    4. Adapter "smartmeter"
      Stan2449 @klassisch last edited by
      @klassisch
      In Netzwerkschrank ist der Pi 4 drine.
        Stan2449 @Stan2449 last edited by
        ▒▒rbe▒▒zw▒▒ǂ▒EMHw       ▒
                                        EMHl▒u▒d▒bR▒VnY▒▒d▒bR▒Vn▒bR▒VnY▒▒bR▒Vn▒bR▒V▒bR▒Vw▒b▒U▒iw▒▒ǂ▒PuTTY                                                       ▒▒▒x▒N▒{▒▒5ܜ▒▒r#▒▒h▒▒𚊀▒6▒▒▒▒/,r*:c▒v
                                            Z▒▒bbrcqc  9▒
                                                         Z▒▒bbrcv▒▒J
        EMHl▒uc]▒v
        Z▒▒bbrcw
        EMHl▒ub
        ▒▒rbe▒▒zw▒▒ǂ▒EMHw       ▒
                                        EMHl▒u▒d▒bR▒VnY▒▒d▒bR▒Vn▒bR▒VnY▒▒bR▒Vn▒bR▒V▒bR▒Vw▒b▒U▒▒w▒▒ǂ▒PuTTY                                                       ▒▒▒x▒N▒{▒▒5ܜ▒▒r#▒▒h▒▒𚊀▒6▒▒▒▒/,r*:c▒▒v
                                             Z▒▒bbrcqc*
                                                       Z▒▒bbrcv▒▒L
        EMHl▒uc.v
        Z▒▒bbrcw
        EMHl▒ub
        ▒▒rbe▒▒zw▒▒ǂ▒EMHw       ▒
                                        EMHl▒u▒d▒bR▒VnY▒▒d▒bR▒Vn▒bR▒VnY▒▒bR▒Vn▒bR▒V▒bR▒Vw▒b▒U▒,w▒▒ǂ▒▒▒▒xP                                                       uTTY▒N▒{▒▒5ܜ▒▒r#▒▒h▒▒𚊀▒6▒▒▒▒/,r*:c▒~v
                                             Z▒▒bbrcqc▒▒]
                                                         Z▒▒bbrcv▒▒N
        EMHl▒uc▒dv
        Z▒▒bbrcw
        EMHl▒ub
        ▒▒rbe▒▒zw▒▒ǂ▒EMHw       ▒
                                        EMHl▒u▒d▒bR▒VnY▒▒d▒bR▒Vn▒bR▒VnY▒▒bR▒Vn▒bR▒V▒bR▒Vw▒b▒U▒▒w▒▒ǂ▒▒▒▒x▒                                                       PuTTYN▒{▒▒5ܜ▒▒r#▒▒h▒▒𚊀▒6▒▒▒▒/,r*:cH▒v
                                             Z▒▒bbrcqc▒▒
                                                        Z▒▒bbrcv▒▒P
        EMHl▒uc▒Pv
        Z▒▒bbrcw
        EMHl▒ub
        ▒▒rbe▒▒zw▒▒ǂ▒EMHw       ▒
                                        EMHl▒u▒d▒bR▒VnZ▒d▒bR▒Vn▒bR▒VnZ▒bR▒Vn▒bR▒V▒bR▒Vw▒b▒U▒▒w▒▒ǂPuTTY▒▒▒                                                       ▒x▒N▒{▒▒5ܜ▒▒r#▒▒h▒▒𚊀▒6▒▒▒▒/,r*:c▒9v
                                           Z▒▒bbrcqc)gm
                                                       Z▒▒bbrcv▒▒R
        EMHl▒ucd▒v
        Z▒▒bbrcw
        EMHl▒ub
        ▒▒rbe▒▒zw▒▒ǂ▒EMHw       ▒
                                        EMHl▒u▒d▒bR▒VnZ▒d▒bR▒Vn▒bR▒VnZ▒bR▒Vn▒bR▒V▒bR▒Vw▒b▒U▒ow▒▒ǂ▒▒PuTTY▒                                                       ▒x▒N▒{▒▒5ܜ▒▒r#▒▒h▒▒𚊀▒6▒▒▒▒/,r*:cHv
                                          Z▒▒bbrcqc▒.▒
                                                      Z▒▒bbrcv▒▒T
        EMHl▒uc▒▒v
        Z▒▒bbrcw
        EMHl▒ub
        ▒▒rbe▒▒zw▒▒ǂ▒EMHw       ▒
                                        EMHl▒u▒d▒bR▒VnZ%▒d▒bR▒Vn▒bR▒VnZ&▒bR▒Vn▒bR▒V▒bR▒Vw▒b▒Uw▒▒ǂ▒PuTTY▒▒                                                       ▒x▒N▒{▒▒5ܜ▒▒r#▒▒h▒▒𚊀▒6▒▒▒▒/,r*:c▒rv
                                           Z▒bbrcqc▒}
                                                     Z▒bbrcv▒▒V
