    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер ioBroker MySensors
      Maxtox last edited by
      after a new reset ардуины:
      the LOG:
      [color]host-raspberrypi	2016-02-19 19:53:16	info	Restart adapter system.adapter.mysensors.0 because enabled
      host-raspberrypi	2016-02-19 19:53:16	error	instance system.adapter.mysensors.0 terminated with code 6 (uncaught exception)
      mysensors-0	2016-02-19 19:53:16	info	cleaned everything up...
      TypeError:	2016-02-19 19:53:16	error	at /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:388:9
      TypeError:	2016-02-19 19:53:16	error	at afterRead (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:372:20)
      TypeError:	2016-02-19 19:53:16	error	at SerialPortFactory.SerialPort._emitData (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:396:20)
      TypeError:	2016-02-19 19:53:16	error	at Object.SerialPort.opts.dataCallback (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:181:12)
      TypeError:	2016-02-19 19:53:16	error	at Object.parser (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/parsers.js:24:13)
      TypeError:	2016-02-19 19:53:16	error	at Array.forEach (native)
      TypeError:	2016-02-19 19:53:16	error	at /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/parsers.js:25:17
      TypeError:	2016-02-19 19:53:16	error	at SerialPort.EventEmitter.emit (events.js:95:17)
      TypeError:	2016-02-19 19:53:16	error	at SerialPort. (/opt/iobroker/node_modules/iobroker.mysensors/mysensors.js:293:8)
      TypeError:	2016-02-19 19:53:16	error	at mkdbmsgUnique (/opt/iobroker/node_modules/iobroker.mysensors/mysensors.js:121:23)
      TypeError:	2016-02-19 19:53:16	error	Cannot read property 'id' of undefined
      uncaught	2016-02-19 19:53:16	error	exception: Cannot read property 'id' of undefined
      mysensors-0	2016-02-19 19:53:16	info	Rx-Raw 255
      mysensors-0	2016-02-19 19:53:16	info	__0_|_255_|_internal_|_false_|_I_SKETCH_VERSION_|_1.0
      mysensors-0	2016-02-19 19:53:16	debug	количество сообщений 3
      mysensors-0	2016-02-19 19:53:16	info	Rx-Raw 0;255;3;0;12;1.0
      mysensors-0	2016-02-19 19:53:16	info	__0_|_255_|_internal_|_false_|_I_SKETCH_NAME_|_ETHduino by JR
      mysensors-0	2016-02-19 19:53:16	debug	количество сообщений 2
      mysensors-0	2016-02-19 19:53:16	info	Rx-Raw 0;255;3;0;11;ETHduino by JR
      mysensors-0	2016-02-19 19:53:16	info	__0_|_255_|_internal_|_false_|_I_GATEWAY_READY_|_Gateway startup complete.
      mysensors-0	2016-02-19 19:53:16	debug	количество сообщений 1
      mysensors-0	2016-02-19 19:53:16	info	Rx-Raw 0;255;3;0;14;Gateway startup complete.
      mysensors-0	2016-02-19 19:53:16	info	__Temperature for the sensor 42 is0_|_255_|_internal_|_false_|_I_LOG_MESSAGE_|_Starting gateway (R-NGA-, 2.0.0-beta)
      mysensors-0	2016-02-19 19:53:16	debug	количество сообщений 0
      mysensors-0	2016-02-19 19:53:16	info	Rx-Raw Temperature for the sensor 42 is0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0-beta)
      mysensors-0	2016-02-19 19:53:15	debug	Communication port:/dev/ttyUSB0
      mysensors-0	2016-02-19 19:53:15	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.mysensors
      mysensors-0	2016-02-19 19:53:14	debug	statesDB connected
      mysensors-0	2016-02-19 19:53:14	debug	objectDB connected[/color]
      • V
        Vlad_k last edited by
        Переустанавливай драйвер, сделал фильтрацию мусора, должно работать.
