    4. Apple Homekit Siri
    Apple Homekit Siri
      ramonh2712 last edited by
      ich kann den Homekit Adapter einfach nicht installieren! 😢
      iobroker	2016-02-26 11:26:35	info	exit 25
      iobroker	2016-02-26 11:26:35	error	host.raspberrypi Cannot install iobroker.homekit: 1
      iobroker	2016-02-26 11:26:35	info	npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
      iobroker	2016-02-26 11:26:33	info	npm owner ls mdnsnpm ERR! There is likely additional logging output above.
      iobroker	2016-02-26 11:26:33	info	ERR!
      iobroker	2016-02-26 11:26:33	info	npm ERR! You can get their info via:
      iobroker	2016-02-26 11:26:33	info	npm ERR! node-gyp rebuild
      iobroker	2016-02-26 11:26:33	info	not with npm itself.npm ERR! Tell the author that this fails on your system:
      iobroker	2016-02-26 11:26:33	info	npm ERR! This is most likely a problem with the mdns package,
      iobroker	2016-02-26 11:26:33	info	npm ERR! npm ERR! Failed at the mdns@2.2.11 install script 'node-gyp rebuild'.
      iobroker	2016-02-26 11:26:33	info	npm ERR! Exit status 1
      iobroker	2016-02-26 11:26:33	info	npm ERR! mdns@2.2.11 install: `node-gyp rebuild`
      iobroker	2016-02-26 11:26:33	info	npm ERR! code ELIFECYCLE
      iobroker	2016-02-26 11:26:33	info	npm ERR! node v0.12.6npm ERR! npm v2.11.2
      iobroker	2016-02-26 11:25:50	info	gyp ERR! not ok
      iobroker	2016-02-26 11:25:50	info	gyp ERR! node -v v0.12.6gyp ERR! node-gyp -v v2.0.1
      iobroker	2016-02-26 11:25:50	info	gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/
      iobroker	2016-02-26 11:25:50	info	ERR! System Linux 4.1.13-v7+
      iobroker	2016-02-26 11:25:50	info	gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:1074:12)gyp
      iobroker	2016-02-26 11:25:50	info	ERR! stack at ChildProcess.emit (events.js:110:17)
      iobroker	2016-02-26 11:25:50	info	gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:269:23)
      iobroker	2016-02-26 11:25:50	info	ERR! stack Error: `make` failed with exit code: 2
      iobroker	2016-02-26 11:25:50	info	build error
      iobroker	2016-02-26 11:25:50	info	make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
      iobroker	2016-02-26 11:25:48	info	compilation terminated.
      iobroker	2016-02-26 11:25:48	info	^
      iobroker	2016-02-26 11:25:48	info	#include
      iobroker	2016-02-26 11:25:48	info	In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
      iobroker	2016-02-26 11:24:44	info	npm install iobroker.homekit --production --prefix "/opt/iobroker" (System call)
      iobroker	2016-02-26 11:24:41	info	add homekit
      Es scheint ein Problem mit dem kompilieren zu geben. Allerdings komm ich nicht weiter.
      Kennt jemand diesen Fehler???
      • fischi87
        fischi87 last edited by
        servus,
        also installiert ist alles und laut log läuft der homefit adapter auch aber meine app "eve" findet einfach nicht den brige Biobroker. gibt es dazu schon eine Lösung?
        Mit freundlichen Grüßen
          steinwedel last edited by
          So nachdem ich ein downgrade auf node.js 4.2.6 gemacht habe gibt es auch Einträge im log.
