    4. View Adapter Status
    View Adapter Status
    • Negalein
      Negalein Global Moderator @Glasfaser last edited by
      @Glasfaser sagte in View Adapter Status:
      Ahh ..dachte im Script, , Danke .
      Und mir ist mit der Schriftfarbe so gegangen. Hab im Widget danach gesucht. 😁
      Scrounger 1 Reply Last reply Reply Quote 1
        sigi234 Forum Testing Most Active @Scrounger last edited by
        @Scrounger sagte in View Adapter Status:
        die auch die ganzen Warn Meldungen abfangen sollte
        Leider noch nicht.
        • Scrounger
          Scrounger Developer @sigi234 last edited by
          @sigi234 sagte in View Adapter Status:
          Leider noch nicht.
          Welche?...
            Leider noch nicht.
            Welche?...
            javascript.0	2020-02-24 22:45:00.815	warn	(15032) at Timer.processTimers (timers.js:223:10)
            javascript.0	2020-02-24 22:45:00.814	warn	(15032) at listOnTimeout (timers.js:263:5)
            javascript.0	2020-02-24 22:45:00.814	warn	(15032) at tryOnTimeout (timers.js:300:5)
            javascript.0	2020-02-24 22:45:00.814	warn	(15032) at ontimeout (timers.js:436:11)
            javascript.0	2020-02-24 22:45:00.814	warn	(15032) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
            javascript.0	2020-02-24 22:45:00.814	warn	(15032) at C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
            javascript.0	2020-02-24 22:45:00.814	warn	(15032) at Job.invoke (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
            javascript.0	2020-02-24 22:45:00.814	warn	(15032) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1340:34)
            javascript.0	2020-02-24 22:45:00.814	warn	(15032) at Object.adapterStatus (script.js.Sigi.Adapter_Abfrage1:115:33)
            javascript.0	2020-02-24 22:45:00.814	warn	(15032) at getStatusColor (script.js.Sigi.Adapter_Abfrage1:123:32)
            javascript.0	2020-02-24 22:45:00.814	warn	(15032) at Object.getStateValueIfExist (script.js.Sigi.Adapter_Abfrage1:195:34)
            javascript.0	2020-02-24 22:45:00.813	warn	(15032) getState "system.adapter.pegelonline.0.alive" not found (3) states[id]=null
            javascript.0	2020-02-24 22:45:00.812	warn	(15032) at Timer.processTimers (timers.js:223:10)
            javascript.0	2020-02-24 22:45:00.812	warn	(15032) at listOnTimeout (timers.js:263:5)
            javascript.0	2020-02-24 22:45:00.812	warn	(15032) at tryOnTimeout (timers.js:300:5)
            javascript.0	2020-02-24 22:45:00.812	warn	(15032) at ontimeout (timers.js:436:11)
            javascript.0	2020-02-24 22:45:00.812	warn	(15032) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
            javascript.0	2020-02-24 22:45:00.812	warn	(15032) at C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
            javascript.0	2020-02-24 22:45:00.812	warn	(15032) at Job.invoke (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
            javascript.0	2020-02-24 22:45:00.812	warn	(15032) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1340:34)
            javascript.0	2020-02-24 22:45:00.812	warn	(15032) at Object.adapterStatus (script.js.Sigi.Adapter_Abfrage1:101:132)
            javascript.0	2020-02-24 22:45:00.812	warn	(15032) at Object.getStateValueIfExist (script.js.Sigi.Adapter_Abfrage1:195:34)
            javascript.0	2020-02-24 22:45:00.811	warn	(15032) getState "system.adapter.pegelonline.0.memRss" not found (3) states[id]=null
            javascript.0	2020-02-24 22:45:00.810	warn	(15032) at Timer.processTimers (timers.js:223:10)
            javascript.0	2020-02-24 22:45:00.810	warn	(15032) at listOnTimeout (timers.js:263:5)
            javascript.0	2020-02-24 22:45:00.810	warn	(15032) at tryOnTimeout (timers.js:300:5)
            javascript.0	2020-02-24 22:45:00.810	warn	(15032) at ontimeout (timers.js:436:11)
            javascript.0	2020-02-24 22:45:00.810	warn	(15032) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
            javascript.0	2020-02-24 22:45:00.810	warn	(15032) at C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
            javascript.0	2020-02-24 22:45:00.810	warn	(15032) at Job.invoke (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
            javascript.0	2020-02-24 22:45:00.810	warn	(15032) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1340:34)
