    4. Test Adapter mihome-vacuum v2.0.x
    • Ralf_N
      Ralf_N @dirkhe last edited by
      @dirkhe
      bei clean ROOM passiert das:
      host.iobroker	2020-02-19 22:05:52.418	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
      host.iobroker	2020-02-19 22:05:52.418	info	instance system.adapter.mihome-vacuum.0 terminated with code 0 (NO_ERROR)
      host.iobroker	2020-02-19 22:05:52.418	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
      host.iobroker	2020-02-19 22:05:52.418	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      host.iobroker	2020-02-19 22:05:52.418	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      host.iobroker	2020-02-19 22:05:52.418	error	Caught by controller[0]: at client.mget (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:619:13)
      host.iobroker	2020-02-19 22:05:52.418	error	Caught by controller[0]: at states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5922:17)
      host.iobroker	2020-02-19 22:05:52.418	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/roomManager.js:120:53
      host.iobroker	2020-02-19 22:05:52.418	error	Caught by controller[0]: TypeError: Cannot read property '0' of null
      mihome-vacuum.0	2020-02-19 22:05:51.909	info	(43649) Terminated (NO_ERROR): Without reason
      mihome-vacuum.0	2020-02-19 22:05:51.908	info	(43649) terminating
      mihome-vacuum.0	2020-02-19 22:05:51.906	error	at process._tickCallback (internal/process/next_tick.js:68:7)
      mihome-vacuum.0	2020-02-19 22:05:51.906	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      mihome-vacuum.0	2020-02-19 22:05:51.906	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      mihome-vacuum.0	2020-02-19 22:05:51.906	error	at client.mget (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:619:13)
      mihome-vacuum.0	2020-02-19 22:05:51.906	error	at states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5922:17)
      mihome-vacuum.0	2020-02-19 22:05:51.906	error	at /opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/roomManager.js:120:53
      mihome-vacuum.0	2020-02-19 22:05:51.906	error	(43649) TypeError: Cannot read property '0' of null
      mihome-vacuum.0	2020-02-19 22:05:51.905	error	(43649) uncaught exception: Cannot read property '0' of null
      • Meistertr
        Meistertr Developer @Ralf_N last edited by Meistertr
        @Ralf_N so bitte nochmal von git ich hatte einen rechtschreibfehler drin wodurch die räume nicht angelegt wurden wenn du die map nciht nutzt, würde ich sie anschließend wieder deaktivieren, da sonst die Resoucen verschwendet werden
        B D Ralf_N 3 Replies Last reply Reply Quote 0
          blackeagle998 @Meistertr last edited by blackeagle998
          @Meistertr
          Yeah, funktioniert 👍 👍 👍
          Räume wurden jetzt angelegt.
          Meistertr 1 Reply Last reply Reply Quote 0
          • Meistertr
            Meistertr Developer @blackeagle998 last edited by
            @blackeagle998 gut dass ist das stichwort fürs bett 🙂
              dirkhe Developer @Meistertr last edited by
              @Meistertr sagte in Test Adapter mihome-vacuum v2.0.x:
              @Meistertr macht es Sinn, MAP.StartMapPoll(); paar Zeilen nach oben zu verschieben und nur zu aktivieren, wenn Cleaning aktiv?
              • Ralf_N
                Ralf_N @Meistertr last edited by
                @Meistertr
                hier knallt es, wenn ich auf roomClean klicker 😞
                iobroker.2020-02-19_3.log.html
                  dirkhe Developer @Ralf_N last edited by
                  @Ralf_N lösche mal den falsch angelegten Raum Manual_
                  Ralf_N 2 Replies Last reply Reply Quote 0
                  • Meistertr
                    @dirkhe die Funktion wird ja nur aufgerufen wenn map aktiviert und wenn er sich bewegt.. oder wie meinst du das? nochmehr kaseln macht ja irgendwie wenig sinn..
                    • Ralf_N
                      soderle..
                      Habe jetzt mal eigenmächtig diesen manual_ raum gelöscht
                      Zack , erscheint ein room1 ( mehr hab ich nicht, da Karte heute abend geloescht )
                      und der Adapter schmiert nicht bei roomclear ab , sondern schickt den Robbie los !
                      Ein riesiger Fortschritt !!!
                      @Meistertr gute Nachte !!!!! 🙂 🙂
                      "Die Tage" dann mehr 😉
                      Vielen lieben Danke Euch allen !!!!
                        Jap herzlichen Dank für diesen top Support!