          host-home	2016-03-01 07:39:45	info	Restart adapter system.adapter.homekit.0 because enabled
          host-home	2016-03-01 07:39:45	error	instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
          homekit-0	2016-03-01 07:39:45	debug	requesting all objects
          homekit-0	2016-03-01 07:39:45	debug	requesting all states
          homekit-0	2016-03-01 07:39:45	info	starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.homekit
          homekit-0	2016-03-01 07:39:44	debug	statesDB connected
          homekit-0	2016-03-01 07:39:44	debug	objectDB connected
          Error:	2016-03-01 07:39:44	error	at Module.load (module.js:344:32)
          Error:	2016-03-01 07:39:44	error	at Object.Module._extensions..js (module.js:417:10)
          Error:	2016-03-01 07:39:44	error	at Module._compile (module.js:410:26)
          Error:	2016-03-01 07:39:44	error	at Object. (/opt/iobroker/node_modules/bignum/index.js:4:14)
          Error:	2016-03-01 07:39:44	error	at new require (internal/module.js:12:17)
          Error:	2016-03-01 07:39:44	error	at Module.require (module.js:354:17)
          Error:	2016-03-01 07:39:44	error	at Function.Module._load (module.js:301:12)
          Error:	2016-03-01 07:39:44	error	at Object.Module._extensions..node (module.js:435:18)
          Error:	2016-03-01 07:39:44	error	at Error (native)
          Error:	2016-03-01 07:39:44	error	Module version mismatch. Expected 46, got 47.
          uncaught	2016-03-01 07:39:44	error	exception: Module version mismatch. Expected 46, got 47.
          host-home	2016-03-01 07:39:44	info	instance system.adapter.homekit.0 started with pid 24660
          Kann jemand etwas damit anfangen? Deinstallieren und neu Installieren des Adapters bringen keine Änderung.
            chka last edited by
            habe leider auch den Fehler "Hinzufügen fehlgeschlagen. Verbindung mit dem Zubehör nicht möglich."
              mimquadrat last edited by
              @fischi87:
              servus,
              Mit freundlichen Grüßen `
              same here
                chaos99 last edited by
                ich kann mich einmal mit EVE und Homekit verbinden , er empfängt die ganzen Geräte, aberer Updatet die Werte nicht mehr und Eve sagt nur das es keine Verbindung gibt zu Homekit, schmeiß ich IoBroker Homekit von eve runter , findet er danach diese nicht mehr beim versuch diese neu hinzuzufügen,
                edit: und im Log
                host-cubietruck 2016-03-05 13:20:09 error instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
                TypeError: 2016-03-05 13:20:08 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                TypeError: 2016-03-05 13:20:08 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
                TypeError: 2016-03-05 13:20:08 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                TypeError: 2016-03-05 13:20:08 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                TypeError: 2016-03-05 13:20:08 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
                TypeError: 2016-03-05 13:20:08 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
                TypeError: 2016-03-05 13:20:08 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:200:60)
                TypeError: 2016-03-05 13:20:08 error at /opt/iobroker/node_modules/iobroker.homekit/main.js:18:13
                TypeError: 2016-03-05 13:20:08 error at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:312:69)
                TypeError: 2016-03-05 13:20:08 error at Object.createAccessory_Thermostat [as Thermostat] (/opt/iobroker/node_modules/iobroker.homekit/main.js:631:47)
                TypeError: 2016-03-05 13:20:08 error Cannot read property 'CurrentTemperature' of undefined
                uncaught 2016-03-05 13:20:08 error exception: Cannot read property 'CurrentTemperature' of undefined
                homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Thermostat hm-rpc.0.LEQ0846063.4.ACTUAL_TEMPERATURE
                homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048896.1.HUMIDITY
                homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048898.1.HUMIDITY
                homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048722.1.HUMIDITY
                homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048624.1.HUMIDITY
                homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1483238.1.HUMIDITY
                homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1215360.1.HUMIDITY
                homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1215309.1.HUMIDITY
                homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1215281.1.HUMIDITY
                homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1071633.1.HUMIDITY
                homekit-0 2016-03-05 13:20:08 debug Accessory: Humidity Object: CurrentRelativeHumidity
                homekit-0 2016-03-05 13:20:08 info hap-nodejs starting…
                homekit-0 2016-03-05 13:20:08 debug received all objects
                • V
                  versteckt last edited by
                  Hallo, aufgrund von Projektstress im Büro und Vereinsstress und privat auch noch verdammt viel um die Ohren,
                  war es mir leider überhaupt nicht möglich, irgendwas zu lesen, schreiben, etc.
