    4. Test Adapter mihome-vacuum v2.0.x
      dirkhe Developer @blackeagle998 last edited by dirkhe
      @blackeagle998 du kannst ja testweise mal resume_zoned_clean für Zone und resume_segment_clean für Räume via xsendcommand senden.
      Hast zufällig debug Log an und kannst das mal Posten?
      Aber du hast Start im adapter gedrückt, oder?
        blackeagle998 @dirkhe last edited by
        @dirkhe
        Kannst du mir mal bitte sagen, wie das mit dem xsendcommand geht? So tief stecke ich da nicht drin, bisher triggere ich ja nur vorhandene States via Javascript.
        Hier ein DEBUG LOG Auszug (inkl. dem TypeError):
        mihome-vacuum.0	2020-02-24 14:12:36.291	error	(29719) TypeError: Cannot read property '0' of undefined
        mihome-vacuum.0	2020-02-24 14:12:35.873	debug	(29719) update_Map use old mapurl
        mihome-vacuum.0	2020-02-24 14:12:35.873	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:12:33.870	error	(29719) TypeError: Cannot read property '0' of undefined
        mihome-vacuum.0	2020-02-24 14:12:33.412	debug	(29719) update_Map use old mapurl
        mihome-vacuum.0	2020-02-24 14:12:33.412	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:12:31.410	error	(29719) TypeError: Cannot read property '0' of undefined
        mihome-vacuum.0	2020-02-24 14:12:30.997	debug	(29719) update_Map use old mapurl
        mihome-vacuum.0	2020-02-24 14:12:30.997	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:12:28.994	error	(29719) TypeError: Cannot read property '0' of undefined
        mihome-vacuum.0	2020-02-24 14:12:28.509	debug	(29719) update_Map use old mapurl
        mihome-vacuum.0	2020-02-24 14:12:28.508	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:12:27.752	debug	(29719) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1582549947749,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1582182216427}
        mihome-vacuum.0	2020-02-24 14:12:26.507	error	(29719) TypeError: Cannot read property '0' of undefined
        mihome-vacuum.0	2020-02-24 14:12:26.091	debug	(29719) update_Map use old mapurl
        mihome-vacuum.0	2020-02-24 14:12:26.090	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:12:24.088	error	(29719) TypeError: Cannot read property '0' of undefined
        mihome-vacuum.0	2020-02-24 14:12:23.657	debug	(29719) update_Map use old mapurl
        mihome-vacuum.0	2020-02-24 14:12:23.656	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:12:16.194	debug	(29719) stateChange mihome-vacuum.0.control.fan_power {"val":104,"ack":false,"ts":1582549936189,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1582142142021}
        mihome-vacuum.0	2020-02-24 14:12:16.184	info	(29719) trigger cleaning segment 17
        mihome-vacuum.0	2020-02-24 14:12:16.178	debug	(29719) sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: 17
        mihome-vacuum.0	2020-02-24 14:12:16.176	debug	(29719) stateChange mihome-vacuum.0.rooms.room17.roomClean {"val":true,"ack":false,"ts":1582549936173,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1582195312287}
        mihome-vacuum.0	2020-02-24 14:12:16.044	error	(29719) TypeError: Cannot read property '0' of undefined
        mihome-vacuum.0	2020-02-24 14:12:15.620	debug	(29719) update_Map use old mapurl
        mihome-vacuum.0	2020-02-24 14:12:15.620	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:12:13.619	error	(29719) TypeError: Cannot read property '0' of undefined
        mihome-vacuum.0	2020-02-24 14:12:13.156	debug	(29719) update_Map use old mapurl
        mihome-vacuum.0	2020-02-24 14:12:13.155	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:12:11.226	debug	(29719) stateChange mihome-vacuum.0.control.fan_power {"val":104,"ack":false,"ts":1582549931222,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1582142142021}
        mihome-vacuum.0	2020-02-24 14:12:11.174	info	(29719) should trigger cleaning segment 17, but is currently active. Add to queue
