    4. tr-064 v3.1.x (Latest Repo) Diskussion
      crunchip Forum Testing Most Active @apollon77 last edited by
      @apollon77 Im heutigen log taucht gar nichts auf, weder tr-64 noch fritzbox.
      Das ist das log, vom letzten Test/Anruf gestern
      2020-02-19 13:13:47.784 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:13:47;RING;0;xxxxxxxx;xxxx;SIP0;
      2020-02-19 13:13:48.827 - info: sayit.0 (3070) saying: xxxxxxx ruft gerade an.
      2020-02-19 13:13:49.073 - info: sayit.0 (3070) Set "chromecast.0.Google_Home_mini.player.announcement to {"url":"http://10.1.1.10:8082/state/sayit.0.tts.mp3","volume":60}
      2020-02-19 13:14:03.757 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:14:03;DISCONNECT;0;0;
      2020-02-19 13:16:00.022 - info: host.IoBroker instance system.adapter.dwd.0 started with pid 11203
      2020-02-19 13:16:05.236 - info: host.IoBroker instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
      2020-02-19 13:18:56.478 - info: info.0 (1703) Popup news was read...
      2020-02-19 13:20:00.083 - info: host.IoBroker instance system.adapter.weatherunderground.0 started with pid 12442
      2020-02-19 13:20:08.684 - info: host.IoBroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
      2020-02-19 13:23:17.103 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:23:17;RING;0;xxxxxxx;981400;SIP0;
      2020-02-19 13:23:18.173 - info: sayit.0 (3070) saying: xxxxxxxxx ruft gerade an.
      2020-02-19 13:23:18.378 - info: sayit.0 (3070) Set "chromecast.0.Google_Home_mini.player.announcement to {"url":"http://10.1.1.10:8082/state/sayit.0.tts.mp3","volume":60}
      2020-02-19 13:23:25.692 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:23:25;DISCONNECT;0;0;
      2020-02-19 13:24:07.593 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:24:07;CALL;0;0;xxxxx;xxxxxxxx;SIP0;
      2020-02-19 13:24:38.693 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:24:38;DISCONNECT;0;0;
      2020-02-19 13:27:59.752 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:27:59;CALL;0;0;xxxxx;xxxxxxxxx;SIP0;
      2020-02-19 13:28:18.208 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:28:18;CONNECT;0;0;xxxxxxxxx;
      2020-02-19 13:28:26.370 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:28:26;DISCONNECT;0;6;
      hier nach dem cronjob
      2020-02-20 00:01:00.016 - info: tr-064.0 (3240) Scheduled restart.
      2020-02-20 00:01:00.041 - info: tr-064.0 (3240) terminating
      2020-02-20 00:01:00.045 - info: tr-064.0 (3240) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2020-02-20 00:01:00.620 - error: host.IoBroker instance system.adapter.tr-064.0 terminated with code 156 (156)
      2020-02-20 00:01:00.620 - info: host.IoBroker Restart adapter system.adapter.tr-064.0 because enabled
      2020-02-20 00:01:01.678 - info: host.IoBroker instance system.adapter.tr-064.0 started with pid 21837
      2020-02-20 00:01:04.336 - info: tr-064.0 (21837) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.19.0
        crunchip Forum Testing Most Active @wendy2702 last edited by
        @wendy2702 nein, es ist nur der tr-64 instaliert.
        nochmal die Reihenfolge
        tr-64 lief in der alten Version, nach Umstellung (js-controller) war das soef Problem, daher zusätzlich den community installiert, der alte war ausgeschaltet. Einige Tage laufen lassen, mit dem Community, dann habe ich den alten tr-64 gelöscht.
        nachdem der alte wiederbelebt wurde, habe ich diesen Installiert und danach den Community gelöscht.
        als einzigstes "Überbleibsel" hab ich die meta noch drin stehen, dazu hatte ich aber glaub ich, auch schon gefragt, ob das so richtig ist, aber keine Antwort bekommen
        • dslraser
          dslraser Forum Testing Most Active @crunchip last edited by
          @crunchip
          hm...wenn es alle Varianten nicht tun, dann deutet es ja fast auf die Fritte selbst hin ? Aber wie gesagt, alles nur Vermutungen. Ohne Fehler im LOG, wie will man da auch was finden...
            crunchip Forum Testing Most Active @apollon77 last edited by Negalein
            @apollon77 du bist witzig😁
            wo und wie pack ich das rein?
