    4. Test Adapter mihome-vacuum v2.0.x
      jensus11 last edited by jensus11
      mihome-vacuum.0	2020-03-03 19:48:03.714	debug	(15538) Receive <<< {"result":[{"msg_ver":8,"msg_seq":3338,"state":8,"battery":100,"clean_time":224,"clean_area":7165000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}
      mihome-vacuum.0	2020-03-03 19:48:03.708	debug	(15538) sendMsg[1] >>> {"id":29,"method":"get_status"}
      mihome-vacuum.0	2020-03-03 19:47:50.191	warn	(15538) Could not receive Mappointer, giving up
      mihome-vacuum.0	2020-03-03 19:47:50.191	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":28}
      mihome-vacuum.0	2020-03-03 19:47:50.182	debug	(15538) 9. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-03-03 19:47:50.182	debug	(15538) sendMsg[1] >>> {"id":28,"method":"get_map_v1"}
      mihome-vacuum.0	2020-03-03 19:47:49.681	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":27}
      mihome-vacuum.0	2020-03-03 19:47:49.662	debug	(15538) 8. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-03-03 19:47:49.662	debug	(15538) sendMsg[1] >>> {"id":27,"method":"get_map_v1"}
      mihome-vacuum.0	2020-03-03 19:47:49.160	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":26}
      mihome-vacuum.0	2020-03-03 19:47:49.156	debug	(15538) 7. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-03-03 19:47:49.155	debug	(15538) sendMsg[1] >>> {"id":26,"method":"get_map_v1"}
      mihome-vacuum.0	2020-03-03 19:47:48.654	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":25}
      mihome-vacuum.0	2020-03-03 19:47:48.642	debug	(15538) 6. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-03-03 19:47:48.641	debug	(15538) sendMsg[1] >>> {"id":25,"method":"get_map_v1"}
      mihome-vacuum.0	2020-03-03 19:47:48.141	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":24}
      mihome-vacuum.0	2020-03-03 19:47:48.117	debug	(15538) 5. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-03-03 19:47:48.117	debug	(15538) sendMsg[1] >>> {"id":24,"method":"get_map_v1"}
      mihome-vacuum.0	2020-03-03 19:47:47.616	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":23}
      mihome-vacuum.0	2020-03-03 19:47:47.610	debug	(15538) 4. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-03-03 19:47:47.610	debug	(15538) sendMsg[1] >>> {"id":23,"method":"get_map_v1"}
      mihome-vacuum.0	2020-03-03 19:47:47.109	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":22}
      mihome-vacuum.0	2020-03-03 19:47:47.105	debug	(15538) 3. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-03-03 19:47:47.104	debug	(15538) sendMsg[1] >>> {"id":22,"method":"get_map_v1"}
      mihome-vacuum.0	2020-03-03 19:47:46.607	debug	(15538) CLEAN_LOGGING[{"Datum":"3.3","Start":"19:02","Saugzeit":"4 min","Fläche":"7.17 m²","Error":0,"Ende":false},{"Datum":"3.3","Start":"16:15","Saugzeit":"10 min","Fläche":"8.27 m²","Error":0,"Ende
      mihome-vacuum.0	2020-03-03 19:47:46.600	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":21}
      mihome-vacuum.0	2020-03-03 19:47:46.588	debug	(15538) 2. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-03-03 19:47:46.588	debug	(15538) sendMsg[1] >>> {"id":21,"method":"get_map_v1"}
      mihome-vacuum.0	2020-03-03 19:47:46.434	debug	(15538) Receive <<< {"result":[[1577275556,1577275612,14,0,0,0]],"id":20}
      mihome-vacuum.0	2020-03-03 19:47:46.405	debug	(15538) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1577275556]}
      mihome-vacuum.0	2020-03-03 19:47:46.210	debug	(15538) Receive <<< {"result":[[1577705584,1577707390,1705,27040000,0,1]],"id":19}
      mihome-vacuum.0	2020-03-03 19:47:46.204	debug	(15538) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1577705584]}
      mihome-vacuum.0	2020-03-03 19:47:46.086	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":18}
      mihome-vacuum.0	2020-03-03 19:47:46.024	debug	(15538) Receive <<< {"result":[[1577707998,1577708227,229,4305000,0,1]],"id":17}
      mihome-vacuum.0	2020-03-03 19:47:46.008	debug	(15538) 1. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-03-03 19:47:46.008	debug	(15538) sendMsg[1] >>> {"id":18,"method":"get_map_v1"}
      mihome-vacuum.0	2020-03-03 19:47:46.004	debug	(15538) sendMsg[1] >>> {"id":17,"method":"get_clean_record","params":[1577707998]}
      mihome-vacuum.0	2020-03-03 19:47:45.830	debug	(15538) Receive <<< {"result":[[1577708513,1577708756,243,3115000,0,1]],"id":16}
      mihome-vacuum.0	2020-03-03 19:47:45.803	debug	(15538) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1577708513]}
      mihome-vacuum.0	2020-03-03 19:47:45.617	debug	(15538) Receive <<< {"result":[[1581150811,1581153929,3118,44420000,0,1]],"id":15}
      mihome-vacuum.0	2020-03-03 19:47:45.602	debug	(15538) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1581150811]}
