    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер ioBroker MySensors
      Maxtox last edited by
      презентация идёт!!!
      см:
      0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0-beta)
      0;255;3;0;14;Gateway startup complete.
      0;255;3;0;11;ETHduino by JR
      0;255;3;0;12;1.0
      255
      0
      0;0;0;0;255;RX
      0;0;1;0;77;for Warnings
      255
      0;1;0;0;255;TX
      0;1;1;0;77;for Warnings
      a LOG= empty!
      host-raspberrypi	2016-02-19 14:19:30	info	instance system.adapter.mysensors.0 started with pid 4281
      host-raspberrypi	2016-02-19 14:19:28	info	instance system.adapter.mysensors.0 terminated with code 0 (OK)
      mysensors-0	2016-02-19 14:19:28	info	terminating
      mysensors-0	2016-02-19 14:19:28	info	cleaned everything up...
      host-raspberrypi	2016-02-19 14:19:28	info	stopInstance system.adapter.mysensors.0 killing pid 4265
      host-raspberrypi	2016-02-19 14:19:28	info	object change system.adapter.mysensors.0
      mysors-0	2016-02-19 14:19:07	info	obj.callback...ToDo выслать список СОМ портов
      admin-0	2016-02-19 14:19:06	info	sendTo "list_uart" to system.adapter.mysensors.0 from system.adapter.admin.0: null
      mysensors-0	2016-02-19 14:18:57	error	setObject id missing!!
      mysensors-0	2016-02-19 14:18:57	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.mysensors
      host-raspberrypi	2016-02-19 14:18:53	info	instance system.adapter.mysensors.0 started with pid 4234
      host-raspberrypi	2016-02-19 14:18:51	info	instance system.adapter.mysensors.0 terminated with code 0 (OK)
      mysensors-0	2016-02-19 14:18:51	info	terminatingensors-0	2016-02-19 14:19:20	error	setObject id missing!!
      mysensors-0	2016-02-19 14:19:20	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.mysensors
      host-raspberrypi	2016-02-19 14:19:16	info	instance system.adapter.mysensors.0 started with pid 4265
      host-raspberrypi	2016-02-19 14:19:14	info	instance system.adapter.mysensors.0 terminated with code 0 (OK)
      mysensors-0	2016-02-19 14:19:14	info	terminating
      host-raspberrypi	2016-02-19 14:19:14	info	stopInstance system.adapter.mysensors.0 killing pid 4234
      host-raspberrypi	2016-02-19 14:19:14	info	object change system.adapter.mysensors.0
      mysensors-0	2016-02-19 14:19:14	info	cleaned everything up...
      mysensors-0	2016-02-19 14:19:07	info	sendTo "list_uart" to system.adapter.admin.0 from system.adapter.mysensors.0: [{"comName":"ttyAMA0","vendorId":"0xundefined","productId":"0xundefined"},{"comName":"/dev/ttyUSB0","manufacturer":"1a86"
      mysens
      Ты на 1.6 или 1.5 от Mysesnors?
        cm my .ino
        933_mysensors_serial_work_v1.rar
        • V
          Vlad_k last edited by
          0;255;3;0;12;1.0
          255                                                   -?
          0                                                       -?
          0;0;0;0;255;RX
          255                                                   -?
          1                                                      -?
          0;1;0;0;255;TX
          на них парсер отваливается это не стандартная посылка mysensors, у меня 1.5.1 и 1.5.4 библиотеки
          1.5.4 сегодня скачал ,порадовала , теперь платы на китайском клоне Si24R1 опять видятся в сети с nRF24
          • V
            @Maxtox:
            cm my .ino `
            MYSENSORS_SERIAL_WORK_V1.ino:131:22: fatal error: Ethernet.h: No such file or directory
            не компилируется…
            все разобрался с твоими сообщениями, нода шлюза не прописывается в таблицу и поэтому не отображается, загрузи стандартный скетч шлюза из примеров библиотеки...
              Да… Я на 1.6 от mysensor, так как только там работает MQTT, signing и многое другое...
              Можешь пожалуйста и для 1.6 доработать? Тогда легче будет для MQTT и для шифрования трафика.
              Могу помочь тестировать!
              К стати, на счёт шлюза не понимаю... В логе же стоит что он начало всё читает. Я даже одну строчку с считаной температурой в логе видел...
              Можешь у себя залить и уувидишь что serial всё посылает...
              • V
                у тебя как я понял, шлюз и нода с сенсорами все в одном? а к сети через ESP цепляешь?
