    4. View Adapter Status
    View Adapter Status
    • Glasfaser
      Glasfaser @Negalein last edited by Glasfaser
      @Scrounger
      Mein View geht im Popup Widget auf ... kann aber nichts anwählen über die Select , dort geht nichts auf.
      Normaler View geht :
      Geht das nicht über ein Popup !?
      • Scrounger
        Scrounger Developer @Glasfaser last edited by
        @Glasfaser sagte in View Adapter Status:
        Was meinst du mit Popup? Welches Widget?
        Mach am besten mal nen export.
        • Glasfaser
          Glasfaser @Scrounger last edited by
          @Scrounger
          Sorry habe ich vergessen .. Container Dialog
          [{"tpl":"tplContainerDialog","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"contains_view":"AdapterStatus","dialog_width":"1400","dialog_height":"782","title":"Adapter Status","dialog_top":"0","dialog_left":"0","modal":false,"noHeader":false,"class":"","name":"Adapterstatus Popup","comment":"transparent Layout"},"style":{"left":"881px","top":"378px","background":"transparent","width":"197px","height":"90px","z-index":"20","border-color":"transparent","font-family":"Jura-DemiBold","font-size":"14px"},"widgetSet":"jqui"}]
          • Scrounger
            Scrounger Developer last edited by Scrounger
            Hab das skript oben nochmal geupdated
            https://forum.iobroker.net/topic/26533/view-adapter-status/142
            und folgende Funktionen hinzugefügt:
            • Sortierung nach x Sekunden zurücksetzen
            • Filter nach x Sekunden zurücksetzen
            Timer startet jedesmal, wenn man die Auswahl für Sortierung oder Filter ändert. Konfigurierbar / Deaktivierbar über
            let sortResetAfter = 120;                                                   // Sortierung nach X Sekunden auf sortReset zurücksetzen (0=deaktiviert)
            let sortReset = 'memHeapUsed'                                               // Sortierung auf die zurückgesetzt werden soll
            let filterResetAfter = 120;                                                 // Filter nach X Sekunden zurücksetzen (0=deaktiviert)
            @Scrounger
            Muss ich mir in Ruhe anschauen, tippe auf einen Bug im Select Widget. Bitte erstellt dazu einen issue auf git, dann vergesse ich es nicht.
            Scrounger Negalein 2 Replies Last reply Reply Quote 0
            • Scrounger
              Scrounger Developer @Scrounger last edited by
              @Scrounger
              Ok ist nur ein z-index problem. Musst für die beiden Select Widgets nur den z-index erhöhen, hab ihn einfach mal auf 1000 gesetzt, dann wirds angezeigt.
              • Negalein
                Negalein Global Moderator @Scrounger last edited by
                @Scrounger sagte in View Adapter Status:
                Muss das ganze Script ausgetauscht werden, oder reicht es die besagten Zeilen einzufügen?
                • Scrounger
                  Scrounger Developer @Negalein last edited by
                  @Negalein sagte in View Adapter Status:
                  Das ganze Skript
                  • Glasfaser
                    Glasfaser @Scrounger last edited by Glasfaser
                    @Scrounger
                    Sorry ... habe alles gemacht auch mal auf 9999 Z-Index gesetzt ....immer das gleiche
                    Habe auch ein ContainerIconDialog genommen , dort auch das gleiche ,
                    [{"tpl":"tplContainerIconDialog","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/negalein/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/negalein/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/negalein/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/negalein/Akkuleer.png","class":"","contains_view":"AdapterStatus","modal":true,"dialog_width":"1400","dialog_height":"782","dialog_top":"0","dialog_left":"0","overflowX":"hidden","overflowY":"hidden","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"791px","top":"403px","width":"36px","height":"23px","z-index":"2"},"widgetSet":"jqui"}]
                    das merkwürdige ist , wenn man den Select-Widget im Popup aufklappt sieht man den weißen Rand der runtergeht und schließt man den Popup ist die Auflistung im Hintergrund noch auf .