        EMHl▒uch▒v
        Z▒bbrcw
        EMHl▒ub
        ▒▒rbe▒▒zw▒▒ǂ▒EMHw       ▒
                                        EMHl▒u▒d▒bR▒VnZ7▒d▒bR▒Vn▒bR▒VnZ8▒bR▒Vn▒bR▒V▒bR▒Vw▒b▒U▒
        w▒▒ǂ▒PuTTY▒                                                       ▒▒x▒N▒{▒▒5ܜ▒▒r#▒▒h▒▒𚊀▒6▒▒▒▒/,r*:cĞv
                                           Z▒bbrcqc▒▒▒^C
        Kann ich damit etwas rausfinden?
        S K 2 Replies Last reply Reply Quote 0
          @Stan2449
          Mal passt es, mal nicht. Das ist etwas komisch
          undefined2020-02-27 18:47:36.533 - info: smartmeter.0 (23611) List of port: [{"manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2129016","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2129016-if00","vendorId":"1cf1","productId":"0030","path":"/dev/ttyACM0"},{"manufacturer":"FTDI","pnpId":"usb-FTDI_USB__-__Serial-if00-port0","vendorId":"0403","productId":"6001","path":"/dev/ttyUSB0"},{"path":"/dev/ttyAMA0"}]
          2020-02-27 18:47:45.769 - info: smartmeter.0 (23611) Received 10 values, 3 updated
          2020-02-27 18:47:52.986 - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 (force=false, process=true)
          2020-02-27 18:47:52.988 - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 send kill signal
          2020-02-27 18:47:52.992 - info: smartmeter.0 (23611) Got terminate signal TERMINATE_YOURSELF
          2020-02-27 18:47:52.994 - info: smartmeter.0 (23611) terminating
          2020-02-27 18:47:52.995 - info: smartmeter.0 (23611) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2020-02-27 18:47:53.514 - info: host.raspberrypi instance system.adapter.smartmeter.0 terminated with code 156 (156)
          2020-02-27 18:47:55.513 - info: host.raspberrypi instance system.adapter.smartmeter.0 started with pid 3418
          2020-02-27 18:47:57.630 - info: smartmeter.0 (3418) starting. Version 3.0.10 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v10.19.0
          2020-02-27 18:47:58.570 - info: smartmeter.0 (3418) Error: Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 18:47:58.574 - warn: smartmeter.0 (3418) Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 18:47:59.202 - info: smartmeter.0 (3418) List of port: [{"manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2129016","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2129016-if00","vendorId":"1cf1","productId":"0030","path":"/dev/ttyACM0"},{"manufacturer":"FTDI","pnpId":"usb-FTDI_USB__-__Serial-if00-port0","vendorId":"0403","productId":"6001","path":"/dev/ttyUSB0"},{"path":"/dev/ttyAMA0"}]
          2020-02-27 18:48:29.893 - info: smartmeter.0 (3418) Received 10 values, 10 updated
          2020-02-27 18:49:00.332 - info: smartmeter.0 (3418) Error: Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 18:49:00.333 - warn: smartmeter.0 (3418) Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 18:49:31.572 - info: smartmeter.0 (3418) Received 10 values, 3 updated
