    3. Entwicklung
    4. ZigBee neue/unbekannte Geräte - ab 1.0.0
      locito09 last edited by
      Hallo
      Wurde diese LED Streifen schon hinzugefügt?
        gd84 @arteck last edited by gd84
        @arteck
        Irgend was stimmt nicht
        zigbee.1	2020-02-27 20:23:56.995	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
        zigbee.1	2020-02-27 20:18:56.906	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
        zigbee.1	2020-02-27 20:13:56.818	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
        zigbee.1	2020-02-27 20:08:56.732	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
        zigbee.1	2020-02-27 20:03:56.645	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
        zigbee.1	2020-02-27 19:59:36.218	info	(655) Zigbee: stop joining
        zigbee.1	2020-02-27 19:58:56.557	info	(655) Device '0x083800b8d1f00000' is supported, identified as: OSRAM OSRAM LED panel TW 595 UGR22 (595UGR22)
        zigbee.1	2020-02-27 19:58:56.557	info	(655) Successfully interviewed '0x083800b8d1f00000', device has succesfully been paired
        zigbee.1	2020-02-27 19:58:56.556	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
        zigbee.1	2020-02-27 19:58:56.448	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
        zigbee.1	2020-02-27 19:58:56.327	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
        zigbee.1	2020-02-27 19:58:56.190	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
        zigbee.1	2020-02-27 19:58:56.071	error	(655) Device 083800b8d1f00000 "Panel TW 595 UGR22" not described in statesMapping.
        zigbee.1	2020-02-27 19:58:44.382	info	(655) Starting interview of '0x083800b8d1f00000'
        zigbee.1	2020-02-27 19:58:35.143	error	at processTimers (internal/timers.js:475:7))
        zigbee.1	2020-02-27 19:58:35.143	error	at listOnTimeout (internal/timers.js:531:17)
        zigbee.1	2020-02-27 19:58:35.143	error	at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
        zigbee.1	2020-02-27 19:58:35.143	error	(655) Failed to do action 0x4a3900b8d1f00000 Panel TW 595 UGR22, attempt 1 (Error: AREQ - ZDO - mgmtLeaveRsp after 10000ms
        zigbee.1	2020-02-27 19:58:31.869	info	(655) Zigbee: allowing new devices to join.
        zigbee.1	2020-02-27 19:58:25.141	info	(655) Do action on 0x4a3900b8d1f00000 Panel TW 595 UGR22
        zigbee.1	2020-02-27 19:58:22.570	info	(655) Do action succesfully 0x083800b8d1f00000 Panel TW 595 UGR22
        zigbee.1	2020-02-27 19:58:19.573	info	(655) Do action on 0x083800b8d1f00000 Panel TW 595 UGR22
        zigbee.1	2020-02-27 19:58:01.993	info	(655) Zigbee started
        Über die Instanz / Analyse kann ich aber Daten abfragen und schalten.
          arteck Developer Most Active @gd84 last edited by
          @gd84 sagte in ZigBee neue/unbekannte Geräte - ab 1.0.0:
          0x083800b8d1f00000
          installier nochmal bitte .. hatte noch ein fehler
            arteck Developer Most Active @locito09 last edited by
            @locito09 jetzt
              @arteck
              Super jetzt geht alles.
              Ein anderes Problem das ich habe ist das Binding.
              Ein Hue Bewegungsmelder sollte mit einer Hue Lampe Verbunden werden.