            javascript.0	2020-02-24 22:45:00.810	warn	(15032) at Object.adapterStatus (script.js.Sigi.Adapter_Abfrage1:97:132)
            javascript.0	2020-02-24 22:45:00.810	warn	(15032) at Object.getStateValueIfExist (script.js.Sigi.Adapter_Abfrage1:195:34)
            javascript.0	2020-02-24 22:45:00.810	warn	(15032) getState "system.adapter.pegelonline.0.memHeapUsed" not found (3) states[id]=null
            javascript.0	2020-02-24 22:45:00.808	warn	(15032) at Timer.processTimers (timers.js:223:10)
            javascript.0	2020-02-24 22:45:00.808	warn	(15032) at listOnTimeout (timers.js:263:5)
            javascript.0	2020-02-24 22:45:00.808	warn	(15032) at tryOnTimeout (timers.js:300:5)
            javascript.0	2020-02-24 22:45:00.808	warn	(15032) at ontimeout (timers.js:436:11)
            javascript.0	2020-02-24 22:45:00.808	warn	(15032) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
            javascript.0	2020-02-24 22:45:00.808	warn	(15032) at C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
            javascript.0	2020-02-24 22:45:00.808	warn	(15032) at Job.invoke (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
            javascript.0	2020-02-24 22:45:00.808	warn	(15032) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1340:34)
            javascript.0	2020-02-24 22:45:00.808	warn	(15032) at Object.adapterStatus (script.js.Sigi.Adapter_Abfrage1:93:132)
            javascript.0	2020-02-24 22:45:00.808	warn	(15032) at Object.getStateValueIfExist (script.js.Sigi.Adapter_Abfrage1:195:34)
            javascript.0	2020-02-24 22:45:00.808	warn	(15032) getState "system.adapter.pegelonline.0.memHeapTotal" not found (3) states[id]=null
            javascript.0	2020-02-24 22:45:00.806	warn	(15032) at Timer.processTimers (timers.js:223:10)
            javascript.0	2020-02-24 22:45:00.806	warn	(15032) at listOnTimeout (timers.js:263:5)
            javascript.0	2020-02-24 22:45:00.806	warn	(15032) at tryOnTimeout (timers.js:300:5)
            javascript.0	2020-02-24 22:45:00.806	warn	(15032) at ontimeout (timers.js:436:11)
            javascript.0	2020-02-24 22:45:00.806	warn	(15032) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
            javascript.0	2020-02-24 22:45:00.806	warn	(15032) at C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
            javascript.0	2020-02-24 22:45:00.806	warn	(15032) at Job.invoke (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
            javascript.0	2020-02-24 22:45:00.806	warn	(15032) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1340:34)
            javascript.0	2020-02-24 22:45:00.806	warn	(15032) at Object.adapterStatus (script.js.Sigi.Adapter_Abfrage1:89:132)
            javascript.0	2020-02-24 22:45:00.806	warn	(15032) at Object.getStateValueIfExist (script.js.Sigi.Adapter_Abfrage1:195:34)
            javascript.0	2020-02-24 22:45:00.806	warn	(15032) getState "system.adapter.pegelonline.0.cpu" not found (3) states[id]=null
            javascript.0	2020-02-24 22:45:00.804	warn	(15032) at Timer.processTimers (timers.js:223:10)
            javascript.0	2020-02-24 22:45:00.804	warn	(15032) at listOnTimeout (timers.js:263:5)
            javascript.0	2020-02-24 22:45:00.804	warn	(15032) at tryOnTimeout (timers.js:300:5)
            javascript.0	2020-02-24 22:45:00.804	warn	(15032) at ontimeout (timers.js:436:11)
            javascript.0	2020-02-24 22:45:00.804	warn	(15032) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
            javascript.0	2020-02-24 22:45:00.804	warn	(15032) at C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
            javascript.0	2020-02-24 22:45:00.804	warn	(15032) at Job.invoke (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
            javascript.0	2020-02-24 22:45:00.804	warn	(15032) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1340:34)
            javascript.0	2020-02-24 22:45:00.803	warn	(15032) at Object.adapterStatus (script.js.Sigi.Adapter_Abfrage1:78:89)
            javascript.0	2020-02-24 22:45:00.803	warn	(15032) getState "system.adapter.pegelonline.0.uptime" not found (3) states[id]=null
            • Scrounger
              @sigi234
              Ist exakt die gleiche Meldung wie bei @Negalein :
              getState "system.adapter.proxy.0.alive" not found (3) states[id]=null
              Schätze da hast nen Fehler beim Skript kopieren gemacht?
