    4. [Vorstellung] Meine dritte VIS
      hofmannha @sigi234 last edited by
      @sigi234
      geht nicht. Ich verschiebe damit ganze Blöcke.
        G4l4h4d @Kuddel last edited by G4l4h4d
        @Kuddel sagte in [Vorstellung] Meine dritte VIS:
        [{"tpl":"tplMfdCamSnapshot","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"true","visibility-groups-action":"hide","asButton":false,"interval":"500","dialog_width":"1200","dialog_height":"700","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"icon":"http://IP_DEINER_CAM:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=DEIN_USER&pwd=DEIN_PASSWORD","icon_interval":"1000","url":"http://IP_DEINER_CAM:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=DEIN_USER&pwd=DEIN_PASSWORD","title":"Balkon","modal":false,"invert_icon":false,"dialog_top":"45px","dialog_left":"5px","name":"Balkon","visibility-oid":"ping.0.ioBroker-MASTER.192_168_4_71"},"style":{"left":"47.5px","top":"37px","width":"145px","height":"82px","border-width":"2px","border-style":"solid","border-color":"white","border-radius":"10px","z-index":"30"},"widgetSet":"jqui-mfd"
        Hallo Kuddel, danke für das Widget.
        Frage: Kann ich auch den Link von der Synology Surveillance Station einbinden?
        Dort habe ich nur einen rstp-link und kein http.
        Wenn ich den Link einbinde öffnet sich leider keine Kamera.
        Danke im Voraus!
          sigi234 Forum Testing Most Active @hofmannha last edited by
          @hofmannha sagte in [Vorstellung] Meine dritte VIS:
          @sigi234
          Rechts klick Baustein aktivieren.
            @sigi234
            auck nicht. Damit aktiviere oder deaktiviere ich nur den kompl. Falls-Block.
              @sigi234
              Welche Version von JS Skript hast du?
                @sigi234
                Version 4.3.4
                  @sigi234
                  Starte mal Neu
                    @sigi234
                    habe meine RaspPi 4 komplett neu gestartet. Hat nichts gebracht.
                      @sigi234
                      Stell das Blockly mal rein
                        @sigi234
                        das Blockly ist das vis_status von Kuddel.
                          saeft_2003 Most Active @Kuddel last edited by
                          @Kuddel
                          ich schließe mich an... eine sehr schöne VIS evtl. versuche ich auch mal das Top App Bar Widget.
                          Eine andere Frage die nicht direkt was mit deiner VIS was zu tun hat. Ist der USG vor oder nach deiner fritzbox? Falls nach hast du dann NAT deaktiviert im USG?
                            Kuddel @saeft_2003 last edited by
                            @saeft_2003 USG ? Wie kommst du darauf, dass ich ein USG habe?
                            Ist geplant, aber nicht umgesetzt.
                            In der Netzwerkübersicht hängt an der FritzBox ein Unifi 8 Port Switch.
                              @Kuddel
                              Oh ich habe den kleinen unifi switch in deinem view mit dem USG verwechselt 😵
                              Planst du dann nach oder vor der fritzbox? Ich frag nur weil ich mir evtl. auch einen holen will und auch eine fritzbox nutze und kein extra Modem kaufen will...
                                @saeft_2003 da ich einen Kabelanschluss mit einer Fritzbox 6460 habe, ist das ja direkt kompliziert. daher habe ich mich noch nicht weiter damit beschäftigt. Wenn wird das USG aber hinter die FB kommen
                                  @Kuddel
                                  So ist auch mein plan. Nur dann muss man im USG NAT deaktivieren sonst hat man es doppelt.
                                    @sigi234
                                    hast Du mal nach dem Blockly geschaut?
                                      larsiwitschino2003 last edited by
                                      Hallo. Habe deine Vis importiert und mir ein paar Sachen "abgeschaut" und ein paar übernommen 🙂 Super klasse Arbeit und schön slchicht gehalten ! Dafür zunächst einmal 👍
                                      Ich habe ein Problem, was leider auch schon andere hatten aber bei mir die Lösung dazu nicht klappt. Es geht um die Verlinkung der Views für die Tabs. Ich bekomme immer die Meldung "Fehler: View wurde nicht gefunden" obwohl die View natürlich vorhanden ist und ich auch den Datenpunkt als aller erstes für die Navigation der Tabs zu den Views erstellt habe.
                                      Ich hab sogar deinen Datenpunkt verwendet. Dann einen weiteren erstellt, aber nichts hilft. Ich bekomme lediglich auf auf ein paar Tabs eine View angezeigt aber nicht auf allen 😕
                                      Was auch sehr kurios ist, wenn ich meine View verlinke auf Tab0 dann erscheint diese auch wenn ich den Tab anklicke. Verlinke ich die gleiche View mit meinem letzten Tab40, dann erscheint nur "Fehler: View wurde nicht gefunden". 😲
                                      Komisch ist auch das ich die View auf den 1. Tab 0 verlinken kann und auch dargestellt wird aber auf anderen Tabs nicht o_O
                                      Sitze schon seit mehreren Stunden daran aber finde einfach echt KEINEN Fehler. Anbei ein paar Screenshots der Vis.
                                      Habe den Datenpunkt in dem Widget für den App Drawer in der ObjektID verlinkt sowie in dem Widget "Widget in View 8".
                                      Danke, Danke im Voraus für die Hilfe 🙂
                                        Kuddel @larsiwitschino2003 last edited by
                                        @larsiwitschino2003 ich habe mir für die Navigation eine Excel Tabelle gebaut, da das ein bisschen undurchsichtig ist.
                                        Die Menüpunkte mit Unterpunkte erhalten auch eine ID, die man dann im View in Widget 8 frei lassen muss.
                                        Am besten lässt du dir mal alle IDs im Menü anzeigen:
                                        Und dann mal in der Runtime schauen, welche ID für welchen Eintrag steht:
                                        Zum Schluss dann noch gucken, die Views alle richtig verlinkt sind
                                          larsiwitschino2003 @Kuddel last edited by
                                          @Kuddel danke für die schnelle Rückmeldung. Zu der Thematik
                                          Das braucht man ja nur durchzählen. Hatte das manuell gemacht 😅 das mit dem Index kenne ich und man sieht ja auch in den Objekten welchen Menü tab man anklickt bzw. welche Zahl dabei raus kommt. Also richtig verlinkt hab ich es definitiv. Die View für das Wetter wird übrigens auch korrekt dargestellt in meiner Verlinkung 🤔
                                          • Sternmiere
                                            Sternmiere last edited by
                                            Hi @Kuddel ,
                                            vielen Dank für Deine VIS.
                                            Ich versuche gerade, die VIS ans laufen zu bringen. In Deiner Anleitung im ersten Post hast Du geschrieben, dass man für die Navigation und alle Widgets ein DP benötigt wird. Was ist das und wie spiele ich das JS ein?
                                            Ist das einfach nur ein neues JS-Skript mit der einen Zeile als Inhalt, welches ich z.B. unter common ablegen muss?
                                            Danke und Gruß,
                                            1.0k
                                            vis vis projekte
                                            83
                                            640
                                            172127
