[gelöst] Stromzähler B+G SDM630:Modbus RS 485/USB + mqtt ?
@panki2 sagte in Stromzähler B+G E-Tech SDM630Modbus V2 via RS 485 /USB ?:
address 48
Lösche mal das Register mit Adresse 48 und zeige dann mal das log.
@wendy2702 jetzt sind alle holding Register im iobroker "leer", also keine Einträge.
Hast Du das so gemeint?
2020-02-21 21:14:23.169 - info: host.raspberrypi instance system.adapter.modbus.0 started with pid 8483
2020-02-21 21:14:24.769 - debug: modbus.0 (8483) Redis Objects: Use Redis connection: 127.0.0.1:9001
2020-02-21 21:14:24.834 - debug: modbus.0 (8483) Objects client ready ... initialize now
2020-02-21 21:14:24.843 - debug: modbus.0 (8483) Objects create System PubSub Client
2020-02-21 21:14:24.845 - debug: modbus.0 (8483) Objects create User PubSub Client
2020-02-21 21:14:24.847 - debug: modbus.0 (8483) Objects client initialize lua scripts
2020-02-21 21:14:24.867 - debug: modbus.0 (8483) Objects connected to redis: 127.0.0.1:9001
2020-02-21 21:14:24.892 - debug: modbus.0 (8483) objectDB connected
2020-02-21 21:14:24.897 - debug: modbus.0 (8483) Redis States: Use Redis connection: 127.0.0.1:9000
2020-02-21 21:14:24.909 - debug: modbus.0 (8483) States create User PubSub Client
2020-02-21 21:14:24.914 - debug: modbus.0 (8483) States create System PubSub Client
2020-02-21 21:14:24.926 - debug: modbus.0 (8483) States connected to redis: 127.0.0.1:9000
2020-02-21 21:14:24.928 - debug: modbus.0 (8483) statesDB connected
2020-02-21 21:14:25.302 - info: sql.0 (1474) enabled logging of modbus.0.info.connection, Alias=false
2020-02-21 21:14:25.343 - info: modbus.0 (8483) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.modbus, node: v10.18.1
2020-02-21 21:14:25.585 - info: sql.0 (1474) disabled logging of modbus.0.info.pollTime
2020-02-21 21:14:26.044 - debug: modbus.0 (8483) connect to serial /dev/ttyUSB0 with 9600
2020-02-21 21:14:26.065 - info: modbus.0 (8483) Connected to slave
2020-02-21 21:14:26.070 - info: modbus.0 (8483) Disconnected from slave
2020-02-21 21:14:26.077 - debug: modbus.0 (8483) Cleaning up request fifo. -
Nö,
Du sollst einen Eintrag drin lassen.
Laut einem deiner Post gibt es ja die Adresse 30001, oder?
Teste mit der.
@wendy2702 Sorry
jetzt stehht wieder die Adresse 30001 drinErgebnis
2020-02-21 21:29:38.277 - debug: modbus.0 (9908) States create System PubSub Client
2020-02-21 21:29:38.290 - debug: modbus.0 (9908) States connected to redis: 127.0.0.1:9000
2020-02-21 21:29:38.292 - debug: modbus.0 (9908) statesDB connected
2020-02-21 21:29:38.597 - info: sql.0 (1474) enabled logging of modbus.0.info.connection, Alias=false
2020-02-21 21:29:38.635 - info: modbus.0 (9908) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.modbus, node: v10.18.1
2020-02-21 21:29:38.922 - info: sql.0 (1474) disabled logging of modbus.0.info.pollTime
2020-02-21 21:29:39.475 - debug: modbus.0 (9908) connect to serial /dev/ttyUSB0 with 9600
2020-02-21 21:29:39.493 - info: modbus.0 (9908) Connected to slave
2020-02-21 21:29:39.496 - debug: modbus.0 (9908) Poll device 1
2020-02-21 21:29:39.500 - debug: modbus.0 (9908) Poll holdingRegs DevID(1) address 30001 - 2 bytes
2020-02-21 21:29:39.534 - error: modbus.0 (9908) Wrong CRC for frame: 0,1,3,4,0,0,0,0
2020-02-21 21:29:44.508 - warn: modbus.0 (9908) Error: undefined
2020-02-21 21:29:44.509 - error: modbus.0 (9908) Request timed out.
