    4. Test Adapter rtspStream v0.0.x GitHub
      el_malto @tob1 last edited by
      @tob1 ich benutze das "basic - image" widget und da wird bei mir kein Scrollbalken angezeigt. Da kann ich das einfach so schieben wie ich will.
      tob1 1 Reply Last reply Reply Quote 0
      • tob1
        tob1 @el_malto last edited by
        @el_malto
        wenn ich dort die IP Adresse des generierten Streams eingebe, dann wird mir leider kein Bild angezeigt.
          @tob1 hmm das ist doof. Bei mir klappt es so.
            Kuddel @el_malto last edited by
            @el_malto magst du von deinem Widget mal einen xport zur Verfügung stellen ?
              el_malto @Kuddel last edited by
              @Kuddel wie gesagt, ist das standard "basic - image" Widget.
              [{"tpl":"tplImage","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"http://192.168.0.20:8080/mjpegfeed?oid=1&size=1280x720"},"style":{"left":"609px","top":"0px","width":"415px","height":"233px"},"widgetSet":"basic"}]
                @el_malto also der Link, den du im Widget verwendest funktioniert.
                Das Widget selber zeigt leider nichts an.
                  @Kuddel der Link? Das ist der Link von meiner Cam bzw. der Link von iSpy. Wäre ja Zufall wenn du auch iSpy und die gleiche IP benutzt...🤷‍♂️
                    @el_malto ich habe die IP und den Port auf die Adresse vom RTSP Adapter geändert
                      @Kuddel achso. Dann liegt es wohl auch daran welches Programm den Stream erzeugt.
                        Hat schon jemand eine Lösung, wie man den Stream vernünftig ohne Scroll-Balken einbinden kann ?
                        Stream = http://192.168.4.31:8086/
                          daniel_iobroker last edited by
                          Hab mir heute auch den Adapter installiert. Zuerst natürlich noch das "ffmpeg"
                          Das ganze am Raspi 4.
                          Habe dann meinen rtsp link eingetragen (inkl. Username / Passwort). Der Adapter gibt auch keinen Fehler aus.
                          Wenn ich aber dann meinen Stream mit der IoBroker IP + Port aufrufen will, kommt nur ein Seiten-Ladefehler
                          Hab ich hier noch was falsch eingestellt? Der rtsp Link funktioniert zumindest im VLC Player ohne Probleme
                          Hier die Einstellungen vom Adapter:
                          Hier das log, nach einem Neustart vom Adapter:
                            skokarl @daniel_iobroker last edited by
                            @daniel_iobroker
                            Du kannst keinen RTSP Stream mit User/Pass im Browser ausgeben, lässt der Browser nicht zu.
                            VLC ist ja ein Programm, da sieht das anders aus.
                            Der RTSP Stream muss umgewandelt werden, z.b. mit MotionEye
                            D werner2000x 2 Replies Last reply Reply Quote 0
                              daniel_iobroker @skokarl last edited by
                              @skokarl
                              Das war mir bewusst, dass der Browser User/Pass nicht mehr unterstützt. Ich dachte aber, dass genau dafür der Adapter da ist? Das der Adapter quasi den Stream mit User/Pass von der CAM abholt und dann ohne Authentifizierung weitergibt.
                              Den umgewandelten Stream kann ich ja sowieso in der VIS nutzen. Geht bei mir zumindest ohne Probleme. Egal ob mit MotionEye oder Zoneminder.
                              dbweb 1 Reply Last reply Reply Quote 0
                              • dbweb
                                dbweb @daniel_iobroker last edited by
                                @daniel_iobroker Wie hast du dies dann im Browser aufgerufen?
                                Du musst die Adresse mit Port 8087 aufrufen, also z.B.
                                http://192.168.1.1:8087/
                                  daniel_iobroker @dbweb last edited by
                                  @dbweb
                                  Richtig. Genau so habe ich die Adresse im Browser aufgerufen. Natürlich mit meiner IP und meinem eingestellten Port
                                    Balu0127 last edited by
                                    Hallo
                                    Kann man den Adpater rtsp auch installieren wenn man Windows nutzt?
                                    • JackDaniel
                                      JackDaniel last edited by
                                      wie bekomme ich diesen adapter nun wieder sauber deinstalliert?
                                      • dbweb
                                        dbweb @Balu0127 last edited by
                                        @Balu0127 Leider nicht, ffmpeg kann da nicht so benutzt werden.
                                        @JackDaniel Das schaut für mich nicht aus, als ob diese Meldung wegen dem Adapter kommt, ich würde ioBroker mal sauber neu starten und dann nochmals probieren.
                                        • JackDaniel
                                          JackDaniel last edited by JackDaniel
                                          hmm ja das war auch mein erster gedanke, brachte nur nichts 😞
                                          auch ein sudo rm -r /opt/iobroker/node_modules/iobroker.rtspStream bringt nicht wirklich etwas, da nach einem restart alles wieder da ist!
                                          Bin für jede Hilfe dankbar wie ich das wieder los werde.
                                          • Endurance
                                            Endurance last edited by
                                            @dbweb
                                            Hab nun auch ein bisschen rumgetestet, inkl. reinstall ffmpeg usw.
                                            Mehr bring ich aktuell, egal mit welchen Settings auch nicht hin:
                                            Noch irgendwelche Ideen / Ansätze?
                                            31.7k
                                            79.8k
                                            rtsp stream
                                            36
                                            157
                                            18651
