    4. Test Adapter mihome-vacuum v2.0.x
    • Ralf_N
      Ralf_N @dirkhe last edited by Ralf_N
      @dirkhe said in Test Adapter mihome-vacuum v2.0.x:
      @Ralf_N lösche mal den falsch angelegten Raum Manual_
      sorry, das hab ich zu spät gelesen. 😞
      Bin aber selber drauf gekommen , Sie unten, aehh oben ! 🙂 🙂 🙂
        dirkhe Developer @Ralf_N last edited by
        @Ralf_N alles gut. Den Fehler werde ich aber totzdem noch abfangen
          blackeagle998 last edited by
          Guten Morgen,
          Testfahrt läuft bisher sehr gut, einen kleinen Fehler habe ich:
          2020-02-20 08:06:38.685 - warn: javascript.0 (6095) You are assigning a boolean to the state "mihome-vacuum.0.control.carpet_mode" which expects a switch. Please fix your code to use a switch or change the state type to boolean. This warning might become an error in future versions.
          Gesetzt wird der Wert per Befehl:
          setState('mihome-vacuum.0.control.carpet_mode', true);
            Coffeelover @base last edited by
            @base Gerne.
              "settings": {
                "style": {
                  "background": "linear-gradient(205deg, #000020, #191970 4%, #000020 4%,#000020)",
                  "font-family": "Jura-Regular",
                  "color": "#bbb9b9",
                  "letter-spacing": ""
                "theme": "eggplant",
                "sizex": "1280",
                "sizey": "800",
                "gridSize": "",
                "useBackground": true,
                "snapType": null
              "widgets": {
                "e00001": {
                  "tpl": "tplVis-materialdesign-List",
                  "data": {
                    "g_fixed": false,
                    "g_visibility": false,
                    "g_css_font_text": true,
                    "g_css_background": false,
                    "g_css_shadow_padding": false,
                    "g_css_border": false,
                    "g_gestures": false,
                    "g_signals": false,
                    "g_last_change": false,
                    "visibility-cond": "==",
                    "visibility-val": 1,
                    "visibility-groups-action": "hide",
                    "count": "7",
                    "listType": "switch",
                    "listItemDividerStyle": "standard",
                    "listLayout": "standard",
                    "vibrateOnMobilDevices": "50",
                    "signals-cond-0": "==",
                    "signals-val-0": true,
                    "signals-icon-0": "/vis/signals/lowbattery.png",
                    "signals-icon-size-0": 0,
                    "signals-blink-0": false,
                    "signals-horz-0": 0,
                    "signals-vert-0": 0,
                    "signals-hide-edit-0": false,
                    "signals-cond-1": "==",
                    "signals-val-1": true,
                    "signals-icon-1": "/vis/signals/lowbattery.png",
                    "signals-icon-size-1": 0,
                    "signals-blink-1": false,
                    "signals-horz-1": 0,
                    "signals-vert-1": 0,
                    "signals-hide-edit-1": false,
                    "signals-cond-2": "==",
                    "signals-val-2": true,
                    "signals-icon-2": "/vis/signals/lowbattery.png",
                    "signals-icon-size-2": 0,
                    "signals-blink-2": false,
                    "signals-horz-2": 0,
                    "signals-vert-2": 0,
                    "signals-hide-edit-2": false,
                    "lc-type": "last-change",
                    "lc-is-interval": true,
                    "lc-is-moment": false,
                    "lc-format": "",
                    "lc-position-vert": "top",
                    "lc-position-horz": "right",
                    "lc-offset-vert": 0,
                    "lc-offset-horz": 0,
                    "lc-font-size": "12px",
                    "lc-font-family": "",
                    "lc-font-style": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-border-width": "0",
                    "lc-border-style": "",
                    "lc-border-color": "",
                    "lc-border-radius": 10,
                    "lc-zindex": 0,
                    "listItemHeight": "5",
                    "listImageHeight": "35",
                    "listItemBackground": "#000020",
                    "colorCheckBox": "#1db954",
                    "colorListItemSelected": "#1db954",
                    "colorListItemText": "#bbb9b9",
                    "colorListItemTextSecondary": "#404040",
                    "colorListItemTextRight": "blue",
                    "colorListItemDivider": "#bbb9b9",
                    "oid0": "node-red.0.javascript.0.Roborock.Zone1",
                    "oid1": "node-red.0.javascript.0.Roborock.Zone2",
                    "label0": "<font face=\"Jura-DemiBold\">Wohnzimmer</font>",
                    "label1": "<font face=\"Jura-DemiBold\">Flur</font>",
                    "oid2": "node-red.0.javascript.0.Roborock.Zone3",
                    "label2": "<font face=\"Jura-DemiBold\">Schlafzimmer</font>",
                    "oid3": "node-red.0.javascript.0.Roborock.Zone4",
                    "label3": "<font face=\"Jura-DemiBold\">Feli</font>",
                    "oid4": "node-red.0.javascript.0.Roborock.Zone5",
                    "label4": "<font face=\"Jura-DemiBold\">Bad</font>",
                    "groupHeader0": "",
                    "groupHeader1": "",
                    "groupHeader2": "",
                    "listImage0": "/vis.0/Sauger Standard.png",
                    "listImage1": "/vis.0/Sauger Standard.png",
                    "listImage2": "/vis.0/Sauger Standard.png",
                    "listImage3": "/vis.0/Sauger Standard.png",
                    "listImage4": "/vis.0/Sauger Standard.png",
                    "listImageActive0": "/vis.0/Sauger Standard.png",
                    "listImageActive1": "/vis.0/Sauger Standard.png",
                    "listImageActive2": "/vis.0/Sauger Standard.png",
                    "listImageActive3": "/vis.0/Sauger Standard.png",
                    "listImageActive4": "/vis.0/Sauger Standard.png",
                    "subLabel0": "<font face=\"Jura-Regular\">automatisch saugen</font>",
                    "listItemSubTextSize": "small",
                    "listItemTextSize": "body2",
                    "subLabel1": "<font face=\"Jura-Regular\">automatisch saugen</font>",
                    "subLabel2": "<font face=\"Jura-Regular\">automatisch saugen</font>",