                скинь мне лог из терминала общения твоего шлюза с другими нодами, и минут через 5(счас залью) переустанови драйвер, чуть поправил чтоб шлюз в таблицу заносился.
                  Log:
                  0;255;3;0;12;1.0
                  0;0;0;0;255;RX
                  0;1;0;0;255;TX
                  0;7;0;0;4;Test PWM
                  0;7;1;0;77;for Warnings
                  0;8;0;0;3;RELAY D8
                  0;8;1;0;77;for Warnings
                  0;10;0;0;255;W5100
                  0;10;1;0;77;for Warnings
                  0;11;0;0;0;Digital Ein
                  0;11;1;0;77;for Warnings
                  0;13;0;0;4;Test PWM
                  0;13;1;0;77;for Warnings
                  0;16;0;0;255;LEDS_BLINKING_FEATURE
                  0;16;1;0;77;for Warnings
                  0;18;0;0;4;Pumpe1_T5
                  0;18;1;0;77;for Warnings
                  0;20;0;0;4;Pumpe2_T3
                  0;20;1;0;77;for Warnings
                  0;22;0;0;3;RELAY D8
                  0;22;1;0;77;for Warnings
                  0;23;0;0;3;RELAY D8
                  0;23;1;0;77;for Warnings
                  0;24;0;0;3;RELAY D8
                  0;24;1;0;77;for Warnings
                  0;25;0;0;3;RELAY D8
                  0;25;1;0;77;for Warnings
                  0;26;0;0;3;RELAY D8
                  0;26;1;0;77;for Warnings
                  0;27;0;0;3;RELAY D8
                  0;27;1;0;77;for Warnings
                  0;28;0;0;3;RELAY D8
                  0;28;1;0;77;for Warnings
                  0;29;0;0;3;RELAY D8
                  0;29;1;0;77;for Warnings
                  0;30;0;0;3;RELAY D8
                  0;30;1;0;77;for Warnings
                  0;31;0;0;3;RELAY D8
                  0;31;1;0;77;for Warnings
                  0;32;0;0;3;RELAY D8
                  0;32;1;0;77;for Warnings
                  0;33;0;0;3;RELAY D8
                  0;33;1;0;77;for Warnings
                  0;34;0;0;3;RELAY D8
                  0;34;1;0;77;for Warnings
                  0;35;0;0;3;RELAY D8
                  0;35;1;0;77;for Warnings
                  0;36;0;0;3;RELAY D8
                  0;36;1;0;77;for Warnings
                  0;37;0;0;3;RELAY D8
                  0;37;1;0;77;for Warnings
                  0;38;0;0;255;MAX31855
                  0;38;1;0;77;for Warnings
                  0;39;0;0;255;MAX31855
                  0;39;1;0;77;for Warnings
                  0;42;0;0;6;dallas
                  0;42;1;0;77;for Warnings
                  0;50;0;0;255;W5100
                  0;50;1;0;77;for Warnings
                  0;51;0;0;255;W5100
                  0;51;1;0;77;for Warnings
                  0;52;0;0;255;W5100
                  0;52;1;0;77;for Warnings
                  0;255;3;0;9;Init complete, id=0, parent=0, distance=0
                  Current State of PIN: 11 changes to: 1
                  0;11;1;1;15;1
                  Temperature for the sensor 42 is -127.00
                  0;42;1;1;0;-127.00
                  tempNTC of Pin 58 is 27.48
                  0;58;1;1;0;27.48
                  0;42;1;1;0;-127.00
                  tempNTC of Pin 58 is 35.45
                  0;58;1;1;0;35.45
                  0;42;1;1;0;-127.00
                  0;42;1;1;0;-127.00
                  tempNTC of Pin 58 is 37.26
                  0;58;1;1;0;37.26
                  0;42;1;1;0;-127.00
                  0;42;1;1;0;-127.00
                  tempNTC of Pin 58 is 38.81
                  0;58;1;1;0;38.81
                  0;42;1;1;0;-127.00
                  0;42;1;1;0;-127.00
                  0;42;1;1;0;-127.00
                  tempNTC of Pin 58 is 37.57
                  0;58;1;1;0;37.57
                  0;42;1;1;0;-127.00
                  tempNTC of Pin 58 is 38.08
                  0;58;1;1;0;38.08
                  0;42;1;1;0;-127.00
                  tempNTC of Pin 58 is 39.02
                  0;58;1;1;0;39.02
                  0;42;1;1;0;-127.00
                  0;42;1;1;0;-127.00
                  0;42;1;1;0;-127.00
                  tempNTC of Pin 58 is 37.67
                  0;58;1;1;0;37.67
                  0;42;1;1;0;-127.00
                  0;42;1;1;0;-127.00
                  0;42;1;1;0;-127.00
                  tempNTC of Pin 58 is 38.50
                  0;58;1;1;0;38.50
                  0;42;1;1;0;-127.00
