    4. Test Adapter mihome-vacuum v2.0.x
      smarti2015 last edited by
      Hi, wollte update Installieren von 1.1.5 auf Version 2.x aber es kommt immer eine Fehlermeldung:
      host.All-In-One-Tinker	2020-02-20 12:50:29.060	info	iobroker exit 25
      host.All-In-One-Tinker	2020-02-20 12:50:28.043	error	iobroker host.All-In-One-Tinker Cannot install https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/master: 1
      host.All-In-One-Tinker	2020-02-20 12:50:28.006	info	iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-02-20T11_50_27_975Z-debug.log
      host.All-In-One-Tinker	2020-02-20 12:50:27.955	info	iobroker This is probably not a problem with npm. There is likely additional logging output above.
      host.All-In-One-Tinker	2020-02-20 12:50:27.954	info	iobroker npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR!
      host.All-In-One-Tinker	2020-02-20 12:50:27.953	info	iobroker errno 1npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
      host.All-In-One-Tinker	2020-02-20 12:50:27.951	info	iobroker code ELIFECYCLEnpm ERR!
      host.All-In-One-Tinker	2020-02-20 12:50:27.950	info	iobroker ERR!
      host.All-In-One-Tinker	2020-02-20 12:50:27.949	info	iobroker npm
      host.All-In-One-Tinker	2020-02-20 12:50:25.594	info	iobroker /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.18.1node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
      host.All-In-One-Tinker	2020-02-20 12:50:25.593	info	iobroker ERR! System Linux 4.19.69-rockchipnode-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ER
      host.All-In-One-Tinker	2020-02-20 12:50:25.591	info	iobroker node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modu
      host.All-In-One-Tinker	2020-02-20 12:50:25.587	info	iobroker node-pre-gyp ERR! build error
      host.All-In-One-Tinker	2020-02-20 12:50:25.571	info	iobroker /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.18.1gyp ERR! node-gyp -v v5.0.5gyp ERR! not ok
      host.All-In-One-Tinker	2020-02-20 12:50:25.569	info	iobroker ERR! System Linux 4.19.69-rockchipgyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroke
      host.All-In-One-Tinker	2020-02-20 12:50:25.568	info	iobroker stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:198:13)gyp ERR! stack at Pr
      host.All-In-One-Tinker	2020-02-20 12:50:25.567	info	iobroker gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR!
      host.All-In-One-Tinker	2020-02-20 12:50:25.565	info	iobroker ERR! configure error
      host.All-In-One-Tinker	2020-02-20 12:50:25.564	info	iobroker gyp
      host.All-In-One-Tinker	2020-02-20 12:50:25.529	info	iobroker gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
      host.All-In-One-Tinker	2020-02-20 12:50:25.528	info	iobroker Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' fou
      host.All-In-One-Tinker	2020-02-20 12:50:22.082	info	iobroker node-aead-crypto not needed on this system, since all ciphers are natively supported
      Bild Text
      Patchwork 3001 D 2 Replies Last reply Reply Quote 0
      • Patchwork 3001
        Patchwork 3001 @smarti2015 last edited by Patchwork 3001
        @smarti2015 Wenn der Adapter nicht installiert werden kann, kann Canvas nicht installiert werden
        npm ERR! canvas@2.6.1 install: node-pre-gyp install --fallback-to-build npm ERR! Exit status 1
        Dann müssen folgende Packete und Bibliotheken selber installiert werden:
        " sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev "
        " sudo npm install canvas --unsafe-perm=true "
        über putty ohne "
        K S 2 Replies Last reply Reply Quote 0
        • Meistertr
          Meistertr Developer @blackeagle998 last edited by
          @blackeagle998 dann bräuchte uch einen etwas größeren logauszug
            K_o_bold @Patchwork 3001 last edited by
            @Patchwork-3001, @Meistertr ,
            bei mir läuft Iobroker in einem Docker-Container.
            Wenn Canvas z.T. manuell installiert werden muss, bedeutet das, dass ich es bei jedem Container Neustart wieder manuell installieren muss. ( Oder ich ändere das Docker-Container Image ).
            Wird das bis zur Stable Version so bleiben, dass man ggf. manuell etwas nachinstallieren muss?
            --> Ich bin am überlegen, ob ich jetzt schon umsteige auf die neue Version.