                  Werde heute und morgen die Fehler analysieren.
                  Ich gehe mal davon aus, das ihr die letzte Version (0.1.2) verwendet.
                  LG Christian
                  • V
                    @lars:
                    Wenn du mit Debug startest, müssten ja solch ähnliche Logeinträge kommen:
                    2016-03-05 14:03:44.145  - debug: homekit.0 requesting all states
                    2016-03-05 14:03:44.146  - debug: homekit.0 requesting all objects
                    2016-03-05 14:03:44.143  - info: homekit.0 starting. Version 0.1.2 in /Users/christian/DEVELOPMENT/node_modules/iobroker.homekit
                    2016-03-05 14:03:44.445  - debug: homekit.0 received all states
                    2016-03-05 14:03:44.655  - debug: homekit.0 received all objects
                    2016-03-05 14:03:44.656  - info: homekit.0 hap-nodejs starting...
                    2016-03-05 14:03:44.670  - debug: homekit.0 Accessory: Switch Object: State
                    2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Thermostat Object: CurrentTemperature
                    2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Thermostat Object: TargetTemperature
                    2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Thermostat Object: State
                    2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Thermostat Object: CurrentRelativeHumidity
                    2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Temperature Object: CurrentTemperature
                    2016-03-05 14:03:44.672  - debug: homekit.0 Accessory: Humidity Object: CurrentRelativeHumidity
                    2016-03-05 14:03:44.674  - debug: homekit.0 > iobroker subscribe SecuritySystem zwave.0.NODE13.ALARM
                    Kannst du deine mal posten?
                    • V
                      @All:
                      Bez. kompilieren:
                      Bitte lt. https://github.com/KhaosT/HAP-NodeJS/issues/3
                      zuerst folgendes ausführen:
                      sudo apt-get install libavahi-compat-libdnssd-dev
                      • V
                        @chaos99:
                        Welche Infrastruktur hast du im Einsatz?
                        Ich hatte auch immer wieder Sorgen mit meinem Netzwerk.
                        Bzw. welche hap-nodejs ist bei dir installiert?
                        Findest du mit
                        grep -i version /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/package.json
                        heraus.
                        Ich hatte bei mir auch schon das Problem, das die Version < 0.2.4 war.
                        LG Christian
                          "version": "0.2.4",
                          ist was ich bekomme,
                          mein cubi mit iobroker hängt am Netzwerk wie meine HUE bridge , die erreiche ich auch ohne Probleme mit EVE, nur iobroker-homekit spinnt rum, am Netztwerk sollte es nicht liegen ich erreiche übers Handy ohne Probleme VIS und den cubi über Putty auf dem Tel. Die HUE bridge hab ich auch schon mal vom Netzwerk genommen um den fehler auszuschließen .
                          • V
                            Ok, nicht missverstehen.
                            Der MDNS / Bonjour Dienst unter Linux ist bescheiden.
                            Der reagiert schon mal empfindlich auf WLAN / LAN.
                            HAP-Nodejs nutzt ja diesen Dienst.
                            Ich lese mir deine Meldungen mal in Ruhe durch und gebe dir dann Bescheid.
                              Nein das nehme ich auch nicht böse, bin ja dankbar für eure Arbeit und für jede Idee offen, ich hab nachdem ich eve noch mal zurückgesetzt habe , iPhone Homekit gelöscht , dann noch mal von vorne begonnen und dann findet Eve die iobroker-homekit nicht, (IO-homekit neu installiert , Eve ebenso) geholfen hat wo ich dann mal die MAC-Adresse vom iobroker-homekit geändert habe….
                              das Hauptproblem liegt aber : das wenn ich Eve und IO-homekit gekoppelt habe alle Aktoren gezeigt werden , auch mit aktuellen Daten(Temperaturen zb.) dann aber keine Aktualisierung mehr geschieht, direkt 1 min später aktualisiert Eve nicht mehr mit IO-Homekit
                              • V
                                Ok, das Problem wurde bei mir durch die 0.2.4 von hap-Models gelöst.
