    4. Fehler bei der Installation
    SOLVED Fehler bei der Installation
      martin last edited by
      Danke.
      Habe jetzt versucht das letzte Backup einzuspielen.
      Hier aber jetzt Probleme mit denen ich nicht klar komme.
      root@iobroker:/# iobroker stop
      root@iobroker:/# iobroker restore 0
      host.iobroker Using backup file total_2019_11_25-02_00_10_backupiobroker.tar.gz
      host.iobroker Cannot find extracted file from file "/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json"
      iobroker controller daemon is not running
      host.iobroker OK.
      (node:4959) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'
          at Object.openSync (fs.js:443:3)
          at Object.readFileSync (fs.js:343:35)
          at BackupRestore.restoreAfterStop (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:566:23)
          at Daemon.daemon.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:846:22)
          at Daemon.emit (events.js:203:15)
          at Daemon._kill (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:246:14)
          at Daemon.stop (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:185:17)
          at tar.extract.err (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:848:20)
      (node:4959) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
      (node:4959) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      root@iobroker:/#
      • FredF
        FredF Most Active Forum Testing @martin last edited by
        @martin
        Ich bin mir nicht sicher, aber muß ioBroker vorher gestoppt werden?
          Wenn er läuft kommt die Meldung, dass man ihn stoppen soll.
          • FredF
            @martin
            Das gemacht
            You need to re-login before doing anything else on the console!
              martin last edited by martin
              Ja, ich mache nach jedem Schritt ein Reboot.
              root@iobroker:~# iobroker upgrade self
              Host    "iobroker"       is up to date.
              • FredF
                @martin Dann probier doch mal das fixer script drüber laufen zu lassen.
                curl -sL https://iobroker.net/fix.sh | bash -
                  Habe jetzt alles (Debian + Iobroker) neu aufgesetzt.
                  root@iobroker:~# iobroker restore 0
                  Dann das Fixer-Script laufen lassen (erfolgreich) und nochmal restore.
                  host.iobroker OK.
                  root@iobroker:~#
                  Ich habe von der gecrashten Festplatte den /opt/iobroker Ordner kopieren können.
                  Kann ich den einfach per FTP drüber bügeln?
                    Habe es jetzt mal mit "backitup" versucht.
                    Log Backitup Restore:
                    [DEBUG] [iobroker] Start ioBroker Restore ...
                    [ERROR] [iobroker] host.iobroker Cannot find extracted file from file "/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json"
                    [DEBUG] [iobroker] iobroker controller daemon is not running
                    [DEBUG] [iobroker] host.iobroker OK.
                    [DEBUG] [iobroker] ioBroker Restore completed successfully
                    [EXIT] 9 **** Restore completed successfully!! ****
                    The log can be closed ...
                      Und nach iobroker upgrade self das hier:
                      root@iobroker:/opt/iobroker# iobroker restore 0
                      host.iobroker Using backup file iobroker_2020_02_18-19_14_04_backupiobroker.tar.gz
                      host.iobroker OK.
                      (node:1151) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'
                          at Object.openSync (fs.js:439:3)
                          at Object.readFileSync (fs.js:344:35)
                          at Daemon.emit (events.js:194:15)
                      (node:1151) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
                      (node:1151) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                        Lösung:
                        du legst dein Backup in den Ordner /opt/iobroker und führst folgenden Befehl in diesem Ordner aus:
                        iobroker stop
                        cd /opt/iobroker
                        sudo tar -xzvf Backupname.tar.gz -C /opt/iobroker
                        iobroker start
                        Jetzt läuft alles zumindest mal wieder und meine Daten sind da.
                        Werde die nächsten Tage mal ein Standard-Backup erstellen das ich dann hoffentlich in eine saubere Neuinstallation per "Restore" einspielen kann.
                        iobroker installation
                        955