                    "subLabel3": "<font face=\"Jura-Regular\">automatisch saugen</font>",
                    "subLabel4": "<font face=\"Jura-Regular\">automatisch saugen</font>",
                    "rightLabel0": "",
                    "dividers2": false,
                    "distanceBetweenTextAndImage": "15",
                    "listItemTextRightSize": "xx-small",
                    "listItemSubTextRightSize": "xx-small",
                    "listItemHeaderTextSize": "xx-small",
                    "colorListItemHover": "red",
                    "label5": "<font face=\"Jura-DemiBold\">Automatik</font>",
                    "oid5": "node-red.0.javascript.0.Roborock.Zone6",
                    "oid6": "node-red.0.javascript.0.Roborock.Zone7",
                    "label6": "<font face=\"Jura-DemiBold\">Jetzt saugen</font>",
                    "subLabel6": "",
                    "subLabel5": "<font face=\"Jura-Regular\">Automatik aktivieren</font>",
                    "dividers5": true,
                    "dividers4": true,
                    "listImage5": "/vis.0/checked (2).png",
                    "listImageActive5": "/vis.0/checked (1).png",
                    "listImage6": "/vis.0/play-button.png",
                    "listImageActive6": "",
                    "oid7": "node-red.0.javascript.0.Roborock.Zone8",
                    "listImage7": "/vis.0/play-button.png",
                    "listImageActive7": "/vis.0/play-button.png",
                    "label7": "<font face=\"Jura-DemiBold\">Küche saugen</font>",
                    "subLabel7": "",
                    "listItemBackgroundActive": "#000020",
                    "listItemAlignment": "left"
                  "style": {
                    "left": "16px",
                    "top": "80px",
                    "width": "270px",
                    "height": "322px",
                    "z-index": "20"
                  "widgetSet": "materialdesign"
                "e00002": {
                  "tpl": "tplValueString",
                  "data": {
                    "oid": "",
                    "g_fixed": true,
                    "g_signals": false,
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "html_prepend": "Sauger",
                    "html_append": "",
                    "test_html": "",
                    "name": "Seitentitel"
                  "style": {
                    "left": "70px",
                    "top": "14px",
                    "color": "#FFFFFF",
                    "font-family": "Jura-DemiBold",
                    "font-style": "normal",
                    "font-variant": "normal",
                    "font-weight": "bold",
                    "font-size": "xx-large",
                    "width": "",
                    "height": "41px",
                    "text-align": "left"
                  "widgetSet": "basic"
                "e00003": {
                  "tpl": "tplHtml",
                  "data": {
                    "g_fixed": true,
                    "g_signals": false,
                    "refreshInterval": "0",
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "html": "<table>\n    <tr>\n        <td>Gesamtfläche: {mihome-vacuum.0.history.total_area} qm</td>\n    </tr>\n    <tr>\n        <td>Akku: {mihome-vacuum.0.info.battery} %</td>\n    </tr>\n    <tr>\n        <td>Laufzeit: {mihome-vacuum.0.history.total_time} min.</td>\n    </tr>\n</table>\n",
                    "name": "Sauger Übersicht"
                  "style": {
                    "left": "335px",
                    "top": "85px",
                    "color": "#bbb9b9",
                    "text-align": "left",
                    "font-weight": "lighter",
                    "font-size": "medium",
                    "width": "319px",
                    "height": "86px",
                    "line-height": "0.9",
                    "z-index": "4"
                "e00004": {
                  "tpl": "tplValueListHtml8",
                  "data": {
                    "oid": "mihome-vacuum.0.info.state",
                    "g_fixed": true,
                    "g_signals": false,
                    "count": "20",
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "html_prepend": "",
                    "html_append": "",
                    "value0": "0",
                    "value1": "Unbekannt",
                    "value2": "Ruht - kein Laden",
                    "test_list": "12",
                    "style0": "color: #bbb9b9",
                    "value8": "Lädt",
                    "style8": "color: #bbb9b9",
                    "value3": "Ruht",
                    "value4": "4",
                    "value5": "Reinigung läuft",
                    "value6": "Kehrt zurück an Ladestation",
                    "value7": "Manueller Modus",
                    "value9": "9",
                    "style9": "color: #1DB954",
                    "style7": "color: #1DB954",
                    "style6": "color: #1DB954",
                    "style5": "color: #1DB954",
                    "style4": "color: #bbb9b9",
                    "style1": "color: red",
                    "style2": "color: #bbb9b9",
                    "style3": "color: #bbb9b9",
                    "style10": "color: #bbb9b9",
                    "value10": "Pausiert",
                    "value11": "Punktreinigung",
                    "value12": "Fehler",
                    "style11": "color: #1DB954",
                    "style12": "color: red",
                    "value17": "Reinigung - Zonen",
                    "style17": "color: yellow",
                    "name": "Sauger Status",
                    "value13": "13",
                    "value14": "14",
                    "value15": "15",
                    "value16": "16"
                  "style": {
                    "left": "335px",
                    "top": "176px",
                    "color": "#bbb9b9",
                    "height": "",
                    "width": "319px",
                    "z-index": "5"
                "e00005": {
                  "data": {
                    "oid": "mihome-vacuum.0.info.error",
                    "g_fixed": true,
                    "g_signals": false,
                    "count": "20",
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "value0": "kein Fehler",
                    "value1": "Fehler Lasersensor",
                    "test_list": "8",
                    "html_prepend": "",
                    "html_append": "",
                    "value11": "Sauger hängt in magnetischer Barriere",
