    4. Test Adapter mihome-vacuum v2.0.x
    • Meistertr
      Meistertr Developer @Ralf_N last edited by
      @Ralf_N also laut log hat er einen raum gefunden und angelegt
      Ralf_N 1 Reply Last reply Reply Quote 0
      • Ralf_N
        Ralf_N @Meistertr last edited by
        @Meistertr
        Ich nutze kein VIS.
        Wo muss die Karte im Objektbaum erkennbar sein ?
        • Ralf_N
          @Meistertr
          Meistertr 1 Reply Last reply Reply Quote 0
            dirkhe Developer last edited by
            Bei dir heißt der manuals_
            • Ralf_N
              Ralf_N @dirkhe last edited by
              @dirkhe
              bei clean ROOM passiert das:
              host.iobroker	2020-02-19 22:05:52.418	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
              host.iobroker	2020-02-19 22:05:52.418	info	instance system.adapter.mihome-vacuum.0 terminated with code 0 (NO_ERROR)
              host.iobroker	2020-02-19 22:05:52.418	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
              host.iobroker	2020-02-19 22:05:52.418	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
              host.iobroker	2020-02-19 22:05:52.418	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
              host.iobroker	2020-02-19 22:05:52.418	error	Caught by controller[0]: at client.mget (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:619:13)
              host.iobroker	2020-02-19 22:05:52.418	error	Caught by controller[0]: at states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5922:17)
              host.iobroker	2020-02-19 22:05:52.418	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/roomManager.js:120:53
              host.iobroker	2020-02-19 22:05:52.418	error	Caught by controller[0]: TypeError: Cannot read property '0' of null
              mihome-vacuum.0	2020-02-19 22:05:51.909	info	(43649) Terminated (NO_ERROR): Without reason
              mihome-vacuum.0	2020-02-19 22:05:51.908	info	(43649) terminating
              mihome-vacuum.0	2020-02-19 22:05:51.906	error	at process._tickCallback (internal/process/next_tick.js:68:7)
              mihome-vacuum.0	2020-02-19 22:05:51.906	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
              mihome-vacuum.0	2020-02-19 22:05:51.906	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
              mihome-vacuum.0	2020-02-19 22:05:51.906	error	at client.mget (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:619:13)
              mihome-vacuum.0	2020-02-19 22:05:51.906	error	at states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5922:17)
              mihome-vacuum.0	2020-02-19 22:05:51.906	error	at /opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/roomManager.js:120:53
              mihome-vacuum.0	2020-02-19 22:05:51.906	error	(43649) TypeError: Cannot read property '0' of null
              mihome-vacuum.0	2020-02-19 22:05:51.905	error	(43649) uncaught exception: Cannot read property '0' of null
              • Meistertr
                Meistertr Developer @Ralf_N last edited by Meistertr
                @Ralf_N so bitte nochmal von git ich hatte einen rechtschreibfehler drin wodurch die räume nicht angelegt wurden wenn du die map nciht nutzt, würde ich sie anschließend wieder deaktivieren, da sonst die Resoucen verschwendet werden
                B D Ralf_N 3 Replies Last reply Reply Quote 0
                  blackeagle998 @Meistertr last edited by blackeagle998
                  @Meistertr
                  Yeah, funktioniert 👍 👍 👍
                  Räume wurden jetzt angelegt.
                  • Meistertr
                    Meistertr Developer @blackeagle998 last edited by
                    @blackeagle998 gut dass ist das stichwort fürs bett 🙂
                      dirkhe Developer @Meistertr last edited by
                      @Meistertr sagte in Test Adapter mihome-vacuum v2.0.x:
                      @Meistertr macht es Sinn, MAP.StartMapPoll(); paar Zeilen nach oben zu verschieben und nur zu aktivieren, wenn Cleaning aktiv?
                      • Ralf_N
                        @Meistertr
                        hier knallt es, wenn ich auf roomClean klicker 😞
                        iobroker.2020-02-19_3.log.html
                          dirkhe Developer @Ralf_N last edited by
                          @Ralf_N lösche mal den falsch angelegten Raum Manual_
                          Ralf_N 2 Replies Last reply Reply Quote 0
                          • Meistertr
                            @dirkhe die Funktion wird ja nur aufgerufen wenn map aktiviert und wenn er sich bewegt.. oder wie meinst du das? nochmehr kaseln macht ja irgendwie wenig sinn..
                            • Ralf_N
                              soderle..
                              Habe jetzt mal eigenmächtig diesen manual_ raum gelöscht
                              Zack , erscheint ein room1 ( mehr hab ich nicht, da Karte heute abend geloescht )
                              und der Adapter schmiert nicht bei roomclear ab , sondern schickt den Robbie los !
                              Ein riesiger Fortschritt !!!
                              @Meistertr gute Nachte !!!!! 🙂 🙂
                              "Die Tage" dann mehr 😉
                              Vielen lieben Danke Euch allen !!!!
