    4. XBox-Adapter Fehler
    SOLVED XBox-Adapter Fehler
    • Negalein
      Negalein Global Moderator @foxriver76 last edited by
      @foxriver76 sagte in XBox-Adapter Fehler:
      installier Mal neu. Angeblich gefixt mit 2.0.1
      $ ./iobroker url "https://github.com/foxriver76/ioBroker.xbox/tarball/master" xbox --debug
      install https://github.com/foxriver76/ioBroker.xbox/tarball/master
      NPM version: 6.11.3
      npm install https://github.com/foxriver76/ioBroker.xbox/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
      > iobroker.xbox@0.5.12 preinstall /opt/iobroker/node_modules/iobroker.xbox> dpkg --help > /dev/null && dpkg -s build-essential | grep -q '' && dpkg -s libssl-dev | grep -q '' && dpkg -s libffi-dev | grep -q '' && dpkg -s python3-dev | grep -q '' && echo -e '[INFO] Required Debian packages are already installed!' || apt install -y build-essential libssl-dev libffi-dev python3-dev || echo -e '[INFO] Cannot install build-essential libssl-dev libffi-dev python3-dev Debian packages. If you are on a Linux system, try installing the package via: sudo npm i iobroker.xbox --unsafe-perm, otherwise you have to manage package installation by yourself. If you are not running on Linux, you can ignore this INFO.'
      -e [INFO] Required Debian packages are already installed!
      > bufferutil@1.1.0 install /opt/iobroker/node_modules/bufferutil> node-gyp rebuild
      make: Verzeichnis „/opt/iobroker/node_modules/bufferutil/build“ wird betreten
        CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
      In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Integer; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local<v8::Integer> v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations] To<v8::Integer>(v8::Handle<v8::Integer> i) { return i->ToInteger(); }        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10052:16: note: declared here Local<Integer> Value::ToInteger() const {                ^~~~~
      In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’ To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note: candidate: v8::MaybeLocal<v8::Int32> v8::Value::ToInt32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Int32> ToInt32(Local<Context> context) const;                                           ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note: candidate: v8::Local<v8::Int32> v8::Value::ToInt32(v8::Isolate*) const                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note:   candidate expects 1 argument, 0 provided                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’ To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }        ^
      In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note: candidate: v8::MaybeLocal<v8::Uint32> v8::Value::ToUint32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Uint32> ToUint32(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note:   candidate expects 1 argument, 0 provided
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                      ^
      In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note: candidate: static v8::Local<v8::Value> v8::BooleanObject::New(v8::Isolate*, bool)   static Local<Value> New(Isolate* isolate, bool value);                       ^~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note:   candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                            ^../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                              ^
      ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::RegExp>::return_t NanIntern::Factory<v8::RegExp>::New(v8::Handle<v8::String>, v8::RegExp::Flags)’:../node_modules/nan/nan_implementation_12_inl.h:158:40: warning: ‘static v8::Local<v8::RegExp> v8::RegExp::New(v8::Local<v8::String>, v8::RegExp::Flags)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   return v8::RegExp::New(pattern, flags);                                        ^
      In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5110:38: note: declared here                        Local<RegExp> New(Local<String> pattern, Flags flags));                                      ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:173:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:../node_modules/nan/nan_implementation_12_inl.h:206:42: error: no matching function for call to ‘v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*&, v8::String::NewStringType, int&)’         v8::String::kNormalString, length);                                          ^
      In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note: candidate: static v8::MaybeLocal<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::NewStringType, int)   static V8_WARN_UNUSED_RESULT MaybeLocal<String> NewFromOneByte(                                                   ^~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note:   no known conversion for argument 3 from ‘v8::String::NewStringType’ to ‘v8::NewStringType’In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:../node_modules/nan/nan_implementation_12_inl.h:217:66: error: no matching function for call to ‘v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*&)’   return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);        ^
      In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note: candidate: static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalOneByteStringResource*)       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note:   no known conversion for argument 2 from ‘v8::String::ExternalStringResource*’ to ‘v8::String::ExternalOneByteStringResource*’       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:237:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:244:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~
      In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘uint32_t NanUInt32OptionValue(v8::Local<v8::Object>, v8::Handle<v8::String>, uint32_t)’:../node_modules/nan/nan.h:248:43: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       ? optionsObj->Get(opt)->Uint32Value()                                           ^
      In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here   V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);                                               ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’ NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {                         ^~~~~~~~~~~~~~~../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {                         ^~~~~~~~~~~~~~~
      ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:../node_modules/nan/nan.h:289:39: error: ‘class v8::Isolate’ has no member named ‘IdleNotification’; did you mean ‘IdleNotificationDeadline’?     return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);                                       ^~~~~~~~~~~~~~~~
      ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void       v8::Isolate::GCEpilogueCallback callback                    ^~~~~~~~~~~~~~~~~~
      ../node_modules/nan/nan.h:473:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCEpilogueCallback callback       ^~../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’     , v8::GCType gc_type_filter = v8::kGCTypeAll) {                  ^~~~~~~~~~~~~~../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void       v8::Isolate::GCEpilogueCallback callback) {                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:479:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCEpilogueCallback callback) {       ^~../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void       v8::Isolate::GCPrologueCallback callback                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:484:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCPrologueCallback callback       ^~../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’     , v8::GCType gc_type_filter = v8::kGCTypeAll) {                  ^~~~~~~~~~~~~~../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void       v8::Isolate::GCPrologueCallback callback) {                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:490:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCPrologueCallback callback) {       ^~
      ../node_modules/nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {               ^~~~~~~~~~~~~~~~
      ../node_modules/nan/nan.h:569:31: error: expected ‘,’ or ‘...’ before ‘<’ token     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {                               ^../node_modules/nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:../node_modules/nan/nan.h:570:42: error: ‘data’ was not declared in this scope       _NanWeakCallbackInfo<T, P> *info = data.GetParameter();                                          ^~~~
      ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared     , node::smalloc::FreeCallback callback             ^~~~~~~../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’     , node::smalloc::FreeCallback callback                                   ^~~~~~~~
      ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                  ^~~~~~~~../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                            ^~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);        ^In file included from ../src/bufferutil.cc:10:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_buffer.h:68:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’ NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,                                        ^~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:../node_modules/nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’     return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);            ^~~~
      ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan.h:710:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^
      In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:../node_modules/nan/nan.h:717:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::UnboundScript>)’:../node_modules/nan/nan.h:723:48: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->BindToCurrentContext()->Run();                                                ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::Script>)’:../node_modules/nan/nan.h:729:24: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->Run();                        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::Function>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, func, argc, argv));                                                            ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
      In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::String>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:747:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, symbol, argc, argv));                                                              ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:170:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
      In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, const char*, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, method, argc, argv));                                                              ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:163:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
      In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In member function ‘v8::Handle<v8::Value> NanCallback::Call_(v8::Isolate*, v8::Handle<v8::Object>, int, v8::Handle<v8::Value>*) const’:../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]     ));     ^../node_modules/nan/nan.h:398:59: note: in definition of macro ‘NanEscapeScope’ # define NanEscapeScope(val) scope.Escape(_NanEnsureLocal(val))                                                           ^~~
      In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘void* _NanRawString(v8::Handle<v8::Value>, Nan::Encoding, size_t*, void*, size_t, int)’:../node_modules/nan/nan.h:2164:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^
      In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:2198:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In constructor ‘NanTap::NanTap(v8::Handle<v8::Value>)’:../node_modules/nan/nan.h:2292:41: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     NanAssignPersistent(t_, t->ToObject());                                         ^
      In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
      ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(v8::Handle<v8::Object>)’:../src/bufferutil.cc:30:52: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [7], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "unmask", BufferUtil::Unmask);                                                    ^
      In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~../src/bufferutil.cc:31:48: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [5], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "mask", BufferUtil::Mask);                                                ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~../src/bufferutil.cc:32:50: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [6], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "merge", BufferUtil::Merge);                                                  ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~
      ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Merge(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/bufferutil.cc:49:49: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> bufferObj = args[0]->ToObject();                                                 ^
      In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:56:51: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       Local<Object> src = array->Get(i)->ToObject();                                                   ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
      ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Unmask(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/bufferutil.cc:67:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> buffer_obj = args[0]->ToObject();                                                  ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