          2020-02-27 18:50:00.026 - info: host.raspberrypi instance system.adapter.openweathermap.0 started with pid 4692
          2020-02-27 18:50:01.978 - info: smartmeter.0 (3418) Error: Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 18:50:01.979 - warn: smartmeter.0 (3418) Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 18:50:03.509 - info: openweathermap.0 (4692) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v10.19.0
          2020-02-27 18:50:06.852 - info: openweathermap.0 (4692) Terminated (NO_ERROR): Without reason
          2020-02-27 18:50:07.376 - info: host.raspberrypi instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
          2020-02-27 18:50:33.046 - info: smartmeter.0 (3418) Received 10 values, 3 updated
          2020-02-27 18:51:03.436 - info: smartmeter.0 (3418) Error: Error while parsing SML message: Error: Wrong TL-Field (7) for Unsigned!: Message: 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
          2020-02-27 18:51:03.436 - warn: smartmeter.0 (3418) Error while parsing SML message: Error: Wrong TL-Field (7) for Unsigned!: Message: 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
          2020-02-27 18:51:33.753 - info: smartmeter.0 (3418) Error: Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 18:51:33.754 - warn: smartmeter.0 (3418) Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 18:52:04.869 - info: smartmeter.0 (3418) Received 10 values, 3 updated
          2020-02-27 18:52:34.989 - info: smartmeter.0 (3418) Error: Error while parsing SML message: Error: Wrong TL-Field (3) for Unsigned!: Message: 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
          2020-02-27 18:52:34.990 - warn: smartmeter.0 (3418) Error while parsing SML message: Error: Wrong TL-Field (3) for Unsigned!: Message: 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
          2020-02-27 18:53:05.103 - info: smartmeter.0 (3418) Error: Error while parsing SML message: Error: Unknown TL-Field for SmlListEntry!: Message: 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
          2020-02-27 18:53:05.105 - warn: smartmeter.0 (3418) Error while parsing SML message: Error: Unknown TL-Field for SmlListEntry!: Message: 1b1b1b1b010101017607000f0b5aa192620062007263010176010107000f03fee0860b0901454d4800006cf775010163da33007607000f0b5aa193620062007263070177010b0901454d4800006cf775070100620affff7262016503fe14357a77078181c78203ff0101010104454d480177070100000009ff010101010b0901454d4800006cf7750177070100010800ff6401018201621e52ff5600046e7ee10177070100020800ff6401018201621e52ff56000000066e0177070100010801ff0101621e52ff5600046e7ee10177070100020801ff0101621e52ff56000000066e0177070100010802ff0101621e52ff5600000000000177070100020802ff8205ff010101018302cfcb78c14eae7bbe0fdd35dc9cc3db722303b07508b068d008118ef2f09a8a80f20636c318060f18b1cdfb2f2c722a3a0101016306ae007607000f0b5aa2026200620072630201710163c4e0001b1b1b1b1a00d446
          2020-02-27 18:53:15.607 - info: tankerkoenig.0 (2928) Reading data from tankerkoenig ...