            Bisher was ich so gelesen habe ist sehr vielversprechend, tolle Arbeit an alle Beteiligten.. 👍
              dirkhe Developer @smarti2015 last edited by dirkhe
              @K_o_bold Das Problem ist, dass dies eine Abhängigkeit beim Installieren ist, hat mit dem Adapter selber nichts zu tun. Ich weiss nicht, ob man das optional machen kann, ich vermute mal eher nicht.
                K_o_bold @dirkhe last edited by
                @Meistertr ,
                noch eine andere Frage:
                Mit IOS war die Tokenauslesung ein echter Krampf.
                Außerdem habe ich bei mir die Besonderheit, dass der Roboter in der App nur halblebig integriert ist, da ich das EU Modell gekauft habe aber alle anderen Geräte aus China kommen, habe ich Mainland China im Gateway eingestellt. Dadurch lässt sich der Roboter nicht sauber integrieren, funktioniert aber trotzdem einwandfrei mit dem Iobroker Adapter. Nur die Karte und Zonenreinigung konnte ich nie machen.
                Es wäre also ein echter Mehrwert die neue Version des Adapters. 😀
                Nun zur Frage:
                Die Token Gewinnung geht jetzt wirklich so einfach wie im ersten Post beschrieben?
                Gibt es für das Update aus der Adapterversion 1.1.5 noch Dinge worauf man achten muss?
                  dirkhe Developer @K_o_bold last edited by
                  @K_o_bold Einfach machen, soviel kannst du ja nicht einstellen, was du verlieren könntest.
                    smarti2015 @Patchwork 3001 last edited by
                    @Patchwork-3001 Danke jetzt hat es geklapt. Wo kann ich jetzt eigentlich die Karte im ioBorker abrufen?
                      Coffeelover @smarti2015 last edited by
                      @smarti2015 Die HTML-Karte in einem HTML-Widget (vgl. Anleitung auf Github) oder die GIF in einem IMG Widget.
                        smarti2015 @Coffeelover last edited by
                        @Coffeelover Ah vielen Dank!
                          blackeagle998 @Meistertr last edited by
                          @Meistertr sagte in Test Adapter mihome-vacuum v2.0.x:
                          Sorry für die späte Rückmeldung, ich habe aktuell drei Punkte:
                          1. Mir fehlt der Datenpunkt ResumeRoomClean --> ResumeZoneClean existiert, der funktioniert aber nicht, wenn man RoomClean gestartet hat (momentan nutze ich beides parallel)
                          2. Kann man irgendwo die Queue sehen und löschen?
                            Ich möchte nicht immer, dass er noch anstehende Jobs weiterführt, ggf. möchte ich per Schalter sagen, dass er zurück zur Ladestation soll und alle anstehenden Aufträge "vergisst".
                          3. Anbei ein größerer DEBUG LOG Auszug zu dem Error "TypeError: Cannot read property '0' of undefined":
                          mihome-vacuum.0	2020-02-21 08:58:39.044	debug	(6784) 24694
                          mihome-vacuum.0	2020-02-21 08:58:38.278	debug	(6784) update_Map use old mapurl
                          mihome-vacuum.0	2020-02-21 08:58:38.278	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:58:37.543	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:58:36.727	debug	(6784) requesting params every: 60 Sec
                          mihome-vacuum.0	2020-02-21 08:58:36.277	error	(6784) TypeError: Cannot read property '0' of undefined
                          mihome-vacuum.0	2020-02-21 08:58:35.534	debug	(6784) update_Map use old mapurl
                          mihome-vacuum.0	2020-02-21 08:58:35.533	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:58:34.992	debug	(6784) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1582271914988,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582182216427}
                          mihome-vacuum.0	2020-02-21 08:58:34.222	debug	(6784) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1582271914214,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582182216427}
                          mihome-vacuum.0	2020-02-21 08:58:33.531	error	(6784) TypeError: Cannot read property '0' of undefined
                          mihome-vacuum.0	2020-02-21 08:58:32.834	debug	(6784) update_Map use old mapurl
                          mihome-vacuum.0	2020-02-21 08:58:32.833	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:58:31.224	debug	(6784) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1582271911221,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582182216427}
                          mihome-vacuum.0	2020-02-21 08:58:30.845	debug	(6784) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1582271910430,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582182216427}
                          mihome-vacuum.0	2020-02-21 08:58:30.832	error	(6784) TypeError: Cannot read property '0' of undefined
                          mihome-vacuum.0	2020-02-21 08:58:30.047	debug	(6784) update_Map use old mapurl