                        Gute Nacht 😴
                          @Meistertr sorry, du hast natürlich recht, ich hatte die Status Abfrage übersehen
                          • Ralf_N
                            @dirkhe
                            sorry, das hab ich zu spät gelesen. 😞
                            Bin aber selber drauf gekommen , Sie unten 🙂 🙂 🙂
                            • Ralf_N
                              Ralf_N @dirkhe last edited by Ralf_N
                              @dirkhe said in Test Adapter mihome-vacuum v2.0.x:
                              Bin aber selber drauf gekommen , Sie unten, aehh oben ! 🙂 🙂 🙂
                                @Ralf_N alles gut. Den Fehler werde ich aber totzdem noch abfangen
                                  Guten Morgen,
                                  Testfahrt läuft bisher sehr gut, einen kleinen Fehler habe ich:
                                  2020-02-20 08:06:38.685 - warn: javascript.0 (6095) You are assigning a boolean to the state "mihome-vacuum.0.control.carpet_mode" which expects a switch. Please fix your code to use a switch or change the state type to boolean. This warning might become an error in future versions.
                                  Gesetzt wird der Wert per Befehl:
                                  setState('mihome-vacuum.0.control.carpet_mode', true);
                                    Coffeelover @base last edited by
                                    @base Gerne.
                                      "settings": {
                                        "style": {
                                          "background": "linear-gradient(205deg, #000020, #191970 4%, #000020 4%,#000020)",
                                          "font-family": "Jura-Regular",
                                          "color": "#bbb9b9",
                                          "letter-spacing": ""
                                        "theme": "eggplant",
                                        "sizex": "1280",
                                        "sizey": "800",
                                        "gridSize": "",
                                        "useBackground": true,
                                        "snapType": null
                                      "widgets": {
                                        "e00001": {
                                          "tpl": "tplVis-materialdesign-List",
                                          "data": {
                                            "g_fixed": false,
                                            "g_visibility": false,
                                            "g_css_font_text": true,
                                            "g_css_background": false,
                                            "g_css_shadow_padding": false,
                                            "g_css_border": false,
                                            "g_gestures": false,
                                            "g_signals": false,
                                            "g_last_change": false,
                                            "visibility-cond": "==",
                                            "visibility-val": 1,
                                            "visibility-groups-action": "hide",
                                            "count": "7",
                                            "listType": "switch",
                                            "listItemDividerStyle": "standard",
                                            "listLayout": "standard",
                                            "vibrateOnMobilDevices": "50",
                                            "signals-cond-0": "==",
                                            "signals-val-0": true,
                                            "signals-icon-0": "/vis/signals/lowbattery.png",
                                            "signals-icon-size-0": 0,
                                            "signals-blink-0": false,
                                            "signals-horz-0": 0,
                                            "signals-vert-0": 0,
                                            "signals-hide-edit-0": false,
                                            "signals-cond-1": "==",
                                            "signals-val-1": true,
                                            "signals-icon-1": "/vis/signals/lowbattery.png",
                                            "signals-icon-size-1": 0,
                                            "signals-blink-1": false,
                                            "signals-horz-1": 0,
                                            "signals-vert-1": 0,
                                            "signals-hide-edit-1": false,
                                            "signals-cond-2": "==",
                                            "signals-val-2": true,
                                            "signals-icon-2": "/vis/signals/lowbattery.png",
                                            "signals-icon-size-2": 0,
                                            "signals-blink-2": false,
                                            "signals-horz-2": 0,
                                            "signals-vert-2": 0,
                                            "signals-hide-edit-2": false,
                                            "lc-type": "last-change",
                                            "lc-is-interval": true,
                                            "lc-is-moment": false,
                                            "lc-format": "",
                                            "lc-position-vert": "top",
                                            "lc-position-horz": "right",
                                            "lc-offset-vert": 0,
                                            "lc-offset-horz": 0,
                                            "lc-font-size": "12px",
                                            "lc-font-family": "",
                                            "lc-font-style": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-border-width": "0",
                                            "lc-border-style": "",
                                            "lc-border-color": "",
                                            "lc-border-radius": 10,
                                            "lc-zindex": 0,
                                            "listItemHeight": "5",
                                            "listImageHeight": "35",
                                            "listItemBackground": "#000020",
                                            "colorCheckBox": "#1db954",
                                            "colorListItemSelected": "#1db954",
                                            "colorListItemText": "#bbb9b9",
                                            "colorListItemTextSecondary": "#404040",
                                            "colorListItemTextRight": "blue",
                                            "colorListItemDivider": "#bbb9b9",
                                            "oid0": "node-red.0.javascript.0.Roborock.Zone1",
                                            "oid1": "node-red.0.javascript.0.Roborock.Zone2",
                                            "label0": "<font face=\"Jura-DemiBold\">Wohnzimmer</font>",
                                            "label1": "<font face=\"Jura-DemiBold\">Flur</font>",
                                            "oid2": "node-red.0.javascript.0.Roborock.Zone3",
                                            "label2": "<font face=\"Jura-DemiBold\">Schlafzimmer</font>",
                                            "oid3": "node-red.0.javascript.0.Roborock.Zone4",
                                            "label3": "<font face=\"Jura-DemiBold\">Feli</font>",
                                            "oid4": "node-red.0.javascript.0.Roborock.Zone5",
                                            "label4": "<font face=\"Jura-DemiBold\">Bad</font>",
                                            "groupHeader0": "",
                                            "groupHeader1": "",
                                            "groupHeader2": "",
                                            "listImage0": "/vis.0/Sauger Standard.png",
