    4. Vorstellung meiner VIS-Oberfläche
      saeft_2003 Most Active @Negalein last edited by saeft_2003
      @Negalein sagte in Vorstellung meiner VIS-Oberfläche:
      @saeft_2003 sagte in Vorstellung meiner VIS-Oberfläche:
      Gefällt mir auch gut. Wie bekommst du den Rahmen von dem popup dialog fenster dunkel hin? Bei mir ist der immer weis. Kannst du mir evtl das widget mal exportieren?
      Danke dir!
      Der dunkle Rahmen kommt mWn vom eingestelltem Thema.
      Bei mir ist es dot-luv
      [{"tpl":"tplContainerIconDialog","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/Akkuleer.png","class":"","contains_view":"091_Batterien_Tabelle","modal":true,"dialog_width":"720","dialog_height":"560","dialog_top":"100","dialog_left":"240","overflowX":"hidden","overflowY":"hidden","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"484px","top":"11px","width":"36px","height":"23px","z-index":"2"},"widgetSet":"jqui"}]
      Schei*** wars. Ich hab jetzt die 1.2.4 installiert. Dein widget verwendet und das Thema eingestellt. Dabei ändert sich die Farbe vom Button aber nicht vom dialog der sich öffnet.
      Hast du noch eine Idee?
      Negalein Glasfaser 3 Replies Last reply Reply Quote 0
      • Negalein
        Negalein Global Moderator @saeft_2003 last edited by
        Leider nicht.
        • Negalein
          hab das gerade gefunden.
          Probiers mal aus.
          • Glasfaser
            Glasfaser @saeft_2003 last edited by
            @saeft_2003
            Alle VIS Seiten von dir müssen auf das Thema umgestellt werden , erst dann funktioniert es mit dem PopUp Fenster !!
            S 2 Replies Last reply Reply Quote 1
              saeft_2003 Most Active @Glasfaser last edited by
              @Glasfaser
              Ok werde ich nachher probieren. Schonmal danke 😊
              • Glasfaser
                Glasfaser @saeft_2003 last edited by Glasfaser
                @saeft_2003
                Das Thema hatte ich erst letztens .... es liegt nur an dem Popup Widget ... wiso warum 🤔 !?
                Link Text
                  @Glasfaser sagte in Vorstellung meiner VIS-Oberfläche:
                  @saeft_2003
                  Danke 😊 das war die Lösung 👍
                  Was jetzt nur doof ist wenn ich schauen will welches Thema mir am besten gefällt muss ich jedes mal alle views umstellen?!
                  • Glasfaser
                    @saeft_2003
                    Hier mit "dark-hive" ... da tut sich nicht viel ....
                    ( In Spoiler gesetz ... damit der Thread klein bleibt 😉 )
                      Conquest last edited by
                      @Negalein
                      Sehr schöne VIS. Würdest du einen Export bereitstellen? Kann ich mir bestimmt wieder einiges abschauen 😊
                      • Negalein
                        Negalein Global Moderator @Conquest last edited by
                        @Conquest sagte in Vorstellung meiner VIS-Oberfläche:
                        Willst du alles oder nur bestimmte Seiten?
                          Conquest @Negalein last edited by
                          Wenn der Export funktioniert würde ich alles nehmen 👍
                          Danke.
                          S Negalein 2 Replies Last reply Reply Quote 0
                            saeft_2003 Most Active @Conquest last edited by
                            Danke.
                            Würde mich interessieren ob bei dir der export von deiner ganzen VIS geht? Weil wenn ich das in verschiedenen Browser anklicke passiert erstmal nichts und kurz danach crashen alle Adapter...
                            https://forum.iobroker.net/topic/30404/projektexport-funktioniert-nicht-instanzen-crashen
                            • Negalein
                              gerade versucht.
                              Funktioniert leider nicht. weder normal, noch anonymisiert.
                              Adapter crashen bei mir nicht. Aber Export funktioniert nicht. Egal welcher Browser.
                                @Negalein
                                Firefox hat bis jetzt eigentlich immer funktioniert. Dauert nur ewig bis der Download startet.
                                Schade.
                                • Negalein
                                  Ich versuchs jetzt mal auf einer anderen Maschine.
                                  Wenns wieder nicht klappt, stell ich die Exporte der Views rein.
                                  • Negalein
                                    @Conquest
                                    Ich hab im 1. Beitrag einiges ergänzt.
                                    Probier mal bitte aus
                                      @Conquest
                                      Super danke.
                                      Import hat funktioniert.
                                      • Negalein
                                        Perfekt
                                          wasi last edited by
                                          @Negalein
                                          Sehr schöne Vis. Ein dickes Lob!