                          mihome-vacuum.0	2020-02-21 08:58:30.046	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:58:28.046	error	(6784) TypeError: Cannot read property '0' of undefined
                          mihome-vacuum.0	2020-02-21 08:58:27.325	debug	(6784) update_Map got new time:1582271907
                          mihome-vacuum.0	2020-02-21 08:58:27.325	debug	(6784) update_Map got new expires:1582273707
                          mihome-vacuum.0	2020-02-21 08:58:27.324	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                          mihome-vacuum.0	2020-02-21 08:58:27.237	debug	(6784) update_Map need new mapurl
                          mihome-vacuum.0	2020-02-21 08:58:27.236	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:58:25.234	error	(6784) TypeError: Cannot read property '0' of undefined
                          mihome-vacuum.0	2020-02-21 08:58:24.455	debug	(6784) update_Map got new time:1582271904
                          mihome-vacuum.0	2020-02-21 08:58:24.454	debug	(6784) update_Map got new expires:1582273704
                          mihome-vacuum.0	2020-02-21 08:58:24.453	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                          mihome-vacuum.0	2020-02-21 08:58:24.370	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:58:24.349	debug	(6784) update_Map need new mapurl
                          mihome-vacuum.0	2020-02-21 08:58:24.348	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:58:21.010	debug	(6784) 24674
                          mihome-vacuum.0	2020-02-21 08:58:20.278	debug	(6784) update_Map got new time:1582271900
                          mihome-vacuum.0	2020-02-21 08:58:20.278	debug	(6784) update_Map got new expires:1582273700
                          mihome-vacuum.0	2020-02-21 08:58:20.277	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                          mihome-vacuum.0	2020-02-21 08:58:20.197	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:58:20.187	debug	(6784) update_Map need new mapurl
                          mihome-vacuum.0	2020-02-21 08:58:20.187	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:58:17.425	debug	(6784) 24656
                          mihome-vacuum.0	2020-02-21 08:58:16.674	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:58:16.665	debug	(6784) update_Map use old mapurl
                          mihome-vacuum.0	2020-02-21 08:58:16.665	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:58:15.102	info	(6784) trigger cleaning zone [19720,32832,24549,35282,1]
                          mihome-vacuum.0	2020-02-21 08:58:15.074	debug	(6784) sendTo "cleanZone" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: [19720,32832,24549,35282,1]
                          mihome-vacuum.0	2020-02-21 08:58:15.074	debug	(6784) stateChange mihome-vacuum.0.control.zoneClean {"val":"[19720,32832,24549,35282,1]","ack":false,"ts":1582271895062,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582
                          mihome-vacuum.0	2020-02-21 08:58:15.071	debug	(6784) stateChange mihome-vacuum.0.control.carpet_mode {"val":true,"ack":false,"ts":1582271895062,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582182398690}
                          mihome-vacuum.0	2020-02-21 08:58:15.067	debug	(6784) stateChange mihome-vacuum.0.control.fan_power {"val":104,"ack":false,"ts":1582271895062,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582142142021}
                          mihome-vacuum.0	2020-02-21 08:58:14.665	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:58:13.308	debug	(6784) 24656
                          mihome-vacuum.0	2020-02-21 08:58:12.530	debug	(6784) update_Map use old mapurl
                          mihome-vacuum.0	2020-02-21 08:58:12.529	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:58:09.812	debug	(6784) 24656
                          mihome-vacuum.0	2020-02-21 08:58:09.098	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:58:09.089	debug	(6784) update_Map use old mapurl
                          mihome-vacuum.0	2020-02-21 08:58:09.088	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:58:05.707	debug	(6784) 24661
                          mihome-vacuum.0	2020-02-21 08:58:04.985	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:58:04.975	debug	(6784) update_Map use old mapurl
                          mihome-vacuum.0	2020-02-21 08:58:04.975	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:58:02.250	debug	(6784) 24669
                          mihome-vacuum.0	2020-02-21 08:58:01.515	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:58:01.503	debug	(6784) update_Map use old mapurl
                          mihome-vacuum.0	2020-02-21 08:58:01.503	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:57:58.149	debug	(6784) 24548
                          mihome-vacuum.0	2020-02-21 08:57:57.423	debug	(6784) update_Map got new time:1582271877
                          mihome-vacuum.0	2020-02-21 08:57:57.423	debug	(6784) update_Map got new expires:1582273677
