    4. Test Adaper Tado v0.1.x
    • Dutchman
      Dutchman Developer Most Active Administrators @Xandar31 last edited by
      @Xandar31 sagte in Test Adaper Tado v0.1.x:
      leider bekomme ich den Fehler nochmal
      dan. hast du irgendwie ne alte Version rauf der Fehler ist lange gefixt 🙂
      • maximal1981
        maximal1981 last edited by
        irgendwie verliert der Adapter öfters die Verbindung zur Cloud. Ich habe leider keine Ahnung wo ich mit der Fehler suche beginnen soll. Kann mir jemand helfen, um die Ursache zu finden?
        tado.0	2020-02-15 00:25:36.516	info	(783) state tado.0.122768.Rooms.3.setting.power deleted
        tado.0	2020-02-15 00:25:12.132	info	(783) state tado.0.122768.Rooms.2.setting.power deleted
        tado.0	2020-02-15 00:23:21.306	info	(783) state tado.0.122768.Rooms.11.setting.power deleted
        tado.0	2020-02-15 00:22:51.968	info	(783) state tado.0.122768.Rooms.8.setting.power deleted
        tado.0	2020-02-15 00:22:28.348	info	(783) state tado.0.122768.Rooms.7.setting.power deleted
        tado.0	2020-02-15 00:22:00.678	info	(783) state tado.0.122768.Rooms.10.setting.power deleted
        tado.0	2020-02-15 00:21:34.694	info	(783) state tado.0.122768.Rooms.6.setting.power deleted
        tado.0	2020-02-15 00:21:08.306	info	(783) state tado.0.122768.Rooms.4.setting.power deleted
        tado.0	2020-02-15 00:20:42.941	info	(783) state tado.0.122768.Rooms.3.setting.power deleted
        tado.0	2020-02-15 00:20:15.455	info	(783) state tado.0.122768.Rooms.2.setting.power deleted
        tado.0	2020-02-15 00:18:28.913	info	(783) state tado.0.122768.Rooms.11.setting.power deleted
        tado.0	2020-02-15 00:18:03.353	info	(783) state tado.0.122768.Rooms.8.setting.power deleted
        tado.0	2020-02-15 00:17:38.525	info	(783) state tado.0.122768.Rooms.7.setting.power deleted
        tado.0	2020-02-15 00:17:12.247	info	(783) state tado.0.122768.Rooms.10.setting.power deleted
        tado.0	2020-02-15 00:16:48.088	info	(783) state tado.0.122768.Rooms.6.setting.power deleted
        tado.0	2020-02-15 00:16:22.085	info	(783) state tado.0.122768.Rooms.4.setting.power deleted
        tado.0	2020-02-15 00:15:55.992	info	(783) state tado.0.122768.Rooms.3.setting.power deleted
        tado.0	2020-02-15 00:15:29.743	info	(783) state tado.0.122768.Rooms.2.setting.power deleted
        tado.0	2020-02-15 00:13:43.238	info	(783) state tado.0.122768.Rooms.11.setting.power deleted
        tado.0	2020-02-15 00:13:17.206	info	(783) state tado.0.122768.Rooms.8.setting.power deleted
        tado.0	2020-02-15 00:12:52.895	info	(783) state tado.0.122768.Rooms.7.setting.power deleted
        tado.0	2020-02-15 00:12:25.584	info	(783) state tado.0.122768.Rooms.10.setting.power deleted
        tado.0	2020-02-15 00:12:03.103	info	(783) Initialisation finished, connected to Tado Cloud service refreshing every : 30 seconds
        tado.0	2020-02-15 00:11:58.006	info	(783) state tado.0.122768.Rooms.6.setting.power deleted
        tado.0	2020-02-15 00:11:31.787	info	(783) state tado.0.122768.Rooms.4.setting.power deleted
        tado.0	2020-02-15 00:11:04.630	info	(783) state tado.0.122768.Rooms.3.setting.power deleted
        tado.0	2020-02-15 00:10:39.095	info	(783) state tado.0.122768.Rooms.2.setting.power deleted
        tado.0	2020-02-15 00:07:35.058	info	(783) Connected to Tado cloud, initialyzing ...
        tado.0	2020-02-15 00:07:23.961	info	(783) state tado.0.122768.Rooms.3.setting.power deleted
        tado.0	2020-02-15 00:06:54.482	error	(783) Disconnected from Tado cloud service ..., retry in 30 seconds !
        tado.0	2020-02-15 00:06:38.791	info	(783) state tado.0.122768.Rooms.2.setting.power deleted
        tado.0	2020-02-15 00:06:04.448	error	(783) Issue in Get all rooms Error: getaddrinfo EAI_AGAIN my.tado.com my.tado.com:443
        tado.0	2020-02-15 00:03:48.115	info	(783) state tado.0.122768.Rooms.11.setting.power deleted
        • Thomas Jansen
          Thomas Jansen last edited by
          Also auch auf die Gefahr hin, das Ihr mich köpft, ist es jetzt möglich (Aus, Auto, Manuell Betrieb) irgendwo in den Datenpunkten mit 1,2,3 einzustellen?
          LG
          Schöne Nacht Euch 😉
          Thomas Jansen 1 Reply Last reply Reply Quote 0
          • Thomas Jansen
            Thomas Jansen @Thomas Jansen last edited by
            @Thomas-Jansen sagte in Test Adaper Tado v0.1.x:
            LG
            Schöne Nacht Euch 😉
            Habe das Problem, das der HAM Adapter nach Update node, nodejs das tado plugin nicht mehr ohne fehler zulässt... 😞
            • Dutchman
              Dutchman Developer Most Active Administrators @Thomas Jansen last edited by
              das hat nix mit diesem adapter zu tun bitte nicht Themen vermischen !