        mihome-vacuum.0	2020-02-24 14:12:11.171	debug	(29719) sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: 17
        mihome-vacuum.0	2020-02-24 14:12:11.169	debug	(29719) stateChange mihome-vacuum.0.rooms.room17.roomClean {"val":true,"ack":false,"ts":1582549930933,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1582195312287}
        mihome-vacuum.0	2020-02-24 14:12:11.154	error	(29719) TypeError: Cannot read property '0' of undefined
        mihome-vacuum.0	2020-02-24 14:12:10.725	debug	(29719) update_Map use old mapurl
        mihome-vacuum.0	2020-02-24 14:12:10.725	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:12:08.724	error	(29719) TypeError: Cannot read property '0' of undefined
        mihome-vacuum.0	2020-02-24 14:12:08.259	debug	(29719) update_Map use old mapurl
        mihome-vacuum.0	2020-02-24 14:12:08.258	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:12:06.275	debug	(29719) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1582549926263,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1582182216427}
        mihome-vacuum.0	2020-02-24 14:12:06.256	error	(29719) TypeError: Cannot read property '0' of undefined
        mihome-vacuum.0	2020-02-24 14:12:05.828	debug	(29719) update_Map use old mapurl
        mihome-vacuum.0	2020-02-24 14:12:05.827	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:12:03.825	error	(29719) TypeError: Cannot read property '0' of undefined
        mihome-vacuum.0	2020-02-24 14:12:03.397	debug	(29719) update_Map use old mapurl
        mihome-vacuum.0	2020-02-24 14:12:03.396	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:12:01.394	error	(29719) TypeError: Cannot read property '0' of undefined
        mihome-vacuum.0	2020-02-24 14:12:00.962	debug	(29719) update_Map use old mapurl
        mihome-vacuum.0	2020-02-24 14:12:00.961	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:11:58.960	error	(29719) TypeError: Cannot read property '0' of undefined
        mihome-vacuum.0	2020-02-24 14:11:58.455	debug	(29719) update_Map got new time:1582549918
        mihome-vacuum.0	2020-02-24 14:11:58.455	debug	(29719) update_Map got new expires:1582551718
        mihome-vacuum.0	2020-02-24 14:11:58.454	debug	(29719) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/74488275/1?Expires=1582551718000&GalaxyAccessKeyId=5271733786445&Signature=43Mqj3JDz3cTKaNgyU86A6Citqc=
        mihome-vacuum.0	2020-02-24 14:11:58.387	debug	(29719) update_Map need new mapurl
        mihome-vacuum.0	2020-02-24 14:11:58.386	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:11:56.385	error	(29719) TypeError: Cannot read property '0' of undefined
        mihome-vacuum.0	2020-02-24 14:11:55.891	debug	(29719) update_Map got new time:1582549915
        mihome-vacuum.0	2020-02-24 14:11:55.890	debug	(29719) update_Map got new expires:1582551715
        mihome-vacuum.0	2020-02-24 14:11:55.890	debug	(29719) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/74488275/0?Expires=1582551715000&GalaxyAccessKeyId=5271733786445&Signature=xOW4TY3DmfbxwdWgtAPvj1KTS20=
        mihome-vacuum.0	2020-02-24 14:11:55.804	debug	(29719) Mappointer_updated
        mihome-vacuum.0	2020-02-24 14:11:55.792	debug	(29719) update_Map need new mapurl
        mihome-vacuum.0	2020-02-24 14:11:55.791	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:11:55.279	debug	(29719) Mappointer_updated
        mihome-vacuum.0	2020-02-24 14:11:55.266	debug	(29719) Mappointer_nomap___retry
        mihome-vacuum.0	2020-02-24 14:11:54.757	debug	(29719) Mappointer_nomap___retry
        mihome-vacuum.0	2020-02-24 14:11:53.691	debug	(29719) 25600
        mihome-vacuum.0	2020-02-24 14:11:53.589	debug	(29719) update_Map got new time:1582549913
        mihome-vacuum.0	2020-02-24 14:11:53.588	debug	(29719) update_Map got new expires:1582551713
        mihome-vacuum.0	2020-02-24 14:11:53.588	debug	(29719) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/74488275/17?Expires=1582551713000&GalaxyAccessKeyId=5271733786445&Signature=llwYzttUU3szZY+oJ4i4nCotXBI=