      ../src/bufferutil.cc:69:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> mask_obj = args[1]->ToObject();                                                ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
      ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Mask(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/bufferutil.cc:88:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> buffer_obj = args[0]->ToObject();                                                  ^
      In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:89:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> mask_obj = args[1]->ToObject();                                                ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:91:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> output_obj = args[2]->ToObject();                                                  ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
      ../src/bufferutil.cc:92:51: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     unsigned int dataOffset = args[3]->Int32Value();                                                   ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here   V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);                                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/bufferutil.cc:93:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     unsigned int length = args[4]->Int32Value();                                               ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here   V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);                                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      bufferutil.target.mk:105: die Regel für Ziel „Release/obj.target/bufferutil/src/bufferutil.o“ scheiterte
      make: Verzeichnis „/opt/iobroker/node_modules/bufferutil/build“ wird verlassen
      make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Fehler 1
      gyp
       ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:193:23)gyp ERR!
      stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.4.59+gyp
       ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/bufferutilgyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3gyp
       ERR! not ok
      > utf-8-validate@1.1.0 install /opt/iobroker/node_modules/utf-8-validate> node-gyp rebuild
      make: Verzeichnis „/opt/iobroker/node_modules/utf-8-validate/build“ wird betreten
        CXX(target) Release/obj.target/validation/src/validation.o
      In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Integer; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local<v8::Integer> v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations] To<v8::Integer>(v8::Handle<v8::Integer> i) { return i->ToInteger(); }        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10052:16: note: declared here Local<Integer> Value::ToInteger() const {                ^~~~~
      In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’ To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note: candidate: v8::MaybeLocal<v8::Int32> v8::Value::ToInt32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Int32> ToInt32(Local<Context> context) const;                                           ^~~~~~~
      /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note: candidate: v8::Local<v8::Int32> v8::Value::ToInt32(v8::Isolate*) const                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note:   candidate expects 1 argument, 0 provided                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’ To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note: candidate: v8::MaybeLocal<v8::Uint32> v8::Value::ToUint32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Uint32> ToUint32(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note:   candidate expects 1 argument, 0 provided
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                      ^
      In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note: candidate: static v8::Local<v8::Value> v8::BooleanObject::New(v8::Isolate*, bool)   static Local<Value> New(Isolate* isolate, bool value);                       ^~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note:   candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                            ^../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                              ^
      In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5110:38: note: declared here                        Local<RegExp> New(Local<String> pattern, Flags flags));                                      ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 provided
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:173:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 provided
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:../node_modules/nan/nan_implementation_12_inl.h:206:42: error: no matching function for call to ‘v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*&, v8::String::NewStringType, int&)’         v8::String::kNormalString, length);                                          ^
      In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note: candidate: static v8::MaybeLocal<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::NewStringType, int)   static V8_WARN_UNUSED_RESULT MaybeLocal<String> NewFromOneByte(                                                   ^~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note:   no known conversion for argument 3 from ‘v8::String::NewStringType’ to ‘v8::NewStringType’In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:../node_modules/nan/nan_implementation_12_inl.h:217:66: error: no matching function for call to ‘v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*&)’   return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note: candidate: static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalOneByteStringResource*)       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note:   no known conversion for argument 2 from ‘v8::String::ExternalStringResource*’ to ‘v8::String::ExternalOneByteStringResource*’       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:237:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:244:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~
      In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘uint32_t NanUInt32OptionValue(v8::Local<v8::Object>, v8::Handle<v8::String>, uint32_t)’:../node_modules/nan/nan.h:248:43: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       ? optionsObj->Get(opt)->Uint32Value()                                           ^
      In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here   V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);                                               ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’ NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {                         ^~~~~~~~~~~~~~~../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {                         ^~~~~~~~~~~~~~~
      ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void       v8::Isolate::GCEpilogueCallback callback                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:473:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCEpilogueCallback callback       ^~../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’     , v8::GCType gc_type_filter = v8::kGCTypeAll) {                  ^~~~~~~~~~~~~~../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void       v8::Isolate::GCEpilogueCallback callback) {                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:479:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCEpilogueCallback callback) {       ^~../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void       v8::Isolate::GCPrologueCallback callback                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:484:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCPrologueCallback callback       ^~../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’     , v8::GCType gc_type_filter = v8::kGCTypeAll) {                  ^~~~~~~~~~~~~~../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void       v8::Isolate::GCPrologueCallback callback) {                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:490:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCPrologueCallback callback) {       ^~
      ../node_modules/nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {               ^~~~~~~~~~~~~~~~../node_modules/nan/nan.h:569:31: error: expected ‘,’ or ‘...’ before ‘<’ token     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {                               ^../node_modules/nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:../node_modules/nan/nan.h:570:42: error: ‘data’ was not declared in this scope       _NanWeakCallbackInfo<T, P> *info = data.GetParameter();                                          ^~~~
      ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared     , node::smalloc::FreeCallback callback             ^~~~~~~../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’     , node::smalloc::FreeCallback callback                                   ^~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                  ^~~~~~~~../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                            ^~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);        ^In file included from ../src/validation.cc:10:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_buffer.h:68:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’ NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,                                        ^~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:../node_modules/nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’     return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);            ^~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan.h:710:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:../node_modules/nan/nan.h:717:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::UnboundScript>)’:../node_modules/nan/nan.h:723:48: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->BindToCurrentContext()->Run();                                                ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::Script>)’:../node_modules/nan/nan.h:729:24: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->Run();                        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::Function>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, func, argc, argv));                                                            ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
      In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::String>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:747:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, symbol, argc, argv));                                                              ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:170:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, const char*, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, method, argc, argv));                                                              ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:163:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
      In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In member function ‘v8::Handle<v8::Value> NanCallback::Call_(v8::Isolate*, v8::Handle<v8::Object>, int, v8::Handle<v8::Value>*) const’:../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]     ));     ^../node_modules/nan/nan.h:398:59: note: in definition of macro ‘NanEscapeScope’ # define NanEscapeScope(val) scope.Escape(_NanEnsureLocal(val))                                                           ^~~In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
      In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘void* _NanRawString(v8::Handle<v8::Value>, Nan::Encoding, size_t*, void*, size_t, int)’:../node_modules/nan/nan.h:2164:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:2198:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In constructor ‘NanTap::NanTap(v8::Handle<v8::Value>)’:../node_modules/nan/nan.h:2292:41: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     NanAssignPersistent(t_, t->ToObject());                                         ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/validation.cc: In static member function ‘static void Validation::Initialize(v8::Handle<v8::Object>)’:../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [12], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "isValidUTF8", Validation::IsValidUTF8);                                                              ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~../src/validation.cc: In static member function ‘static void Validation::IsValidUTF8(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/validation.cc:132:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> buffer_obj = args[0]->ToObject();                                                  ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
      validation.target.mk:105: die Regel für Ziel „Release/obj.target/validation/src/validation.o“ scheitertemake: Verzeichnis „/opt/iobroker/node_modules/utf-8-validate/build“ wird verlassenmake: *** [Release/obj.target/validation/src/validation.o] Fehler 1gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:193:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp
      ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.4.59+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validategyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3gyp ERR! not ok
      > iobroker.xbox@0.5.12 install /opt/iobroker/node_modules/iobroker.xbox> npip install
      No python_modules directory; installing pip locally if needed.