                                Das mit dem löschen und neu installieren ist so eine Sache, dein Lösungsweg ist aber voll ok.
                                Welches Betriebssystem setzt du ein bzw. welche node Version?
                                Gesendet von meinem iPhone mit Tapatalk
                                • V
                                  @chaos99:
                                  Siehst du beim starten von homekit (mit Debug) solch ähnliche Einträge?
                                  debug: homekit.0 < hap JEQ0550466 get CurrentTemperature for hm-rpc.1.JEQ0550466.1.TEMPERATURE
                                  Den Fehler bez. der Exception hab ich schon gefunden, da kommt demnächst eine Aktualisierung.
                                  • V
                                    Die Version 0.1.3 ist draussen, bitte mal aktualisieren
                                    und per Debug starten.
                                    Danach mir bitte das Logfile zukommen lassen.
                                    Danke, LG Christian
                                      chka last edited by
                                      Bitscheen 883_iobroker.2016-03-05.log
                                      Verbinden geht leider immer noch nicht
                                      • V
                                        @chka: Version 0.1.4 ist hochgeladen, der Fehler zum Schluss in deinem Log sollte nun weg sein.
                                        Kannst du mal versuchen, die Parameter von homekit zu ändern?
                                        Vor allem den Username.
                                        Aber Achtung, dadurch wird quasi eine neue Instanz erzeugt, nur als Info falls du in Eve bereits
                                        Sachen definiert hast, sind die dann dadurch weg.
                                        LG Christian
                                          host-raspberrypi 2016-03-05 20:19:27 info Restart adapter system.adapter.homekit.0 because enabled
                                          host-raspberrypi 2016-03-05 20:19:27 error instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
                                          TypeError: 2016-03-05 20:19:27 error at IncomingMessage.emit (events.js:104:17)
                                          TypeError: 2016-03-05 20:19:27 error at HAPServer. (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/HAPServer.js:188:39)
                                          TypeError: 2016-03-05 20:19:27 error at HAPServer._handleCharacteristics (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/HAPServer.js:724:10)
                                          TypeError: 2016-03-05 20:19:27 error at HAPServer.emit (events.js:118:17)
                                          TypeError: 2016-03-05 20:19:27 error at Bridge.Accessory._handleGetCharacteristics (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Accessory.js:554:8)
                                          TypeError: 2016-03-05 20:19:27 error at Array.forEach (native)
                                          TypeError: 2016-03-05 20:19:27 error at Bridge. (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Accessory.js:587:20)
                                          TypeError: 2016-03-05 20:19:27 error at Characteristic.getValue (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Characteristic.js:120:10)
                                          TypeError: 2016-03-05 20:19:27 error at emit (events.js:110:17)
                                          TypeError: 2016-03-05 20:19:27 error at null. (/opt/iobroker/node_modules/iobroker.homekit/main.js:759:37)
                                          TypeError: 2016-03-05 20:19:27 error Cannot read property 'val' of undefined
                                          uncaught 2016-03-05 20:19:27 error exception: Cannot read property 'val' of undefined
                                          homekit-0 2016-03-05 20:19:27 debug < hap Summer get Switch for hm-rpc.0.LEQ0569487.4undefined
                                          homekit-0 2016-03-05 20:19:27 debug < hap Treppenhauslicht get Switch for hm-rpc.0.JEQ0147075.1.STATE
                                            So ich hab noch mal etwas rum probiert , ich hab jetzt IO- HomeKit bei eve , verliere dann nach 1 min die Verbindung zu den aktoren , wenn ich jetzt das WLAN aus und wieder an mache hab ich wieder Verbindung zu den aktoren für 1 min
                                            Edit: so ich hab mal ein anderes program genommen , also sogar zwei , und beide funktionieren ohne Probleme , also liegt es bei mir an eve , jetzt muss ich nur noch eine App finden die die sprach Steuerung so umsetzt wie ich mir das denke ,
                                            250
                                            52421
