    4. Java-Script Adapter startet ab und an nicht -> DB?
    • sissiwup
      sissiwup last edited by
      Normaler Start:
      2016-11-16 04:05:48.691  - info: javascript.0 terminating
      2016-11-16 04:05:48.887  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (OK)
      2016-11-16 04:11:41.818  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 515
      2016-11-16 04:12:00.103  - info: javascript.0 starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.6.0
      2016-11-16 04:12:00.175  - info: javascript.0 requesting all states
      2016-11-16 04:12:00.186  - info: javascript.0 requesting all objects
      2016-11-16 04:12:09.147  - info: javascript.0 received all states
      2016-11-16 04:12:13.740  - info: javascript.0 received all objects
      2016-11-16 04:12:18.920  - info: javascript.0 Start javascript script.js.ereignisse
      2016-11-16 04:12:20.551  - info: javascript.0 script.js.ereignisse: DeviceST=ST-05:1.STATE
      Start ohne Skripte zu initialisieren:
      2016-11-17 04:05:43.684  - info: javascript.0 terminating
      2016-11-17 04:05:43.916  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (OK)
      2016-11-17 04:11:37.940  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 12174
      2016-11-17 04:11:56.047  - info: javascript.0 starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.6.0
      2016-11-17 04:11:56.129  - info: javascript.0 requesting all states
      2016-11-17 04:11:56.140  - info: javascript.0 requesting all objects
      2016-11-17 04:12:05.932  - info: javascript.0 received all states
      2016-11-17 04:12:10.809  - info: javascript.0 received all objects
      2016-11-17 04:13:59.884  - warn: javascript.0 Reconnection to DB.
      2016-11-17 04:14:00.630  - warn: javascript.0 Reconnection to DB.
      2016-11-17 11:42:06.763  - info: host.raspberrypi object change system.adapter.javascript.0
      2016-11-17 11:42:06.790  - info: host.raspberrypi stopInstance system.adapter.javascript.0
      2016-11-17 11:42:06.794  - info: host.raspberrypi stopInstance system.adapter.javascript.0 killing pid 12174
      2016-11-17 11:42:06.868  - info: javascript.0 terminating
      2016-11-17 11:42:06.965  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (OK)
      2016-11-17 11:42:09.386  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 12060
      2016-11-17 11:42:14.561  - info: javascript.0 starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.6.0
      2016-11-17 11:42:14.606  - info: javascript.0 requesting all states
      2016-11-17 11:42:14.613  - info: javascript.0 requesting all objects
      2016-11-17 11:42:20.738  - info: javascript.0 received all states
      2016-11-17 11:42:24.296  - info: javascript.0 received all objects
      2016-11-17 11:42:24.423  - info: javascript.0 Start javascript script.js.ereignisse
      2016-11-17 11:42:25.198  - info: javascript.0 script.js.ereignisse: DeviceST=ST-05:1.STATE
      (um 11.42 habe ich dann einen Restart des Script-Adapters gemacht. Er wird aber normal als running, ohne Probleme angezeigt)
      => Hat das warn: Reconnection to DB etwas zu sagen?
      • Bluefox
        Bluefox last edited by
        @sissiwup:
        Normaler Start:
        => Hat das warn: Reconnection to DB etwas zu sagen? `
        Vermutlich ist der Adapter am Start so mit Skripten beschäftigt, dass er keine Zeit zum Kommunizieren hat. Und die Verbindung zum Controller wird abgebrochen.
        Versuche ein paar Intensivskripte mit setTimeout zu versehen.
        • sissiwup
          habe jetzt mal das "servicemeldungen" von paul53 deaktiviert.
          Kann sein, das seit dem ich das nutze, die Fehler auftauchen.
          Werde das mal beobachten. Danke für den Tipp.
          • sissiwup
            Aktuell läuft er. Ich werde es weiter beobachten.