      Successfully completed pip check.
      Collecting xbox-smartglass-rest>=0.9.8
        Using cached https://files.pythonhosted.org/packages/4d/4f/f035df8a2ec5742b9e772071e006ea21aae3fc3bd0963753cfc1045d6fda/xbox_smartglass_rest-0.9.8-py2.py3-none-any.whl
      Collecting xbox-smartglass-stump>=0.9.5
        Using cached https://files.pythonhosted.org/packages/34/f0/a75667f67ce6251b96a6989b8169eb9f2e25407ce2b0888e544b8caa98fe/xbox_smartglass_stump-0.9.5-py2.py3-none-any.whl
      Collecting xbox-smartglass-core>=1.0.12
        Using cached https://files.pythonhosted.org/packages/13/c8/2ffce1ddabe5b73422c7c46e808e4b02dbbc9362d2ecd2aee2a65e6e30a5/xbox_smartglass_core-1.0.12-py2.py3-none-any.whl
      Collecting xbox-webapi>=1.1.7
        Using cached https://files.pythonhosted.org/packages/2d/bf/aaf24cc78184393c5c2472e822c0e145b793e346a8085bee02e89a3428ba/xbox_webapi-1.1.7-py2.py3-none-any.whl
      Collecting Flask
        Using cached https://files.pythonhosted.org/packages/9b/93/628509b8d5dc749656a9641f4caf13540e2cdec85276964ff8f43bbb1d3b/Flask-1.1.1-py2.py3-none-any.whl
      Collecting marshmallow-objects
        Downloading https://files.pythonhosted.org/packages/8e/51/65733d6411bc2623922df2e0ac86c2620374620ddd62e108bb454e3412e2/marshmallow_objects-2.0.1-py2.py3-none-any.whl
      Processing /home/iobroker/.cache/pip/wheels/13/cd/02/acabe4bfa9899d53c3e3b13675610d2e2dcb9ae110359d4f61/construct-2.9.41-cp35-none-any.whl
      Collecting aenum==2.1.2; python_version <= "3.5"
        Using cached https://files.pythonhosted.org/packages/0d/46/5b6a6c13fee40f9dfaba84de1394bfe082c0c7d95952ba0ffbd56ce3a3f7/aenum-2.1.2-py3-none-any.whl
      Collecting cryptography==2.3.1
        Using cached https://files.pythonhosted.org/packages/59/32/92cade62c645756a83598edf56289e9b19aae5370642a7ce690cd06bc72f/cryptography-2.3.1-cp34-abi3-manylinux1_x86_64.whl
      Processing /home/iobroker/.cache/pip/wheels/0a/5f/3c/e0ffceb6554711f12a7101384f29ec13b85136dfcf1f692b8f/dpkt-1.9.1-cp35-none-any.whl
      Collecting appdirs==1.4.3
        Using cached https://files.pythonhosted.org/packages/56/eb/810e700ed1349edde4cbdc1b2a21e28cdf115f9faf263f6bbf8447c1abf3/appdirs-1.4.3-py2.py3-none-any.whl
      Processing /home/iobroker/.cache/pip/wheels/34/06/50/24011714e101b5ad8518c69175d117a257413e3c15a92983f0/urwid-2.0.1-cp35-none-any.whl
      Collecting gevent==1.3.7
        Using cached https://files.pythonhosted.org/packages/87/c4/9afb40b4a8b9186787d477aa6ebcfa17ead40ecbf83d5a1ed53dadd4f6ef/gevent-1.3.7-cp35-cp35m-manylinux1_x86_64.whl
      Collecting requests
        Using cached https://files.pythonhosted.org/packages/51/bd/23c926cd341ea6b7dd0b2a00aba99ae0f828be89d72b2190f27c11d4b7fb/requests-2.22.0-py2.py3-none-any.whl
      Processing /home/iobroker/.cache/pip/wheels/c5/d2/ab/a54fb5ea53ac3badba098160e8452fa126a51febda80440ded/demjson-2.2.4-cp35-none-any.whl
      Collecting click>=5.1
        Using cached https://files.pythonhosted.org/packages/fa/37/45185cb5abbc30d7257104c434fe0b07e5a195a6847506c074527aa599ec/Click-7.0-py2.py3-none-any.whl
      Collecting Werkzeug>=0.15
        Using cached https://files.pythonhosted.org/packages/ce/42/3aeda98f96e85fd26180534d36570e4d18108d62ae36f87694b476b83d6f/Werkzeug-0.16.0-py2.py3-none-any.whl
      Collecting itsdangerous>=0.24
        Using cached https://files.pythonhosted.org/packages/76/ae/44b03b253d6fade317f32c24d100b3b35c2239807046a4c953c7b89fa49e/itsdangerous-1.1.0-py2.py3-none-any.whl
      Collecting Jinja2>=2.10.1
        Using cached https://files.pythonhosted.org/packages/65/e0/eb35e762802015cab1ccee04e8a277b03f1d8e53da3ec3106882ec42558b/Jinja2-2.10.3-py2.py3-none-any.whl
      Collecting marshmallow>=3.0.0
        Using cached https://files.pythonhosted.org/packages/6e/76/01224f14737627166b94eb3bf0e334372c014edca781e39db320ce977755/marshmallow-3.3.0-py2.py3-none-any.whl
      Collecting cffi!=1.11.3,>=1.7
        Using cached https://files.pythonhosted.org/packages/a8/8d/986e0c4e2aa3b24db56a0affc50d1a379150e3c4da45d51d549dc2697d53/cffi-1.13.2-cp35-cp35m-manylinux1_x86_64.whl
      Collecting idna>=2.1
        Using cached https://files.pythonhosted.org/packages/14/2c/cd551d81dbe15200be1cf41cd03869a46fe7226e7450af7a6545bfc474c9/idna-2.8-py2.py3-none-any.whl
      Collecting six>=1.4.1
        Using cached https://files.pythonhosted.org/packages/65/eb/1f97cb97bfc2390a276969c6fae16075da282f5058082d4cb10c6c5c1dba/six-1.14.0-py2.py3-none-any.whl
      Collecting asn1crypto>=0.21.0
        Using cached https://files.pythonhosted.org/packages/e9/51/1db4a60049fb7390959be586b6eb743098e6cea3f6b2d3ed9e17fec62ba2/asn1crypto-1.3.0-py2.py3-none-any.whl
      Collecting greenlet>=0.4.14; platform_python_implementation == "CPython"
        Using cached https://files.pythonhosted.org/packages/2e/65/27f35497cc0102a792390d056e793e064da95fc9eae45d75ae0ba49c0a0d/greenlet-0.4.15-cp35-cp35m-manylinux1_x86_64.whl
      Collecting certifi>=2017.4.17
        Using cached https://files.pythonhosted.org/packages/b9/63/df50cac98ea0d5b006c55a399c3bf1db9da7b5a24de7890bc9cfd5dd9e99/certifi-2019.11.28-py2.py3-none-any.whl
