                                      • joergeli
                                        joergeli @Dutchman last edited by
                                        @Dutchman
                                        Dein Adapter funktioniert mit WLED einwandfrei.
                                        Was mir aber aufgefallen ist: Anscheinend verbraucht er mit der Zeit immer mehr RAM.
                                        Nach erstmaligen Start nutzt die WLED-Instanz ca. 47 MB RAM.
                                        Nach ca. 1 Tag Laufzeit hat sich das dann auf fast das Doppelte ( 94 MB) erhöht.
                                        Nach weiteren Tagen sind es dann schon 187 MB.
                                        Solch eine hohe RAM-Nutzung konnte ich bei keinem anderen ioBroker-Adapter feststellen.
                                        Liegt da evtl. ein Memory-Leak, oder ähnliches vor?
                                        • Dutchman
                                          Dutchman Developer Most Active Administrators @joergeli last edited by
                                          @joergeli sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                                          soweit ich beurteilen kan sind das nur Reservierungen also alle normal 🙂
                                          joergeli 1 Reply Last reply Reply Quote 0
                                            Stormbringer @Dutchman last edited by Stormbringer
                                            @Dutchman Hab gerade meinen bestehenden Skript der vorher über HTPP Request einwandfrei lief auf deinen tollen Adapter umgestrickt.
                                            Nur leider reagiert der WLED nicht so wie vorher. Ich kann den WLED zwar über die Admin Oberfläche normal steuern aber sobald er über Skript die WLEDS anspricht kommt häufiger im LOG
                                            wled.0	2020-02-22 14:25:03.407	debug	(15628) API feedback{"message":"connect ETIMEDOUT 10.0.1.40:80","name":"Error","stack":"Error: connect ETIMEDOUT 10.0.1.40:80\n at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)","con
                                            wled.0	2020-02-22 14:25:03.406	error	(15628) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                            wled.0	2020-02-22 14:25:03.406	debug	(15628) API feedback{"message":"connect ETIMEDOUT 10.0.1.40:80","name":"Error","stack":"Error: connect ETIMEDOUT 10.0.1.40:80\n at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)","con
                                            wled.0	2020-02-22 14:25:03.405	debug	(15628) API feedback{"message":"connect ETIMEDOUT 10.0.1.40:80","name":"Error","stack":"Error: connect ETIMEDOUT 10.0.1.40:80\n at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)","con
                                            wled.0	2020-02-22 14:25:03.405	error	(15628) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                            wled.0	2020-02-22 14:25:03.404	error	(15628) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                            wled.0	2020-02-22 14:25:03.404	debug	(15628) API feedback{"message":"connect ETIMEDOUT 10.0.1.40:80","name":"Error","stack":"Error: connect ETIMEDOUT 10.0.1.40:80\n at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)","con
                                            wled.0	2020-02-22 14:25:03.403	debug	(15628) API feedback{"message":"connect ETIMEDOUT 10.0.1.40:80","name":"Error","stack":"Error: connect ETIMEDOUT 10.0.1.40:80\n at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)","con
                                            wled.0	2020-02-22 14:25:03.403	error	(15628) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                            wled.0	2020-02-22 14:25:01.159	debug	(15628) Create special drop donwn state with value {"0":"Solid","1":"Blink","2":"Breathe","3":"Wipe","4":"Wipe Random","5":"Random Colors","6":"Sweep","7":"Dynamic","8":"Colorloop","9":"Rainbow","10":
                                            wled.0	2020-02-22 14:25:01.142	debug	(15628) Create special drop donwn state with value {"0":"Solid","1":"Blink","2":"Breathe","3":"Wipe","4":"Wipe Random","5":"Random Colors","6":"Sweep","7":"Dynamic","8":"Colorloop","9":"Rainbow","10":
                                            oder
                                            wled.0	2020-02-21 11:36:37.552	error	(3772) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                            wled.0	2020-02-21 11:36:37.551	error	(3772) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                            wled.0	2020-02-21 11:36:37.550	error	(3772) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                            wled.0	2020-02-21 11:36:37.549	error	(3772) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                            wled.0	2020-02-21 11:36:37.548	error	(3772) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                            wled.0	2020-02-21 11:36:37.547	error	(3772) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                            ...und sie leuchten dann unterm Strich nicht so wie sie sollen.
                                            Hast du eine Idee woher das kommt?
                                            WLED bekommt halt n paar Kommandos hintereinander. Kann das, das Problem sein? Ist dafür der Adapter nicht ausgelegt?
                                            adapater adapter neu hier test testen tester wled
                                            73
                                            655
                                            144849
