    4. Test Adapter mihome-vacuum v2.0.x
    • Meistertr
      Meistertr Developer @Kaschi68 last edited by
      @Kaschi68 hast du nochmal ein debug log während des saugens
      K haselchen 2 Replies Last reply Reply Quote 0
        Kaschi68 @Meistertr last edited by Kaschi68
        @Meistertr
        Kein Problem, habe Raumreinigung für einen Raum gestartet :
        2020-02-17 18:37:27.082 - debug: mihome-vacuum.0 (16111) stateChange mihome-vacuum.0.rooms.74001007490.roomClean {"val":true,"ack":false,"ts":1581961047078,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1581917877134}
        2020-02-17 18:37:27.085 - debug: mihome-vacuum.0 (16111) sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: 19
        2020-02-17 18:37:27.088 - info: mihome-vacuum.0 (16111) trigger cleaning segment 19
        2020-02-17 18:37:27.089 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf57
        2020-02-17 18:37:27.090 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20666,"method":"app_segment_clean","params":[19]}
        2020-02-17 18:37:27.090 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310060000000000f9e615a5e4acf57a6d44d183c27b36a6426be7fda18825eec0a60cefd8c3e1d443c4ad421b722eaef6a70a9a1a2809cb039400ffa1abedddf9f72767cd34f2114cd6819a9c6fecd4e3088991a9cf7d4bae5ebaccb7ac7e2
        2020-02-17 18:37:27.099 - debug: mihome-vacuum.0 (16111) stateChange mihome-vacuum.0.control.fan_power {"val":103,"ack":false,"ts":1581961047094,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1578242997602}
        2020-02-17 18:37:27.100 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20638,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20665,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:27.100 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf57
        2020-02-17 18:37:27.101 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20667,"method":"set_custom_mode","params":[103]}
        2020-02-17 18:37:27.101 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310060000000000f9e615a5e4acf57e884bf42595e481d05c1df16c0e295b9fc26ab5323f6098303608a5fb2d470953bb7921c2ee23f7d82438d2cc7946897a6d99ff703f1ba236b9e9234cf230859589554a551632b4eea741bc2a47b7bc2
        2020-02-17 18:37:27.102 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["ok"],"id":20666}<<< 21310040000000000f9e615a5e4acf560b455c4087c126734900d9dc3c2fb247ec87e88ef01de47a340fa8b6355da6571ea43c68d2ee9959d9f3b66ff130aac2
        2020-02-17 18:37:27.108 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["ok"],"id":20667}<<< 21310040000000000f9e615a5e4acf56418a168f454f6bd5f504de858314a1f8ec87e88ef01de47a340fa8b6355da657f45f018160202b7c2fc876266f69e84d
        2020-02-17 18:37:27.302 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20638,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20668,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:27.303 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf57
        2020-02-17 18:37:27.304 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20668,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:27.304 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf57b40d2ec8bbb42a124340ef0f5269070445469e1649be22c043dea7ca717fe542d8bb70405381e36b685b09e06ef37cb2020b9f2733ca780b3566f005ac5483d8
        2020-02-17 18:37:27.304 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:27.317 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20668}<<< 21310060000000000f9e615a5e4acf56762794ddf3343d9919f517f652ef969383b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e02754c8dcf338f4fa53e9af96a7d6013303f3ef724cfcbe20b32b962f1e81e41fe4
        2020-02-17 18:37:27.819 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20638,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20669,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:27.820 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf57
        2020-02-17 18:37:27.820 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20669,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:27.821 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf57ab78352975001d264cd8bc7668a47eb2f0cc385f56b410d535d2735074b6d0ddc641a46d80689fc0d9b454af47bd58199127a0818f6edf076e10d0403842de7f
        2020-02-17 18:37:27.821 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:27.827 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20669}<<< 21310060000000000f9e615a5e4acf578f213324fe4526985aabe4a8219f8eb383b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e0273f18272298fcea8a9c443308dd71812e3f3312eddca1573cda612b990b62600d
        2020-02-17 18:37:28.329 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20638,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20670,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:28.330 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf58
        2020-02-17 18:37:28.332 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20670,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:28.333 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf58ecb12da091bf552e1057ec314fee06f42eb4dfd9755826fd5f30178d2bd9cb9c4ed9f5333a1d8b5082cf867fb328ba2db590dc7b6152a6b9be1bf621aa39c68c
        2020-02-17 18:37:28.333 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:28.339 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20670}<<< 21310060000000000f9e615a5e4acf583fe0d9b6315177152a85c14fb948054d83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027ac01b32583a4f4c2bcf5bbdd1f708e3a5ae3fd1b138def43d208405897cafd8c
        2020-02-17 18:37:28.840 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20638,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20671,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:28.840 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf58
        2020-02-17 18:37:28.841 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20671,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:28.841 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf58f09e184dd0552dc008c62b6a89a728e3f515fd9b155d910cdabb65940de724e2b137341e0ad2562ec1a5cb0f3fd367ac63062860359e4c58d0f5c4d986f20522
        2020-02-17 18:37:28.842 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:28.853 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20671}<<< 21310060000000000f9e615a5e4acf5800aad5c57feee38b0aa3656fc99d25cd83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027f385375a46ac3c59f133df0879bc05537af4d9d6314a907c614c63044ceac8fe
        2020-02-17 18:37:29.354 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20638,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20672,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:29.355 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf59
        2020-02-17 18:37:29.356 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20672,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:29.356 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf59b3998f3ca13b282cf03ece4925d626067b5fd6c53e2564f75cf7b5b4bab499f9cb5a33b71fed101fe2291e912750bc1d7e4e9a46e648f6443ea05291d105275f
        2020-02-17 18:37:29.357 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:29.363 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20672}<<< 21310060000000000f9e615a5e4acf590e9349f9f9f08c5ac97f3a6f90b5cf8683b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e02710d6093df586b2931a88b63123bf6f1b31eec5c2e9933152b5127da1e710a769
        2020-02-17 18:37:29.864 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20638,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20673,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:29.864 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf59
        2020-02-17 18:37:29.865 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20673,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:29.865 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf593b525e5600a4488b2a200ae627b6030ffc11792c4165c167901d47a697f0b320b53dcd347609cd7f4d3b6c5bbf1bbb7dfd6d57e8f9bb3e2618a0ce274d727f75
        2020-02-17 18:37:29.865 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:29.874 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20673}<<< 21310060000000000f9e615a5e4acf599c10172b4deb4adb2997b1061a83e7d883b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e02704ba4f8a6b6594c1a06dbd2683a6f610004f2afe387e7000ebd857eebab904c2
        2020-02-17 18:37:30.376 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20638,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20674,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:30.376 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf5a
        2020-02-17 18:37:30.377 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20674,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:30.377 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf5af891610fdd538a6ebaea2ac03f5da20d53d66f83d79f996e92be1a970870810980595db180eb7bfcb5320f4333ea622f2e6fe8c028eb0c97985bf1b1392faa96
        2020-02-17 18:37:30.377 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:30.386 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20674}<<< 21310060000000000f9e615a5e4acf5a13f6f10401fcab66d2ee1f5f1a4f787283b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027215a7ad424b5f5d98c1936d5f6be6a385ed485b08f73ab9233b862e4290f5ec8
        2020-02-17 18:37:30.888 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20638,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20675,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:30.889 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf5a
        2020-02-17 18:37:30.889 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20675,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:30.890 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf5aa5d42533c9cd0b438c2ff611f9ed0d9eee15ee1413f9760f0acdca62903f529b1e93700c91c9f68c63365958105616b4d3789a5545b84b1ef2a2e7b87cc7072f
        2020-02-17 18:37:30.890 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:30.900 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20675}<<< 21310060000000000f9e615a5e4acf5ade3f7a7b440855cff1af8a70a583f72383b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e0270099290e0c6a93311c8e38f5c9f63e98bff9c3556236d266dddcef80a7a958ae