                    • Scrounger
                      @Glasfaser
                      Das dropdown wird hinter dem popup nach dem öffnen angezeigt.
                      Bin mir sicher das des ein z-index thema ist.
                      Bei mir gehts, auch mit ContainerIconDialog
                      Glasfaser 1 Reply Last reply Reply Quote 1
                      • Glasfaser
                        @Scrounger
                        Danke ... dein Popup Video hat mich gerade darauf gebracht ...
                        Ich habe ein anderes Design von Material Design CSS V1 ,
                        dort ist mir gerade aufgefallen , das im Skript der Fehler liegt , da wenn ich es entferne dann wird der Select-Widget richtig geöffnet .
                        Habe mal zum Test das neue Material Design CSS V2 Skript eingefügt , dort ist der Fehler auch
                        Hast du eine Idee wo der Fehler sein könnte ??
                        SKRIPT :
                          Material Design JS for ioBroker.vis
                          (c) 2017 Uhula, MIT License
                          https://github.com/Uhula/ioBroker-Material-Design-Style
                          V1.7 28.12.2017
                          o Korrektur mdui-lnav/rnav. Funktionierte mit mdui-toggle nicht korrekt
                          V1.6 16.10.2017
                          O _toggleFullscreen geändert, damit die function auch im ioBroker
                                          fullscreen Mode funktioniert
                          o Delegator-Eventhandler für body gesetzt (bisher #vis_container, wirkten dann aber in Dialogen nicht)
                          V1.5 11.10.2017
                          o MDUI.handleTables fertig
                          V1.3 24.09.2017
                          + MDUI.handleTables hinzu (in Entwicklung)
                          V1.0 01.09.2017
                        // Zur sicheren CSS-Erkennung der Runtime eine CSS-Klasse anlegen
                        document.documentElement.className +=  " mdui-runtime";
                        // Überprüfen ob touch zur Verfügung steht und entsprechend eine
                        // CSS Klasse touch bzw no-touch erzeugen
                           (("ontouchstart" in document.documentElement) ? " mdui-touch" : " mdui-notouch");
                          MDUI
                          Sammlung von JS-Funktionen für das Material Design
                        var MDUI = (function () {
                        var isSubtreeModified = false;
                        // liefert den suffix einer gegeben class zurück-Navigieren
                        // Bsp: mdui-target-w00002 -> w00002
                        //      mdui-zoom-to-200 -> 200
                        function _getClassSuffix( $ele, classname ) {
                           var suf = "";
                           if ($ele) {
                               var c = $ele.attr( "class" );
                               suf = c.substr(c.indexOf(classname)+classname.length,1000)+" ";
                               suf = suf.substr(0,suf.indexOf(" "));
                           return suf;
                        function _getGroupID( ele ) { return _getClassSuffix(ele, "mdui-group-" ); }
                        function _getTargetID( ele ) { return _getClassSuffix(ele, "mdui-target-" ); }
                        function _getScrollbarWidth() {
                           var $outer = $('<div>').css({visibility: 'hidden', width: 100, overflow: 'scroll'}).appendTo('body'),
                               widthWithScroll = $('<div>').css({width: '100%'}).appendTo($outer).outerWidth();
                           $outer.remove();
                           return 100 - widthWithScroll;
                        function _getScrollbarHeight() {
                           var $outer = $('<div>').css({visibility: 'hidden', height: 100, overflow: 'scroll'}).appendTo('body'),
                               heightWithScroll = $('<div>').css({height: '100%'}).appendTo($outer).outerHeight();
                           $outer.remove();
                           return 100 - heightWithScroll;
                        function _formatDatetime(date, format) {
                           function fill(comp) {
                               return ((parseInt(comp) < 10) ? ('0' + comp) : comp)
                           var months = ['Jan', 'Feb', 'Mär', 'Apr', 'Mai', 'Jun', 'Jul', 'Aug', 'Sep', 'Okt', 'Nov', 'Dez'];
                           var d = format;
                           var o = {
                                   "y+": date.getFullYear(), // year
