    4. Apple Homekit Siri
    Apple Homekit Siri
      funzel1607 last edited by
      Bekommen auf meinem BananaPi ebenfalls folgende Fehler während der Installation des Adapters:
      ! $ ./iobroker add homekit
      ! npm install iobroker.homekit –production --prefix "/opt/iobroker" (System call)
      ! In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
      ! compilation terminated.
      ! make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
      ! gyp
      ! ERR! build error
      ! gyp ERR! stack Error: make failed with exit code: 2
      ! gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:269:23)gyp ERR! stack at ChildProcess.emit (events.js:110:17)
      ! gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:1074:12)
      ! gyp ERR! System Linux 3.4.110-sun7i
      ! gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns
      ! gyp ERR! node -v v0.12.6
      ! gyp
      ! ERR! node-gyp -v v2.0.1gyp ERR! not ok
      ! npm
      ! ERR! Linux 3.4.110-sun7i
      ! npm ERR!
      ! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.homekit" "–production" "--prefix" "/opt/iobroker"
      ! npm ERR! node v0.12.6npm ERR! npm v2.11.2
      ! npm ERR! code ELIFECYCLE
      ! npm ERR! mdns@2.2.11 install: node-gyp rebuild
      ! npm ERR!
      ! Exit status 1npm
      ! ERR! npm
      ! ERR! Failed at the mdns@2.2.11 install script 'node-gyp rebuild'.npm ERR! This is most likely a problem with the mdns package,
      ! npm ERR! not with npm itself.
      ! npm ERR! Tell the author that this fails on your system:
      ! npm ERR! node-gyp rebuild
      ! npm ERR! You can get their info via:
      ! npm ERR! npm owner ls mdnsnpm ERR! There is likely additional logging output above.
      ! npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
      ! ERROR: host.bananapi Cannot install iobroker.homekit: 1
      ! ERROR: process exited with code 25
        lars last edited by
        Bei mir lief die Version 0.1.1 ganz ordentlich. Hab heute das Update auf 0.1.2 gemacht, seitdem habe ich in EVE keine Geräte mehr.
        Habe bisher die Instanz und den Adapter deinstalliert, den homekit Ordner unter iobroker-data entfernt. Die Neuinstallation lief ohne Probleme durch, der Adapter startet auch, es werden auch Änderungen meiner homematic Geräte im homekit log angezeigt.
        Eve habe ich auch schon mehrfach neuinstalliert und neu eingerichtet, die Brigde ist leider das einzige Gerät was ich sehe.
        Hat vielleicht jemand eine Idee?
        Das Ganze läuft auf einem Raspberry mit Jessie…
        Lars
        Hier noch ein kurzer Auszug des LOGs.
        Scheint soweit alles i.O.
        ! homekit-0 2016-02-25 08:04:54 debug 3. Change state for hm-rpc.0.JEQ0089188.1.HUMIDITY to 57 ack = true
        ! homekit-0 2016-02-25 08:04:54 debug 2. Change state for hm-rpc.0.JEQ0089188.1.HUMIDITY to 57 ack = true
        ! homekit-0 2016-02-25 08:04:54 debug 1. Change state for hm-rpc.0.JEQ0089188.1.HUMIDITY to 57 ack = true
        ! homekit-0 2016-02-25 08:04:54 debug NEWVALUE: 57
        ! homekit-0 2016-02-25 08:04:54 debug OLDVALUE: 0
        ! homekit-0 2016-02-25 08:04:54 debug VALUE: 57 id = hm-rpc.0.JEQ0089188.1.HUMIDITY
        ! homekit-0 2016-02-25 08:04:53 debug 3. Change state for hm-rpc.0.JEQ0089188.1.TEMPERATURE to 20.6 ack = true
        ! homekit-0 2016-02-25 08:04:53 debug 2. Change state for hm-rpc.0.JEQ0089188.1.TEMPERATURE to 20.6 ack = true
        ! homekit-0 2016-02-25 08:04:53 debug 1. Change state for hm-rpc.0.JEQ0089188.1.TEMPERATURE to 20.6 ack = true
        ! homekit-0 2016-02-25 08:04:53 debug NEWVALUE: 20.6
        ! homekit-0 2016-02-25 08:04:53 debug OLDVALUE: 0
        ! homekit-0 2016-02-25 08:04:53 debug VALUE: 20.6 id = hm-rpc.0.JEQ0089188.1.TEMPERATURE
          steinwedel last edited by
          Leider bekomme ich HomeKit immer noch nicht zum Laufen. Die Installation des Adapters verläuft ohne Fehler. Wenn ich dannmit der App Eve zugreifen möchte, kommt nach Eingabe der Pin die Fehlermeldung: "Hinzufügen fehlgeschlagen. Verbindung mit dem Zubehör nicht möglich." Im Log tauchen bei der Einstellung Info keine Einträge. Was läuft falsch?
