    2. Русский
    3. ioBroker
    4. Визуализация
    5. ioBroker.vis Драйвер
    6. Android App
    Android App
    • Bluefox
      Bluefox last edited by
      Нужна помощь! Все у кого не работает
      • Удалите установленное приложение,
      • включите отладку: https://developer.chrome.com/devtools/d … -debugging
      • скачайте debug app: http://download.iobroker.org/android-debug.apk
      И скажите, на что ругается в консоли!
        DAndre last edited by
        БББББлин
        android-debug.apk выдал страничку настроек 😄 . Android v4.
        Failed to load resource file:///data/data/net.iobroker.vis/files/vis-common-user.css
        Received Event: deviceready app.js:125
        "Text 2 speech": {"en": "Text 2 speech", "de": "Text 2 speech", "ru": "Text 2 speech"}, translate.js:20
        "Default room": {"en": "Default room", "de": "Default room", "ru": "Default room"}, translate.js:20
        ArrayBuffer is deprecated in XMLHttpRequest.send(). Use ArrayBufferView instead. index.html:1
        2016-02-27T12:35:12.431Z Connected => authenticate conn.js:201
        2016-02-27T12:35:12.575Z Authenticated: true conn.js:204
        Check why views are not yet loaded! vis.js:236
        Version vis-colorpicker: 0.1.3
        Version justgage: 0.4.0
        Version iobroker.vis-keyboard: 0.0.2
        Metro version: "0.2.1"
        Version starline: 0.1.0
        "Message": {"en": "Message", "de": "Message", "ru": "Message"}, translate.js:20
        esource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/cordova.js". index.html:28
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/js/config.js". index.html:42
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/js/app.js". index.html:33
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/lib/js/can.2.2.4.custom.min.js". index.html:35
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/lib/js/jquery-ui-1.11.4.full.min.js". index.html:30
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/lib/js/jquery.ui.touch-punch.min.js". index.html:36
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/lib/js/jquery.multiselect-1.13.min.js". index.html:37
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/lib/js/translate.js". index.html:32
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/lib/js/jquery-1.11.2.min.js". index.html:29
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/lib/js/socket.io.js". index.html:31
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/lib/js/loStorage.js". index.html:39
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/js/conn.js". index.html:43
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/cordova_plugins.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/js/vis.js". index.html:44
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-whitelist/whitelist.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/nl.x-services.plugins.insomnia/www/Insomnia.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/DirectoryEntry.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/DirectoryReader.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/Entry.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/File.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/FileEntry.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/FileError.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/FileReader.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/FileSystem.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/FileUploadOptions.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/FileUploadResult.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/FileWriter.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/Flags.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/LocalFileSystem.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/Metadata.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/ProgressEvent.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/fileSystems.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/requestFileSystem.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/android/FileSystem.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/fileSystems-roots.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-file/www/fileSystemPaths.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-network-information/www/network.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-network-information/www/Connection.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-tts/www/tts.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/org.apache.cordova.speech.speechrecognition/www/SpeechRecognition.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/org.apache.cordova.speech.speechrecognition/www/SpeechRecognitionError.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/org.apache.cordova.speech.speechrecognition/www/SpeechRecognitionAlternative.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/org.apache.cordova.speech.speechrecognition/www/SpeechRecognitionResult.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/org.apache.cordova.speech.speechrecognition/www/SpeechRecognitionResultList.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/org.apache.cordova.speech.speechrecognition/www/SpeechRecognitionEvent.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/org.apache.cordova.speech.speechrecognition/www/SpeechGrammar.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/org.apache.cordova.speech.speechrecognition/www/SpeechGrammarList.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/org.apache.cordova.wifiinfo/www/WifiInfo.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-app-version/www/AppVersionPlugin.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-x-toast/www/Toast.js". cordova.js:1692
        Resource interpreted as Script but transferred with MIME type text/plain: "file:///android_asset/www/plugins/cordova-plugin-x-toast/test/tests.js". cordova.js:1692
        ArrayBuffer is deprecated in XMLHttpRequest.send(). Use ArrayBufferView instead. socket.io.js:2680
        2016-02-27T12:37:42.155Z Connected => authenticate conn.js:201
        Cannot read file: [object Object] app.js:233
        2016-02-27T12:37:42.322Z Authenticated: true conn.js:204
        Страничка загрузилась. График на рисовался. Лампочка вкл\выкл. Пока все ОК.