        2020-02-17 18:37:31.401 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20638,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20676,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:31.403 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf5b
        2020-02-17 18:37:31.404 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20676,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:31.405 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf5bb8d21b534146b0bfbcb1c8cfb19784b57bf715cf97633d10ea61c5c26f44994242a951492c349eacb2dff773f2e1169c66182913da440504a651234ac0b3a1ef
        2020-02-17 18:37:31.406 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:31.413 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20676}<<< 21310060000000000f9e615a5e4acf5b4be92bc4d8a5731aa4cdb8b0c38e726e83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027715e8e685d5cb08e83f3310ef0fa2927a2bed62225337fd1519c7e1ce765f261
        2020-02-17 18:37:31.915 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20638,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20677,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:31.916 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf5b
        2020-02-17 18:37:31.917 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20677,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:31.917 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf5bef6be9c4c52313516836f2b520176d38a1ca2250ae5a6a6fbb31be0d91f21696f78e1f2650d9cc14fa3e9aa9e3cb42b216dabd701e803478e7367da2e212b420
        2020-02-17 18:37:31.917 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:31.930 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20677}<<< 21310060000000000f9e615a5e4acf5b581e1ef38adca335d38a1d02cf261ecc83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e02762259b05ee73cda1739aff6a587887535137a2ee5f73892ea7f2bd6c1c042be8
        2020-02-17 18:37:32.431 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20638,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20678,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:32.432 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf5c
        2020-02-17 18:37:32.432 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20678,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:32.433 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf5c7bd2a4bc8029a167e9ebcbdccd9a658031ab29d9308447d0d69b2a6794705d3957f8f5a38d63153c7753572e6e5baa712831d2af35cb568c6d15635e0edb8aad
        2020-02-17 18:37:32.433 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:32.439 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20678}<<< 21310060000000000f9e615a5e4acf5c4a33df2b450e03dcd8bbf71020140dee83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027346ae34c122d108f2ef690a219879c8e3a24d8556292a56386d5931f06262d66
        2020-02-17 18:37:32.941 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20638,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20679,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:32.942 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf5c
        2020-02-17 18:37:32.943 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20679,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:32.943 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf5cbd91d8fba8458f644e8897c78cd66be7c823e68c7d84d0617caa4d457e2483fd34e5c91e9cf8a9eb67f3dda25cd8a9351286a4942ff071336e626dff78d163c6
        2020-02-17 18:37:32.943 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:32.949 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20679}<<< 21310060000000000f9e615a5e4acf5c617b44445dcfdf05f69d036e1e88d2ee83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027101b91d3423d7a38222dff544c8bafba48886f2449f12c5a0ce237085c09ad59
        2020-02-17 18:37:33.423 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20679,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:33.423 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf5d
        2020-02-17 18:37:33.424 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20680,"method":"get_status"}
        2020-02-17 18:37:33.424 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf5d614fbc5501e5fff99fb4e7fc7b75fcb6d5a234a90f8bb365b4abdbcc2b74ce296e008e5fd331d5dea7d19783af2649048097e58e0d4fc561e647136cc98954db
        2020-02-17 18:37:33.431 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3480,"state":18,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":20680}<<< 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
        2020-02-17 18:37:33.450 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20681,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:33.451 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf5d
        2020-02-17 18:37:33.452 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20681,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:33.452 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf5d9f661ac2cbca15fe1969dd1e957408b5f6a63ca91fa1d8bbf5b00a22edf1dc7ed6bd8fc06cdf3ad0617062adf83cc9c21d1b6ecdfb33103d7955eeffc6e0a83b
        2020-02-17 18:37:33.453 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:33.458 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20681}<<< 21310060000000000f9e615a5e4acf5d643431445dd6a67f8c5db60e4e2a3b0b83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e02733e54701428c72caeca49f2951cefcfbca65883c361839fa4f1e44b21012c2a1
        2020-02-17 18:37:33.519 - debug: mihome-vacuum.0 (16111) [object Object]
        2020-02-17 18:37:33.519 - debug: mihome-vacuum.0 (16111) Xiaomi Cloud: Logging in
        2020-02-17 18:37:33.959 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20682,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:33.960 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf5d
        2020-02-17 18:37:33.961 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20682,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:33.962 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf5d86f9df19eb7e1704297a5da3eb2d45402849bb5076014dd6446ec6f70c494dc200f59cd289e8e9b3cfcc0cfba9a1c48007a547f3a3d46cd0f2ec1451150392b0
        2020-02-17 18:37:33.962 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:33.973 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20682}<<< 21310060000000000f9e615a5e4acf5d6c21314aeb24b525865f0a4b755f9b3483b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e02726c736851561d0e4a7fbf48040d4e738792eb942d8d071e0496373d0e042ccc9
        2020-02-17 18:37:34.474 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20683,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:34.474 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf5e
        2020-02-17 18:37:34.475 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20683,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:34.475 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf5ed829ee152fe4c14f6a1a59fbf9555e4f0d3fcea11ab45ae1102a2b27f5fc0a2f05d92b49bc2284836ba96fcdec49aee313f7405ac162af7295ff7175dfd25fd2
        2020-02-17 18:37:34.475 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:34.485 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20683}<<< 21310060000000000f9e615a5e4acf5efa545093e27eff45e7b25e76e9e9ff7583b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e0270455432458cebe357974c4678589237944abf4424fc9f09e722265bc7d2d4621
        2020-02-17 18:37:34.986 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20684,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:34.986 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf5e
        2020-02-17 18:37:34.987 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20684,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:34.987 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf5e37f7c58f7081887fdf69353b27475c09e62e8247533a0b188e6ff3521e5a5c5712e7bef75ef944c8e356bd990867e6281085afe5ee11daf73475ab0b0841cff1
        2020-02-17 18:37:34.988 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:34.993 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20684}<<< 21310060000000000f9e615a5e4acf5ecaf05e7c84d3486f5fc00c33638bfb7b83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027056f59f06a971b0a441480e2c94ef8ae1c9671949c96bf8f50c270e6f3b56ffd
        2020-02-17 18:37:35.494 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20685,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:35.494 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf5f
        2020-02-17 18:37:35.495 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20685,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:35.495 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf5ff5614cbbd60d9aedb3ee80c0e37c2d271bf32de1261bf2b2ffaf96f75b9d636771d5622277589a86ee352f8cf486da968a4ccd6ec77b140f0ec984a574bb6017
        2020-02-17 18:37:35.496 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:35.509 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20685}<<< 21310060000000000f9e615a5e4acf5f9fcebc5e136f58c38695ba8b8b0c830783b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e02706bba8cb2ad2e8aac8a793060a45982265a8f728e113034d79332df93fd2de79
        2020-02-17 18:37:35.578 - debug: mihome-vacuum.0 (16111) Xiaomi Cloud: Login successful
        2020-02-17 18:37:35.663 - error: mihome-vacuum.0 (16111) Error when receiving mapurl
        2020-02-17 18:37:36.010 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20686,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:36.011 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf60
        2020-02-17 18:37:36.011 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20686,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:36.012 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf60b52c0f02c41f3e4f6bf2f7e92841cd9ca3a08862e0c28dc671881f4e17a5d89fbea87030442f82ecbe447d24125e337c1ef92fd70e8b794a2302d7c3c25c05e8
        2020-02-17 18:37:36.012 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:36.017 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20686}<<< 21310060000000000f9e615a5e4acf5f33d50691cf7f877a9b9466fe69059a9483b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027dea17e89152fb0f2865517e83a73b70b3f0f4f44b0d430eaeb043cbbf64d9e5b
        2020-02-17 18:37:36.518 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20687,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:36.518 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf60