      mihome-vacuum.0	2020-03-03 19:47:45.508	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":14}
      mihome-vacuum.0	2020-03-03 19:47:45.491	debug	(15538) 0. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-03-03 19:47:45.491	debug	(15538) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
      mihome-vacuum.0	2020-03-03 19:47:45.416	debug	(15538) Receive <<< {"result":[[1582118288,1582120675,2387,39517500,0,1]],"id":13}
      mihome-vacuum.0	2020-03-03 19:47:45.401	debug	(15538) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1582118288]}
      mihome-vacuum.0	2020-03-03 19:47:45.223	debug	(15538) Receive <<< {"result":[[1583060389,1583063854,3465,54702500,0,1]],"id":12}
      mihome-vacuum.0	2020-03-03 19:47:45.201	debug	(15538) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1583060389]}
      mihome-vacuum.0	2020-03-03 19:47:45.012	debug	(15538) Receive <<< {"result":[[1583244883,1583245887,1004,17005000,0,1]],"id":11}
      mihome-vacuum.0	2020-03-03 19:47:44.999	debug	(15538) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1583244883]}
      mihome-vacuum.0	2020-03-03 19:47:44.990	debug	(15538) Receive <<< {"result":["map_upload_handler"],"id":10}
      mihome-vacuum.0	2020-03-03 19:47:44.984	debug	(15538) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
      mihome-vacuum.0	2020-03-03 19:47:44.804	debug	(15538) Receive <<< {"result":[[1583248554,1583249170,616,8267500,0,1]],"id":9}
      mihome-vacuum.0	2020-03-03 19:47:44.799	debug	(15538) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1583248554]}
      mihome-vacuum.0	2020-03-03 19:47:44.794	debug	(15538) Receive <<< {"result":"unknown_method","id":8}
      mihome-vacuum.0	2020-03-03 19:47:44.791	info	(15538) create state for carpet_mode
      mihome-vacuum.0	2020-03-03 19:47:44.791	debug	(15538) Receive <<< {"result":[{"enable":1,"current_integral":0,"current_high":0,"current_low":0,"stall_time":0}],"id":7}
      mihome-vacuum.0	2020-03-03 19:47:44.785	debug	(15538) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
      mihome-vacuum.0	2020-03-03 19:47:44.785	debug	(15538) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"}
      mihome-vacuum.0	2020-03-03 19:47:44.615	debug	(15538) Receive <<< {"result":[[1583258556,1583258934,224,7165000,0,0]],"id":6}
      mihome-vacuum.0	2020-03-03 19:47:44.598	debug	(15538) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1583258556]}
      mihome-vacuum.0	2020-03-03 19:47:44.597	debug	(15538) Receive <<< {"result":[397771,6147175000,265,[1583258556,1583248554,1583244883,1583060389,1582118288,1581150811,1577708513,1577707998,1577705584,1577275556]],"id":5}
      mihome-vacuum.0	2020-03-03 19:47:44.585	debug	(15538) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"}
      mihome-vacuum.0	2020-03-03 19:47:44.416	debug	(15538) Receive <<< {"result":[{"main_brush_work_time":398002,"side_brush_work_time":398002,"filter_work_time":182552,"sensor_dirty_time":12991}],"id":4}
      mihome-vacuum.0	2020-03-03 19:47:44.384	debug	(15538) sendMsg[1] >>> {"id":4,"method":"get_consumable"}
      mihome-vacuum.0	2020-03-03 19:47:44.238	info	(15538) set nächster Timer: Nicht verfügbar
      mihome-vacuum.0	2020-03-03 19:47:44.192	debug	(15538) Receive <<< {"result":[90],"id":3}
      mihome-vacuum.0	2020-03-03 19:47:44.185	debug	(15538) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"}
      mihome-vacuum.0	2020-03-03 19:47:44.157	error	(15538) TypeError: Cannot read property 'id' of undefined
      mihome-vacuum.0	2020-03-03 19:47:44.128	debug	(15538) 25444
      mihome-vacuum.0	2020-03-03 19:47:44.011	debug	(15538) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_003468","ap":{"ssid":"Wlan","bssid":"21:9B:C2:F5:08:F7","rssi":-50},"netif":{"l
      mihome-vacuum.0	2020-03-03 19:47:43.986	debug	(15538) Next WiFi check: 03.03 19:48
      mihome-vacuum.0	2020-03-03 19:47:43.985	debug	(15538) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
      mihome-vacuum.0	2020-03-03 19:47:43.783	info	(15538) Connected
      mihome-vacuum.0	2020-03-03 19:47:43.755	debug	(15538) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
      mihome-vacuum.0	2020-03-03 19:47:43.754	debug	(15538) Receive <<< {"result":[{"msg_ver":8,"msg_seq":3337,"state":8,"battery":100,"clean_time":224,"clean_area":7165000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}
      mihome-vacuum.0	2020-03-03 19:47:43.740	debug	(15538) sendMsg[1] >>> {"id":1,"method":"get_status"}
      mihome-vacuum.0	2020-03-03 19:47:43.732	debug	(15538) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
      mihome-vacuum.0	2020-03-03 19:47:43.731	info	(15538) connecting, This can take up to 5 minutes ...