          2020-02-27 18:53:35.949 - info: smartmeter.0 (3418) Error: Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 18:53:35.950 - warn: smartmeter.0 (3418) Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 1b1b1b1b010101017607000f0b5aa204620062007263010176010107000f03fee0ac0b0901454d4800006cf775010163e753007607000f0b5aa20562006200007263070177010b0901454d4800006cf775070100620affff7262016503fe14537a77078181c78203ff0101010104454d480177070100000009ff01010100010b0901454d4800006cf7750177070100010800ff6401018201621e52ff5600046e7f700177070100020800ff6401018201621e52ff56000000066e017700070100010801ff0101621e52ff5600046e7f700177070100020801ff0101621e52ff56000000066e0177070100010802ff0101621e52ff560000000000010077070100020802fff41b1b1b1b01010101
          2020-02-27 18:54:07.170 - info: smartmeter.0 (3418) Received 10 values, 3 updated
          2020-02-27 18:54:38.345 - info: smartmeter.0 (3418) Error: Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 18:54:38.347 - warn: smartmeter.0 (3418) Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 18:55:00.031 - info: host.raspberrypi instance system.adapter.openweathermap.0 started with pid 8180
          2020-02-27 18:55:03.322 - info: openweathermap.0 (8180) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v10.19.0
          2020-02-27 18:55:06.730 - info: openweathermap.0 (8180) Terminated (NO_ERROR): Without reason
          2020-02-27 18:55:07.255 - info: host.raspberrypi instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
          2020-02-27 18:55:09.599 - info: smartmeter.0 (3418) Received 10 values, 3 updated
          2020-02-27 18:55:39.749 - info: smartmeter.0 (3418) Error: Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 18:55:39.749 - warn: smartmeter.0 (3418) Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 18:56:11.480 - info: smartmeter.0 (3418) Received 10 values, 3 updated
          2020-02-27 18:56:41.789 - info: smartmeter.0 (3418) Error: Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 18:56:41.789 - warn: smartmeter.0 (3418) Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 18:57:12.287 - info: smartmeter.0 (3418) Received 10 values, 3 updated
          2020-02-27 18:57:42.595 - info: smartmeter.0 (3418) Error: Error while parsing SML message: Error: Wrong TL-Field (7) for Unsigned!: Message: 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
          2020-02-27 18:57:42.596 - warn: smartmeter.0 (3418) Error while parsing SML message: Error: Wrong TL-Field (7) for Unsigned!: Message: 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
          2020-02-27 18:58:12.880 - info: smartmeter.0 (3418) Error: Error while parsing SML message: Error: Wrong TL-Field (4) for Unsigned!: Message: 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
          2020-02-27 18:58:12.883 - warn: smartmeter.0 (3418) Error while parsing SML message: Error: Wrong TL-Field (4) for Unsigned!: Message: 1b1b1b1b010101017607000f0b5aa5ee620062007263010176010107000f03fee1fa0b0901454d4800006cf775010163becb007607000f0b5aa5ef620062007263070177010b0901454d4800006cf775070100620affff7262016503fe15697a77078181c78203ff0101010104454d480177070100000009ff010101010b0901454d4800006cf7750177070100010800ff6401018201621e52ff5600046e827b0177070100020800ff6401018201621e52ff56000000066e0177070100010801ff0101621e52ff5600046e827b0177070100020801ff0101621e52ff56000000066e0177070100010802ff0101621e52ff5600000000000177070100020802ff4800006cf7750177070100010800ff6401018201621e52ff5600046e82ce0177070100020800ff6401018201621e52ff56000000066e0177070100010801ff0101621e52ff5600046e82ce0177070100020801ff0101621e52ff56000000066e0177070100010802ff0101621e52ff5600000000000177070100020802ff0101621e52ff5600000000000177070100100700ff0101621b52ff5500002e640177078181c78205ff010101018302cfcb78c14eae7bbe0fdd35dc9cc3db722303b07508b068d008118ef2f09a8a80f20636c318060f18b1cdfb2f2c722a3a01010163b881007607000f0b5aa66462006200726302017101634a3f001b1b1b1b1a00940a
