    4. [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen
    • Chaot
      Chaot @Dutchman last edited by
      @Dutchman
      Ich habe den Adapter gestern abgeschaltet weil ich nicht das ganze log voll haben wollte.
      Aktuell sieht es nach dem Start so aus:
      wled.0	2020-03-02 21:59:49.421	error	(9307) Read Data error : TypeError: Cannot read property 'info' of null
      wled.0	2020-03-02 21:59:18.699	error	(9307) Read Data error : TypeError: Cannot read property 'info' of null
      wled.0	2020-03-02 21:58:26.858	error	(9307) Read Data error : TypeError: Cannot read property 'info' of undefined
      wled.0	2020-03-02 21:58:12.896	error	(9307) Read Data error : TypeError: Cannot read property 'info' of undefined
      wled.0	2020-03-02 21:57:44.763	info	(9307) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e","192.168.8.186":"3c71bf29273b","192.168.8.185":"cc50e304f753","192.168.8.188":"246f28b4865c"}
      wled.0	2020-03-02 21:57:44.763	info	(9307) Device wled-b4865c found on IP 192.168.8.188
      wled.0	2020-03-02 21:57:44.676	error	(9307) Read Data error : TypeError: Cannot read property 'info' of null
      wled.0	2020-03-02 21:57:44.670	error	(9307) Read Data error : TypeError: Cannot read property 'info' of null
      wled.0	2020-03-02 21:57:44.634	info	(9307) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e","192.168.8.186":"3c71bf29273b","192.168.8.185":"cc50e304f753"}
      wled.0	2020-03-02 21:57:44.633	info	(9307) Device wled-04f753 found on IP 192.168.8.185
      wled.0	2020-03-02 21:57:44.629	info	(9307) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e","192.168.8.186":"3c71bf29273b"}
      wled.0	2020-03-02 21:57:44.628	info	(9307) Device wled-29273b found on IP 192.168.8.186
      wled.0	2020-03-02 21:57:44.606	info	(9307) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e"}
      wled.0	2020-03-02 21:57:44.605	info	(9307) Device wled-ea1b7e found on IP 192.168.8.189
      wled.0	2020-03-02 21:57:44.554	warn	(9307) State attribute definition missing for + Connection
      wled.0	2020-03-02 21:57:44.517	info	(9307) starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.wled, node: v10.19.0
      Adapter ist gün und alle aktiven Controler sind vorhanden.
        liv-in-sky @Chaot last edited by
        @Chaot bin mir nicht mehr sicher- aber ich glaube ich habe die 0.9.0 version geflsht, weil die 0.9.1 nicht lief - irgendetwas war da
        • Chaot
          Chaot @liv-in-sky last edited by
          @liv-in-sky @Dutchman
          Ich denke mal das das mit der 0.9.1 zusammenhängt.