                    "value2": "Fehler Kollisionssensor",
                    "value3": "Räder auf Hindernis, Sauger neu positionieren",
                    "value5": "Hauptbürste reinigen",
                    "value6": "Seitenbürste reinigen",
                    "value7": "Hauptrad blockiert",
                    "value8": "Sauger hängt fest",
                    "value9": "Staubbehälter fehlt",
                    "value10": "Filter reinigen",
                    "value12": "Akku leer",
                    "value13": "Ladefehler",
                    "value14": "Batteriefehler",
                    "value4": "Absturzsensoren reinigen, Sauger neu positionieren",
                    "value15": "Wandsensoren schmutzig, bitte reinigen",
                    "value16": "Sauger auf ebenem Untergrund platzieren",
                    "value17": "Fehler mit Seitenbürste, Neustart erforderlich",
                    "value18": "Fehler Saugventilator",
                    "value19": "Ladestation ohne Strom",
                    "style3": "color: orange",
                    "value20": "",
                    "style2": "color: red",
                    "style4": "color: orange",
                    "style5": "color: orange",
                    "style6": "color: orange",
                    "style7": "color: orange",
                    "style8": "color: orange",
                    "style9": "color: orange",
                    "style10": "color: orange",
                    "style11": "color: orange",
                    "style12": "color: orange",
                    "style13": "color: red",
                    "style14": "color: red",
                    "style15": "color: orange",
                    "style16": "color: orange",
                    "style17": "color: red",
                    "style18": "color: red",
                    "style19": "color: orange",
                    "name": "Sauger Fehler 2"
                  "style": {
                    "left": "335px",
                    "top": "200px",
                    "width": "319px",
                    "height": "",
                    "color": "red",
                    "z-index": "5"
                "e00006": {
                  "tpl": "tplHqButton",
                  "data": {
                    "g_fixed": true,
                    "g_css_font_text": false,
                    "g_signals": false,
                    "oid": "mihome-vacuum.0.control.start",
                    "min": "true",
                    "max": "true",
                    "iconName": "/vis.0/Sauger Standard.png",
                    "btIconWidth": "64",
                    "offsetAuto": true,
                    "leftOffset": "",
                    "topOffset": "",
                    "timeAsInterval": false,
                    "infoLeftFontSize": "12",
                    "infoFontRightSize": "12",
                    "infoLeftPaddingLeft": "0",
                    "infoLeftPaddingRight": "0",
                    "infoRightPaddingRight": "0",
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "infoRightPaddingLeft": "",
                    "iconOn": "/vis.0/Sauger Standard.png",
                    "descriptionLeftDisabled": true,
                    "changeEffect": "waves",
                    "testActive": true,
                    "descriptionLeft": "Start vacuum",
                    "styleNormal": "hq-button-no-background",
                    "styleActive": "hq-button-no-background",
                    "pushButton": true,
                    "name": "Starte Sauger",
                    "oid-battery": ""
                  "style": {
                    "left": "355px",
                    "top": "259px",
                    "width": "40px",
                    "height": "40px",
                    "z-index": "50"
                  "widgetSet": "hqwidgets"
                "e00007": {
                  "data": {
                    "g_fixed": true,
                    "g_signals": false,
                    "oid": "mihome-vacuum.0.control.pause",
                    "min": "true",
                    "max": "true",
                    "iconName": "/vis.0/Sauger Pause.png",
                    "offsetAuto": true,
                    "leftOffset": "0",
                    "topOffset": "0",
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "iconOn": "/vis.0/Sauger Pause.png",
                    "testActive": true,
                    "pushButton": true,
                    "name": "Sauger Pause",
                    "oid-battery": ""
                  "style": {
                    "left": "355px",
                    "top": "329px",
                    "width": "40px",
                    "height": "40px",
                    "z-index": "50"
                "e00008": {
                  "data": {
                    "g_fixed": true,
                    "g_signals": false,
                    "oid": "mihome-vacuum.0.control.home",
                    "min": "true",
                    "max": "true",
                    "iconName": "/vis.0/Sauger Home.png",
                    "offsetAuto": true,
                    "leftOffset": "0",
                    "topOffset": "0",
                    "infoLeftPaddingLeft": "2",
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "iconOn": "/vis.0/Sauger Home.png",
                    "testActive": true,
                    "pushButton": true,
                    "name": "Sauger Go home",
                    "oid-battery": ""
                  "style": {
                    "left": "355px",
                    "top": "399px",
                    "width": "40px",
                    "height": "40px",
                    "z-index": "50"
                "e00009": {
                  "tpl": "tplJquiBool",
                  "data": {
                    "oid": "",
                    "g_fixed": true,
                    "g_css_background": true,
                    "g_css_border": true,
                    "g_signals": false,
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "html_true": "Alles",
                    "html_false": "Alles",
                    "name": "Sauge Text"
                  "style": {
                    "left": "405px",
                    "top": "274px",
                    "z-index": "51",
                    "width": "45px",
                    "height": "",
                    "text-align": "center",
                    "font-size": "small",
                    "color": "#bbb9b9",
                    "border-width": "0px",
                    "border-style": "none",