          2020-02-27 18:58:43.727 - info: smartmeter.0 (3418) Error: Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 1b1b1b1b010101017607000f0b5aa666620062007263010176010107000f03fee2220b0901454d4800006cf775010163d9ee007607000f0b5aa66762006200007263070177010b0901454d4800006cf775070100620affff7262016503fe15877a77078181c78203ff0101010104454d480177070100000009ff01010100010b0901454d4800006cf7750177070100010800ff6401018201621e52ff5600046e82d90177070100020800ff6401018201621e52ff56000000066e017700070100010801ff0101621e52ff5600046e82da0177070100020801ff0101621e52ff56000000066e0177070100010802ff0101621e52ff560000000000010077070100020802ff081b1b1b1b01010101
          2020-02-27 18:58:43.728 - warn: smartmeter.0 (3418) Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 18:59:15.352 - info: smartmeter.0 (3418) Received 10 values, 3 updated
          2020-02-27 18:59:46.079 - info: smartmeter.0 (3418) Error: Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 18:59:46.079 - warn: smartmeter.0 (3418) Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 19:00:00.012 - info: host.raspberrypi instance system.adapter.openweathermap.0 started with pid 11211
          2020-02-27 19:00:03.020 - info: openweathermap.0 (11211) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v10.19.0
          2020-02-27 19:00:06.732 - info: openweathermap.0 (11211) Terminated (NO_ERROR): Without reason
          2020-02-27 19:00:07.244 - info: host.raspberrypi instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
          2020-02-27 19:00:17.575 - info: smartmeter.0 (3418) Received 10 values, 3 updated
          2020-02-27 19:00:48.509 - info: smartmeter.0 (3418) Error: Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 1b1b1b1b010101017607000f0b5aa85e620062007263010176010107000f03fee2ca0b0901454d4800006cf7750101630f8a007607000f0b5aa85f62006200007263070177010b0901454d4800006cf775070100620affff7262016503fe16047a77078181c78203ff0101010104454d480177070100000009ff01010100010b0901454d4800006cf7750177070100010800ff6401018201621e52ff5600046e87850177070100020800ff6401018201621e52ff56000000066e017700070100010801ff0101621e52ff5600046e87850177070100020801ff0101621e52ff56000000066e0177070100010802ff0101621e52ff560000000000010077070100020802ffa91b1b1b1b01010101
          2020-02-27 19:00:48.510 - warn: smartmeter.0 (3418) Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
          2020-02-27 19:01:20.455 - info: smartmeter.0 (3418) Received 10 values, 3 updated
          2020-02-27 19:01:50.572 - info: smartmeter.0 (3418) Error: Error while parsing SML message: Error: Wrong TL-Field (7) for Unsigned!: Message: 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
          2020-02-27 19:01:50.572 - warn: smartmeter.0 (3418) Error while parsing SML message: Error: Wrong TL-Field (7) for Unsigned!: Message: 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
            klassisch Most Active @Stan2449 last edited by
            @Stan2449 Was ist das? Terminlausgabe des USB Datenstroms?
            SML ist binär, also keine lesbare Klarschrift. Ich habe das auch mal mit einem billigen "IR flame detector" versucht. Das Terminalprogramm zeigt nur unlesbares, ioBroker konnte aber alles lesen.
              apollon77 @klassisch last edited by
              @klassisch sagte in Adapter "smartmeter":
              Laut Datenblatt 25mA Stromaufnahme, das sollte kein Problem sein.
              Wäre ich mir so nicht sicher ... Ich musste das machen weil ich sonst störungen hatte ... also who knows
                klassisch Most Active @apollon77 last edited by
                @apollon77 sagte in Adapter "smartmeter":
                den aktiven Hub zwischenschalten?
                kann natürlich auch andere Ursachen haben. Vielleicht hat der Hub die bessere noise rejection oder einfach die stabilere Versorgung. Aber einen Versuch ist der aktive Hub allemal wert, da bin ich völlig bei Dir.
