    4. Apple Homekit Siri
    Apple Homekit Siri
      chaos99 last edited by
      ich kann mich einmal mit EVE und Homekit verbinden , er empfängt die ganzen Geräte, aberer Updatet die Werte nicht mehr und Eve sagt nur das es keine Verbindung gibt zu Homekit, schmeiß ich IoBroker Homekit von eve runter , findet er danach diese nicht mehr beim versuch diese neu hinzuzufügen,
      edit: und im Log
      host-cubietruck 2016-03-05 13:20:09 error instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
      TypeError: 2016-03-05 13:20:08 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      TypeError: 2016-03-05 13:20:08 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
      TypeError: 2016-03-05 13:20:08 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
      TypeError: 2016-03-05 13:20:08 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      TypeError: 2016-03-05 13:20:08 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
      TypeError: 2016-03-05 13:20:08 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
      TypeError: 2016-03-05 13:20:08 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:200:60)
      TypeError: 2016-03-05 13:20:08 error at /opt/iobroker/node_modules/iobroker.homekit/main.js:18:13
      TypeError: 2016-03-05 13:20:08 error at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:312:69)
      TypeError: 2016-03-05 13:20:08 error at Object.createAccessory_Thermostat [as Thermostat] (/opt/iobroker/node_modules/iobroker.homekit/main.js:631:47)
      TypeError: 2016-03-05 13:20:08 error Cannot read property 'CurrentTemperature' of undefined
      uncaught 2016-03-05 13:20:08 error exception: Cannot read property 'CurrentTemperature' of undefined
      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Thermostat hm-rpc.0.LEQ0846063.4.ACTUAL_TEMPERATURE
      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048896.1.HUMIDITY
      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048898.1.HUMIDITY
      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048722.1.HUMIDITY
      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048624.1.HUMIDITY
      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1483238.1.HUMIDITY
      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1215360.1.HUMIDITY
      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1215309.1.HUMIDITY
      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1215281.1.HUMIDITY
      homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1071633.1.HUMIDITY
      homekit-0 2016-03-05 13:20:08 debug Accessory: Humidity Object: CurrentRelativeHumidity
      homekit-0 2016-03-05 13:20:08 info hap-nodejs starting…
      homekit-0 2016-03-05 13:20:08 debug received all objects
      • V
        versteckt last edited by
        Hallo, aufgrund von Projektstress im Büro und Vereinsstress und privat auch noch verdammt viel um die Ohren,
        war es mir leider überhaupt nicht möglich, irgendwas zu lesen, schreiben, etc.
        Werde heute und morgen die Fehler analysieren.
        Ich gehe mal davon aus, das ihr die letzte Version (0.1.2) verwendet.
        LG Christian
        • V
          @lars:
          Wenn du mit Debug startest, müssten ja solch ähnliche Logeinträge kommen:
          2016-03-05 14:03:44.145  - debug: homekit.0 requesting all states
          2016-03-05 14:03:44.146  - debug: homekit.0 requesting all objects
          2016-03-05 14:03:44.143  - info: homekit.0 starting. Version 0.1.2 in /Users/christian/DEVELOPMENT/node_modules/iobroker.homekit
          2016-03-05 14:03:44.445  - debug: homekit.0 received all states
          2016-03-05 14:03:44.655  - debug: homekit.0 received all objects
          2016-03-05 14:03:44.656  - info: homekit.0 hap-nodejs starting...
          2016-03-05 14:03:44.670  - debug: homekit.0 Accessory: Switch Object: State
          2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Thermostat Object: CurrentTemperature
          2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Thermostat Object: TargetTemperature
          2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Thermostat Object: State
          2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Thermostat Object: CurrentRelativeHumidity
          2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Temperature Object: CurrentTemperature
          2016-03-05 14:03:44.672  - debug: homekit.0 Accessory: Humidity Object: CurrentRelativeHumidity
          2016-03-05 14:03:44.674  - debug: homekit.0 > iobroker subscribe SecuritySystem zwave.0.NODE13.ALARM
          Kannst du deine mal posten?