                                            "listImage1": "/vis.0/Sauger Standard.png",
                                            "listImage2": "/vis.0/Sauger Standard.png",
                                            "listImage3": "/vis.0/Sauger Standard.png",
                                            "listImage4": "/vis.0/Sauger Standard.png",
                                            "listImageActive0": "/vis.0/Sauger Standard.png",
                                            "listImageActive1": "/vis.0/Sauger Standard.png",
                                            "listImageActive2": "/vis.0/Sauger Standard.png",
                                            "listImageActive3": "/vis.0/Sauger Standard.png",
                                            "listImageActive4": "/vis.0/Sauger Standard.png",
                                            "subLabel0": "<font face=\"Jura-Regular\">automatisch saugen</font>",
                                            "listItemSubTextSize": "small",
                                            "listItemTextSize": "body2",
                                            "subLabel1": "<font face=\"Jura-Regular\">automatisch saugen</font>",
                                            "subLabel2": "<font face=\"Jura-Regular\">automatisch saugen</font>",
                                            "subLabel3": "<font face=\"Jura-Regular\">automatisch saugen</font>",
                                            "subLabel4": "<font face=\"Jura-Regular\">automatisch saugen</font>",
                                            "rightLabel0": "",
                                            "dividers2": false,
                                            "distanceBetweenTextAndImage": "15",
                                            "listItemTextRightSize": "xx-small",
                                            "listItemSubTextRightSize": "xx-small",
                                            "listItemHeaderTextSize": "xx-small",
                                            "colorListItemHover": "red",
                                            "label5": "<font face=\"Jura-DemiBold\">Automatik</font>",
                                            "oid5": "node-red.0.javascript.0.Roborock.Zone6",
                                            "oid6": "node-red.0.javascript.0.Roborock.Zone7",
                                            "label6": "<font face=\"Jura-DemiBold\">Jetzt saugen</font>",
                                            "subLabel6": "",
                                            "subLabel5": "<font face=\"Jura-Regular\">Automatik aktivieren</font>",
                                            "dividers5": true,
                                            "dividers4": true,
                                            "listImage5": "/vis.0/checked (2).png",
                                            "listImageActive5": "/vis.0/checked (1).png",
                                            "listImage6": "/vis.0/play-button.png",
                                            "listImageActive6": "",
                                            "oid7": "node-red.0.javascript.0.Roborock.Zone8",
                                            "listImage7": "/vis.0/play-button.png",
                                            "listImageActive7": "/vis.0/play-button.png",
                                            "label7": "<font face=\"Jura-DemiBold\">Küche saugen</font>",
                                            "subLabel7": "",
                                            "listItemBackgroundActive": "#000020",
                                            "listItemAlignment": "left"
                                          "style": {
                                            "left": "16px",
                                            "top": "80px",
                                            "width": "270px",
                                            "height": "322px",
                                            "z-index": "20"
                                          "widgetSet": "materialdesign"
                                        "e00002": {
                                          "tpl": "tplValueString",
                                          "data": {
                                            "oid": "",
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "html_prepend": "Sauger",
                                            "html_append": "",
                                            "test_html": "",
                                            "name": "Seitentitel"
                                          "style": {
                                            "left": "70px",
                                            "top": "14px",
                                            "color": "#FFFFFF",
                                            "font-family": "Jura-DemiBold",
                                            "font-style": "normal",
                                            "font-variant": "normal",
                                            "font-weight": "bold",
                                            "font-size": "xx-large",
                                            "width": "",
                                            "height": "41px",
                                            "text-align": "left"
                                          "widgetSet": "basic"
                                        "e00003": {
                                          "tpl": "tplHtml",
                                          "data": {
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "refreshInterval": "0",
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "html": "<table>\n    <tr>\n        <td>Gesamtfläche: {mihome-vacuum.0.history.total_area} qm</td>\n    </tr>\n    <tr>\n        <td>Akku: {mihome-vacuum.0.info.battery} %</td>\n    </tr>\n    <tr>\n        <td>Laufzeit: {mihome-vacuum.0.history.total_time} min.</td>\n    </tr>\n</table>\n",
                                            "name": "Sauger Übersicht"
                                          "style": {
                                            "left": "335px",
                                            "top": "85px",
                                            "color": "#bbb9b9",
                                            "text-align": "left",
                                            "font-weight": "lighter",
                                            "font-size": "medium",
                                            "width": "319px",
                                            "height": "86px",
                                            "line-height": "0.9",
                                            "z-index": "4"
                                        "e00004": {
                                          "tpl": "tplValueListHtml8",
                                          "data": {
                                            "oid": "mihome-vacuum.0.info.state",
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "count": "20",
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "html_prepend": "",
                                            "html_append": "",
                                            "value0": "0",
                                            "value1": "Unbekannt",
                                            "value2": "Ruht - kein Laden",
                                            "test_list": "12",
                                            "style0": "color: #bbb9b9",
                                            "value8": "Lädt",
                                            "style8": "color: #bbb9b9",
                                            "value3": "Ruht",
                                            "value4": "4",
                                            "value5": "Reinigung läuft",
                                            "value6": "Kehrt zurück an Ladestation",
                                            "value7": "Manueller Modus",
                                            "value9": "9",
                                            "style9": "color: #1DB954",
                                            "style7": "color: #1DB954",
                                            "style6": "color: #1DB954",
                                            "style5": "color: #1DB954",
                                            "style4": "color: #bbb9b9",