                Man könnte auch noch ioBroker mit dem SmartMeter-Adapter probehalber auf einen Laptop installieren. Dann sieht man, ob es etwas mit dem RasPi zu tun hat. So habe ich das getestet. Ich habe ja noch keinen neuen Zähler, aber schon mal gespielt, Leitungen verlegt und das Setup erstellt und andernorts mit einer gleich langen Leitung und einem Laptop getestet. Dabei verwende ich einen passiven Hub und ziehe knapp <200mA aus der USB-Buchse meines Test-Laptops. Am Hub hängt auch noch der RFLink Arduino Mega
                Die Leitung zum SmartMeter Lesekopf ist 23m lang; dünne billige Telefonleitung, damit ich nicht so viel bohren muß (passt noch in vorhandene Löcher mit rein). Die Übertragung erfolgt allerdings via RS485. Entsprechende Module und Konverter gibts billig bei Aliexpress und ebay. In die USB-Leitung zum RS485 Konverter habe ich sicherheitshalber noch einen USB Isolator geschaltet. Wahrscheinlich völlig übeflüssig, und daher wohl auch die rel. hohe Stromaufnahme. Hat aber bei meinem Tests bisher funktioniert.
                  sourex last edited by
                  Moin.
                  Habe gestern meine Leseköpfe bekommen und wollte mich nächste Woche mal daran machen das umzusetzen. Leider bin ich das ganze Wochenende am arbeiten und habe extreme diesen Thread hier zu lesen auf dem Handy, da beim Scrollen immer plötzlich entweder zig Seiten übersprungen werden oder der Thread auf einmal nicht mehr weiter lädt.
                  Falls ich irgendwo eine Anleitung übersehen die die Installation des Adapters an sich (host) übersehen habe könnt ihr mir diese gerne verlinken.
                  Ausgangslage:
                  Ein Nuc ähnlichen Rechner
                  2 Leseköpfe gebaut nach Anleitung
                  zwei Iscra mt681 Zähler mit PIN
                  Keine PV Anlage.
                  Also werde ich als erstes die beiden usb Ports mit der Rule Datei klar definieren und anschließend mit Minicom Datentransfer einrichten.
                  Was ich verstanden habe ist das wenn man zusätzlich ein PI zum auslesen nutz man diesen als Slave installieren muss. Ich wollte die Zähler allerdings direkt an dem Rechner anschließen an dem auch IOBroker am laufen habe. Muss ich dann auch irgendwas mit den Hosts machen ?
                  Habe den Adapter einfach schon mal testweise installiert, finde aber nichts zu dieser Einstellung. Auch im IOBroker selber habe ich nichts unter dem Reiter Host gefunden was in Richtung Slave geht. Könnte mir das bitte einer erklären ??
                  Daten die ich im Adapter selber einstellen muss habe ich schon über das volkszähler Wiki gefunden..
                    klassisch Most Active @sourex last edited by
                    @sourex sagte in Adapter "smartmeter":
                    Ausgangslage:
                    Ein Nuc ähnlicher Rechner
                    Welches OS? Linux?
                    Getestet?
                    Haben die jeweils eine eindeutige Id? Volkszähler verwendet CP2104, da sollte das gehen. Starte der Einfachheit erst mal mit einem Kopf solange bis alles mit diesem Kopf richtig läuft.
                    Also USB Extender? Zwei Extender oder ein Extender mit USB-Hub auf der Zählerseite?
                    Dein ioBroker Rechner ist derH Master-Host. Der reicht dann und Du brauchst keinen weiteren Slave. Du mußt also keinen Multihost Betrieb einrichten. Das ist einer der Vorteile des USB Extenders.
                    Prima, bei 2 Leseköpfe wird man wohl 2 Instanzen brauchen, je einen für jeden Adapter. Auch hier würde ich nacheinander installieren. Erst einen zum Laufen bekommen, dann den anderen nachziehen.
                      sourex @klassisch last edited by sourex
                      @klassisch said in Adapter "smartmeter":
                      Welches OS? Linux?