        2020-02-17 18:37:36.519 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20687,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:36.519 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf602cbdd553c715fb5745d7cb3f09de5cb30a674d2c364bd063f8d025b03be27bbf3c8fab8032863e9cf7868d7d70c99b8a7b64fdab1b51cfa9db3a150851810e89
        2020-02-17 18:37:36.520 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:36.529 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20687}<<< 21310060000000000f9e615a5e4acf600bbeb5493218725081ee872543b9cd9183b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e0270b20b2ecff88515bd310ad4c9e93669dc87d6467010630726d6f857a62d99ef7
        2020-02-17 18:37:37.030 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20688,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:37.031 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf61
        2020-02-17 18:37:37.031 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20688,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:37.032 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf61bf82f5e36b760bbbbf42bd0513b6062501e7fe4ac39bbe92f8ea7b74ebaf3c58572208ea8e5957dc20a3aff0040bda3cc520b486a7fa741d07019b520656a820
        2020-02-17 18:37:37.032 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:37.037 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20688}<<< 21310060000000000f9e615a5e4acf6053ff87a1c8429af0617bc59a3f6c1efe83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027e249b4c73d09682017c0e7c0025296d9e0fdd8029012267a0d7960a94051c145
        2020-02-17 18:37:37.537 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20689,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:37.538 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf61
        2020-02-17 18:37:37.539 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20689,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:37.539 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf617e34be77aaf06e8f46467ae77560a498e70c60e32c0b8412fe95baeb0a5d530b9c3a83bc60370075236b119b7b32410d961b1070bbdc7e570af311818f7d9240
        2020-02-17 18:37:37.540 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:37.545 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20689}<<< 21310060000000000f9e615a5e4acf6139491ddd785292c55453f3959be93c5f83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027313527500d9f256cadfce333465d2b5fefb8fc3edf33d449187999e68d3e97c1
        2020-02-17 18:37:38.046 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20690,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:38.047 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf62
        2020-02-17 18:37:38.047 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20690,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:38.048 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf62484b54c7097b55460367b96d78619c5576cf0fb77b7436c54ea1af1feaac057e85d6e9a6f8a383d82ebeab11b9e938ba75dfec571e82f26174bc39e3a2a4b0e8
        2020-02-17 18:37:38.048 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:38.054 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20690}<<< 21310060000000000f9e615a5e4acf612d859a5f1bae9fea8964a2653839af5f83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e02785fc318a8735949b47b8ae5a67af0326a09d269cf8d993e75e4e49cd431684e9
        2020-02-17 18:37:38.554 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20691,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:38.555 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf62
        2020-02-17 18:37:38.555 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20691,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:38.555 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf62b30cf6e105f86342f280b05c40400808f71d06ead21d5fd92ce6b24ad8330ef95abd960d6407a0f0ba859158fddd3f636cab3a8df93ad6df6a6cf224b2f38672
        2020-02-17 18:37:38.556 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:38.563 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20691}<<< 21310060000000000f9e615a5e4acf629cc6c63d26764e0d91cf584fb74664b283b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027e838720c9f717243c3d39cd250225c2e83de017ec5306e6c2ec72b9ccda608d8
        2020-02-17 18:37:39.064 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20692,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:39.065 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf63
        2020-02-17 18:37:39.066 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20692,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:39.066 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf633f8d7faf7b2d048c48b09da81b4802598bede4ec65310ac12bd8c2006d2924f6670e41e4dffb214a59ae33653283c63e5274681205fe4a985c7411c062b7981d
        2020-02-17 18:37:39.066 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:39.081 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20692}<<< 21310060000000000f9e615a5e4acf626dd038b9505dc34994dc613b4e074e3983b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027e025861a19cd20c4238a25d30edd983d5d801c91f6d99bfe41bc8ee6f5418e78
        2020-02-17 18:37:39.581 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20693,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:39.582 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf63
        2020-02-17 18:37:39.583 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20693,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:39.584 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf639b4bacab5cca181e196f5e98ffa3f64d5bc11c530dfe8f8afcbf087c52acc3efc71504fac6bcbfb4f6ee569febe24a8c64b76de3224f98f4a9d8051afe4857df
        2020-02-17 18:37:39.584 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:39.597 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20693}<<< 21310060000000000f9e615a5e4acf63c06ac2b55debb0e515c3a9cbedc63a2f83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e02785120a562be9c1f052a2875d5005962fd13a4c2d19ce4383905eac57be2bb2d0
        2020-02-17 18:37:40.099 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20694,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:40.100 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf64
        2020-02-17 18:37:40.100 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20694,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:40.101 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf64396ce6378201a31e33174e284efbbc5feff6b92649215cef36b2b805d04a01435d4f4c8f78a303eafea0739f7c9b49a602d5f6ed70b6111af2e49804a7eec41a
        2020-02-17 18:37:40.101 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:40.113 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20694}<<< 21310060000000000f9e615a5e4acf63dc478f5ab61f07b6e365004528d5c75283b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027927a414de30745d645fe041039e8abc5709dfeb4b09e9333a400cd78a0d0ee41
        2020-02-17 18:37:40.613 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20695,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:40.614 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf64
        2020-02-17 18:37:40.615 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20695,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:40.615 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf64ae74799b0bba95c9707f77aaa7131cc0af3d602c6e9bc4a38b678335aad20eab420720269ceaa80c06e221703a86169ea161023bf6fd895de702c2b3c490f67f
        2020-02-17 18:37:40.615 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:40.620 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20695}<<< 21310060000000000f9e615a5e4acf64d5df1100a952afeca78e0fa470e266d483b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027423f0cd61a4d683a8f3ffe8c837bf8da925627a196f31fd337709bb4bb618afc
        2020-02-17 18:37:41.121 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20696,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:41.122 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf65
        2020-02-17 18:37:41.123 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20696,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:41.123 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf659fd9bc2c720457f9a8692335b6f3ec047ba308bae1d7631b4cf125708cf3ab4522f17fb5513c08c5e4d69a0c824a3926f86d920a137ba11cf5a8b3754652c0b2
        2020-02-17 18:37:41.123 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:41.141 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20696}<<< 21310060000000000f9e615a5e4acf648fbfbd607ea323420b9e70c8584cb7f383b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e02717409bdfc37eb47cf215ec8f297a10b6a5e5a5f6b5f0cc46520ac4f8d48ec552
        2020-02-17 18:37:41.642 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20697,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:41.642 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf65
        2020-02-17 18:37:41.643 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20697,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:41.643 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf65093889d4d354ed6b68b859a268f7978f33944a8eb603bcd86c2dec1fffc0897c255712560435bdaa72ce20c585c38b82bd4278c54dde85809d173e70a0f27ad4
        2020-02-17 18:37:41.643 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:42.926 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20697}<<< 21310060000000000f9e615a5e4acf66a86dd6a7778ba9fda64094d84ee798ae83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e0274317f8ad487e02b129b38af178a0afdda234852dee91a1984b69c2b215ccfc04
        2020-02-17 18:37:43.427 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20698,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:43.428 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf67
        2020-02-17 18:37:43.428 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20698,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:43.428 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf6796d5532f60cdb320234d664c3cb183fbd51f20cd3db661625f1cf2bd51e959f70359ce237001b3ad537a5e1200a363c9a5ecb3681f63a0ebcde5974271f3930b
        2020-02-17 18:37:43.429 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:43.550 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20698}<<< 21310060000000000f9e615a5e4acf676482675bda888a1c52cf657387322f2383b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027d08813a945eda2a813459af3e3ac8448ad3077d6762846c14813dbbe5a0eea3c
