    4. tr-064 v3.1.x (Latest Repo) Diskussion
    • N
      NetFritz last edited by
      @Frank579 sagte in tr-064 v3.1.x (Latest Repo) Diskussion:
      die 3.2.0 läuft nicht..... musst auf die 3.1.4 zurück
      Hallo
      Das war es,
      Danke NetFritz
        crunchip Forum Testing Most Active last edited by crunchip
        @apollon77
        aktueller stand
        den fix https://forum.iobroker.net/post/380696 habe ich eingebaut
        cronjob für tr-64 hab ich dieses mal weggelassen, am Abend nochmal Testanruf gestartet, alles ok, fritzbox und auch tr-64
        um 23:57, hatte ich nen upload angestoßen
        2020-02-23 23:57:31.443 - info: host.IoBroker instance system.adapter.vis.0 terminated while should be started once
        2020-02-23 23:57:32.800 - info: host.IoBroker iobroker upload tr-064
        2020-02-23 23:57:34.701 - info: host.IoBroker iobroker upload [3] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
        2020-02-23 23:57:34.880 - info: host.IoBroker iobroker upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
        2020-02-23 23:57:34.950 - info: host.IoBroker iobroker upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
        2020-02-23 23:57:35.063 - info: host.IoBroker iobroker upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index.html index.html text/html
        2020-02-23 23:57:35.321 - info: host.IoBroker iobroker Update "system.adapter.tr-064.0"
        2020-02-23 23:57:35.391 - info: host.IoBroker stopInstance system.adapter.tr-064.0 (force=false, process=true)
        2020-02-23 23:57:35.392 - info: host.IoBroker stopInstance system.adapter.tr-064.0 send kill signal
        2020-02-23 23:57:35.416 - info: tr-064.0 (8990) Got terminate signal TERMINATE_YOURSELF
        2020-02-23 23:57:35.419 - info: tr-064.0 (8990) terminating
        2020-02-23 23:57:35.420 - info: tr-064.0 (8990) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2020-02-23 23:57:35.983 - info: host.IoBroker instance system.adapter.tr-064.0 terminated with code 156 (156)
        2020-02-23 23:57:36.413 - info: host.IoBroker iobroker exit 0
        2020-02-23 23:57:38.317 - info: host.IoBroker instance system.adapter.tr-064.0 started with pid 18130
        2020-02-23 23:57:41.713 - info: tr-064.0 (18130) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.19.0
        cronjob 0:05Uhr für fritzbox hab ich drin gelassen, funktioniert
        fritzbox.0	2020-02-24 00:05:16.973	info	(20613) Successfully connected to TR-064
        fritzbox.0	2020-02-24 00:05:14.475	info	(20613) adapter connected to fritzbox: 192.168.178.1
        fritzbox.0	2020-02-24 00:05:14.387	info	(20613) Trying to connect to TR-064: 192.168.178.1:49000
        fritzbox.0	2020-02-24 00:05:14.382	info	(20613) try to connect: 192.168.178.1
        fritzbox.0	2020-02-24 00:05:14.214	info	(20613) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.fritzbox, node: v10.19.0
        Testanruf 0:20
        fritzbox Adapter funktioniert, tr-64 wieder nicht
        fritzbox.0	2020-02-24 00:20:44.095	info	(20613) data from 192.168.178.1: 24.02.20 00:20:44;CALL;0;0;xxxxx;xxxxxxx;SIP0;
        danach tr-64 manuell neu gestartet, erneuten TestAnruf und tr-64 aktualisiert wieder
          aleks-83 last edited by aleks-83
          @MathiasJ sagte in [gelöst] TR-064 Adapter neuer state:
          jedoch bleibt das Resultat das selbe.....
          Ein Ordner callForwarding wird nicht angelegt, somit habe ich auch keine states.
          Ich habe aktuell genau das gleiche Problem.
          Der Ordner "callforwarding" wird gar nicht angezeigt.
          Der Thread zum 3.1.X Adapter wurde ja leider gesperrt.
          Den TR-064 Adapter (3.1.4) habe ich nicht per Github installiert, sondern über den Admin Adapter.
          Ich habe auch bereits neue Rufumleitungen in der FB angelegt und den Adapter neu gestartet um ein erneutes Synchronierieren zu triggern.
          • wendy2702
            wendy2702 last edited by
            Ich Zitiere mal was:
            @liv-in-sky
            habe ich gemacht.
            das gleiche wie vorher.
            Kein Ordner, keine States.
            Mal auf dumm gefragt, wo soll den der Ordner dann sein?