      mihome-vacuum.0	2020-03-03 19:47:43.731	warn	(15538) Time difference between Mihome Vacuum and ioBroker: -90 sec
      mihome-vacuum.0	2020-03-03 19:47:43.730	debug	(15538) Receive <<< Helo <<< 21310020000
      mihome-vacuum.0	2020-03-03 19:47:43.720	info	(15538) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
      mihome-vacuum.0	2020-03-03 19:47:43.711	debug	(15538) server started on 0.0.0.0:53421
      mihome-vacuum.0	2020-03-03 19:47:43.707	info	(15538) Disconnect
      mihome-vacuum.0	2020-03-03 19:47:43.703	info	(15538) Create state clean_home for controlling by cloud adapter
      mihome-vacuum.0	2020-03-03 19:47:43.703	info	(15538) Expert mode enabled, states created
      mihome-vacuum.0	2020-03-03 19:47:43.696	debug	(15538) load Map creator... true
      mihome-vacuum.0	2020-03-03 19:47:43.669	info	(15538) starting. Version 2.0.8 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
      mihome-vacuum.0	2020-03-03 19:47:39.709	info	(10066) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      mihome-vacuum.0	2020-03-03 19:47:39.708	info	(10066) terminating
      mihome-vacuum.0	2020-03-03 19:47:39.708	info	(10066) Got terminate signal TERMINATE_YOURSELF
      Nach Neustart des Adapters.
        dirkhe Developer @jensus11 last edited by
        @jensus11 Hmmm, ich glaube, da muss @Meistertr meistertmal einen Blick drauf werfen. Aber das ist aktuell der Adapter von mir, nehme zur Sicherheit hat 2.0.7 vom offiziellen Community github.
          Hatte 2.0.6 dann 2.0.7 und jetzt die von dir. Bei den anderen ging das auch nicht.
          Meistertr 1 Reply Last reply Reply Quote 0
          • Meistertr
            Meistertr Developer @jensus11 last edited by
            @jensus11 hast du valetudo in der config angeklickt? auf jedenfall hast du Xiaomi map mit angeklickt, was nicht sollte wenn du valetudo installiert hast
              So habe ich das eingestellt.
                dirkhe Developer @Meistertr last edited by
                @Meistertr sagte in Test Adapter mihome-vacuum v2.0.x:
                Sollten wir dann da Radio Buttons von machen?
                • Meistertr
                  Meistertr Developer @dirkhe last edited by
                  @dirkhe jep wollte da noch ein deselect mit einbauen das nur eins geht
                    dehein2 last edited by
                    Hallo nochmal,
                    ich habe nun Valetudo installiert und das webinterface funktioniert. Leider klappt die Bedienung über iobroker nicht. Es hat kurz funktioniert nun aber wieder nicht. Weder reagiert der Roboter zuverflässig auf Tastendrücke noch bekomme ich eine Karte angezeigt. Hier einmal ein Log:
                    mihome-vacuum.0	2020-03-03 21:32:51.728	debug	(9962) requesting params every: 60 Sec
                    mihome-vacuum.0	2020-03-03 21:32:43.764	info	(9962) should trigger cleaning all null, but is currently active. Add to queue
                    mihome-vacuum.0	2020-03-03 21:32:43.759	debug	(9962) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-03 21:32:43.758	debug	(9962) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1583267563751,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581065963877}
                    mihome-vacuum.0	2020-03-03 21:32:42.738	debug	(9962) stateChange mihome-vacuum.0.control.resumeRoomClean {"val":true,"ack":false,"ts":1583267562734,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1582918439862}
                    mihome-vacuum.0	2020-03-03 21:32:39.365	debug	(9962) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1583267559362,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066074377}
                    mihome-vacuum.0	2020-03-03 21:32:33.774	debug	(9962) no answer for get_consumable(id:19) received, giving up
                    mihome-vacuum.0	2020-03-03 21:32:33.575	warn	(9962) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
                    mihome-vacuum.0	2020-03-03 21:32:33.574	debug	(9962) no answer for miIO.info(id:18) received, giving up
                    mihome-vacuum.0	2020-03-03 21:32:33.572	debug	(9962) no answer for get_status(id:17) received, giving up
                    mihome-vacuum.0	2020-03-03 21:32:30.061	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267550058,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
                    mihome-vacuum.0	2020-03-03 21:32:29.391	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267549384,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
                    mihome-vacuum.0	2020-03-03 21:32:28.387	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267548380,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