        ты сам скетч писал?
          Да… Писал сам....
          Спасибо!
          Сейчас оттестю...
            Console LOG:
            root@raspberrypi:/opt/iobroker# npm install https://github.com/DJONvl/iobroker.myse … all/master
            npm http GET https://github.com/DJONvl/iobroker.myse ... all/master
            npm http 200 https://github.com/DJONvl/iobroker.myse ... all/master
            npm http GET https://registry.npmjs.org/sensors
            npm http GET https://registry.npmjs.org/serialport
            npm http 304 https://registry.npmjs.org/sensors
            npm http 304 https://registry.npmjs.org/serialport
            npm http GET https://registry.npmjs.org/optimist
            npm http GET https://registry.npmjs.org/nan
            npm http GET https://registry.npmjs.org/bindings/1.2.1
            npm http GET https://registry.npmjs.org/sf/0.1.7
            npm http GET https://registry.npmjs.org/async/0.9.0
            npm http GET https://registry.npmjs.org/debug
            npm http 304 https://registry.npmjs.org/nan
            npm http 304 https://registry.npmjs.org/debug
            npm http 304 https://registry.npmjs.org/sf/0.1.7
            npm http 200 https://registry.npmjs.org/optimist
            npm http 304 https://registry.npmjs.org/bindings/1.2.1
            npm http 304 https://registry.npmjs.org/async/0.9.0
            npm http GET https://registry.npmjs.org/ms/0.7.1
            npm http 304 https://registry.npmjs.org/ms/0.7.1
            npm http GET https://registry.npmjs.org/wordwrap
            npm http GET https://registry.npmjs.org/minimist
            npm http 304 https://registry.npmjs.org/wordwrap
            npm http 304 https://registry.npmjs.org/minimist
            serialport@2.0.6 install /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport
            node-pre-gyp install --fallback-to-build
            node-pre-gyp http GET https://github.com/voodootikigod/node-s … arm.tar.gz
            node-pre-gyp http 404 https://github.com/voodootikigod/node-s ... arm.tar.gz
            node-pre-gyp http Pre-built binary not available for your system, looked for https://github.com/voodootikigod/node-s ... arm.tar.gz (falling back to source compile with node-gyp)
            make: Entering directory '/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build'
            CXX(target) Release/obj.target/serialport/src/serialport.o
            CXX(target) Release/obj.target/serialport/src/serialport_unix.o
            CXX(target) Release/obj.target/serialport/src/serialport_poller.o
            SOLINK_MODULE(target) Release/obj.target/serialport.node
            SOLINK_MODULE(target) Release/obj.target/serialport.node: Finished
            COPY Release/serialport.node
            COPY /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build/Release/node-v11-linux-arm/serialport.node
            TOUCH Release/obj.target/action_after_build.stamp
            make: Leaving directory '/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build'
            iobroker.mysensors@0.0.1 node_modules/iobroker.mysensors
            ├── sensors@0.1.0
            └── serialport@2.0.6 (bindings@1.2.1, sf@0.1.7, async@0.9.0, nan@2.0.9, debug@2.2.0, optimist@0.6.1)
              смотрим!!!
              https://youtu.be/SyWTYB084xQ
              УЖЕ ЛУЧШЕ!
              Только BIND не сработал!
              • V
                bind срабатывает, только переменная не сохраняется
                смотри что сделай:
                нажми bind в списке devices появятся твои юниты щелкни по любому 2 раза и нажми сохранить, чтобы активировалась кнопка Сохранить и выйти
                ToDo сделать активацию сохранения при добавлении в список новых юнитов
                  Ок… Попробую...
                    Привет, могу ставить новую версию? Bluefox что-то запулил?!
                    • V
                      да ставь
                        смотрим!!!
                        https://youtu.be/mvjW1XE959E
                          не читает… только информация из presentation
                          https://youtu.be/wylcfQUxXgk
                          • V
                            @Maxtox:
                            смотрим!!!