        mihome-vacuum.0	2020-02-24 14:11:53.484	debug	(29719) update_Map need new mapurl
        mihome-vacuum.0	2020-02-24 14:11:53.484	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:11:53.443	debug	(29719) requesting params every: 60 Sec
        mihome-vacuum.0	2020-02-24 14:11:50.849	debug	(29719) stateChange mihome-vacuum.0.control.fan_power {"val":104,"ack":false,"ts":1582549910844,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1582142142021}
        mihome-vacuum.0	2020-02-24 14:11:50.840	info	(29719) trigger cleaning segment 17
        mihome-vacuum.0	2020-02-24 14:11:50.836	debug	(29719) sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: 17
        mihome-vacuum.0	2020-02-24 14:11:50.833	debug	(29719) stateChange mihome-vacuum.0.rooms.room17.roomClean {"val":true,"ack":false,"ts":1582549910830,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1582195312287}
        mihome-vacuum.0	2020-02-24 14:10:55.879	debug	(29719) Mappointer_updated
        mihome-vacuum.0	2020-02-24 14:10:55.871	debug	(29719) Mappointer_nomap___retry
        mihome-vacuum.0	2020-02-24 14:10:53.443	debug	(29719) requesting params every: 60 Sec
        mihome-vacuum.0	2020-02-24 14:10:31.600	debug	(29719) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1582549831597,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1582182216427}
        mihome-vacuum.0	2020-02-24 14:10:23.257	debug	(29719) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1582549823254,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1582271390689}
        mihome-vacuum.0	2020-02-24 14:10:15.170	debug	(29719) 25240
        mihome-vacuum.0	2020-02-24 14:10:14.741	debug	(29719) update_Map got new time:1582549814
        mihome-vacuum.0	2020-02-24 14:10:14.741	debug	(29719) update_Map got new expires:1582551614
        mihome-vacuum.0	2020-02-24 14:10:14.740	debug	(29719) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/74488275/14?Expires=1582551614000&GalaxyAccessKeyId=5271733786445&Signature=JIiXrz8t78N580S1EoaHcYwl9VI=
        mihome-vacuum.0	2020-02-24 14:10:14.684	debug	(29719) Mappointer_updated
        mihome-vacuum.0	2020-02-24 14:10:14.674	debug	(29719) update_Map need new mapurl
        mihome-vacuum.0	2020-02-24 14:10:14.674	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:10:12.677	debug	(29719) stateChange mihome-vacuum.0.control.resumeZoneClean {"val":true,"ack":false,"ts":1582549812001,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1582196233822}
        mihome-vacuum.0	2020-02-24 14:10:11.979	debug	(29719) 25240
        mihome-vacuum.0	2020-02-24 14:10:11.542	debug	(29719) update_Map got new time:1582549811
        mihome-vacuum.0	2020-02-24 14:10:11.542	debug	(29719) update_Map got new expires:1582551611
        mihome-vacuum.0	2020-02-24 14:10:11.541	debug	(29719) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/74488275/13?Expires=1582551611000&GalaxyAccessKeyId=5271733786445&Signature=f4iaa0GmE/+TYVETX4xODv8W9r8=
        mihome-vacuum.0	2020-02-24 14:10:11.486	debug	(29719) Mappointer_updated
        mihome-vacuum.0	2020-02-24 14:10:11.475	debug	(29719) update_Map need new mapurl
        mihome-vacuum.0	2020-02-24 14:10:11.474	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:10:08.154	debug	(29719) 25274
        mihome-vacuum.0	2020-02-24 14:10:07.676	debug	(29719) update_Map got new time:1582549807
        mihome-vacuum.0	2020-02-24 14:10:07.675	debug	(29719) update_Map got new expires:1582551607
        mihome-vacuum.0	2020-02-24 14:10:07.675	debug	(29719) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/74488275/12?Expires=1582551607000&GalaxyAccessKeyId=5271733786445&Signature=GEsiSAJkypn6xAFtSG+ZLNOUCVY=
        mihome-vacuum.0	2020-02-24 14:10:07.594	debug	(29719) Mappointer_updated
        mihome-vacuum.0	2020-02-24 14:10:07.582	debug	(29719) update_Map need new mapurl
        mihome-vacuum.0	2020-02-24 14:10:07.582	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:10:04.873	debug	(29719) 25356