                    "background": "transparent"
                  "widgetSet": "jqui"
                "e00010": {
                  "data": {
                    "oid": "",
                    "g_fixed": true,
                    "g_signals": false,
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "html_true": "Pause",
                    "html_false": "Pause",
                  "style": {
                    "left": "405px",
                    "top": "344px",
                    "z-index": "51",
                    "width": "45px",
                    "height": "",
                    "color": "#bbb9b9",
                  "widgetSet": "jqui"
                "e00011": {
                  "data": {
                    "oid": "",
                    "g_fixed": true,
                    "g_signals": false,
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "html_true": "Home",
                    "html_false": "Home",
                  "style": {
                    "left": "405px",
                    "top": "414px",
                    "z-index": "51",
                    "width": "45px",
                    "height": "",
                    "color": "#bbb9b9",
                  "widgetSet": "jqui"
                "e00012": {
                  "tpl": "tplTableBody",
                  "data": {
                    "g_fixed": true,
                    "g_signals": false,
                    "static_value": "",
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "table_oid": "mihome-vacuum.0.history.allTableJSON",
                    "colCount": "5",
                    "colName1": "Tag",
                    "colWidth1": "35px",
                    "colAttr1": "",
                    "colName2": "Start",
                    "colWidth2": "45px",
                    "colAttr2": "",
                    "colName3": "Dauer",
                    "colWidth3": "50px",
                    "colAttr3": "",
                    "colName4": "Fläche",
                    "colWidth4": "70px",
                    "colAttr4": "",
                    "new_on_top": false,
                    "class": "justme",
                    "show_scroll": false,
                    "max_rows": "8",
                    "filterkey": "",
                    "hide_header": false,
                    "colWidth5": "30px",
                    "colName5": "Fehler",
                    "name": "Sauger Lauftabelle"
                  "style": {
                    "left": "708px",
                    "top": "253px",
                    "font-weight": "normal",
                    "width": "281px",
                    "height": "",
                    "z-index": "5",
                    "color": "#bbb9b9",
                    "background": "",
                    "background-color": "",
                "e00013": {
                  "tpl": "tplJquiButtonState",
                  "data": {
                    "oid": "mihome-vacuum.0.consumable.side_brush_reset",
                    "g_fixed": true,
                    "g_signals": false,
                    "buttontext": "Reset",
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "value": "true",
                    "no_style": false,
                    "name": "Reset Seitenbürste"
                  "style": {
                    "left": "981px",
                    "top": "202px",
                    "width": "100px",
                    "z-index": "20",
                    "color": "white",
                    "background": "transparent",
                    "font-size": "x-small",
                    "height": "30px",
                  "widgetSet": "jqui"
                "e00014": {
                  "data": {
                    "oid": "mihome-vacuum.0.consumable.filter_reset",
                    "g_fixed": true,
                    "g_signals": false,
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "value": "true",
                    "no_style": false,
                  "style": {
                    "left": "981px",
                    "top": "162px",
                    "width": "100px",
                    "z-index": "20",
                    "color": "white",
                    "height": "30px",
                  "widgetSet": "jqui"
                "e00015": {
                  "data": {
                    "oid": "mihome-vacuum.0.consumable.main_brush_reset",
                    "g_fixed": true,
                    "g_signals": false,
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "value": "true",
                    "no_style": false,
                  "style": {
                    "left": "981px",
                    "top": "122px",
                    "width": "100px",
                    "z-index": "20",
                    "color": "white",
                    "height": "30px",
                  "widgetSet": "jqui"
                "e00016": {
                  "data": {
                    "oid": "mihome-vacuum.0.consumable.sensors_reset",
                    "g_fixed": true,
                    "g_signals": false,
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "value": "true",
                    "no_style": false,
                  "style": {
                    "left": "981px",
                    "top": "82px",
                    "width": "100px",
                    "z-index": "20",
                    "color": "white",
                    "height": "30px",
                  "widgetSet": "jqui"
                "e00017": {
                  "tpl": "tplValueFloatBar",
                  "data": {
                    "oid": "mihome-vacuum.0.consumable.side_brush",
                    "g_fixed": true,
                    "g_signals": false,
                    "min": "0",
                    "max": "100",
                    "orientation": "horizontal",
                    "color": "{wert:mihome-vacuum.0.consumable.side_brush;wert <= 10 ? \"red\" :: wert <= 25 ? \"orange\" :: wert <= 50 ? \"yellow\" :: wert == 2 ? \"orange\" :: \"#248948\"}",
                    "reverse": false,
                    "class": "mdui-h-bargraph mdui-segment-10",
                    "border": "",
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "name": "Sauger Seitenbürste"
                  "style": {
                    "left": "855px",
                    "top": "208px",
                    "width": "100px",
                    "height": "15px",
                    "z-index": 2
                "e00018": {
                  "data": {
                    "oid": "mihome-vacuum.0.consumable.filter",
                    "g_fixed": true,
                    "g_signals": false,