      Collecting urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1
        Using cached https://files.pythonhosted.org/packages/b4/40/a9837291310ee1ccc242ceb6ebfd9eb21539649f193a7c8c86ba15b98539/urllib3-1.25.7-py2.py3-none-any.whl
      Collecting chardet<3.1.0,>=3.0.2
        Using cached https://files.pythonhosted.org/packages/bc/a9/01ffebfb562e4274b6487b4bb1ddec7ca55ec7510b22e4c51f14098443b8/chardet-3.0.4-py2.py3-none-any.whl
      Collecting MarkupSafe>=0.23
        Using cached https://files.pythonhosted.org/packages/6e/57/d40124076756c19ff2269678de7ae25a14ebbb3f6314eb5ce9477f191350/MarkupSafe-1.1.1-cp35-cp35m-manylinux1_x86_64.whl
      Processing /home/iobroker/.cache/pip/wheels/f2/9a/90/de94f8556265ddc9d9c8b271b0f63e57b26fb1d67a45564511/pycparser-2.19-py2.py3-none-any.whl
      Installing collected packages: construct, aenum, pycparser, cffi, idna, six, asn1crypto, cryptography, dpkt, appdirs, urwid, certifi, urllib3, chardet, requests, demjson, xbox-webapi, greenlet, gevent, xbox-smartglass-core, marshmallow, marshmallow-objects, xbox-smartglass-stump, click, Werkzeug, itsdangerous, MarkupSafe, Jinja2, Flask, xbox-smartglass-rest
      Successfully installed Flask-1.1.1 Jinja2-2.10.3 MarkupSafe-1.1.1 Werkzeug-0.16.0 aenum-2.1.2 appdirs-1.4.3 asn1crypto-1.3.0 certifi-2019.11.28 cffi-1.13.2 chardet-3.0.4 click-7.0 construct-2.9.41 cryptography-2.3.1 demjson-2.2.4 dpkt-1.9.1 gevent-1.3.7 greenlet-0.4.15 idna-2.8 itsdangerous-1.1.0 marshmallow-3.3.0 marshmallow-objects-2.0.1 pycparser-2.19 requests-2.22.0 six-1.14.0 urllib3-1.25.7 urwid-2.0.1 xbox-smartglass-core-1.0.12 xbox-smartglass-rest-0.9.8 xbox-smartglass-stump-0.9.5 xbox-webapi-1.1.7
      + iobroker.xbox@0.5.12updated 1 package in 72.846s
      upload [2] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/xbox.png xbox.png image/png
      upload [1] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/words.js words.js application/javascript
      upload [0] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/index_m.html index_m.html text/html
      Update "system.adapter.xbox.0"
      process exited with code 0
      Adapter ist grün 😁
      xbox.0	2020-01-18 21:21:59.327	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
      xbox.0	2020-01-18 21:21:59.317	debug	(5900) [CONNECT] Still connected
      xbox.0	2020-01-18 21:21:59.311	debug	(5900) [CONNECT] Check connection
      xbox.0	2020-01-18 21:21:59.310	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_status
      xbox.0	2020-01-18 21:21:59.303	debug	(5900) [UPDATE] Check console status
      xbox.0	2020-01-18 21:21:59.301	debug	(5900) [PING] Xbox online
      xbox.0	2020-01-18 21:21:53.320	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
      xbox.0	2020-01-18 21:21:53.314	debug	(5900) [CONNECT] Still connected
      xbox.0	2020-01-18 21:21:53.312	debug	(5900) [CONNECT] Check connection
      xbox.0	2020-01-18 21:21:53.309	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_status
      xbox.0	2020-01-18 21:21:53.304	debug	(5900) [UPDATE] Check console status
      xbox.0	2020-01-18 21:21:53.301	debug	(5900) [PING] Xbox online
      xbox.0	2020-01-18 21:21:52.035	debug	(5900) system.adapter.admin.0: logging true
      xbox.0	2020-01-18 21:21:47.317	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
      xbox.0	2020-01-18 21:21:47.311	debug	(5900) [CONNECT] Still connected
      xbox.0	2020-01-18 21:21:47.309	debug	(5900) [CONNECT] Check connection
      xbox.0	2020-01-18 21:21:47.308	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
      xbox.0	2020-01-18 21:21:47.303	debug	(5900) [UPDATE] Check console status
      xbox.0	2020-01-18 21:21:47.301	debug	(5900) [PING] Xbox online
      xbox.0	2020-01-18 21:21:41.325	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
      xbox.0	2020-01-18 21:21:41.319	debug	(5900) [CONNECT] Still connected
      xbox.0	2020-01-18 21:21:41.315	debug	(5900) [CONNECT] Check connection
      xbox.0	2020-01-18 21:21:41.315	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
      xbox.0	2020-01-18 21:21:41.307	debug	(5900) [UPDATE] Check console status
      xbox.0	2020-01-18 21:21:41.303	debug	(5900) [PING] Xbox online
      xbox.0	2020-01-18 21:21:35.324	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
      xbox.0	2020-01-18 21:21:35.316	debug	(5900) [CONNECT] Still connected
      xbox.0	2020-01-18 21:21:35.313	debug	(5900) [CONNECT] Check connection
      xbox.0	2020-01-18 21:21:35.312	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
      xbox.0	2020-01-18 21:21:35.304	debug	(5900) [UPDATE] Check console status
      xbox.0	2020-01-18 21:21:35.303	debug	(5900) [PING] Xbox online
      xbox.0	2020-01-18 21:21:29.331	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
      xbox.0	2020-01-18 21:21:29.321	debug	(5900) [CONNECT] Still connected
      xbox.0	2020-01-18 21:21:29.317	debug	(5900) [CONNECT] Check connection
      xbox.0	2020-01-18 21:21:29.316	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
      xbox.0	2020-01-18 21:21:29.305	debug	(5900) [UPDATE] Check console status