                          mihome-vacuum.0	2020-02-21 08:57:57.422	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                          mihome-vacuum.0	2020-02-21 08:57:57.342	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:57:57.330	debug	(6784) update_Map need new mapurl
                          mihome-vacuum.0	2020-02-21 08:57:57.329	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:57:54.610	debug	(6784) 24570
                          mihome-vacuum.0	2020-02-21 08:57:53.898	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:57:53.888	debug	(6784) update_Map use old mapurl
                          mihome-vacuum.0	2020-02-21 08:57:53.888	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:57:50.514	debug	(6784) 24570
                          mihome-vacuum.0	2020-02-21 08:57:49.815	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:57:49.806	debug	(6784) update_Map use old mapurl
                          mihome-vacuum.0	2020-02-21 08:57:49.806	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:57:47.088	debug	(6784) 24570
                          mihome-vacuum.0	2020-02-21 08:57:46.321	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:57:46.305	debug	(6784) update_Map use old mapurl
                          mihome-vacuum.0	2020-02-21 08:57:46.304	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:57:42.967	debug	(6784) 24663
                          mihome-vacuum.0	2020-02-21 08:57:42.272	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:57:42.262	debug	(6784) update_Map use old mapurl
                          mihome-vacuum.0	2020-02-21 08:57:42.262	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:57:39.525	debug	(6784) 24790
                          mihome-vacuum.0	2020-02-21 08:57:38.795	debug	(6784) update_Map got new time:1582271858
                          mihome-vacuum.0	2020-02-21 08:57:38.795	debug	(6784) update_Map got new expires:1582273658
                          mihome-vacuum.0	2020-02-21 08:57:38.794	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                          mihome-vacuum.0	2020-02-21 08:57:38.739	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:57:38.727	debug	(6784) update_Map need new mapurl
                          mihome-vacuum.0	2020-02-21 08:57:38.727	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:57:37.540	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:57:36.727	debug	(6784) requesting params every: 60 Sec
                          mihome-vacuum.0	2020-02-21 08:57:35.314	debug	(6784) 25095
                          mihome-vacuum.0	2020-02-21 08:57:34.604	debug	(6784) update_Map got new time:1582271854
                          mihome-vacuum.0	2020-02-21 08:57:34.603	debug	(6784) update_Map got new expires:1582273654
                          mihome-vacuum.0	2020-02-21 08:57:34.603	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                          mihome-vacuum.0	2020-02-21 08:57:34.543	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:57:34.533	debug	(6784) update_Map need new mapurl
                          mihome-vacuum.0	2020-02-21 08:57:34.532	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:57:31.806	debug	(6784) 25095
                          mihome-vacuum.0	2020-02-21 08:57:31.095	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:57:31.075	debug	(6784) update_Map use old mapurl
                          mihome-vacuum.0	2020-02-21 08:57:31.075	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:57:27.734	debug	(6784) 25095
                          mihome-vacuum.0	2020-02-21 08:57:27.009	debug	(6784) update_Map use old mapurl
                          mihome-vacuum.0	2020-02-21 08:57:27.008	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:57:27.006	info	(6784) trigger cleaning zone [19720,32832,24549,35282,1]
                          mihome-vacuum.0	2020-02-21 08:57:27.006	debug	(6784) use clean trigger from Queue
                          mihome-vacuum.0	2020-02-21 08:57:25.090	debug	(6784) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1582271845086,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582182857281}
                          mihome-vacuum.0	2020-02-21 08:57:18.680	debug	(6784) 25095
                          mihome-vacuum.0	2020-02-21 08:57:17.892	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:57:17.883	debug	(6784) update_Map use old mapurl
                          mihome-vacuum.0	2020-02-21 08:57:17.883	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:57:15.908	info	(6784) should trigger cleaning zone [19720,32832,24549,35282,1], but is currently active. Add to queue
                          mihome-vacuum.0	2020-02-21 08:57:15.892	debug	(6784) sendTo "cleanZone" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: [19720,32832,24549,35282,1]
                          mihome-vacuum.0	2020-02-21 08:57:15.891	debug	(6784) stateChange mihome-vacuum.0.control.zoneClean {"val":"[19720,32832,24549,35282,1]","ack":false,"ts":1582271834293,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582
