    4. Test Adapter deConz v1.2.x Github
      e-s last edited by
      @Jey-Cee
      irgendwie startet der Adapter ständig neu:
      deconz.0	2020-02-25 20:59:47.881	debug	(31577) Subscribed to updates...
      deconz.0	2020-02-25 20:59:47.456	debug	(31577) Code 200: Request succeded get group attributes 65259: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["3
      deconz.0	2020-02-25 20:59:47.442	debug	(31577) Code 200: Request succeded get group attributes 3: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"eta
      deconz.0	2020-02-25 20:59:47.437	debug	(31577) Code 200: Request succeded get group attributes 2: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"eta
      deconz.0	2020-02-25 20:59:47.431	debug	(31577) Code 200: Request succeded get group attributes 1: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["5"],"
      deconz.0	2020-02-25 20:59:47.340	info	(31577) Code 404: Ressource not found get devices: []
      deconz.0	2020-02-25 20:59:47.146	debug	(31577) Code 200: Request succeded get all groups: {"1":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["5"],"eta
      deconz.0	2020-02-25 20:59:47.055	debug	(31577) Code 200: Request succeded get all sensors: {"10":{"config":{"battery":95,"on":true,"reachable":true,"temperature":2400},"ep":1,"etag":"9cb1f92a7f59e29ab5a5cc7d922f79ff","manufacturername":"LU
      deconz.0	2020-02-25 20:59:47.015	debug	(31577) Code 200: Request succeded get all lights: {"1":{"etag":"94975c4b3b5d467616ff32409c79d3fa","hascolor":false,"manufacturername":"IKEA of Sweden","modelid":"TRADFRI signal repeater","name":"Rang
      deconz.0	2020-02-25 20:59:46.990	info	(31577) deConz Version: 2.5.74; API version: 1.16.0
      deconz.0	2020-02-25 20:59:46.988	debug	(31577) Code 200: Request succeded get config: {"UTC":"2020-02-25T19:59:46","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF04D6DF","datastoreversion":"60","devic
      deconz.0	2020-02-25 20:59:46.877	info	(31577) starting. Version 1.2.5 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.19.0
      host.ubuntuserver	2020-02-25 20:59:45.064	info	Restart adapter system.adapter.deconz.0 because enabled
      host.ubuntuserver	2020-02-25 20:59:45.059	error	instance system.adapter.deconz.0 terminated with code 156 (156)
      deconz.0	2020-02-25 20:59:44.490	warn	(30451) Got terminate signal. Checking desired PID: 31577 vs own PID 30451
      deconz.0	2020-02-25 20:59:44.489	debug	(30451) Websocket connection closed
      deconz.0	2020-02-25 20:59:44.487	info	(30451) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      deconz.0	2020-02-25 20:59:44.486	info	(30451) terminating
      deconz.0	2020-02-25 20:59:44.482	warn	(30451) Got terminate signal. Checking desired PID: 0 vs own PID 30451
      host.ubuntuserver	2020-02-25 20:59:44.475	info	instance system.adapter.deconz.0 started with pid 31577
      deconz.0	2020-02-25 20:59:27.860	debug	(30451) Subscribed to updates...
      bei Subscribed to updates... bleibt er immer hängen und startet dann neu
      api habe ich mal neu erstellt, ohne Erfolg. was hat der 404 error zu sagen?
      • Jey Cee
        Jey Cee Developer @e-s last edited by
        @e-s puh irgendwo her bekommt er ein Terminate Signal, aber keine Ahnung wo her. Du müsstest auf dem Host mit "ps -uax" schauen welcher Prozess die ID hat.
        Hier wäre es die 31577.
        Der 404 kommt von einer API Abfrage die in einer Zukünftigen deConz Version kommen wird. Deswegen ist er auch nur als Info drin, wenn es ein Fehler wäre wäre es mindestens Warn oder Error. Also kein Stress.
          e-s @Jey Cee last edited by
          @Jey-Cee
          nach downgrade von 1.2.5 zu 1.2.2. und hoch auf 1.2.4 sind keine Fehler mehr im log. Vielleicht lag es an der 1.2.5
          • Jey Cee
            Ich hab gerade die version 1.2.6 auf Github und npm Veröffentlicht. Alle die die Version 1.2.5 installiert haben sollten auf 1.2.6 Updaten.