        2020-02-17 18:37:44.051 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20699,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:44.052 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf68
        2020-02-17 18:37:44.053 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20699,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:44.054 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf688caf8ec805964d005f59e58c59798e5cd8a667f567e302a0b7e08352fbc002c72167cdc5efd6322c0ffd45c7a50e277afb24ebe26baa61cf81883f9dc62f14af
        2020-02-17 18:37:44.054 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:44.141 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20699}<<< 21310060000000000f9e615a5e4acf673e813c2d856079a57a0d4824de36571483b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e02701589af29de362c24828d9e2ea61975dfc175e424ac89cc0c70c182523cd82ef
        2020-02-17 18:37:44.642 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20700,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:44.642 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf68
        2020-02-17 18:37:44.643 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20700,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:44.643 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf6882bea96567525ed129c59a133fd7cd4b8c9341ea10d46b68619594d5303362b5dd7ba15b9c094bb9e53aca92ebc879347e853c243aa2f0567191a776a4fb6d5e
        2020-02-17 18:37:44.643 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:44.675 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20700}<<< 21310060000000000f9e615a5e4acf6899cb7af3d6a9b4b5645f4bf68869deef83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027d80f6fa07674344a43077ea53d5819ecffad3922bb8b93a4cf0987c859576d19
        2020-02-17 18:37:45.176 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20701,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:45.177 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf69
        2020-02-17 18:37:45.178 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20701,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:45.178 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf699a77257cfb7c7bb49b722455dca41390de8f9f2ab4a0256e3ac545c98fc923536c36380198e71d28148f1ab90d6b8ce5b05e33cc502abef69a7f4d12b67409a1
        2020-02-17 18:37:45.178 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:45.338 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20701}<<< 21310060000000000f9e615a5e4acf68bdde5746bd799d9fa147c4d51b928f5283b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e02787303a93e30a9f83261132fe432effe79131d3fb0b385ba9bbee1b60e9df9cbb
        2020-02-17 18:37:45.839 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20702,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:45.840 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf69
        2020-02-17 18:37:45.840 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20702,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:45.841 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf69c81317d7ffbf32be24dd70d0489bbbff19a828775869cc28d59ba1fc31fa717655a6081807a36fde3ecb952debeb9a46d5bb28300f49867080bf142a75f84791
        2020-02-17 18:37:45.841 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:45.889 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20702}<<< 21310060000000000f9e615a5e4acf69441b22b8df670f49ccd6d3dddf28af8383b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027932998593ff4254470bc291ea9103c7c938738e54c2c0fce7601d6ff00bb2696
        2020-02-17 18:37:46.390 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20703,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:46.391 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf6a
        2020-02-17 18:37:46.391 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20703,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:46.392 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf6aef6e5a397ec2a161f52aa5880de54e775691edfbd89f03725a8cff5747a2a6f4f2313dc193040460f45bbbdcc6107c9c109fecae03ebffa447aad4b71acd9b6c
        2020-02-17 18:37:46.392 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:46.458 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20703}<<< 21310060000000000f9e615a5e4acf6a4bacf1bba925cc7ba4ac9d89567c1f1a83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027a464318a4064553b89dfe47d01308769e0f03e70b623a47574f404f371a18512
        2020-02-17 18:37:46.959 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20704,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:46.961 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf6a
        2020-02-17 18:37:46.962 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20704,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:46.962 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf6ac7486c6753f07f3df4195ed32aa1872a5c27ac809bd5a225d09d9c36e70730897ade68cb934b34a1430853e950e3a74bcb0305fc976f12e26aadaa541234a222
        2020-02-17 18:37:46.963 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:46.998 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20704}<<< 21310060000000000f9e615a5e4acf6a631afc904187622999fe562b823cddf983b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027517f1158200fb7fc4bcc09204a96766f28d8fd19eedc9f82ddf7739a3a94d37c
        2020-02-17 18:37:47.500 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20705,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:47.500 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf6b
        2020-02-17 18:37:47.501 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20705,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:47.501 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf6b572546ff3932df840895e64477fa4a91a2469eb1e9a7e28a1421fa629b6a94b198d95ef8bb8e4fc9546e312446839b1880f744f7a41551227b0c50cc96cf066a
        2020-02-17 18:37:47.501 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:47.517 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20705}<<< 21310060000000000f9e615a5e4acf6bc46232d029c94879f17682e2428ab61583b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e0277f0c59db10ddc5aa1a0ba1cc22c7114b02d6dd1bbe2882b929a86cb06cb698ca
        2020-02-17 18:37:48.019 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20706,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:48.019 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf6c
        2020-02-17 18:37:48.020 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20706,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:48.020 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf6c2f8f9413388f40e1e3cc04e301298547f5603eedd8ad0b93a89fd5232459442d12b8060ac1643abd0119b3401ad48d4dd318495a9f2628d97d2b443d724792f8
        2020-02-17 18:37:48.021 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:48.149 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20706}<<< 21310060000000000f9e615a5e4acf6b3b9a52908c9267c5d9b0e012941fbdae83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027e9067e95cc97036eef0a621d49e973d92e3b0c7d7a7414edc33a6874a6b95637
        2020-02-17 18:37:48.650 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20707,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:48.650 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf6c
        2020-02-17 18:37:48.651 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20707,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:48.651 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf6cbddaf389b15aa56ab2a497b0d2e1cd46431b2f9f12cbfba8e74c7dcd4ca57d36c4c1fe80d7f4d5d74e781ae1beb4e43e042a42323c8a94d25b67d7f28dff9e02
        2020-02-17 18:37:48.651 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:48.951 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20707}<<< 21310060000000000f9e615a5e4acf6c7c6205bf6d86c665cbff55d090ce2c2883b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027c9370c1355bef66dd325df7f951be461ba0bd159800829699d2c3e9b14c12a28
        2020-02-17 18:37:49.453 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20708,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:49.454 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf6d
        2020-02-17 18:37:49.456 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20708,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:49.457 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf6d4525a7ecad958c0f335864b3d8c5c39a62161faf3e838ee8d30bf319c45a2bc07b04e919350406418fe3b0acbeea6268facd06f56118bc350cadb8019a51fb38
        2020-02-17 18:37:49.457 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:49.537 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20708}<<< 21310060000000000f9e615a5e4acf6dd8a6d6d9fe9df61053a68897f3df377583b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027e97200529fd9c4df2c86b4edac41eb9762e788463a5f7e45bbb9cfbbdba2a922
        2020-02-17 18:37:50.038 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20709,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:50.039 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf6e
        2020-02-17 18:37:50.040 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20709,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:50.040 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf6e2cba7932cddd72ca448815fb46171d4f990834d667220aee0b1667bd6d5cd76ab8142fc401eb994e9f224a6a38ddfc87b2e6c0549ec029ba3def742f78c7497d
        2020-02-17 18:37:50.040 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:50.071 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20709}<<< 21310060000000000f9e615a5e4acf6dfb2aefef672c0f1777c8dc55209a07c183b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027ab1075171684a64e658f43a7fad88a82b671a7ecf748a6dbb15d44ed0f78f6e3
        2020-02-17 18:37:50.572 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20710,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:50.573 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf6e
        2020-02-17 18:37:50.573 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20710,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:50.574 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf6e0889beb5deaa07838ef08a5eeec5c1da40ab8974916115185f09ed721a9fe07d28d9c7bb76cdcddd819440ff85c2093a619ae25c579bd647db5fa158b6bbb8e7