          • V
            @All:
            Bez. kompilieren:
            Bitte lt. https://github.com/KhaosT/HAP-NodeJS/issues/3
            zuerst folgendes ausführen:
            sudo apt-get install libavahi-compat-libdnssd-dev
            • V
              @chaos99:
              Welche Infrastruktur hast du im Einsatz?
              Ich hatte auch immer wieder Sorgen mit meinem Netzwerk.
              Bzw. welche hap-nodejs ist bei dir installiert?
              Findest du mit
              grep -i version /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/package.json
              heraus.
              Ich hatte bei mir auch schon das Problem, das die Version < 0.2.4 war.
              LG Christian
                "version": "0.2.4",
                ist was ich bekomme,
                mein cubi mit iobroker hängt am Netzwerk wie meine HUE bridge , die erreiche ich auch ohne Probleme mit EVE, nur iobroker-homekit spinnt rum, am Netztwerk sollte es nicht liegen ich erreiche übers Handy ohne Probleme VIS und den cubi über Putty auf dem Tel. Die HUE bridge hab ich auch schon mal vom Netzwerk genommen um den fehler auszuschließen .
                • V
                  Ok, nicht missverstehen.
                  Der MDNS / Bonjour Dienst unter Linux ist bescheiden.
                  Der reagiert schon mal empfindlich auf WLAN / LAN.
                  HAP-Nodejs nutzt ja diesen Dienst.
                  Ich lese mir deine Meldungen mal in Ruhe durch und gebe dir dann Bescheid.
                    Nein das nehme ich auch nicht böse, bin ja dankbar für eure Arbeit und für jede Idee offen, ich hab nachdem ich eve noch mal zurückgesetzt habe , iPhone Homekit gelöscht , dann noch mal von vorne begonnen und dann findet Eve die iobroker-homekit nicht, (IO-homekit neu installiert , Eve ebenso) geholfen hat wo ich dann mal die MAC-Adresse vom iobroker-homekit geändert habe….
                    das Hauptproblem liegt aber : das wenn ich Eve und IO-homekit gekoppelt habe alle Aktoren gezeigt werden , auch mit aktuellen Daten(Temperaturen zb.) dann aber keine Aktualisierung mehr geschieht, direkt 1 min später aktualisiert Eve nicht mehr mit IO-Homekit
                    • V
                      Ok, das Problem wurde bei mir durch die 0.2.4 von hap-Models gelöst.
                      Das mit dem löschen und neu installieren ist so eine Sache, dein Lösungsweg ist aber voll ok.
                      Welches Betriebssystem setzt du ein bzw. welche node Version?
                      Gesendet von meinem iPhone mit Tapatalk
                      • V
                        @chaos99:
                        Siehst du beim starten von homekit (mit Debug) solch ähnliche Einträge?
                        debug: homekit.0 < hap JEQ0550466 get CurrentTemperature for hm-rpc.1.JEQ0550466.1.TEMPERATURE
                        Den Fehler bez. der Exception hab ich schon gefunden, da kommt demnächst eine Aktualisierung.
                        • V
                          Die Version 0.1.3 ist draussen, bitte mal aktualisieren
                          und per Debug starten.
                          Danach mir bitte das Logfile zukommen lassen.
                          Danke, LG Christian
                            chka last edited by
                            Bitscheen 883_iobroker.2016-03-05.log
                            Verbinden geht leider immer noch nicht
                            • V
                              @chka: Version 0.1.4 ist hochgeladen, der Fehler zum Schluss in deinem Log sollte nun weg sein.
                              Kannst du mal versuchen, die Parameter von homekit zu ändern?
                              Vor allem den Username.
                              Aber Achtung, dadurch wird quasi eine neue Instanz erzeugt, nur als Info falls du in Eve bereits
                              Sachen definiert hast, sind die dann dadurch weg.
