    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер ioBroker MySensors
      Maxtox last edited by
      Console LOG:
      root@raspberrypi:/opt/iobroker# npm install https://github.com/DJONvl/iobroker.myse … all/master
      npm http GET https://github.com/DJONvl/iobroker.myse ... all/master
      npm http 200 https://github.com/DJONvl/iobroker.myse ... all/master
      npm http GET https://registry.npmjs.org/sensors
      npm http GET https://registry.npmjs.org/serialport
      npm http 304 https://registry.npmjs.org/sensors
      npm http 304 https://registry.npmjs.org/serialport
      npm http GET https://registry.npmjs.org/optimist
      npm http GET https://registry.npmjs.org/nan
      npm http GET https://registry.npmjs.org/bindings/1.2.1
      npm http GET https://registry.npmjs.org/sf/0.1.7
      npm http GET https://registry.npmjs.org/async/0.9.0
      npm http GET https://registry.npmjs.org/debug
      npm http 304 https://registry.npmjs.org/nan
      npm http 304 https://registry.npmjs.org/debug
      npm http 304 https://registry.npmjs.org/sf/0.1.7
      npm http 200 https://registry.npmjs.org/optimist
      npm http 304 https://registry.npmjs.org/bindings/1.2.1
      npm http 304 https://registry.npmjs.org/async/0.9.0
      npm http GET https://registry.npmjs.org/ms/0.7.1
      npm http 304 https://registry.npmjs.org/ms/0.7.1
      npm http GET https://registry.npmjs.org/wordwrap
      npm http GET https://registry.npmjs.org/minimist
      npm http 304 https://registry.npmjs.org/wordwrap
      npm http 304 https://registry.npmjs.org/minimist
      serialport@2.0.6 install /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport
      node-pre-gyp install --fallback-to-build
      node-pre-gyp http GET https://github.com/voodootikigod/node-s … arm.tar.gz
      node-pre-gyp http 404 https://github.com/voodootikigod/node-s ... arm.tar.gz
      node-pre-gyp http Pre-built binary not available for your system, looked for https://github.com/voodootikigod/node-s ... arm.tar.gz (falling back to source compile with node-gyp)
      make: Entering directory '/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build'
      CXX(target) Release/obj.target/serialport/src/serialport.o
      CXX(target) Release/obj.target/serialport/src/serialport_unix.o
      CXX(target) Release/obj.target/serialport/src/serialport_poller.o
      SOLINK_MODULE(target) Release/obj.target/serialport.node
      SOLINK_MODULE(target) Release/obj.target/serialport.node: Finished
      COPY Release/serialport.node
      COPY /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build/Release/node-v11-linux-arm/serialport.node
      TOUCH Release/obj.target/action_after_build.stamp
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build'
      iobroker.mysensors@0.0.1 node_modules/iobroker.mysensors
      ├── sensors@0.1.0
      └── serialport@2.0.6 (bindings@1.2.1, sf@0.1.7, async@0.9.0, nan@2.0.9, debug@2.2.0, optimist@0.6.1)
        смотрим!!!
        https://youtu.be/SyWTYB084xQ
        УЖЕ ЛУЧШЕ!
        Только BIND не сработал!
        • V
          Vlad_k last edited by
          bind срабатывает, только переменная не сохраняется
          смотри что сделай:
          нажми bind в списке devices появятся твои юниты щелкни по любому 2 раза и нажми сохранить, чтобы активировалась кнопка Сохранить и выйти
          ToDo сделать активацию сохранения при добавлении в список новых юнитов
            Ок… Попробую...
              Привет, могу ставить новую версию? Bluefox что-то запулил?!
              • V
                да ставь
                  смотрим!!!
                  https://youtu.be/mvjW1XE959E
                    не читает… только информация из presentation
                    https://youtu.be/wylcfQUxXgk
                    • V
                      @Maxtox:
                      смотрим!!!
                      https://youtu.be/mvjW1XE959E `
                      1 ты очень торопишься и не даешь запуститься драйверу, поэтому входя в настройки селектор ком портов пустой
                      2 ты добавил один и тот же юнит несколько раз, зачем? все равно имя переменной одно создается
                      3 для управления реле тебе нужно прописать в RAW посылку управляющую твоим реле без Value
                      а так все работает отлично
                        смотрим
                        почему ack TRUE?
                        https://youtu.be/rPdlEBoaDGc
                        в скетче на ардуине
                        `present(i, iomodus[i].sensorType, iomodus[i].description, false);`
                        смотрим что происходит
                        [https://youtu.be/mcUTM45SjG8](https://youtu.be/mcUTM45SjG8)[/i][/i]
                          @Vlad_k:
                          @Maxtox:
                          смотрим!!!
                          а так все работает отлично `
                          1. привык так 🙂
                          2. убрал!