        2020-02-17 18:37:50.574 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:50.770 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20710}<<< 21310060000000000f9e615a5e4acf6ee411720f4648eccb2113e2970613efb283b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e0277d0d5c10a0498b6a988d0a42261d2ac916b33d49f4e3c9e8a88222ece6ed2406
        2020-02-17 18:37:51.272 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20711,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:51.273 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf6f
        2020-02-17 18:37:51.274 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20711,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:51.274 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf6ff0aebfe3a31c0ec4b5caca47bda8b6f09b20d524aaf718629999b11d5b99f20852cee80d732fb9a3e9572459796a2b79e812ce2f52376450a25e5518a4408b8c
        2020-02-17 18:37:51.275 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:51.395 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20711}<<< 21310060000000000f9e615a5e4acf6e7f02c0685d06906a84351fbbeb1959f883b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027fd90720c1c15748e261784278c1687290894cd9bbb54b856650b778cb1013612
        2020-02-17 18:37:51.896 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20581,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20712,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:51.897 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf6f
        2020-02-17 18:37:51.897 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20712,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:51.897 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf6fb24688090f849a77dc0ba60a547f494ae0cfa8731dcfd84fdcb85b76774e50d036ebb16f2e929f2068f8f4c71371e75f3a38457c1266838fa59d233d418e7ed7
        2020-02-17 18:37:51.898 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:52.123 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20712}<<< 21310060000000000f9e615a5e4acf6f6f98f61f0873ca96d97a65baad02a6b683b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e0274bae76db7200346e80a06728c9483d624a13c0a85add6c4e94a2ee80ffc50e51
        2020-02-17 18:37:52.305 - debug: mihome-vacuum.0 (16111) requesting params every: 60 Sec
        2020-02-17 18:37:52.306 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20582,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20712,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:52.306 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf70
        2020-02-17 18:37:52.307 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20713,"method":"miIO.info"}
        2020-02-17 18:37:52.308 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf709eb01d4c09a68291e1d64bf211400a159a1f6ac053eab512a92bb7affac3318d141904c5cf30503478f3f8533ceaa12d29e17b61f6211d4c6b45951df703302b
        2020-02-17 18:37:52.412 - debug: mihome-vacuum.0 (16111) Receive <<< {"partner_id":"","id":20713,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.4_1048","ap":{"ssid":"NastyWlan","bssid":"98:9B:CB:BB:A0:78","rssi":-47},"netif":{"localIp":"192.168.xxx.40","mask":"255.255.255.0","gw":"192.168.xxx.1"},"model":"roborock.vacuum.s6","mac":"50:EC:50:1D:A6:33","token":"4539696e6a77784e4462374b37376978","life":55490}}<<< 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
        2020-02-17 18:37:52.508 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20714,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20712,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:52.509 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf70
        2020-02-17 18:37:52.510 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20714,"method":"get_consumable"}
        2020-02-17 18:37:52.510 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf708aec9a642697153ccad6a9d88c306dc78acc6aade361901ad5e45d86d7b352c9d1321ec6a61200227bd2a4e33f31ba652d3567a22626eee33118f3e6cca505dc
        2020-02-17 18:37:52.530 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":[{"main_brush_work_time":103375,"side_brush_work_time":103375,"filter_work_time":103375,"filter_element_work_time":28706,"sensor_dirty_time":103357}],"id":20714}<<< 213100d0000000000f9e615a5e4acf70e4b76710d4c5740690e80a8aaa60fdd01d9e085c7b843cfba35da0f5811f50b7f8134b96fc1bb9f7365c61c1de54106efdaf3792f0d7f75a720067b39340cce8977ecc9f06b3fa07456e7ec2bb5836f50b716250a1e4182a985e7ec5dbe3e9273a8fc0fd91592bf85b2e61afab101c477a4ea9d2c6ebd655d28632f111ded24a69fbbeb801a439ecb4bbede12eb83c6e0519004efc0d0dd6e648f22abc72b288a86baa030506b4743a7392492f878be0225464941dbf1b7cb20f97af28926b2e
        2020-02-17 18:37:52.625 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20714,"get_clean_summary":20583,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20715,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:52.626 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf70
        2020-02-17 18:37:52.626 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20715,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:52.626 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf70749d44db1e5428fafec03068a917ba78d13d4a32f29edc11db96e96ab67db2bbc50da8861d157fd372de95afa90055b1f96705ff862cd85e760c9c1347a2b137
        2020-02-17 18:37:52.627 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:52.659 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20715}<<< 21310060000000000f9e615a5e4acf70078e0cce5fc18163a8090a05cd97cc3783b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e0273e54c8beb1681c61ae62eb5e55383437ae4658f094549b7cf5950dcd69f8f4ea
        2020-02-17 18:37:52.711 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20585,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20715,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:52.712 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf70
        2020-02-17 18:37:52.712 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20716,"method":"get_clean_summary"}
        2020-02-17 18:37:52.713 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf703538cfb73a947b7d4954aabcbedebd73f35dc607b70382d5cfdc91b88e208296be44ab5d786a5c6919b124f8bfc2fe686e2baaa4dc11b775b956b144ff1c9a22
        2020-02-17 18:37:52.736 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":[103357,1815947500,57,[1581960701,1581959546,1581959441,1581958502,1581951184,1581943466,1581940453,1581918970,1581918799,1581917709,1581917249,1581916954,1581916305,1581796026,1581785007,1581089142,1581087392,1581083264,1580479419,1580474924]],"id":20716}<<< 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
        2020-02-17 18:37:52.912 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20586,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20715,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:52.913 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf70
        2020-02-17 18:37:52.914 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20717,"method":"get_sound_volume"}
        2020-02-17 18:37:52.914 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf7078b91274596ec28229107fa9107bf72b2776605d80bf7615d303d6cc60f28106ec440c1c242a1dbd61c103651b3299edf9e8a590e73fa5cd58afe926ff4992f8
        2020-02-17 18:37:53.068 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":[90],"id":20717}<<< 21310040000000000f9e615a5e4acf70b802ebdd01ff6902357c7ceacd2fc5ea73ed4c460b5dff8828b4f42abac8b1c191104c10e1471e19080646b82017d2aa
        2020-02-17 18:37:53.115 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20715,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:53.115 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf71
        2020-02-17 18:37:53.116 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20718,"method":"get_map_v1"}
        2020-02-17 18:37:53.116 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf710b13a3a1ed27f76f71d07ad93cba1c75278c71aa8de058269569d0423e0063442b7db9c8f198e17f5c15156505213a4e246ef5089c869564076fa0124093f233
        2020-02-17 18:37:53.151 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["retry"],"id":20718}<<< 21310050000000000f9e615a5e4acf70dc01373fc9887833098768e467941aa97c8435268de26b3a9f5f11e10761ea3dd52bb2cb4bbdbd5cac4900b3f67f37ae74452733b4c6d9dd86a572aded613aa4
        2020-02-17 18:37:53.160 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20680,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20719,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:53.161 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf71
        2020-02-17 18:37:53.162 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20719,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:53.162 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf7163531cad9d6755302eb47661518b72a48e9eeef7e2435144c63889733fbf30341df4041812200380bd2734bca30452650976bc0c5e342cbe23415624c7924716
        2020-02-17 18:37:53.163 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:53.242 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20719}<<< 21310060000000000f9e615a5e4acf70bf5ce632fc29f485ed87e3190964793b83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e0275f2d6ca6cc0d3e1997321ff42cf03cdaaa42c9243cbf466eac77f289b41e3454
        2020-02-17 18:37:53.425 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20719,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:53.426 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf71
        2020-02-17 18:37:53.426 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20720,"method":"get_status"}
        2020-02-17 18:37:53.427 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf7137e85320949acbf970f52f2fa41e1205ecf726e5e909723db85e188e995d900031aab443ffb9da9c5c946598b84033f5e9657e2f37ae188487b0d5f0940a0986
        2020-02-17 18:37:53.454 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3481,"state":18,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":20720}<<< 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
        2020-02-17 18:37:53.652 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20721,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:53.653 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf71