                    "min": "0",
                    "max": "100",
                    "color": "{wert:mihome-vacuum.0.consumable.filter;wert <= 10 ? \"red\" :: wert <= 25 ? \"orange\" :: wert <= 50 ? \"yellow\" :: wert == 2 ? \"orange\" :: \"#248948\"}",
                    "reverse": false,
                    "border": "",
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "name": "Sauger Filter"
                  "style": {
                    "left": "855px",
                    "top": "168px",
                    "width": "100px",
                    "height": "15px",
                    "z-index": 2
                "e00019": {
                  "data": {
                    "oid": "mihome-vacuum.0.consumable.main_brush",
                    "g_fixed": true,
                    "g_signals": false,
                    "min": "0",
                    "max": "100",
                    "color": "{wert:mihome-vacuum.0.consumable.main_brush;wert <= 10 ? \"red\" :: wert <= 25 ? \"orange\" :: wert <= 50 ? \"yellow\" :: wert == 2 ? \"orange\" :: \"#248948\"}",
                    "reverse": false,
                    "border": "",
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "name": "Sauger Bürste"
                  "style": {
                    "left": "855px",
                    "top": "128px",
                    "width": "100px",
                    "height": "15px",
                    "z-index": 2
                "e00020": {
                  "data": {
                    "oid": "mihome-vacuum.0.consumable.sensors",
                    "g_fixed": true,
                    "g_signals": false,
                    "min": "0",
                    "max": "100",
                    "color": "{wert:mihome-vacuum.0.consumable.sensors;wert <= 10 ? \"red\" :: wert <= 25 ? \"orange\" :: wert <= 50 ? \"yellow\" :: wert == 2 ? \"orange\" :: \"#248948\"}",
                    "reverse": false,
                    "border": "",
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "name": "Sauger Sensor"
                  "style": {
                    "left": "855px",
                    "top": "88px",
                    "width": "100px",
                    "height": "15px",
                    "z-index": 2
                "e00021": {
                  "data": {
                    "g_fixed": false,
                    "g_signals": false,
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "test_html": "",
                    "html_append": " %",
                    "html_prepend": "Sensor: "
                  "style": {
                    "left": "711px",
                    "top": "87px",
                    "height": "",
                    "width": ""
                "e00022": {
                  "data": {
                    "g_fixed": false,
                    "g_signals": false,
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "test_html": "",
                    "html_prepend": "Hauptbürste "
                  "style": {
                    "left": "712px",
                    "top": "127px",
                    "height": "",
                    "width": ""
                "e00023": {
                  "data": {
                    "g_fixed": false,
                    "g_signals": false,
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "test_html": "",
                    "html_prepend": "Filter "
                  "style": {
                    "left": "712px",
                    "top": "167px",
                    "height": "",
                    "width": ""
                "e00024": {
                  "data": {
                    "g_fixed": false,
                    "g_signals": false,
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "test_html": "",
                    "html_prepend": "Seitenbürste "
                  "style": {
                    "left": "713px",
                    "top": "207px",
                    "height": "",
                    "width": ""
                "e00025": {
                  "tpl": "tplHtml",
                  "data": {
                    "g_fixed": true,
                    "g_css_shadow_padding": true,
                    "g_signals": false,
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "class": "myframe",
                    "name": "Rahmen"
                  "style": {
                    "left": "5px",
                    "top": "60px",
                    "box-shadow": "",
                    "z-index": "2",
                    "width": "1100px",
                    "height": "400px"
                "e00026": {
                  "tpl": "tplHtml",
                  "data": {
                    "g_fixed": true,
                    "g_signals": false,
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "html": "{mihome-vacuum.0.map.map64}",
                    "class": "",
                    "name": "Sauger Bild"
                  "style": {
                    "left": "-130px",
                    "top": "335px",
                    "width": "700px",
                    "height": "600px",
                    "z-index": "0"
                "e00027": {
                  "data": {
                    "oid": "mihome-vacuum.0.control.fan_power",
                    "g_fixed": true,
                    "g_signals": false,
                    "min": "0",
                    "max": "100",
                    "color": "#1db954",
                    "reverse": false,
                    "class": "mdui-h-bargraph mdui-triangle mdui-segment-10",
                    "border": "",
                    "html": "mdui-h-segment-10 mdui-h-fade",
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "name": "Lautstärke",
                  "style": {
                    "left": "333px",
                    "top": "222px",
                    "width": "calc(20% - 13px)",
                    "height": "15px",
                    "z-index": "20"
                "e00028": {
                  "tpl": "tplVis-materialdesign-Select",
                  "data": {
                    "g_fixed": false,
                    "g_signals": false,
                    "inputType": "text",
                    "inputLayout": "solo",
                    "showInputCounter": false,
                    "clearIconShow": false,
                    "listDataMethod": "valueList",
                    "countSelectItems": "2",
                    "listPosition": "auto",
                    "showSelectedIcon": "prepend-inner",
                    "showValue": "true",
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "inputLayoutBackgroundColor": "#000020",