                                Jap herzlichen Dank für diesen top Support!
                                Gute Nacht 😴
                                  @Meistertr sorry, du hast natürlich recht, ich hatte die Status Abfrage übersehen
                                  • Ralf_N
                                    @dirkhe
                                    sorry, das hab ich zu spät gelesen. 😞
                                    Bin aber selber drauf gekommen , Sie unten 🙂 🙂 🙂
                                    • Ralf_N
                                      Ralf_N @dirkhe last edited by Ralf_N
                                      @dirkhe said in Test Adapter mihome-vacuum v2.0.x:
                                      Bin aber selber drauf gekommen , Sie unten, aehh oben ! 🙂 🙂 🙂
                                        @Ralf_N alles gut. Den Fehler werde ich aber totzdem noch abfangen
                                          Guten Morgen,
                                          Testfahrt läuft bisher sehr gut, einen kleinen Fehler habe ich:
                                          2020-02-20 08:06:38.685 - warn: javascript.0 (6095) You are assigning a boolean to the state "mihome-vacuum.0.control.carpet_mode" which expects a switch. Please fix your code to use a switch or change the state type to boolean. This warning might become an error in future versions.
                                          Gesetzt wird der Wert per Befehl:
                                          setState('mihome-vacuum.0.control.carpet_mode', true);
                                            Coffeelover @base last edited by
                                            @base Gerne.
                                              "settings": {
                                                "style": {
                                                  "background": "linear-gradient(205deg, #000020, #191970 4%, #000020 4%,#000020)",
                                                  "font-family": "Jura-Regular",
                                                  "color": "#bbb9b9",
                                                  "letter-spacing": ""
                                                "theme": "eggplant",
                                                "sizex": "1280",
                                                "sizey": "800",
                                                "gridSize": "",
                                                "useBackground": true,
                                                "snapType": null
                                              "widgets": {
                                                "e00001": {
                                                  "tpl": "tplVis-materialdesign-List",
                                                  "data": {
                                                    "g_fixed": false,
                                                    "g_visibility": false,
                                                    "g_css_font_text": true,
                                                    "g_css_background": false,
                                                    "g_css_shadow_padding": false,
                                                    "g_css_border": false,
                                                    "g_gestures": false,
                                                    "g_signals": false,
                                                    "g_last_change": false,
                                                    "visibility-cond": "==",
                                                    "visibility-val": 1,
                                                    "visibility-groups-action": "hide",
                                                    "count": "7",
                                                    "listType": "switch",
                                                    "listItemDividerStyle": "standard",
                                                    "listLayout": "standard",
                                                    "vibrateOnMobilDevices": "50",
                                                    "signals-cond-0": "==",
                                                    "signals-val-0": true,
                                                    "signals-icon-0": "/vis/signals/lowbattery.png",
                                                    "signals-icon-size-0": 0,
                                                    "signals-blink-0": false,
                                                    "signals-horz-0": 0,
                                                    "signals-vert-0": 0,
                                                    "signals-hide-edit-0": false,
                                                    "signals-cond-1": "==",
                                                    "signals-val-1": true,
                                                    "signals-icon-1": "/vis/signals/lowbattery.png",
                                                    "signals-icon-size-1": 0,
                                                    "signals-blink-1": false,
                                                    "signals-horz-1": 0,
                                                    "signals-vert-1": 0,
                                                    "signals-hide-edit-1": false,
                                                    "signals-cond-2": "==",
                                                    "signals-val-2": true,
                                                    "signals-icon-2": "/vis/signals/lowbattery.png",
                                                    "signals-icon-size-2": 0,
                                                    "signals-blink-2": false,
                                                    "signals-horz-2": 0,
                                                    "signals-vert-2": 0,
                                                    "signals-hide-edit-2": false,
                                                    "lc-type": "last-change",
                                                    "lc-is-interval": true,
                                                    "lc-is-moment": false,
                                                    "lc-format": "",
                                                    "lc-position-vert": "top",
                                                    "lc-position-horz": "right",
                                                    "lc-offset-vert": 0,
                                                    "lc-offset-horz": 0,
                                                    "lc-font-size": "12px",
                                                    "lc-font-family": "",
                                                    "lc-font-style": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-border-width": "0",
                                                    "lc-border-style": "",
                                                    "lc-border-color": "",
                                                    "lc-border-radius": 10,
                                                    "lc-zindex": 0,
                                                    "listItemHeight": "5",
                                                    "listImageHeight": "35",
                                                    "listItemBackground": "#000020",
                                                    "colorCheckBox": "#1db954",
                                                    "colorListItemSelected": "#1db954",
                                                    "colorListItemText": "#bbb9b9",
                                                    "colorListItemTextSecondary": "#404040",
                                                    "colorListItemTextRight": "blue",
                                                    "colorListItemDivider": "#bbb9b9",
                                                    "oid0": "node-red.0.javascript.0.Roborock.Zone1",
                                                    "oid1": "node-red.0.javascript.0.Roborock.Zone2",
                                                    "label0": "<font face=\"Jura-DemiBold\">Wohnzimmer</font>",
                                                    "label1": "<font face=\"Jura-DemiBold\">Flur</font>",
                                                    "oid2": "node-red.0.javascript.0.Roborock.Zone3",
                                                    "label2": "<font face=\"Jura-DemiBold\">Schlafzimmer</font>",
                                                    "oid3": "node-red.0.javascript.0.Roborock.Zone4",
                                                    "label3": "<font face=\"Jura-DemiBold\">Feli</font>",
                                                    "oid4": "node-red.0.javascript.0.Roborock.Zone5",
                                                    "label4": "<font face=\"Jura-DemiBold\">Bad</font>",
                                                    "groupHeader0": "",