            das ist die aktuelle callmonitor.js
            /* jshint -W097 */
            /* jshint strict: false */
            /* jslint node: true */
            'use strict';
            const CALLMONITOR_NAME = 'callmonitor';
            const enableConnect1012 = '--- To use the callmonitor, enable connects to port 1012 on FritzBox by dialing #96*5* with a directly connected phone (line/dect) and restart this adapter';
            function checkPatchForECONNREFUSED(adapter) {
               if (process || process.version) {
                   const ar = process.version.split('.');
                   if (ar[0].indexOf('v') === 0) {
                       ar[0] = ar[0].substr(1);
                   let version = 0;
                   for (let i = 0; i < ar.length; i++) {
                       version *= 1000;
                       version += ~~ar[i];
                   if (version >= 6000000) return;
               const util = require('util');
               const old_errnoException = util._errnoException;
               util._errnoException = function (err, syscall, original) {
                   if (typeof original === 'string' && original.indexOf(':1012') >= 0) {
                       adapter.log.error('--- ECONNREFUSED ' + original);
                       adapter.log.error(enableConnect1012);
                   return old_errnoException(err, syscall, original);
            const pauseStates = {
               inbound:  'ring',
               lastCall: 'end',
               connect:  'connect'
            function CallMonitor(adapter, devices, phonebook) {
               if (!adapter.config.useCallMonitor) {
                   return;
               adapter.log.debug('starting callmonitor');
               checkPatchForECONNREFUSED(adapter);
               const net = require('net');
               const connections = {};
               let timeout;
               let lastCaller;
               let lastCallee;
               let client;
               devices.root.createNew(CALLMONITOR_NAME + '.toPauseState', {val: '', common: {name: 'On call states', desc: 'State to pause players. values are: ring, connect, end'}});
               function init() {
                   client = new net.Socket();
                   client.on('connect', () =>
                       adapter.log.debug('callmonitor connected'));
                   client.on('error', err => {
                       if (err.errno === 'ECONNREFUSED') {
                           this.close();
                   client.on('close', _hadError => {
                       timeout && clearTimeout(timeout);
                       timeout = setTimeout(() => {
                           timeout = null;
                           init();
                       }, adapter.config.reconnectInterval || 5000);
                   client.on('data', data => {
                       const raw = data.toString();
                       adapter.log.debug('Callmonitor Raw: ' + raw);
                       const array = raw.split(';');
                       const type = array[1];
                       const id = array[2];
                       const timestamp = array[0];
                       let message;
                       //var dev = new devices.CDevice(0, '');
                       //dev.setDevice(CALLMONITOR_NAME, {common: {name: CALLMONITOR_NAME, role: 'channel'}, native: {} });
                       const dev = new devices.CDevice(CALLMONITOR_NAME, '');
                       dev.force = true;
                       let timer = null;
                       function set(name) {
                           //const dev = new devices.CDevice(CALLMONITOR_NAME, '');
                           //dev.force = true;
                           timer && clearTimeout(timer);
                           timer = null;
                           adapter.log.debug('New Call data ' + name + ': ' + JSON.stringify(message));
                           dev.setChannel('', '');
                           dev.set('ringing', name === 'inbound');
                           // var pause = pauseStates[name];
                           // if (pause !== undefined) {
                           //     dev.set('toPauseState', pause);
                           dev.setChannel(name, name);
                           for (const i in message) {
                               if (i[0] !== '_') {
                                   dev.set(i, message[i]);
                           dev.set('timestamp', timestamp);
                           message._type = name;
                           if (adapter.config.usePhonebook && phonebook) {
                               if (lastCaller !== message.caller) {
                                   lastCaller = message.caller;
                               if (!message.callerName && message.caller) {
                                   const pbe = phonebook.byNumber(message.caller);
                                   if (pbe) {
                                       message.callerName = pbe.name;
                                       if (pbe.imageurl) {
                                           message.imageurlcaller = pbe.imageurl;
                                   } else {
                                       message.callerName = '';
                               dev.set('callerName', message.callerName || '');
                               if (lastCallee !== message.callee) {
                                   lastCallee = message.callee;
                               if (!message.calleeName && message.callee) {
                                   const pbee = phonebook.byNumber(message.callee);
                                   if (pbee) {
                                       message.calleeName = pbee.name;
                                       if (pbee.imageurl) message.imageurlcallee = pbee.imageurl;
                                   } else {
                                       message.calleeName = '';
                               dev.set('calleeName', message.calleeName || '');
                           dev.set('json', JSON.stringify(message));
                           const pause = pauseStates[name];
                               message.extension && dev.set('toPauseState-' + message.extension, pause);
                           // soef.getHttpData(message.imageurlcaller, function (err, body, res) {
