    • simatec
      simatec Developer Most Active @LJSven last edited by
      @LJSven
      Ja alles korrekt ...
      • simatec
        simatec Developer Most Active @sigi234 last edited by
        @sigi234 sagte in Test Adapter Backitup v1.3.x:
        @simatec
        System erfolgreich zurückgesetzt! 👍
        Sehr gut ... WebIf geht also auch ...👍
        • StM47
          StM47 last edited by
          Moin,
          was besagt folgende Fehlermeldung aus?
          host.ioBroker	2020-02-26 12:09:35.512	info	Restart adapter system.adapter.backitup.0 because enabled
          host.ioBroker	2020-02-26 12:09:35.511	error	instance system.adapter.backitup.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.ioBroker	2020-02-26 12:09:35.511	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
          host.ioBroker	2020-02-26 12:09:35.511	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
          host.ioBroker	2020-02-26 12:09:35.511	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
          host.ioBroker	2020-02-26 12:09:35.511	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
          host.ioBroker	2020-02-26 12:09:35.510	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
          host.ioBroker	2020-02-26 12:09:35.510	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/googleapis/build/src/apis/dfareporting/index.js:17:16)
          host.ioBroker	2020-02-26 12:09:35.510	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
          host.ioBroker	2020-02-26 12:09:35.509	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
          host.ioBroker	2020-02-26 12:09:35.509	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:562:25)
          host.ioBroker	2020-02-26 12:09:35.509	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
          host.ioBroker	2020-02-26 12:09:35.508	error	Caught by controller[0]: Error: Cannot find module './v3.3'
          host.ioBroker	2020-02-26 12:09:35.508	error	Caught by controller[0]: ^
          host.ioBroker	2020-02-26 12:09:35.507	error	Caught by controller[0]: throw err;
          host.ioBroker	2020-02-26 12:09:35.507	error	Caught by controller[0]: internal/modules/cjs/loader.js:638
          host.ioBroker	2020-02-26 12:09:33.861	info	instance system.adapter.backitup.0 started with pid 2857
          • simatec
            Auf Github liegt aktuell die Release Version 1.4.0.
            Changelog
            1.4.0 (27.02.2020)
            • (simatec) added next Backup Time
            • (simatec) added Name Suffix for mysql Backup
            • (simatec) added more Options for mysql
            • (simatec) added domain support for cifs
            • (simatec) added json historystate
            Wer Zeit und Lust hat, kann diese gerne mal testen, um mögliche Fehler noch vor Veröffentlichung im latest zu beheben.
            J sigi234 2 Replies Last reply Reply Quote 0
              Jan1 @simatec last edited by
              @simatec
              läuft 👍
                sigi234 Forum Testing Most Active @simatec last edited by sigi234
                @simatec sagte in Test Adapter Backitup v1.3.x:
                Eine Null zu viel beim Datum
                • simatec
                  @sigi234
                  Danke für dein Feedback. Wird noch vorm Release geändert.
                  Kannst du den Widget für die history mal posten?
                    Was genau?
                    • simatec
                      posten
                      Wäre Interessant, wie du den json state in deine VIS eingebunden hast ...
                      Die Zeitangabe sollte nun auf Github gefixt sein
                        @simatec
                        View_BackItup.txt
                        Überarbeitet, man braucht Vis-materialdesign
                        simatec 1 Reply Last reply Reply Quote 1
                        • simatec
                          @sigi234
                          Sieht sehr schick aus ... 👍
                            @sigi234
                            Danke, funktioniert bei dir Alles nach dem Import? Auch die Animation?
                            simatec Negalein 2 Replies Last reply Reply Quote 0
                            • simatec
                              @sigi234
                              Ich habe mir nur den Code angeschaut.
                              Werde ich am WE mal testen.
                              Mir ging es nur darum, ob in den state für die json alles passt
                              • Negalein
                                Negalein Global Moderator @sigi234 last edited by
                                Auch die Animation?
                                Apropo Animation.
                                Die funktioniert bei mir nicht.
                                Benötige ich da was spezielles?
                                sigi234 Glasfaser 2 Replies Last reply Reply Quote 0
                                  sigi234 Forum Testing Most Active @Negalein last edited by
                                  @Negalein sagte in Test Adapter Backitup v1.3.x:
                                  Material Design Widget ab V 0.2.62
                                  • Glasfaser
                                    Glasfaser @Negalein last edited by Glasfaser
                                    @Negalein
                                    Du meinst bestimmt die Pfeilanimation
                                    Material Design CSS v2
                                    sigi234 Negalein 2 Replies Last reply Reply Quote 0
                                    • Negalein
                                      hab ich
                                      @Glasfaser sagte in Test Adapter Backitup v1.3.x:
                                      Genau
                                      Dann werde ich mal Uhalas CSS austauschen
                                      Thx
                                        sigi234 Forum Testing Most Active @Glasfaser last edited by
                                        @Negalein
                                        Jupp, die 2 verwechsel ich immer.
                                        • Negalein
                                          Negalein Global Moderator @Glasfaser last edited by
                                          Fuck, das war keine gute Idee.
                                          hat mir einiges im Design zerhaut. 😞
                                          • Glasfaser
                                            @Negalein
                                            Lass mich raten , die Popup Widget sehen besch.... aus 😉 , habe ich gestern auch bemerkt .
                                            Link Text
                                            Link Text
                                            170
                                            2780
                                            2373987