            Es wurde ein Fehler behoben der den Adapter abstürzen lässt.
            Der bezieht sich auf diesen Issue bei Github von @realwax und wurde im Forum von @Holger76 gemeldet.
            realwax 2 Replies Last reply Reply Quote 1
            • realwax
              realwax @Jey Cee last edited by
              @Jey-Cee Danke! Ich werde ihn gleich testen.
              Interessant für alle Tradfri und deconz user ist der thread/issue hier
              https://github.com/dresden-elektronik/deconz-rest-plugin/issues/1261
              Kurzfassung: Es gibt eine neue FW für Conbee I & II (II dürfte noch nicht so gut sein.) Mit dieser FW plus
              http://deconz.dresden-elektronik.de/raspbian/beta/deconz-2.05.74-qt5.deb
              dürften die Tradfri Lampen fallen raus, freezen Probleme besser werden.
              Auch zu empfehlen ist das Update der Birnen auf die 2.x FWs. Das Netz scheint stabiler, und etwas "schneller".
              JBS5 created this issue in dresden-elektronik/deconz-rest-plugin
              closed IKEA lights occasionally lost connection #1261
              • realwax
                @Jey-Cee Kann bestätigen der Fehler ist weg, Ersteindruck: adapter läuft ohne Fehlermeldungen gut und stabil. Werde weiter testen... DANKE!
                • lobomau
                  lobomau @frankyboy73 last edited by lobomau
                  @frankyboy73 sagte in Test Adapter deConz v1.2.x Github:
                  Hi, gibt es bei Sensoren und Schalter irgendeine Begrenzung der Anzahl? Ich konnte 20 Senoren und Schalter Problemlos einbinden. Beim 21. kriege ich jetzt keine Objekte mehr angezeigt. In Phoscon ist er aber vorhanden und lässt sich auch verwenden. Habe Ihn auch schon mal glöscht und neu angelernt, keine Änderung. Es handelt sich um eine Ikea Fernbedienung, 2 andere habe ich auch schon drin und auch unter den Objekten dargestellt.
                  Habe es mal mit Adapter neustart versucht, da kommt dann im Log.
                  (1501) Code 404: Ressource not found get devices: []
                  hat das etwas damit zu tun?
                  Adapter Version ist 1.2.5
                  Ich habe ein ähnliches Probleme. Ich bekomme einen weiteren Xiaomi Kontaktsensor nicht unter Objekte bei ioBroker angezeigt. Es ist bereits der zweite, funktioniert also grundsätzlich (beide Version 20161128).
                  Sensoren habe ich 14 angelernt in der Phoscon App.
                  Unter ioBroker Objekte bin ich bei Nr. 50 angekommen. Da gibt es wohl keine Begrenzung?
                  Edit: ich habe vorher auf 1.2.6 geupdatet und habe auch die neue Gateway firmware 2.05.74.
                  Anderes Thema: grundsätzlich finde ich es schlecht, wenn für einen Sensor mehrere Ordner gemacht werden, z.B. beim Klimasensor jeweils für Temp, Feuchte und Druck:
                  haselchen A 2 Replies Last reply Reply Quote 1
                  • haselchen
                    haselchen Most Active @lobomau last edited by haselchen
                    @lobomau
                    "Edit: ich habe vorher auf 1.2.6 geupdatet und habe auch die neue Gateway firmware 2.05.74."
                    Software bitte nicht mit der Conbee 2 Firmware verwechseln .
                      sub1ne last edited by sub1ne
                      Ich hab stellenweise das Phänomen, dass meine Sensore meine Lichter nicht mehr ansteuern. Das lässt sich dann beheben indem ich den deconz Adapter stoppe und neu starte. Leider bin ich noch auf dem 1.1.2 stable. Gibt es einen Plan ab wann ein neueres Release verfügbar sein wird im stable? Oder habe ich die Möglichkeit nur den deconz adapter irgendwie zu aktualisieren (sorry für die Anfängerfrage)?
