    3. Entwicklung
    4. Test Adapter Alarm 0.0.8
    • blauholsten
      blauholsten Developer @sigi234 last edited by
      @sigi234 okay, dann muss ich morgen in Ruhe schauen. Könntest du eventuell nochmal ein kleinen Log Auszug schicken
        sigi234 Forum Testing Most Active @blauholsten last edited by
        @blauholsten sagte in Test Adapter Alarm 0.0.8:
        undefined2020-02-19 22:19:00.094 - debug: alarm.0 (7316) SUBSCRIBTION for: hm-rpc.0.NEQ1826414.1.STATE
        2020-02-19 22:19:00.096 - debug: alarm.0 (7316) SUBSCRIBTION for: hm-rpc.0.NEQ1818500.1.STATE
        2020-02-19 22:19:00.096 - debug: alarm.0 (7316) SUBSCRIBTION for: hm-rpc.0.OEQ0926852.1.STATE
        2020-02-19 22:19:13.960 - info: sayit.0 (16792) saying: C:\Program Files\iobroker\Test\node_modules\iobroker.sayit/gong.mp3
        2020-02-19 22:19:14.970 - info: sayit.0 (16792) saying: Test
        2020-02-19 22:19:16.939 - debug: alarm.0 (7316) system.adapter.admin.0: logging false
        2020-02-19 22:19:20.132 - debug: alarm.0 (7316) system.adapter.admin.0: logging true
        2020-02-19 22:19:25.459 - debug: alarm.0 (7316) state alarm.0.use.toggle changed: false (ack = false)
        2020-02-19 22:19:25.462 - info: alarm.0 (7316) Alarmanlage deaktiviert
        2020-02-19 22:19:25.464 - info: alarm.0 (7316) Alarmanlage deaktiviert
        2020-02-19 22:19:25.472 - debug: alarm.0 (7316) state alarm.0.status.siren changed: false (ack = false)
        2020-02-19 22:19:25.474 - debug: alarm.0 (7316) state alarm.0.status.activated changed: false (ack = false)
        2020-02-19 22:19:25.475 - debug: alarm.0 (7316) state alarm.0.status.deactivated changed: true (ack = false)
        2020-02-19 22:19:25.476 - debug: alarm.0 (7316) state alarm.0.status.activated_with_warnings changed: false (ack = false)
        2020-02-19 22:19:25.477 - debug: alarm.0 (7316) state alarm.0.status.activation_failed changed: false (ack = false)
        2020-02-19 22:19:25.481 - debug: alarm.0 (7316) state alarm.0.status.siren changed: false (ack = false)
        2020-02-19 22:19:25.482 - debug: alarm.0 (7316) state alarm.0.status.burglar_alarm changed: false (ack = false)
        2020-02-19 22:19:25.483 - debug: alarm.0 (7316) state alarm.0.status.activation_failed changed: false (ack = false)
        2020-02-19 22:19:25.486 - debug: alarm.0 (7316) state alarm.0.status.siren changed: false (ack = false)
        2020-02-19 22:19:25.487 - debug: alarm.0 (7316) state alarm.0.status.activated changed: false (ack = false)
        2020-02-19 22:19:25.488 - debug: alarm.0 (7316) state alarm.0.status.deactivated changed: true (ack = false)
        2020-02-19 22:19:25.489 - debug: alarm.0 (7316) state alarm.0.status.activated_with_warnings changed: false (ack = false)
        2020-02-19 22:19:25.490 - debug: alarm.0 (7316) state alarm.0.status.activation_failed changed: false (ack = false)
        2020-02-19 22:19:25.492 - debug: alarm.0 (7316) state alarm.0.status.siren changed: false (ack = false)
        2020-02-19 22:19:25.494 - debug: alarm.0 (7316) state alarm.0.status.burglar_alarm changed: false (ack = false)
        2020-02-19 22:19:25.495 - debug: alarm.0 (7316) state alarm.0.status.activation_failed changed: false (ack = false)
        2020-02-19 22:19:30.875 - debug: alarm.0 (7316) state alarm.0.use.toggle changed: true (ack = false)
        2020-02-19 22:19:30.877 - info: alarm.0 (7316) Alarmanlage aktiviert
        2020-02-19 22:19:30.884 - debug: alarm.0 (7316) state alarm.0.status.activated changed: true (ack = false)
        2020-02-19 22:19:30.886 - debug: alarm.0 (7316) state alarm.0.status.deactivated changed: false (ack = false)
        2020-02-19 22:19:30.888 - debug: alarm.0 (7316) state alarm.0.status.activation_failed changed: false (ack = false)
          @blauholsten
          Wichtig:
          Wenn ein Alarm ausgelöst wir, sollte man diese bestätigen können damit sich die DP's wieder auf false stellen.