                              LG Christian
                                mimquadrat last edited by
                                host-raspberrypi 2016-03-05 20:19:27 info Restart adapter system.adapter.homekit.0 because enabled
                                host-raspberrypi 2016-03-05 20:19:27 error instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
                                TypeError: 2016-03-05 20:19:27 error at IncomingMessage.emit (events.js:104:17)
                                TypeError: 2016-03-05 20:19:27 error at HAPServer. (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/HAPServer.js:188:39)
                                TypeError: 2016-03-05 20:19:27 error at HAPServer._handleCharacteristics (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/HAPServer.js:724:10)
                                TypeError: 2016-03-05 20:19:27 error at HAPServer.emit (events.js:118:17)
                                TypeError: 2016-03-05 20:19:27 error at Bridge.Accessory._handleGetCharacteristics (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Accessory.js:554:8)
                                TypeError: 2016-03-05 20:19:27 error at Array.forEach (native)
                                TypeError: 2016-03-05 20:19:27 error at Bridge. (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Accessory.js:587:20)
                                TypeError: 2016-03-05 20:19:27 error at Characteristic.getValue (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Characteristic.js:120:10)
                                TypeError: 2016-03-05 20:19:27 error at emit (events.js:110:17)
                                TypeError: 2016-03-05 20:19:27 error at null. (/opt/iobroker/node_modules/iobroker.homekit/main.js:759:37)
                                TypeError: 2016-03-05 20:19:27 error Cannot read property 'val' of undefined
                                uncaught 2016-03-05 20:19:27 error exception: Cannot read property 'val' of undefined
                                homekit-0 2016-03-05 20:19:27 debug < hap Summer get Switch for hm-rpc.0.LEQ0569487.4undefined
                                homekit-0 2016-03-05 20:19:27 debug < hap Treppenhauslicht get Switch for hm-rpc.0.JEQ0147075.1.STATE
                                  So ich hab noch mal etwas rum probiert , ich hab jetzt IO- HomeKit bei eve , verliere dann nach 1 min die Verbindung zu den aktoren , wenn ich jetzt das WLAN aus und wieder an mache hab ich wieder Verbindung zu den aktoren für 1 min
                                  Edit: so ich hab mal ein anderes program genommen , also sogar zwei , und beide funktionieren ohne Probleme , also liegt es bei mir an eve , jetzt muss ich nur noch eine App finden die die sprach Steuerung so umsetzt wie ich mir das denke ,
                                    chka last edited by
                                    der code ist leider immer noch nicht ok,
                                    Benutzer habe ich geändert der anmeldeprozes war diesmal anders
                                    • V
                                      @chaos99:
                                      Ok!? Mit Eve hatte ich eigentlich immer die gleichen Probleme wie z.B. mit MyHome.
                                      Die Sprachsteuerung ist ja fix in iOS integriert. Du musst ja nur die Geräte, Räume, Szenen, etc.
                                      korrekt benennen und dann ist dies mit Siri nativ möglich.
                                      @chka:
                                      In deinem Logfile sind aber keine Exceptions mehr drinnen.
                                      Hast du wie chaos99 auch schon mal eine andere App ausprobiert?
                                      LG Christian
                                        okay noch ein update, es ging zwar ne weile gut mit der anderen App dann aber das gleiche Problem, ich hatte mir da schon die App myHome gekauft,
                                        da bekomme ich dann auch ne Fehlermeldung, ich hab den Support angeschrieben und auch ne Antwort bekommen :
                                        PS: OSStatus 6723 also hints that you are using homebridge. If so, please refer to https://github.com/nfarina/homebridge
                                        This has been an issue there in the past, e.g. https://github.com/nfarina/homebridge/issues/117
                                        so weit ich das verstehe , könnte es also an einem Aktor liegen ?