                          mihome-vacuum.0	2020-02-21 08:57:15.889	debug	(6784) stateChange mihome-vacuum.0.control.carpet_mode {"val":true,"ack":false,"ts":1582271834293,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582182398690}
                          mihome-vacuum.0	2020-02-21 08:57:15.887	debug	(6784) stateChange mihome-vacuum.0.control.fan_power {"val":104,"ack":false,"ts":1582271834293,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582142142021}
                          mihome-vacuum.0	2020-02-21 08:57:14.513	debug	(6784) 25095
                          mihome-vacuum.0	2020-02-21 08:57:13.636	debug	(6784) update_Map got new time:1582271833
                          mihome-vacuum.0	2020-02-21 08:57:13.635	debug	(6784) update_Map got new expires:1582273633
                          mihome-vacuum.0	2020-02-21 08:57:13.635	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                          mihome-vacuum.0	2020-02-21 08:57:13.554	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:57:13.538	debug	(6784) update_Map need new mapurl
                          mihome-vacuum.0	2020-02-21 08:57:13.538	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:57:10.790	debug	(6784) 25246
                          mihome-vacuum.0	2020-02-21 08:57:10.068	debug	(6784) update_Map got new time:1582271829
                          mihome-vacuum.0	2020-02-21 08:57:10.068	debug	(6784) update_Map got new expires:1582273630
                          mihome-vacuum.0	2020-02-21 08:57:10.067	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                          mihome-vacuum.0	2020-02-21 08:57:10.010	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:57:09.999	debug	(6784) update_Map need new mapurl
                          mihome-vacuum.0	2020-02-21 08:57:09.999	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:57:06.649	debug	(6784) 25261
                          mihome-vacuum.0	2020-02-21 08:57:06.178	debug	(6784) update_Map got new time:1582271826
                          mihome-vacuum.0	2020-02-21 08:57:06.178	debug	(6784) update_Map got new expires:1582273626
                          mihome-vacuum.0	2020-02-21 08:57:06.177	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                          mihome-vacuum.0	2020-02-21 08:57:06.124	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:57:06.114	debug	(6784) update_Map need new mapurl
                          mihome-vacuum.0	2020-02-21 08:57:06.113	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:57:03.391	debug	(6784) 25258
                          mihome-vacuum.0	2020-02-21 08:57:02.917	debug	(6784) update_Map got new time:1582271822
                          mihome-vacuum.0	2020-02-21 08:57:02.916	debug	(6784) update_Map got new expires:1582273622
                          mihome-vacuum.0	2020-02-21 08:57:02.916	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                          mihome-vacuum.0	2020-02-21 08:57:02.859	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:57:02.848	debug	(6784) update_Map need new mapurl
                          mihome-vacuum.0	2020-02-21 08:57:02.847	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:57:02.073	info	(6784) trigger cleaning zone [19720,32832,24549,35282,1]
                          mihome-vacuum.0	2020-02-21 08:57:02.032	debug	(6784) sendTo "cleanZone" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: [19720,32832,24549,35282,1]
                          mihome-vacuum.0	2020-02-21 08:57:02.030	debug	(6784) stateChange mihome-vacuum.0.control.zoneClean {"val":"[19720,32832,24549,35282,1]","ack":false,"ts":1582271822011,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582
                          mihome-vacuum.0	2020-02-21 08:57:02.027	debug	(6784) stateChange mihome-vacuum.0.control.carpet_mode {"val":true,"ack":false,"ts":1582271822011,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582182398690}
                          mihome-vacuum.0	2020-02-21 08:57:02.019	debug	(6784) stateChange mihome-vacuum.0.control.fan_power {"val":104,"ack":false,"ts":1582271822011,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582142142021}
                          mihome-vacuum.0	2020-02-21 08:56:59.520	debug	(6784) 25258
                          mihome-vacuum.0	2020-02-21 08:56:59.079	debug	(6784) update_Map got new time:1582271818
                          mihome-vacuum.0	2020-02-21 08:56:59.079	debug	(6784) update_Map got new expires:1582273619
                          mihome-vacuum.0	2020-02-21 08:56:59.078	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                          mihome-vacuum.0	2020-02-21 08:56:59.005	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:56:58.995	debug	(6784) update_Map need new mapurl
                          mihome-vacuum.0	2020-02-21 08:56:58.995	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:56:56.297	debug	(6784) 25258