                                                    "groupHeader1": "",
                                                    "groupHeader2": "",
                                                    "listImage0": "/vis.0/Sauger Standard.png",
                                                    "listImage1": "/vis.0/Sauger Standard.png",
                                                    "listImage2": "/vis.0/Sauger Standard.png",
                                                    "listImage3": "/vis.0/Sauger Standard.png",
                                                    "listImage4": "/vis.0/Sauger Standard.png",
                                                    "listImageActive0": "/vis.0/Sauger Standard.png",
                                                    "listImageActive1": "/vis.0/Sauger Standard.png",
                                                    "listImageActive2": "/vis.0/Sauger Standard.png",
                                                    "listImageActive3": "/vis.0/Sauger Standard.png",
                                                    "listImageActive4": "/vis.0/Sauger Standard.png",
                                                    "subLabel0": "<font face=\"Jura-Regular\">automatisch saugen</font>",
                                                    "listItemSubTextSize": "small",
                                                    "listItemTextSize": "body2",
                                                    "subLabel1": "<font face=\"Jura-Regular\">automatisch saugen</font>",
                                                    "subLabel2": "<font face=\"Jura-Regular\">automatisch saugen</font>",
                                                    "subLabel3": "<font face=\"Jura-Regular\">automatisch saugen</font>",
                                                    "subLabel4": "<font face=\"Jura-Regular\">automatisch saugen</font>",
                                                    "rightLabel0": "",
                                                    "dividers2": false,
                                                    "distanceBetweenTextAndImage": "15",
                                                    "listItemTextRightSize": "xx-small",
                                                    "listItemSubTextRightSize": "xx-small",
                                                    "listItemHeaderTextSize": "xx-small",
                                                    "colorListItemHover": "red",
                                                    "label5": "<font face=\"Jura-DemiBold\">Automatik</font>",
                                                    "oid5": "node-red.0.javascript.0.Roborock.Zone6",
                                                    "oid6": "node-red.0.javascript.0.Roborock.Zone7",
                                                    "label6": "<font face=\"Jura-DemiBold\">Jetzt saugen</font>",
                                                    "subLabel6": "",
                                                    "subLabel5": "<font face=\"Jura-Regular\">Automatik aktivieren</font>",
                                                    "dividers5": true,
                                                    "dividers4": true,
                                                    "listImage5": "/vis.0/checked (2).png",
                                                    "listImageActive5": "/vis.0/checked (1).png",
                                                    "listImage6": "/vis.0/play-button.png",
                                                    "listImageActive6": "",
                                                    "oid7": "node-red.0.javascript.0.Roborock.Zone8",
                                                    "listImage7": "/vis.0/play-button.png",
                                                    "listImageActive7": "/vis.0/play-button.png",
                                                    "label7": "<font face=\"Jura-DemiBold\">Küche saugen</font>",
                                                    "subLabel7": "",
                                                    "listItemBackgroundActive": "#000020",
                                                    "listItemAlignment": "left"
                                                  "style": {
                                                    "left": "16px",
                                                    "top": "80px",
                                                    "width": "270px",
                                                    "height": "322px",
                                                    "z-index": "20"
                                                  "widgetSet": "materialdesign"
                                                "e00002": {
                                                  "tpl": "tplValueString",
                                                  "data": {
                                                    "oid": "",
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "html_prepend": "Sauger",
                                                    "html_append": "",
                                                    "test_html": "",
                                                    "name": "Seitentitel"
                                                  "style": {
                                                    "left": "70px",
                                                    "top": "14px",
                                                    "color": "#FFFFFF",
                                                    "font-family": "Jura-DemiBold",
                                                    "font-style": "normal",
                                                    "font-variant": "normal",
                                                    "font-weight": "bold",
                                                    "font-size": "xx-large",
                                                    "width": "",
                                                    "height": "41px",
                                                    "text-align": "left"
                                                  "widgetSet": "basic"
                                                "e00003": {
                                                  "tpl": "tplHtml",
                                                  "data": {
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "refreshInterval": "0",
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "html": "<table>\n    <tr>\n        <td>Gesamtfläche: {mihome-vacuum.0.history.total_area} qm</td>\n    </tr>\n    <tr>\n        <td>Akku: {mihome-vacuum.0.info.battery} %</td>\n    </tr>\n    <tr>\n        <td>Laufzeit: {mihome-vacuum.0.history.total_time} min.</td>\n    </tr>\n</table>\n",
                                                    "name": "Sauger Übersicht"
                                                  "style": {
                                                    "left": "335px",
                                                    "top": "85px",
                                                    "color": "#bbb9b9",
                                                    "text-align": "left",
                                                    "font-weight": "lighter",
                                                    "font-size": "medium",
                                                    "width": "319px",
                                                    "height": "86px",
                                                    "line-height": "0.9",
                                                    "z-index": "4"
                                                "e00004": {
                                                  "tpl": "tplValueListHtml8",
                                                  "data": {
                                                    "oid": "mihome-vacuum.0.info.state",
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "count": "20",
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "html_prepend": "",
                                                    "html_append": "",
                                                    "value0": "0",
                                                    "value1": "Unbekannt",
                                                    "value2": "Ruht - kein Laden",
                                                    "test_list": "12",
                                                    "style0": "color: #bbb9b9",
                                                    "value8": "Lädt",
                                                    "style8": "color: #bbb9b9",
                                                    "value3": "Ruht",
                                                    "value4": "4",
                                                    "value5": "Reinigung läuft",
                                                    "value6": "Kehrt zurück an Ladestation",
                                                    "value7": "Manueller Modus",
