    3. Entwicklung
    4. Test Adapter Alarm 0.0.8
    • Homer.J.
      Homer.J. @blauholsten last edited by
      @blauholsten hier mal die Ausgabe.
       alarm.0	2020-02-24 05:28:59.433	debug	(14204) system.adapter.admin.0: logging true
      alarm.0	2020-02-24 05:28:56.945	debug	(14204) Password denied
      alarm.0	2020-02-24 05:28:56.944	debug	(14204) state alarm.0.use.toggle_password changed: false (ack = false)
      alarm.0	2020-02-24 05:28:54.210	debug	(14204) Password denied
      alarm.0	2020-02-24 05:28:54.209	debug	(14204) state alarm.0.use.toggle_password changed: true (ack = false)
      alarm.0	2020-02-24 05:28:51.838	debug	(14204) Password denied
      alarm.0	2020-02-24 05:28:51.838	debug	(14204) state alarm.0.use.toggle_password changed: false (ack = false)
      alarm.0	2020-02-24 05:28:45.545	debug	(14204) state alarm.0.status.silent_alarm changed: false (ack = false)
      alarm.0	2020-02-24 05:28:45.544	debug	(14204) state alarm.0.status.activation_failed changed: false (ack = false)
      alarm.0	2020-02-24 05:28:45.543	debug	(14204) state alarm.0.status.burglar_alarm changed: false (ack = false)
      alarm.0	2020-02-24 05:28:45.542	debug	(14204) state alarm.0.status.siren changed: false (ack = false)
      alarm.0	2020-02-24 05:28:45.541	debug	(14204) state alarm.0.status.activation_failed changed: false (ack = false)
      alarm.0	2020-02-24 05:28:45.540	debug	(14204) state alarm.0.status.activated_with_warnings changed: false (ack = false)
      alarm.0	2020-02-24 05:28:45.539	debug	(14204) state alarm.0.status.deactivated changed: true (ack = false)
      alarm.0	2020-02-24 05:28:45.539	debug	(14204) state alarm.0.status.activated changed: false (ack = false)
      alarm.0	2020-02-24 05:28:45.539	debug	(14204) state alarm.0.status.siren changed: false (ack = false)
      sayit.0	2020-02-24 05:28:45.532	info	(2872) saying: Alarmanlage deaktiviert
      alarm.0	2020-02-24 05:28:45.531	debug	(14204) state alarm.0.info.log changed: Alarmanlage deaktiviert (ack = false)
      alarm.0	2020-02-24 05:28:45.528	info	(14204) Alarmanlage deaktiviert
      alarm.0	2020-02-24 05:28:45.528	debug	(14204) Message for sayit instance 0: Alarmanlage deaktiviert
      alarm.0	2020-02-24 05:28:45.527	debug	(14204) state alarm.0.use.disable changed: true (ack = false)
      alarm.0	2020-02-24 05:28:40.375	debug	(14204) state alarm.0.status.activation_failed changed: false (ack = false)
      alarm.0	2020-02-24 05:28:40.374	debug	(14204) state alarm.0.status.deactivated changed: false (ack = false)
      alarm.0	2020-02-24 05:28:40.374	debug	(14204) state alarm.0.status.activated changed: true (ack = false)
      alarm.0	2020-02-24 05:28:40.370	debug	(14204) state alarm.0.info.log changed: Alarmanlage aktiviert (ack = false)
      sayit.0	2020-02-24 05:28:40.371	info	(2872) saying: Alarmanlage aktiviert
      alarm.0	2020-02-24 05:28:40.368	debug	(14204) Message for sayit instance 0: Alarmanlage aktiviert
      alarm.0	2020-02-24 05:28:40.367	info	(14204) Alarmanlage aktiviert
      alarm.0	2020-02-24 05:28:40.366	debug	(14204) state alarm.0.use.enable changed: true (ack = false)
      alarm.0	2020-02-24 05:28:32.230	debug	(14204) SUBSCRIBTION for: hm-rpc.2.0000D709956A55.1.STATE
      alarm.0	2020-02-24 05:28:30.238	debug	(14204) {"hm-rpc.2.0000D709956A55.1.STATE":0}
      alarm.0	2020-02-24 05:28:30.233	debug	(14204) No night rest configured
      alarm.0	2020-02-24 05:28:30.228	debug	(14204) Messages to: []
      alarm.0	2020-02-24 05:28:30.214	info	(14204) starting. Version 0.0.9 in /opt/iobroker/node_modules/iobroker.alarm, node: v10.19.0
      alarm.0	2020-02-24 05:28:28.567	debug	(14204) statesDB connected
      alarm.0	2020-02-24 05:28:28.566	debug	(14204) States connected to redis: 0.0.0.0:9000
      alarm.0	2020-02-24 05:28:28.556	debug	(14204) States create System PubSub Client
      alarm.0	2020-02-24 05:28:28.555	debug	(14204) States create User PubSub Client
      alarm.0	2020-02-24 05:28:28.549	debug	(14204) Redis States: Use Redis connection: 0.0.0.0:9000
      alarm.0	2020-02-24 05:28:28.548	debug	(14204) objectDB connected
      alarm.0	2020-02-24 05:28:28.546	debug	(14204) Objects connected to redis: 0.0.0.0:9001
      alarm.0	2020-02-24 05:28:28.504	debug	(14204) Objects client initialize lua scripts
      alarm.0	2020-02-24 05:28:28.504	debug	(14204) Objects create User PubSub Client
      alarm.0	2020-02-24 05:28:28.503	debug	(14204) Objects create System PubSub Client
      alarm.0	2020-02-24 05:28:28.501	debug	(14204) Objects client ready ... initialize now
      alarm.0	2020-02-24 05:28:28.187	debug	(14204) Redis Objects: Use Redis connection: 0.0.0.0:9001
      [/s]
      blauholsten 1 Reply Last reply Reply Quote 0
      • blauholsten
        blauholsten Developer @Homer.J. last edited by
        @Homer-J dein Passwort ist verkehrt
        • blauholsten
          blauholsten Developer @sigi234 last edited by
          @sigi234 du musst einen der beiden datenpunkte mit dem Passwort beschreiben, z.B. über ein Widget.