                                   "m+": fill(date.getMonth()+1), //month
                                   "M+": months[date.getMonth()], //month
                                   "d+": fill(date.getDate()), //day
                                   "H+": fill((date.getHours() > 12) ? date.getHours() % 12 : date.getHours()), //hour
                                   "h+": fill(date.getHours()), //hour
                                   "n+": fill(date.getMinutes()), //minute
                                   "s+": fill(date.getSeconds()), //second
                                   "S+": fill(date.getMilliseconds()), //millisecond,
                                   "b+": (date.getHours() >= 12) ? 'PM' : 'AM'
                           for (var k in o) {
                               if (new RegExp("(" + k + ")").test(format)) {
                                   d = d.replace(RegExp.$1, o[k]);
                           return d;
                        // alle Elemente mit class "mdui-group-XXX" togglen, in denen
                        // XXX aus class "mdui-group-XXX" des ele ist UND
                        // alle Elemente mit class "mdui-target-XXX" togglen, in denen
                        // XXX aus class "mdui-target-XXX" des ele ist
                        function _toggleVisibility( $ele ) {
                           $ele.toggleClass("ui-state-active");
                           var id = _getGroupID( $ele );
                           if (id!=="")
                               $("[class*='mdui-group-"+id+"']").not("[class*='mdui-toggle']").each( function (index) {
                                   $(this).toggleClass("mdui-hide");
                           id = _getTargetID( $ele );
                           if (id!=="")
                               $( "[class*='mdui-target-"+id+"']").not("[class*='mdui-toggle']").each( function (index) {
                        // das in ele class \"mdui-target-XXX\" angegeben Element mit der id \"XXX\"  wird
                        // - fullscreen angezeigt, wenn es noch nicht fullscreen ist
                        // - wieder normal angezeigt, wenn es fullscreen ist
                        function _toggleFullscreen( $ele ){
                           if (!$ele) return;
                           var $target = $ele.closest(".vis-view");
                           if (!$target) return;
                           var styleold = $target.attr("styleold");
                           if (styleold) {
                               $target.attr("style",styleold);
                               $target.removeAttr("styleold");
                               $target.appendTo(".mdui-id-"+$target.attr("id"));
                               } else {
                                   $target.parent().addClass("mdui-id-"+$target.attr("id"));
                                   $target.attr("styleold",$target.attr("style"));
                                   $target.attr("style","position:fixed; left:0; top:0; width:100%; height:100%; z-index: 2147483647 !important;background:#212121 !important; ");
                                   $target.appendTo( "body" );
                                   //$target.appendTo( "body #vis_container" );
                        // ele muss class Einträge für das Target und den Skalierungsmodus haben
                        // "mdui-target-(id) mdui-scale-(scalemode)"
                        // id: Ziel-Element mit id=id, welches ein zu skalierendes img enthält
                        // scalemode: fit / hfit / vfit / in / out / (number)
                        // number: Zahl in %
                        function _scale( ele ) {
                           var id = _getTargetID( ele );
                           var $img = $( "#"+id+" img" );
                           if ($img) {
                               var scale = _getClassSuffix(ele, "mdui-scale-" );
                               $img.width("1px"); // Scrollbars entfernen um die echte Höhe zu bekommen
                               $img.height("1px");
                               var dim = {
                                   pw : $img.parent().width(),
                                   ph : $img.parent().height(),
                                   w  : $img[0].naturalWidth,
                                   h  : $img[0].naturalHeight
                               switch(scale) {
                                   case "fit":
                                       if (dim.pw / dim.w < dim.ph / dim.h ) scale = dim.pw / dim.w;