                                                    "value9": "9",
                                                    "style9": "color: #1DB954",
                                                    "style7": "color: #1DB954",
                                                    "style6": "color: #1DB954",
                                                    "style5": "color: #1DB954",
                                                    "style4": "color: #bbb9b9",
                                                    "style1": "color: red",
                                                    "style2": "color: #bbb9b9",
                                                    "style3": "color: #bbb9b9",
                                                    "style10": "color: #bbb9b9",
                                                    "value10": "Pausiert",
                                                    "value11": "Punktreinigung",
                                                    "value12": "Fehler",
                                                    "style11": "color: #1DB954",
                                                    "style12": "color: red",
                                                    "value17": "Reinigung - Zonen",
                                                    "style17": "color: yellow",
                                                    "name": "Sauger Status",
                                                    "value13": "13",
                                                    "value14": "14",
                                                    "value15": "15",
                                                    "value16": "16"
                                                  "style": {
                                                    "left": "335px",
                                                    "top": "176px",
                                                    "color": "#bbb9b9",
                                                    "height": "",
                                                    "width": "319px",
                                                    "z-index": "5"
                                                "e00005": {
                                                  "data": {
                                                    "oid": "mihome-vacuum.0.info.error",
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "count": "20",
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "value0": "kein Fehler",
                                                    "value1": "Fehler Lasersensor",
                                                    "test_list": "8",
                                                    "html_prepend": "",
                                                    "html_append": "",
                                                    "value11": "Sauger hängt in magnetischer Barriere",
                                                    "value2": "Fehler Kollisionssensor",
                                                    "value3": "Räder auf Hindernis, Sauger neu positionieren",
                                                    "value5": "Hauptbürste reinigen",
                                                    "value6": "Seitenbürste reinigen",
                                                    "value7": "Hauptrad blockiert",
                                                    "value8": "Sauger hängt fest",
                                                    "value9": "Staubbehälter fehlt",
                                                    "value10": "Filter reinigen",
                                                    "value12": "Akku leer",
                                                    "value13": "Ladefehler",
                                                    "value14": "Batteriefehler",
                                                    "value4": "Absturzsensoren reinigen, Sauger neu positionieren",
                                                    "value15": "Wandsensoren schmutzig, bitte reinigen",
                                                    "value16": "Sauger auf ebenem Untergrund platzieren",
                                                    "value17": "Fehler mit Seitenbürste, Neustart erforderlich",
                                                    "value18": "Fehler Saugventilator",
                                                    "value19": "Ladestation ohne Strom",
                                                    "style3": "color: orange",
                                                    "value20": "",
                                                    "style2": "color: red",
                                                    "style4": "color: orange",
                                                    "style5": "color: orange",
                                                    "style6": "color: orange",
                                                    "style7": "color: orange",
                                                    "style8": "color: orange",
                                                    "style9": "color: orange",
                                                    "style10": "color: orange",
                                                    "style11": "color: orange",
                                                    "style12": "color: orange",
                                                    "style13": "color: red",
                                                    "style14": "color: red",
                                                    "style15": "color: orange",
                                                    "style16": "color: orange",
                                                    "style17": "color: red",
                                                    "style18": "color: red",
                                                    "style19": "color: orange",
                                                    "name": "Sauger Fehler 2"
                                                  "style": {
                                                    "left": "335px",
                                                    "top": "200px",
                                                    "width": "319px",
                                                    "height": "",
                                                    "color": "red",
                                                    "z-index": "5"
                                                "e00006": {
                                                  "tpl": "tplHqButton",
                                                  "data": {
                                                    "g_fixed": true,
                                                    "g_css_font_text": false,
                                                    "g_signals": false,
                                                    "oid": "mihome-vacuum.0.control.start",
                                                    "min": "true",
                                                    "max": "true",
                                                    "iconName": "/vis.0/Sauger Standard.png",
                                                    "btIconWidth": "64",
                                                    "offsetAuto": true,
                                                    "leftOffset": "",
                                                    "topOffset": "",
                                                    "timeAsInterval": false,
                                                    "infoLeftFontSize": "12",
                                                    "infoFontRightSize": "12",
                                                    "infoLeftPaddingLeft": "0",
                                                    "infoLeftPaddingRight": "0",
                                                    "infoRightPaddingRight": "0",
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "infoRightPaddingLeft": "",
                                                    "iconOn": "/vis.0/Sauger Standard.png",
                                                    "descriptionLeftDisabled": true,
                                                    "changeEffect": "waves",
                                                    "testActive": true,
                                                    "descriptionLeft": "Start vacuum",
                                                    "styleNormal": "hq-button-no-background",
                                                    "styleActive": "hq-button-no-background",
                                                    "pushButton": true,
                                                    "name": "Starte Sauger",
                                                    "oid-battery": ""
                                                  "style": {
                                                    "left": "355px",
                                                    "top": "259px",
                                                    "width": "40px",