          Hier mal ein Auszug aus dem Debug:
          wled.0	2020-03-02 22:57:19.856	debug	(14947) Create_state called for : info.connection with value : true
          wled.0	2020-03-02 22:57:19.849	error	(14947) Read Data error : TypeError: Cannot read property 'info' of null
          wled.0	2020-03-02 22:57:19.843	debug	(14947) "API response data : null"
          wled.0	2020-03-02 22:57:19.840	debug	(14947) Datatype : boolean
          wled.0	2020-03-02 22:57:19.839	debug	(14947) Write value : false
          wled.0	2020-03-02 22:57:19.839	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.seglock with value : false
          wled.0	2020-03-02 22:57:19.839	debug	(14947) State created : seglock : false
          wled.0	2020-03-02 22:57:19.838	debug	(14947) Write value : false
          wled.0	2020-03-02 22:57:19.838	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.maxseg with value : 10
          wled.0	2020-03-02 22:57:19.837	debug	(14947) State created : maxseg : 10
          wled.0	2020-03-02 22:57:19.837	debug	(14947) Write value : false
          wled.0	2020-03-02 22:57:19.836	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.maxpwr with value : 850
          wled.0	2020-03-02 22:57:19.836	debug	(14947) State created : maxpwr : 850
          wled.0	2020-03-02 22:57:19.835	debug	(14947) Write value : false
          wled.0	2020-03-02 22:57:19.835	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.pwr with value : 140
          wled.0	2020-03-02 22:57:19.834	debug	(14947) State created : pwr : 140
          wled.0	2020-03-02 22:57:19.834	debug	(14947) Write value : false
          wled.0	2020-03-02 22:57:19.833	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.pin with value : 2
          wled.0	2020-03-02 22:57:19.833	debug	(14947) State created : pin : [2]
          wled.0	2020-03-02 22:57:19.832	debug	(14947) Write value : false
          wled.0	2020-03-02 22:57:19.832	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.wv with value : false
          wled.0	2020-03-02 22:57:19.831	debug	(14947) State created : wv : false
          wled.0	2020-03-02 22:57:19.830	debug	(14947) Write value : false
          wled.0	2020-03-02 22:57:19.830	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.rgbw with value : false
          wled.0	2020-03-02 22:57:19.830	debug	(14947) State created : rgbw : false
          wled.0	2020-03-02 22:57:19.828	debug	(14947) Write value : false
          wled.0	2020-03-02 22:57:19.828	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.count with value : 40
          wled.0	2020-03-02 22:57:19.827	debug	(14947) State created : count : 40
          wled.0	2020-03-02 22:57:19.824	debug	(14947) Data received from WLED device 3c71bf29273b : {"state":{"on":true,"bri":38,"transition":7,"ps":-1,"pss":0,"pl":-1,"ccnf":{"min":1,"max":5,"time":12},"nl":{"on":false,"dur":60,"fade":true,"tbri
          wled.0	2020-03-02 22:57:19.823	debug	(14947) "API response data : [object Object]"
          wled.0	2020-03-02 22:57:19.821	debug	(14947) Datatype : object
          wled.0	2020-03-02 22:57:19.820	debug	(14947) Write value : false
          wled.0	2020-03-02 22:57:19.820	debug	(14947) Create_state called for : 68c63aea1b7e._info.vid with value : 2002222
          wled.0	2020-03-02 22:57:19.819	debug	(14947) State created : vid : 2002222
          wled.0	2020-03-02 22:57:19.816	debug	(14947) Datatype : number
          wled.0	2020-03-02 22:57:19.815	debug	(14947) Write value : false
          wled.0	2020-03-02 22:57:19.815	debug	(14947) Create_state called for : 68c63aea1b7e._info.ver with value : 0.9.1
          wled.0	2020-03-02 22:57:19.815	debug	(14947) State created : ver : "0.9.1"
          wled.0	2020-03-02 22:57:19.811	debug	(14947) Datatype : string
          wled.0	2020-03-02 22:57:19.808	debug	(14947) Write value : true
          wled.0	2020-03-02 22:57:19.807	debug	(14947) Create_state called for : 68c63aea1b7e._info._online with value : true
          wled.0	2020-03-02 22:57:19.803	error	(14947) Read Data error : TypeError: Cannot read property 'info' of null
          wled.0	2020-03-02 22:57:19.802	debug	(14947) "API response data : null"
          wled.0	2020-03-02 22:57:19.801	error	(14947) Read Data error : TypeError: Cannot read property 'info' of null