            Edit:
            Jetzt hat es funktioniert.
            Ich musste 2 Rufumleitungen anlegen, damit der Ordner kommt.
            2 Rufumleitungen angelegt, die falsche Rufumleitung gelöscht,
            auf Blockly bei der Anwesenheitssteuerung die Rufumleitung hinzugfügt.
            Nun weiß ich wenigstens, wie ich es machen soll, wenn ich mehrere AB's habe.....
            Bin gespannt, ob es geht.
            Gruß,
            Mathias
              apollon77 @aleks-83 last edited by
              @aleks-83 sagte in tr-064 v3.1.x (Latest Repo) Diskussion:
              Warum leider? Der Test war mit dem Release ins Latest zu Ende und damit ist das hier der aktuelle Thread.
              Stellt sicher das Eure Probleme alle sauber und detsilliert im GitHub erfasst sind bitte
                Achso. Das wusste ich ja nicht.
                Mein issue ist ausreichend beschrieben, oder?
                  aleks-83 @wendy2702 last edited by aleks-83
                  @wendy2702 sagte in tr-064 v3.1.x (Latest Repo) Diskussion:
                  Danke, aber wie ich in meinem Post oben geschrieben habe hab ich dieses Vorgehen bereits ausprobiert ohne Erfolg.
                  • wendy2702
                    Lies mal hier. So hat es damals bei mir geklappt:
                    https://forum.iobroker.net/topic/11246/tr-064-adapter-update-geht-nicht/25
                      Das ist ja quasi das gleiche. Rufumleitung anlegen...
                      Oder muss man erst alle Umleitungen löschen?
                      • wendy2702
                        Ich meinte das mit der Rufsperre:
                          @apollon77
                          Ich mal wieder, immer noch😁
                          Die Fritzbox/Netzbetreiber aktualisieren ja ihre Daten in irgendeiner Weise täglich/nächtlich.
                          Der tr-64 sollte ja auch mit einem automatischen schedule versehen werden.
                          Ich habe diesen schedule nun die letzen Tage mehrmals getestet, sei es auf frühs, mittags, abends, oder nachts/ vor 0:00,nach 0:00Uhr. Ich bekomme die Daten nicht aktualisiert, somit auch keine Ansage.
                          Selbiges habe ich auch mit dem Fritzbox Adapter gemacht, selbes Problem.
                          Nun zur eigentlichen Frage:
                          Kann es dennoch sein, das es einen Unterschied im Sytem gibt, zwischen schedule automatisch und manuell neustarten?
                          Wenn ich einen Testanruf vor und nach dem automatischen schedule tätige....tote Hose, keine Aktualisierung.
                          Löse ich manuell einen Neustart aus, danach Testanruf, funktioniert alles.....bis zur Zeit x, ab da geht wieder nichts mehr. (X ist in dem Fall die Variable, bis Fritzbox/Netzbetreiber aktualisiert)
                          Das ist bei beiden Adaptern der Fall, daher die Frage ob es einen Unterschied gibt, zwischen automatisch und manuell Neustarten.
                          Gruss
                          • wendy2702
                            wendy2702 @crunchip last edited by
                            @crunchip sagte in tr-064 v3.1.x (Latest Repo) Diskussion:
                            Ähem..
                            Wie kommst du darauf?
                            Was die Netzbetreiber machen ist eine Zwangstrennung. Aber das die täglich etwas aktualisieren habe ich in meinen 19 Jahren Tätigkeit bei einem Systemlieferanten, für unter anderem DSL Technik, noch nicht gehört.
                            Werde das aber bei befreundeten DSL Technikern der Telekom und O2 nochmal anfragen.
                            ? crunchip 2 Replies Last reply Reply Quote 0
                              A Former User @wendy2702 last edited by
                              @wendy2702 was der DSL Anbieter machen kann, ist zum Beispiel den DNS und NTP Server ändern, ist bei mir so gewesen, nach Umstellung von 1&1 zu O2 letzten Monat, DNS war mir klar, aber dass O2 auch seine NTP anbietet.. naja.. habs auch erst durch Zufall gesehen, so oft schau ich mir die Settings ja nicht an.. und ne Email schickt die Fritte nicht...
                              • wendy2702
                                wendy2702 @Guest last edited by
                                @ilovegym sagte in tr-064 v3.1.x (Latest Repo) Diskussion:
                                Wenn du den Provider wechselst ist doch ein anderer DNS und NTP Server nicht ungewöhnlich.
                                Täglich ändern die das aber auch nicht.
                                  crunchip Forum Testing Most Active @wendy2702 last edited by
                                  @wendy2702 dann eben falsch ausgedrückt.
