    • simatec
      simatec Developer Most Active @LJSven last edited by
      @LJSven sagte in Test Adapter Backitup v1.3.x:
      mysqldump
      mysqldump auf dem Master installieren hilft bei deinem Problem
      sudo apt-get install mysql-client
        sigi234 Forum Testing Most Active @simatec last edited by
        @simatec
        System erfolgreich zurückgesetzt! 👍
        simatec 1 Reply Last reply Reply Quote 1
          LJSven @simatec last edited by
          @simatec
          Ist der jetzt richtig durchgelaufen? Das Fenster schließt sich nicht ->
          [DEBUG] [iobroker] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerMini","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"dbName":"iobroker","user":"LJSven","pass":"****","deleteBackupAfter":"5","host":"192.168.178.44","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"10","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"longTelegramNotice","User":null,"onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"","emailSender":"","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
          [DEBUG] [iobroker] - host.tinkerboardmaster 8231 states saved
          [DEBUG] [iobroker] - host.tinkerboardmaster 9474 objects saved
          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2020_02_10-12_13_48_ioBrokerMini_backupiobroker.tar.gz
          [DEBUG] [iobroker] - done
          [DEBUG] [mysql] - Packed 11MB so far...
          [DEBUG] [mysql] - done
          [DEBUG] [mysql] - MySql File deleted!
          [DEBUG] [ftp] start with {"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21","deleteBackupAfter":0}
          [DEBUG] [ftp] - FTP connected.
          [DEBUG] [ftp] - Send iobroker_2020_02_10-12_13_48_ioBrokerMini_backupiobroker.tar.gz
          [DEBUG] [ftp] - Send mysql_2020_02_10-12_14_06_backupiobroker.tar.gz
          [DEBUG] [ftp] - done
          [DEBUG] [clean] - done
          [DEBUG] [telegram] - [iobroker] used Telegram-Instance: telegram.0
          [DEBUG] [telegram] - done
          [DEBUG] [history] - backitup.0.history.html
          [EXIT] 0
          [DEBUG] [telegram] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerMini","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"dbName":"iobroker","user":"LJSven","pass":"****","deleteBackupAfter":"5","host":"192.168.178.44","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"10","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"longTelegramNotice","User":null,"onlyError":true,"telegramWaiting":0,"systemLang":"de","time":"10. Februar 2020 um 12:15 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"","emailSender":"","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
          [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerMini","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"dbName":"iobroker","user":"LJSven","pass":"****","deleteBackupAfter":"5","host":"192.168.178.44","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"10","systemLang":"de","time":"10. Februar 2020 um 12:15 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"longTelegramNotice","User":null,"onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"","emailSender":"","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
          • simatec
            @LJSven
            Ja alles korrekt ...
            • simatec
              simatec Developer Most Active @sigi234 last edited by
              @sigi234 sagte in Test Adapter Backitup v1.3.x:
              @simatec
              Sehr gut ... WebIf geht also auch ...👍
              • StM47
                StM47 last edited by
                Moin,
                was besagt folgende Fehlermeldung aus?
                host.ioBroker	2020-02-26 12:09:35.512	info	Restart adapter system.adapter.backitup.0 because enabled
                host.ioBroker	2020-02-26 12:09:35.511	error	instance system.adapter.backitup.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.ioBroker	2020-02-26 12:09:35.511	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                host.ioBroker	2020-02-26 12:09:35.511	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                host.ioBroker	2020-02-26 12:09:35.511	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                host.ioBroker	2020-02-26 12:09:35.511	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                host.ioBroker	2020-02-26 12:09:35.510	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                host.ioBroker	2020-02-26 12:09:35.510	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/googleapis/build/src/apis/dfareporting/index.js:17:16)
                host.ioBroker	2020-02-26 12:09:35.510	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                host.ioBroker	2020-02-26 12:09:35.509	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
                host.ioBroker	2020-02-26 12:09:35.509	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                host.ioBroker	2020-02-26 12:09:35.509	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                host.ioBroker	2020-02-26 12:09:35.508	error	Caught by controller[0]: Error: Cannot find module './v3.3'
                host.ioBroker	2020-02-26 12:09:35.508	error	Caught by controller[0]: ^
                host.ioBroker	2020-02-26 12:09:35.507	error	Caught by controller[0]: throw err;
                host.ioBroker	2020-02-26 12:09:35.507	error	Caught by controller[0]: internal/modules/cjs/loader.js:638
                host.ioBroker	2020-02-26 12:09:33.861	info	instance system.adapter.backitup.0 started with pid 2857
                • simatec
                  Auf Github liegt aktuell die Release Version 1.4.0.
                  Changelog
                  1.4.0 (27.02.2020)
                  • (simatec) added next Backup Time
                  • (simatec) added Name Suffix for mysql Backup
                  • (simatec) added more Options for mysql
                  • (simatec) added domain support for cifs
                  • (simatec) added json historystate
                  Wer Zeit und Lust hat, kann diese gerne mal testen, um mögliche Fehler noch vor Veröffentlichung im latest zu beheben.
                  J sigi234 2 Replies Last reply Reply Quote 0
                    Jan1 @simatec last edited by
                    @simatec
                    läuft 👍
                      sigi234 Forum Testing Most Active @simatec last edited by sigi234
                      @simatec sagte in Test Adapter Backitup v1.3.x:
                      Eine Null zu viel beim Datum
                      • simatec
                        @sigi234
                        Danke für dein Feedback. Wird noch vorm Release geändert.
                        Kannst du den Widget für die history mal posten?
                          Was genau?
                          • simatec
                            posten
                            Wäre Interessant, wie du den json state in deine VIS eingebunden hast ...
                            Die Zeitangabe sollte nun auf Github gefixt sein
                              @simatec
                              View_BackItup.txt
                              Überarbeitet, man braucht Vis-materialdesign
                              • simatec
                                @sigi234
                                Sieht sehr schick aus ... 👍
                                  @sigi234
                                  Danke, funktioniert bei dir Alles nach dem Import? Auch die Animation?
                                  simatec Negalein 2 Replies Last reply Reply Quote 0
                                  • simatec
                                    @sigi234
                                    Ich habe mir nur den Code angeschaut.
                                    Werde ich am WE mal testen.
                                    Mir ging es nur darum, ob in den state für die json alles passt
                                    • Negalein
                                      Negalein Global Moderator @sigi234 last edited by
                                      Auch die Animation?
                                      Apropo Animation.
                                      Die funktioniert bei mir nicht.
                                      Benötige ich da was spezielles?
                                      sigi234 Glasfaser 2 Replies Last reply Reply Quote 0
                                        sigi234 Forum Testing Most Active @Negalein last edited by
                                        @Negalein sagte in Test Adapter Backitup v1.3.x:
                                        Material Design Widget ab V 0.2.62
                                        • Glasfaser
                                          Glasfaser @Negalein last edited by Glasfaser
                                          @Negalein
                                          Du meinst bestimmt die Pfeilanimation
                                          Material Design CSS v2
                                          sigi234 Negalein 2 Replies Last reply Reply Quote 0
                                          • Negalein
                                            hab ich
                                            @Glasfaser sagte in Test Adapter Backitup v1.3.x:
                                            Genau
                                            Dann werde ich mal Uhalas CSS austauschen
                                            Thx
                                            80.8k
                                            170
                                            2779
                                            2316823