                                       else scale = dim.ph / dim.h;
                                       break;
                                   case "hfit":
                                       else scale = (dim.pw - _getScrollbarWidth() - 4  ) / dim.w;
                                       break;
                                   case "vfit":
                                       if ( dim.pw / dim.w > dim.ph / dim.h ) scale = dim.ph / dim.h;
                                       else scale = (dim.ph - _getScrollbarHeight() - 4  ) / dim.h;
                                       break;
                                   case "in":
                                   case "out":
                                       var old = $img.attr( "style" );
                                       old = old.substr(old.indexOf("scale(")+6,20);
                                       old = old.substr(0,old.indexOf(")"));
                                       if (old * 1==0) scale = 1;
                                       else if (scale=="in") scale = old * 1.41;
                                            else scale = old / 1.41;
                                       break;
                                   default:
                                       if (scale<=0 || scale>10000)
                                           scale = 100;
                                       scale = scale/100;
                               scale = Math.round(scale*100)/100;
                               $img.attr( "style", "position:absolute;top:0;left:0;transform-origin:0 0;transition: transform 0.3s ease-out; transform:scale("+scale+");" );
                        // ersetzt im src-Attribute des Unter-Elements von (id) den "&range=&
                        // durch den Wert des in ele angegebenen (span). Für flot-Diagramme
                        // "mdui-target-(id) mdui-timespan-(span)"
                        // id: Ziel-Element mit id=id, welches das flot (src) enthält
                        // span: inc / dec / (number)
                        // number: Zahl in Minuten
                        function _timespan( ele ) {
                           var target = $( "#"+id+" [src]" );
                           if (target) {
                               var timespan = _getClassSuffix(ele, "mdui-timespan-" );
                               var src = target.attr( "src" );
                               var min = src.substr(src.indexOf("&range=")+7,20);
                               min = min.substr(0,min.indexOf("&"));
                               switch(timespan) {
                                   case "inc":
                                       min = min * 2;
                                       break;
                                   case "dec":
                                       min = min / 2;
                                       break;
                                   default:
                                       if ( timespan<=0 )
                                           timespan = 1440;
                                       min = timespan;
                               src = src.replace(/&range=[0-9]*&/g, "&range="+min+"&");
                               target.attr("src",src);
                        function _resetTable( $ele, $table ) {
                           $ele.removeClass("mdui-table-tile");
                           $ele.removeClass("mdui-table-card");
                           $ele.removeClass("mdui-table-list");
                           $table.find("tbody>tr").each( function(index) {
                               $(this).width("auto");
                               $(this).height("auto");
                               $(this).find("td").each( function(index) {
                                   $(this).attr("labelth","");
                        function _handleTable( $ele, $table, opt ) {
                           function setColWidth( colwidth ) {
                                   $(this).outerWidth(colwidth);
                           function setColHeight() {
                               var height = 0;
                                   if ($(this).height() > height ) height = $(this).height();
                               if ( height > 0 )
                                       $(this).height( height );
                           var innerWidth = $ele.innerWidth();
                           _resetTable($ele, $table);
                           $ele.addClass("mdui-table-"+opt.type);
                           if (opt.label) {
                               // Zellen mit Labels aus <th> ergänzen ?