                            https://youtu.be/mvjW1XE959E `
                            1 ты очень торопишься и не даешь запуститься драйверу, поэтому входя в настройки селектор ком портов пустой
                            2 ты добавил один и тот же юнит несколько раз, зачем? все равно имя переменной одно создается
                            3 для управления реле тебе нужно прописать в RAW посылку управляющую твоим реле без Value
                            а так все работает отлично
                              смотрим
                              почему ack TRUE?
                              https://youtu.be/rPdlEBoaDGc
                              в скетче на ардуине
                              `present(i, iomodus[i].sensorType, iomodus[i].description, false);`
                              смотрим что происходит
                              [https://youtu.be/mcUTM45SjG8](https://youtu.be/mcUTM45SjG8)[/i][/i]
                                @Vlad_k:
                                @Maxtox:
                                смотрим!!!
                                а так все работает отлично `
                                1. привык так 🙂
                                2. убрал!
                                3. смотрим https://youtu.be/IiU1DlUT9cc
                                • V
                                  все правильно, что тебя смущает? то что в ком порт от юнита приходит то и отображается, в логе постоянно надо жать кнопку обновить иначе не корректно показывает, но это не проблема в драйвере
                                    проблема в том что VALUE ПРЫГАЕТ, я думаю из за ack=TRUE,
                                    https://youtu.be/-uoDqlupOiE
                                    mysensors-0 2016-02-21 11:34:21 info Rx-Raw 0;58;1;1;0;55.91
                                    mysensors-0 2016-02-21 11:32:34 info _0|42|set|true|V_TEMP|_-127.00
                                    mysensors-0 2016-02-21 11:31:43 info raw_data_error 1
                                    mysensors-0 2016-02-21 11:33:36 info Rx-Raw 0;58;1;1;0;56.07
                                    mysensors-0 2016-02-21 11:34:21 info ack is not set!
                                    пробыvал изменит RAW от RELAY…Скрипт зависает! (последнее видео)
                                      BUG
                                      смотри как время в логе выходит!
                                      Или как ты время лога сортируешь?
                                      mysensors-0	2016-02-21 11:34:25	info	raw_data_error 1
                                      mysensors-0	2016-02-21 11:31:47	info	Rx-Raw -127.00
                                      mysensors-0	2016-02-21 11:33:39	info	Rx-Raw TYPE
                                      mysensors-0	2016-02-21 11:32:38	info	raw_data_error 1
                                      mysensors-0	2016-02-21 11:34:25	info	Rx-Raw String
                                      mysensors-0	2016-02-21 11:31:47	info	raw_data_error 1
                                      mysensors-0	2016-02-21 11:33:39	info	raw_data_error 1
                                      mysensors-0	2016-02-21 11:32:38	info	Rx-Raw 58
                                      mysensors-0	2016-02-21 11:31:47	info	Rx-Raw String
                                      mysensors-0	2016-02-21 11:33:39	info	Rx-Raw -127.00
                                      mysensors-0	2016-02-21 11:34:25	info	Rx-Raw 42
                                      mysensors-0	2016-02-21 11:32:38	info	Rx-Raw PIN
                                      mysensors-0	2016-02-21 11:31:47	info	Rx-Raw 42
                                      mysensors-0	2016-02-21 11:33:39	info	Rx-Raw String
                                      mysensors-0	2016-02-21 11:32:38	info	__0_|_58_|_set_|_true_|_V_TEMP_|_40.08
                                      mysensors-0	2016-02-21 11:34:25	info	Rx-Raw PIN
                                      • V
                                        0;8;1;1;2 для твоего реле напиши, остальные поля можно не трогать
                                        не понял какое время? только мусор и температура в логе
                                          https://youtu.be/LFCIhMTMtIY
                                          • V
                                            прыгает потому что твой шлюз отправляет данные постоянно
                                            106
                                            31403