        2020-02-17 18:37:53.654 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20721,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:53.654 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf711a768f26258dfad4563ffd133199e609e3dc72f44d09a578c5427506b8af6a24c5519e0710e7f9100db9871296093a7513a0f74b1ef76e9d2739f521f82d5137
        2020-02-17 18:37:53.654 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___retry
        2020-02-17 18:37:53.743 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20722,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:53.744 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf71
        2020-02-17 18:37:53.745 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20722,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:53.745 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf71d800201aa6c550298064b93fe22bf94cd96e1b76ea01ecb135acd5071e9a2cb599fcc50604ea20ff26af44403ae4eac7162b7bf6ce803310c2826446ba408c96
        2020-02-17 18:37:53.746 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:53.779 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20721}<<< 21310060000000000f9e615a5e4acf716bb51fde1b29b6ee3095c43237f9977983b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e02712581103c1a73e508027351ca2648f66faf51bc93aceb66edf4ebbb8f9d365a9
        2020-02-17 18:37:53.944 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20722}<<< 21310060000000000f9e615a5e4acf719903da017360a2077742994905731f2883b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027c8ab28bbe1f05f28509031b0264c8b92cced6dbdf2d9525b660fd55cc612ad2e
        2020-02-17 18:37:54.445 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20723,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:54.446 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf72
        2020-02-17 18:37:54.446 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20723,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:54.446 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf72366742c8b652da3b93a04783868edf0cf0f34d8a97a6f798f7fe808e9798221872028c25e8cedbc90e7ac267f621ffb89fc47a492d788bbe80f77f6124d0632e
        2020-02-17 18:37:54.447 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:54.662 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20723}<<< 21310060000000000f9e615a5e4acf72f6088452572c3a15ed635a9688e8d55e83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e0278c828be1c6c37a02e6be54f28b0f857f350818531d276174f78b6b2b4aa74ecf
        2020-02-17 18:37:55.164 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20724,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:55.164 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf73
        2020-02-17 18:37:55.165 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20724,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:55.165 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf73341a53c127c32e0478b41321edb42b368c352e5a496b389062a49e15db52f19be8e3eb50304d17f196a15856f00f1e23a5490d5ebfe284a3f92c2c0135e6f717
        2020-02-17 18:37:55.166 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:55.200 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20724}<<< 21310060000000000f9e615a5e4acf7227c042c787c9063e94cec70346b65c9083b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e0272a8971eef0bca4b790821c2d64ef30ecefc25305eb6427bce917240c66971892
        2020-02-17 18:37:55.701 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20725,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:55.702 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf73
        2020-02-17 18:37:55.703 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20725,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:55.703 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf73dab91180e7a92e96a6ce957896b1dfacbcdf9565691f5a149a334ee913ef7f4da4f9be5e0716d644f8b32d00f97a24200971fe73c9275553c079c9f5ba3dbf3b
        2020-02-17 18:37:55.703 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:55.812 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20725}<<< 21310060000000000f9e615a5e4acf737c3ce2aa93243243f3b7f2766a162a5583b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e0279d95a2aedb59e8d7c6ee57b593322c0adfd807b469a3e82da9bc8dd6f39e9e09
        2020-02-17 18:37:56.315 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20726,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:56.316 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf74
        2020-02-17 18:37:56.317 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20726,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:56.317 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf7417e41425996c41b7c44bc7576ba0146d249bab8d050c9c081d31b0e2b4b3afca29cc7b232dfbd5cbf639f3fee52876266f32f173e61fe06fe68f2c61f6f7c3c4
        2020-02-17 18:37:56.317 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:56.344 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20726}<<< 21310060000000000f9e615a5e4acf748d1e446ee549d0d314bc93348f508ff983b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027ca8f3194608f4b3314217b37a8e936c12c7ed4cf0ab7bcb90d752c973ce97c54
        2020-02-17 18:37:56.846 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20727,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:56.847 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf74
        2020-02-17 18:37:56.847 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20727,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:56.848 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf74ce20c2b695b0d8a9564d6faaf2eb3b97d103bf62579be3727b1652135c08c8195a41d8b4e2e163d922f71aa7200fc162ecbe2b4b3f0609188a3cc6a8a248ed77
        2020-02-17 18:37:56.848 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:56.940 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20727}<<< 21310060000000000f9e615a5e4acf746583c4105a806384eb06af311fedd2ae83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027a02dd53ad7c15f84347934eb7577a2faa9b501a29d88bec89d6b9c453a05d7c2
        2020-02-17 18:37:57.223 - debug: mihome-vacuum.0 (16111) system.adapter.admin.0: logging true
        2020-02-17 18:37:57.243 - debug: javascript.0 (1210) system.adapter.admin.0: logging true
        2020-02-17 18:37:57.440 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20728,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:57.441 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf75
        2020-02-17 18:37:57.442 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20728,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:57.442 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf75dfd13628511556e5e72b7ee118cde019c0da92163910e74f05a32dcae43a50acc74faf1b35b6d160908f5fd2da78d0f456a432e35888bae01edaf6662fc4023d
        2020-02-17 18:37:57.442 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:57.566 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20728}<<< 21310060000000000f9e615a5e4acf750c2f0da80c600e69ba8c72c38a11983483b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027b95fc750a6bd986b5fedd336e5f5172524212b08869422150eb0b0f18ed0c082
        2020-02-17 18:37:58.067 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20729,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:58.068 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf76
        2020-02-17 18:37:58.069 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20729,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:58.069 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf76c90aed266032ab3c97bd8e39b140cc62b0152dbf15f671ba8660fb26d7eaed1bcac5cf2b5ab040e3bff0a403a4445d8c313955ac02f70a9158a9d33f54b729a2
        2020-02-17 18:37:58.070 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:58.271 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20729}<<< 21310060000000000f9e615a5e4acf751082039640d0fe6696e07960e6f30bcc83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e0272bd89dacdf74f5a338868e229d9f56d14b8ca8a38e6751c8c98581a4338a6fc6
        2020-02-17 18:37:58.772 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20730,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:58.773 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf76
        2020-02-17 18:37:58.774 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20730,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:58.774 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf76b46b384bd83169db56517a077ca2b09bc105a4113ab1aeb515ca40e510ab3c8c7c5459e6912d7b818715055a9c0e5a3b6d2c7ac17b49344dbc625117caf22f76
        2020-02-17 18:37:58.774 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:58.882 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20730}<<< 21310060000000000f9e615a5e4acf761f00ea0751b4532dbe5035955555c03783b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027bdfd13e13ea2cf3c37659a0c20cf0f1cf133cbef023d92a37ccffa107ffa6f45
        2020-02-17 18:37:59.383 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20731,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:37:59.384 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf77
        2020-02-17 18:37:59.385 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20731,"method":"get_fresh_map_v1"}
        2020-02-17 18:37:59.385 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf77d7370453e3a9800df5cabf91994f2b87eafefd0eaa5f7aab430fbf28c348361225ae16612e26caa00457b7aff7f40bb060d6e36e90ea39431404259799900d26
        2020-02-17 18:37:59.385 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:37:59.594 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20731}<<< 21310060000000000f9e615a5e4acf7767b7a83690029d7d26faf61e8177872d83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e02786cadb5adabeeaf9278b24d4e99ef5137ce467b434c4f8921a2b98751d503026
        2020-02-17 18:38:00.095 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20732,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:38:00.096 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf78
        2020-02-17 18:38:00.096 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20732,"method":"get_fresh_map_v1"}
        2020-02-17 18:38:00.097 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf78af588de5819a3d1deb352c33aad283762c0f6c2c36183bd09dd13f7ae25ec1913fb7d07d66c9ee469fbe81d5707c90e99382177f3dbc503d3b85ad1b63e3c9ab