            ramonh2712 last edited by
            ich kann den Homekit Adapter einfach nicht installieren! 😢
            iobroker	2016-02-26 11:26:35	info	exit 25
            iobroker	2016-02-26 11:26:35	error	host.raspberrypi Cannot install iobroker.homekit: 1
            iobroker	2016-02-26 11:26:35	info	npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
            iobroker	2016-02-26 11:26:33	info	npm owner ls mdnsnpm ERR! There is likely additional logging output above.
            iobroker	2016-02-26 11:26:33	info	ERR!
            iobroker	2016-02-26 11:26:33	info	npm ERR! You can get their info via:
            iobroker	2016-02-26 11:26:33	info	npm ERR! node-gyp rebuild
            iobroker	2016-02-26 11:26:33	info	not with npm itself.npm ERR! Tell the author that this fails on your system:
            iobroker	2016-02-26 11:26:33	info	npm ERR! This is most likely a problem with the mdns package,
            iobroker	2016-02-26 11:26:33	info	npm ERR! npm ERR! Failed at the mdns@2.2.11 install script 'node-gyp rebuild'.
            iobroker	2016-02-26 11:26:33	info	npm ERR! Exit status 1
            iobroker	2016-02-26 11:26:33	info	npm ERR! mdns@2.2.11 install: `node-gyp rebuild`
            iobroker	2016-02-26 11:26:33	info	npm ERR! code ELIFECYCLE
            iobroker	2016-02-26 11:26:33	info	npm ERR! node v0.12.6npm ERR! npm v2.11.2
            iobroker	2016-02-26 11:25:50	info	gyp ERR! not ok
            iobroker	2016-02-26 11:25:50	info	gyp ERR! node -v v0.12.6gyp ERR! node-gyp -v v2.0.1
            iobroker	2016-02-26 11:25:50	info	gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/
            iobroker	2016-02-26 11:25:50	info	ERR! System Linux 4.1.13-v7+
            iobroker	2016-02-26 11:25:50	info	gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:1074:12)gyp
            iobroker	2016-02-26 11:25:50	info	ERR! stack at ChildProcess.emit (events.js:110:17)
            iobroker	2016-02-26 11:25:50	info	gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:269:23)
            iobroker	2016-02-26 11:25:50	info	ERR! stack Error: `make` failed with exit code: 2
            iobroker	2016-02-26 11:25:50	info	build error
            iobroker	2016-02-26 11:25:50	info	make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
            iobroker	2016-02-26 11:25:48	info	compilation terminated.
            iobroker	2016-02-26 11:25:48	info	^
            iobroker	2016-02-26 11:25:48	info	#include
            iobroker	2016-02-26 11:25:48	info	In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
            iobroker	2016-02-26 11:24:44	info	npm install iobroker.homekit --production --prefix "/opt/iobroker" (System call)
            iobroker	2016-02-26 11:24:41	info	add homekit
            Es scheint ein Problem mit dem kompilieren zu geben. Allerdings komm ich nicht weiter.
            Kennt jemand diesen Fehler???
            • fischi87
              fischi87 last edited by
              servus,
              also installiert ist alles und laut log läuft der homefit adapter auch aber meine app "eve" findet einfach nicht den brige Biobroker. gibt es dazu schon eine Lösung?
              Mit freundlichen Grüßen
                So nachdem ich ein downgrade auf node.js 4.2.6 gemacht habe gibt es auch Einträge im log.