                                                    "height": "40px",
                                                    "z-index": "50"
                                                  "widgetSet": "hqwidgets"
                                                "e00007": {
                                                  "data": {
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "oid": "mihome-vacuum.0.control.pause",
                                                    "min": "true",
                                                    "max": "true",
                                                    "iconName": "/vis.0/Sauger Pause.png",
                                                    "offsetAuto": true,
                                                    "leftOffset": "0",
                                                    "topOffset": "0",
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "iconOn": "/vis.0/Sauger Pause.png",
                                                    "testActive": true,
                                                    "pushButton": true,
                                                    "name": "Sauger Pause",
                                                    "oid-battery": ""
                                                  "style": {
                                                    "left": "355px",
                                                    "top": "329px",
                                                    "width": "40px",
                                                    "height": "40px",
                                                    "z-index": "50"
                                                "e00008": {
                                                  "data": {
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "oid": "mihome-vacuum.0.control.home",
                                                    "min": "true",
                                                    "max": "true",
                                                    "iconName": "/vis.0/Sauger Home.png",
                                                    "offsetAuto": true,
                                                    "leftOffset": "0",
                                                    "topOffset": "0",
                                                    "infoLeftPaddingLeft": "2",
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "iconOn": "/vis.0/Sauger Home.png",
                                                    "testActive": true,
                                                    "pushButton": true,
                                                    "name": "Sauger Go home",
                                                    "oid-battery": ""
                                                  "style": {
                                                    "left": "355px",
                                                    "top": "399px",
                                                    "width": "40px",
                                                    "height": "40px",
                                                    "z-index": "50"
                                                "e00009": {
                                                  "tpl": "tplJquiBool",
                                                  "data": {
                                                    "oid": "",
                                                    "g_fixed": true,
                                                    "g_css_background": true,
                                                    "g_css_border": true,
                                                    "g_signals": false,
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "html_true": "Alles",
                                                    "html_false": "Alles",
                                                    "name": "Sauge Text"
                                                  "style": {
                                                    "left": "405px",
                                                    "top": "274px",
                                                    "z-index": "51",
                                                    "width": "45px",
                                                    "height": "",
                                                    "text-align": "center",
                                                    "font-size": "small",
                                                    "color": "#bbb9b9",
                                                    "border-width": "0px",
                                                    "border-style": "none",
                                                    "background": "transparent"
                                                  "widgetSet": "jqui"
                                                "e00010": {
                                                  "data": {
                                                    "oid": "",
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "html_true": "Pause",
                                                    "html_false": "Pause",
                                                  "style": {
                                                    "left": "405px",
                                                    "top": "344px",
                                                    "z-index": "51",
                                                    "width": "45px",
                                                    "height": "",
                                                    "color": "#bbb9b9",
                                                  "widgetSet": "jqui"
                                                "e00011": {
                                                  "data": {
                                                    "oid": "",
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "html_true": "Home",
                                                    "html_false": "Home",
                                                  "style": {
                                                    "left": "405px",
                                                    "top": "414px",
                                                    "z-index": "51",
                                                    "width": "45px",
                                                    "height": "",
                                                    "color": "#bbb9b9",
                                                  "widgetSet": "jqui"
                                                "e00012": {
                                                  "tpl": "tplTableBody",
                                                  "data": {
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "static_value": "",
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "table_oid": "mihome-vacuum.0.history.allTableJSON",
                                                    "colCount": "5",
                                                    "colName1": "Tag",
                                                    "colWidth1": "35px",
                                                    "colAttr1": "",
                                                    "colName2": "Start",
                                                    "colWidth2": "45px",
                                                    "colAttr2": "",
                                                    "colName3": "Dauer",
                                                    "colWidth3": "50px",
                                                    "colAttr3": "",
                                                    "colName4": "Fläche",
                                                    "colWidth4": "70px",
                                                    "colAttr4": "",
                                                    "new_on_top": false,
                                                    "class": "justme",
                                                    "show_scroll": false,
                                                    "max_rows": "8",
                                                    "filterkey": "",
                                                    "hide_header": false,
                                                    "colWidth5": "30px",
                                                    "colName5": "Fehler",
                                                    "name": "Sauger Lauftabelle"
                                                  "style": {
                                                    "left": "708px",
                                                    "top": "253px",
                                                    "font-weight": "normal",
                                                    "width": "281px",
                                                    "height": "",
                                                    "z-index": "5",
                                                    "color": "#bbb9b9",