                                            "style1": "color: red",
                                            "style2": "color: #bbb9b9",
                                            "style3": "color: #bbb9b9",
                                            "style10": "color: #bbb9b9",
                                            "value10": "Pausiert",
                                            "value11": "Punktreinigung",
                                            "value12": "Fehler",
                                            "style11": "color: #1DB954",
                                            "style12": "color: red",
                                            "value17": "Reinigung - Zonen",
                                            "style17": "color: yellow",
                                            "name": "Sauger Status",
                                            "value13": "13",
                                            "value14": "14",
                                            "value15": "15",
                                            "value16": "16"
                                          "style": {
                                            "left": "335px",
                                            "top": "176px",
                                            "color": "#bbb9b9",
                                            "height": "",
                                            "width": "319px",
                                            "z-index": "5"
                                        "e00005": {
                                          "data": {
                                            "oid": "mihome-vacuum.0.info.error",
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "count": "20",
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "value0": "kein Fehler",
                                            "value1": "Fehler Lasersensor",
                                            "test_list": "8",
                                            "html_prepend": "",
                                            "html_append": "",
                                            "value11": "Sauger hängt in magnetischer Barriere",
                                            "value2": "Fehler Kollisionssensor",
                                            "value3": "Räder auf Hindernis, Sauger neu positionieren",
                                            "value5": "Hauptbürste reinigen",
                                            "value6": "Seitenbürste reinigen",
                                            "value7": "Hauptrad blockiert",
                                            "value8": "Sauger hängt fest",
                                            "value9": "Staubbehälter fehlt",
                                            "value10": "Filter reinigen",
                                            "value12": "Akku leer",
                                            "value13": "Ladefehler",
                                            "value14": "Batteriefehler",
                                            "value4": "Absturzsensoren reinigen, Sauger neu positionieren",
                                            "value15": "Wandsensoren schmutzig, bitte reinigen",
                                            "value16": "Sauger auf ebenem Untergrund platzieren",
                                            "value17": "Fehler mit Seitenbürste, Neustart erforderlich",
                                            "value18": "Fehler Saugventilator",
                                            "value19": "Ladestation ohne Strom",
                                            "style3": "color: orange",
                                            "value20": "",
                                            "style2": "color: red",
                                            "style4": "color: orange",
                                            "style5": "color: orange",
                                            "style6": "color: orange",
                                            "style7": "color: orange",
                                            "style8": "color: orange",
                                            "style9": "color: orange",
                                            "style10": "color: orange",
                                            "style11": "color: orange",
                                            "style12": "color: orange",
                                            "style13": "color: red",
                                            "style14": "color: red",
                                            "style15": "color: orange",
                                            "style16": "color: orange",
                                            "style17": "color: red",
                                            "style18": "color: red",
                                            "style19": "color: orange",
                                            "name": "Sauger Fehler 2"
                                          "style": {
                                            "left": "335px",
                                            "top": "200px",
                                            "width": "319px",
                                            "height": "",
                                            "color": "red",
                                            "z-index": "5"
                                        "e00006": {
                                          "tpl": "tplHqButton",
                                          "data": {
                                            "g_fixed": true,
                                            "g_css_font_text": false,
                                            "g_signals": false,
                                            "oid": "mihome-vacuum.0.control.start",
                                            "min": "true",
                                            "max": "true",
                                            "iconName": "/vis.0/Sauger Standard.png",
                                            "btIconWidth": "64",
                                            "offsetAuto": true,
                                            "leftOffset": "",
                                            "topOffset": "",
                                            "timeAsInterval": false,
                                            "infoLeftFontSize": "12",
                                            "infoFontRightSize": "12",
                                            "infoLeftPaddingLeft": "0",
                                            "infoLeftPaddingRight": "0",
                                            "infoRightPaddingRight": "0",
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "infoRightPaddingLeft": "",
                                            "iconOn": "/vis.0/Sauger Standard.png",
                                            "descriptionLeftDisabled": true,
                                            "changeEffect": "waves",
                                            "testActive": true,
                                            "descriptionLeft": "Start vacuum",
                                            "styleNormal": "hq-button-no-background",
                                            "styleActive": "hq-button-no-background",
                                            "pushButton": true,
                                            "name": "Starte Sauger",
                                            "oid-battery": ""
                                          "style": {
                                            "left": "355px",
                                            "top": "259px",
                                            "width": "40px",
                                            "height": "40px",
                                            "z-index": "50"
                                          "widgetSet": "hqwidgets"
                                        "e00007": {
                                          "data": {
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "oid": "mihome-vacuum.0.control.pause",
                                            "min": "true",
                                            "max": "true",
                                            "iconName": "/vis.0/Sauger Pause.png",