      xbox.0	2020-01-18 21:21:29.301	debug	(5900) [PING] Xbox online
      xbox.0	2020-01-18 21:21:23.356	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
      xbox.0	2020-01-18 21:21:23.351	debug	(5900) [CONNECT] Still connected
      xbox.0	2020-01-18 21:21:23.311	debug	(5900) [CONNECT] Check connection
      xbox.0	2020-01-18 21:21:23.310	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
      xbox.0	2020-01-18 21:21:23.303	debug	(5900) [UPDATE] Check console status
      xbox.0	2020-01-18 21:21:23.302	debug	(5900) [PING] Xbox online
      xbox.0	2020-01-18 21:21:17.318	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
      xbox.0	2020-01-18 21:21:17.308	debug	(5900) [CONNECT] Still connected
      xbox.0	2020-01-18 21:21:17.307	debug	(5900) [CONNECT] Check connection
      xbox.0	2020-01-18 21:21:17.306	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
      xbox.0	2020-01-18 21:21:17.301	debug	(5900) [UPDATE] Check console status
      xbox.0	2020-01-18 21:21:17.300	debug	(5900) [PING] Xbox online
      xbox.0	2020-01-18 21:21:11.355	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
      xbox.0	2020-01-18 21:21:11.348	debug	(5900) [CONNECT] Still connected
      xbox.0	2020-01-18 21:21:11.308	debug	(5900) [CONNECT] Check connection
      xbox.0	2020-01-18 21:21:11.307	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
      xbox.0	2020-01-18 21:21:11.300	debug	(5900) [UPDATE] Check console status
      xbox.0	2020-01-18 21:21:11.298	debug	(5900) [PING] Xbox online
      xbox.0	2020-01-18 21:21:05.314	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
      xbox.0	2020-01-18 21:21:05.308	debug	(5900) [CONNECT] Still connected
      xbox.0	2020-01-18 21:21:05.306	debug	(5900) [CONNECT] Check connection
      xbox.0	2020-01-18 21:21:05.306	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
      xbox.0	2020-01-18 21:21:05.300	debug	(5900) [UPDATE] Check console status
      xbox.0	2020-01-18 21:21:05.298	debug	(5900) [PING] Xbox online
      xbox.0	2020-01-18 21:21:02.349	debug	(5900) system.adapter.admin.0: logging false
      xbox.0	2020-01-18 21:20:59.323	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
      xbox.0	2020-01-18 21:20:59.317	debug	(5900) [CONNECT] Still connected
      xbox.0	2020-01-18 21:20:59.312	debug	(5900) [CONNECT] Check connection
      xbox.0	2020-01-18 21:20:59.312	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
      xbox.0	2020-01-18 21:20:59.304	debug	(5900) [UPDATE] Check console status
      xbox.0	2020-01-18 21:20:59.298	debug	(5900) [PING] Xbox online
      xbox.0	2020-01-18 21:20:54.449	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
      xbox.0	2020-01-18 21:20:53.312	debug	(5900) [CONNECT] Still connected
      xbox.0	2020-01-18 21:20:53.310	debug	(5900) [CONNECT] Check connection
      xbox.0	2020-01-18 21:20:53.310	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
      xbox.0	2020-01-18 21:20:53.302	debug	(5900) [UPDATE] Check console status
      xbox.0	2020-01-18 21:20:53.298	debug	(5900) [PING] Xbox online
      xbox.0	2020-01-18 21:20:50.423	info	(5900) [CONNECT] <=== Successfully connected to FD001101536384EE (10.0.1.83)
      xbox.0	2020-01-18 21:20:49.834	debug	(5900) [CONNECT] Check connection
      xbox.0	2020-01-18 21:20:49.833	debug	(5900) [DISCOVER] <=== {"FD001101536384EE":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Disconnected","console_users_allowed":fals
      xbox.0	2020-01-18 21:20:47.309	debug	(5900) [DISCOVER] Searching for consoles
      xbox.0	2020-01-18 21:20:47.305	debug	(5900) [PING] Xbox online
      xbox.0	2020-01-18 21:20:44.423	info	(5900) [LOGIN] <=== Successfully logged in as: Negalein2901
      xbox.0	2020-01-18 21:20:41.314	debug	(5900) [LOGOUT] <=== Successfully logged out
      xbox.0	2020-01-18 21:20:39.588	debug	(5900) system.adapter.admin.0: logging true
      xbox.0	2020-01-18 21:20:34.726	info	(5900) [START] Starting REST server
      xbox.0	2020-01-18 21:20:34.726	debug	(5900) [START] IP address is 10.0.1.83
      xbox.0	2020-01-18 21:20:34.699	info	(5900) starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.17.0
      xbox.0	2020-01-18 21:20:32.119	debug	(5900) States connected to redis: 0.0.0.0:9000
      xbox.0	2020-01-18 21:20:32.067	debug	(5900) statesDB connected
      xbox.0	2020-01-18 21:20:32.065	debug	(5900) States create PubSub Client
      xbox.0	2020-01-18 21:20:32.056	debug	(5900) Objects connected to redis: 0.0.0.0:9001
      xbox.0	2020-01-18 21:20:32.053	debug	(5900) Redis States: Use Redis connection: 0.0.0.0:9000
      xbox.0	2020-01-18 21:20:32.051	debug	(5900) objectDB connected
      xbox.0	2020-01-18 21:20:32.040	debug	(5900) Objects client initialize lua scripts
      xbox.0	2020-01-18 21:20:32.039	debug	(5900) Objects create PubSub Client
      xbox.0	2020-01-18 21:20:32.028	debug	(5900) Objects client ready ... initialize now
      xbox.0	2020-01-18 21:20:31.994	debug	(5900) Redis Objects: Use Redis connection: 0.0.0.0:9001
      DANKE
      • foxriver76
        foxriver76 Developer @Negalein last edited by
        @Negalein perfekt. Gerne.