                      Lubuntu
                      Das hoffe ich. Die einzige Info die ich habe ist das er nach der Anleitung von Smarthome-Tricks.de gebaut ist.
                      Das habe ich wohl unterschätzt, ich hatte es einfach ohne geplant. Mein Server hat 4 USB Ports wovon ich zwei nutzen wollte.
                      Aktuell ist die Situation das an den Köpfen ein 85cm Kabel langes Kabel ist welches aus dem Zählerschrank führt. Diese wollte ich jeweils mit einer 2m USB Verlängerung zum Server führen.
                      Sollte ich da besser direkt ein aktiven hub einplanen oder reicht der Strom vom Server evtl ???
                      Heißt dein Kommentar mit den Extender das bei eine Hub doch Multihost brächte. Da fehlt mir wohl noch wissen.
                      Ansonsten vielen Dank schon mal für deine wertvollen Tipps.
                        klassisch Most Active @sourex last edited by klassisch
                        @sourex ca. 3m USB Leitung sollte gehen, auch ohne den Minicom-Extender. Praktisch wenn der ioBroker Rechner so nahe ist. Und bei meinen Versuchen - allerdings mit einem anderen Kopf - lief es probehalbe auch direkt am USB Port des Laptops. Aber @apollon77 hat die Erfahrung gemacht, daß er den aktiven USB Hub mit Netzteil gebraucht hat. Experimenteller Befund. Und wenn Du Probleme hast, dann ist das allemal ein Versuch wert. Meist liegt noch so ein Ding mit Netzteil rum, ansonsten kostet das nicht die Welt und kann auch anderweitig verwendet werden.
                        Bei einem Hub brauchst Du keinen Multihost. Das verhält sich ähnlich wie wenn Du 2 USB Buchsen Deines Rechners belegst. Der aktive Hub hat den Vorteil, daß er ein zusätzliches Netzteil hat und damit oft eine bessere Versorgung der angeschlossenen Geräte bewirkt als der Rechner selbst. Wie gesagt, bei meinen Versuchen gings ohne, aber die Erfahrungen von @apollon77 sind anders. Kann von vielen Dingen abhängen: Dem Rechner dem Lesekopf, Signalstörungen. Deshalb: experimenteller Befund ohne genau Ursachenkenntnis und bei Problemen sicher einen Versuch wert. Ohne Probleme aber auch kein Bedarf.
                        S apollon77 2 Replies Last reply Reply Quote 0
                          @klassisch
                          Super erklärt.
                          Danke.
                          Hoffe ich komme Dienstag dazu ihn einzurichten..
                            @klassisch Jupp. Wenn ich mich richtig erinnere fingen die Probleme auch erst als ich einen zweiten Kopf von den gleichen Rechner bei USB angeschlossen habe. Kannst du sprechen danach von noch einem mbus Stick 😉
                              Leider bin ich nicht weit gekommen.
                              Habe wie geraten erst mal nur einen Zähler angeschlossen.
                              Dieser wird erkannt am USB Anschluss. Allerdings habe ich nicht den Eintrag den man laut Anweisung vom Volkszähler benutzten soll um eine eindeutige ID zuzuweisen
                              Anschließend habe ich über Minicom alles eingestellt (auch mit 8n1 getestet weil das anscheinend für meinen Zähler richtig ist.
                              stutzig macht mich das dort immer offline steht, ist das richtig ?
                              wenn ich anschließend den cat Befehl ausführe zum Anzeigen benutzte passiert nichts.
                              Habe anschließend einfach trotzdem mal den Adapter getestet aber auch der geht natürlich nicht.
                              Kann mir einer weiterhelfen bitte ??
                              Danke !
                                apollon77 @sourex last edited by
                                @sourex also das zuweisen des eigenen Namens brauchst du nicht mit dem 3er smartmeter Adapter. Der Adapter speichert eine is die sich nicht ändert.
                                Jetzt zeig mal die Einstellungen im Adapter und sag nochmal welcher Zähler es ist und was im iobroker logfile steht.
