    4. Test Adapter TrashSchedule
      sigi234 Forum Testing Most Active @Guest last edited by
      @HeinrichB
      Ich habe 3 Instanzen und man kann einen beliebigen Typ eintragen, muss halt im Kalender vorkommen.
        A Former User @sigi234 last edited by
        @sigi234 Danke, ich war mir nur unsicher und bevor wir einem Phantom nachjagen 🙂
        @Jens-Lattwesen Dann nochmals alles checken und ggf. Instanz mal neustarten
          jwedenig Most Active last edited by
          Hi!
          Seit gestern (js controller update) ist mein Adapter rot.
          Hier das Log:
          host.raspberrypi	2020-01-28 08:31:31.600	error	Cannot download and install adapter "trashschedule@0.0.3". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
          host.raspberrypi	2020-01-28 08:31:31.599	info	iobroker npm-install: exit 1
          host.raspberrypi	2020-01-28 08:31:31.585	info	iobroker npm-install: host.raspberrypi download trashscheduleFile not found: trashschedule
          host.raspberrypi	2020-01-28 08:31:31.583	error	iobroker npm-install: host.raspberrypi Unknown packetName trashschedule
          host.raspberrypi	2020-01-28 08:31:29.441	error	Cannot download and install adapter "trashschedule@0.0.3". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
          host.raspberrypi	2020-01-28 08:31:29.439	info	iobroker npm-install: exit 1
          host.raspberrypi	2020-01-28 08:31:29.406	info	iobroker npm-install: host.raspberrypi download trashscheduleFile not found: trashschedule
          host.raspberrypi	2020-01-28 08:31:29.405	error	iobroker npm-install: host.raspberrypi Unknown packetName trashschedule
          host.raspberrypi	2020-01-28 08:31:29.201	error	Cannot download and install adapter "trashschedule@0.0.3". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
          host.raspberrypi	2020-01-28 08:31:28.169	info	iobroker install trashschedule@0.0.3 using installedVersion
          host.raspberrypi	2020-01-28 08:31:28.169	warn	startInstance cannot find adapter "trashschedule@0.0.3". Try to install it... 4 attempt
          host.raspberrypi	2020-01-28 08:31:28.167	info	iobroker npm-install: exit 1
          host.raspberrypi	2020-01-28 08:31:28.158	info	iobroker npm-install: host.raspberrypi download trashscheduleFile not found: trashschedule
          host.raspberrypi	2020-01-28 08:31:28.150	error	iobroker npm-install: host.raspberrypi Unknown packetName trashschedule
          host.raspberrypi	2020-01-28 08:31:26.225	info	iobroker install trashschedule@0.0.3 using installedVersion
          host.raspberrypi	2020-01-28 08:31:26.224	warn	startInstance cannot find adapter "trashschedule@0.0.3". Try to install it... 3 attempt
          host.raspberrypi	2020-01-28 08:31:25.176	info	iobroker install trashschedule@0.0.3 using installedVersion
          host.raspberrypi	2020-01-28 08:31:25.175	warn	startInstance cannot find adapter "trashschedule@0.0.3". Try to install it... 2 attempt
          host.raspberrypi	2020-01-28 08:31:25.173	info	iobroker npm-install: exit 1
          host.raspberrypi	2020-01-28 08:31:25.166	info	iobroker npm-install: File not found: trashschedule
          host.raspberrypi	2020-01-28 08:31:25.163	info	iobroker npm-install: host.raspberrypi download trashschedule
          host.raspberrypi	2020-01-28 08:31:25.154	error	iobroker npm-install: host.raspberrypi Unknown packetName trashschedule
          host.raspberrypi	2020-01-28 07:31:22.334	info	iobroker install trashschedule@0.0.3 using installedVersion
          host.raspberrypi	2020-01-28 07:31:22.333	warn	startInstance cannot find adapter "trashschedule@0.0.3". Try to install it... 1 attempt
          host.raspberrypi	2020-01-28 07:31:22.330	info	"system.adapter.trashschedule.0" enabled
          Wer eine Idee?
            jwedenig Most Active @jwedenig last edited by
            Habe den Adapter nochmals über Github installiert, jetzt läufts wieder!
              mikiline last edited by
              Hi und Super Adapter. Zu dem Thema mit dem Geburtstag und dem anzuzeigenden Alter mal ein Vorschlag.
              Da man im Kalender eh einen Eintrag machen muss/kann mit z.B. Geburtstag Karin könnte man den doch auch etwas erweitern.
              Und zwar mit dem Geburtsjahr. Das kann man sicher aus dem Text extrahieren "Geburtstag Karin 1989", dann mit dem aktuellen Jahr verrechnen und schon hat man das Alter....
              Grüsse und Danke für die Entwicklung
                Hi!
                Irgendwer eine Idee, warum der Wert bei "Ferien"mir so angezeigt wird?
                Bei allen anderen funktionierts!
                  stockics6 last edited by
                  bei mir stürzt regelmäßig die iCal Instanz, die für den TrashSchedule zuständig ist, immer ab.
                  Weiß jemand woran das liegen kann?
                  Danke!