          Derzeit bleiben diese auf true, oder habe ich so was übersehen?
          blauholsten 1 Reply Last reply Reply Quote 0
          • blauholsten
            @sigi234 ich weiß nicht genau wie du das meinst, aber sollte die Anlage einen Einbruch erkannt haben, geht die Quittung durch deaktivieren der Anlage.
              sigi234 Forum Testing Most Active @blauholsten last edited by sigi234
              Ok.Grundgerüst steht schon.
              Also mit Blockly funktioniert sowohl Sayit, Alexa, und der Mailversand.
              • Amnesia1211
                Amnesia1211 last edited by
                @blauholsten Sehr cool, dass werde ich mir auch mal anschauen !! Danke für deine Arbeit und Mühe !!!
                • blauholsten
                  @sigi234 In der aktuellen GitHub Version sollte Sayit funktionieren. Es wäre schön wenn du es mal testen könntest
                    Funktioniert. 👍
                    • Fenian
                      Fenian last edited by Fenian
                      @blauholsten
                      Ich habe jetzt auch mal die aktuelle Version von Github installiert
                      Wenn ich die Alarmanlage aktiviere, finde ich das im Log:
                      alarm.0	2020-02-21 00:19:09.365	info	(10660) Terminated (NO_ERROR): Without reason
                      alarm.0	2020-02-21 00:19:09.364	info	(10660) terminating
                      alarm.0	2020-02-21 00:19:09.294	info	(10660) cleaned everything up...
                      alarm.0	2020-02-21 00:19:09.292	error	at processImmediate (timers.js:658:5)
                      alarm.0	2020-02-21 00:19:09.292	error	at tryOnImmediate (timers.js:676:5)
                      alarm.0	2020-02-21 00:19:09.292	error	at runCallback (timers.js:705:18)
                      alarm.0	2020-02-21 00:19:09.292	error	at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                      alarm.0	2020-02-21 00:19:09.292	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.alarm/main.js:81:17)
                      alarm.0	2020-02-21 00:19:09.292	error	at change (/opt/iobroker/node_modules/iobroker.alarm/main.js:293:9)
                      alarm.0	2020-02-21 00:19:09.292	error	at enable (/opt/iobroker/node_modules/iobroker.alarm/main.js:193:9)
                      alarm.0	2020-02-21 00:19:09.292	error	at logging (/opt/iobroker/node_modules/iobroker.alarm/main.js:567:25)
                      alarm.0	2020-02-21 00:19:09.292	error	(10660) TypeError: log_list.split is not a function
                      alarm.0	2020-02-21 00:19:09.290	error	(10660) uncaught exception: log_list.split is not a function
                      alarm.0	2020-02-21 00:19:09.268	info	(10660) Alarmanlage aktiviert
                      alarm.0	2020-02-21 00:19:09.264	debug	(10660) state alarm.0.use.enable changed: true (ack = true)
                      Und wenn ein Alarm ausgelöst wird:
                      alarm.0	2020-02-21 00:58:00.910	info	(12562) Terminated (NO_ERROR): Without reason
                      alarm.0	2020-02-21 00:58:00.909	info	(12562) terminating
                      alarm.0	2020-02-21 00:58:00.784	info	(12562) cleaned everything up...
                      alarm.0	2020-02-21 00:58:00.783	error	(12562) TypeError: log_list.split is not a function at logging (/opt/iobroker/node_modules/iobroker.alarm/main.js:567:25) at change (/opt/iobroker/node_modules/iobroker.alarm/main.js:330:13)
                      alarm.0	2020-02-21 00:58:00.783	error	(12562) uncaught exception: log_list.split is not a function
                      alarm.0	2020-02-21 00:58:00.770	info	(12562) Alarmanlage meldet Einbruch in: Küche links
                      burglar_alarm bleibt 'false', der Alarm wird nicht ausgelöst.