                      • Jey Cee
                        Jey Cee Developer @sub1ne last edited by
                        @sub1ne sagte in Test Adapter deConz v1.2.x Github:
                        Ich werde ihn im Laufe der Woche ins stable repo schieben.
                        • haselchen
                          haselchen Most Active @Jey Cee last edited by haselchen
                          @Jey-Cee
                          Jetzt bin ich auch mal von einem merkwürdigen Phänomen betroffen.
                          Ich habe in der Deconz App und im IObroker einen Xiaomi Temp.Sensor gelöscht.
                          Ich hatte ihn auch in der VIS drinnen. Adapter Version 1.2.6. Neu gestartet.
                          Er hatte die ID 5.
                          Wie man sieht, in den Okjekten keine 5 mehr da.
                          In der VIS erscheint aber immer noch Last Updatet. Wie geht das denn?
                          Als Datenpunkt ist noch die ID 5 eingetragen.
                          • Jey Cee
                            Jey Cee Developer @haselchen last edited by
                            @haselchen wie hast du die Objekte in ioBroker gelöscht?
                            Es sieht so aus als wäre der State lastupdated nicht gelöscht worden.
                            • haselchen
                              @Jey-Cee
                              Mülleimer des Ordners, alle Objekte löschen.
                              Ist ja auch nichts mehr da vom ID 5 Ordner.
                                Tirador last edited by
                                Hallo, ich habe heute auf die Version 1.2.6 geupdated.
                                Deconz hat die Version 2.5.74.
                                Leider bleibt der Adapter damit gelb (keine Verbindung).
                                Im Log steht nur folgendes:
                                  A Former User last edited by
                                  @Tirador das liegt glaube ich nicht am Adapter, ich habe auch 1.2.6 mit 2.05.74 ohne Probleme am laufen.
                                    Tirador @Guest last edited by
                                    @Brainbug Ich bin jetzt wieder auf die alte Version 1.1.2 zurück. Da ist der Adapter wieder grün. Zugangsdaten etc. absolut gleich. Und nun?
                                    • haselchen
                                      haselchen Most Active @Tirador last edited by haselchen
                                      @Tirador
                                      Ich würde eher die 2.05.74 downgraden.
                                      Da könnte der Fehler bei dir sein.
                                        Tirador @haselchen last edited by
                                        @haselchen ich hatte vorher auf der console per npm installiert. nun habe ich den weg über die oberfläche gemacht. nun ist der adapter grün.
                                        • haselchen
                                          @Tirador
                                          Da komme ich jetzt nicht ganz hinterher 🙂
                                          Was installiert, welche Version?
                                          Deconz?
                                          Adapter?
                                            @haselchen
                                            ich hatte vorher das upgrade des deconz Adapters auf der Console gemacht:
                                            d.h.
                                             cd /opt/iobroker
                                             npm i iobroker.deconz
                                            Nun habe ich die Installation des "community-Adapters" über die "Katze" im Adapter in der IOBroker Oberfläche durchgeführt.
                                            Auffällig war eventuell noch, dass der Port und das Passwort resettet wurden. Eventuell hat sich hier die Konfigurationsdatei geändert von Version 1.1.2 auf 1.2.6?
                                            Auf jeden Fall hat dies mein eigentliches Problem gelöst.
                                            Im Adapter der Version 1.1.2 hatten bestimmte Hue Taster keine Auswirkungen auf die Objekte von IOBroker.
                                            Man konnte gut erkennen, dass die Taster seit mehreren Tagen schon nicht mehr geupdatet wurden.
                                            In der Version 1.2.6 klappt es nun einwandfrei. Besten Dank an die Entwickler!
                                            31.7k
                                            79.8k
                                            deconz hue zigbee
                                            30
                                            250
                                            28479