                                                    "background": "",
                                                    "background-color": "",
                                                "e00013": {
                                                  "tpl": "tplJquiButtonState",
                                                  "data": {
                                                    "oid": "mihome-vacuum.0.consumable.side_brush_reset",
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "buttontext": "Reset",
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "value": "true",
                                                    "no_style": false,
                                                    "name": "Reset Seitenbürste"
                                                  "style": {
                                                    "left": "981px",
                                                    "top": "202px",
                                                    "width": "100px",
                                                    "z-index": "20",
                                                    "color": "white",
                                                    "background": "transparent",
                                                    "font-size": "x-small",
                                                    "height": "30px",
                                                  "widgetSet": "jqui"
                                                "e00014": {
                                                  "data": {
                                                    "oid": "mihome-vacuum.0.consumable.filter_reset",
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "value": "true",
                                                    "no_style": false,
                                                  "style": {
                                                    "left": "981px",
                                                    "top": "162px",
                                                    "width": "100px",
                                                    "z-index": "20",
                                                    "color": "white",
                                                    "height": "30px",
                                                  "widgetSet": "jqui"
                                                "e00015": {
                                                  "data": {
                                                    "oid": "mihome-vacuum.0.consumable.main_brush_reset",
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "value": "true",
                                                    "no_style": false,
                                                  "style": {
                                                    "left": "981px",
                                                    "top": "122px",
                                                    "width": "100px",
                                                    "z-index": "20",
                                                    "color": "white",
                                                    "height": "30px",
                                                  "widgetSet": "jqui"
                                                "e00016": {
                                                  "data": {
                                                    "oid": "mihome-vacuum.0.consumable.sensors_reset",
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "value": "true",
                                                    "no_style": false,
                                                  "style": {
                                                    "left": "981px",
                                                    "top": "82px",
                                                    "width": "100px",
                                                    "z-index": "20",
                                                    "color": "white",
                                                    "height": "30px",
                                                  "widgetSet": "jqui"
                                                "e00017": {
                                                  "tpl": "tplValueFloatBar",
                                                  "data": {
                                                    "oid": "mihome-vacuum.0.consumable.side_brush",
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "min": "0",
                                                    "max": "100",
                                                    "orientation": "horizontal",
                                                    "color": "{wert:mihome-vacuum.0.consumable.side_brush;wert <= 10 ? \"red\" :: wert <= 25 ? \"orange\" :: wert <= 50 ? \"yellow\" :: wert == 2 ? \"orange\" :: \"#248948\"}",
                                                    "reverse": false,
                                                    "class": "mdui-h-bargraph mdui-segment-10",
                                                    "border": "",
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "name": "Sauger Seitenbürste"
                                                  "style": {
                                                    "left": "855px",
                                                    "top": "208px",
                                                    "width": "100px",
                                                    "height": "15px",
                                                    "z-index": 2
                                                "e00018": {
                                                  "data": {
                                                    "oid": "mihome-vacuum.0.consumable.filter",
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "min": "0",
                                                    "max": "100",
                                                    "color": "{wert:mihome-vacuum.0.consumable.filter;wert <= 10 ? \"red\" :: wert <= 25 ? \"orange\" :: wert <= 50 ? \"yellow\" :: wert == 2 ? \"orange\" :: \"#248948\"}",
                                                    "reverse": false,
                                                    "border": "",
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "name": "Sauger Filter"
                                                  "style": {
                                                    "left": "855px",
                                                    "top": "168px",
                                                    "width": "100px",
                                                    "height": "15px",
                                                    "z-index": 2
                                                "e00019": {
                                                  "data": {
                                                    "oid": "mihome-vacuum.0.consumable.main_brush",
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "min": "0",
                                                    "max": "100",
                                                    "color": "{wert:mihome-vacuum.0.consumable.main_brush;wert <= 10 ? \"red\" :: wert <= 25 ? \"orange\" :: wert <= 50 ? \"yellow\" :: wert == 2 ? \"orange\" :: \"#248948\"}",
                                                    "reverse": false,
                                                    "border": "",
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "name": "Sauger Bürste"
                                                  "style": {
                                                    "left": "855px",
                                                    "top": "128px",
                                                    "width": "100px",
                                                    "height": "15px",
                                                    "z-index": 2
                                                "e00020": {
                                                  "data": {
                                                    "oid": "mihome-vacuum.0.consumable.sensors",
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "min": "0",
                                                    "max": "100",
                                                    "color": "{wert:mihome-vacuum.0.consumable.sensors;wert <= 10 ? \"red\" :: wert <= 25 ? \"orange\" :: wert <= 50 ? \"yellow\" :: wert == 2 ? \"orange\" :: \"#248948\"}",
                                                    "reverse": false,
                                                    "border": "",
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "name": "Sauger Sensor"
                                                  "style": {
                                                    "left": "855px",
                                                    "top": "88px",
                                                    "width": "100px",
                                                    "height": "15px",