                    mihome-vacuum.0	2020-03-03 21:32:24.506	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267544500,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
                    mihome-vacuum.0	2020-03-03 21:32:23.564	debug	(9962) no answer for get_status(id:16) received, giving up
                    mihome-vacuum.0	2020-03-03 21:32:22.574	debug	(9962) stateChange mihome-vacuum.0.control.resumeRoomClean {"val":true,"ack":false,"ts":1583267542571,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1582918439862}
                    mihome-vacuum.0	2020-03-03 21:32:18.567	debug	(9962) requesting params every: 60 Sec
                    mihome-vacuum.0	2020-03-03 21:32:18.565	info	(9962) Connected
                    mihome-vacuum.0	2020-03-03 21:32:18.561	info	(9962) Disconnect
                    mihome-vacuum.0	2020-03-03 21:32:16.356	debug	(9962) no answer for get_status(id:15) received, giving up
                    mihome-vacuum.0	2020-03-03 21:32:14.354	debug	(9962) no answer for undefined(id:14) received, giving up
                    mihome-vacuum.0	2020-03-03 21:32:09.741	debug	(9962) no answer for get_room_mapping(id:13) received, giving up
                    mihome-vacuum.0	2020-03-03 21:32:09.730	debug	(9962) no answer for get_carpet_mode(id:12) received, giving up
                    mihome-vacuum.0	2020-03-03 21:32:09.679	debug	(9962) system.adapter.admin.0: logging true
                    mihome-vacuum.0	2020-03-03 21:32:08.412	debug	(9962) CLEAN_LOGGING[{"Datum":"3.3","Start":"21:30","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"3.3","Start":"21:16","Saugzeit":"3 min","Fläche":"4.38 m²","Error":0,"Ende":fa
                    mihome-vacuum.0	2020-03-03 21:32:08.210	debug	(9962) no answer for get_clean_record(id:11) received, giving up
                    mihome-vacuum.0	2020-03-03 21:32:06.558	info	(9962) should trigger cleaning all null, but is currently active. Add to queue
                    mihome-vacuum.0	2020-03-03 21:32:06.555	debug	(9962) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-03 21:32:06.554	debug	(9962) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1583267526551,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581065963877}
                    mihome-vacuum.0	2020-03-03 21:32:03.410	debug	(9962) CLEAN_LOGGING[{"Datum":"3.3","Start":"21:30","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"3.3","Start":"21:16","Saugzeit":"3 min","Fläche":"4.38 m²","Error":0,"Ende":fa
                    mihome-vacuum.0	2020-03-03 21:31:59.347	info	(9962) trigger cleaning all null
                    VG
                      root_ last edited by root_
                      Hab seit dem update auf die neusste Version auch so 1-2 Probleme.
                      Bei mir startet der Sauger über ein js. das hat heut nicht mehr funktioniert.
                      9Uhr sollte er loslegen:
                      mihome-vacuum.0	2020-03-04 09:00:00.029	info	(13716) trigger cleaning all null
                      Das js löst den mihome-vacuum.0.control.start button aus.
                      Jetzt hab ich den Button per hand ausgelöst und da ging es dann.
                      Zum anderen bekomme ich diese Meldungen:
                      mihome-vacuum.0	2020-03-04 09:37:13.736	error	(13716) Error: IndexSizeError: The source width is 0.
                      mihome-vacuum.0	2020-03-04 09:35:53.774	error	(13716) Error: IndexSizeError: The source width is 0.
                      mihome-vacuum.0	2020-03-04 09:34:27.812	error	(13716) Error: IndexSizeError: The source width is 0.
                      mihome-vacuum.0	2020-03-04 09:34:24.708	error	(13716) Error: IndexSizeError: The source width is 0.
                      mihome-vacuum.0	2020-03-04 09:34:20.458	error	(13716) Error: IndexSizeError: The source width is 0.
                      mihome-vacuum.0	2020-03-04 09:34:17.147	error	(13716) Error: IndexSizeError: The source width is 0.
                      mihome-vacuum.0	2020-03-04 09:34:13.814	error	(13716) Error: IndexSizeError: The source width is 0.
                      mihome-vacuum.0	2020-03-04 09:34:10.498	error	(13716) Error: IndexSizeError: The source width is 0.
                      mihome-vacuum.0	2020-03-04 09:34:07.335	error	(13716) Error: IndexSizeError: The source width is 0.
                      Es handelt sich um einen Gen1 mit Xiaomi FW und Cloudanbindung im Adapter.
                        dirkhe Developer @root_ last edited by
                        @root_ bitte Mal loglevel auf debug setzen.
                        Wie triggerst du denn per ja?