        mihome-vacuum.0	2020-02-24 14:10:04.435	debug	(29719) update_Map got new time:1582549804
        mihome-vacuum.0	2020-02-24 14:10:04.434	debug	(29719) update_Map got new expires:1582551604
        mihome-vacuum.0	2020-02-24 14:10:04.434	debug	(29719) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/74488275/11?Expires=1582551604000&GalaxyAccessKeyId=5271733786445&Signature=qFzgiYHZd/S7uE+JrtIOCG8W6+0=
        mihome-vacuum.0	2020-02-24 14:10:04.384	debug	(29719) Mappointer_updated
        mihome-vacuum.0	2020-02-24 14:10:04.373	debug	(29719) update_Map need new mapurl
        mihome-vacuum.0	2020-02-24 14:10:04.373	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:10:03.540	debug	(29719) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1582549803536,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582182216427}
        mihome-vacuum.0	2020-02-24 14:10:02.752	debug	(29719) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1582549802746,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582182216427}
        mihome-vacuum.0	2020-02-24 14:10:01.066	debug	(29719) 25375
        mihome-vacuum.0	2020-02-24 14:10:00.624	debug	(29719) update_Map got new time:1582549800
        mihome-vacuum.0	2020-02-24 14:10:00.624	debug	(29719) update_Map got new expires:1582551600
        mihome-vacuum.0	2020-02-24 14:10:00.624	debug	(29719) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/74488275/10?Expires=1582551600000&GalaxyAccessKeyId=5271733786445&Signature=LK5KTkw3/FZqoL2/ri4+Zk+kk6I=
        mihome-vacuum.0	2020-02-24 14:10:00.555	debug	(29719) Mappointer_updated
        mihome-vacuum.0	2020-02-24 14:10:00.540	debug	(29719) update_Map need new mapurl
        mihome-vacuum.0	2020-02-24 14:10:00.540	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:09:57.847	debug	(29719) 25375
        mihome-vacuum.0	2020-02-24 14:09:57.345	debug	(29719) update_Map got new time:1582549797
        mihome-vacuum.0	2020-02-24 14:09:57.344	debug	(29719) update_Map got new expires:1582551597
        mihome-vacuum.0	2020-02-24 14:09:57.344	debug	(29719) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/74488275/9?Expires=1582551597000&GalaxyAccessKeyId=5271733786445&Signature=o2E+CNIiNUi1FDnf729lHBXi2fA=
        mihome-vacuum.0	2020-02-24 14:09:57.282	debug	(29719) Mappointer_updated
        mihome-vacuum.0	2020-02-24 14:09:57.269	debug	(29719) update_Map need new mapurl
        mihome-vacuum.0	2020-02-24 14:09:57.268	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:09:56.391	debug	(29719) Mappointer_updated
        mihome-vacuum.0	2020-02-24 14:09:56.382	debug	(29719) Mappointer_nomap___retry
        mihome-vacuum.0	2020-02-24 14:09:53.961	debug	(29719) 25698
        mihome-vacuum.0	2020-02-24 14:09:53.482	debug	(29719) update_Map use old mapurl
        mihome-vacuum.0	2020-02-24 14:09:53.481	debug	(29719) update_Map Mimap enabled
        mihome-vacuum.0	2020-02-24 14:09:53.441	debug	(29719) requesting params every: 60 Sec
        mihome-vacuum.0	2020-02-24 14:09:37.899	debug	(29719) stateChange mihome-vacuum.0.control.fan_power {"val":104,"ack":false,"ts":1582549777895,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1582142142021}
        mihome-vacuum.0	2020-02-24 14:09:37.891	info	(29719) trigger cleaning segment 17
        mihome-vacuum.0	2020-02-24 14:09:37.886	debug	(29719) sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: 17
        mihome-vacuum.0	2020-02-24 14:09:37.881	debug	(29719) stateChange mihome-vacuum.0.rooms.room17.roomClean {"val":true,"ack":false,"ts":1582549777877,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582195312287}
        mihome-vacuum.0	2020-02-24 14:08:57.456	debug	(29719) get rooms from map data: [19,2,3,22,18,21,16,23,17,20,7,8]
          @dirkhe
          Ahhhhh habs kapiert, man muss im Adapter "Eigene Befehle senden" aktivieren, ich teste mal...
            dirkhe Developer last edited by
            Zum Schluss hast du noch einmal Pause gedrückt, aber kein Start mehr?