                                  Zwangstrennung weiss ich...mal läufts mehrere Tage ohne Trennung, dann mal wieder täglich und hin und wieder auch mehrmals am Tag...kommt vom Netztbetreiber...is klar und weiss ich.
                                  Dennoch muss ja irgendwas passieren, was zur Folge hat, das am "nächsten Tag" eben keine Aktualisierung mehr erfolgt, mit den Adaptern.
                                  Unabhängig vom Netzbetreiber...die besteht in dem Fall seit 6 Tagen ohne Trennung.
                                  Viel mehr war lediglich auch nur die Eigentliche Frage:
                                  Ob es einen Unterschied zwischen automatisch und manuell schedule gibt.
                                    aca_home last edited by
                                    ich bin noch sehr neu hier finde das Forum aber echt super! Gute Arbeit und Danke an alle die hier mitmachen😀
                                    Wie gesagt, ich bin neu hier und beschäftige mich erst seit drei Wochen mit Home Automation.
                                    Ich bin jedoch schon relativ weit gekommen und bis jetzt vieles hinbkommen.
                                    Bei dem Thema Fritz Box TR-064 habe ich eine Frage und hoffe ihr könnt mir helfen.
                                    In meiner Fritzbox habe ich ja mehrere Rufnummer eingespeichert. In der Tabelle "Verpasste Anrufe" werden ja alle Anrufe an alle angerufene Nummern angezeigt.
                                    Kann man irgendwie einstellen, dass nur verpasste Anrufe an bestimmte Nummer angezeigt werden? Oder mehrere Tabellen mit jeweiliger Rufnummer?
                                    Sollte ich im Falschen Thread sein, dann bitte verschieben.
                                    Danke schon mal für eure Hilfe!
                                      Kann mir hier keiner weiterhelfen oder bin ich im falschen Bereich?
                                      ? liv-in-sky 2 Replies Last reply Reply Quote 0
                                        A Former User @aca_home last edited by
                                        @aca_home du bist hier schon richtig, nein, Einstellen kann man das leider nicht.
                                        Nur, dass dies überhaupt von der Fritzbox übernommen wird, im json und html.
                                        Ich denke, das kann man nur mit einem script machen, @liv-in-sky ist hier unsere Tabellen-Script-Guru, hast du eine Idee dazu?
                                          liv-in-sky @Guest last edited by liv-in-sky
                                          @ilovegym @aca_home
                                          man kann auf jeden fall einetabelle erstellen die das json anzeigt - mit filtern kann man dann nach called number filtern - bzw sortieren, dass wäre am einfachsten
                                          man kann aber im script eingeben, welche nummer man sehen will - dann bekommt man nur diese angerufene nummer zu sehen - also theoretisch kein problem und machbar
                                          mit dem neuen materialdesign widget sollte auch ein flexibles filtern möglich sein
                                            liv-in-sky @aca_home last edited by liv-in-sky
                                            @aca_home
                                            in diesem thread siehst du mal , wie es aussieht- da kann gefiltert und sortiert werden - anstatt der einzelnen rechner würden dann halt die telefonnummer drinstehen
                                            https://forum.iobroker.net/topic/30875/material-design-widgets-unifi-netzwerk-status
                                            hier mal ein widget zum import (materil design table) - da siehst du schon mal die ersten 4 werte des json files - du mußt den wert schalter im widget auf dein system angleichen
                                            [{"tpl":"tplVis-materialdesign-Table","data":{"oid":"tr-064-community.0.calllists.missed.json","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","countCols":"4","tableLayout":"standard","showHeader":"true","headerTextSize":"headline6","showColumn0":"true","colType0":"text","textAlign0":"left","showColumn1":"true","colType1":"text","textAlign1":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"showColumn2":"true","colType2":"text","textAlign2":"left","showColumn3":"true","colType3":"text","textAlign3":"center","dataJson":"","colTextSize0":"headline4","label1":"Name","label0":" ","label2":"IP","sortKey0":"name","fontFamily0":"RobotoCondensed-Regular","padding_left0":"10","colTextColor0":"#beb7b7","colorBackground":"#ffffff","colorHeaderRowBackground":"#424242","colorHeaderRowText":"#b6b9b7","borderColor":"#000000","fontFamily1":"RobotoCondensed-Regular","colTextColor1":"","rowHeight":"19","label