        Как голосовое распознование прикрутить?
          Вот при голосовых к
          {"type":"error"} app.js:794
          {"text":"Вика моё имя.А ВАС?","locale":"ru-RU"} app.js:679
          Error in Success callbackId: TTS198092319 : TypeError: Cannot read property 'project' of undefined cordova.js:311
          и встает на паузу.
            Haus last edited by
            @Bluefox:
            И скажите, на что ругается в консоли! `
            Android 5.1.1 На вопрос Алиса Который час, на экране пишет вопрос и даёт ответ а вот сказать в лучшем случае одно слово или пару букв. Из наблюдений прога при запуске выключает звук, а когда пытается говорить включает на мгновение и вырубает прежде чем что то скажет. Если в этот момент включить громкость то можно дослушать что говорит. Ещё на экране всё время пишет о чем говорят наверно при ключевом слове Алиса это как то не в тему.
            app.js:771 {"type":"error"}
            app.js:658 {"text":"один час тридцать шесть минут","locale":"ru-RU"}
            cordova.js:310 Error in Success callbackId: TTS1285520170 : TypeError: Cannot read property 'project' of undefined
            cordova.js:312 Uncaught TypeError: Cannot read property 'project' of undefined(anonymous function) @ app.js:660(anonymous function) @ tts.js:24cordova.callbackFromNative @ cordova.js:291processMessage @ cordova.js:1079processMessages @ cordova.js:1102pollOnce @ cordova.js:971pollOnceFromOnlineEvent @ cordova.js:958
            8app.js:771 {"type":"error"}
            app.js:658 {"text":"один час тридцать семь минут","locale":"ru-RU"}
            cordova.js:310 Error in Success callbackId: TTS1285520182 : TypeError: Cannot read property 'project' of undefined
            24app.js:771 {"type":"error"}
              при работе приложения кнопка настроек меняет свой цвет светлая - темная.
              Те при темной идет запись(громкость в 0) при светлой воспроизведение.
              Вот только все это дело как то хаотично 🙂
              При присутствии ключевого слова (в любой последовательности) данные передаются на text commands и тд.
              Если ключевое не прописать все что расползалось уходит на text commands .
              Вопр как сделать чтобы ответ на команды (голос) уходил на sayit.0.tts.text, а не на Android App?
              • Bluefox
                @DAndre:
                Вопр как сделать чтобы ответ на команды (голос) уходил на sayit.0.tts.text, а не на Android App? `
                Можно прописать в text2command "Ответ в ID:" (смотри наверху).
                Правда в таком случае на телефоне всё равно будет произносится. Надо сделать настраиваемым.
                  Так оно и стоит
                  Но при работе через APP молчок. Только на экран устройства выводит.
                  ! ` > web.0 2016-02-29 18:26:31 info web.0 sendTo "getHistory" to system.adapter.sql.0 from system.adapter.web.0: {"id":"megad.0.p2_P2","options":{"start":1456752269,"end":1456752389,"ignoreNull":false,"aggregate":"average","count":1,"in
                  text2command.0 2016-02-29 18:26:20 info text2command.0 sendTo "send" to system.adapter.socketio.0 from system.adapter.text2command.0: {"text":"Спасибо","response":"Всегда пожалуйста"}
                  text2command.0 2016-02-29 18:26:20 info text2command.0 processText: "Спасибо"
                  socketio.0 2016-02-29 18:26:20 info socketio.0 sendTo "send" to system.adapter.text2command.0 from system.adapter.socketio.0: "Спасибо"
                  sql.0 2016-02-29 18:26:18 info sql.0 sendTo "getHistory" to system.adapter.web.0 from system.adapter.sql.0: {"result":[{"ts":1456748837,"val":null},{"ts":1456748957,"val":682},{"ts":1456749077,"val":637},{"ts":1456749197,"val":621} `
                  Если использовать скрипт + приложение (то instalator) говорит
                  ! ` > sayit.0 2016-02-29 18:28:14 info sayit.0 Copied file '/opt/iobroker/node_modules/iobroker.sayit/say.mp3' to '/opt/iobroker/cache/1323c88c80addd50efb7d8f95c2d6e16.mp3'
                  sayit.0 2016-02-29 18:28:13 info sayit.0 saying: С радостью
                  sayit.0 2016-02-29 18:28:11 info sayit.0 saying: /opt/iobroker/node_modules/iobroker.sayit/gong.mp3
                  text2command.0 2016-02-29 18:28:11 info text2command.0 processText: "огромное спасибо"
                  javascript.0 2016-02-29 18:28:11 info javascript.0 script.js.GolosComm: огромное спасибо
                    Haus last edited by
                    @DAndre:
                    Так оно и стоит
                    filename="xxx.gif" index="0">~~
                    ! sayit.0 у тебя в браузер настроен? `
                      не совсем понял вопр, вообще то совсем не понял.