                           //     res = res;
                           adapter.log.debug('callMonitor.set: type=' + name + ' caller=' + message.caller + ' callee=' + message.callee + (message.callerName ? ' callerName=' + message.callerName : '') + (message.calleeName ? ' calleeName=' + message.calleeName : ''));
                           timer = setTimeout(() => {
                               dev.update();
                               devices.update();
                           }, 500);
                       switch (type) {
                           case 'CALL':
                               message = {caller: array[4], callee: array[5], extension: array[3], timestamp, id};
                               connections[id] = message;
                               set('outbound');
                               break;
                           case 'RING':
                               message = {caller: array[3], callee: array[4], timestamp, id};
                               set('inbound');
                               break;
                           case 'CONNECT':
                               message = connections[id];
                               if (!message) {
                                   break;
                               message.extension = array[3];
                               set('connect');
                               break;
                           case 'DISCONNECT':
                               if (!message) {
                                   break;
                               switch (message._type) {
                                   case 'inbound':
                                       message.type = 'missed';
                                       break;
                                   case 'connect':
                                       message.type = 'disconnect';
                                       break;
                                   case 'outbound':
                                       message.type = 'unreached';
                                       break;
                               message.duration = array[3] >> 0;
                               //set('disconnect');
                               set('lastCall');
                               delete connections[id];
                               break;
                   client.connect({
                       host: adapter.config.ip,
                       port: 1012
                       .on('error', error =>
                           adapter.log.error('Cannot start ' + CALLMONITOR_NAME + ': ' + error));
               this.close = function () {
                   if (client) {
                       try {
                           client.removeAllListeners();
                           client.destroy();
                       } catch (e) {
                       client = null;
                   timeout = null;
               init();
               return this;
            module.exports = CallMonitor;
            • wendy2702
              kannst du mal auf Konsolen ebene schauen ob es den wirklich nur einmal gibt?
              iobroker list adapters
                @wendy2702 gibt nur den einen
                system.adapter.tr-064 : tr-064 - v3.1.4
                  apollon77 @crunchip last edited by
                  @crunchip das links in dem GitHub Link auf der Seite sind die Zeilennummern. Rote sind gelöschte und grüne sind neue. Und es wird immer bissl mehr oben und unten drunter angezeigt. Das sollte reichen um die Stellen im Code zu finden. Alternativ Klick im GitHub oben rechts auf file anzeigen oder so und dort ggf raw. Dann kopierst du halt alles
                    @crunchip heißt das vllt das nach einem scheduled restart das Problem da war und keine Daten mehr ankamen ? Dann wäre wieder debug log interessant ...
                      @apollon77 ok, werd ich testen
                        crunchip Forum Testing Most Active @apollon77 last edited by crunchip
                        @apollon77 der nächtliche Neustart wäre zumindest eine mögliche Fehlerquelle, dachte ja zuerst, das Fritzbox/Telekom aktualisiert hat und das der Grund wäre, aber ja nicht der Fall war.
                        jetzt könnt ich testen
                        • a) gucken, das ich ihn aktuell zum laufen bekomm und nehm den Neustart raus
                        • b) ich lass wie es ist und änder die Datei
                        @apollon77 sagte in tr-064 v3.1.x (Latest Repo) Diskussion:
                        könnte ich machen, falls ich so lange wach bin heute
                          @apollon77 v3.2.0 gerade probiert
                          host.IoBroker	2020-02-21 08:26:54.076	info	Restart adapter system.adapter.tr-064.0 because enabled
                          host.IoBroker	2020-02-21 08:26:54.076	info	instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                          host.IoBroker	2020-02-21 08:26:54.075	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
                          host.IoBroker	2020-02-21 08:26:54.075	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                          host.IoBroker	2020-02-21 08:26:54.075	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                          host.IoBroker	2020-02-21 08:26:54.075	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
                          host.IoBroker	2020-02-21 08:26:54.075	error	Caught by controller[0]: at objects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2491:65)
                          host.IoBroker	2020-02-21 08:26:54.075	error	Caught by controller[0]: at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.tr-064/main.js:115:13)
                          host.IoBroker	2020-02-21 08:26:54.074	error	Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1119:49)
                          host.IoBroker	2020-02-21 08:26:54.074	error	Caught by controller[0]: ReferenceError: secret is not defined
                          tr-064.0	2020-02-21 08:26:53.526	info	(25256) Terminated (NO_ERROR): Without reason
                          tr-064.0	2020-02-21 08:26:53.525	info	(25256) terminating
                          tr-064.0	2020-02-21 08:26:53.495	error	(25256) ReferenceError: secret is not defined at main (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1119:49) at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.tr-064/main.