3":" Status","imageSize3":"20","padding_right3":"-5","imageSize0":"25","colTextSize3":"12px","colTextColor2":"#beb7b7","fontFamily2":"RobotoCondensed-Regular","dividers":"grey","showColumn4":"true","colType4":"text","textAlign4":"center","showColumn5":"true","colType5":"text","textAlign5":"center","showColumn6":"true","colType6":"text","textAlign6":"center","showColumn7":"true","colType7":"text","textAlign7":"center","showColumn8":"true","colType8":"text","textAlign8":"center","showColumn9":"true","colType9":"text","textAlign9":"center","showColumn10":"true","colType10":"text","textAlign10":"center","showColumn11":"true","colType11":"text","textAlign11":"center","showColumn12":"true","colType12":"text","textAlign12":"center","showColumn13":"true","colType13":"text","textAlign13":"center","showColumn14":"true","colType14":"text","textAlign14":"center","showColumn15":"true","colType15":"text","textAlign15":"center","showColumn16":"true","colType16":"text","textAlign16":"center","showColumn17":"true","colType17":"text","textAlign17":"center","showColumn18":"true","colType18":"text","textAlign18":"center","showColumn19":"true","colType19":"text","textAlign19":"center","showColumn20":"true","colType20":"text","textAlign20":"center","showColumn21":"true","colType21":"text","textAlign21":"center","showColumn22":"true","colType22":"text","textAlign22":"center","showColumn23":"true","colType23":"text","textAlign23":"center","showColumn24":"true","colType24":"text","textAlign24":"center","showColumn25":"true","colType25":"text","textAlign25":"center","showColumn26":"true","colType26":"text","textAlign26":"center","showColumn27":"true","colType27":"text","textAlign27":"center","showColumn28":"true","colType28":"text","textAlign28":"center","showColumn29":"true","colType29":"text","textAlign29":"center","showColumn30":"true","colType30":"text","textAlign30":"center","showColumn31":"true","colType31":"text","textAlign31":"center","showColumn32":"true","colType32":"text","textAlign32":"center","showColumn33":"true","colType33":"text","textAlign33":"center","showColumn34":"true","colType34":"text","textAlign34":"center","showColumn35":"true","colType35":"text","textAlign35":"center","showColumn36":"true","colType36":"text","textAlign36":"center","showColumn37":"true","colType37":"text","textAlign37":"center","showColumn38":"true","colType38":"text","textAlign38":"center","showColumn39":"true","colType39":"text","textAlign39":"center","showColumn40":"true","colType40":"text","textAlign40":"center","showColumn41":"true","colType41":"text","textAlign41":"center","showColumn42":"true","colType42":"text","textAlign42":"center","showColumn43":"true","colType43":"text","textAlign43":"center","showColumn44":"true","colType44":"text","textAlign44":"center","showColumn45":"true","colType45":"text","textAlign45":"center","showColumn46":"true","colType46":"text","textAlign46":"center","showColumn47":"true","colType47":"text","textAlign47":"center","showColumn48":"true","colType48":"text","textAlign48":"center","showColumn49":"true","colType49":"text","textAlign49":"center","showColumn50":"true","colType50":"text","textAlign50":"center","showColumn51":"true","colType51":"text","textAlign51":"center","showColumn52":"true","colType52":"text","textAlign52":"center","showColumn53":"true","colType53":"text","textAlign53":"center","showColumn54":"true","colType54":"text","textAlign54":"center","showColumn55":"true","colType55":"text","textAlign55":"center","showColumn56":"true","colType56":"text","textAlign56":"center","showColumn57":"true","colType57":"text","textAlign57":"center","showColumn58":"true","colType58":"text","textAlign58":"center","showColumn59":"true","colType59":"text","textAlign59":"center","showColumn60":"true","colType60":"text","textAlign60":"center","showColumn61":"true","colType61":"text","textAlign61":"center","showColumn62":"true","colType62":"text","textAlign62":"center","showColumn63":"true","colType63":"text","textAlign63":"center","showColumn64":"true","colType64":"text","textAlign64":"center","showColumn65":"true","colType65":"text","textAlign65":"center","showColumn66":"true","colType66":"text","textAlign66":"center","showColumn67":"true","colType67":"text","textAlign67":"center","showColumn68":"true","colType68":"text","textAlign68":"center","showColumn69":"true","colType69":"text","textAlign69":"center","showColumn70":"true","colType70":"text","textAlign70":"center","showColumn71":"true","colType71":"text","textAlign71":"center","showColumn72":"true","colType72":"text","textAlign72":"center","showColumn73":"true","colType73":"text","textAlign73":"center","showColumn74":"true","colType74":"text","textAlign74":"center","showColumn75":"true","colType75":"text","textAlign75":"center","showColumn76":"true","colType76":"text","textAlign76":"center