        • Negalein
          @foxriver76
          Ich wollte heute auf 0.6.0 updaten.
          Bekomme aber einen Error 25
          $ ./iobroker upgrade xbox
          Update xbox from @0.5.12 to @0.6.0
          NPM version: 6.11.3
          npm install iobroker.xbox@0.6.0 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
          In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Integer; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local<v8::Integer> v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations] To<v8::Integer>(v8::Handle<v8::Integer> i) { return i->ToInteger(); }        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10052:16: note: declared here Local<Integer> Value::ToInteger() const {                ^~~~~
          In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’ To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note: candidate: v8::MaybeLocal<v8::Int32> v8::Value::ToInt32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Int32> ToInt32(Local<Context> context) const;                                           ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note: candidate: v8::Local<v8::Int32> v8::Value::ToInt32(v8::Isolate*) const                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note:   candidate expects 1 argument, 0 provided                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
          In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’ To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note: candidate: v8::MaybeLocal<v8::Uint32> v8::Value::ToUint32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Uint32> ToUint32(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note:   candidate expects 1 argument, 0 provided
          In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                      ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note: candidate: static v8::Local<v8::Value> v8::BooleanObject::New(v8::Isolate*, bool)   static Local<Value> New(Isolate* isolate, bool value);                       ^~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note:   candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                            ^../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                              ^
          ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::RegExp>::return_t NanIntern::Factory<v8::RegExp>::New(v8::Handle<v8::String>, v8::RegExp::Flags)’:../node_modules/nan/nan_implementation_12_inl.h:158:40: warning: ‘static v8::Local<v8::RegExp> v8::RegExp::New(v8::Local<v8::String>, v8::RegExp::Flags)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   return v8::RegExp::New(pattern, flags);                                        ^
          In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5110:38: note: declared here                        Local<RegExp> New(Local<String> pattern, Flags flags));                                      ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
          In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:173:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 provided
          In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:../node_modules/nan/nan_implementation_12_inl.h:206:42: error: no matching function for call to ‘v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*&, v8::String::NewStringType, int&)’         v8::String::kNormalString, length);                                          ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note: candidate: static v8::MaybeLocal<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::NewStringType, int)   static V8_WARN_UNUSED_RESULT MaybeLocal<String> NewFromOneByte(                                                   ^~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note:   no known conversion for argument 3 from ‘v8::String::NewStringType’ to ‘v8::NewStringType’In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:../node_modules/nan/nan_implementation_12_inl.h:217:66: error: no matching function for call to ‘v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*&)’   return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note: candidate: static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalOneByteStringResource*)       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note:   no known conversion for argument 2 from ‘v8::String::ExternalStringResource*’ to ‘v8::String::ExternalOneByteStringResource*’       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~
          In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:237:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:244:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~
          In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘uint32_t NanUInt32OptionValue(v8::Local<v8::Object>, v8::Handle<v8::String>, uint32_t)’:../node_modules/nan/nan.h:248:43: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       ? optionsObj->Get(opt)->Uint32Value()                                           ^
          In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here   V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);                                               ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’ NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {                         ^~~~~~~~~~~~~~~../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {                         ^~~~~~~~~~~~~~~
          ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:../node_modules/nan/nan.h:289:39: error: ‘class v8::Isolate’ has no member named ‘IdleNotification’; did you mean ‘IdleNotificationDeadline’?     return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);                                       ^~~~~~~~~~~~~~~~
          ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared     , node::smalloc::FreeCallback callback             ^~~~~~~../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’     , node::smalloc::FreeCallback callback                                   ^~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                  ^~~~~~~~../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                            ^~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);        ^In file included from ../src/bufferutil.cc:10:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_buffer.h:68:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’ NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,                                        ^~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
          ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan.h:710:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:../node_modules/nan/nan.h:717:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 provided
          In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::UnboundScript>)’:../node_modules/nan/nan.h:723:48: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->BindToCurrentContext()->Run();                                                ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::Script>)’:../node_modules/nan/nan.h:729:24: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->Run();                        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::Function>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, func, argc, argv));                                                            ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
          In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::String>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:747:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, symbol, argc, argv));                                                              ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:170:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, const char*, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, method, argc, argv));                                                              ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:163:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
          In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In member function ‘v8::Handle<v8::Value> NanCallback::Call_(v8::Isolate*, v8::Handle<v8::Object>, int, v8::Handle<v8::Value>*) const’:../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]     ));     ^../node_modules/nan/nan.h:398:59: note: in definition of macro ‘NanEscapeScope’ # define NanEscapeScope(val) scope.Escape(_NanEnsureLocal(val))                                                           ^~~
          In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘void* _NanRawString(v8::Handle<v8::Value>, Nan::Encoding, size_t*, void*, size_t, int)’:../node_modules/nan/nan.h:2164:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
          In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:2198:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
          In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In constructor ‘NanTap::NanTap(v8::Handle<v8::Value>)’:../node_modules/nan/nan.h:2292:41: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     NanAssignPersistent(t_, t->ToObject());                                         ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
          ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(v8::Handle<v8::Object>)’:../src/bufferutil.cc:30:52: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [7], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "unmask", BufferUtil::Unmask);                                                    ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~../src/bufferutil.cc:31:48: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [5], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "mask", BufferUtil::Mask);                                                ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~../src/bufferutil.cc:32:50: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [6], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "merge", BufferUtil::Merge);                                                  ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~
          ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Merge(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/bufferutil.cc:49:49: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> bufferObj = args[0]->ToObject();                                                 ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
          ../src/bufferutil.cc:56:51: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       Local<Object> src = array->Get(i)->ToObject();                                                   ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc: In static member function ‘static void BufferUtil::Unmask(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/bufferutil.cc:67:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> buffer_obj = args[0]->ToObject();                                                  ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:69:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> mask_obj = args[1]->ToObject();                                                ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc: In static member function ‘static void BufferUtil::Mask(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/bufferutil.cc:88:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> buffer_obj = args[0]->ToObject();                                                  ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:89:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> mask_obj = args[1]->ToObject();                                                ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:91:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> output_obj = args[2]->ToObject();                                                  ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:92:51: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     unsigned int dataOffset = args[3]->Int32Value();                                                   ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here   V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);                                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/bufferutil.cc:93:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     unsigned int length = args[4]->Int32Value();                                               ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here   V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);                                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