                                        Edit:
                                        um das mit den Aktoren mal zu prüfen , will ich das nur ein teil der Aktoren an Homekit übertragen wird, aber wie mach ich das? unter Konfiguration kann ich ja Geräte löschen(hab Homekit neu installiert Geräte gelöscht und dann erst gestartet) bekomme dann im log aber diese Fehler:
                                        host-cubietruck 2016-03-06 12:22:30 error instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
                                        TypeError: 2016-03-06 12:22:29 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                                        TypeError: 2016-03-06 12:22:29 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
                                        TypeError: 2016-03-06 12:22:29 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                                        TypeError: 2016-03-06 12:22:29 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                                        TypeError: 2016-03-06 12:22:29 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
                                        TypeError: 2016-03-06 12:22:29 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
                                        TypeError: 2016-03-06 12:22:29 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:200:60)
                                        TypeError: 2016-03-06 12:22:29 error at /opt/iobroker/node_modules/iobroker.homekit/main.js:18:13
                                        TypeError: 2016-03-06 12:22:29 error at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:280:67)
                                        TypeError: 2016-03-06 12:22:29 error at Object.createAccessory_Humidity [as Humidity] (/opt/iobroker/node_modules/iobroker.homekit/main.js:511:41)
                                        TypeError: 2016-03-06 12:22:29 error Cannot read property 'CurrentRelativeHumidity' of undefined
                                        uncaught 2016-03-06 12:22:29 error exception: Cannot read property 'CurrentRelativeHumidity' of undefined
                                        homekit-0 2016-03-06 12:22:29 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1071633.1.HUMIDITY
                                        homekit-0 2016-03-06 12:22:29 debug < hap Type for Humidity = HM-TC-IT-WM-W-EU
                                        homekit-0 2016-03-06 12:22:29 debug Accessory: Switch Object: State
                                        homekit-0 2016-03-06 12:22:29 info hap-nodejs starting…
                                        homekit-0 2016-03-06 12:22:29 debug received all objects
                                        homekit-0 2016-03-06 12:22:28 debug received all states
                                        homekit-0 2016-03-06 12:22:24 debug requesting all objects
                                        homekit-0 2016-03-06 12:22:24 debug requesting all states
                                        homekit-0 2016-03-06 12:22:24 info starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.homekit
                                        ich hab was gelesen das ich das über enum.homekit machen kann , hab dies auch versucht aber ich weiß nicht wie das dann mit Homekit verbunden wird das er nur diese Geräte nutzt
                                        nzhome created this issue in nfarina/homebridge
                                        closed New version: Failed with OSStatus code -6723 (Communication Failure) server jammed? #117
                                          chka last edited by
                                          Ich habe es jetzt mal die My Home app con Clemens Putschei ausprobiert, leider das gleiche 883_iobroker.2016-03-06-0.log 883_iobroker.2016-03-06-1.log
                                            MaggeO last edited by
                                            auch ich habe es mittlerweile gewagt, und ioBroker auf einem Debian in einer VM installiert. Das ganze läuft auch schon richtig gut. Daher habe ich mich nun auch an die Installation von Homekit getraut, stehe aber vor dem gleichen bzw. sehr ähnlichen Problem wie ihr. Die Einrichtung in Eve (oder auch Devices) funktioniert mit den bekannten Tücken wie Username ändern ansonsten problemlos und es werden auch alle Geräte aufgelistet. Allerdings stürzt dann sofort homekit ab und startet neu. Durch eine erzwungene Aktualisierung in Eve kann ich den erneuten Absturz aber provozieren.
                                            Da ich in der selben VM vor der Installation von ioBroker/homekit mit denselben Versionen der anderen Tools wie node.js/hap… jedoch eine lauffähige Version von Homebridge hatte, gehe ich davon aus, dass es nur an einem bestimmten Gerät liegt. Denn bei der Homebridge hatte ich gezielt über ein Gewerk in der CCU2 nur eine bestimmte Auswahl an Geräten für Homebridge "aktiviert".
                                            Im Anhang auch noch ein Ausschnitt meines Logfiles.
                                            1112_homekit_problem.log
                                            250
                                            52416