                          mihome-vacuum.0	2020-02-21 08:56:55.807	debug	(6784) update_Map got new time:1582271815
                          mihome-vacuum.0	2020-02-21 08:56:55.807	debug	(6784) update_Map got new expires:1582273615
                          mihome-vacuum.0	2020-02-21 08:56:55.806	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                          mihome-vacuum.0	2020-02-21 08:56:55.753	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:56:55.731	debug	(6784) update_Map need new mapurl
                          mihome-vacuum.0	2020-02-21 08:56:55.730	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:56:52.417	debug	(6784) 25258
                          mihome-vacuum.0	2020-02-21 08:56:51.925	debug	(6784) update_Map got new time:1582271811
                          mihome-vacuum.0	2020-02-21 08:56:51.924	debug	(6784) update_Map got new expires:1582273611
                          mihome-vacuum.0	2020-02-21 08:56:51.924	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                          mihome-vacuum.0	2020-02-21 08:56:51.844	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:56:51.834	debug	(6784) update_Map need new mapurl
                          mihome-vacuum.0	2020-02-21 08:56:51.833	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:56:49.081	debug	(6784) 25258
                          mihome-vacuum.0	2020-02-21 08:56:48.632	debug	(6784) update_Map got new time:1582271808
                          mihome-vacuum.0	2020-02-21 08:56:48.631	debug	(6784) update_Map got new expires:1582273608
                          mihome-vacuum.0	2020-02-21 08:56:48.631	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                          mihome-vacuum.0	2020-02-21 08:56:48.598	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:56:48.539	debug	(6784) update_Map need new mapurl
                          mihome-vacuum.0	2020-02-21 08:56:48.538	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:56:45.232	debug	(6784) 25253
                          mihome-vacuum.0	2020-02-21 08:56:44.791	debug	(6784) update_Map got new time:1582271804
                          mihome-vacuum.0	2020-02-21 08:56:44.791	debug	(6784) update_Map got new expires:1582273604
                          mihome-vacuum.0	2020-02-21 08:56:44.790	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                          mihome-vacuum.0	2020-02-21 08:56:44.705	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:56:44.688	debug	(6784) update_Map need new mapurl
                          mihome-vacuum.0	2020-02-21 08:56:44.688	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:56:41.961	debug	(6784) 25234
                          mihome-vacuum.0	2020-02-21 08:56:41.523	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:56:41.511	debug	(6784) update_Map use old mapurl
                          mihome-vacuum.0	2020-02-21 08:56:41.511	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:56:40.350	debug	(6784) get rooms from map data: [19,2,3,22,18,21,16,20,17,7,8]
                          mihome-vacuum.0	2020-02-21 08:56:40.262	debug	(6784) 25234
                          mihome-vacuum.0	2020-02-21 08:56:39.666	debug	(6784) update_Map use old mapurl
                          mihome-vacuum.0	2020-02-21 08:56:39.653	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:56:39.653	debug	(6784) get rooms from map
                          mihome-vacuum.0	2020-02-21 08:56:39.652	debug	(6784) Empty array try to get from Map
                          mihome-vacuum.0	2020-02-21 08:56:38.138	debug	(6784) 25234
                          mihome-vacuum.0	2020-02-21 08:56:37.534	debug	(6784) update_Map got new time:1582271797
                          mihome-vacuum.0	2020-02-21 08:56:37.533	debug	(6784) update_Map got new expires:1582273597
                          mihome-vacuum.0	2020-02-21 08:56:37.533	debug	(6784) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/xxx
                          mihome-vacuum.0	2020-02-21 08:56:37.431	debug	(6784) update_Map need new mapurl
                          mihome-vacuum.0	2020-02-21 08:56:37.431	debug	(6784) update_Map Mimap enabled
                          mihome-vacuum.0	2020-02-21 08:56:37.430	debug	(6784) Mappointer_updated
                          mihome-vacuum.0	2020-02-21 08:56:36.616	debug	(6784) requesting params every: 60 Sec
                          mihome-vacuum.0	2020-02-21 08:56:19.644	debug	(6784) get rooms from map pending...
                          mihome-vacuum.0	2020-02-21 08:56:19.643	debug	(6784) get rooms from map
                          mihome-vacuum.0	2020-02-21 08:56:19.643	debug	(6784) Empty array try to get from Map
                          mihome-vacuum.0	2020-02-21 08:55:59.636	debug	(6784) get rooms from map pending...
                          mihome-vacuum.0	2020-02-21 08:55:59.636	debug	(6784) Empty array try to get from Map
                          mihome-vacuum.0	2020-02-21 08:55:39.629	debug	(6784) get rooms from map pending...