                host-home	2016-03-01 07:39:45	info	Restart adapter system.adapter.homekit.0 because enabled
                host-home	2016-03-01 07:39:45	error	instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
                homekit-0	2016-03-01 07:39:45	debug	requesting all objects
                homekit-0	2016-03-01 07:39:45	debug	requesting all states
                homekit-0	2016-03-01 07:39:45	info	starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.homekit
                homekit-0	2016-03-01 07:39:44	debug	statesDB connected
                homekit-0	2016-03-01 07:39:44	debug	objectDB connected
                Error:	2016-03-01 07:39:44	error	at Module.load (module.js:344:32)
                Error:	2016-03-01 07:39:44	error	at Object.Module._extensions..js (module.js:417:10)
                Error:	2016-03-01 07:39:44	error	at Module._compile (module.js:410:26)
                Error:	2016-03-01 07:39:44	error	at Object. (/opt/iobroker/node_modules/bignum/index.js:4:14)
                Error:	2016-03-01 07:39:44	error	at new require (internal/module.js:12:17)
                Error:	2016-03-01 07:39:44	error	at Module.require (module.js:354:17)
                Error:	2016-03-01 07:39:44	error	at Function.Module._load (module.js:301:12)
                Error:	2016-03-01 07:39:44	error	at Object.Module._extensions..node (module.js:435:18)
                Error:	2016-03-01 07:39:44	error	at Error (native)
                Error:	2016-03-01 07:39:44	error	Module version mismatch. Expected 46, got 47.
                uncaught	2016-03-01 07:39:44	error	exception: Module version mismatch. Expected 46, got 47.
                host-home	2016-03-01 07:39:44	info	instance system.adapter.homekit.0 started with pid 24660
                Kann jemand etwas damit anfangen? Deinstallieren und neu Installieren des Adapters bringen keine Änderung.
                  chka last edited by
                  habe leider auch den Fehler "Hinzufügen fehlgeschlagen. Verbindung mit dem Zubehör nicht möglich."
                    mimquadrat last edited by
                    @fischi87:
                    servus,
                    Mit freundlichen Grüßen `
                    same here
                      chaos99 last edited by
                      ich kann mich einmal mit EVE und Homekit verbinden , er empfängt die ganzen Geräte, aberer Updatet die Werte nicht mehr und Eve sagt nur das es keine Verbindung gibt zu Homekit, schmeiß ich IoBroker Homekit von eve runter , findet er danach diese nicht mehr beim versuch diese neu hinzuzufügen,
                      edit: und im Log
                      host-cubietruck 2016-03-05 13:20:09 error instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
                      TypeError: 2016-03-05 13:20:08 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                      TypeError: 2016-03-05 13:20:08 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
                      TypeError: 2016-03-05 13:20:08 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                      TypeError: 2016-03-05 13:20:08 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                      TypeError: 2016-03-05 13:20:08 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
                      TypeError: 2016-03-05 13:20:08 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
                      TypeError: 2016-03-05 13:20:08 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:200:60)
                      TypeError: 2016-03-05 13:20:08 error at /opt/iobroker/node_modules/iobroker.homekit/main.js:18:13
                      TypeError: 2016-03-05 13:20:08 error at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:312:69)
                      TypeError: 2016-03-05 13:20:08 error at Object.createAccessory_Thermostat [as Thermostat] (/opt/iobroker/node_modules/iobroker.homekit/main.js:631:47)
                      TypeError: 2016-03-05 13:20:08 error Cannot read property 'CurrentTemperature' of undefined
                      uncaught 2016-03-05 13:20:08 error exception: Cannot read property 'CurrentTemperature' of undefined
                      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Thermostat hm-rpc.0.LEQ0846063.4.ACTUAL_TEMPERATURE
                      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048896.1.HUMIDITY
                      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048898.1.HUMIDITY
                      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048722.1.HUMIDITY
                      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048624.1.HUMIDITY
                      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1483238.1.HUMIDITY
                      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1215360.1.HUMIDITY
                      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1215309.1.HUMIDITY
                      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1215281.1.HUMIDITY
                      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1071633.1.HUMIDITY
                      homekit-0 2016-03-05 13:20:08 debug Accessory: Humidity Object: CurrentRelativeHumidity
                      homekit-0 2016-03-05 13:20:08 info hap-nodejs starting…
                      homekit-0 2016-03-05 13:20:08 debug received all objects
                      • V
                        versteckt last edited by
                        Hallo, aufgrund von Projektstress im Büro und Vereinsstress und privat auch noch verdammt viel um die Ohren,
                        war es mir leider überhaupt nicht möglich, irgendwas zu lesen, schreiben, etc.
                        Werde heute und morgen die Fehler analysieren.
                        Ich gehe mal davon aus, das ihr die letzte Version (0.1.2) verwendet.
                        LG Christian
                        • V
                          @lars:
                          Wenn du mit Debug startest, müssten ja solch ähnliche Logeinträge kommen:
                          2016-03-05 14:03:44.145  - debug: homekit.0 requesting all states
                          2016-03-05 14:03:44.146  - debug: homekit.0 requesting all objects
                          2016-03-05 14:03:44.143  - info: homekit.0 starting. Version 0.1.2 in /Users/christian/DEVELOPMENT/node_modules/iobroker.homekit
                          2016-03-05 14:03:44.445  - debug: homekit.0 received all states
                          2016-03-05 14:03:44.655  - debug: homekit.0 received all objects
                          2016-03-05 14:03:44.656  - info: homekit.0 hap-nodejs starting...