                      Sayit habe ich bisher nicht beachtet, finde dazu allerdings folgendes im Log vom Sayit-Adapter:
                      sayit.0	2020-02-21 00:58:00.946	error	(2637) Cannot get file: received file is too short
                      sayit.0	2020-02-21 00:58:00.872	info	(2637) saying: Verlassen Sie sofort das Haus
                      sayit.0	2020-02-21 00:57:49.877	error	(2637) Cannot get file: received file is too short
                      sayit.0	2020-02-21 00:57:49.773	info	(2637) saying: Alarmanlage aktiviert
                      blauholsten 2 Replies Last reply Reply Quote 0
                      • blauholsten
                        blauholsten Developer @Fenian last edited by
                        @Fenian Hi,
                        sorry ich habe gestern Abend noch weitere Funktionen versucht zu integrieren, musste dann aber abbrechen ohne es zu Testen.
                        Die aktuelle GitHub Version ist also fehlerbehaftet. Ich fixe es die nächsten Stunden.
                        Homer.J. 1 Reply Last reply Reply Quote 0
                        • Homer.J.
                          Homer.J. @blauholsten last edited by
                          Morgen @blauholsten ist es möglich das du auch eine Datenpunkt für eine Innensirene bei Auslösung mit einbauen könntest.
                          Grüße Homer.J.
                          • blauholsten
                            blauholsten Developer @Homer.J. last edited by
                            @Homer-J
                            Für welchen Zweck? Kann mir leider nichts drunter vorstellen....
                            • blauholsten
                              @Fenian die aktuelle GitHub Version sollte lauffähig sein, es wurde der Stille Alarm hinzugefügt. Man kann jetzt quasi eine Verzögerung in der konfigseite einstellen. diese Zeit überbrückt die Zeit bis zur eigentlichen Auslösung, falls nicht deaktiviert wird. Während der Zeit ist der Stille Alarm aktiv.
                              Homer.J. C 2 Replies Last reply Reply Quote 0
                              • Homer.J.
                                @blauholsten hab eine Innensirene die bei internen Alarm auslöst. Wäre schön wenn du genau so einen Datenpunkt wie du als Sirene schon hast mit einbauen könntest.
                                • Fenriswolf
                                  Fenriswolf last edited by
                                  Sieht sehr vielversprechend aus. Bin auch schon fleißig am probieren. Eine gute Anleitung würde ich auch begrüßen. Momenten habe ich noch die Frage, wie genau der Eintrag bei den Benachrichtigungsinstanzen aussehen muss.
                                  Ansonsten erstmal weiter so. !!
                                  • blauholsten
                                    blauholsten Developer @Fenriswolf last edited by
                                    @Fenriswolf sagte in Test Adapter Alarm 0.0.8:
                                    Das ist noch ein kleiner Fehler, man kann Dialog Fenster leider nicht die reine Instanz auswählen, des halb muss man erst irgend einen state von der Instanz auswählen und dann händisch bis.... Z.b. Telegramm.0 löschen.
                                    • blauholsten
                                      blauholsten Developer last edited by
                                      In der aktuellen GitHub Version habe ich dir Benutzung eines Passwortes integriert.
                                      Homer.J. sigi234 2 Replies Last reply Reply Quote 0
                                      • Homer.J.
                                        @blauholsten schon gesehen wie wird es genutzt.
                                          Cool, wann kommt eine neue Version, kann ich jetzt schon updaten?
                                          • blauholsten
                                            @sigi234 sagte in Test Adapter Alarm 0.0.8:
                                            Einfach deinstallieren und dann neu von GitHub installieren. Wichtig ,sichere vorher deine konfigseite.
                                            alarm alarmanlage sicherheit überwachung
                                            17
                                            119
                                            15631