                          mihome-vacuum.0	2020-02-21 08:55:39.628	debug	(6784) Empty array try to get from Map
                          mihome-vacuum.0	2020-02-21 08:55:39.626	info	(6784) create state for carpet_mode
                          mihome-vacuum.0	2020-02-21 08:55:38.961	debug	(6784) Xiaomi Cloud: Login successful
                          mihome-vacuum.0	2020-02-21 08:55:37.154	info	(6784) set nächster Timer: Nicht verfügbar
                          mihome-vacuum.0	2020-02-21 08:55:36.729	info	(6784) create states for water box filter
                          mihome-vacuum.0	2020-02-21 08:55:36.728	info	(6784) create states for water box
                          mihome-vacuum.0	2020-02-21 08:55:36.701	debug	(6784) requesting params every: 60 Sec
                          mihome-vacuum.0	2020-02-21 08:55:36.696	debug	(6784) Connected
                          mihome-vacuum.0	2020-02-21 08:55:36.675	info	(6784) New generation or new fw detected, create new states goto and zoneclean
                          mihome-vacuum.0	2020-02-21 08:55:36.673	info	(6784) extend state mop for State control.fan_power
                          mihome-vacuum.0	2020-02-21 08:55:36.672	info	(6784) change states from State control.fan_power
                          mihome-vacuum.0	2020-02-21 08:55:36.622	debug	(6784) server started on 0.0.0.0:53421
                          mihome-vacuum.0	2020-02-21 08:55:36.599	info	(6784) Cloud control disabled
                          mihome-vacuum.0	2020-02-21 08:55:36.597	info	(6784) Expert mode disabled, states deleted
                          mihome-vacuum.0	2020-02-21 08:55:36.586	debug	(6784) Xiaomi Cloud: Logging in
                          mihome-vacuum.0	2020-02-21 08:55:36.584	debug	(6784) load Map creator... true
                          mihome-vacuum.0	2020-02-21 08:55:36.489	info	(6784) starting. Version 2.0.6 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                          mihome-vacuum.0	2020-02-21 08:55:33.823	debug	(6784) statesDB connected
                          mihome-vacuum.0	2020-02-21 08:55:33.823	debug	(6784) States connected to redis: 127.0.0.1:9000
                          mihome-vacuum.0	2020-02-21 08:55:33.805	debug	(6784) States create System PubSub Client
                          mihome-vacuum.0	2020-02-21 08:55:33.802	debug	(6784) States create User PubSub Client
                          mihome-vacuum.0	2020-02-21 08:55:33.791	debug	(6784) Redis States: Use Redis connection: 127.0.0.1:9000
                          mihome-vacuum.0	2020-02-21 08:55:33.788	debug	(6784) objectDB connected
                          mihome-vacuum.0	2020-02-21 08:55:33.782	debug	(6784) Objects connected to redis: 127.0.0.1:9001
                          mihome-vacuum.0	2020-02-21 08:55:33.763	debug	(6784) Objects client initialize lua scripts
                          mihome-vacuum.0	2020-02-21 08:55:33.763	debug	(6784) Objects create User PubSub Client
                          mihome-vacuum.0	2020-02-21 08:55:33.761	debug	(6784) Objects create System PubSub Client
                          mihome-vacuum.0	2020-02-21 08:55:33.757	debug	(6784) Objects client ready ... initialize now
                          mihome-vacuum.0	2020-02-21 08:55:33.364	debug	(6784) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          Diginix D 2 Replies Last reply Reply Quote 0
                          • Diginix
                            Diginix @blackeagle998 last edited by
                            @blackeagle998 sagte in Test Adapter mihome-vacuum v2.0.x:
                            Bei wem hast du diesen Datenpunkt denn gesehen? Den gibt es doch noch gar nicht.
                            1. Kann man irgendwo die Queue sehen und löschen?
                            Das ist sicher eine sinnvolle Erweiterung. Entweder die Warteschlange wird gelöscht wenn man nach "Pause" auch noch "Go Home" auslöst oder es gäbe noch ein neuen Button mit zB "Cancel all jobs".