                          3. смотрим https://youtu.be/IiU1DlUT9cc
                          • V
                            все правильно, что тебя смущает? то что в ком порт от юнита приходит то и отображается, в логе постоянно надо жать кнопку обновить иначе не корректно показывает, но это не проблема в драйвере
                              проблема в том что VALUE ПРЫГАЕТ, я думаю из за ack=TRUE,
                              https://youtu.be/-uoDqlupOiE
                              mysensors-0 2016-02-21 11:34:21 info Rx-Raw 0;58;1;1;0;55.91
                              mysensors-0 2016-02-21 11:32:34 info _0|42|set|true|V_TEMP|_-127.00
                              mysensors-0 2016-02-21 11:31:43 info raw_data_error 1
                              mysensors-0 2016-02-21 11:33:36 info Rx-Raw 0;58;1;1;0;56.07
                              mysensors-0 2016-02-21 11:34:21 info ack is not set!
                              пробыvал изменит RAW от RELAY…Скрипт зависает! (последнее видео)
                                BUG
                                смотри как время в логе выходит!
                                Или как ты время лога сортируешь?
                                mysensors-0	2016-02-21 11:34:25	info	raw_data_error 1
                                mysensors-0	2016-02-21 11:31:47	info	Rx-Raw -127.00
                                mysensors-0	2016-02-21 11:33:39	info	Rx-Raw TYPE
                                mysensors-0	2016-02-21 11:32:38	info	raw_data_error 1
                                mysensors-0	2016-02-21 11:34:25	info	Rx-Raw String
                                mysensors-0	2016-02-21 11:31:47	info	raw_data_error 1
                                mysensors-0	2016-02-21 11:33:39	info	raw_data_error 1
                                mysensors-0	2016-02-21 11:32:38	info	Rx-Raw 58
                                mysensors-0	2016-02-21 11:31:47	info	Rx-Raw String
                                mysensors-0	2016-02-21 11:33:39	info	Rx-Raw -127.00
                                mysensors-0	2016-02-21 11:34:25	info	Rx-Raw 42
                                mysensors-0	2016-02-21 11:32:38	info	Rx-Raw PIN
                                mysensors-0	2016-02-21 11:31:47	info	Rx-Raw 42
                                mysensors-0	2016-02-21 11:33:39	info	Rx-Raw String
                                mysensors-0	2016-02-21 11:32:38	info	__0_|_58_|_set_|_true_|_V_TEMP_|_40.08
                                mysensors-0	2016-02-21 11:34:25	info	Rx-Raw PIN
                                • V
                                  0;8;1;1;2 для твоего реле напиши, остальные поля можно не трогать
                                  не понял какое время? только мусор и температура в логе
                                    https://youtu.be/LFCIhMTMtIY
                                    • V
                                      прыгает потому что твой шлюз отправляет данные постоянно
                                        @Vlad_k:
                                        прыгает потому что твой шлюз отправляет данные постоянно `
                                        вроде не прыгает ( подключил к компу)…
                                        https://youtu.be/rQqTmg9WccY
                                        в иоброкере...ЛОГ:
                                        @bluefox:
                                        stateChange	mysensors.0.V_TEMP_0_58	"43.29"	false	mysensors.0	2016-02-21 12:58:28	2016-02-21 12:58:18
                                        stateChange	mysensors.0.V_TEMP_0_58	"43.29"	false	mysensors.0	2016-02-21 12:58:27	2016-02-21 12:58:18
                                        stateChange	mysensors.0.V_TEMP_0_58	"43.29"	false	mysensors.0	2016-02-21 12:58:26	2016-02-21 12:58:18
                                        stateChange	mysensors.0.V_TEMP_0_58	"43.29"	false	mysensors.0	2016-02-21 12:58:25	2016-02-21 12:58:18
                                        stateChange	mysensors.0.V_TEMP_0_58	"43.29"	false	mysensors.0	2016-02-21 12:58:24	2016-02-21 12:58:18
                                        stateChange	mysensors.0.V_TEMP_0_58	"43.29"	false	mysensors.0	2016-02-21 12:58:23	2016-02-21 12:58:18
                                        • V
                                          а попробуй-ка только один датчик температуры выбрать в девлист, может прыгает потому что с двух датчиков неправильно парсит, хотя врятли…
                                            ни чего не понимаю!
                                            https://youtu.be/wsnjSjnc0gU
                                            в скетче каждые 10сек. update!
                                            https://www.youtube.com/watch?v=wsnjSjnc0gU
                                            `if (millis() > next_Time[i])
                                                    next_Time[i] = next_Time[i] + 10000;  //Update Value every 10s
                                                    Rt = Rv / ((1024.0 / analogRead(i)) - 1.0);
                                                    float tempNTC = (B_wert * Tn / (B_wert + (Tn * log(Rt / Rn)))) - Tn + 25.0 + Temp_offset[i];// Here Offset if needed
                                                    if ((tempNTC > (last_float_value[i] + delta_ntc)) || (tempNTC < (last_float_value[i] - delta_ntc))
                                                      || complete_loop)
                                                      //MyMessage msg(i, iomodus[i].variableType);
                                                      Serial.print("tempNTC of Pin ");
                                                      Serial.print(i);
                                                      Serial.print(" is ");
                                                      Serial.println(tempNTC);
                                                      send(msg.setSensor(i).set(tempNTC, 2), false);
                                                      last_float_value[i] = tempNTC;
                                                  }`[/i][/i][/i][/i][/i][/i][/i][/i]
                                            106
                                            31403