                          2016-03-05 14:03:44.670  - debug: homekit.0 Accessory: Switch Object: State
                          2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Thermostat Object: CurrentTemperature
                          2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Thermostat Object: TargetTemperature
                          2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Thermostat Object: State
                          2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Thermostat Object: CurrentRelativeHumidity
                          2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Temperature Object: CurrentTemperature
                          2016-03-05 14:03:44.672  - debug: homekit.0 Accessory: Humidity Object: CurrentRelativeHumidity
                          2016-03-05 14:03:44.674  - debug: homekit.0 > iobroker subscribe SecuritySystem zwave.0.NODE13.ALARM
                          Kannst du deine mal posten?
                          • V
                            @All:
                            Bez. kompilieren:
                            Bitte lt. https://github.com/KhaosT/HAP-NodeJS/issues/3
                            zuerst folgendes ausführen:
                            sudo apt-get install libavahi-compat-libdnssd-dev
                            • V
                              @chaos99:
                              Welche Infrastruktur hast du im Einsatz?
                              Ich hatte auch immer wieder Sorgen mit meinem Netzwerk.
                              Bzw. welche hap-nodejs ist bei dir installiert?
                              Findest du mit
                              grep -i version /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/package.json
                              heraus.
                              Ich hatte bei mir auch schon das Problem, das die Version < 0.2.4 war.
                              LG Christian
                                "version": "0.2.4",
                                ist was ich bekomme,
                                mein cubi mit iobroker hängt am Netzwerk wie meine HUE bridge , die erreiche ich auch ohne Probleme mit EVE, nur iobroker-homekit spinnt rum, am Netztwerk sollte es nicht liegen ich erreiche übers Handy ohne Probleme VIS und den cubi über Putty auf dem Tel. Die HUE bridge hab ich auch schon mal vom Netzwerk genommen um den fehler auszuschließen .
                                • V
                                  Ok, nicht missverstehen.
                                  Der MDNS / Bonjour Dienst unter Linux ist bescheiden.
                                  Der reagiert schon mal empfindlich auf WLAN / LAN.
                                  HAP-Nodejs nutzt ja diesen Dienst.
                                  Ich lese mir deine Meldungen mal in Ruhe durch und gebe dir dann Bescheid.
                                    Nein das nehme ich auch nicht böse, bin ja dankbar für eure Arbeit und für jede Idee offen, ich hab nachdem ich eve noch mal zurückgesetzt habe , iPhone Homekit gelöscht , dann noch mal von vorne begonnen und dann findet Eve die iobroker-homekit nicht, (IO-homekit neu installiert , Eve ebenso) geholfen hat wo ich dann mal die MAC-Adresse vom iobroker-homekit geändert habe….
                                    das Hauptproblem liegt aber : das wenn ich Eve und IO-homekit gekoppelt habe alle Aktoren gezeigt werden , auch mit aktuellen Daten(Temperaturen zb.) dann aber keine Aktualisierung mehr geschieht, direkt 1 min später aktualisiert Eve nicht mehr mit IO-Homekit
                                    • V
                                      Ok, das Problem wurde bei mir durch die 0.2.4 von hap-Models gelöst.
                                      Das mit dem löschen und neu installieren ist so eine Sache, dein Lösungsweg ist aber voll ok.
                                      Welches Betriebssystem setzt du ein bzw. welche node Version?
                                      Gesendet von meinem iPhone mit Tapatalk
                                      • V
                                        @chaos99:
                                        Siehst du beim starten von homekit (mit Debug) solch ähnliche Einträge?
                                        debug: homekit.0 < hap JEQ0550466 get CurrentTemperature for hm-rpc.1.JEQ0550466.1.TEMPERATURE
                                        Den Fehler bez. der Exception hab ich schon gefunden, da kommt demnächst eine Aktualisierung.
                                        • V
                                          Die Version 0.1.3 ist draussen, bitte mal aktualisieren
                                          und per Debug starten.
                                          Danach mir bitte das Logfile zukommen lassen.
                                          Danke, LG Christian
                                            chka last edited by
                                            Bitscheen 883_iobroker.2016-03-05.log
                                            Verbinden geht leider immer noch nicht
                                            250
                                            52421