            Zwischendurch hast du mal Start gedrückt, aber davor kein Pause, zumindest lese ich das so aus dem log
              @dirkhe
              Zeile 113 = Pause
              Zeile 90 = resumeZoneClean --> nur zum Testen
              Zeile 82 = Start, danach Zeile 81 = wieder Pause, weil er nicht alles reinigen sollte
                blackeagle998 @blackeagle998 last edited by
                @blackeagle998 sagte in Test Adapter mihome-vacuum v2.0.x:
                @dirkhe
                Ich bin zu blöd dazu...
                Habe jetzt zwar den Datenpunkt "mihome-vacuum.0.control.X_send_command", aber keine Ahnung was ich da wie eintragen muss. Folgende Befehle wurden jedenfalls nicht angenommen:
                • resume_17_clean (segment 17 ist der gestartete Raum)
                • resume_segment_clean(17)
                • resume_segment_clean[17]
                • home
                • home()
                Keinen dieser Befehle schluckt er, helft mir mal bitte 🤷‍♂️
                  @dirkhe
                  • home
                  • home()
                  Einfach nur resume_segment_clean, aber vorher Pause drücken
                    @blackeagle998 aber das Log musst du von unten nach oben lesen, schau mal auf den zeitstempel
                      @dirkhe
                      Ja hab ich gemacht.
                      Zeile 135 (ganz unten) startet die Raumreinigung Segment 17.
                      Dann wie eben beschrieben:
                      Zeile 113 = Pause
                        Der Ablauf sollte folgender sein
                        Du startest entweder per Start die volle Zimmerreinigung oder einen Raum oder eine Zone
                        Dann drückst du auf dem robbi selber Pause oder in der App oder im adapter Pause
                        Wenn du dann im adapter auf Start klickst, sollte er je nach gestarteten Modus Resume machen
                          @dirkhe
                          Bei klick auf Start reagiert er nicht mehr.
                          mihome-vacuum.0	2020-02-24 14:53:37.873	debug	(28202) Resuming paused zoneclean.
                          mihome-vacuum.0	2020-02-24 14:53:37.872	debug	(28202) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1582552417869,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1582271390689}
                          mihome-vacuum.0	2020-02-24 14:53:34.624	debug	(28202) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1582552414621,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1582182216427}
                          mihome-vacuum.0	2020-02-24 14:53:23.820	debug	(28202) stateChange mihome-vacuum.0.control.fan_power {"val":104,"ack":false,"ts":1582552403815,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1582142142021}
                          mihome-vacuum.0	2020-02-24 14:53:23.810	info	(28202) trigger cleaning segment 17
                          "resume_segment_clean" als x_send_command funktioniert übrigens.
                          Ich wäre dennoch für einen Button 😊
                          Danke!!!
                            @blackeagle998 Den Button kann ich rein machen, kein Problem.
                            Aber wenn ich mir das log so anschaue, bin ich etwas verwundert. In Zeile 5 triggert er ein segment und in zeile 1 plätzlich die zone. Das klingt für mich unlogisch, bzw. nach einer älteren Version. Pass auf, ich baue dir gerade den button rein. Bitte aktualisiere dann nochmal und teste nochmal. Dann kannst du ja den Haken as den Einstllungen wieder rausnehmen und du hast die beiden Buttons. Ist das ok?
                              dirkhe Developer last edited by dirkhe
                              So, eine neue Version ist hochgeladen.
                              Wenn der enable zone cleaning in den Einstllungen nicht gesetzt ist, wird jetzt auch ein resumeRoomClean Button angelegt
                              Ich habe auch vlt die Stelle gefunden wo das 0 of undefined herkommt:
                              @Meistertr in der mapCreator Zeile 180 war es vorher so
                                  // Zeichne Roboter
                                      adapter.log.debug(Mapdata.robot[0])
                                     if (Mapdata.robot) {
                              Ich habe die logmeldung jetzt mal in die if Abfrage verschoben
                                blackeagle998 @dirkhe last edited by blackeagle998
                                @dirkhe
                                Ich habe die Instanz deaktiviert, alle Objekte gelöscht und von GitHub installiert. Danach die Instanz wieder gestartet, den neuen Button finde ich aber nicht.