                              dirkhe Developer @blackeagle998 last edited by
                              @blackeagle998
                              1. Das ist ein spezieller Befehl, ob es so Was für segment(raum) such gibt, weiß ich nicht. Aber wofür braucht man den eigentlich? Man kann doch Pause und Start machen. Ich hatte immer gedacht, dass es eine Eigenheit der alten Firmware wäre und habe mich damit noch nicht näher beschäftigt
                              2. Wie viel in der queue noch anstehen, siehst du in info.queue. Den beschreibbar zu machen ist nicht so sinnvoll, da könnte man sich eher einen Knopf machen. Oder wir machen es so, wenn man den home Button in ioBroker drückt (bzw. Triggert durch Alexa oder vis), dass dann auch die queue gewettet wird
                                @Diginix
                                @dirkhe
                                zu Thema 1:
                                Den Knopf "ResumeRoomClean" habe ich noch nirgends gesehen, dachte mir aber, dass es Pendant zum ResumeZoneClean geben muss. Wenn ich nämlich in der MiHome APP einen Raum auswähle, dann die Reinigung starte, dann Pause drücke und dann wieder auf reinigen, sagt der Roboter "Resume Room clean".
                                Mache ich das gleiche mit einer Zone sagt der Roboter "Resume Zone clean".
                                --> Es muss also einen Unterschied in der Steuerung geben
                                Die Variante Pause und dann Start war auch mein erster Gedanke, der führt aber nicht dazu, dass der spezielle Raum weiter gereinigt wird, sondern alles (oder irre ich mich? --> teste ich gleich nochmal).
                                zu Thema 2:
                                Die Variante wenn 'mihome-vacuum.0.control.home' gedrückt wird, die Queue zu löschen halte ich für die beste Lösung.
                                Danke für eure schnellen Rückmeldungen.
                                • Diginix
                                  Diginix @dirkhe last edited by
                                  @dirkhe Ich fände ein "Cancel all queued jobs" besser. Das müsste dann zusätzlich auch Pause auslösen.
                                  Mal angenommen er ist im zweiten von 4 geplanten Räumen und mir fällt ein dass er aber nun doch ein SportClean oder noch anderen Raum saugen soll. Dann würde er bei "Home" anfangen in Richtung Station zu fahren. Mit Cancel bliebe er aber genau da stehen wo er ist und kann von dort aus den abweichenden Auftrag anfahren.
                                  In 99% sollte man ja vorher wissen was er machen soll oder man ist gar nicht vor Ort.
                                  Ich habe bisher auch noch nie probiert welche Kombinationen funktionieren und welche nicht.
                                  Mal angenommen ich pausiere eine Raumreinigung bei der noch Räume in der Warteschlange stehen und starte ein SpotClean. Dann würde er wahrscheinlich danach den nächsten Raum aus der Warteschlange anfahren, aber nicht den abgebrochenen fertig saugen.
                                  @blackeagle998 Ich starte meine Raumreinigungen auch immer über multiRoomClean und da müsste Pause > Start dazu führen dass er weiter macht.
                                  D B 3 Replies Last reply Reply Quote 0
                                    dirkhe Developer @Diginix last edited by dirkhe
                                    Wenn er Pause macht, bleibt er stehen. Wenn du dann einen Spot anfahren wolltest, ob das dann geht?
                                      blackeagle998 @Diginix last edited by
                                      @Diginix
                                      Guter Einwand, die Variante "Cancel all Jobs und bleib wo du bist bis du weitere Befehle bekommst" finde ich sehr gut!
                                      Wie startest du denn über multiRoomClean, mir ist noch nicht klar, wie dieser Button funktioniert.
                                      Momentan wähle ich noch bei jedem Raum einzeln den "roomClean" Button.
                                      Man muss doch aber die Raum-Indexe dem multiRoomClean irgendwie per Javascript zuweisen können oder wie machst du das?
                                        @blackeagle998 vergiss den multiclean, den have ich eingebaut, als es noch keine queue gab. Einfach alle räume antriggern oder einen Timer erstellen, denen ggf. Auf inaktiv setzt und den dann per "jetzt starten" antriggern
                                        B Diginix 2 Replies Last reply Reply Quote 0
                                          blackeagle998 @Diginix last edited by blackeagle998
                                          @Diginix
                                          @dirkhe
                                          Wenn ich vorher nur einen oder einige Räume gewählt hatte, dann Pause mache und dann Start drücke, führt das nicht dazu, dass er die vorherige Raumreinigung fortsetzt, sondern dazu, dass er alles reinigen will, er wählt dann nämlich die gesamte Karte aus.
                                            blackeagle998 @dirkhe last edited by
                                            @dirkhe sagte in Test Adapter mihome-vacuum v2.0.x:
                                            Alles klar, Danke 👍
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            490950