          Homer.J. 1 Reply Last reply Reply Quote 0
          • Homer.J.
            Morgen @blauholsten funktioniert mit der Pineingabe, kann man die Datenpunkte nicht als Number anlegen es irritiert ein wenig da die Datenpunkte als true oder false angezeigt werden.
            Bei einer falschen Pineingabe wird aber nichts angezeigt ist das so gewollt, du hast hier aber ein Datenpunkt
            Wrong password ich dachte der ist dafür.
            Kann man den Datenpunkt nicht dafür nehmen das er eine Ausgabe zurück gibt ob das Passwort richtig oder falsch ist. ?
            sigi234 blauholsten 2 Replies Last reply Reply Quote 0
              sigi234 Forum Testing Most Active @Homer.J. last edited by
              @Homer-J sagte in Test Adapter Alarm 0.0.8:
              Welches Widget hast du dafür genommen?
              • Homer.J.
                Homer.J. @sigi234 last edited by
                Hi @sigi234 hab es erstmal nur in den Datenpunkt eingegeben ob es funktioniert, mit einem Widget hab ich es noch nicht Versucht.
                  sigi234 Forum Testing Most Active @blauholsten last edited by sigi234
                  @blauholsten
                  1. Nachtruhe endet wird bei mir 10:15 Uhr angezeigt, habe aber 06:00 Uhr eingegeben?
                  1. Kann man den DP logs today als Html oder Table ausgeben? Die Schrift und die Größe ist so nicht änderbar.
                  • blauholsten
                    @sigi234 das mit der Nachtruhe kann ich nicht reproduzieren.
                    Bei den Logs müsstest du mir mal ein Bsp. geben.
                    • blauholsten
                      Da hast du recht, habe ich gefixed!
                      Den state wrong password hatte ich noch nicht aktiviert, da ich mir noch nicht sicher war wie ich das final machen will. Jetzt habe ich mich dazu entschlossen, dass der Datenpunkt auf true gesetzt wird sobald ein falsches Passwort eingegebne wird. Auf false wird er gesetzt wenn ein richtiges eingegeben wird.
                      • Homer.J.
                        Homer.J. @blauholsten last edited by Homer.J.
                        @blauholsten funktioniert soweit, kann man die Pineingabe irgendwie über eine Tastatur oder ein Pineingabefeld eingeben. Oder wie hast du dir das über ein Widget gedacht. ?
                          Denke mit einen Input Widget
                          • Homer.J.
                            @sigi234 Hast du schon eine Idee. ?
                              Nö
                              Beliar_666 1 Reply Last reply Reply Quote 0
                              • Beliar_666
                                Beliar_666 @sigi234 last edited by
                                @sigi234 @Homer-J @blauholsten Da gab es doch dieses Thema mit dem Vis per Pineingabefeld Schützen, kann man das nicht irgendwie verwenden?
                                blauholsten sigi234 2 Replies Last reply Reply Quote 0
                                • blauholsten
                                  blauholsten Developer @Beliar_666 last edited by
                                  @Beliar_666 sagte in Test Adapter Alarm 0.0.8:
                                  Diesen Thread habe ich gesucht, aber nicht gefunden.
                                  Mit einen Input Widget sollte es trotzdem gehen, unter ObjectID einfach einen der beiden datenpunkte eintragen....
                                    sigi234 Forum Testing Most Active @Beliar_666 last edited by
                                    Das?