        2020-02-17 18:38:00.097 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:38:00.443 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20732}<<< 21310060000000000f9e615a5e4acf77071d38416cc90ed2f25866819176b67e83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027685597cdce3aeb4970704d12258700faea9dab57c4908cb3d7bcdfd9ea9811a2
        2020-02-17 18:38:00.945 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20733,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:38:00.946 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf78
        2020-02-17 18:38:00.946 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20733,"method":"get_fresh_map_v1"}
        2020-02-17 18:38:00.946 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf78d567a0751f434b9963e31eb04766ea23f463d5f044c7891d4081e79e27d62d8a72a9a176e447859acdf5a167386bd2adb85b5fa452c80e07f78e5a17dde024d9
        2020-02-17 18:38:00.947 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:38:01.007 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20733}<<< 21310060000000000f9e615a5e4acf784978b8b0fb46311059547de4c909f1d483b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027de49c43410d7a18893b0c797f137edef8206c67a2a31edfc83fee11d172a4299
        2020-02-17 18:38:01.508 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20734,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:38:01.508 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf79
        2020-02-17 18:38:01.509 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20734,"method":"get_fresh_map_v1"}
        2020-02-17 18:38:01.510 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf79df3a8d7b73fdc296f1cf67e48ec93c4e86623ea9614dadad0e1dbef520cb97f1ccb667fc8765ebb15dee2853297ca37f063f1164ae6541a9bf5c2ac2167c1c63
        2020-02-17 18:38:01.510 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:38:01.528 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20734}<<< 21310060000000000f9e615a5e4acf7917ba3b86662c42c09fe39f598dc2d76883b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027f3e9e2ec1add796661170cf1c84b8f2ba2be787f356817e265352e3b18afa683
        2020-02-17 18:38:02.029 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20735,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:38:02.029 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf7a
        2020-02-17 18:38:02.030 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20735,"method":"get_fresh_map_v1"}
        2020-02-17 18:38:02.030 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf7a655b359e04c2ca39d7cf27725fd04be96d59a100c6a3271726310450b8880943e7767028c20efd50280005ecb071513d31c3395998963baeb1fe959f4c51c036
        2020-02-17 18:38:02.031 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:38:02.073 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20735}<<< 21310060000000000f9e615a5e4acf79efbe3a8c6ec1a147329823e6fb385d2b83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027e97e2baa790485333d6a836a6b93ff0c3587e4a7f43278410ad3ec8d14c57ff4
        2020-02-17 18:38:02.574 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20736,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:38:02.575 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf7a
        2020-02-17 18:38:02.575 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20736,"method":"get_fresh_map_v1"}
        2020-02-17 18:38:02.576 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf7a0fba310a38a6982cd8d95846032df7d94a986f4d34cfd9e5b1b6a6f02a5e5f22cccff481495ff51b7837b00f9d7614aa0d05f9ac8ca51a3b50a3838cd7dc437f
        2020-02-17 18:38:02.576 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:38:02.685 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20736}<<< 21310060000000000f9e615a5e4acf7ab0b355bc22c7042226608285c91b7d5583b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e0272eafbeb72b76585bacab0b13c0e8200f94ed986466ec5f637ef02d755c29be7c
        2020-02-17 18:38:03.186 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20737,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:38:03.187 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf7b
        2020-02-17 18:38:03.187 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20737,"method":"get_fresh_map_v1"}
        2020-02-17 18:38:03.187 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf7b9b66199d24480bccbd9acd2a0c57be59fe29a3ae872d659f38865e7a84193821e36499f1b47b2609bb99ecb68a6a984a492e67f026eaac8d253394ee925b5c20
        2020-02-17 18:38:03.188 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:38:03.565 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20737}<<< 21310060000000000f9e615a5e4acf7b1810d8f999f812829d3609cfa5505be683b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e02768d511419f52b4d3c702345c274257ceff223a5282c3f68863ab3c7d91488f88
        2020-02-17 18:38:04.066 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20738,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:38:04.067 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf7c
        2020-02-17 18:38:04.068 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20738,"method":"get_fresh_map_v1"}
        2020-02-17 18:38:04.068 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf7c2b164d16bca37ff385c9eca3837fad7bf6577248fea439598faf322f6da8e7828a526a03983198ba85ec12e272c849cc6254784d4e55a031c0a5fe1424509657
        2020-02-17 18:38:04.068 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:38:04.084 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20738}<<< 21310060000000000f9e615a5e4acf7bbe80ea20a15a3ef9b5ea303901a22d5983b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e02733da5c74461b72610f288a508e0ed932b086aa5919ce2c46419e7c42eb8b641d
        2020-02-17 18:38:04.585 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20739,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:38:04.586 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf7c
        2020-02-17 18:38:04.586 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20739,"method":"get_fresh_map_v1"}
        2020-02-17 18:38:04.587 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf7c40d7416fb14fe88e9b03dd25f85728ab87307460f0eaad6883ecb3ea5ae1c08fda048b13f4e1282f5ba08896b649c970956ba9ef334a6c30a7e9c79afb3c3b66
        2020-02-17 18:38:04.587 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:38:04.658 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20739}<<< 21310060000000000f9e615a5e4acf7cfb96b6a63a283d4552a41ae0ddf2d9a283b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027e9a6fe4ee16defea7bc604a4c08588456bf55811f3ed0c6f8c9a4cb35bf8f698
        2020-02-17 18:38:05.159 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20740,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:38:05.160 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf7d
        2020-02-17 18:38:05.160 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20740,"method":"get_fresh_map_v1"}
        2020-02-17 18:38:05.161 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf7de5b21c4f6b44218da0f7af326bc660107fe50fdfd4021de20427fe6dd3c8d5dd9e23457d7c0063c57fdb124fd85ffda7322a982ff7ccd353cb62a2f5e4cb5769
        2020-02-17 18:38:05.161 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:38:05.207 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20740}<<< 21310060000000000f9e615a5e4acf7c27cde674a17170bd92cf59af6f92d24583b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e027bab14ab5602aa20cf83d1f150a7d455fd3decc6de73797e2e7ff73a1dfb0a231
        2020-02-17 18:38:05.709 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20741,"set_custom_mode":20667,"app_charge":18030}
        2020-02-17 18:38:05.709 - debug: mihome-vacuum.0 (16111) Timestamp: 5e4acf7d
        2020-02-17 18:38:05.710 - debug: mihome-vacuum.0 (16111) sendMsg >>> {"id":20741,"method":"get_fresh_map_v1"}
        2020-02-17 18:38:05.710 - debug: mihome-vacuum.0 (16111) sendMsgRaw >>> 21310050000000000f9e615a5e4acf7d41f2b03e0259499d6c4a4e7d948451b08d72c18d68d281417ae5f77e19251e8ecf34890ac331cc62fe2bfea6d091ad6d8201a5c1193a110f1c5979ec964cf8f3
        2020-02-17 18:38:05.710 - debug: mihome-vacuum.0 (16111) Mappointer_nomap___tanos%2F262037850%2F18
        2020-02-17 18:38:05.732 - debug: mihome-vacuum.0 (16111) Receive <<< {"result":["tanos%2F262037850%2F18"],"id":20741}<<< 21310060000000000f9e615a5e4acf7d9d270e813ebde21e5788c9733011d4bd83b18267fdfb5e6c3468ffcfcd9d155ee182715ead510376a5dd00b1eb75e0279b7dfbf0f3934e6521daadf74cf155579d90e7829f3a0293d50630f2b5913f7f
        2020-02-17 18:38:06.243 - debug: mihome-vacuum.0 (16111) lastid{"get_status":20720,"get_consumable":20714,"get_clean_summary":20716,"get_clean_record":20307,"X_send_command":19713,"miIO.info":20713,"get_sound_volume":20717,"get_map_v1":20718,"get_carpet_mode":7,"get_room_mapping":19713,"get_fresh_map_v1":20742,"set_custom_mode":20667,"app_charge":18030}
        Das sind die Räume erstellt in der App !
        Meistertr 1 Reply Last reply Reply Quote 0
        • haselchen
          haselchen Most Active @Meistertr last edited by
          @Meistertr
          die 2.0.4 bringt soweit keine Fehler mehr.
          Danke dafür!
          Nun hakt es bei der aktuellen Karte bzw. map url.
          mihome-vacuum.0 2020-02-17 18:49:53.608 error (5783) Error when receiving mapurl
          In VIS zeigt er noch die Karte von gestern vom 1 .Stock an.
          Starte ich jetzt den Robbi im Erdgeschoss, dann wird in der App die aktuelle Karte angezeigt, in VIS bleibt aber die von gestern und es tut sich nichts.
          Log versuche ich zu bekommen beim nächsten Saugversuch.
          • Meistertr
            Meistertr Developer @Kaschi68 last edited by
            @Kaschi68 bitte nochmal von git ich hatte mich verrechnet, jetzt sollte es gehen
            K haselchen 2 Replies Last reply Reply Quote 1
              Kaschi68 @Meistertr last edited by
              @Meistertr
              1A, jetzt läuft alles...... Vielen Dank 👍 👍 👍
              und schönen Abend
              • haselchen
                @Meistertr
                Wollte ich auch gerade schreiben.
                Nochmal von Gitub geladen.
                Karte ist da, URL wird auch befüllt.
                Bisher lüppt alles.
                Vielen Dank 👍 👍
                  sabphil22 last edited by sabphil22
                  wollte grade die aktuelle Version testen.