                                                    "z-index": 2
                                                "e00021": {
                                                  "data": {
                                                    "g_fixed": false,
                                                    "g_signals": false,
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "test_html": "",
                                                    "html_append": " %",
                                                    "html_prepend": "Sensor: "
                                                  "style": {
                                                    "left": "711px",
                                                    "top": "87px",
                                                    "height": "",
                                                    "width": ""
                                                "e00022": {
                                                  "data": {
                                                    "g_fixed": false,
                                                    "g_signals": false,
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "test_html": "",
                                                    "html_prepend": "Hauptbürste "
                                                  "style": {
                                                    "left": "712px",
                                                    "top": "127px",
                                                    "height": "",
                                                    "width": ""
                                                "e00023": {
                                                  "data": {
                                                    "g_fixed": false,
                                                    "g_signals": false,
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "test_html": "",
                                                    "html_prepend": "Filter "
                                                  "style": {
                                                    "left": "712px",
                                                    "top": "167px",
                                                    "height": "",
                                                    "width": ""
                                                "e00024": {
                                                  "data": {
                                                    "g_fixed": false,
                                                    "g_signals": false,
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "test_html": "",
                                                    "html_prepend": "Seitenbürste "
                                                  "style": {
                                                    "left": "713px",
                                                    "top": "207px",
                                                    "height": "",
                                                    "width": ""
                                                "e00025": {
                                                  "tpl": "tplHtml",
                                                  "data": {
                                                    "g_fixed": true,
                                                    "g_css_shadow_padding": true,
                                                    "g_signals": false,
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "class": "myframe",
                                                    "name": "Rahmen"
                                                  "style": {
                                                    "left": "5px",
                                                    "top": "60px",
                                                    "box-shadow": "",
                                                    "z-index": "2",
                                                    "width": "1100px",
                                                    "height": "400px"
                                                "e00026": {
                                                  "tpl": "tplHtml",
                                                  "data": {
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "html": "{mihome-vacuum.0.map.map64}",
                                                    "class": "",
                                                    "name": "Sauger Bild"
                                                  "style": {
                                                    "left": "-130px",
                                                    "top": "335px",
                                                    "width": "700px",
                                                    "height": "600px",
                                                    "z-index": "0"
                                                "e00027": {
                                                  "data": {
                                                    "oid": "mihome-vacuum.0.control.fan_power",
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "min": "0",
                                                    "max": "100",
                                                    "color": "#1db954",
                                                    "reverse": false,
                                                    "class": "mdui-h-bargraph mdui-triangle mdui-segment-10",
                                                    "border": "",
                                                    "html": "mdui-h-segment-10 mdui-h-fade",
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "name": "Lautstärke",
                                                  "style": {
                                                    "left": "333px",
                                                    "top": "222px",
                                                    "width": "calc(20% - 13px)",
                                                    "height": "15px",
                                                    "z-index": "20"
                                                "e00028": {
                                                  "tpl": "tplVis-materialdesign-Select",
                                                  "data": {
                                                    "g_fixed": false,
                                                    "g_signals": false,
                                                    "inputType": "text",
                                                    "inputLayout": "solo",
                                                    "showInputCounter": false,
                                                    "clearIconShow": false,
                                                    "listDataMethod": "valueList",
                                                    "countSelectItems": "2",
                                                    "listPosition": "auto",
                                                    "showSelectedIcon": "prepend-inner",
                                                    "showValue": "true",
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "inputLayoutBackgroundColor": "#000020",
                                                    "inputLayoutBackgroundColorHover": "#000020",
                                                    "inputLayoutBackgroundColorSelected": "#000020",
                                                    "inputLayoutBorderColor": "#bbb9b9",
                                                    "inputTextFontFamily": "Jura-Regular",
                                                    "inputTextFontSize": "14",
                                                    "inputTextColor": "#bbb9b9",
                                                    "inputLabelText": "Saugstärke wählen",
                                                    "inputLabelFontFamily": "Jura-Regular",
                                                    "inputLabelFontSize": "14",
                                                    "clearIconSize": "-1",
                                                    "valueList": "38,60,77,90",
                                                    "value0": "",
                                                    "value1": "",
                                                    "value2": "",
                                                    "label0": "",
                                                    "label1": "",
                                                    "label2": "",
                                                    "inputPrefix": "",
                                                    "inputCounterColor": "",
                                                    "jsonStringObject": "",
                                                    "subLabel0": "",
                                                    "listIcon0": "",