                      Вот из-за этого и все проблемы. 😞
                      Вы говорите о драйвер sayIt > Настройки > Тип (System)
                        Haus last edited by
                        @DAndre:
                        Вы говорите о драйвер sayIt > Настройки > Тип (System) `
                        Да только если хочешь чтобы говорила в браузер не на локальной машине став браузер вместо систем
                        http://forum.iobroker.net/download/file … &mode=view
                          Запутал Вас всех.
                          Нужно наоборот, так как Android App глючит, чтобы все шло на звуковуху сервера.
                          В данный момент Android App выводит ответы только на экран и динамик планшета с 0й громкостью.
                            electric last edited by
                            Можно где скачать apk?
                            У меня на планшете в playmarket нет этого приложения))
                            Девайс perfeo 1006-IPS, андроид 4.1.1
                            • Bluefox
                              https://play.google.com/apps/testing/net.iobroker.vis
                                andrey99986 last edited by
                                При первом запуске приложения сколько мегабайт будет скачено с сервера?
                                Запустил, не знаю верные настройки или нет - просто указал IP и порт 8084, таймер загрузки крутиться, трафик какой то судя по tcpdump идёт. Ждать до победного?
                                • Bluefox
                                  @andrey99986:
                                  Запустил, не знаю верные настройки или нет - просто указал IP и порт 8084, таймер загрузки крутиться, трафик какой то судя по tcpdump идёт. Ждать до победного? `
                                  И?
                                    @Bluefox:
                                    @andrey99986:
                                    Запустил, не знаю верные настройки или нет - просто указал IP и порт 8084, таймер загрузки крутиться, трафик какой то судя по tcpdump идёт. Ждать до победного? И?
                                    Пока без результата.
                                    Сервер по всем портам доступен, соединение через 4G (мобильное), настройки WIFI не трогал.
                                    Должно работать на обоих портах - 8082 и 8084?
                                    Надо ли указывать после порта путь к странице как в браузере?
                                      Haus last edited by
                                      @andrey99986:
                                      @Bluefox:
                                      @andrey99986:
                                      Надо ли указывать после порта путь к странице как в браузере? `
                                      http://www.iobroker.net/docu/?page_id=5032&lang=ru
                                        @Haus:
                                        @andrey99986:
                                        @Bluefox:
                                        И? `
                                        Надо ли указывать после порта путь к странице как в браузере? [http://www.iobroker.net/docu/?page_id=5032&lang=ru](http://www.iobroker.net/docu/?page_id=5032&lang=ru)
                                        Да видел я эту страницу. Толку-то, хоть бы лог на стороне сервера был бы какой чтобы понять…
                                        • I
                                          instalator last edited by
                                          @Haus:
                                          @andrey99986:
                                          @Bluefox:
                                          И? `
                                            @instalator:
                                            @Haus:
                                            @andrey99986:
                                            Надо ли указывать после порта путь к странице как в браузере? [http://www.iobroker.net/docu/?page_id=5032&lang=ru](http://www.iobroker.net/docu/?page_id=5032&lang=ru) `
                                            Через мобильное соединение (4G) работает?
                                            104
                                            30429