          make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Fehler 1gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:193:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.4.59+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/bufferutilgyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3gyp ERR! not ok
          In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Integer; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local<v8::Integer> v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations] To<v8::Integer>(v8::Handle<v8::Integer> i) { return i->ToInteger(); }        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10052:16: note: declared here Local<Integer> Value::ToInteger() const {                ^~~~~
          In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’ To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note: candidate: v8::MaybeLocal<v8::Int32> v8::Value::ToInt32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Int32> ToInt32(Local<Context> context) const;                                           ^~~~~~~
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note: candidate: v8::Local<v8::Int32> v8::Value::ToInt32(v8::Isolate*) const                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note:   candidate expects 1 argument, 0 provided                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’ To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note: candidate: v8::MaybeLocal<v8::Uint32> v8::Value::ToUint32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Uint32> ToUint32(                                            ^~~~~~~~
          In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                      ^
          In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note: candidate: static v8::Local<v8::Value> v8::BooleanObject::New(v8::Isolate*, bool)   static Local<Value> New(Isolate* isolate, bool value);                       ^~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note:   candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                            ^../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                              ^
          In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5110:38: note: declared here                        Local<RegExp> New(Local<String> pattern, Flags flags));                                      ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
          In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:173:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 provided
          In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:../node_modules/nan/nan_implementation_12_inl.h:206:42: error: no matching function for call to ‘v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*&, v8::String::NewStringType, int&)’         v8::String::kNormalString, length);                                          ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note: candidate: static v8::MaybeLocal<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::NewStringType, int)   static V8_WARN_UNUSED_RESULT MaybeLocal<String> NewFromOneByte(                                                   ^~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note:   no known conversion for argument 3 from ‘v8::String::NewStringType’ to ‘v8::NewStringType’
          In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:../node_modules/nan/nan_implementation_12_inl.h:217:66: error: no matching function for call to ‘v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*&)’   return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note: candidate: static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalOneByteStringResource*)       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note:   no known conversion for argument 2 from ‘v8::String::ExternalStringResource*’ to ‘v8::String::ExternalOneByteStringResource*’       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:237:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:244:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~
          In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘uint32_t NanUInt32OptionValue(v8::Local<v8::Object>, v8::Handle<v8::String>, uint32_t)’:../node_modules/nan/nan.h:248:43: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       ? optionsObj->Get(opt)->Uint32Value()                                           ^
          In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here   V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);                                               ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’ NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {                         ^~~~~~~~~~~~~~~../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {                         ^~~~~~~~~~~~~~~
          ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void       v8::Isolate::GCEpilogueCallback callback                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:473:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCEpilogueCallback callback       ^~../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’     , v8::GCType gc_type_filter = v8::kGCTypeAll) {                  ^~~~~~~~~~~~~~../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void       v8::Isolate::GCEpilogueCallback callback) {                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:479:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCEpilogueCallback callback) {       ^~../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void       v8::Isolate::GCPrologueCallback callback                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:484:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCPrologueCallback callback       ^~../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’     , v8::GCType gc_type_filter = v8::kGCTypeAll) {                  ^~~~~~~~~~~~~~../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void       v8::Isolate::GCPrologueCallback callback) {                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:490:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCPrologueCallback callback) {       ^~../node_modules/nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {               ^~~~~~~~~~~~~~~~../node_modules/nan/nan.h:569:31: error: expected ‘,’ or ‘...’ before ‘<’ token     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {                               ^../node_modules/nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:../node_modules/nan/nan.h:570:42: error: ‘data’ was not declared in this scope       _NanWeakCallbackInfo<T, P> *info = data.GetParameter();                                          ^~~~
          ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared     , node::smalloc::FreeCallback callback             ^~~~~~~../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’     , node::smalloc::FreeCallback callback                                   ^~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                  ^~~~~~~~../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                            ^~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);        ^In file included from ../src/validation.cc:10:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_buffer.h:68:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’ NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,                                        ^~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:../node_modules/nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’     return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);            ^~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan.h:710:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:../node_modules/nan/nan.h:717:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 provided
          In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::UnboundScript>)’:../node_modules/nan/nan.h:723:48: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->BindToCurrentContext()->Run();                                                ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::Script>)’:../node_modules/nan/nan.h:729:24: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->Run();                        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::Function>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, func, argc, argv));                                                            ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
          In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::String>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:747:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, symbol, argc, argv));                                                              ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:170:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, const char*, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, method, argc, argv));                                                              ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:163:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
          In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In member function ‘v8::Handle<v8::Value> NanCallback::Call_(v8::Isolate*, v8::Handle<v8::Object>, int, v8::Handle<v8::Value>*) const’:../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]     ));     ^../node_modules/nan/nan.h:398:59: note: in definition of macro ‘NanEscapeScope’ # define NanEscapeScope(val) scope.Escape(_NanEnsureLocal(val))                                                           ^~~In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
          In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘void* _NanRawString(v8::Handle<v8::Value>, Nan::Encoding, size_t*, void*, size_t, int)’:../node_modules/nan/nan.h:2164:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
          In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:2198:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
          In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In constructor ‘NanTap::NanTap(v8::Handle<v8::Value>)’:../node_modules/nan/nan.h:2292:41: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     NanAssignPersistent(t_, t->ToObject());                                         ^
          In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
          ../src/validation.cc: In static member function ‘static void Validation::Initialize(v8::Handle<v8::Object>)’:../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [12], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "isValidUTF8", Validation::IsValidUTF8);                                                              ^
          In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~
          ../src/validation.cc: In static member function ‘static void Validation::IsValidUTF8(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/validation.cc:132:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> buffer_obj = args[0]->ToObject();                                                  ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
          make: *** [Release/obj.target/validation/src/validation.o] Fehler 1
          gyp
           ERR! build error
          gyp ERR! System Linux 4.4.59+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validategyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3gyp
           ERR! not ok
          ERROR: Could not find a version that satisfies the requirement xbox-smartglass-core>=1.1.2 (from versions: 1.0.2, 1.0.3, 1.0.6, 1.0.7, 1.0.8, 1.0.9, 1.0.10, 1.0.11, 1.0.12, 1.1.0, 1.1.1)ERROR: No matching distribution found for xbox-smartglass-core>=1.1.2
          npm ERR! code ELIFECYCLEnpm ERR! errno 1
          npm ERR! iobroker.xbox@0.6.0 install: `npip install`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the iobroker.xbox@0.6.0 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-03-02T13_00_25_297Z-debug.log
          ERROR: host.iobroker Cannot install iobroker.xbox@0.6.0: 1
          ERROR: process exited with code 25
          Das komische danach war, dass der Adapter nicht mehr als installiert angezeigt wurde.
          Unter Instanzen war er aber da.
          Erst als ich wieder 0.5.12 instaliert habe, schien er wieder als installierter Adapter auf.
          • foxriver76
            foxriver76 Developer @Negalein last edited by
            @Negalein 0.6.0 benötigt mindestens Python 3.6, da die Xbox Kollegen den Support für 3.5 raus genommen haben. Musst allerdings nicht upgraden, war eher so für die Zukunftssicherheit, da sie das Modul umgezogen haben. Ansonsten müsstest du mal schauen, wie Python installiert ist bei dir. Evtl via apt.