                          tr-064.0	2020-02-21 08:26:53.494	error	(25256) uncaught exception: secret is not defined
                          tr-064.0	2020-02-21 08:26:53.251	info	(25256) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.19.0
                          host.IoBroker	2020-02-21 08:26:50.119	info	instance system.adapter.tr-064.0 started with pid 25256
                          host.IoBroker	2020-02-21 08:26:49.074	info	Restart adapter system.adapter.tr-064.0 because enabled
                            @crunchip hat ja auch keiner gesagt das GitHub gerade nutzbar ist, oder?! 😉
                              @apollon77 stimmt, wollte es nur testen, da ich durch https://forum.iobroker.net/post/381090 darauf gekommen bin
                              diesbezüglich wollte ich es nur melden, bzw Bescheid geben😘
                              • wendy2702
                                Gestern eine Ansage komplett neu aufgesetzt.
                                TR-064 in Version 3.1.4 installiert, Benutzer auf Fritzbox eingerichtet und Haken gesetzt um TR064 Zugriff zu erlauben.
                                Direkt beim ersten Anruf wurden alle Datenpunkte angelegt und aktualisiert.
                                @crunchip : habe nicht alle Beiträge gelesen aber der Haken für TR064 Zugriff in der Fritzbox ist noch drin?
                                Du könntest mal den Netzwerkverkehr mitschneiden zwischen Fritzbox und iobroker.
                                Entweder hier: http://fritz.box/html/capture.html oder mit Wireshark im Netzwerk schnüffeln um zu sehen wer wann nicht antwortet.
                                  @wendy2702 sagte in tr-064 v3.1.x (Latest Repo) Diskussion:
                                  ja klar, funktioniert ja auch wieder nach einem manuellen Neustart, hab versuchsweise mal den scheduled von 0:01 vorverlegt auf 23:58
                                  mit wireshark kenn ich mich leider nicht aus
                                  • wendy2702
                                    Mach doch mal den Mitschnitt auf der Fritzbox, also Mitschnitt starten, z.b. einen Anruf empfangen, Mitschnitt stoppen und log hier posten.
                                      @wendy2702 ok und was muss ich da anklicken zum mitschneiden?
                                      • wendy2702
                                        Starten für den "ethx" Port an denen dein Iobroker hängt.
                                        Habe mal versucht dein Historie mit dem Problem zu lesen.
                                        Hast du mal versucht alles was mit TR-064 zu tun hat zu löschen und neu zu installieren?
                                        Also Instanz löschen, Adapter löschen, alle Objekte löschen, iobroker bzw. iobroker rechner neu starten, dann Adapter installieren, Instanz erzeugen und konfigurieren?
                                        Was steht bei dir im Adapter drin, "fritz.box" oder die IP ?
                                        Mal zum testen Callmonitor in der Box deaktiviert, Fritzbox neustart, Callmonitor aktiviert ?
                                        crunchip 2 Replies Last reply Reply Quote 0
                                          könnte ich mal versuchen, das artet jedoch dann etwas aus, da ich sämtliche Datenpunkte(Influx/Flot/Grafana)...alles wieder neu anlegen müsste
                                          IP-Adresse ist hinterlegt
                                          das wäre nochmal ne Option
                                            crunchip Forum Testing Most Active @wendy2702 last edited by crunchip
                                            denke, hat damit nichts zu tun, da auch der fritzbox Adapter nicht aktualisiert
                                            .....und täglich grüsst das Murmeltier....😁
                                            • gestern die Option in der Fritzbox de/aktiviert
                                            • Adapter neugestartet, fritzbox.0, sowie tr-64.0.
                                            cronjob hatte ich bei beiden eingestellt, tr-64-- 23:58 und fritzbox--23:59, also bewusst mal vor 0:00
                                            hatte es laufe des Tages mehrfach gestestet, funktionierte den ganzen Tag, jedoch heute morgen wieder nicht,
                                            weder der fritzbox , noch der tr-64 aktualisieren, eingehende und ausgehende Anrufe getestet.
                                            beide Adapter manuell neugestartet und funktioniert wieder alles.
                                            werde den nächtlichen cronjob jetzt mal weglassen und testen ob es morgen aktualisiert.
                                            tr-064
                                            50
                                            295
                                            41296