                  0;42;1;1;0;-127.00
                  tempNTC of Pin 58 is 39.34
                  0;58;1;1;0;39.34
                  0;42;1;1;0;-127.00
                  0;42;1;1;0;-127.00
                    @Vlad_k:
                    скинь мне лог из терминала общения твоего шлюза с другими нодами, и минут через 5(счас залью) переустанови драйвер, чуть поправил чтоб шлюз в таблицу заносился. `
                    да…всё в одном
                    а остальное через NRF24L01
                    но пока не юзаю, т.к. ВСЁ В ОДНОМ 🙂
                    • V
                      0;11;1;1;15;1
                      0;42;1;1;0;-127.00
                      0;58;1;1;0;27.48
                      0;42;1;1;0;-127.00
                      0;58;1;1;0;35.45
                      вот это все прям в ком порт шлюз шлет (Temperature for the sensor 42 is -127.00),
                      скинь ссылку на 1.6 библиотеку
                        к стати…
                        елси
                        npm install https....
                        задавать из роота, то адаптера в админе не видно!!!!
                        /opt/iobroker
                        ````is ok!
                          смотри
                          https://youtu.be/FDPYlRaAp9E
                          а потом всё пропадает!!!!
                          host-raspberrypi 2016-02-19 19:50:09 info instance system.adapter.mysensors.0 started with pid 3189
                          host-raspberrypi 2016-02-19 19:49:46 info Restart adapter system.adapter.mysensors.0 because enabled
                          host-raspberrypi 2016-02-19 19:49:46 error instance system.adapter.mysensors.0 terminated with code 6 (uncaught exception)
                          mysensors-0 2016-02-19 19:49:46 info cleaned everything up…
                          TypeError: 2016-02-19 19:49:46 error at /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:388:9
                          TypeError: 2016-02-19 19:49:46 error at afterRead (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:372:20)
                          TypeError: 2016-02-19 19:49:46 error at SerialPortFactory.SerialPort._emitData (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:396:20)
                          TypeError: 2016-02-19 19:49:46 error at Object.SerialPort.opts.dataCallback (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:181:12)
                          TypeError: 2016-02-19 19:49:46 error at Object.parser (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/parsers.js:24:13)
                          TypeError: 2016-02-19 19:49:46 error at Array.forEach (native)
                          TypeError: 2016-02-19 19:49:46 error at /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/parsers.js:25:17
                          TypeError: 2016-02-19 19:49:46 error at SerialPort.EventEmitter.emit (events.js:95:17)
                          TypeError: 2016-02-19 19:49:46 error at SerialPort. (/opt/iobroker/node_modules/iobroker.mysensors/mysensors.js:293:8)
                          TypeError: 2016-02-19 19:49:46 error at mkdbmsgUnique (/opt/iobroker/node_modules/iobroker.mysensors/mysensors.js:121:23)
                          TypeError: 2016-02-19 19:49:46 error Cannot read property 'id' of undefined
                          uncaught 2016-02-19 19:49:46 error exception: Cannot read property 'id' of undefined
                          mysensors-0 2016-02-19 19:49:46 info Rx-Raw 255
                          mysensors-0 2016-02-19 19:49:46 info _0|255|internal|false|I_SKETCH_VERSION|_1.0
                          mysensors-0 2016-02-19 19:49:46 debug количество сообщений 3
                          mysensors-0 2016-02-19 19:49:46 info Rx-Raw 0;255;3;0;12;1.0
                          mysensors-0 2016-02-19 19:49:46 info _0|255|internal|false|I_SKETCH_NAME|_ETHduino by JR
                          mysensors-0 2016-02-19 19:49:46 debug количество сообщений 2
                          mysensors-0 2016-02-19 19:49:46 info Rx-Raw 0;255;3;0;11;ETHduino by JR
                          mysensors-0 2016-02-19 19:49:46 info _0|255|internal|false|I_GATEWAY_READY|_Gateway startup complete.
                          mysensors-0 2016-02-19 19:49:46 debug количество сообщений 1
                          mysensors-0 2016-02-19 19:49:46 info Rx-Raw 0;255;3;0;14;Gateway startup complete.