          wled.0	2020-03-02 22:57:19.800	debug	(14947) "API response data : null"
          wled.0	2020-03-02 22:57:19.798	debug	(14947) Write value : true
          wled.0	2020-03-02 22:57:19.797	debug	(14947) Create_state called for : info.connection with value : true
          wled.0	2020-03-02 22:57:19.788	debug	(14947) Data received from WLED device 68c63aea1b7e : {"state":{"on":true,"bri":86,"transition":7,"ps":-1,"pss":1023,"pl":-1,"ccnf":{"min":1,"max":5,"time":12},"nl":{"on":false,"dur":60,"fade":true,"t
          wled.0	2020-03-02 22:57:19.787	debug	(14947) "API response data : [object Object]"
          wled.0	2020-03-02 22:57:19.750	debug	(14947) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e","192.168.8.186":"3c71bf29273b","192.168.8.185":"cc50e304f753"}
          wled.0	2020-03-02 22:57:19.750	debug	(14947) Getting data for cc50e304f753
          wled.0	2020-03-02 22:57:19.750	debug	(14947) Getting data for 3c71bf29273b
          wled.0	2020-03-02 22:57:19.749	debug	(14947) Getting data for 68c63aea1b7e
          wled.0	2020-03-02 22:57:19.749	debug	(14947) polling timer for devices : {"192.168.8.189":"68c63aea1b7e","192.168.8.186":"3c71bf29273b","192.168.8.185":"cc50e304f753"}
          • Dutchman
            Dutchman Developer Most Active Administrators @bishop last edited by
            @bishop sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
            wonach sucht er Automatisch, fehlt eine Einstellung in der WLed Gui?
            er such nach dem DNS bonjour service, sicher das du dir richtige Firmware version drauf hast von WLED ?
            • Dutchman
              Dutchman Developer Most Active Administrators @Chaot last edited by
              @Chaot sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
              hmm danke, ich schau es mir nachher mal an die version ist 9 Tage alt viellicht hat Aircookie da doch was geändert.
                bigd-73 @Dutchman last edited by
                @Dutchman Version 0.9.1 läuft bei mir problemlos mit deiner aktuellen Adapterversion
                SG
                Mario
                • Dutchman
                  Dutchman Developer Most Active Administrators @bigd-73 last edited by
                  @bigd-73 sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                  welche 0.9.1, rc1 .... rc2 oder. die vor 9 Tagen released wurde ?
                  B Chaot 2 Replies Last reply Reply Quote 0
                    bigd-73 @Dutchman last edited by bigd-73
                    @Dutchman ok, da gibts verschiedene ... diese hier: https://github.com/Aircoookie/WLED/releases
                    Also die vor 10 Tagen wie ich gerade sehe.
                    • Chaot
                      Chaot @Dutchman last edited by Chaot
                      @Dutchman Oh, dann nutze ich vermutlich zwei verschieden Versionen der 0.9.1.
                      Die Deckenlichter habe ich gleich am Erscheinungstag geflasht und den letzten Streifen erst gestern.
                      Ich kann aber mal versuchen den neuen Streifen mit der anderen Version zu flashen um zu schauen ob das was ändert.
                      Edit:
                      Der Fehler ist noch da:
                      wled.0	2020-03-03 19:58:13.891	error	(738) Read Data error : TypeError: Cannot read property 'info' of undefined
                      wled.0	2020-03-03 19:55:52.158	error	(738) Read Data error : TypeError: Cannot read property 'info' of null
                      wled.0	2020-03-03 19:55:52.139	error	(738) Read Data error : TypeError: Cannot read property 'info' of null
                      wled.0	2020-03-03 19:55:51.995	warn	(738) State attribute definition missing for + Connection
                      host.ioBroker	2020-03-03 19:55:50.435	info	instance system.adapter.wled.0 started with pid 738
                        @Dutchman also bei mir funktioniert nur die "WLED_0.9.0-b1_ESP8266.bin"
                        die 0.9.1 wird nicht erkannt von dem Adapter!
                          e-s @bishop last edited by
                          @bishop @Chaot
                          hatte damals mit der 0.9.0-b1 angefangen und vor 2 Tagen per OTA auf 0.9.1, hatte bisher keine Fehlermeldungen. Läuft alles so wie es soll.
                            kann ich bestätigen nach update von 0.9.0 auf 0.9.1 funktioniert es bei mir auch.