                                            "offsetAuto": true,
                                            "leftOffset": "0",
                                            "topOffset": "0",
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "iconOn": "/vis.0/Sauger Pause.png",
                                            "testActive": true,
                                            "pushButton": true,
                                            "name": "Sauger Pause",
                                            "oid-battery": ""
                                          "style": {
                                            "left": "355px",
                                            "top": "329px",
                                            "width": "40px",
                                            "height": "40px",
                                            "z-index": "50"
                                        "e00008": {
                                          "data": {
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "oid": "mihome-vacuum.0.control.home",
                                            "min": "true",
                                            "max": "true",
                                            "iconName": "/vis.0/Sauger Home.png",
                                            "offsetAuto": true,
                                            "leftOffset": "0",
                                            "topOffset": "0",
                                            "infoLeftPaddingLeft": "2",
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "iconOn": "/vis.0/Sauger Home.png",
                                            "testActive": true,
                                            "pushButton": true,
                                            "name": "Sauger Go home",
                                            "oid-battery": ""
                                          "style": {
                                            "left": "355px",
                                            "top": "399px",
                                            "width": "40px",
                                            "height": "40px",
                                            "z-index": "50"
                                        "e00009": {
                                          "tpl": "tplJquiBool",
                                          "data": {
                                            "oid": "",
                                            "g_fixed": true,
                                            "g_css_background": true,
                                            "g_css_border": true,
                                            "g_signals": false,
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "html_true": "Alles",
                                            "html_false": "Alles",
                                            "name": "Sauge Text"
                                          "style": {
                                            "left": "405px",
                                            "top": "274px",
                                            "z-index": "51",
                                            "width": "45px",
                                            "height": "",
                                            "text-align": "center",
                                            "font-size": "small",
                                            "color": "#bbb9b9",
                                            "border-width": "0px",
                                            "border-style": "none",
                                            "background": "transparent"
                                          "widgetSet": "jqui"
                                        "e00010": {
                                          "data": {
                                            "oid": "",
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "html_true": "Pause",
                                            "html_false": "Pause",
                                          "style": {
                                            "left": "405px",
                                            "top": "344px",
                                            "z-index": "51",
                                            "width": "45px",
                                            "height": "",
                                            "color": "#bbb9b9",
                                          "widgetSet": "jqui"
                                        "e00011": {
                                          "data": {
                                            "oid": "",
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "html_true": "Home",
                                            "html_false": "Home",
                                          "style": {
                                            "left": "405px",
                                            "top": "414px",
                                            "z-index": "51",
                                            "width": "45px",
                                            "height": "",
                                            "color": "#bbb9b9",
                                          "widgetSet": "jqui"
                                        "e00012": {
                                          "tpl": "tplTableBody",
                                          "data": {
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "static_value": "",
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "table_oid": "mihome-vacuum.0.history.allTableJSON",
                                            "colCount": "5",
                                            "colName1": "Tag",
                                            "colWidth1": "35px",
                                            "colAttr1": "",
                                            "colName2": "Start",
                                            "colWidth2": "45px",
                                            "colAttr2": "",
                                            "colName3": "Dauer",
                                            "colWidth3": "50px",
                                            "colAttr3": "",
                                            "colName4": "Fläche",
                                            "colWidth4": "70px",
                                            "colAttr4": "",
                                            "new_on_top": false,
                                            "class": "justme",
                                            "show_scroll": false,
                                            "max_rows": "8",
                                            "filterkey": "",
                                            "hide_header": false,
                                            "colWidth5": "30px",
                                            "colName5": "Fehler",
                                            "name": "Sauger Lauftabelle"
                                          "style": {
                                            "left": "708px",
                                            "top": "253px",
                                            "font-weight": "normal",
                                            "width": "281px",
                                            "height": "",
                                            "z-index": "5",
                                            "color": "#bbb9b9",
                                            "background": "",
                                            "background-color": "",
                                        "e00013": {
                                          "tpl": "tplJquiButtonState",
                                          "data": {
                                            "oid": "mihome-vacuum.0.consumable.side_brush_reset",
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "buttontext": "Reset",
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "value": "true",
                                            "no_style": false,
                                            "name": "Reset Seitenbürste"
                                          "style": {
                                            "left": "981px",