              @maximal1981 sagte in Test Adaper Tado v0.1.x:
              Das kann viele. gründe. haben, schlechte. internet Verbindung/tado überlastet usw.
              du könntest das polling mal erhöhen das er wenig oft die. cloud abfragt.
              Thomas Jansen 1 Reply Last reply Reply Quote 1
              • Thomas Jansen
                Thomas Jansen @Dutchman last edited by
                @Dutchman sorry, habe gestern abend echt was verwechselt. Also ich habe bisher den HAM Adapter mit dem homebridge tado plugin benutzt. Das funktioniert aber nicht mehr da nach dem Update npm etc dieses Plugin wohl nicht mehr unterstützt wird. Er spuck auf jedenfall jede menge Fehler aus. Egal, anderes Problem..... Ich hatte jedoch in meiner VIS alles auf HAM ausgelegt. Jetzt möchte ich aber komplett auf diesen Adapter wechseln. Deshalb noch mal etwas klarer die Frage 😉 ob in den Datenpunkten des Adapters (läuft übrigens bei mir sehr gut) AUS,AUTO,Manuell eingestellt werden können mit 1,2,3 oder so?
                • Dutchman
                  Dutchman Developer Most Active Administrators @Thomas Jansen last edited by Dutchman
                  Alles gut, hatte Frage Dan falsch verstanden 😉
                  BIn gerade unterwegs müsste ich selber erst schauen 🙈
                  • Thomas Jansen
                    @Dutchman 👍 😊 wäre echt cool.... 4 Monate IOBROKER meine NERVEN hihihihih bis später... LG
                      senger1985 @Thomas Jansen last edited by
                      @Thomas-Jansen
                      "Aus" kannst du die Thermostate, über den Datenpunkt "Power", "Auto" ist ja, wenn man "clearZoneOverlay" ausführt und "Manuell" stellt er ja automatisch ein, sobald man die Temperatur ändert.
                      Oder verstehe ich dich gerade falsch?
                        Jogi19 last edited by
                        Ich bekomme keine Werte mehr im Bereich openWindow.
                        Im LOG kommt folgende Fehlermeldung:
                        881) Send this info to developer !!! { Unhandable information found in DoReadDevices : "openWindowDetected" with value : true
                        Hier noch ein Bild:
                        Der Bereich openWindow ist bei mir auch nicht bei allen Zimmern vorhanden.
                        Ich habe den Eindruck als ob das erst seit den letzten Änderungen von Tado in der IOS APP 5.9.4 (9255) so ist
                          senger1985 @Jogi19 last edited by
                          @Jogi19 ich kann den Fehler bei mir nicht reproduzieren.
                          Welche Adapter-Version hast du drauf?
                            Jogi19 @senger1985 last edited by
                            @senger1985 Ich habe die Version 0.1.6
                            Wie gesagt, wenn ich das Fenster öffne bekomme ich in der App von Tado angezeigt, dass das Fenster offen ist, aber im ioBroker bleibt alles leer. Müssten nicht bei openWindow dann irgendwelche Werte stehen.
                            S Dutchman 2 Replies Last reply Reply Quote 0
                              senger1985 @Jogi19 last edited by senger1985
                              @Jogi19 jup, die dürften, unter "openWindow", eigentlich nicht leer bleiben.
                              Würdest du so nett sein und hier:
                              https://github.com/iobroker-community-adapters/ioBroker.tado/issues
                              ein Issue erstellen, damit Dutchman Bescheid weiß.
                              • Dutchman
                                Dutchman Developer Most Active Administrators @Jogi19 last edited by
                                @Jogi19 sagte in Test Adaper Tado v0.1.x:
                                hmm ... installiere mal bitte von git ich habe extra loggin eingebaut.
                                wen der Fehler auftritt sollte ein state "test_data" erstellt. werden mit einen JSON. string da drin.
                                Den brauche ich mal 🙂
                                  Coffeelover last edited by
                                  Hallo @Dutchman
                                  ich habe in der Tado-App gerade die Meldung bekommen, dass ich ab jetzt händisch die Modi Home/Away wechseln kann. Kannst du mal sehen, ob dieser "Schalter" auch über die API verfügbar geworden ist?
                                  Vielen Dank
                                    Jogi19 @Dutchman last edited by
                                    @Dutchman Ich habe mal probiert den Adapter über Github neu zu installieren. Habe über ioBroker "über eigene Url installieren" ausgewählt kann aber keine Veränderung erkennen.
                                    Nach wie vor bekomme ich im Log diese Meldung:
                                    2931) Send this info to developer !!! { Unhandable information found in DoZoneState : "openWindowDetected" with value : true
                                    aber ich kann kein state "test_data" finden.
                                    Habe ich bei der Installation was falsch gemacht?
                                    • Dutchman
                                      1. Send this info to developer !!! { Unhandable information found in DoZoneState : "openWindowDetected" with value : true
                                      das ist was ich brauchte danke 🙂
                                      fix kommt morgen
                                      • Dutchman
                                        Dutchman Developer Most Active Administrators last edited by Dutchman
                                        @Jogi19 bitte. 0.1.7 probieren
                                        • Dutchman
                                          Dutchman Developer Most Active Administrators @senger1985 last edited by
                                          @senger1985 sagte in Test Adaper Tado v0.1.x:
                                          hast du 0.1.7 probiert ?!
                                            K_o_bold last edited by
                                            Habt ihr auch Probleme mit dem Tado Server?
                                            79.9k
                                            adapter tado testing team
                                            62
                                            868
                                            198781