                          dirkhe Developer @dehein2 last edited by
                          @dehein2 der Roboter spricht nicht mit dem Adapter. IP und token richtig?
                            root_ @dirkhe last edited by root_
                            @dirkhe
                            Genau, per true. Ging bis jetzt 1a.
                            Ob es notwendig ist bei einem Button weiss ich nicht aber ich setze ihn nach 1000ms wieder auf false.
                            • Diginix
                              Diginix last edited by Diginix
                              @dirkhe @Meistertr
                              Mein 1S reagiert mit 2.0.7 und 2.0.8 auf "Home" nicht.
                              Zwischen "Pause" und "Find Me" habe ich immer wieder den "Home" Button im Admin betätigt. Der Sauger stand pausiert im Raum rum, also nicht im Dock. In der MiHome App hat der "Dock" Button dann sofort funktioniert.
                              Hier das Debug Log dazu:
                              2020-03-04 19:13:03.749  - info: mihome-vacuum.0 (20921) starting. Version 2.0.8 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                              2020-03-04 19:13:03.846  - debug: mihome-vacuum.0 (20921) load Map creator... true
                              2020-03-04 19:13:03.850  - debug: mihome-vacuum.0 (20921) Xiaomi Cloud: Logging in
                              2020-03-04 19:13:03.868  - info: mihome-vacuum.0 (20921) Expert mode enabled, states created
                              2020-03-04 19:13:03.870  - info: mihome-vacuum.0 (20921) Create state clean_home for controlling by cloud adapter
                              2020-03-04 19:13:03.884  - info: mihome-vacuum.0 (20921) Disconnect
                              2020-03-04 19:13:03.896  - debug: mihome-vacuum.0 (20921) server started on 0.0.0.0:53422
                              2020-03-04 19:13:03.968  - info: mihome-vacuum.0 (20921) change states from State control.fan_power
                              2020-03-04 19:13:03.971  - info: mihome-vacuum.0 (20921) New generation or new fw(3.5.4,0948) detected, create new states goto and zoneclean
                              2020-03-04 19:13:04.428  - info: mihome-vacuum.0 (20921) set nächster Timer: Nicht verfügbar
                              2020-03-04 19:13:06.831  - debug: mihome-vacuum.0 (20921) Xiaomi Cloud: Login successful
                              2020-03-04 19:13:13.677  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.find {"val":true,"ack":false,"ts":1583345593672,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1573675095947}
                              2020-03-04 19:13:13.684  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":1,"method":"find_me"}
                              2020-03-04 19:13:18.687  - debug: mihome-vacuum.0 (20921) sendMsg[2] >>> {"id":1,"method":"find_me"}
                              2020-03-04 19:13:23.690  - debug: mihome-vacuum.0 (20921) sendMsg[3] >>> {"id":1,"method":"find_me"}
                              2020-03-04 19:13:23.887  - info: mihome-vacuum.0 (20921) Disconnect
                              2020-03-04 19:13:23.892  - debug: mihome-vacuum.0 (20921) Receive <<< Helo <<< 21310020000000000f92f23c5e5fefc3ffffffffffffffffffffffffffffffff
                              2020-03-04 19:13:23.894  - info: mihome-vacuum.0 (20921) connecting, This can take up to 5 minutes ...
                              2020-03-04 19:13:23.896  - debug: mihome-vacuum.0 (20921) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                              2020-03-04 19:13:23.904  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":2,"method":"get_status"}
                              2020-03-04 19:13:23.915  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[{"msg_ver":1,"msg_seq":5745,"state":3,"battery":81,"clean_time":531,"clean_area":9650000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"fan_power":104,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":2}
                              2020-03-04 19:13:23.918  - debug: mihome-vacuum.0 (20921) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                              2020-03-04 19:13:23.922  - info: mihome-vacuum.0 (20921) Connected
                              2020-03-04 19:13:24.125  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":3,"method":"miIO.info"}
                              2020-03-04 19:13:24.133  - debug: mihome-vacuum.0 (20921) Next WiFi check: 04.03 19:14
                              2020-03-04 19:13:24.136  - debug: mihome-vacuum.0 (20921) Receive <<< {"partner_id":"","id":3,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.4_0948","ap":{"ssid":"sparky","bssid":"CC:CE:1E:C2:11:17","rssi":-45},"netif":{"localIp":"192.168.2.122","mask":"255.255.255.0","gw":"192.168.2.4"},"model":"roborock.vacuum.m1s","mac":"50:EC:50:12:37:15","token":"59414c416c4246694b3048764435577a","life":55952}}
                              2020-03-04 19:13:24.323  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":4,"method":"get_sound_volume"}
                              2020-03-04 19:13:24.332  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[100],"id":4}
                              2020-03-04 19:13:24.525  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":5,"method":"get_consumable"}
                              2020-03-04 19:13:24.534  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[{"main_brush_work_time":75966,"side_brush_work_time":75966,"filter_work_time":75966,"sensor_dirty_time":74777}],"id":5}
                              2020-03-04 19:13:24.724  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":6,"method":"get_clean_summary"}
                              2020-03-04 19:13:24.733  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[74777,1474542500,91,[1583340758,1583339903,1583225954,1583180962,1583180261,1582735711,1582735619,1582735055,1582617128,1582571726,1582570856,1582570281,1582566875,1581790042,1581761962,1581629504,1581322645,1581244828,1581244266,1580840290]],"id":6}