                                  sourex @apollon77 last edited by
                                  @apollon77
                                  moin und schon mal Danke das mir geholfen wird.
                                  Die Zähler sind beide Ikra mt681.
                                  Habe es zunächst mit diesen Einstellungen versucht die jemand hier im Thread erfolgreich mit dem Zähler getestet hat.
                                  Anschließend habe ich mir die Daten von der Volkszählerseite vorgenommen und habe es so versucht
                                  LogFile
                                  Frage meinerseits:
                                  Also kann ich mir die Anleitung mit der ID-Namensvergabe komplett vergessen? Der zweite Zähler würde nie mit dem ersten vertauscht werden bei der aktuellen Version ?
                                  Falls es daran liegt das ich einen aktiven Hub bräuchte wie du auch, würde es dann so wie jetzt aussehen oder würden dann sporadisch Werte ankommen ?
                                    @sourex Ja mit der aktuellen Version (siehe auch dieser laaange String bei der Auswahl des gerätes) - der ist Geräterspezifisch und USB port spezifisch. Wenn das Gerät im gleichen USB drin bleib dann behält es in jedem Fall die ID.
                                    ALso ja scheinbar kommen gar keine Werte vom gerät.
                                    Wäre also zuerst mal zu testen ob überhaupt was gesendet wird. Der Zähler sollte alle paar sekunden was schicken. Dazu am besten kopf abmachen und nen digital fotoapparat nehmen (bei Handy kameras geht das teilweise nimmer). dann drauf halten auf die LEDs und ins display schauen. wenn Daten kommen solltest Du sehen das die eine LED im display" leuchtet". wenn das nicht kommt sendet der nix. Wenn es geht checken das der kopf richtig rum drauf ist 🙂
                                      habe ich gemacht. ich sehe geschätzt alle 2 sek eine rote led aufflackern.
                                      Pin habe ich zwar noch nicht eingegeben aber dachte das mach ich wenn es läuft.
                                      beim Kopf ist es so das das Kabel nach unten zeigt, hatte ich mal irgendwo gelesen.
                                      Teste das aber mal eben.
                                      soll ich lieber mit dem cat befehl oder direkt über smartmeter testen ?
                                        @sourex So wenn die leuchtet dann sendet er schonmal daten und du weisst auch welche LED die Daten sendet. Kopf richtig aufsetzen und dann mit cat versuchen. Wenn er datens endet ists erstmal egal was minicom da eingestellt hat ... du solltest etwas sehen (auch wenns Datenschrott ist). So lange das nicht kommt brauchst Du Adapter nicht anzufangen 😉
                                          @apollon77 said in Adapter "smartmeter":
                                          so leicht kann es sein 😄 das war es !!
                                          Den anderen Zähler auch direkt verbunden, wurde auch im Smartmeter direkt übernommen.
                                          Cooler Adapter und sofortiger Support. Perfekte Arbeit Apollon !!
                                          da wir eh gerade diskutieren, darf ich der Leichtigkeit (Faulheit) um einen Link bitten der die nun ausgewerteten Daten erklärt bzw in eine VIS übernimmt 🙄
                                            sourex last edited by sourex
                                            Leider zu früh gefreut. Aber es geht voran 😄
                                            Die zweite Instanz greift leider auch auf den Zähler mit ttyUSB0.
                                            Wenn ich dort auf ttyUSB1 wechsel (welcher auch erkannt wurde und zuvor auch glaube ich garnicht in der Auswahl stand) und speichere wird das nicht übernommen ! er wechselt automatisch wieder auf port 0.
                                            Bei der Einrichtung des zweiten IR Kopf bin ich mir aber eigentlich recht sicher das ich auch kurz wirklich beide unterschiedlichen Zählerwerte hatte.
                                            Soll ich das nun doch mit der Benennung der Ports machen ?
                                            3625
                                            2287008