                                            "top": "202px",
                                            "width": "100px",
                                            "z-index": "20",
                                            "color": "white",
                                            "background": "transparent",
                                            "font-size": "x-small",
                                            "height": "30px",
                                          "widgetSet": "jqui"
                                        "e00014": {
                                          "data": {
                                            "oid": "mihome-vacuum.0.consumable.filter_reset",
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "value": "true",
                                            "no_style": false,
                                          "style": {
                                            "left": "981px",
                                            "top": "162px",
                                            "width": "100px",
                                            "z-index": "20",
                                            "color": "white",
                                            "height": "30px",
                                          "widgetSet": "jqui"
                                        "e00015": {
                                          "data": {
                                            "oid": "mihome-vacuum.0.consumable.main_brush_reset",
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "value": "true",
                                            "no_style": false,
                                          "style": {
                                            "left": "981px",
                                            "top": "122px",
                                            "width": "100px",
                                            "z-index": "20",
                                            "color": "white",
                                            "height": "30px",
                                          "widgetSet": "jqui"
                                        "e00016": {
                                          "data": {
                                            "oid": "mihome-vacuum.0.consumable.sensors_reset",
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "value": "true",
                                            "no_style": false,
                                          "style": {
                                            "left": "981px",
                                            "top": "82px",
                                            "width": "100px",
                                            "z-index": "20",
                                            "color": "white",
                                            "height": "30px",
                                          "widgetSet": "jqui"
                                        "e00017": {
                                          "tpl": "tplValueFloatBar",
                                          "data": {
                                            "oid": "mihome-vacuum.0.consumable.side_brush",
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "min": "0",
                                            "max": "100",
                                            "orientation": "horizontal",
                                            "color": "{wert:mihome-vacuum.0.consumable.side_brush;wert <= 10 ? \"red\" :: wert <= 25 ? \"orange\" :: wert <= 50 ? \"yellow\" :: wert == 2 ? \"orange\" :: \"#248948\"}",
                                            "reverse": false,
                                            "class": "mdui-h-bargraph mdui-segment-10",
                                            "border": "",
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "name": "Sauger Seitenbürste"
                                          "style": {
                                            "left": "855px",
                                            "top": "208px",
                                            "width": "100px",
                                            "height": "15px",
                                            "z-index": 2
                                        "e00018": {
                                          "data": {
                                            "oid": "mihome-vacuum.0.consumable.filter",
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "min": "0",
                                            "max": "100",
                                            "color": "{wert:mihome-vacuum.0.consumable.filter;wert <= 10 ? \"red\" :: wert <= 25 ? \"orange\" :: wert <= 50 ? \"yellow\" :: wert == 2 ? \"orange\" :: \"#248948\"}",
                                            "reverse": false,
                                            "border": "",
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "name": "Sauger Filter"
                                          "style": {
                                            "left": "855px",
                                            "top": "168px",
                                            "width": "100px",
                                            "height": "15px",
                                            "z-index": 2
                                        "e00019": {
                                          "data": {
                                            "oid": "mihome-vacuum.0.consumable.main_brush",
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "min": "0",
                                            "max": "100",
                                            "color": "{wert:mihome-vacuum.0.consumable.main_brush;wert <= 10 ? \"red\" :: wert <= 25 ? \"orange\" :: wert <= 50 ? \"yellow\" :: wert == 2 ? \"orange\" :: \"#248948\"}",
                                            "reverse": false,
                                            "border": "",
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "name": "Sauger Bürste"
                                          "style": {
                                            "left": "855px",
                                            "top": "128px",
                                            "width": "100px",
                                            "height": "15px",
                                            "z-index": 2
                                        "e00020": {
                                          "data": {
                                            "oid": "mihome-vacuum.0.consumable.sensors",
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "min": "0",
                                            "max": "100",
                                            "color": "{wert:mihome-vacuum.0.consumable.sensors;wert <= 10 ? \"red\" :: wert <= 25 ? \"orange\" :: wert <= 50 ? \"yellow\" :: wert == 2 ? \"orange\" :: \"#248948\"}",
                                            "reverse": false,
                                            "border": "",
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "name": "Sauger Sensor"
                                          "style": {
                                            "left": "855px",
                                            "top": "88px",
                                            "width": "100px",
                                            "height": "15px",
                                            "z-index": 2
                                        "e00021": {
                                          "data": {
                                            "g_fixed": false,
                                            "g_signals": false,
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "test_html": "",
                                            "html_append": " %",
                                            "html_prepend": "Sensor: "
                                          "style": {
                                            "left": "711px",
                                            "top": "87px",
                                            "height": "",
                                            "width": ""
                                        "e00022": {
                                          "data": {
                                            "g_fixed": false,