                              2020-03-04 19:13:24.737  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":7,"method":"get_clean_record","params":[1583340758]}
                              2020-03-04 19:13:24.749  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1583340758,1583341334,531,9650000,0,1,2,3]],"id":7}
                              2020-03-04 19:13:24.924  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":8,"method":"get_carpet_mode"}
                              2020-03-04 19:13:24.925  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":9,"method":"get_room_mapping"}
                              2020-03-04 19:13:24.934  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":8}
                              2020-03-04 19:13:24.936  - info: mihome-vacuum.0 (20921) create state for carpet_mode
                              2020-03-04 19:13:24.939  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[16,"277001004452"],[17,"277001004448"],[18,"277001004451"],[19,"277001004453"],[20,"277001118019"],[21,"277001004449"]],"id":9}
                              2020-03-04 19:13:24.943  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":10,"method":"get_clean_record","params":[1583339903]}
                              2020-03-04 19:13:24.953  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1583339903,1583340754,829,17177500,0,1,2,3]],"id":10}
                              2020-03-04 19:13:25.124  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":11,"method":"get_map_v1"}
                              2020-03-04 19:13:25.132  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":["retry"],"id":11}
                              2020-03-04 19:13:25.146  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1583225954]}
                              2020-03-04 19:13:25.155  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1583225954,1583227596,1642,34910000,0,1,2,3]],"id":12}
                              2020-03-04 19:13:25.349  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1583180962]}
                              2020-03-04 19:13:25.357  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1583180962,1583181066,104,1735000,0,1,2,3]],"id":13}
                              2020-03-04 19:13:25.551  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":14,"method":"get_clean_record","params":[1583180261]}
                              2020-03-04 19:13:25.562  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1583180261,1583180956,695,14795000,0,1,2,3]],"id":14}
                              2020-03-04 19:13:25.636  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":15,"method":"get_map_v1"}
                              2020-03-04 19:13:25.636  - debug: mihome-vacuum.0 (20921) 0. Mappointer_nomap___retry
                              2020-03-04 19:13:25.669  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":["retry"],"id":15}
                              2020-03-04 19:13:25.755  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1582735711]}
                              2020-03-04 19:13:25.766  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582735711,1582736153,442,9622500,0,1,2,3]],"id":16}
                              2020-03-04 19:13:25.957  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":17,"method":"get_clean_record","params":[1582735619]}
                              2020-03-04 19:13:25.966  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582735619,1582735640,18,0,0,0,2,1]],"id":17}
                              2020-03-04 19:13:26.159  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1582735055]}
                              2020-03-04 19:13:26.168  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582735055,1582735619,504,9577500,0,0,2,3]],"id":18}
                              2020-03-04 19:13:26.171  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":19,"method":"get_map_v1"}
                              2020-03-04 19:13:26.172  - debug: mihome-vacuum.0 (20921) 1. Mappointer_nomap___retry
                              2020-03-04 19:13:26.193  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":["ruby2%2F261288508%2F17"],"id":19}
                              2020-03-04 19:13:26.195  - debug: mihome-vacuum.0 (20921) Mappointer_updated
                              2020-03-04 19:13:26.197  - debug: mihome-vacuum.0 (20921) update_Map Mimap enabled
                              2020-03-04 19:13:26.198  - debug: mihome-vacuum.0 (20921) update_Map need new mapurl
                              2020-03-04 19:13:26.362  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1582617128]}
                              2020-03-04 19:13:26.370  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582617128,1582618883,1755,35097500,0,1,2,3]],"id":20}
                              2020-03-04 19:13:26.563  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":21,"method":"get_clean_record","params":[1582571726]}
                              2020-03-04 19:13:26.571  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582571726,1582571734,6,0,0,0,2,1]],"id":21}
                              2020-03-04 19:13:26.766  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1582570856]}
                              2020-03-04 19:13:26.773  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582570856,1582571680,802,16392500,0,1,2,3]],"id":22}
                              2020-03-04 19:13:26.968  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1582570281]}
                              2020-03-04 19:13:26.975  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582570281,1582570721,13,240000,0,0,2,3]],"id":23}