              Das ist die Fehlermeldung:
              zigbee.1	2020-02-28 09:52:00.182	warn	at processImmediate (internal/timers.js:439:21)
              zigbee.1	2020-02-28 09:52:00.182	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:227:41)
              zigbee.1	2020-02-28 09:52:00.182	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4808:34)
              zigbee.1	2020-02-28 09:52:00.182	warn	at Zigbee.emit (events.js:228:7)
              zigbee.1	2020-02-28 09:52:00.182	warn	at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:50:26)
              zigbee.1	2020-02-28 09:52:00.182	warn	at Developer.getLibData (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:69:39)
              zigbee.1	2020-02-28 09:52:00.182	warn	at Object.getCluster (/opt/iobroker/node_modules/zigbee-herdsman/dist/zcl/utils.js:59:15)
              zigbee.1	2020-02-28 09:52:00.182	warn	(1152) Error: Cluster with key '' does not exist
              zigbee.1	2020-02-28 09:52:00.181	warn	(1152) States system pmessage io.messagebox.system.adapter.zigbee.1 {"command":"getLibData","message":{"key":"cmdListFunctional","cid":""},"from":"system.adapter.admin.0","callback":{"message":{"key"
                @gd84 das binding geht nicht mit jedem Gerät...
                was geht sind die Tradfri komponenten..
                  @arteck
                  Ah ok, ist das ein prinzipielles problem der Firmware der Geräte oder fehlen nur Angaben in der Datenbank.
                    locito09 @arteck last edited by
                    @arteck
                      @gd84 mit der Datenbank hat das nix zu tun..
                      Nicht alle Geräte machen da mit
                        A Former User last edited by
                        Habe ein Problem mit dem Rauchmelder Heiman SmokeSensor-N-3.0, zigbee erkennt ihn aber bekomme folgende Fehlermeldung:
                        Device 00158d0004c34730 "SmokeSensor-N-3.0" not described in statesMapping.
                          @arteck
                          Ah ok.
                          Kann man eigentlich schon die Ota Funktion nutzen? Soll ja für Tradfri und Osram schon gehen.
                            Saxnot last edited by
                            vielen Dank für die tolle Arbeit, die ihr macht!
                            Bitte das folgende Gerät aufnehmen:
                            Produkt: Innr RS 230 C (Smart Spot Colour GU10)
                            Link: https://www.innr.com/en/product/smart-spot-colour/
                            Kachel:
                            Eigentlich wollte ich auch noch die Innr RS 228 T (https://www.innr.com/en/product/smart-spot-comfort-4pack/) aufnehmen. Da scheitere ich aber schon am Pairing. Dabei kommt auch keine Meldung. Was muss man in solchen Fällen machen? Vielen Dank!
                              arteck Developer Most Active @Saxnot last edited by
                              @Saxnot drin
                                Saxnot @arteck last edited by
                                @arteck said in ZigBee neue/unbekannte Geräte - ab 1.0.0:
                                @Saxnot drin
                                Wahnsinn, wie schnell du bist👍 Die RS 230 C wird jetzt erkannt! Zur RS 228 T kann ich nichts berichten, bekomme sie einfach nicht verbunden... Aber besten Dank!
                                • Z
                                  Zentapher last edited by
                                  Meine neue Steckdose mag nicht so richtig...
                                  Adapter ist aktuell aus GitHub::
                                  starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.18.1
                                  Ich verwende einen CC1352P-2 mit aktueller Z-Stack_3.x.0 Firmware:
                                  Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20191106}}
                                  Device Details:
                                  Device details
                                  model:ZNCZ04LM
                                  vendor:Xiaomi
                                  description:Mi power plug ZigBee EU
                                  supports:on/off, power measurement
                                  model:lumi.plug.mmeu01
                                  type:Router
                                  nwk:54748
                                  manuf id:4447
                                  manufacturer:LUMI
                                  power:Mains (single phase)
                                  app version:22
                                  hard version:1
                                  zcl version:3
                                  stack version:2
                                  date code:09-06-2019
                                  interviewed:true
                                  configured:false
                                  endpoint:1
                                  profile:260
                                  input clusters:genBasic (0)
                                  genDeviceTempCfg (2)
                                  genIdentify (3)
                                  genGroups (4)
                                  genScenes (5)
                                  genOnOff (6)
                                  aqaraOpple (64704)
                                  output clusters:genTime (10)
                                  genOta (25)
                                  endpoint:21
                                  profile:260
                                  input clusters:genAnalogInput (12)
                                  endpoint:22
                                  profile:260
                                  endpoint:242
                                  profile:41440
                                  output clusters:33
                                  Pairing Logs:
                                  New device joined '0x04cf8cdf3c75a3d1' model lumi.plug.mmeu01
                                  Interview successful: {"friendly_name":"0x04cf8cdf3c75a3d1","model":"ZNCZ04LM","vendor":"Xiaomi","description":"Mi power plug ZigBee EU","supported":true}
                                  Error: Device 04cf8cdf3c75a3d1 "lumi.plug.mmeu01" not described in statesMapping.. undefined
                                  Device '0x04cf8cdf3c75a3d1' announced itself
                                  Interview started: 0x04cf8cdf3c75a3d1
                                  • FredF
                                    FredF Most Active Forum Testing last edited by
                                    Ich nutze den FLS-PP3/Mega23M12 mit dem Adapter 1.0.3
                                    Das ist ein RGBW controller, nur leider wird der W Anteil nicht in den Datenpunkten angeboten bzw. mit eingabe einem 8 stelligen Hex code in color passiert nichts.