                                                    "listIcon1": "",
                                                    "subLabel1": "",
                                                    "valueListLabels": "Silent,Standard,Turbo,Extrem",
                                                    "inputLayoutBorderColorHover": "#bbb9b9",
                                                    "inputLayoutBorderColorSelected": "#bbb9b9",
                                                    "inputLabelColor": "#bbb9b9",
                                                    "inputLabelColorSelected": "#bbb9b9",
                                                    "inputTranslateY": "0",
                                                    "inputTranslateX": "0",
                                                    "g_inputSubText": false,
                                                    "showInputMessageAlways": "true"
                                                  "style": {
                                                    "left": "488px",
                                                    "top": "265px",
                                                    "z-index": "30"
                                                "e00029": {
                                                  "tpl": "tplHtml",
                                                  "data": {
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "class": "myframe",
                                                    "name": "Rahmen"
                                                  "style": {
                                                    "left": "5px",
                                                    "top": "468px",
                                                    "box-shadow": "",
                                                    "z-index": "2",
                                                    "width": "500px",
                                                    "height": "330px"
                                                "e00030": {
                                                  "tpl": "tplHtml",
                                                  "data": {
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "name": "Überdecker"
                                                  "style": {
                                                    "left": "509px",
                                                    "top": "468px",
                                                    "z-index": "1",
                                                    "background": "",
                                                    "width": "200px",
                                                    "height": "330px",
                                                    "background-color": "#000020"
                                                "e00031": {
                                                  "tpl": "tplHtml",
                                                  "data": {
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                  "style": {
                                                    "left": "0px",
                                                    "top": "468px",
                                                    "z-index": "1",
                                                    "background": "",
                                                    "width": "5px",
                                                    "height": "330px",
                                                "e00032": {
                                                  "tpl": "tplHtml",
                                                  "data": {
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                  "style": {
                                                    "left": "0px",
                                                    "top": "330px",
                                                    "z-index": "1",
                                                    "background": "",
                                                    "width": "709px",
                                                    "height": "138px",
                                                "e00033": {
                                                  "tpl": "tplTwSimpleDate",
                                                  "data": {
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "prependZero": "true",
                                                    "signals-icon-0": "/vis.0/Wetter_Sigi/lowbattery.png",
                                                    "signals-icon-1": "/vis.0/Wetter_Sigi/lowbattery.png",
                                                    "signals-icon-2": "/vis.0/Wetter_Sigi/lowbattery.png",
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "showWeekDay": true,
                                                    "noClass": true,
                                                    "shortWeekDay": false,
                                                    "name": "Überschrift Datum",
                                                    "filterkey": "Wetter",
                                                    "views": [
                                                      "Auto",
                                                      "Cam-Stream_innen",
                                                      "Dimmer",
                                                      "Gefahrenmeldung",
                                                      "Heizung",
                                                      "homee",
                                                      "Music",
                                                      "Raeume",
                                                      "Sauger",
                                                      "Wetter_komplett"
                                                  "style": {
                                                    "left": "1070px",
                                                    "top": "12px",
                                                    "color": "#bbb9b9",
                                                    "width": "200px",
                                                    "height": "24px",
                                                    "text-align": "right",
                                                    "z-index": "20",
                                                    "text-shadow": "",
                                                  "widgetSet": "timeandweather"
                                                "e00034": {
                                                  "tpl": "tplTwSimpleClock",
                                                  "data": {
                                                    "g_fixed": true,
                                                    "g_signals": false,
                                                    "lc-format": "",
                                                    "lc-bkg-color": "",
                                                    "lc-color": "",
                                                    "lc-zindex": 0,
                                                    "name": "Überschrift Zeit",
                                                    "blink": false,
                                                    "hideSeconds": false,
                                                    "noClass": true,
                                                    "views": [
                                                      "Auto",
                                                      "Cam-Stream_innen",
                                                      "Dimmer",
                                                      "Gefahrenmeldung",
                                                      "Heizung",
                                                      "homee",
                                                      "Music",
                                                      "Raeume",
                                                      "Sauger",
                                                      "Wetter_komplett"
                                                  "style": {
                                                    "left": "1166px",
                                                    "top": "32px",
                                                    "color": "#bbb9b9",
                                                    "width": "104px",
                                                    "height": "20px",
                                                    "text-shadow": "0",
                                                    "word-spacing": "",
                                                    "letter-spacing": "",
                                                    "z-index": "1",
                                              "name": "Sauger",
                                              "filterList": [
                                                "Wetter"
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            490977