                              2020-03-04 19:13:27.171  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":24,"method":"get_clean_record","params":[1582566875]}
                              2020-03-04 19:13:27.180  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582566875,1582567670,795,16565000,0,1,2,3]],"id":24}
                              2020-03-04 19:13:27.375  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":25,"method":"get_clean_record","params":[1581790042]}
                              2020-03-04 19:13:27.384  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1581790042,1581790663,621,9707500,0,1,2,3]],"id":25}
                              2020-03-04 19:13:27.579  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1581761962]}
                              2020-03-04 19:13:27.588  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1581761962,1581765162,3200,68240000,0,1,2,3]],"id":26}
                              2020-03-04 19:13:27.783  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1581629504]}
                              2020-03-04 19:13:27.792  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1581629504,1581629795,291,9602500,0,0,2,3]],"id":27}
                              2020-03-04 19:13:27.986  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":28,"method":"get_clean_record","params":[1581322645]}
                              2020-03-04 19:13:27.993  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1581322645,1581323442,797,17057500,0,1,2,3]],"id":28}
                              2020-03-04 19:13:28.189  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1581244828]}
                              2020-03-04 19:13:28.199  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1581244828,1581247475,2647,51210000,0,1,2,3]],"id":29}
                              2020-03-04 19:13:28.395  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":30,"method":"get_clean_record","params":[1581244266]}
                              2020-03-04 19:13:28.404  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1581244266,1581244810,544,9777500,0,1,2,3]],"id":30}
                              2020-03-04 19:13:28.599  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":31,"method":"get_clean_record","params":[1580840290]}
                              2020-03-04 19:13:28.606  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1580840290,1580840773,483,9737500,0,1,2,3]],"id":31}
                              2020-03-04 19:13:28.690  - debug: mihome-vacuum.0 (20921) no answer for find_me(id:1) received, giving up
                              2020-03-04 19:13:28.801  - debug: mihome-vacuum.0 (20921) CLEAN_LOGGING[{"Datum":"4.3","Start":"17:52","Saugzeit":"9 min","Fläche":"9.65 m²","Error":0,"Ende":true},{"Datum":"4.3","Start":"17:38","Saugzeit":"14 min","Fläche":"17.18 m²","Error":0,"Ende":true},{"Datum":"3.3","Start":"09:59","Saugzeit":"27 min","Fläche":"34.91 m²","Error":0,"Ende":true},{"Datum":"2.3","Start":"21:29","Saugzeit":"2 min","Fläche":"1.74 m²","Error":0,"Ende":true},{"Datum":"2.3","Start":"21:17","Saugzeit":"12 min","Fläche":"14.8 m²","Error":0,"Ende":true},{"Datum":"26.2","Start":"17:48","Saugzeit":"7 min","Fläche":"9.62 m²","Error":0,"Ende":true},{"Datum":"26.2","Start":"17:46","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"26.2","Start":"17:37","Saugzeit":"8 min","Fläche":"9.58 m²","Error":0,"Ende":false},{"Datum":"25.2","Start":"08:52","Saugzeit":"29 min","Fläche":"35.1 m²","Error":0,"Ende":true},{"Datum":"24.2","Start":"20:15","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"24.2","Start":"20:00","Saugzeit":"13 min","Fläche":"16.39 m²","Error":0,"Ende":true},{"Datum":"24.2","Start":"19:51","Saugzeit":"0 min","Fläche":"0.24 m²","Error":0,"Ende":false},{"Datum":"24.2","Start":"18:54","Saugzeit":"13 min","Fläche":"16.57 m²","Error":0,"Ende":true},{"Datum":"15.2","Start":"19:07","Saugzeit":"10 min","Fläche":"9.71 m²","Error":0,"Ende":true},{"Datum":"15.2","Start":"11:19","Saugzeit":"53 min","Fläche":"68.24 m²","Error":0,"Ende":true},{"Datum":"13.2","Start":"22:31","Saugzeit":"5 min","Fläche":"9.6 m²","Error":0,"Ende":false},{"Datum":"10.2","Start":"09:17","Saugzeit":"13 min","Fläche":"17.06 m²","Error":0,"Ende":true},{"Datum":"9.2","Start":"11:40","Saugzeit":"44 min","Fläche":"51.21 m²","Error":0,"Ende":true},{"Datum":"9.2","Start":"11:31","Saugzeit":"9 min","Fläche":"9.78 m²","Error":0,"Ende":true},{"Datum":"4.2","Start":"19:18","Saugzeit":"8 min","Fläche":"9.74 m²","Error":0,"Ende":true}]
                              2020-03-04 19:13:30.421  - debug: mihome-vacuum.0 (20921) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/ruby2/261288508/17?Expires=1583347410000&GalaxyAccessKeyId=5271733786445&Signature=rnfZhuZbNi6QHn/Vkf7tvjbAqQE=
                              2020-03-04 19:13:30.422  - debug: mihome-vacuum.0 (20921) update_Map got new expires:1583347410
                              2020-03-04 19:13:30.422  - debug: mihome-vacuum.0 (20921) update_Map got new time:1583345606
                              2020-03-04 19:13:32.381  - debug: mihome-vacuum.0 (20921) 25653
                              2020-03-04 19:13:35.515  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.find {"val":true,"ack":false,"ts":1583345615511,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1573675095947}
                              2020-03-04 19:13:35.517  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":32,"method":"find_me"}
                              2020-03-04 19:13:35.581  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":["ok"],"id":32}
                              2020-03-04 19:13:38.489  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583345618484,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575408936787}
                              2020-03-04 19:13:43.894  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":33,"method":"get_status"}