                    "inputLayoutBackgroundColorHover": "#000020",
                    "inputLayoutBackgroundColorSelected": "#000020",
                    "inputLayoutBorderColor": "#bbb9b9",
                    "inputTextFontFamily": "Jura-Regular",
                    "inputTextFontSize": "14",
                    "inputTextColor": "#bbb9b9",
                    "inputLabelText": "Saugstärke wählen",
                    "inputLabelFontFamily": "Jura-Regular",
                    "inputLabelFontSize": "14",
                    "clearIconSize": "-1",
                    "valueList": "38,60,77,90",
                    "value0": "",
                    "value1": "",
                    "value2": "",
                    "label0": "",
                    "label1": "",
                    "label2": "",
                    "inputPrefix": "",
                    "inputCounterColor": "",
                    "jsonStringObject": "",
                    "subLabel0": "",
                    "listIcon0": "",
                    "listIcon1": "",
                    "subLabel1": "",
                    "valueListLabels": "Silent,Standard,Turbo,Extrem",
                    "inputLayoutBorderColorHover": "#bbb9b9",
                    "inputLayoutBorderColorSelected": "#bbb9b9",
                    "inputLabelColor": "#bbb9b9",
                    "inputLabelColorSelected": "#bbb9b9",
                    "inputTranslateY": "0",
                    "inputTranslateX": "0",
                    "g_inputSubText": false,
                    "showInputMessageAlways": "true"
                  "style": {
                    "left": "488px",
                    "top": "265px",
                    "z-index": "30"
                "e00029": {
                  "tpl": "tplHtml",
                  "data": {
                    "g_fixed": true,
                    "g_signals": false,
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "class": "myframe",
                    "name": "Rahmen"
                  "style": {
                    "left": "5px",
                    "top": "468px",
                    "box-shadow": "",
                    "z-index": "2",
                    "width": "500px",
                    "height": "330px"
                "e00030": {
                  "tpl": "tplHtml",
                  "data": {
                    "g_fixed": true,
                    "g_signals": false,
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "name": "Überdecker"
                  "style": {
                    "left": "509px",
                    "top": "468px",
                    "z-index": "1",
                    "background": "",
                    "width": "200px",
                    "height": "330px",
                    "background-color": "#000020"
                "e00031": {
                  "tpl": "tplHtml",
                  "data": {
                    "g_fixed": true,
                    "g_signals": false,
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                  "style": {
                    "left": "0px",
                    "top": "468px",
                    "z-index": "1",
                    "background": "",
                    "width": "5px",
                    "height": "330px",
                "e00032": {
                  "tpl": "tplHtml",
                  "data": {
                    "g_fixed": true,
                    "g_signals": false,
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                  "style": {
                    "left": "0px",
                    "top": "330px",
                    "z-index": "1",
                    "background": "",
                    "width": "709px",
                    "height": "138px",
                "e00033": {
                  "tpl": "tplTwSimpleDate",
                  "data": {
                    "g_fixed": true,
                    "g_signals": false,
                    "prependZero": "true",
                    "signals-icon-0": "/vis.0/Wetter_Sigi/lowbattery.png",
                    "signals-icon-1": "/vis.0/Wetter_Sigi/lowbattery.png",
                    "signals-icon-2": "/vis.0/Wetter_Sigi/lowbattery.png",
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "showWeekDay": true,
                    "noClass": true,
                    "shortWeekDay": false,
                    "name": "Überschrift Datum",
                    "filterkey": "Wetter",
                    "views": [
                      "Auto",
                      "Cam-Stream_innen",
                      "Dimmer",
                      "Gefahrenmeldung",
                      "Heizung",
                      "homee",
                      "Music",
                      "Raeume",
                      "Sauger",
                      "Wetter_komplett"
                  "style": {
                    "left": "1070px",
                    "top": "12px",
                    "color": "#bbb9b9",
                    "width": "200px",
                    "height": "24px",
                    "text-align": "right",
                    "z-index": "20",
                    "text-shadow": "",
                  "widgetSet": "timeandweather"
                "e00034": {
                  "tpl": "tplTwSimpleClock",
                  "data": {
                    "g_fixed": true,
                    "g_signals": false,
                    "lc-format": "",
                    "lc-bkg-color": "",
                    "lc-color": "",
                    "lc-zindex": 0,
                    "name": "Überschrift Zeit",
                    "blink": false,
                    "hideSeconds": false,
                    "noClass": true,
                    "views": [
                      "Auto",
                      "Cam-Stream_innen",
                      "Dimmer",
                      "Gefahrenmeldung",
                      "Heizung",
                      "homee",
                      "Music",
                      "Raeume",
                      "Sauger",
                      "Wetter_komplett"
                  "style": {
                    "left": "1166px",
                    "top": "32px",
                    "color": "#bbb9b9",
                    "width": "104px",
                    "height": "20px",
                    "text-shadow": "0",
                    "word-spacing": "",
                    "letter-spacing": "",
                    "z-index": "1",
              "name": "Sauger",
              "filterList": [
                "Wetter"
            • Dutchman
              @Meistertr Yes raeume gehen jetzt mit meinem S55 GEIL !!!!