","showColumn77":"true","colType77":"text","textAlign77":"center","showColumn78":"true","colType78":"text","textAlign78":"center","showColumn79":"true","colType79":"text","textAlign79":"center","showColumn80":"true","colType80":"text","textAlign80":"center","showColumn81":"true","colType81":"text","textAlign81":"center","showColumn82":"true","colType82":"text","textAlign82":"center","showColumn83":"true","colType83":"text","textAlign83":"center","showColumn84":"true","colType84":"text","textAlign84":"center","showColumn85":"true","colType85":"text","textAlign85":"center","showColumn86":"true","colType86":"text","textAlign86":"center","showColumn87":"true","colType87":"text","textAlign87":"center","showColumn88":"true","colType88":"text","textAlign88":"center","showColumn89":"true","colType89":"text","textAlign89":"center","showColumn90":"true","colType90":"text","textAlign90":"center","showColumn91":"true","colType91":"text","textAlign91":"center","showColumn92":"true","colType92":"text","textAlign92":"center","showColumn93":"true","colType93":"text","textAlign93":"center","showColumn94":"true","colType94":"text","textAlign94":"center","showColumn95":"true","colType95":"text","textAlign95":"center","showColumn96":"true","colType96":"text","textAlign96":"center","showColumn97":"true","colType97":"text","textAlign97":"center","showColumn98":"true","colType98":"text","textAlign98":"center","showColumn99":"true","colType99":"text","textAlign99":"center","showColumn100":"true","colType100":"text","textAlign100":"center","showColumn101":"true","colType101":"text","textAlign101":"center","showColumn102":"true","colType102":"text","textAlign102":"center","showColumn103":"true","colType103":"text","textAlign103":"center","showColumn104":"true","colType104":"text","textAlign104":"center","showColumn105":"true","colType105":"text","textAlign105":"center","showColumn106":"true","colType106":"text","textAlign106":"center","showColumn107":"true","colType107":"text","textAlign107":"center","showColumn108":"true","colType108":"text","textAlign108":"center","showColumn109":"true","colType109":"text","textAlign109":"center","showColumn110":"true","colType110":"text","textAlign110":"center","showColumn111":"true","colType111":"text","textAlign111":"center","showColumn112":"true","colType112":"text","textAlign112":"center","showColumn113":"true","colType113":"text","textAlign113":"center","showColumn114":"true","colType114":"text","textAlign114":"center","showColumn115":"true","colType115":"text","textAlign115":"center","showColumn116":"true","colType116":"text","textAlign116":"center","showColumn117":"true","colType117":"text","textAlign117":"center","showColumn118":"true","colType118":"text","textAlign118":"center","showColumn119":"true","colType119":"text","textAlign119":"center","showColumn120":"true","colType120":"text","textAlign120":"center","showColumn121":"true","colType121":"text","textAlign121":"center","showColumn122":"true","colType122":"text","textAlign122":"center","showColumn123":"true","colType123":"text","textAlign123":"center","showColumn124":"true","colType124":"text","textAlign124":"center","showColumn125":"true","colType125":"text","textAlign125":"center","showColumn126":"true","colType126":"text","textAlign126":"center","showColumn127":"true","colType127":"text","textAlign127":"center","showColumn128":"true","colType128":"text","textAlign128":"center","showColumn129":"true","colType129":"text","textAlign129":"center","showColumn130":"true","colType130":"text","textAlign130":"center","showColumn131":"true","colType131":"text","textAlign131":"center","showColumn132":"true","colType132":"text","textAlign132":"center","showColumn133":"true","colType133":"text","textAlign133":"center","showColumn134":"true","colType134":"text","textAlign134":"center","showColumn135":"true","colType135":"text","textAlign135":"center","showColumn136":"true","colType136":"text","textAlign136":"center","showColumn137":"true","colType137":"text","textAlign137":"center","showColumn138":"true","colType138":"text","textAlign138":"center","showColumn139":"true","colType139":"text","textAlign139":"center","showColumn140":"true","colType140":"text","textAlign140":"center","showColumn141":"true","colType141":"text","textAlign141":"center","showColumn142":"true","colType142":"text","textAlign142":"center","showColumn143":"true","colType143":"text","textAlign143":"center","showColumn144":"true","colType144":"text","textAlign144":"center"},"style":{"left":"599px","top":"84px","z-index":"200","width":"1017px","height":"448px","overflow-y":"auto"},"widgetSet":"materialdesign"}]
                                            tr-064
                                            50
                                            295
                                            41270