                              2020-03-04 19:13:43.907  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[{"msg_ver":1,"msg_seq":5746,"state":3,"battery":81,"clean_time":531,"clean_area":9650000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"fan_power":104,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":33}
                              2020-03-04 19:13:44.860  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1583345624788,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1573587802676}
                              2020-03-04 19:13:44.862  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":34,"method":"app_pause"}
                              2020-03-04 19:13:44.868  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":["ok"],"id":34}
                              2020-03-04 19:13:47.722  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583345627719,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575408936787}
                              2020-03-04 19:13:49.408  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.find {"val":true,"ack":false,"ts":1583345629404,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1573675095947}
                              2020-03-04 19:13:49.409  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":35,"method":"find_me"}
                              2020-03-04 19:13:49.415  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":["ok"],"id":35}
                              2020-03-04 19:13:51.438  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583345631434,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575408936787}
                              2020-03-04 19:13:52.192  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583345632186,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575408936787}
                              2020-03-04 19:13:53.210  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583345633204,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575408936787}
                              2020-03-04 19:13:53.664  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583345633658,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575408936787}
                              2020-03-04 19:14:00.173  - info: mihome-vacuum.0 (20921) Got terminate signal TERMINATE_YOURSELF
                              Hier die History für den Button "Home":
                              true	true	mihome-vacuum.0	2020-03-04 19:13:53.665
                              true	false	admin.0	2020-03-04 19:13:53.658
                              true	true	mihome-vacuum.0	2020-03-04 19:13:53.213
                              true	false	admin.0	2020-03-04 19:13:53.204
                              true	true	mihome-vacuum.0	2020-03-04 19:13:52.194
                              true	false	admin.0	2020-03-04 19:13:52.186
                              true	true	mihome-vacuum.0	2020-03-04 19:13:51.440
                              true	false	admin.0	2020-03-04 19:13:51.434
                              true	true	mihome-vacuum.0	2020-03-04 19:13:47.726
                              true	false	admin.0	2020-03-04 19:13:47.719
                              true	true	mihome-vacuum.0	2020-03-04 19:13:38.491
                              true	false	admin.0	2020-03-04 19:13:38.484
                                dirkhe Developer @Diginix last edited by
                                @Diginix Alles klar, Fehler gefunden. Ich löse bei home nur aus, wnn er gerade aktiv am Reinigen ist. Flasche Annahme, nehme ich gleich raus und melde mich
                                  @root_ Also ich habe jetzt mal geschaut. Einen Button per true zu triggern funktioniert. ich habe dieselbe funktion hinter start und clean_home gepackt und damit akzeptierte start auch ein false, mit dem Ergebniss, dass sofort wieder angehalten wurde. Ist gefixt und wird gleich hochgeladen. Für den IndexSizeError brauche ich ein debug log
                                    dirkhe Developer last edited by
                                    So für meine Version gibt es jetzt die 2.0.8-RC2
                                    • Meistertr
                                      @dirkhe machs doch direkt alles in der hauptversion
                                      haselchen D 2 Replies Last reply Reply Quote 0
                                      • haselchen
                                        haselchen Most Active @Meistertr last edited by
                                        @Meistertr @dirkhe
                                        Das wäre auch meine Bitte.
                                        1 Version, die man im Admin oder auf Github bekommt.
                                        Man steigt schon leider nicht mehr durch, wer von euch beiden was macht und woher man es beziehen kann.
                                          @Meistertr Ich hatte ja gedacht, du wolltest die erstmal für dich testen, weil ich ich ja doch einiges umgebaut habe. Jetzt bin ich davon ausgegangen, dass du gerade keine Zeit hast und da wollte ich dich auch nicht drängen...
                                          Jetzt haben aber schon Leute hier ohne Aufforderung getestet (was ich gut finde) und es scheint ja zu funktionieren. Wenn es aber doch noch zu Problemen geführt hätte, könnten wir vlt. nicht so schnell zurück.
                                          Aber ich kann meine Version gerne mergen, bin gerade dabei, den aktuellen Raum-channel einen Status zu geben, ob gerade gereinigt oder in Queue..
                                          • Diginix
                                            Meine Frage nach einem finalen verzögerten Kartenupdate nachdem der Sauger im Dock parkt, blieb bisher ja unbeantwortet.
                                            Vllt kann das ja noch in das Update einfließen.
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            491829