                                    Ist der richtig eingebunden oder mache ich was falsch?
                                    Details
                                    model:Mega23M12
                                    vendor:Dresden Elektronik
                                    description:ZigBee Light Link wireless electronic ballast
                                    supports:on/off, brightness, color temperature, color xy
                                    model:FLS-PP3
                                    type:Router
                                    nwk:29323
                                    manuf id:4405
                                    manufacturer:dresden elektronik
                                    app version:2
                                    hard version:1
                                    zcl version:1
                                    stack version:3
                                    date code:20180517
                                    build:0214.201000EB
                                    interviewed:true
                                    configured:false
                                    endpoint:10
                                    profile:49246
                                    input clusters:0,4096,4,3,5,6,8,768,64718
                                    output clusters:25
                                    endpoint:11
                                    profile:49246
                                    output clusters:
                                      arteck Developer Most Active @Zentapher last edited by arteck
                                      @Zentapher sagte in ZigBee neue/unbekannte Geräte - ab 1.0.0:
                                      lumi.plug.mmeu01
                                      probiermal
                                      @FredF
                                      supports: on/off, brightness, color temperature, color xy
                                      das wird supported.. da steht nix von W
                                      FredF Z Robi1010MD 3 Replies Last reply Reply Quote 0
                                      • FredF
                                        FredF Most Active Forum Testing @arteck last edited by
                                        @arteck sagte in ZigBee neue/unbekannte Geräte - ab 1.0.0:
                                        • Z
                                          Zentapher @arteck last edited by
                                          @arteck
                                          Super, funktioniert! Vielen Dank.
                                            chiroptera @aSilentSniper last edited by chiroptera
                                            @Asgothian Ich habe das selbe Problem mit der open/close Remote. Das Rollo kann mit dem CC2531 Stick gepairt werden und ist auch über ioBroker steuerbar. Wenn man versucht die Fernbedienung direkt mit dem Rollo zu pairen, dann ist das Pairing des Rollos wieder entfernt. Rollo und Fernbedienung lassen sich mit dem CC2531 Stick pairen, dann kommt aber die Fehlermeldung wie oben im Screenshot "not described in statesMapping" bei jedem Tastendruck. Das Profil der Fernbedienung ist auch nicht ordentlich vorhanden - keine Zustände. Das Rollo lässt sich in diesem Zustand über ioBroker aber noch steuern.
                                            Es scheint also nicht möglich das Rollo mit der Fernbedienung zu pairen und gleichzeitig über zigbee2mqqt. Beide Geräte Rollo und Fernbedienung lassen sich über zigbee2mqqt pairen.
                                            Nachtrag: Wenn man nur die Fernbedienung allein pairt, dann kommt die selbe Fehlermeldung bei jedem Tastendruck.
                                            Edit:
                                            Gerade erst gesehen - ich schau mal welche Version ich einsetze und gebe Rückmeldung ob es mit 1.0.3 funktioniert.
                                            Edit:
                                            Funktioniert einwandfrei mit V1.0.3 🙂
                                            neuer converter zigbee zigbee 3.x
                                            87
                                            402
                                            71209