                                          Könntest Du Deine googleChartWeatherGraph.html noch einstellen bitte.
                                          Die wurde beim Projektexport nicht mitgenommen, da sie wohl in vis.0/ liegt.
                                          Danke!
                                          • Negalein
                                            Negalein Global Moderator @wasi last edited by Negalein
                                            @wasi sagte in Vorstellung meiner VIS-Oberfläche:
                                            Da benötigst du das Script.
                                            ist im Ordner Wetter
                                            Oder nimms gleich von hier
                                            * Script, um mittels Google Charts einen Wetter-Graph anzuzeigen
                                            * Change Log:
                                            *  0.1 Mic - Initial Release
                                            * Autor: Mic (ioBroker-Forum) / Mic-M (Github)
                                            * Quelle: https://github.com/Mic-M/iobroker.google-charts-example/
                                            * Support: https://forum.iobroker.net/topic/22779/vorlage-google-charts-beispiel
                                            * Konfiguration
                                            // Der Pfad der HTML-Datei, einfach entsprechend anpassen.
                                            // In VIS dann etwa folgenden Pfad im iFrame-Widget einfügen: '/vis.0/M3/googleChartWeatherGraph.html',
                                            // also nur den hinteren Abschnitt ab '/vis.....'
                                            const FILE_PATH = '/opt/iobroker/iobroker-data/files/vis.0/googleChartWeatherGraph.html';
                                            // Schedule
                                            const M_SCHEDULE = '5 1 * * *'; // Um 1:05 Uhr jeden Tag
                                            * Executed on every script start.
                                            let mSchedule;
                                            main();
                                            function main() {
                                                // Write the file initially on script start
                                                writeWeatherHtml();
                                                // Update file per schedule
                                                clearSchedule(mSchedule);
                                                mSchedule = schedule(M_SCHEDULE, writeWeatherHtml);
                                            function writeWeatherHtml() {
                                                // Requiring fs module in which writeFile function is defined.
                                                const fs = require('fs');
                                                // Write data in 'Output.txt' .
                                                fs.writeFile(FILE_PATH, buildHTML(), (err) => {
                                                    if (err) throw err; // In case of a error throw err.
                                            function buildHTML() {
                                                let html = '';
                                                html += '<html>\n';
                                                html += '<script type="text/javascript" src="https://www.gstatic.com/charts/loader.js"></script>\n';
                                                html += '<script type="text/javascript">\n';
                                                html += "google.charts.load('current', {'packages':['corechart']});\n";
                                                html += "google.charts.setOnLoadCallback(drawChart);\n";
                                                html += "function drawChart() {"; + "\n";
                                                html += "var data = new google.visualization.DataTable();\n";
                                                html += "data.addColumn('string', 'Temperature');\n";
                                                html += "data.addColumn('number', 'Minimum');\n";
                                                html += "data.addColumn({type: 'number', role: 'annotation'});\n";
                                                html += "data.addColumn('number', 'Maximum');\n";
                                                for (let i = 1; i <= 7; i++) {
                                                    let day = (i === 1) ? 'Heute' : getState('daswetter.0.NextDays.Location_1.Day_' + i + '.Tag_value').val.substr(0, 2);
                                                    let tHigh = getState('daswetter.0.NextDays.Location_1.Day_' + i + '.Maximale_Temperatur_value').val;
                                                    let tLow  = getState('daswetter.0.NextDays.Location_1.Day_' + i + '.Minimale_Temperatur_value').val;
                                                    html += "    data.addRow(['" + day + "', " + tLow + ", " + tLow + ", " + tHigh + ", " + tHigh + "]);\n";
                                            // See: https://developers.google.com/chart/interactive/docs/gallery/linechart#configuration-options
                                                html += "var options = {\n";
                                                html += "    curveType: 'function', backgroundColor: 'transparent', pointSize: 4,\n";
                                                html += "    hAxis: {textStyle:{color:'white'}},\n";
                                                html += "    vAxis: { textPosition: 'none', textStyle:{color:'red'},\n";
                                                html += "    baselineColor:'transparent', gridlines:{count:0} }, legend: { position: 'none' },\n";
                                                html += "    annotations: { stem: { length: 5, color: 'transparent' }, textStyle: {fontSize: 10, alwaysOutside: true, bold: false} }\n";
                                                html += "};\n";
                                                html += "var chart = new google.visualization.LineChart(document.getElementById('mychart'));\n";
                                                html += "chart.draw(data, options);\n";
                                                html += "}\n";
                                                html += "</script>\n";
                                                html += '<div id="mychart" style="width: 420px; height: 210px;"></div>\n';
                                                html += '</html>\n';
                                                return html;
                                            51
                                            9609