                          mysensors-0 2016-02-19 19:49:46 info _Temperature for the sensor 42 is0|255|internal|false|I_LOG_MESSAGE|_Starting gateway (R-NGA-, 2.0.0-beta)
                          mysensors-0 2016-02-19 19:49:46 debug количество сообщений 0
                          mysensors-0 2016-02-19 19:49:46 info Rx-Raw Temperature for the sensor 42 is0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0-beta)
                          log from Arduino:
                          0;42;1;1;0;-127.00
                          mysensors-0 2016-02-19 19:49:45 debug Communication port:/dev/ttyUSB0
                          mysensors-0 2016-02-19 19:49:45 info starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.mysensors
                          mysensors-0 2016-02-19 19:49:45 debug statesDB connected
                          mysensors-0 2016-02-19 19:49:45 debug objectDB connected
                          host-raspberrypi 2016-02-19 19:49:41 info instance system.adapter.mysensors.0 started with pid 3156
                          host-raspberrypi 2016-02-19 19:49:39 info Restart adapter system.adapter.mysensors.0 because enabled
                            after a new reset ардуины:
                            the LOG:
                            [color]host-raspberrypi	2016-02-19 19:53:16	info	Restart adapter system.adapter.mysensors.0 because enabled
                            host-raspberrypi	2016-02-19 19:53:16	error	instance system.adapter.mysensors.0 terminated with code 6 (uncaught exception)
                            mysensors-0	2016-02-19 19:53:16	info	cleaned everything up...
                            TypeError:	2016-02-19 19:53:16	error	at /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:388:9
                            TypeError:	2016-02-19 19:53:16	error	at afterRead (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:372:20)
                            TypeError:	2016-02-19 19:53:16	error	at SerialPortFactory.SerialPort._emitData (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:396:20)
                            TypeError:	2016-02-19 19:53:16	error	at Object.SerialPort.opts.dataCallback (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:181:12)
                            TypeError:	2016-02-19 19:53:16	error	at Object.parser (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/parsers.js:24:13)
                            TypeError:	2016-02-19 19:53:16	error	at Array.forEach (native)
                            TypeError:	2016-02-19 19:53:16	error	at /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/parsers.js:25:17
                            TypeError:	2016-02-19 19:53:16	error	at SerialPort.EventEmitter.emit (events.js:95:17)
                            TypeError:	2016-02-19 19:53:16	error	at SerialPort. (/opt/iobroker/node_modules/iobroker.mysensors/mysensors.js:293:8)
                            TypeError:	2016-02-19 19:53:16	error	at mkdbmsgUnique (/opt/iobroker/node_modules/iobroker.mysensors/mysensors.js:121:23)
                            TypeError:	2016-02-19 19:53:16	error	Cannot read property 'id' of undefined
                            uncaught	2016-02-19 19:53:16	error	exception: Cannot read property 'id' of undefined
                            mysensors-0	2016-02-19 19:53:16	info	Rx-Raw 255
                            mysensors-0	2016-02-19 19:53:16	info	__0_|_255_|_internal_|_false_|_I_SKETCH_VERSION_|_1.0
                            mysensors-0	2016-02-19 19:53:16	debug	количество сообщений 3
                            mysensors-0	2016-02-19 19:53:16	info	Rx-Raw 0;255;3;0;12;1.0
                            mysensors-0	2016-02-19 19:53:16	info	__0_|_255_|_internal_|_false_|_I_SKETCH_NAME_|_ETHduino by JR
                            mysensors-0	2016-02-19 19:53:16	debug	количество сообщений 2
                            mysensors-0	2016-02-19 19:53:16	info	Rx-Raw 0;255;3;0;11;ETHduino by JR
                            mysensors-0	2016-02-19 19:53:16	info	__0_|_255_|_internal_|_false_|_I_GATEWAY_READY_|_Gateway startup complete.
                            mysensors-0	2016-02-19 19:53:16	debug	количество сообщений 1
                            mysensors-0	2016-02-19 19:53:16	info	Rx-Raw 0;255;3;0;14;Gateway startup complete.