                                            "g_signals": false,
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "test_html": "",
                                            "html_prepend": "Hauptbürste "
                                          "style": {
                                            "left": "712px",
                                            "top": "127px",
                                            "height": "",
                                            "width": ""
                                        "e00023": {
                                          "data": {
                                            "g_fixed": false,
                                            "g_signals": false,
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "test_html": "",
                                            "html_prepend": "Filter "
                                          "style": {
                                            "left": "712px",
                                            "top": "167px",
                                            "height": "",
                                            "width": ""
                                        "e00024": {
                                          "data": {
                                            "g_fixed": false,
                                            "g_signals": false,
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "test_html": "",
                                            "html_prepend": "Seitenbürste "
                                          "style": {
                                            "left": "713px",
                                            "top": "207px",
                                            "height": "",
                                            "width": ""
                                        "e00025": {
                                          "tpl": "tplHtml",
                                          "data": {
                                            "g_fixed": true,
                                            "g_css_shadow_padding": true,
                                            "g_signals": false,
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "class": "myframe",
                                            "name": "Rahmen"
                                          "style": {
                                            "left": "5px",
                                            "top": "60px",
                                            "box-shadow": "",
                                            "z-index": "2",
                                            "width": "1100px",
                                            "height": "400px"
                                        "e00026": {
                                          "tpl": "tplHtml",
                                          "data": {
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "html": "{mihome-vacuum.0.map.map64}",
                                            "class": "",
                                            "name": "Sauger Bild"
                                          "style": {
                                            "left": "-130px",
                                            "top": "335px",
                                            "width": "700px",
                                            "height": "600px",
                                            "z-index": "0"
                                        "e00027": {
                                          "data": {
                                            "oid": "mihome-vacuum.0.control.fan_power",
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "min": "0",
                                            "max": "100",
                                            "color": "#1db954",
                                            "reverse": false,
                                            "class": "mdui-h-bargraph mdui-triangle mdui-segment-10",
                                            "border": "",
                                            "html": "mdui-h-segment-10 mdui-h-fade",
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "name": "Lautstärke",
                                          "style": {
                                            "left": "333px",
                                            "top": "222px",
                                            "width": "calc(20% - 13px)",
                                            "height": "15px",
                                            "z-index": "20"
                                        "e00028": {
                                          "tpl": "tplVis-materialdesign-Select",
                                          "data": {
                                            "g_fixed": false,
                                            "g_signals": false,
                                            "inputType": "text",
                                            "inputLayout": "solo",
                                            "showInputCounter": false,
                                            "clearIconShow": false,
                                            "listDataMethod": "valueList",
                                            "countSelectItems": "2",
                                            "listPosition": "auto",
                                            "showSelectedIcon": "prepend-inner",
                                            "showValue": "true",
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "inputLayoutBackgroundColor": "#000020",
                                            "inputLayoutBackgroundColorHover": "#000020",
                                            "inputLayoutBackgroundColorSelected": "#000020",
                                            "inputLayoutBorderColor": "#bbb9b9",
                                            "inputTextFontFamily": "Jura-Regular",
                                            "inputTextFontSize": "14",
                                            "inputTextColor": "#bbb9b9",
                                            "inputLabelText": "Saugstärke wählen",
                                            "inputLabelFontFamily": "Jura-Regular",
                                            "inputLabelFontSize": "14",
                                            "clearIconSize": "-1",
                                            "valueList": "38,60,77,90",
                                            "value0": "",
                                            "value1": "",
                                            "value2": "",
                                            "label0": "",
                                            "label1": "",
                                            "label2": "",
                                            "inputPrefix": "",
                                            "inputCounterColor": "",
                                            "jsonStringObject": "",
                                            "subLabel0": "",
                                            "listIcon0": "",
                                            "listIcon1": "",
                                            "subLabel1": "",
                                            "valueListLabels": "Silent,Standard,Turbo,Extrem",
                                            "inputLayoutBorderColorHover": "#bbb9b9",
                                            "inputLayoutBorderColorSelected": "#bbb9b9",
                                            "inputLabelColor": "#bbb9b9",
                                            "inputLabelColorSelected": "#bbb9b9",
                                            "inputTranslateY": "0",
                                            "inputTranslateX": "0",
                                            "g_inputSubText": false,
                                            "showInputMessageAlways": "true"
                                          "style": {
                                            "left": "488px",
                                            "top": "265px",
                                            "z-index": "30"
                                        "e00029": {
                                          "tpl": "tplHtml",
                                          "data": {
