    4. [Vorstellung] Meine dritte VIS
      G4l4h4d last edited by
      @Kuddel
      Hallo Kuddel, mich würde interessieren wie du deine Kameras eingebunden hast.
        Kuddel @G4l4h4d last edited by
        @G4l4h4d ich nutze das Widget jqui-mfd - Cam/Snapsh.
        MIt dem Widget hat man eine kleine Vorschau und wenn man drauf klickt ein Popup in Vollbild (je nach dem was man für Maße einstellt).
        Adapter:
        Widget Export:
        [{"tpl":"tplMfdCamSnapshot","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"true","visibility-groups-action":"hide","asButton":false,"interval":"500","dialog_width":"1200","dialog_height":"700","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"icon":"http://IP_DEINER_CAM:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=DEIN_USER&pwd=DEIN_PASSWORD","icon_interval":"1000","url":"http://IP_DEINER_CAM:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=DEIN_USER&pwd=DEIN_PASSWORD","title":"Balkon","modal":false,"invert_icon":false,"dialog_top":"45px","dialog_left":"5px","name":"Balkon","visibility-oid":"ping.0.ioBroker-MASTER.192_168_4_71"},"style":{"left":"47.5px","top":"37px","width":"145px","height":"82px","border-width":"2px","border-style":"solid","border-color":"white","border-radius":"10px","z-index":"30"},"widgetSet":"jqui-mfd"}]
        H G 2 Replies Last reply Reply Quote 0
          hofmannha @Kuddel last edited by
          @Kuddel
          Moin Kuddel,
          wie kann ich denn in Blockly aus 4 Datenpunkte zwei machen?
            sigi234 Forum Testing Most Active @hofmannha last edited by
            @hofmannha
            klick auf das blaue Symbol
              hofmannha @sigi234 last edited by
              @sigi234
              Ja habe ich. Und dann?
              Hinzufügen geht. Ich will zwei entfernen.
              H sigi234 2 Replies Last reply Reply Quote 0
                hofmannha @hofmannha last edited by
                @hofmannha sagte in [Vorstellung] Meine dritte VIS:
                @sigi234
                  @sigi234
                  Klick auf das im Rechten Feld das du entfernen willst und halte die linke Maustaste gedrückt und schiebe es nach links.
                  D H 2 Replies Last reply Reply Quote 0
                    DennisMenger @sigi234 last edited by
                    @sigi234 jetzt solltest du die nicht benötigten Objekte einfach markieren und entfernen können.
                      sigi234 Forum Testing Most Active @DennisMenger last edited by
                      @DennisMenger sagte in [Vorstellung] Meine dritte VIS:
                      Falscher User
                        @sigi234
                        geht nicht. Ich verschiebe damit ganze Blöcke.
                          G4l4h4d @Kuddel last edited by G4l4h4d
                          @Kuddel sagte in [Vorstellung] Meine dritte VIS:
                          Hallo Kuddel, danke für das Widget.
                          Frage: Kann ich auch den Link von der Synology Surveillance Station einbinden?
                          Dort habe ich nur einen rstp-link und kein http.
                          Wenn ich den Link einbinde öffnet sich leider keine Kamera.
                          Danke im Voraus!
                            @sigi234
                            Rechts klick Baustein aktivieren.
                              @sigi234
                              auck nicht. Damit aktiviere oder deaktiviere ich nur den kompl. Falls-Block.
                                @sigi234
                                Welche Version von JS Skript hast du?
                                  @sigi234
                                  Version 4.3.4
                                    @sigi234
                                    Starte mal Neu
                                      @sigi234
                                      habe meine RaspPi 4 komplett neu gestartet. Hat nichts gebracht.
                                        @sigi234
                                        Stell das Blockly mal rein
                                          @sigi234
                                          das Blockly ist das vis_status von Kuddel.
                                            saeft_2003 Most Active @Kuddel last edited by
                                            @Kuddel
                                            ich schließe mich an... eine sehr schöne VIS evtl. versuche ich auch mal das Top App Bar Widget.
                                            Eine andere Frage die nicht direkt was mit deiner VIS was zu tun hat. Ist der USG vor oder nach deiner fritzbox? Falls nach hast du dann NAT deaktiviert im USG?
                                            1.0k
                                            vis vis projekte
                                            83
                                            640
                                            172098