                                Generell müsste das Ziel sein, einen allgemeinen Resume Button hinzubekommen, der für alles gilt, je nachdem was vorher gestartet wurde.
                                Sonst braucht man in der Visualisierung ja zwei Resume Knöpfe, daran habe ich vorher nicht gedacht...
                                  @blackeagle998 Entweder du machst das manuell, dann hast du die Knöpfe, wobei ich den 2. ja jetzt erst hinzugefügt habe.
                                  Im prinzip sollte das ja per auto gehen und bei mir geht es ja auch, da nimmt dann halt den Start Button.
                                  Wenn du jetzt neu installiert hast, dann mache doch bitte mal folgendes und poste das Log:
                                  @dirkhe sagte in Test Adapter mihome-vacuum v2.0.x:
                                  Wenn er dass dann immer noch falsch macht, stelle den Adpater mal auf silly und wiederhole das ganze nochmal.
                                    Man könnte das ganze auch auf den Pause Knopf legen, anstelle des Start Knopfes. Aber das war durch @Meistertr so vorgegeben und da wollte ich nicht eingreifen.
                                      @dirkhe
                                      Ich teste das morgen früh und melde mich, heute geht leider nicht mehr.
                                      Nur kurz zur Sicherheit:
                                      Version 2.0.6 ist noch aktuell, richtig?
                                        @blackeagle998 Ja, ich muss mir mal angewönen, noch einen release-candidate hinzuzufügen, ich habe aber vor ca. 2h. noch was hinzugefügt, bzw. ggf. den undefined of 0 gefixt
                                        • Diginix
                                          Diginix @dirkhe last edited by Diginix
                                          @dirkhe
                                          Ich hab jetzt ein Deadlock mit deinem Fork.
                                          Kann "get devices" nicht ausführen weil Instanz nicht aktiv und Instanz geht nicht mehr aktiv weil mit dem Token was nicht stimmt. Der manuelle Teil mit IP und Token ist nocht korrekt gefüllt.
                                          2020-02-24 18:25:41.718  - error: host.BT3-PRO instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          2020-02-24 18:26:12.133  - error: host.BT3-PRO Caught by controller[0]: /opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:322
                                          2020-02-24 18:26:12.134  - error: host.BT3-PRO Caught by controller[0]:     setCarpetMode(enabled) {
                                          2020-02-24 18:26:12.134  - error: host.BT3-PRO Caught by controller[0]:                            ^
                                          2020-02-24 18:26:12.134  - error: host.BT3-PRO Caught by controller[0]: SyntaxError: Unexpected token {
                                          2020-02-24 18:26:12.135  - error: host.BT3-PRO Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:723:23)
                                          2020-02-24 18:26:12.135  - error: host.BT3-PRO Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                          2020-02-24 18:26:12.135  - error: host.BT3-PRO Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:653:32)
                                          2020-02-24 18:26:12.135  - error: host.BT3-PRO Caught by controller[0]:     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                          2020-02-24 18:26:12.135  - error: host.BT3-PRO Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                          2020-02-24 18:26:12.136  - error: host.BT3-PRO Caught by controller[0]:     at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                                          2020-02-24 18:26:12.136  - error: host.BT3-PRO Caught by controller[0]:     at startup (internal/bootstrap/node.js:283:19)
                                          2020-02-24 18:26:12.136  - error: host.BT3-PRO Caught by controller[0]:     at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                                          2020-02-24 18:26:12.136  - error: host.BT3-PRO instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          Rollback auf latest 2.0.6 und alles funktioniert wieder. Dann noch mal auf deinen Fork und wieder das gleiche Problem.
                                            @Diginix sagte in Test Adapter mihome-vacuum v2.0.x:
                                            setCarpetMode
                                            Mein Fehler, da war ein Zeichen durch copy and paste zuviel, bitte die RC-05 installieren (2.1.06-RC05 sollte jetzt als Version im Log angezeigt werden)
                                            Diginix Meistertr 2 Replies Last reply Reply Quote 0
                                            1.0k
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            491318