              • Diginix
                Diginix @blackeagle998 last edited by
                @blackeagle998 sagte in Test Adapter mihome-vacuum v2.0.x:
                Guten Morgen,
                @Meistertr & @dirkhe
                Das ist ein Fehler im Datenpunkt "carpet_mode". Dieser ist vom type=switch. Switch ist aber eine Rolle und der type muss boolean sein.
                Also so gehört es in der main.js ab Zeile 279:
                "type": "boolean",
                "role": "switch"
                  dirkhe Developer last edited by
                  is gefixt und im git
                  Patchwork 3001 Diginix 2 Replies Last reply Reply Quote 0
                    dirkhe Developer last edited by dirkhe
                    @Meistertr Beim JSON.parse wird ein Fehler geworfen, wenn der String leer ist. Das bekommt man bespielsweise bei miIo_info zurück, wenn der robo nicht mit dem inet verbunden ist. Ich habe daher das mal wieder zurückgebaut und habe den loglevel da auf silly gesetzt
                    Meistertr 1 Reply Last reply Reply Quote 0
                    • Patchwork 3001
                      Patchwork 3001 @dirkhe last edited by
                      @dirkhe danke alles top
                      • Meistertr
                        Meistertr Developer @dirkhe last edited by
                        @dirkhe top. War auch nur zum testen gedacht.
                        Patchwork 3001 1 Reply Last reply Reply Quote 0
                        • Patchwork 3001
                          Patchwork 3001 @Meistertr last edited by Patchwork 3001
                          @Meistertr so habe getestet. Alles läuft mit dem s5.
                          Nur eins verstehe ich nicht alles ist da sogar die räume mit Nummern und alles geht .
                          aber im log steht
                          " mihome-vacuum.0 2020-02-20 10:02:31.053 error (9276) TypeError: Cannot read property '0' of undefined "
                          aber alles läuft so wie gedacht.???
                            dirkhe Developer @Patchwork 3001 last edited by
                            @Patchwork-3001 sagte in Test Adapter mihome-vacuum v2.0.x:
                            property
                            kannst du bitte mal das debug schicken?
                            Patchwork 3001 B 2 Replies Last reply Reply Quote 0
                            • Patchwork 3001
                              @dirkhe gerne wenn du mir sagst wie das geht
                              • Diginix
                                Diginix @dirkhe last edited by
                                @dirkhe sagte in Test Adapter mihome-vacuum v2.0.x:
                                Das ist aber auch nicht korrekt. Button braucht read=false 😉
                                Meiner hat diese Funktion nicht, aber Switch ist sicher eindeutiger zu erkennen vom Zustand.