                  Leider kommt es zu folgenden Fehler:
                  canvas@2.6.1 install /opt/iobroker/node_modules/canvas
                  node-pre-gyp install --fallback-to-build
                  node-pre-gyp WARN Using request for node-pre-gyp https download
                  node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v64-linux-glibc-arm.tar.gz
                  node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@10.19.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
                  Package pixman-1 was not found in the pkg-config search path.
                  Perhaps you should add the directory containing pixman-1.pc' to the PKG_CONFIG_PATH environment variable No package 'pixman-1' found gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp gyp ERR! configure error gyp ERR! stack Error: gyp` failed with exit code: 1
                  gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
                  gyp ERR! stack at ChildProcess.emit (events.js:198:13)
                  gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                  gyp ERR! System Linux 4.19.97-v7l+
                  gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
                  gyp ERR! cwd /opt/iobroker/node_modules/canvas
                  gyp ERR! node -v v10.19.0
                  gyp ERR! node-gyp -v v5.0.5
                  gyp ERR! not ok
                  node-pre-gyp ERR! build error
                  node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
                  node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                  node-pre-gyp ERR! stack at ChildProcess.emit (events.js:198:13)
                  node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:982:16)
                  node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                  node-pre-gyp ERR! System Linux 4.19.97-v7l+
                  node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                  node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                  node-pre-gyp ERR! node -v v10.19.0
                  node-pre-gyp ERR! node-pre-gyp -v v0.11.0
                  node-pre-gyp ERR! not ok
                  npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! canvas@2.6.1 install: node-pre-gyp install --fallback-to-build
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the canvas@2.6.1 install script.
                  npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  npm ERR! /home/iobroker/.npm/_logs/2020-02-17T18_44_10_000Z-debug.log
                  Hardware ist ein RPI4
                  Nodejs 10.19.0
                  Hat einer die neue Version schon auf dem RPI4 ans laufen bekommen?
                  Edit: Hab es mit dem Beitrag von Foxriver fixen können:
                  https://forum.iobroker.net/topic/26900/hinzufuegen-von-roomba-adapter-wirft-fehler/2
                  • Meistertr
                    Meistertr Developer @sabphil22 last edited by
                    @sabphil22 schau mal in der readme habe es gerade hinzugefügt
                    • Meistertr
                      Für die S50 Besitzer habe ich noch die Raumerkennung mit eingebunden, wenn man eingeloggt ist, werden die Raüme aus der Karte gelesen und angelegt version 2.0.5
                        sabphil22 @Meistertr last edited by
                        @Meistertr sagte in Test Adapter mihome-vacuum v2.0.x:
                        pdown Menü ist nur ein Zwischenspeicher nach Auswahl des Gerätes werden die anderen Felder gesetzt. Die Liste der Geräte wird nur tämporär gespeichert
                        Ich habe nur ein Gerät zur Auswahl, allerdings wird, wenn ich es anklicke, der manuelle Bereich für den Token nicht gefüllt und speichern kann ich nicht, da kein Token eingetragen ist.
                        • Meistertr
                          @sabphil22 ist es den das richtige gerät? steht der token mit im Dropdown drin ? Die Liste MUSS exact den angelegenten Geräten in der app entsprechen, da beide sie von der gleichen stelle abgreifen. Ist dies nicht der fall, ist wahrscheinlich der Server falsch
                            @Meistertr das Gerät, Token und Ip Adresse stimmen. Wenn ich auf "Get Devices" klicke wird das Gerät vorgeblendet. Auch wenn ich es nochmal im Dropdown anwähle, wird der Token in den manuellen Einstellungen nicht eingetragen.
                            • Meistertr
                              @sabphil22 ok den Fall mit einem Gerät hatte ich noch nicht, schau ich mir morgen an
                              • Diginix
                                Diginix @haselchen last edited by Diginix
                                @haselchen sagte in Test Adapter mihome-vacuum v2.0.x:
                                @Meistertr
                                Danke dafür!
                                Bei mir kommt heute auch nur dieser Fehler.
                                2020-02-17 19:51:16.744  - [31merror [39m: mihome-vacuum.0 (19013) Error when receiving mapurl
                                Allerdings sagt sogar die MiHome App dass sie Probleme hat Daten vom China Server zu erhalten. Also warte ich mal ab und gehe von einem Netzwerk Problem aus.
                                • haselchen
                                  haselchen Most Active @Diginix last edited by haselchen
                                  @Diginix
                                  Hab den DE Server.
                                  Mitunter bekomme ich jetzt ab und zu wilde Fehlermeldungen.
                                  2020-02-17 19:40:42.807 - error: mihome-vacuum.0 (7751) Unknown state "mihome-vacuum.0.rooms.manual_1.mapIndex"
                                  2020-02-17 19:42:05.670 - info: mihome-vacuum.0 (7751) create new room: manual_2
                                  2020-02-17 19:43:04.001 - info: mihome-vacuum.0 (7751) create new room: manual_3
                                  2020-02-17 19:43:48.096 - info: mihome-vacuum.0 (7751) create new room: manual_4
                                  Obwohl die Räume vorher auch so angelegt waren. Räume 2,3,4 wurden ja auch wie man sieht normal angelegt.
                                  Und das kam mit der Version 2.0.5 als ich eine Raumreinigung gemacht habe, die auch normal ausgeführt wurde.
                                  2020-02-17 19:56:48.393 - error: mihome-vacuum.0 (8437) TypeError: Cannot read property '0' of undefined
                                  2020-02-17 19:56:50.698 - error: mihome-vacuum.0 (8437) TypeError: Cannot read property '0' of undefined
                                  2020-02-17 19:56:52.983 - error: mihome-vacuum.0 (8437) TypeError: Cannot read property '0' of undefined
                                  2020-02-17 19:56:55.230 - error: mihome-vacuum.0 (8437) TypeError: Cannot read property '0' of undefined
                                  2020-02-17 19:56:57.485 - error: mihome-vacuum.0 (8437) TypeError: Cannot read property '0' of undefined
                                  2020-02-17 19:56:59.792 - error: mihome-vacuum.0 (8437) TypeError: Cannot read property '0' of undefined
                                  2020-02-17 19:57:02.041 - error: mihome-vacuum.0 (8437) TypeError: Cannot read property '0' of undefined
                                  Mit der Karte muss ich mal gucken wie das ist, wenn er wieder im 1.Stock war und dann wieder Erdgeschoss.
                                  Aber ansonsten klasse Leistung von den Entwicklern.
                                  Ich denke, dass sie nicht mehr weit vom perfekten MiHome-Vacuum Adapter weg sind!
                                    dirkhe Developer last edited by
                                    Da werden wir wohl ein debug log brauchen, so können wir damit leider nichts anfangen
                                    • Patchwork 3001
                                      Patchwork 3001 @dirkhe last edited by
                                      @dirkhe habe bis jetzt alles neu aufgesetzt habe es mir total zerschossen. würde halt schon gern die einzelnen zimmer räume nutzen wenn es geht
                                        Was heisst zerschossen, ggf. Mal den adapter deinstallieren und dann wieder neu installieren.
                                        Patchwork 3001 1 Reply Last reply Reply Quote 0
                                        • Patchwork 3001
                                          @dirkhe hab solange rum probiert bis der ras4 nicht mehr die Web Oberfläche aufmachen wollte.
                                          dann halt mehrfach versucht ein Backup wieder einzuspielen aber immer an unterschiedlichen punkten Fehler gehabt.
                                          also zum Saturn ne jute micro sd geholt und sauber neu aufgespielt. läuft jetzt bis auf die neue für den robo s5
                                            Also was klappt denn nicht? Wenn das installieren nicht klappt, gibt es hier im Forum genug Hinweise. Gestern habe ich sogar einen eigenen Thread dafür gesehen.
                                            Wenn irgendeine Funktion nicht geht, am besten auf debug stellen und das dann hier Posten.
                                            1.5k
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            490416