                               var labels = [];
                               $table.find("thead>tr>th").each( function(index) {
                                   labels[index] = $(this).text();
                                       if (index < labels.length)
                                           $(this).attr("labelth",labels[index]);
                           if (opt.colwidth>1) setColWidth(opt.colwidth);
                           if (opt.colwidth>2) setColHeight();
                           return true;
                        /* Alle mdui-table durchlaufen und überprüfen, ob die minimale Width erreicht
                        wurde um sie in den responsive State zu überführen
                        mdui-table-(mode)(-opt1)(-opt2)...(-optn)
                        mdui-table-ascard-r600-w200-l */
                        function _handleTables( ) {
                           $("[class*='mdui-table ']").each( function (index) {
                               var $ele = $(this);
                               var $table;
                               $table = $ele;
                               if (!$table.is("table")) $table=$table.find("table");
                               if (!$table.is("table")) return true; // next each
                               var classes = $ele.attr("class")
                                   .split(" ")
                                   .filter( function ( ele ) {
                                           return  (ele.indexOf("mdui-table-ascard") > -1)
                                                || (ele.indexOf("mdui-table-astile") > -1)
                                                || (ele.indexOf("mdui-table-aslist") > -1); });
                               var opts = [];
                               var opt;
                               for (var i = 0; i < classes.length; i++) {
                                   opts[i] = [];
                                   opts[i].reswidth = 9999;
                                   opts[i].colwidth = 0;
                                   opts[i].label = false;
                                   opts[i].type = classes[i].substr(13,4);
                                   opt = classes[i].substr(18,200).split("-");
                                   for (var j = 0; j < opt.length; j++) {
                                       switch(opt[j][0]) {
                                       case "r":
                                           opts[i].reswidth = parseInt(opt[j].substr(1,5));
                                           break;
                                       case "w":
                                           opts[i].colwidth = parseInt(opt[j].substr(1,5));
                                           break;
                                       case "c":
                                           if (opts[i].colwidth>0) opts[i].colwidth = (innerWidth-_getScrollbarWidth()-8) / opts[i].colwidth;
                                           break;
                                       case "l":
                                           opts[i].label = true;
                                           break;
                                       default:
                               opts.sort(function(a, b){return a.reswidth-b.reswidth});
                        //console.log(opts);
                               if (opts.length === 0) return true; // next each
                               var handled = false;
                               for (i = 0; i < opts.length; i++) {
                                   if ( innerWidth < opts[i].reswidth )
                                      handled = _handleTable( $ele, $table, opts[i]);
                                   if (handled) break;
                               if (!handled) _resetTable($ele, $table);
                        // DOM SubTree-Änderungen einmalig alle 500ms auswerten (diese Events werden
                        // u.U. 1000-fach gefeuert und müssen deswegen verzögert ausgeführt werden)
                        function _onSubTreeModified( $ele ) {
                           if (!isSubtreeModified) {
                               isSubtreeModified = true;
                               setTimeout(function () {
                                   _handleTables();
                                   isSubtreeModified=false;
                               }, 500);
                        return {
                           toggleVisibility: _toggleVisibility,
                           toggleFullscreen: _toggleFullscreen,
                           scale: _scale,
                           timespan: _timespan,
                           handleTables: _handleTables,
                           onSubTreeModified : _onSubTreeModified
                        // Eventhandler für body-Delegators setzen (früher:#vis_container)
                           // click-Event für das left-nav Element zum Öffnen
                           $("body").on( "click", ".mdui-lnavbutton", function() {
                               $( ".mdui-lnav" ).addClass( "mdui-lnav-open" );
                           // click-Event für die left-nav zum Schließen
                           $("body").on( "click", ".mdui-lnav", function() {
                               $( ".mdui-lnav" ).removeClass( "mdui-lnav-open" );
                           // click-Event für das right-nav Element zum Öffnen
                           $("body").on( "click", ".mdui-rnavbutton", function() {
                               $( ".mdui-rnav" ).addClass( "mdui-rnav-open" );
                           // click-Event für die right-nav zum Schließen
                           $("body").on( "click", ".mdui-rnav", function() {
                               $( ".mdui-rnav" ).removeClass( "mdui-rnav-open" );
                           // click-Eventhandler für "mdui-scale-" setzen
                           $("body").on( "click", "[class*='mdui-scale-']", function(event) {
                               MDUI.scale( $(this) );
                           // click-Handler für "mdui-toggle"
                           $("body").on( "click", ".mdui-toggle", function(event) {
                               event.preventDefault();
                               event.stopImmediatePropagation();
                               MDUI.toggleVisibility( $(this) );
                           // click-Handler für "mdui-fullscreen"
                           $("body").on( "click", ".mdui-fullscreen", function(event) {
                               MDUI.toggleFullscreen( $(this) );
                           // click-Handler für "mdui-timepsan-"
                           $("body").on( "click", "[class*='mdui-timespan-']", function(event) {
                               MDUI.timespan( $(this) );
                           $( window ).on("resize", function() {
                             MDUI.handleTables();
                           // Überwachen des #vis_containers auf Änderungen (z.B. wenn views nachgeladen
                           // werden)
                           $( "#vis_container" ).on( "DOMSubtreeModified", function(event) {
                               MDUI.onSubTreeModified( $(this) );
                           // für den ersten load einmal aufrufen
                           MDUI.onSubTreeModified( );
                        }, 1000);
                        • Scrounger
                          @Glasfaser
                          Nee sorry, hab mich mit Material Design CSS noch nie beschäftigt.