                            Direkt mit 0.9.1 ging es nicht!
                            • Dutchman
                              danke wichtige info für die analyse.
                              • Chaot
                                @Dutchman
                                Ich bin jetzt mit dem neuen Streifen auf 0.9.0 runter.
                                wled.0	2020-03-03 21:29:30.457	error	(26393) Read Data error : TypeError: Cannot read property 'info' of undefined
                                wled.0	2020-03-03 21:29:22.941	error	(26393) Read Data error : TypeError: Cannot read property 'info' of undefined
                                wled.0	2020-03-03 21:29:15.078	error	(26393) Read Data error : TypeError: Cannot read property 'info' of undefined
                                wled.0	2020-03-03 21:28:59.618	error	(26393) Read Data error : TypeError: Cannot read property 'info' of undefined
                                wled.0	2020-03-03 21:28:13.806	error	(26393) Read Data error : TypeError: Cannot read property 'info' of undefined
                                wled.0	2020-03-03 21:26:36.651	error	(26393) Read Data error : TypeError: Cannot read property 'info' of null
                                wled.0	2020-03-03 21:26:36.643	error	(26393) Read Data error : TypeError: Cannot read property 'info' of null
                                wled.0	2020-03-03 21:26:36.426	warn	(26393) State attribute definition missing for + Connection
                                host.ioBroker	2020-03-03 21:26:35.035	info	instance system.adapter.wled.0 started with pid 26393
                                21:26 Adapterstart
                                21:28 auf WLED Instanz Schraubenschlüssel (ohne Veränderungen)
                                21:29 In Objekte den Datenpunkt "wled.0.cc50e304f753.seg.0.ix" geschrieben (mehrfach und jedes mal Fehler im LOG
                                Jetzt lange Pause ohne Fehler im Log.
                                Nochmal Datenpunkt geschrieben und
                                wled.0	2020-03-03 21:34:47.355	error	(26393) Read Data error : TypeError: Cannot read property 'info' of undefined
                                Der Fehler wird bei allen Stripes gesetzt. Jedes mal wenn ich einen Datenpunkt manuell schreibe.
                                Update:
                                Ich kann jetzt sicher nachvollziehen das dieFehlermeldung nur beim Schreiben eines Datenpunkts kommt.
                                  @Chaot @Dutchman
                                  kann ich bestätigen, es läuft alles. Wenn man aber ein DP schreiben möchte bekommt man diese Fehlermeldung.
                                    stefande last edited by stefande
                                    Mal eine blöde Frage:
                                    Instructions
                                    3. Configure intervall times for data polling and auto-detect cyclus
                                    5. Adapter will send changes immediatly and polls data every x seconds (configurable)
                                    Wo können die oben genannten Parameter eingestellt werden?
                                    • Dutchman
                                      Dutchman Developer Most Active Administrators @stefande last edited by
                                      @stefande sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                                      noch nirgendwo sind momentan hard coded kommt später als state bei info
                                      • Dutchman
                                        mit der neuen Firmware ? ... ok mist... hab ich was zu. tun
                                          stefande @Dutchman last edited by
                                          @Dutchman sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                                          Danke für die Rückmeldung. Hab schon gedacht ich bin blind.
                                          Ist das denn normal, dass es knapp 30 Sekunden dauert bis ich die "Ein Rückmeldung" bekomme?
                                            HomeTed last edited by
                                            welche LED Streifen lassen sich alles mit WLED steuern, gibt es da irgendwo eine Übersicht?
                                            Ich suche die Eierlegende Wollmilchsau, RGB aber auch warmes & kaltes Weiß, wenn ich das richtig sehe wäre das zum Beispiel ein LED Streifen SK6812. Kann ich diesen Streifen auch komplett mit WLED steuern?
                                            31.7k
                                            79.9k
                                            adapater adapter neu hier test testen tester wled
                                            73
                                            655
                                            141395