                  • SBorg
                    SBorg Forum Testing Most Active @stockics6 last edited by
                    @stockics6 Da stürzt nix ab 🙂
                    "Terminated (NO_ERROR): Without reason" ist eine Standardmeldung, dass sich der Dienst ohne Fehler/Grund korrekt beendet hat. iCal (und andere) sind sogenannte "schedulded Adapter" die nicht immer laufen, sondern nur zu einem bestimmten Zeitpunkt gestartet werden und sich dann beenden 😉
                    • Negalein
                      @haus-automatisierung
                      Ist es möglich, die Kommastellen zu entfernen?
                      Im Adapter gibt es keine Möglichkeit dazu.
                      Homoran haus-automatisierung 2 Replies Last reply Reply Quote 0
                        Homoran Global Moderator Administrators @Negalein last edited by
                        @Negalein Mit welchem Widget zeigst du sie an?
                        Da gibt es bestimmt die Möglichkeit
                        Muss natürlich ein Zahlen-Widget sein
                        Nicht wenn du basic string statt basic number nimmst 😉
                        • Negalein
                          Negalein Global Moderator @Homoran last edited by
                          @Homoran sagte in Test Adapter TrashSchedule v0.0.x:
                          Ahhhh, klar hab ich das falsche erwischt.
                          Ist mir nie aufgefallen, da bis zum letzten Update (glaube ich) von Trashschedule nur ganze Zahlen angezeigt wurden.
                          • opossum
                            opossum last edited by opossum
                            Hallo, @sigi234 ,
                            Du zeigst bei Dir in der vIS auch die Ferien an. Leider klappt das bei mir nicht. Ich habe mir aus dem Netz die ics-Datei für die Ferien 2020/2021 für Mecklenburg-Vorpommern heruntergeladen und diese in meinen Google-Kalender importiert. Dann im ical-Adapter testweise die Winterferien eingetragen mit komplettem Wortlaut, trotz dem werden diese Ferien nicht gefunden. Wie hast Du die Ferien eingetragen, ist dort für jeden einzelnen Tag Ferien eingetragen? Vielleicht könntest Du das in groben Zügen mal skizzieren?
                            EDIT: Habe es hinbekommen, im ical war es schon ermittelt, Trashscedule hatte noch nicht den richtigen Suchbegriff.
                            • haus-automatisierung
                              haus-automatisierung Developer Most Active @Negalein last edited by haus-automatisierung
                              @Negalein Die Nachkommastellen sind in der letzten Version raus. Das hatte etwas mit der Umstellung der Uhrzeit auf Sommerzeit zu tun (dadurch war eine Stunde Differenz und eben kein vollständiger Tag mehr).
                                das ist wirklich ein hilfreicher Adapter.
                                Wie benutze ich das Widget? Irgendwie verstehe ich das nicht.
                                  BoehserWolf @haus-automatisierung last edited by
                                  Gibt es Pläne den Adapter ins stable Repo zu schieben?
                                  Die Installation aus github Repo per Katze liefert neben einem unbekannten Zustand von github ja auch keine Aktualisierungsinfo.
                                  • Negalein
                                    Negalein Global Moderator last edited by Negalein
                                    Es gibt jetzt ein Widget vom Trashschedule
                                    https://forum.iobroker.net/topic/22912/vorlagen-ideen-müllplan-view-widget/152
                                      sigi234 Forum Testing Most Active @Guest last edited by sigi234
                                      @telekom0815 sagte in Test Adapter TrashSchedule v0.0.x:
                                      Und ein bisschen CSS
                                      .trashtype .daysleft {
                                          background: transparent !important;
                                          color: #222222 !important;
                                      .trashtype .dumpster {
                                           transform: scale(0.80) !important;
                                      Und Adaptereinstellungen:
                                      Ergebnis:
                                      Widget:
                                      [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"15px","top":"17px","width":"544px","height":"265px","border-width":"1px","border-style":"solid","border-radius":"5px","border-color":"#bfbfbf"},"widgetSet":"basic"},{"tpl":"tplTrashscheduleHelper","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"trashschedule.0.type.json","extraAttr":""},"style":{"left":"26px","top":"31px","width":"520px","height":"241px","z-index":"1","color":"#bdbdbd","font-family":"RobotoCondensed-Light","transform":"","text-align":"","font-size":"medium","line-height":"","border-width":"","border-style":"","border-radius":"","border-color":"","opacity":"","text-shadow":""},"widgetSet":"trashschedule"}]
                                      lobomau 1 Reply Last reply Reply Quote 3
                                      • Meister Mopper
                                        Meister Mopper last edited by
                                        Moinsen,
                                        was läuft denn hier falsch? Passiert das woanders auch?
                                          sigi234 Forum Testing Most Active @Meister Mopper last edited by
                                          @Meister-Mopper sagte in Test Adapter TrashSchedule v0.0.x:
                                          Nö, welche Version hast du?
                                          • Meister Mopper
                                            Meister Mopper @sigi234 last edited by
                                            @sigi234 0.03
                                            1.0k
                                            adapter calendar ical kalender müll trash
                                            185
                                            1434
                                            484318