2020-02-21 21:29:44.512 - warn: modbus.0 (9908) Poll error count: 1 code: {"err":"timeout"}
2020-02-21 21:29:45.513 - info: modbus.0 (9908) Disconnected from slave
2020-02-21 21:29:45.521 - debug: modbus.0 (9908) Clearing timeout of the current request.
2020-02-21 21:29:45.523 - debug: modbus.0 (9908) Cleaning up request fifo. -
Ich denke „Float Big Endian“ ist nicht richtig.
Da solltest du mal von oben nach unten durch probieren. Ich weiß das es lästig ist aber wenn es nicht in der Anleitung steht und es im Netzt keine weitere Info gibt wird wohl kein weg daran vorbei führen.
Ich fange damit leider nicht viel an:
Vielleicht hilft es einem FAchmann weiter
modbus protokoll SDM630V2
https://bg-etech.de/download/manual/SDM630Register1-5.pdf -
@wendy2702 said in Stromzähler B+G E-Tech SDM630Modbus V2 via RS 485 /USB ?:
Was schreibe ich bei Faktor, Länge und Offset rein?
Faktor und Offset sind erstmal uninteressant.
Länge 1 oder 2 ohne in das PDF geschaut zu haben.
Ist je nach Einstellung (Float, Signed. Etc) aber eh fest gelegt.
Ich habe jetzt alle float, endian von oben nach unten usw durch.
..geändert,
grüner Haken und
Speichern und dann in putty geschaut. immer wrong CRC.... -
Float Big Endian mal mit Länge 2 versucht?
Bin nur am IPad und kann selber nicht schauen bei mir.
Ja, Länge 2
Value ist richtig bei "Rolle"? -
Value passt.
Hast du auch Float BIG Endian Byte und Word Swap probiert?
Ich habe alle von oben nach unten durchexerziert...
aber auf Länge usw nicht geachtet -
@panki2 ich schaue mal ins PDF...
Nur leider heute nicht mehr.
@wendy2702
Ok, lieb von Dir. Ist egal, es kommt da uf einen Tag nicht drauf an.
Ich spiel dann mal mit den anderen adaptern rum. Wetterstation, google home usw. Da tut wenigstens etwas..
Also vielen DAnk für Deine Mühe bisher... -
Hier https://wiki.volkszaehler.org/hardware/channels/meters/power/eastron_sdm630_modbus
Gibt es noch einen Hinweis zum BUS. Pull UP/Down und Abschluß erforderlich.
Auch sind die Anschlüsse wohl verdreht.
Hier mal lesen und scrollen. Steht auch mit Bild etwas bezüglich BUS Anbindung:
Die Abschlusswiderstände habe ich, die pullup and down nicht, da auf youtube andere User mit dem SDM 630 nur mit Abschlusswiderständen mit normalen Klingeldraht erfolgreich waren..
Ich lese mir das nochmal durch. Kabel hatte ich schon vertauscht (Anschlüsse) -
Hier How To wie ich das gemacht habe:
- Das hier Runterladen :
https://github.com/letscontrolit/ESPEasy/releases/download/mega-20200204/ESPEasy_mega-20200204.zip
Entpacken
Markierte Datei auf ESP flashen
MQTT Broker in IoBroker installieren.
ESPEasy Einstellungen:
@panki2 said in Stromzähler B+G E-Tech SDM630Modbus V2 via RS 485 /USB ?:
Bei mir kommt nur CRC fehler bei A zu A und B zu B. Wenn ich vertausche, so wie bechriben, kommt überhaupt keine Antwort.
@panki2 hast du mal geschaut ob dann in den Objekten ein Wert steht?
Hast du da auch beim CRC Fehler mal geschaut ?