                                    https://forum.iobroker.net/topic/4461/vorlage-flexible-pin-eingabe-mit-blockly
                                    • Homer.J.
                                      @blauholsten Ich hab jetzt mal testweise ein Pincodescript gebaut das triggert aber halt auf die normalen Datenpunkte disable. Das funktioniert ganz gut. Wenn dann müsste man ja irgendwie den Wert oder das Passwort in den Datenpunkt Passwort schreiben können. Dafür hab ich aber auch keinen Lösungsansatz.
                                      • blauholsten
                                        @Homer-J
                                        Zeig mir doch dein Skript😊
                                        • blauholsten
                                          blauholsten Developer last edited by
                                          Also ich habe es eben per Input Widget probiert, klappt bestens. Ich habe dabei festgestellt, dass es sinnig ist den Wert des eingegebenen Datenpunktes wieder zu leerren, da er sonst im Input stehen bleibt. In der aktuellen Version ist das Problem behoben.
                                          • Homer.J.
                                            @blauholsten
                                            // allgemeine Variablen
                                            var logging = true;                                                        // Logging on/off
                                            var instanz = 'javascript.0';  instanz = instanz + '.Alarm';                     //
                                            var pfad0 =     'alarm.0.use.disable'/*Disable*/;                        // Pfad innerhalb der Instanz
                                            // Variablen für Pin-Abfrage
                                            var PinTast = "";                   // Inhalt der Eingabe
                                            var PinTemp ="";                    // Puffer für eingegebe Ziffern
                                            var PinLae = 0;                     // Pin-Länge bei Eingabe
                                            var PinState = false ;              // Eingabestatus - Eingabe beginnt nach Taste '#' und wird mit Taste '#' abgeschlossen
                                            var PinFehl =false;                 // Statusflag für fehlerhafte Eingabe
                                            var PinAnz = "";                    // Angezeiger 'Displaytext' z.B. ****
                                            var PinSoll = 2054;                 // Pin die zur Deaktivierung der Alarmanlage benötigt wird
                                            // Objekte
                                            // Objekte für Pin-Eingabe
                                            createState(pfad0 + 'PinSelect', "" , {name: 'Pin-Eingabe'});
                                            createState(pfad0 + 'Pin', '0000' ,  {name: 'Pin'});
                                            createState(pfad0 + 'PinFehler', false ,  {name: 'Pin-Fehler'});
                                            createState(pfad0 + 'PinAnz', '' ,  {name: 'Pin-Anzeige'});
                                            createState(pfad0 + 'VisKeyPad', '' ,  {name: 'State für Vis Keypad Sichtbar'}); //State für Vis Keypad Sichtbar wird von Button in Vis beschrieben und bei unscharf zurück gesetzt
                                            // #  Pin-Abfrage                                                              #
                                            on('javascript.0.Alarmanlage.test.Pin.Disable.PinSelect', function (dp) {
                                                if (dp.newState.val === 0 || dp.newState.val === 1 || dp.newState.val === 2 || dp.newState.val === 3 || dp.newState.val === 4 || dp.newState.val === 5 || dp.newState.val === 6 || dp.newState.val === 7 || dp.newState.val === 8 || dp.newState.val === 9) {
                                                    PinTast = dp.newState.val;
                                                    PinEingabe();
                                                if (dp.newState.val === 'E') {
                                                    PinPruef();
                                                if (dp.newState.val === 'R') {
                                                    PinReset();
                                            function PinEingabe () {
                                                PinTemp = (PinTemp + PinTast);
                                                PinAnz = (PinAnz + '*');
                                                setState('javascript.0.Alarmanlage.test.Pin.Disable.PinAnz', PinAnz);
                                                PinLae = (PinLae +1) ;
                                            function unscharf(){
                                                setState('alarm.0.use.disable'/*Disable*/, true);
                                                setState('javascript.0.Alarmanlage.test.Pin.Disable.VisKeyPad', false);
                                                 if(logging) log('Deaktivierung der Alarmanlage durch Pineingabe erfolgreich');
                                            ///////////////////////////////////////////////////// Hier musst du dann deinen Türöffner auf machen reinschreiben
                                            function PinPruef() {
                                                if (PinTemp == PinSoll) {
                                                    if(logging) log('PinEingabe Disable erfolgreich');
                                                    unscharf();
                                                    setTimeout(function() {
                                                        PinReset();
                                                    }, 10 * 1000);
                                                } else {
                                                    if(logging) log('Pin Eingabe Disable falscher Pin');
                                                    setState('javascript.0.Alarmanlage.test.Pin.Disable.PinFehler', true);
                                                    PinReset();
                                            function PinReset() {
                                                    PinLae=0;
                                                    PinAnz="";
                                                    PinTemp="";
                                            alarm alarmanlage sicherheit überwachung
                                            17
                                            119
                                            12076