            • Negalein
              Negalein Global Moderator @foxriver76 last edited by
              @foxriver76 sagte in XBox-Adapter Fehler:
              wie finde ich das raus?
              Hab ioBroker auf einer Synology.
              Oder reicht es, direkt auf der Syno Python zu installieren?
              • foxriver76
                @Negalein was gibt sudo apt update | grep python denn bei dir aus?
                • Negalein
                  root@iobroker:/opt/iobroker# sudo apt update | grep python
                  WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                  • foxriver76
                    @Negalein sudo apt upgrade python3.6 und danach ein neues Terminalfenster öffnen und mal python --version && python3 -version
                    • Negalein
                      root@iobroker:/opt/iobroker# sudo apt upgrade python3.6
                      E: Paket python3.6 kann nicht gefunden werden.
                      E: Mittels des Musters »python3.6« konnte kein Paket gefunden werden.
                      E: Mittels regulärem Ausdruck »python3.6« konnte kein Paket gefunden werden.
                      • foxriver76
                        foxriver76 Developer @Negalein last edited by foxriver76
                        @Negalein Ups, sorry meinte sudo apt install python3.6
                        • Negalein
                          findet das Paket nicht
                          root@iobroker:/opt/iobroker# sudo apt install python3.6
                          Aber egal, lassen wir es derweil bei der bestehenden Version.
                          Sonst hat sich eh nichts geändert.
                          • foxriver76
                            @Negalein ist vernünftig. KP was für ein OS genau auf der Synology läuft.
                            • Spegeli
                              Spegeli last edited by Spegeli
                              Also ich erhalte ebenfalls die Meldung:
                              spegeli@ioBrokerVM:~$ sudo apt install python3.6
                              und Version 6.0 des Adapters lässt sich nicht Installieren.
                              Aktuell ist Phyton 3.5.3 bei mir Installiert und er sagt mir auch das das wohl die aktuellste Version ist? Nutze Debian.
                              • foxriver76
                                Dann muss das entsprechende Repo hinzugefügt werden und am Ende muss noch python3 auf 3.6 gelinkt werden. Auf was läuft denn deine Installation?
                                Spegeli 1 Reply Last reply Reply Quote 0
                                • Spegeli
                                  Spegeli @foxriver76 last edited by Spegeli
                                  Läuft auf Debian 9.
                                  Versuche es jetzt mal über die direkte Source Installation: https://www.rosehosting.com/blog/how-to-install-python-3-6-4-on-debian-9/
                                  Die Installation von Python 3.6 direkt über die Source oder das Test System hat nicht Funktioniert, hat mir jedes mal was zerschossen.
                                  Hab jetzt einfach nen komplett Upgrade von Debian 9 auf 10 gemacht und wie ich anschließend gesehen hab, hat dieses Upgrade Automatisch Python 3.7 mit gebracht. Somit hat sich das Problem für mich erledigt 😉
                                    hajuerue last edited by
                                    Hallo XBox-Adapter User,
                                    habe seit dem Umstieg auf js.controller 3.1.6 Node 12 und einem Ubuntu drunter,
                                    Probleme beim einrichten des Adapter. Er wirft immer Fehler beim aktivieren. (siehe Anhang)
                                    Kann es sein das Python 3.8 zu neu ist für den Adapter?
                                      Thomas Braun Most Active @hajuerue last edited by Thomas Braun
                                      @hajuerue
                                      127.0.0.1 ist ja der iobroker-Server selber. Ich denke da sollte die IP von der Xbox rein.
                                      Und log files bitte nicht als screenshots sondern als Text in CodeTags.
                                        hajuerue @Thomas Braun last edited by
                                        @Thomas-Braun
                                        Hallo Thomas, Danke für die Rückmeldung.
                                        Die 127.0.0.1 kann ich als User nicht beeinflussen 😉
                                        Denn dass ist doch der "REST-Server" auf dem IoBroker, den der Adapter installiert, oder?
                                        Anbei meine Konfig im Adapter selbst.
                                        Wie sieht denn da eure Konfig aus?
                                        Gruss
                                        Hansi
                                          hajuerue @hajuerue last edited by
                                          Hallo an alle,
                                          es waren 2 Punkte beteiligt.
                                          Zum einen wurde das Python 2.7 statt das 3.8 default benutzt.
                                          Zum anderen hat Python ein anderes locale erwartet, als eingestellt war.
                                          C.UTF-8 -> de_DE.utf8
                                          Diejenigen von euch die auch "Ubuntu 20.04 live Server" frisch installiert haben,
                                          könnten hier die gleichen Probleme bekommen.
                                          Gruss
                                          HaJueRue
                                            Schnutexxl last edited by
                                            Hallo Zusammen,
                                            ich habe mich gefreut das es zu dieser Thematik bereits ein ausführlichen Fred gibt, da ich das "selbe" Problem habe.
                                            Aber leider kann ich mein Problem mit den hier geschriebenen Möglichkeiten nicht fixen. Bei mir kommt weiterhin:
                                            host.iobroker-docker	2020-12-23 16:52:41.900	info	instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
                                            xbox.0	2020-12-23 16:52:41.331	info	(18742) Terminated (NO_ERROR): Without reason
                                            xbox.0	2020-12-23 16:52:41.329	info	(18742) terminating
                                            xbox.0	2020-12-23 16:52:41.285	info	(18742) [END] cleaned everything up...
                                            xbox.0	2020-12-23 16:52:41.261	info	(18742) [END] Could not stop REST server:
                                            xbox.0	2020-12-23 16:52:41.227	warn	(18742) Restart initiated
                                            xbox.0	2020-12-23 16:52:41.226	error	(18742) [START] Restarting adapter
                                            xbox.0	2020-12-23 16:52:41.225	error	(18742) [START] Failed starting REST server: Process exited with code 1: Traceback (most recent call last): File "/opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server"
                                            xbox.0	2020-12-23 16:52:39.584	info	(18742) [START] Starting REST server
                                            xbox.0	2020-12-23 16:52:39.542	info	(18742) starting. Version 0.7.2 in /opt/iobroker/node_modules/iobroker.xbox, node: v12.20.0, js-controller: 3.1.6
                                            host.iobroker-docker	2020-12-23 16:52:36.404	info	instance system.adapter.xbox.0 started with pid 18742
                                            Meine Umgebung:
                                            Node.js v12.20.0
                                            NPM 6.14.8
                                            xbox Adapter 0.7.2
                                            buanet docker latest
                                            Kann mir hier jemand helfen den Adapter zum laufen zu bekommen, ich habe nun schon vergebliche Stunden investiert.
                                            Danke und schöne Grüße
                                            xbox
                                            7246