                          • Glasfaser
                            @Scrounger
                            Kein Problem , aber trotzdem wurde der Fehler dadurch eingekreißt .
                            Danke ....für deine Mühe 🙂
                            • ub.privat
                              ub.privat last edited by
                              @Scrounger
                              Guten entspannten Guten Abend!
                              Mit meinem langsam wachsendem Verständnis in der Anwendung deiner MEISTERWERKE versuche ich mich wieder mal.
                              Der Adapter-View ist ganz großes Kino. Leider verende ich beim "Trailer".
                              Was habe ich bisher gemacht:
                              1. notwendige Einstellungen im JS Adapter vorgenommen:
                              2. Script eingestellt:
                                Leider mit Warnungen...
                              3. Datenpunkte angelegt:
                                Leider werden keine Werte erzeugt.
                              4. View importiert:
                                Mit entsprechender Warnung.
                              5. NUN IST GUTER RAT TEUER - wo mache ich wie weiter????
                                Lesse den Tread hoch und runter, aber die Erleeuchtung will sich nicht einstellen...
                              sigi234 Scrounger Glasfaser 3 Replies Last reply Reply Quote 0
                                sigi234 Forum Testing Most Active @ub.privat last edited by sigi234
                                @ub-privat
                                Hast du die Aktuelle Version? 0.2.62
                                ub.privat 1 Reply Last reply Reply Quote 0
                                • Scrounger
                                  Scrounger Developer @ub.privat last edited by Scrounger
                                  @ub-privat
                                  Hast du das skript 1:1 kopiert?
                                  Die Fehlermeldung bezieht sich auf Zeile 518-520 - das skript hat aber nur 339 Zeilen.
                                  Und laut deinem Screenshot hast du irgendwas an dem Skript verändert. Weil ab Zeile 8 müssten die settings zu sehen sein.
                                  Und bitte das vollständige log posten, also aus dem reiter 'log' im admin bereich.
                                  ub.privat sigi234 2 Replies Last reply Reply Quote 0
                                  • ub.privat
                                    ub.privat @sigi234 last edited by
                                    @sigi234
                                    Ja, habe ich!
                                    • ub.privat
                                      ub.privat @Scrounger last edited by
                                      @Scrounger
                                      Bin mir keiner Änderung bewußt!
                                      Würdest du das AKTUELLESTE Script nochmals bitte verlinken!?
                                      DANKE.
                                      • ub.privat
                                        @Scrounger
                                        Habe dieses Script verwendet und das hat nach dem kopieren 679 Zeilen
                                        Leerzeilen sind natürlich mitgezählt...
                                          @ub-privat sagte in View Adapter Status:
                                          @Scrounger
                                          DANKE.
                                          Edit: Falsches Skript gewesen.
                                            sigi234 Forum Testing Most Active @Scrounger last edited by
                                            Ich habe 310?
                                            view view adapter
                                            31
                                            212
                                            33730