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "class": "myframe",
                                            "name": "Rahmen"
                                          "style": {
                                            "left": "5px",
                                            "top": "468px",
                                            "box-shadow": "",
                                            "z-index": "2",
                                            "width": "500px",
                                            "height": "330px"
                                        "e00030": {
                                          "tpl": "tplHtml",
                                          "data": {
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "name": "Überdecker"
                                          "style": {
                                            "left": "509px",
                                            "top": "468px",
                                            "z-index": "1",
                                            "background": "",
                                            "width": "200px",
                                            "height": "330px",
                                            "background-color": "#000020"
                                        "e00031": {
                                          "tpl": "tplHtml",
                                          "data": {
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                          "style": {
                                            "left": "0px",
                                            "top": "468px",
                                            "z-index": "1",
                                            "background": "",
                                            "width": "5px",
                                            "height": "330px",
                                        "e00032": {
                                          "tpl": "tplHtml",
                                          "data": {
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                          "style": {
                                            "left": "0px",
                                            "top": "330px",
                                            "z-index": "1",
                                            "background": "",
                                            "width": "709px",
                                            "height": "138px",
                                        "e00033": {
                                          "tpl": "tplTwSimpleDate",
                                          "data": {
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "prependZero": "true",
                                            "signals-icon-0": "/vis.0/Wetter_Sigi/lowbattery.png",
                                            "signals-icon-1": "/vis.0/Wetter_Sigi/lowbattery.png",
                                            "signals-icon-2": "/vis.0/Wetter_Sigi/lowbattery.png",
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "showWeekDay": true,
                                            "noClass": true,
                                            "shortWeekDay": false,
                                            "name": "Überschrift Datum",
                                            "filterkey": "Wetter",
                                            "views": [
                                              "Auto",
                                              "Cam-Stream_innen",
                                              "Dimmer",
                                              "Gefahrenmeldung",
                                              "Heizung",
                                              "homee",
                                              "Music",
                                              "Raeume",
                                              "Sauger",
                                              "Wetter_komplett"
                                          "style": {
                                            "left": "1070px",
                                            "top": "12px",
                                            "color": "#bbb9b9",
                                            "width": "200px",
                                            "height": "24px",
                                            "text-align": "right",
                                            "z-index": "20",
                                            "text-shadow": "",
                                          "widgetSet": "timeandweather"
                                        "e00034": {
                                          "tpl": "tplTwSimpleClock",
                                          "data": {
                                            "g_fixed": true,
                                            "g_signals": false,
                                            "lc-format": "",
                                            "lc-bkg-color": "",
                                            "lc-color": "",
                                            "lc-zindex": 0,
                                            "name": "Überschrift Zeit",
                                            "blink": false,
                                            "hideSeconds": false,
                                            "noClass": true,
                                            "views": [
                                              "Auto",
                                              "Cam-Stream_innen",
                                              "Dimmer",
                                              "Gefahrenmeldung",
                                              "Heizung",
                                              "homee",
                                              "Music",
                                              "Raeume",
                                              "Sauger",
                                              "Wetter_komplett"
                                          "style": {
                                            "left": "1166px",
                                            "top": "32px",
                                            "color": "#bbb9b9",
                                            "width": "104px",
                                            "height": "20px",
                                            "text-shadow": "0",
                                            "word-spacing": "",
                                            "letter-spacing": "",
                                            "z-index": "1",
                                      "name": "Sauger",
                                      "filterList": [
                                        "Wetter"
                                    • Dutchman
                                      @Meistertr Yes raeume gehen jetzt mit meinem S55 GEIL !!!!
                                      • Diginix
                                        Diginix @blackeagle998 last edited by
                                        @blackeagle998 sagte in Test Adapter mihome-vacuum v2.0.x:
                                        Guten Morgen,
                                        @Meistertr & @dirkhe
                                        Das ist ein Fehler im Datenpunkt "carpet_mode". Dieser ist vom type=switch. Switch ist aber eine Rolle und der type muss boolean sein.
                                        Also so gehört es in der main.js ab Zeile 279:
                                        "type": "boolean",
                                        "role": "switch"
                                          dirkhe Developer last edited by
                                          is gefixt und im git
                                          Patchwork 3001 Diginix 2 Replies Last reply Reply Quote 0
                                            dirkhe Developer last edited by dirkhe
                                            @Meistertr Beim JSON.parse wird ein Fehler geworfen, wenn der String leer ist. Das bekommt man bespielsweise bei miIo_info zurück, wenn der robo nicht mit dem inet verbunden ist. Ich habe daher das mal wieder zurückgebaut und habe den loglevel da auf silly gesetzt
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            490877