              Negalein sigi234 2 Replies Last reply Reply Quote 0
              • Negalein
                Negalein Global Moderator @Scrounger last edited by
                mit dem aktuellen Script hab ich 0 Fehlermeldungen, bzw. Warnmeldungen
                • Scrounger
                  Scrounger Developer @Negalein last edited by Scrounger
                  @Negalein sagte in View Adapter Status:
                  Die kann man übrigens auch per Widget einstellen.
                  Keine Ahnung warum ich das im Skript gemacht habe. Werf ich beim nächsten Update raus, weil da passt noch was nicht mit dem connect status 😉
                    Wie immer hattest du Recht. 👍
                    • Negalein
                      Aber nur den linken Teil.
                      Den rechten teil mit den werten geht nur im Script.
                      • Scrounger
                        @Negalein
                        Ja korrekt.
                        • Negalein
                          Ja korrekt.
                          Deshalb bitte im Script belassen 🙂
                            saeft_2003 Most Active last edited by
                            Das neue skript läuft bei mir auch super und ist optisch nochmal besser 😊 👍
                              sigi234 Forum Testing Most Active @saeft_2003 last edited by
                              @saeft_2003 sagte in View Adapter Status:
                              Ja, sehr gut geworden.
                                Wie schon mal erwähnt wäre eine Sortierung nach läuft und gestoppt nicht schlecht.
                                sigi234 Scrounger 2 Replies Last reply Reply Quote 0
                                  sigi234 Forum Testing Most Active @saeft_2003 last edited by sigi234
                                  Jupp, könnte man ja nach Farbe sortieren?
                                  Überlege mir gerade wie man auch nach Ramverbrauch oder CPU sortieren könnte?
                                  • Scrounger
                                    Scrounger Developer @saeft_2003 last edited by
                                    Kann man z.B. mit dem Select Widget realisieren. Dazu muss ein weiterer Datenpunkt angelegt werden, ein listener für diesen Datenpunkt im Skript erzeugt werden und je nachdem welchen state der Datenpunkt hat, muss eine entsprechende Sortierung angestoßen werden (siehe Zeile 156).
                                      saeft_2003 Most Active @Scrounger last edited by
                                      @Scrounger
                                      ok danke für die Info.
                                      @sigi234
                                      Bekommst du das hin? Ich habs zwar noch nicht probiert, aber ich habe da doch meine selbstzweifel...
                                      • Stephan Schleich
                                        Stephan Schleich last edited by Stephan Schleich
                                        Wenn man die View etwas verkleinert aber die Listenelementr pro Zeile gleich lässt kommt bei mir ein Anzeige Fehler (ändert man die Listenelemente (weniger) ist der Fehler weg) - Nur zur Info.
                                          Nö, das würde ich eher @Scrounger überlassen. 😀
                                            Kuddel last edited by
                                            Wo genau finde ich die aktuelle Version vom Skript ?
                                            view view adapter
                                            31
                                            212
                                            33749