                            mysensors-0	2016-02-19 19:53:16	info	__Temperature for the sensor 42 is0_|_255_|_internal_|_false_|_I_LOG_MESSAGE_|_Starting gateway (R-NGA-, 2.0.0-beta)
                            mysensors-0	2016-02-19 19:53:16	debug	количество сообщений 0
                            mysensors-0	2016-02-19 19:53:16	info	Rx-Raw Temperature for the sensor 42 is0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0-beta)
                            mysensors-0	2016-02-19 19:53:15	debug	Communication port:/dev/ttyUSB0
                            mysensors-0	2016-02-19 19:53:15	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.mysensors
                            mysensors-0	2016-02-19 19:53:14	debug	statesDB connected
                            mysensors-0	2016-02-19 19:53:14	debug	objectDB connected[/color]
                            • V
                              Переустанавливай драйвер, сделал фильтрацию мусора, должно работать.
                              ты сам скетч писал?
                                Да… Писал сам....
                                Спасибо!
                                Сейчас оттестю...
                                  Console LOG:
                                  root@raspberrypi:/opt/iobroker# npm install https://github.com/DJONvl/iobroker.myse … all/master
                                  npm http GET https://github.com/DJONvl/iobroker.myse ... all/master
                                  npm http 200 https://github.com/DJONvl/iobroker.myse ... all/master
                                  npm http GET https://registry.npmjs.org/sensors
                                  npm http GET https://registry.npmjs.org/serialport
                                  npm http 304 https://registry.npmjs.org/sensors
                                  npm http 304 https://registry.npmjs.org/serialport
                                  npm http GET https://registry.npmjs.org/optimist
                                  npm http GET https://registry.npmjs.org/nan
                                  npm http GET https://registry.npmjs.org/bindings/1.2.1
                                  npm http GET https://registry.npmjs.org/sf/0.1.7
                                  npm http GET https://registry.npmjs.org/async/0.9.0
                                  npm http GET https://registry.npmjs.org/debug
                                  npm http 304 https://registry.npmjs.org/nan
                                  npm http 304 https://registry.npmjs.org/debug
                                  npm http 304 https://registry.npmjs.org/sf/0.1.7
                                  npm http 200 https://registry.npmjs.org/optimist
                                  npm http 304 https://registry.npmjs.org/bindings/1.2.1
                                  npm http 304 https://registry.npmjs.org/async/0.9.0
                                  npm http GET https://registry.npmjs.org/ms/0.7.1
                                  npm http 304 https://registry.npmjs.org/ms/0.7.1
                                  npm http GET https://registry.npmjs.org/wordwrap
                                  npm http GET https://registry.npmjs.org/minimist
                                  npm http 304 https://registry.npmjs.org/wordwrap
                                  npm http 304 https://registry.npmjs.org/minimist
                                  serialport@2.0.6 install /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport
                                  node-pre-gyp install --fallback-to-build
                                  node-pre-gyp http GET https://github.com/voodootikigod/node-s … arm.tar.gz
                                  node-pre-gyp http 404 https://github.com/voodootikigod/node-s ... arm.tar.gz
                                  node-pre-gyp http Pre-built binary not available for your system, looked for https://github.com/voodootikigod/node-s ... arm.tar.gz (falling back to source compile with node-gyp)
                                  make: Entering directory '/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build'
                                  CXX(target) Release/obj.target/serialport/src/serialport.o
                                  CXX(target) Release/obj.target/serialport/src/serialport_unix.o
                                  CXX(target) Release/obj.target/serialport/src/serialport_poller.o
                                  SOLINK_MODULE(target) Release/obj.target/serialport.node
                                  SOLINK_MODULE(target) Release/obj.target/serialport.node: Finished
                                  COPY Release/serialport.node
                                  COPY /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build/Release/node-v11-linux-arm/serialport.node
                                  TOUCH Release/obj.target/action_after_build.stamp
                                  make: Leaving directory '/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build'
                                  iobroker.mysensors@0.0.1 node_modules/iobroker.mysensors
                                  ├── sensors@0.1.0
                                  └── serialport@2.0.6 (bindings@1.2.1, sf@0.1.7, async@0.9.0, nan@2.0.9, debug@2.2.0, optimist@0.6.1)
                                    смотрим!!!
                                    https://youtu.be/SyWTYB084xQ
                                    УЖЕ ЛУЧШЕ!
                                    Только BIND не сработал!
                                    • V
                                      bind срабатывает, только переменная не сохраняется
                                      смотри что сделай:
                                      нажми bind в списке devices появятся твои юниты щелкни по любому 2 раза и нажми сохранить, чтобы активировалась кнопка Сохранить и выйти
                                      ToDo сделать активацию сохранения при добавлении в список новых юнитов
                                        Ок… Попробую...
                                          Привет, могу ставить новую версию? Bluefox что-то запулил?!
                                          • V
                                            да ставь
                                            106
                                            31401