                                adapter.setObjectNotExists('control.carpet_mode', {
                                    type: 'state',
                                    common: {
                                        type: 'boolean',
                                        role: 'button',
                                        read: true,
                                        write: true,
                                        desc: 'Fanspeed is Max on carpets',
                                    native: {}
                                  blackeagle998 @dirkhe last edited by
                                  property
                                  Habe das gleiche Thema, hier der DEBUG Auszug:
                                  mihome-vacuum.0	2020-02-20 11:54:12.943	error	(17390) TypeError: Cannot read property '0' of undefined
                                  mihome-vacuum.0	2020-02-20 11:54:12.430	debug	(17390) update_Map use old mapurl
                                  mihome-vacuum.0	2020-02-20 11:54:12.430	debug	(17390) update_Map Mimap enabled
                                  mihome-vacuum.0	2020-02-20 11:54:10.428	error	(17390) TypeError: Cannot read property '0' of undefined
                                  mihome-vacuum.0	2020-02-20 11:54:09.973	debug	(17390) update_Map got new time:1582196049
                                  mihome-vacuum.0	2020-02-20 11:54:09.973	debug	(17390) update_Map got new expires:1582197849
                                  mihome-vacuum.0	2020-02-20 11:54:09.972	debug	(17390) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/74488275/7?Expires=xxxxxxxxx&GalaxyAccessKeyId=xxxxxxxxx&Signature=xxxxxxxxxx=
                                  mihome-vacuum.0	2020-02-20 11:54:09.906	debug	(17390) update_Map need new mapurl
                                  mihome-vacuum.0	2020-02-20 11:54:09.905	debug	(17390) update_Map Mimap enabled
                                  mihome-vacuum.0	2020-02-20 11:54:07.903	error	(17390) TypeError: Cannot read property '0' of undefined
                                  mihome-vacuum.0	2020-02-20 11:54:07.388	debug	(17390) update_Map got new time:1582196047
                                  mihome-vacuum.0	2020-02-20 11:54:07.388	debug	(17390) update_Map got new expires:1582197847
                                    Ich habe den Fehler jetzt abgefangen, aber warum es keine Kartendaten gibt, sollte sich @Meistertr anschauen, der ist da tiefer drin
                                    Den button habe ich jetzt auch auf read gesetzt. Ich habe button genommen, weil alle button sind und nicht switch, wollte das einheitlich lassen
                                    Patchwork 3001 1 Reply Last reply Reply Quote 1
                                    • Patchwork 3001
                                      @dirkhe karte und alles sind ja da und laufen perfekt . aber das trotzdem der Fehler im log steht ist halt komisch
                                        smarti2015 last edited by
                                        Hi, wollte update Installieren von 1.1.5 auf Version 2.x aber es kommt immer eine Fehlermeldung:
                                        host.All-In-One-Tinker	2020-02-20 12:50:29.060	info	iobroker exit 25
                                        host.All-In-One-Tinker	2020-02-20 12:50:28.043	error	iobroker host.All-In-One-Tinker Cannot install https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/master: 1
                                        host.All-In-One-Tinker	2020-02-20 12:50:28.006	info	iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-02-20T11_50_27_975Z-debug.log
                                        host.All-In-One-Tinker	2020-02-20 12:50:27.955	info	iobroker This is probably not a problem with npm. There is likely additional logging output above.
                                        host.All-In-One-Tinker	2020-02-20 12:50:27.954	info	iobroker npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR!
                                        host.All-In-One-Tinker	2020-02-20 12:50:27.953	info	iobroker errno 1npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
                                        host.All-In-One-Tinker	2020-02-20 12:50:27.951	info	iobroker code ELIFECYCLEnpm ERR!
                                        host.All-In-One-Tinker	2020-02-20 12:50:27.950	info	iobroker ERR!
                                        host.All-In-One-Tinker	2020-02-20 12:50:27.949	info	iobroker npm
                                        host.All-In-One-Tinker	2020-02-20 12:50:25.594	info	iobroker /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.18.1node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
                                        host.All-In-One-Tinker	2020-02-20 12:50:25.593	info	iobroker ERR! System Linux 4.19.69-rockchipnode-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ER
                                        host.All-In-One-Tinker	2020-02-20 12:50:25.591	info	iobroker node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modu
                                        host.All-In-One-Tinker	2020-02-20 12:50:25.587	info	iobroker node-pre-gyp ERR! build error
                                        host.All-In-One-Tinker	2020-02-20 12:50:25.571	info	iobroker /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.18.1gyp ERR! node-gyp -v v5.0.5gyp ERR! not ok
                                        host.All-In-One-Tinker	2020-02-20 12:50:25.569	info	iobroker ERR! System Linux 4.19.69-rockchipgyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroke
                                        host.All-In-One-Tinker	2020-02-20 12:50:25.568	info	iobroker stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:198:13)gyp ERR! stack at Pr
                                        host.All-In-One-Tinker	2020-02-20 12:50:25.567	info	iobroker gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR!
                                        host.All-In-One-Tinker	2020-02-20 12:50:25.565	info	iobroker ERR! configure error
                                        host.All-In-One-Tinker	2020-02-20 12:50:25.564	info	iobroker gyp
                                        host.All-In-One-Tinker	2020-02-20 12:50:25.529	info	iobroker gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                                        host.All-In-One-Tinker	2020-02-20 12:50:25.528	info	iobroker Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' fou
                                        host.All-In-One-Tinker	2020-02-20 12:50:22.082	info	iobroker node-aead-crypto not needed on this system, since all ciphers are natively supported
                                        Bild Text
                                        Patchwork 3001 D 2 Replies Last reply Reply Quote 0
                                        • Patchwork 3001
                                          Patchwork 3001 @smarti2015 last edited by Patchwork 3001
                                          @smarti2015 Wenn der Adapter nicht installiert werden kann, kann Canvas nicht installiert werden
                                          npm ERR! canvas@2.6.1 install: node-pre-gyp install --fallback-to-build npm ERR! Exit status 1
                                          Dann müssen folgende Packete und Bibliotheken selber installiert werden:
                                          " sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev "
                                          " sudo npm install canvas --unsafe-perm=true "
                                          über putty ohne "
                                          K S 2 Replies Last reply Reply Quote 0
                                          • Meistertr
                                            Meistertr Developer @blackeagle998 last edited by
                                            @blackeagle998 dann bräuchte uch einen etwas größeren logauszug
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            491413
